[U-Boot] [PATCH v3] powerpc/usb: fix bug of CPU hang when missing USB PHY clock
when missing USB PHY clock, u-boot will hang during USB initialization when issuing "usb start". We should check USBGP[PHY_CLK_VALID] bit to avoid CPU hanging in this case.
Due to controller issue of PHY_CLK_VALID in ULPI mode, we set USB_EN before checking PHY_CLK_VALID, otherwise PHY_CLK_VALID doesn't work.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com Acked-by: Marek Vasut marex@denx.de --- against master branch of upstream u-boot tree v3: added explanation for set USB_EN earlier for ULPI case. v2: integrated Marek's comment to use single negation.
drivers/usb/host/ehci-fsl.c | 22 ++++++++++++++++------ 1 files changed, 16 insertions(+), 6 deletions(-)
diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index 7b8f033..f54b408 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -30,6 +30,18 @@
#include "ehci.h"
+/* Check USB PHY clock valid */ +static int usb_phy_clk_valid(struct usb_ehci *ehci) +{ + if (!((in_be32(&ehci->control) & PHY_CLK_VALID) || + in_be32(&ehci->prictrl))) { + printf("USB PHY clock invalid!\n"); + return 0; + } else { + return 1; + } +} + /* * Create the appropriate control structures to manage * a new EHCI host controller. @@ -82,18 +94,16 @@ int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor) udelay(1000); /* delay required for PHY Clk to appear */ #endif out_le32(&(*hcor)->or_portsc[0], PORT_PTS_UTMI); + setbits_be32(&ehci->control, USB_EN); } else { -#if defined(CONFIG_SYS_FSL_USB_INTERNAL_UTMI_PHY) - clrbits_be32(&ehci->control, UTMI_PHY_EN); setbits_be32(&ehci->control, PHY_CLK_SEL_ULPI); + clrsetbits_be32(&ehci->control, UTMI_PHY_EN, USB_EN); udelay(1000); /* delay required for PHY Clk to appear */ -#endif + if (!usb_phy_clk_valid(ehci)) + return -EINVAL; out_le32(&(*hcor)->or_portsc[0], PORT_PTS_ULPI); }
- /* Enable interface. */ - setbits_be32(&ehci->control, USB_EN); - out_be32(&ehci->prictrl, 0x0000000c); out_be32(&ehci->age_cnt_limit, 0x00000040); out_be32(&ehci->sictrl, 0x00000001);
Dear Shengzhou Liu,
Applied, thanks
Best regards, Marek Vasut
Shengzhou Liu
