[PATCH 1/3] mmc: mv_sdhci: Simplify call to sdhci_mvebu_mbus_config()
This driver already depends on CONFIG_ARCH_MVEBU, so there is no need to have some checks for this Kconfig symbol in the driver itself. Let's remove these superfluous checks.
Signed-off-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/mv_sdhci.c | 12 ++++-------- 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/mmc/mv_sdhci.c b/drivers/mmc/mv_sdhci.c index 336ebf141026..50d03b703ed7 100644 --- a/drivers/mmc/mv_sdhci.c +++ b/drivers/mmc/mv_sdhci.c @@ -64,10 +64,8 @@ int mv_sdh_init(unsigned long regbase, u32 max_clk, u32 min_clk, u32 quirks) host->ops = &mv_ops; #endif
- if (CONFIG_IS_ENABLED(ARCH_MVEBU)) { - /* Configure SDHCI MBUS mbus bridge windows */ - sdhci_mvebu_mbus_config((void __iomem *)regbase); - } + /* Configure SDHCI MBUS mbus bridge windows */ + sdhci_mvebu_mbus_config((void __iomem *)regbase);
return add_sdhci(host, 0, min_clk); } @@ -103,10 +101,8 @@ static int mv_sdhci_probe(struct udevice *dev) if (ret) return ret;
- if (CONFIG_IS_ENABLED(ARCH_MVEBU)) { - /* Configure SDHCI MBUS mbus bridge windows */ - sdhci_mvebu_mbus_config(host->ioaddr); - } + /* Configure SDHCI MBUS mbus bridge windows */ + sdhci_mvebu_mbus_config(host->ioaddr);
upriv->mmc = host->mmc;
CONFIG_MMC_SDHCI_IO_ACCESSORS is not supported and/or used by this driver so let's remove these unused parts completely.
Signed-off-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/mv_sdhci.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/drivers/mmc/mv_sdhci.c b/drivers/mmc/mv_sdhci.c index 50d03b703ed7..42fa735f3160 100644 --- a/drivers/mmc/mv_sdhci.c +++ b/drivers/mmc/mv_sdhci.c @@ -42,10 +42,6 @@ static void sdhci_mvebu_mbus_config(void __iomem *base)
#ifndef CONFIG_DM_MMC
-#ifdef CONFIG_MMC_SDHCI_IO_ACCESSORS -static struct sdhci_ops mv_ops; -#endif /* CONFIG_MMC_SDHCI_IO_ACCESSORS */ - int mv_sdh_init(unsigned long regbase, u32 max_clk, u32 min_clk, u32 quirks) { struct sdhci_host *host = NULL; @@ -59,10 +55,6 @@ int mv_sdh_init(unsigned long regbase, u32 max_clk, u32 min_clk, u32 quirks) host->ioaddr = (void *)regbase; host->quirks = quirks; host->max_clk = max_clk; -#ifdef CONFIG_MMC_SDHCI_IO_ACCESSORS - memset(&mv_ops, 0, sizeof(struct sdhci_ops)); - host->ops = &mv_ops; -#endif
/* Configure SDHCI MBUS mbus bridge windows */ sdhci_mvebu_mbus_config((void __iomem *)regbase);
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
-#endif
Signed-off-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Applied to u-boot-mmc/master.
-#endif
All build targets using this driver already use DM_MMC. So let's depend this driver on this Kconfig symbol and remove the non-DM driver part.
Signed-off-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/Kconfig | 1 + drivers/mmc/mv_sdhci.c | 39 +++++++-------------------------------- 2 files changed, 8 insertions(+), 32 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 878f867c627b..3f5f61503fb6 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -621,6 +621,7 @@ config MMC_SDHCI_MV bool "SDHCI support on Marvell platform" depends on ARCH_MVEBU depends on MMC_SDHCI + depends on DM_MMC help This selects the Secure Digital Host Controller Interface on Marvell platform. diff --git a/drivers/mmc/mv_sdhci.c b/drivers/mmc/mv_sdhci.c index 42fa735f3160..dbdd671c88bc 100644 --- a/drivers/mmc/mv_sdhci.c +++ b/drivers/mmc/mv_sdhci.c @@ -15,6 +15,13 @@ #define SDHCI_WINDOW_CTRL(win) (0x4080 + ((win) << 4)) #define SDHCI_WINDOW_BASE(win) (0x4084 + ((win) << 4))
+DECLARE_GLOBAL_DATA_PTR; + +struct mv_sdhci_plat { + struct mmc_config cfg; + struct mmc mmc; +}; + static void sdhci_mvebu_mbus_config(void __iomem *base) { const struct mbus_dram_target_info *dram; @@ -40,37 +47,6 @@ static void sdhci_mvebu_mbus_config(void __iomem *base) } }
-#ifndef CONFIG_DM_MMC - -int mv_sdh_init(unsigned long regbase, u32 max_clk, u32 min_clk, u32 quirks) -{ - struct sdhci_host *host = NULL; - host = calloc(1, sizeof(*host)); - if (!host) { - printf("sdh_host malloc fail!\n"); - return -ENOMEM; - } - - host->name = MVSDH_NAME; - host->ioaddr = (void *)regbase; - host->quirks = quirks; - host->max_clk = max_clk; - - /* Configure SDHCI MBUS mbus bridge windows */ - sdhci_mvebu_mbus_config((void __iomem *)regbase); - - return add_sdhci(host, 0, min_clk); -} - -#else - -DECLARE_GLOBAL_DATA_PTR; - -struct mv_sdhci_plat { - struct mmc_config cfg; - struct mmc mmc; -}; - static int mv_sdhci_probe(struct udevice *dev) { struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); @@ -123,4 +99,3 @@ U_BOOT_DRIVER(mv_sdhci_drv) = { .priv_auto = sizeof(struct sdhci_host), .plat_auto = sizeof(struct mv_sdhci_plat), }; -#endif /* CONFIG_DM_MMC */
- depends on DM_MMC help This selects the Secure Digital Host Controller Interface on Marvell platform.
- struct mmc mmc;
- if (!host) {
return -ENOMEM;
-#else
- struct mmc mmc;
Signed-off-by: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Simon Glass sjg@chromium.org Cc: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
- struct mmc mmc;
- if (!host) {
return -ENOMEM;
-#else
- struct mmc mmc;
Jaehoon Chung
Jaehoon Chung
Stefan Roese
