[PULL] u-boot-sh/master_common_h_cleanup
The following changes since commit a803f87202aa48974bdff4d8100464a8288931e4:
Merge https://source.denx.de/u-boot/custodians/u-boot-mmc (2023-11-01 09:44:33 -0400)
https://source.denx.de/u-boot/custodians/u-boot-sh.git master_common_h_cleanup
for you to fetch changes up to 7d824618d7eb5340e63892c919abc62d831e7482:
board: rzg2l: Drop <common.h> (2023-11-02 11:30:19 +0100)
---------------------------------------------------------------- Paul Barker (8): arm: armv8: mmu: Prepare for common.h removal arm: mach-rmobile: Drop <common.h> serial: sh: Drop <common.h> pinctrl: rzg2l: Drop <common.h> mmc: renesas-sdhi: Drop <common.h> gpio: rzg2l: Drop <common.h> clk: rzg2l: Drop <common.h> board: rzg2l: Drop <common.h>
arch/arm/include/asm/armv8/mmu.h | 2 ++ arch/arm/mach-rmobile/board.c | 2 +- arch/arm/mach-rmobile/cpu_info-r8a7740.c | 2 +- arch/arm/mach-rmobile/cpu_info-rcar.c | 2 +- arch/arm/mach-rmobile/cpu_info-rzg.c | 2 +- arch/arm/mach-rmobile/cpu_info-rzg2l.c | 1 - arch/arm/mach-rmobile/cpu_info.c | 2 +- arch/arm/mach-rmobile/emac.c | 1 - arch/arm/mach-rmobile/memmap-gen3.c | 4 ++-- arch/arm/mach-rmobile/memmap-rzg2l.c | 2 +- arch/arm/mach-rmobile/pfc-r8a7740.c | 2 +- arch/arm/mach-rmobile/psci-r8a779a0.c | 1 - board/renesas/rzg2l/rzg2l.c | 1 - drivers/clk/renesas/r9a07g044-cpg.c | 1 - drivers/clk/renesas/rzg2l-cpg.c | 1 - drivers/gpio/rzg2l-gpio.c | 1 - drivers/mmc/renesas-sdhi.c | 1 - drivers/pinctrl/renesas/rzg2l-pfc.c | 1 - drivers/serial/serial_sh.c | 1 - 19 files changed, 11 insertions(+), 19 deletions(-)
