[v2] I2C: ls1043a, ls1046a: enable SYS_I2C_MXC
This enables SYS_I2C_MXC to fix a bug that failed to boot from sd card with image u-boot-with-spl-pbl.bin
Signed-off-by: Biwen Li biwen.li@nxp.com --- Change in v2: - fix copyright
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++-- include/configs/ls1043a_common.h | 3 +-- include/configs/ls1046a_common.h | 1 - 3 files changed, 3 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index b256391..ac53d64 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -74,7 +74,7 @@ config ARCH_LS1043A select SYS_FSL_HAS_DDR4 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F - select SYS_I2C_MXC if !DM_I2C + select SYS_I2C_MXC select SYS_I2C_MXC_I2C1 if !DM_I2C select SYS_I2C_MXC_I2C2 if !DM_I2C select SYS_I2C_MXC_I2C3 if !DM_I2C @@ -107,7 +107,7 @@ config ARCH_LS1046A select SYS_FSL_SRDS_2 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F - select SYS_I2C_MXC if !DM_I2C + select SYS_I2C_MXC select SYS_I2C_MXC_I2C1 if !DM_I2C select SYS_I2C_MXC_I2C2 if !DM_I2C select SYS_I2C_MXC_I2C3 if !DM_I2C diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 985f404..7026814 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -1,7 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright (C) 2015 Freescale Semiconductor - * Copyright (C) 2019 NXP + * Copyright 2019-2020 NXP */
#ifndef __LS1043A_COMMON_H @@ -144,7 +144,6 @@ /* I2C */ #ifndef CONFIG_DM_I2C #define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ #define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index e80c299..1748422 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -129,7 +129,6 @@ /* I2C */ #ifndef CONFIG_DM_I2C #define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ #define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */
Biwen Li
