Re: [PATCH v6 1/7] riscv: dts: add fu740 support
Hi Green,
From: Green Wan [mailto:green.wan@sifive.com] Sent: Thursday, April 08, 2021 9:40 PM Cc: bmeng.cn@gmail.com; Green Wan; Greentime Hu; Rick Jian-Zhi Chen(陳建志); Paul Walmsley; Palmer Dabbelt; Anup Patel; Atish Patra; Pragnesh Patel; Lukasz Majewski; Joe Hershberger; Ramon Fried; u-boot@lists.denx.de Subject: [PATCH v6 1/7] riscv: dts: add fu740 support
Add dts support for fu740. The HiFive Unmatched support is based on fu740 cpu and drivers in following patch set.
Signed-off-by: Green Wan green.wan@sifive.com [greentime.hu: set fu740 speed to 1.2GHz] Signed-off-by: Greentime Hu greentime.hu@sifive.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
arch/riscv/dts/Makefile | 1 + arch/riscv/dts/fu740-c000-u-boot.dtsi | 105 ++++++ arch/riscv/dts/fu740-c000.dtsi | 329 ++++++++++++++++++ include/dt-bindings/clock/sifive-fu740-prci.h | 25 ++ include/dt-bindings/reset/sifive-fu740-prci.h | 19 + 5 files changed, 479 insertions(+) create mode 100644 arch/riscv/dts/fu740-c000-u-boot.dtsi create mode 100644 arch/riscv/dts/fu740-c000.dtsi create mode 100644 include/dt-bindings/clock/sifive-fu740-prci.h create mode 100644 include/dt-bindings/reset/sifive-fu740-prci.h
diff --git a/arch/riscv/dts/Makefile b/arch/riscv/dts/Makefile index 8138d89d84..ed32f56c9e 100644 --- a/arch/riscv/dts/Makefile +++ b/arch/riscv/dts/Makefile @@ -2,6 +2,7 @@
dtb-$(CONFIG_TARGET_AX25_AE350) += ae350_32.dtb ae350_64.dtb dtb-$(CONFIG_TARGET_SIFIVE_UNLEASHED) += hifive-unleashed-a00.dtb +dtb-$(CONFIG_TARGET_SIFIVE_UNMATCHED) += hifive-unmatched-a00.dtb
Makefile need the dts file, but it is not exist in this patch. It doesn't make sense.
Maybe you can combine with the dts relative files in [PATCH v6 6/7] into one patch and name as : riscv: dts: ...
LGTM. Other than that,
Reviewed-by: Rick Chen rick@andestech.com
dtb-$(CONFIG_TARGET_SIPEED_MAIX) += k210-maix-bit.dtb dtb-$(CONFIG_TARGET_MICROCHIP_ICICLE) += microchip-mpfs-icicle-kit.dtb
diff --git a/arch/riscv/dts/fu740-c000-u-boot.dtsi b/arch/riscv/dts/fu740-c000-u-boot.dtsi new file mode 100644 index 0000000000..a5d0688b06 --- /dev/null +++ b/arch/riscv/dts/fu740-c000-u-boot.dtsi @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/*
- (C) Copyright 2020-2021 SiFive, Inc
+#include <dt-bindings/reset/sifive-fu740-prci.h>
cpus {
assigned-clocks = <&prci PRCI_CLK_COREPLL>;
assigned-clock-rates = <1200000000>;
u-boot,dm-spl;
cpu0: cpu@0 {
u-boot,dm-spl;
status = "okay";
cpu0_intc: interrupt-controller {
u-boot,dm-spl;
cpu1: cpu@1 {
u-boot,dm-spl;
cpu1_intc: interrupt-controller {
u-boot,dm-spl;
cpu2: cpu@2 {
u-boot,dm-spl;
cpu2_intc: interrupt-controller {
u-boot,dm-spl;
cpu3: cpu@3 {
u-boot,dm-spl;
cpu3_intc: interrupt-controller {
u-boot,dm-spl;
cpu4: cpu@4 {
u-boot,dm-spl;
cpu4_intc: interrupt-controller {
u-boot,dm-spl;
soc {
u-boot,dm-spl;
clint: clint@2000000 {
compatible = "riscv,clint0";
interrupts-extended = <&cpu0_intc 3 &cpu0_intc 7
&cpu1_intc 3 &cpu1_intc 7
&cpu2_intc 3 &cpu2_intc 7
&cpu3_intc 3 &cpu3_intc 7
&cpu4_intc 3 &cpu4_intc 7>;
reg = <0x0 0x2000000 0x0 0x10000>;
u-boot,dm-spl;
prci: clock-controller@10000000 {
#reset-cells = <1>;
resets = <&prci PRCI_RST_DDR_CTRL_N>,
<&prci PRCI_RST_DDR_AXI_N>,
<&prci PRCI_RST_DDR_AHB_N>,
<&prci PRCI_RST_DDR_PHY_N>,
<&prci PRCI_RST_GEMGXL_N>,
<&prci PRCI_RST_CLTX_N>;
reset-names = "ddr_ctrl", "ddr_axi", "ddr_ahb",
"ddr_phy", "gemgxl_reset", "cltx_reset";
dmc: dmc@100b0000 {
compatible = "sifive,fu740-c000-ddr";
reg = <0x0 0x100b0000 0x0 0x0800
0x0 0x100b2000 0x0 0x2000
0x0 0x100b8000 0x0 0x1000>;
clocks = <&prci PRCI_CLK_DDRPLL>;
clock-frequency = <933333324>;
u-boot,dm-spl;
+&prci {
u-boot,dm-spl;
+&uart0 {
u-boot,dm-spl;
+&spi0 {
u-boot,dm-spl;
+ð0 {
assigned-clocks = <&prci PRCI_CLK_GEMGXLPLL>;
assigned-clock-rates = <125125000>;
+&ccache {
status = "okay";
+}; diff --git a/arch/riscv/dts/fu740-c000.dtsi b/arch/riscv/dts/fu740-c000.dtsi new file mode 100644 index 0000000000..0325e51e39 --- /dev/null +++ b/arch/riscv/dts/fu740-c000.dtsi @@ -0,0 +1,329 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* Copyright (c) 2020-2021 SiFive, Inc */
+/dts-v1/;
+#include <dt-bindings/clock/sifive-fu740-prci.h> +#include <dt-bindings/reset/sifive-fu740-prci.h>
#address-cells = <2>;
#size-cells = <2>;
compatible = "sifive,fu740-c000", "sifive,fu740";
aliases {
serial0 = &uart0;
serial1 = &uart1;
ethernet0 = ð0;
chosen {
cpus {
#address-cells = <1>;
#size-cells = <0>;
cpu0: cpu@0 {
compatible = "sifive,bullet0", "riscv";
device_type = "cpu";
i-cache-block-size = <64>;
i-cache-sets = <128>;
i-cache-size = <16384>;
next-level-cache = <&ccache>;
reg = <0x0>;
riscv,isa = "rv64imac";
status = "disabled";
#interrupt-cells = <1>;
compatible = "riscv,cpu-intc";
interrupt-controller;
cpu1: cpu@1 {
d-cache-block-size = <64>;
d-cache-sets = <64>;
d-cache-size = <32768>;
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-cache-size = <32768>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
mmu-type = "riscv,sv39";
reg = <0x1>;
riscv,isa = "rv64imafdc";
tlb-split;
cpu2: cpu@2 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x2>;
tlb-split;
cpu3: cpu@3 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x3>;
tlb-split;
cpu4: cpu@4 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x4>;
tlb-split;
soc {
#size-cells = <2>;
compatible = "sifive,fu740-c000", "sifive,fu740", "simple-bus";
ranges;
plic0: interrupt-controller@c000000 {
compatible = "sifive,plic-1.0.0";
reg = <0x0 0xc000000 0x0 0x4000000>;
riscv,ndev = <69>;
&cpu0_intc 0xffffffff
&cpu1_intc 0xffffffff &cpu1_intc 9
&cpu2_intc 0xffffffff &cpu2_intc 9
&cpu3_intc 0xffffffff &cpu3_intc 9
&cpu4_intc 0xffffffff &cpu4_intc 9>;
compatible = "sifive,fu740-c000-prci";
reg = <0x0 0x10000000 0x0 0x1000>;
clocks = <&hfclk>, <&rtcclk>;
#clock-cells = <1>;
#reset-cells = <1>;
uart0: serial@10010000 {
compatible = "sifive,fu740-c000-uart", "sifive,uart0";
reg = <0x0 0x10010000 0x0 0x1000>;
interrupt-parent = <&plic0>;
interrupts = <39>;
clocks = <&prci PRCI_CLK_PCLK>;
uart1: serial@10011000 {
reg = <0x0 0x10011000 0x0 0x1000>;
interrupts = <40>;
i2c0: i2c@10030000 {
compatible = "sifive,fu740-c000-i2c", "sifive,i2c0";
reg = <0x0 0x10030000 0x0 0x1000>;
interrupts = <52>;
reg-shift = <2>;
reg-io-width = <1>;
#size-cells = <0>;
i2c1: i2c@10031000 {
reg = <0x0 0x10031000 0x0 0x1000>;
interrupts = <53>;
reg-shift = <2>;
reg-io-width = <1>;
#size-cells = <0>;
qspi0: spi@10040000 {
compatible = "sifive,fu740-c000-spi", "sifive,spi0";
reg = <0x0 0x10040000 0x0 0x1000
0x0 0x20000000 0x0 0x10000000>;
interrupts = <41>;
#size-cells = <0>;
qspi1: spi@10041000 {
reg = <0x0 0x10041000 0x0 0x1000
0x0 0x30000000 0x0 0x10000000>;
interrupts = <42>;
#size-cells = <0>;
spi0: spi@10050000 {
reg = <0x0 0x10050000 0x0 0x1000>;
interrupts = <43>;
#size-cells = <0>;
eth0: ethernet@10090000 {
compatible = "sifive,fu740-c000-gem";
interrupts = <55>;
reg = <0x0 0x10090000 0x0 0x2000
0x0 0x100a0000 0x0 0x1000>;
local-mac-address = [00 00 00 00 00 00];
clock-names = "pclk", "hclk";
clocks = <&prci PRCI_CLK_GEMGXLPLL>,
#size-cells = <0>;
pwm0: pwm@10020000 {
compatible = "sifive,fu740-c000-pwm", "sifive,pwm0";
reg = <0x0 0x10020000 0x0 0x1000>;
interrupts = <44 45 46 47>;
#pwm-cells = <3>;
pwm1: pwm@10021000 {
reg = <0x0 0x10021000 0x0 0x1000>;
interrupts = <48 49 50 51>;
#pwm-cells = <3>;
ccache: cache-controller@2010000 {
compatible = "sifive,fu740-c000-ccache", "cache";
cache-level = <2>;
cache-sets = <2048>;
cache-size = <2097152>;
cache-unified;
interrupts = <19 21 22 20>;
reg = <0x0 0x2010000 0x0 0x1000>;
gpio: gpio@10060000 {
compatible = "sifive,fu740-c000-gpio", "sifive,gpio0";
interrupts = <23>, <24>, <25>, <26>, <27>, <28>, <29>,
<30>, <31>, <32>, <33>, <34>, <35>, <36>,
<37>, <38>;
reg = <0x0 0x10060000 0x0 0x1000>;
gpio-controller;
#gpio-cells = <2>;
#interrupt-cells = <2>;
pcie@e00000000 {
#address-cells = <3>;
#num-lanes = <8>;
#size-cells = <2>;
compatible = "sifive,fu740-pcie";
reg = <0xe 0x00000000 0x1 0x0
0xd 0xf0000000 0x0 0x10000000
0x0 0x100d0000 0x0 0x1000>;
reg-names = "dbi", "config", "mgmt";
device_type = "pci";
dma-coherent;
bus-range = <0x0 0xff>;
ranges = <0x81000000 0x0 0x60080000 0x0 0x60080000 0x0 0x10000
0x82000000 0x0 0x60090000 0x0 0x60090000 0x0 0xff70000
0x82000000 0x0 0x70000000 0x0 0x70000000 0x0 0x1000000
0xc3000000 0x20 0x00000000 0x20 0x00000000 0x20 0x00000000>;
num-lanes = <0x8>;
interrupts = <56 57 58 59 60 61 62 63 64>;
interrupt-names = "msi", "inta", "intb", "intc", "intd";
interrupt-map-mask = <0x0 0x0 0x0 0x7>;
interrupt-map = <0x0 0x0 0x0 0x1 &plic0 57>,
<0x0 0x0 0x0 0x2 &plic0 58>,
<0x0 0x0 0x0 0x3 &plic0 59>,
<0x0 0x0 0x0 0x4 &plic0 60>;
pwren-gpios = <&gpio 5 0>;
perstn-gpios = <&gpio 8 0>;
clocks = <&prci PRCI_CLK_PCIEAUX>;
clock-names = "pcieaux";
resets = <&prci PRCI_RST_PCIE_POWER_UP_N>;
reset-names = "rst_n";
status = "okay";
+}; diff --git a/include/dt-bindings/clock/sifive-fu740-prci.h b/include/dt-bindings/clock/sifive-fu740-prci.h new file mode 100644 index 0000000000..c1224783c0 --- /dev/null +++ b/include/dt-bindings/clock/sifive-fu740-prci.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0 OR MIT */ +/*
- Copyright (C) 2020-2021 SiFive, Inc.
- Wesley Terpstra
- Paul Walmsley
- Zong Li
- Pragnesh Patel
+#ifndef __DT_BINDINGS_CLOCK_SIFIVE_FU740_PRCI_H +#define __DT_BINDINGS_CLOCK_SIFIVE_FU740_PRCI_H
+/* Clock indexes for use by Device Tree data and the PRCI driver */
+#define PRCI_CLK_COREPLL 0 +#define PRCI_CLK_DDRPLL 1 +#define PRCI_CLK_GEMGXLPLL 2 +#define PRCI_CLK_DVFSCOREPLL 3 +#define PRCI_CLK_HFPCLKPLL 4 +#define PRCI_CLK_CLTXPLL 5 +#define PRCI_CLK_TLCLK 6 +#define PRCI_CLK_PCLK 7 +#define PRCI_CLK_PCIEAUX 8
+#endif diff --git a/include/dt-bindings/reset/sifive-fu740-prci.h b/include/dt-bindings/reset/sifive-fu740-prci.h new file mode 100644 index 0000000000..02210f4105 --- /dev/null +++ b/include/dt-bindings/reset/sifive-fu740-prci.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0 OR MIT */ +/*
- Copyright (C) 2020-2021 Sifive, Inc.
- Author: Pragnesh Patel pragnesh.patel@sifive.com
+#ifndef __DT_BINDINGS_RESET_SIFIVE_FU740_PRCI_H +#define __DT_BINDINGS_RESET_SIFIVE_FU740_PRCI_H
+/* Reset indexes for use by device tree data and the PRCI driver */ +#define PRCI_RST_DDR_CTRL_N 0 +#define PRCI_RST_DDR_AXI_N 1 +#define PRCI_RST_DDR_AHB_N 2 +#define PRCI_RST_DDR_PHY_N 3 +#define PRCI_RST_PCIE_POWER_UP_N 4 +#define PRCI_RST_GEMGXL_N 5 +#define PRCI_RST_CLTX_N 6
2.31.0
On Thu, Apr 15, 2021 at 1:25 PM Rick Chen rickchen36@gmail.com wrote:
Hi Green,
Hi Rick,
Thanks for review.
How about move change of arch/riscv/dts/Makefile to [PATCH v6 6/7] since it's more like a board dependent change. This patch [1/7] is pure for fu740 dts review. I'd like to keep one for fu740 dts and the rest dts for unmatched board.
What do you think of it?
Thanks, - Green
cpus {
u-boot,dm-spl;
cpu0: cpu@0 {
u-boot,dm-spl;
status = "okay";
u-boot,dm-spl;
cpu1: cpu@1 {
u-boot,dm-spl;
u-boot,dm-spl;
cpu2: cpu@2 {
u-boot,dm-spl;
u-boot,dm-spl;
cpu3: cpu@3 {
u-boot,dm-spl;
u-boot,dm-spl;
cpu4: cpu@4 {
u-boot,dm-spl;
u-boot,dm-spl;
soc {
u-boot,dm-spl;
u-boot,dm-spl;
#reset-cells = <1>;
dmc: dmc@100b0000 {
u-boot,dm-spl;
+&prci {
u-boot,dm-spl;
+&uart0 {
u-boot,dm-spl;
+&spi0 {
u-boot,dm-spl;
+ð0 {
+&ccache {
status = "okay";
+/dts-v1/;
#size-cells = <2>;
aliases {
serial0 = &uart0;
serial1 = &uart1;
ethernet0 = ð0;
chosen {
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0x0>;
cpu1: cpu@1 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x1>;
tlb-split;
cpu2: cpu@2 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x2>;
tlb-split;
cpu3: cpu@3 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x3>;
tlb-split;
cpu4: cpu@4 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x4>;
tlb-split;
soc {
#size-cells = <2>;
ranges;
riscv,ndev = <69>;
#clock-cells = <1>;
#reset-cells = <1>;
interrupts = <39>;
interrupts = <40>;
interrupts = <52>;
reg-shift = <2>;
reg-io-width = <1>;
#size-cells = <0>;
interrupts = <53>;
reg-shift = <2>;
reg-io-width = <1>;
#size-cells = <0>;
interrupts = <41>;
#size-cells = <0>;
interrupts = <42>;
#size-cells = <0>;
interrupts = <43>;
#size-cells = <0>;
interrupts = <55>;
#size-cells = <0>;
#pwm-cells = <3>;
#pwm-cells = <3>;
cache-level = <2>;
cache-unified;
<37>, <38>;
gpio-controller;
#gpio-cells = <2>;
pcie@e00000000 {
#num-lanes = <8>;
#size-cells = <2>;
dma-coherent;
num-lanes = <0x8>;
status = "okay";
- Wesley Terpstra
- Paul Walmsley
- Zong Li
- Pragnesh Patel
2.31.0
Hi Green
Hi Green,
Hi Rick,
Thanks for review.
It is OK.
You may arrange them nearby as below: 6/x riscv: dts: support fu740 7/x riscv: dst: support HiFive Unmatched board
Thanks, Rick
Thanks,
Green
cpus {
u-boot,dm-spl;
cpu0: cpu@0 {
u-boot,dm-spl;
status = "okay";
u-boot,dm-spl;
cpu1: cpu@1 {
u-boot,dm-spl;
u-boot,dm-spl;
cpu2: cpu@2 {
u-boot,dm-spl;
u-boot,dm-spl;
cpu3: cpu@3 {
u-boot,dm-spl;
u-boot,dm-spl;
cpu4: cpu@4 {
u-boot,dm-spl;
u-boot,dm-spl;
soc {
u-boot,dm-spl;
u-boot,dm-spl;
#reset-cells = <1>;
dmc: dmc@100b0000 {
u-boot,dm-spl;
+&prci {
u-boot,dm-spl;
+&uart0 {
u-boot,dm-spl;
+&spi0 {
u-boot,dm-spl;
+ð0 {
+&ccache {
status = "okay";
+/dts-v1/;
#size-cells = <2>;
aliases {
serial0 = &uart0;
serial1 = &uart1;
ethernet0 = ð0;
chosen {
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0x0>;
cpu1: cpu@1 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x1>;
tlb-split;
cpu2: cpu@2 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x2>;
tlb-split;
cpu3: cpu@3 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x3>;
tlb-split;
cpu4: cpu@4 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x4>;
tlb-split;
soc {
#size-cells = <2>;
ranges;
riscv,ndev = <69>;
#clock-cells = <1>;
#reset-cells = <1>;
interrupts = <39>;
interrupts = <40>;
interrupts = <52>;
reg-shift = <2>;
reg-io-width = <1>;
#size-cells = <0>;
interrupts = <53>;
reg-shift = <2>;
reg-io-width = <1>;
#size-cells = <0>;
interrupts = <41>;
#size-cells = <0>;
interrupts = <42>;
#size-cells = <0>;
interrupts = <43>;
#size-cells = <0>;
interrupts = <55>;
#size-cells = <0>;
#pwm-cells = <3>;
#pwm-cells = <3>;
cache-level = <2>;
cache-unified;
<37>, <38>;
gpio-controller;
#gpio-cells = <2>;
pcie@e00000000 {
#num-lanes = <8>;
#size-cells = <2>;
dma-coherent;
num-lanes = <0x8>;
status = "okay";
- Wesley Terpstra
- Paul Walmsley
- Zong Li
- Pragnesh Patel
2.31.0
On Fri, Apr 16, 2021 at 3:11 PM Rick Chen rickchen36@gmail.com wrote:
Hi Green
Hi Green,
Hi Rick,
Thanks for review.
It is OK.
Thanks for confirmation. I can do it. Originally, I want to keep fu740 dts in front of CPU and drivers patch. That means they will be in front of fu740 dts in v7 patch. Hope it's fine for upstream.
-- Green
Thanks, Rick
Thanks,
Green
cpus {
u-boot,dm-spl;
cpu0: cpu@0 {
u-boot,dm-spl;
status = "okay";
u-boot,dm-spl;
cpu1: cpu@1 {
u-boot,dm-spl;
u-boot,dm-spl;
cpu2: cpu@2 {
u-boot,dm-spl;
u-boot,dm-spl;
cpu3: cpu@3 {
u-boot,dm-spl;
u-boot,dm-spl;
cpu4: cpu@4 {
u-boot,dm-spl;
u-boot,dm-spl;
soc {
u-boot,dm-spl;
u-boot,dm-spl;
#reset-cells = <1>;
dmc: dmc@100b0000 {
u-boot,dm-spl;
+&prci {
u-boot,dm-spl;
+&uart0 {
u-boot,dm-spl;
+&spi0 {
u-boot,dm-spl;
+ð0 {
+&ccache {
status = "okay";
+/dts-v1/;
#size-cells = <2>;
aliases {
serial0 = &uart0;
serial1 = &uart1;
ethernet0 = ð0;
chosen {
cpus {
#size-cells = <0>;
cpu0: cpu@0 {
reg = <0x0>;
cpu1: cpu@1 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x1>;
tlb-split;
cpu2: cpu@2 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x2>;
tlb-split;
cpu3: cpu@3 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x3>;
tlb-split;
cpu4: cpu@4 {
d-tlb-sets = <1>;
d-tlb-size = <40>;
i-tlb-sets = <1>;
i-tlb-size = <40>;
reg = <0x4>;
tlb-split;
soc {
#size-cells = <2>;
ranges;
riscv,ndev = <69>;
#clock-cells = <1>;
#reset-cells = <1>;
interrupts = <39>;
interrupts = <40>;
interrupts = <52>;
reg-shift = <2>;
reg-io-width = <1>;
#size-cells = <0>;
interrupts = <53>;
reg-shift = <2>;
reg-io-width = <1>;
#size-cells = <0>;
interrupts = <41>;
#size-cells = <0>;
interrupts = <42>;
#size-cells = <0>;
interrupts = <43>;
#size-cells = <0>;
interrupts = <55>;
#size-cells = <0>;
#pwm-cells = <3>;
#pwm-cells = <3>;
cache-level = <2>;
cache-unified;
<37>, <38>;
gpio-controller;
#gpio-cells = <2>;
pcie@e00000000 {
#num-lanes = <8>;
#size-cells = <2>;
dma-coherent;
num-lanes = <0x8>;
status = "okay";
- Wesley Terpstra
- Paul Walmsley
- Zong Li
- Pragnesh Patel
2.31.0
Green Wan
Rick Chen
