[PATCH 0/6] efi_loader: fix efi_dp_from_file()
efi_dp_from_file() has multiple issues:
* When called from efi_dp_from_name() we miss to append the filename for non-block devices. * When called from efi_dp_from_name we invoke efi_dp_from_part() twice. * expand_media_path() could be simplified by using efi_dp_from_file to prepend the device path of the boot device.
This can be avoided by passing a device path to efi_dp_from_file() instead of a block device descriptor and a partition number.
efi_dp_from_name() has duplicate code to replace slash by backslash. path_to_uefi() called by efi_dp_from_file() already does this.
Heinrich Schuchardt (6): efi_loader: avoid #ifdef in efi_dp_from_name() efi_loader: duplicate code in efi_dp_from_name efi_loader: clean up efi_dp_from_file efi_loader: error code efi_dp_from_name() efi_loader: simplify efi_dp_from_name() efi_loader: fix efi_dp_from_file()
cmd/bootefi.c | 2 +- include/efi_loader.h | 2 +- lib/efi_loader/efi_bootmgr.c | 13 ++--- lib/efi_loader/efi_device_path.c | 91 ++++++++++---------------------- 4 files changed, 36 insertions(+), 72 deletions(-)
According to our coding style guide #ifdef should be avoided. Use IS_ENABLED() instead.
Sort string comparisons alphabetically.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_device_path.c | 20 ++++++++------------ 1 file changed, 8 insertions(+), 12 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 20ad948498..a6a6ef0d6c 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1079,8 +1079,7 @@ struct efi_device_path *efi_dp_from_uart(void) return buf; }
-#ifdef CONFIG_NETDEVICES -struct efi_device_path *efi_dp_from_eth(void) +struct efi_device_path __maybe_unused *efi_dp_from_eth(void) { void *buf, *start; unsigned dpsize = 0; @@ -1099,7 +1098,6 @@ struct efi_device_path *efi_dp_from_eth(void)
return start; } -#endif
/* Construct a device-path for memory-mapped image */ struct efi_device_path *efi_dp_from_mem(uint32_t memory_type, @@ -1195,15 +1193,7 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, if (path && !file) return EFI_INVALID_PARAMETER;
- if (!strcmp(dev, "Net")) { -#ifdef CONFIG_NETDEVICES - if (device) - *device = efi_dp_from_eth(); -#endif - } else if (!strcmp(dev, "Uart")) { - if (device) - *device = efi_dp_from_uart(); - } else if (!strcmp(dev, "Mem") || !strcmp(dev, "hostfs")) { + if (!strcmp(dev, "Mem") || !strcmp(dev, "hostfs")) { /* loadm command and semihosting */ efi_get_image_parameters(&image_addr, &image_size);
@@ -1211,6 +1201,12 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, *device = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, (uintptr_t)image_addr, image_size); + } else if (IS_ENABLED(CONFIG_NETDEVICES) && !strcmp(dev, "Net")) { + if (device) + *device = efi_dp_from_eth(); + } else if (!strcmp(dev, "Uart")) { + if (device) + *device = efi_dp_from_uart(); } else { part = blk_get_device_part_str(dev, devnr, &desc, &fs_partition, 1);
Hi Heinrich,
Looking at this function can we clean it up since you are touching it already?
I think it would look nicer if you defined a local variable of struct efi_device_path * and always assign it in the if cases.
Then at the bottom of the function, we could store the ptr value if that exists. While at it the 'if (!*file)' seems to be misplaced.
Regards /Ilias
On Sat, 13 May 2023 at 11:48, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
return start;
} -#endif
if (device)
-#endif
if (device)
if (device)
if (device)
-- 2.39.2
On 5/15/23 09:37, Ilias Apalodimas wrote:
Hi Heinrich,
Please, have a look at another patch in the series: "efi_loader: simplify efi_dp_from_name()"
"if (!*file)" is not touched in this patch.
We cannot check the return value of efi_dp_from_file() before calling the function. We have checked that that parameter file is non-null above. Could you, please, describe what feels wrong for you.
Best regards
Heinrich
Regards /Ilias
return start;
} -#endif
if (device)
-#endif
if (device)
if (device)
if (device)
-- 2.39.2
Hi Heinrich
On Mon, 15 May 2023 at 10:54, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
Hi Heinrich,
Ah haven't got that far. Yes, this does exactly what I asked, thanks!
Nothing, I misread that, if (!file) is already checked on the top of the function which is correct
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Best regards
Heinrich
Regards /Ilias
return start;
} -#endif
if (device)
-#endif
if (device)
if (device)
if (device)
-- 2.39.2
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_device_path.c | 14 +------------- 1 file changed, 1 insertion(+), 13 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index a6a6ef0d6c..c4f0cc23a0 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1187,8 +1187,6 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, size_t image_size; void *image_addr; int part = 0; - char *filename; - char *s;
if (path && !file) return EFI_INVALID_PARAMETER; @@ -1220,17 +1218,7 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, if (!path) return EFI_SUCCESS;
- filename = calloc(1, strlen(path) + 1); - if (!filename) - return EFI_OUT_OF_RESOURCES; - - sprintf(filename, "%s", path); - /* DOS style file path: */ - s = filename; - while ((s = strchr(s, '/'))) - *s++ = '\'; - *file = efi_dp_from_file(desc, part, filename); - free(filename); + *file = efi_dp_from_file(desc, part, path);
if (!*file) return EFI_INVALID_PARAMETER;
char *filename;
char *s; if (path && !file) return EFI_INVALID_PARAMETER;
if (!filename)
s = filename;
*s++ = '\\';
free(filename);
*file = efi_dp_from_file(desc, part, path); if (!*file) return EFI_INVALID_PARAMETER;
-- 2.39.2
* Improve variable name usage: Use pos instead of buf to indicate the current position in a buffer. * Avoid double assignment in a single code line.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_device_path.c | 16 +++++++++------- 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index c4f0cc23a0..0f58082141 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1022,7 +1022,7 @@ struct efi_device_path *efi_dp_from_file(struct blk_desc *desc, int part, const char *path) { struct efi_device_path_file_path *fp; - void *buf, *start; + void *buf, *pos; size_t dpsize = 0, fpsize;
if (desc) @@ -1035,26 +1035,28 @@ struct efi_device_path *efi_dp_from_file(struct blk_desc *desc, int part,
dpsize += fpsize;
- start = buf = efi_alloc(dpsize + sizeof(END)); + buf = efi_alloc(dpsize + sizeof(END)); if (!buf) return NULL;
if (desc) - buf = dp_part_fill(buf, desc, part); + pos = dp_part_fill(buf, desc, part); + else + pos = buf;
/* add file-path: */ if (*path) { - fp = buf; + fp = pos; fp->dp.type = DEVICE_PATH_TYPE_MEDIA_DEVICE; fp->dp.sub_type = DEVICE_PATH_SUB_TYPE_FILE_PATH; fp->dp.length = (u16)fpsize; path_to_uefi(fp->str, path); - buf += fpsize; + pos += fpsize; }
- *((struct efi_device_path *)buf) = END; + memcpy(pos, &END, sizeof(END));
- return start; + return buf; }
Hi Heinrich
- Improve variable name usage: Use pos instead of buf to indicate the current position in a buffer.
- Avoid double assignment in a single code line.
void *buf, *start;
void *buf, *pos; size_t dpsize = 0, fpsize; if (desc)
dpsize += fpsize;
buf = efi_alloc(dpsize + sizeof(END)); if (!buf) return NULL; if (desc)
else
pos = buf; /* add file-path: */ if (*path) {
fp = buf;
buf += fpsize;
pos += fpsize; }
return start;
return buf;
2.39.2
Use EFI_OUT_OF_RESOURCES if the device path cannot be constructed.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_device_path.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 0f58082141..1436244f99 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1223,7 +1223,7 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, *file = efi_dp_from_file(desc, part, path);
if (!*file) - return EFI_INVALID_PARAMETER; + return EFI_OUT_OF_RESOURCES;
return EFI_SUCCESS; }
if (!*file)
return EFI_OUT_OF_RESOURCES; return EFI_SUCCESS;
2.39.2
Don't do the same check and assignment in multiple places.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_device_path.c | 18 ++++++++---------- 1 file changed, 8 insertions(+), 10 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 1436244f99..a9b0ea4015 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1185,6 +1185,7 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, struct efi_device_path **file) { struct blk_desc *desc = NULL; + struct efi_device_path *dp; struct disk_partition fs_partition; size_t image_size; void *image_addr; @@ -1197,25 +1198,22 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, /* loadm command and semihosting */ efi_get_image_parameters(&image_addr, &image_size);
- if (device) - *device = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, - (uintptr_t)image_addr, - image_size); + dp = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, + (uintptr_t)image_addr, image_size); } else if (IS_ENABLED(CONFIG_NETDEVICES) && !strcmp(dev, "Net")) { - if (device) - *device = efi_dp_from_eth(); + dp = efi_dp_from_eth(); } else if (!strcmp(dev, "Uart")) { - if (device) - *device = efi_dp_from_uart(); + dp = efi_dp_from_uart(); } else { part = blk_get_device_part_str(dev, devnr, &desc, &fs_partition, 1); if (part < 0 || !desc) return EFI_INVALID_PARAMETER;
- if (device) - *device = efi_dp_from_part(desc, part); + dp = efi_dp_from_part(desc, part); } + if (device) + *device = dp;
if (device)
image_size);
if (device)
if (device)
if (device)
if (device)
*device = dp; if (!path) return EFI_SUCCESS;
-- 2.39.2
* When called from efi_dp_from_name() we miss to append the filename for non-block devices. * expand_media_path() could be simplified by using efi_dp_from_file to prepend the device path of the boot device.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- cmd/bootefi.c | 2 +- include/efi_loader.h | 2 +- lib/efi_loader/efi_bootmgr.c | 13 ++++------- lib/efi_loader/efi_device_path.c | 39 +++++++++----------------------- 4 files changed, 18 insertions(+), 38 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 8aa15a64c8..5c0afec154 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -589,7 +589,7 @@ static efi_status_t bootefi_test_prepare if (!bootefi_device_path) return EFI_OUT_OF_RESOURCES;
- bootefi_image_path = efi_dp_from_file(NULL, 0, path); + bootefi_image_path = efi_dp_from_file(NULL, path); if (!bootefi_image_path) { ret = EFI_OUT_OF_RESOURCES; goto failure; diff --git a/include/efi_loader.h b/include/efi_loader.h index b395eef9e7..38d7f66bab 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -810,7 +810,7 @@ bool efi_dp_is_multi_instance(const struct efi_device_path *dp); struct efi_device_path *efi_dp_from_part(struct blk_desc *desc, int part); /* Create a device node for a block device partition. */ struct efi_device_path *efi_dp_part_node(struct blk_desc *desc, int part); -struct efi_device_path *efi_dp_from_file(struct blk_desc *desc, int part, +struct efi_device_path *efi_dp_from_file(const struct efi_device_path *dp, const char *path); struct efi_device_path *efi_dp_from_eth(void); struct efi_device_path *efi_dp_from_mem(uint32_t mem_type, diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 4b24b41047..7ac5f89f76 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -47,7 +47,7 @@ const efi_guid_t efi_guid_bootmenu_auto_generated = static struct efi_device_path *expand_media_path(struct efi_device_path *device_path) { - struct efi_device_path *dp, *rem, *full_path; + struct efi_device_path *rem, *full_path; efi_handle_t handle;
if (!device_path) @@ -58,15 +58,12 @@ struct efi_device_path *expand_media_path(struct efi_device_path *device_path) * simple file system protocol, append a default file name to support * booting from removable media. */ - dp = device_path; - handle = efi_dp_find_obj(dp, &efi_simple_file_system_protocol_guid, - &rem); + handle = efi_dp_find_obj(device_path, + &efi_simple_file_system_protocol_guid, &rem); if (handle) { if (rem->type == DEVICE_PATH_TYPE_END) { - dp = efi_dp_from_file(NULL, 0, - "/EFI/BOOT/" BOOTEFI_NAME); - full_path = efi_dp_append(device_path, dp); - efi_free_pool(dp); + full_path = efi_dp_from_file(device_path, + "/EFI/BOOT/" BOOTEFI_NAME); } else { full_path = efi_dp_dup(device_path); } diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index a9b0ea4015..71923b1127 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1002,47 +1002,31 @@ static void path_to_uefi(void *uefi, const char *src) }
/** - * efi_dp_from_file() - create device path for file + * efi_dp_from_file() - append file path node to device path. * - * The function creates a device path from the block descriptor @desc and the - * partition number @part and appends a device path node created describing the - * file path @path. - * - * If @desc is NULL, the device path will not contain nodes describing the - * partition. - * If @path is an empty string "", the device path will not contain a node - * for the file path. - * - * @desc: block device descriptor or NULL - * @part: partition number - * @path: file path on partition or "" + * @dp: device path or NULL + * @path: file path or NULL * Return: device path or NULL in case of an error */ -struct efi_device_path *efi_dp_from_file(struct blk_desc *desc, int part, - const char *path) +struct efi_device_path *efi_dp_from_file(const struct efi_device_path *dp, + const char *path) { struct efi_device_path_file_path *fp; void *buf, *pos; - size_t dpsize = 0, fpsize; - - if (desc) - dpsize = dp_part_size(desc, part); + size_t dpsize, fpsize;
+ dpsize = efi_dp_size(dp); fpsize = sizeof(struct efi_device_path) + 2 * (utf8_utf16_strlen(path) + 1); if (fpsize > U16_MAX) return NULL;
- dpsize += fpsize; - - buf = efi_alloc(dpsize + sizeof(END)); + buf = efi_alloc(dpsize + fpsize + sizeof(END)); if (!buf) return NULL;
- if (desc) - pos = dp_part_fill(buf, desc, part); - else - pos = buf; + memcpy(buf, dp, dpsize); + pos = buf + dpsize;
/* add file-path: */ if (*path) { @@ -1218,8 +1202,7 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, if (!path) return EFI_SUCCESS;
- *file = efi_dp_from_file(desc, part, path); - + *file = efi_dp_from_file(dp, path); if (!*file) return EFI_OUT_OF_RESOURCES;
Ilias Apalodimas
