[U-Boot] [PATCH v3 00/20] sunxi: sync H3, H5, A64 DTs from mainline Linux
This is an extended version of the EMAC DT binding update, this time including the full Linux DTs for all H3, H5 and A64 boards. Patch 01 should be merged *now*, to leave some hint in the README for the v2018.03 release. Without building ARM Trusted Firmware with DEBUG=0 many H5 boards and the Pine64 can't be built successfully at the moment.
The old v2 EMAC DT update series is in patches 02-08, it prepares U-Boot's EMAC driver for using the new DT binding used in Linux, also updates the DTs to the new EMAC DT node already.
This time I added patches to sync the whole U-Boot DT files for the mentioned SoCs with those from Linux. However this first requires lifting the space limit we currently have due to the raw MMC environment. Patch 09 disables that for 64 bit sunxi boards, to give us finally some space. Patch 10 consequently reverts the disabling of features we saw a few weeks ago to migitate the size problem.
Patches 11-20 then brings in the Linux DTs, split by SoCs, with the .dtsi files first, then the board files.
Merging the H3 and H5 device tree files brings in significant changes, also to the structure of the .dtsi files. However U-Boot's own DT usage is pretty limited, so it doesn't matter.
The huge benefit of syncing the DTs is that we can use U-Boot's DT copy to directly pass it to the kernel, avoiding to actually load a .dtb file from somewhere. To allows seamless and automatic UEFI booting, so distribution installer images should just work (TM).
As a goodie the final patch brings in the actual SoPine + baseboard DT files, which we were completely missing so far.
Please let me know if that looks good. I am happy to rearrange or squash patches, but I tried to avoid huge commits, for the sake of reviewability.
Cheers, Andre.
Changelog v2 .. v3: 01: added, was on the list before 02: drop redundant H5 line 03-08: unchanged 09-20: added
Changelog v1 .. v2: 01, 02, 03: unchanged 04, 05, 06, 07: added
Andre Przywara (20): sunxi: README.sunxi64: Add hint about non-debug of ARM Trusted Firmware sunxi: gpio: add missing compatible strings net: sun8i-emac: support new pinctrl DT bindings net: sun8i-emac: add support for new EMAC DT binding arm: dts: sunxi: update A64 to new EMAC binding arm: dts: sunxi: update H3 to new EMAC binding arm: dts: sunxi: update H5 to new EMAC binding net: sun8i-emac: remove support for old binding sunxi: disable direct MMC environment for 64 bit boards sunxi: revert disabling of features sunxi: DT: A64: update device tree file for Allwinner A64 SoC sunxi: DT: A64: update board .dts files from Linux Revert: arm64: allwinner: a64: pine64: Use dcdc1 regulator for mmc0 sunxi: dts: A64 boards: Use fixed regulator for mmc0 sunxi: DT: update device tree files for Allwinner H3 and H5 SoCs sunxi: DT: H5: update board .dts files from Linux sunxi: DT: H3: update board .dts files from Linux sunxi: DT: H3: update libre-cc board .dts file sunxi: DT: H2+: update Opi-zero .dts sunxi: DT: A64: add proper SoPine baseboard device tree
arch/arm/dts/Makefile | 3 +- arch/arm/dts/axp803.dtsi | 150 +++++ arch/arm/dts/sun50i-a64-bananapi-m64.dts | 154 +++++- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 99 ++++ arch/arm/dts/sun50i-a64-olinuxino.dts | 122 +++++ arch/arm/dts/sun50i-a64-orangepi-win.dts | 7 +- arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi | 50 -- arch/arm/dts/sun50i-a64-pine64-plus.dts | 17 +- arch/arm/dts/sun50i-a64-pine64.dts | 171 ++++++ arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 150 +++++ arch/arm/dts/sun50i-a64-sopine.dtsi | 142 +++++ arch/arm/dts/sun50i-a64.dtsi | 204 ++++++- arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts | 105 +++- arch/arm/dts/sun50i-h5-nanopi-neo2.dts | 89 ++- arch/arm/dts/sun50i-h5-orangepi-pc2.dts | 170 ++++-- arch/arm/dts/sun50i-h5-orangepi-prime.dts | 164 +++++- arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts | 7 +- arch/arm/dts/sun50i-h5.dtsi | 36 +- arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts | 58 +- arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts | 78 ++- arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts | 15 +- arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts | 71 +++ arch/arm/dts/sun8i-h3-nanopi-m1.dts | 6 + arch/arm/dts/sun8i-h3-nanopi-neo-air.dts | 1 - arch/arm/dts/sun8i-h3-nanopi-neo.dts | 6 +- arch/arm/dts/sun8i-h3-orangepi-2.dts | 67 ++- arch/arm/dts/sun8i-h3-orangepi-lite.dts | 25 +- arch/arm/dts/sun8i-h3-orangepi-one.dts | 72 ++- arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts | 9 +- arch/arm/dts/sun8i-h3-orangepi-pc.dts | 88 ++- arch/arm/dts/sun8i-h3-orangepi-plus.dts | 37 +- arch/arm/dts/sun8i-h3-orangepi-plus2e.dts | 18 +- arch/arm/dts/sun8i-h3.dtsi | 488 ++--------------- arch/arm/dts/sunxi-h3-h5.dtsi | 698 ++++++++++++++++++++++++ board/sunxi/README.sunxi64 | 6 + cmd/Kconfig | 5 - configs/sopine_baseboard_defconfig | 2 +- drivers/gpio/sunxi_gpio.c | 3 + drivers/net/sun8i_emac.c | 89 ++- drivers/video/Kconfig | 2 - env/Kconfig | 5 +- include/configs/sunxi-common.h | 2 +- include/dt-bindings/clock/sun8i-r-ccu.h | 59 ++ include/dt-bindings/reset/sun8i-r-ccu.h | 53 ++ lib/Kconfig | 1 - 45 files changed, 2980 insertions(+), 824 deletions(-) create mode 100644 arch/arm/dts/axp803.dtsi delete mode 100644 arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi create mode 100644 arch/arm/dts/sun50i-a64-sopine-baseboard.dts create mode 100644 arch/arm/dts/sun50i-a64-sopine.dtsi create mode 100644 arch/arm/dts/sunxi-h3-h5.dtsi create mode 100644 include/dt-bindings/clock/sun8i-r-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-r-ccu.h
As we are running into issues where the final U-Boot FIT image file is exceeding our size limit, add a hint to the README.sunxi64 file to point out the possibility of building non-debug versions of the ATF binary. These are about 12KB smaller than the standard debug build, and so allow successful U-Boot builds for many boards with the Allwinner H5 SoC. Please note that under normal circumstances the debug build is still recommended, as it gives valuable clues in case something goes wrong in the ATF.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- board/sunxi/README.sunxi64 | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/board/sunxi/README.sunxi64 b/board/sunxi/README.sunxi64 index c492f749b8..eefa5001a2 100644 --- a/board/sunxi/README.sunxi64 +++ b/board/sunxi/README.sunxi64 @@ -38,6 +38,12 @@ the root of your U-Boot build directory (or create a symbolic link). $ export BL31=/src/arm-trusted-firmware/build/sun50iw1p1/debug/bl31.bin (adjust the actual path accordingly)
+If you run into size issues with the resulting U-Boot image file, it might +help to use a release build, by using "DEBUG=0" when building bl31.bin. +As sometimes the ATF build process is a bit picky about the toolchain used, +or if you can't be bothered with building ATF, there are known working +binaries in the firmware repository[3], purely for convenience reasons. + SPL/U-Boot ------------ Both U-Boot proper and the SPL are using the 64-bit mode. As the boot ROM
The sunxi GPIO driver is missing some compatible strings for recent SoCs. While most of the sunxi GPIO code seems to not rely on this (and so works anyway), the sunxi_name_to_gpio() function does and fails at the moment (for instance when resolving the MMC CD pin name). Add the compatible strings for the A64 and V3s, which were missing from the list. This now covers all pinctrl nodes in our own DTs.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- drivers/gpio/sunxi_gpio.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/gpio/sunxi_gpio.c b/drivers/gpio/sunxi_gpio.c index 3cf01b6e36..ea6f3593b9 100644 --- a/drivers/gpio/sunxi_gpio.c +++ b/drivers/gpio/sunxi_gpio.c @@ -354,12 +354,15 @@ static const struct udevice_id sunxi_gpio_ids[] = { ID("allwinner,sun8i-a83t-pinctrl", a_all), ID("allwinner,sun8i-h3-pinctrl", a_all), ID("allwinner,sun8i-r40-pinctrl", a_all), + ID("allwinner,sun8i-v3s-pinctrl", a_all), ID("allwinner,sun9i-a80-pinctrl", a_all), + ID("allwinner,sun50i-a64-pinctrl", a_all), ID("allwinner,sun6i-a31-r-pinctrl", l_2), ID("allwinner,sun8i-a23-r-pinctrl", l_1), ID("allwinner,sun8i-a83t-r-pinctrl", l_1), ID("allwinner,sun8i-h3-r-pinctrl", l_1), ID("allwinner,sun9i-a80-r-pinctrl", l_3), + ID("allwinner,sun50i-a64-r-pinctrl", l_1), { } };
The Linux kernel driver for the Allwinner pin controller gained support for generic properties, which are now also used in the DTs. The sun8i-emac Ethernet driver for new Allwinner MACs reads the pins from the DT, but so far only supported the old binding. Update the parsing routine to cope with both the old and new bindings, so that the newer DTs can be used with U-Boot and its Ethernet driver.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- drivers/net/sun8i_emac.c | 52 ++++++++++++++++++++++++++++++++++++------------ 1 file changed, 39 insertions(+), 13 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 3ccc6b0bb6..df2b857310 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -21,6 +21,7 @@ #include <malloc.h> #include <miiphy.h> #include <net.h> +#include <dt-bindings/pinctrl/sun4i-a10.h> #ifdef CONFIG_DM_GPIO #include <asm-generic/gpio.h> #endif @@ -465,30 +466,55 @@ static int parse_phy_pins(struct udevice *dev) }
drive = fdt_getprop_u32_default_node(gd->fdt_blob, offset, 0, - "allwinner,drive", 4); - pull = fdt_getprop_u32_default_node(gd->fdt_blob, offset, 0, - "allwinner,pull", 0); + "drive-strength", ~0); + if (drive != ~0) { + if (drive <= 10) + drive = SUN4I_PINCTRL_10_MA; + else if (drive <= 20) + drive = SUN4I_PINCTRL_20_MA; + else if (drive <= 30) + drive = SUN4I_PINCTRL_30_MA; + else + drive = SUN4I_PINCTRL_40_MA; + } else { + drive = fdt_getprop_u32_default_node(gd->fdt_blob, offset, 0, + "allwinner,drive", 4); + } + + if (fdt_get_property(gd->fdt_blob, offset, "bias-pull-up", NULL)) + pull = SUN4I_PINCTRL_PULL_UP; + else if (fdt_get_property(gd->fdt_blob, offset, "bias-disable", NULL)) + pull = SUN4I_PINCTRL_NO_PULL; + else if (fdt_get_property(gd->fdt_blob, offset, "bias-pull-down", NULL)) + pull = SUN4I_PINCTRL_PULL_DOWN; + else + pull = fdt_getprop_u32_default_node(gd->fdt_blob, offset, 0, + "allwinner,pull", 0); for (i = 0; ; i++) { int pin;
pin_name = fdt_stringlist_get(gd->fdt_blob, offset, "allwinner,pins", i, NULL); - if (!pin_name) - break; - if (pin_name[0] != 'P') - continue; - pin = (pin_name[1] - 'A') << 5; - if (pin >= 26 << 5) + if (!pin_name) { + pin_name = fdt_stringlist_get(gd->fdt_blob, offset, + "pins", i, NULL); + if (!pin_name) + break; + } + + pin = sunxi_name_to_gpio(pin_name); + if (pin < 0) continue; - pin += simple_strtol(&pin_name[2], NULL, 10);
sunxi_gpio_set_cfgpin(pin, SUN8I_GPD8_GMAC); - sunxi_gpio_set_drv(pin, drive); - sunxi_gpio_set_pull(pin, pull); + if (drive != ~0) + sunxi_gpio_set_drv(pin, drive); + if (pull != ~0) + sunxi_gpio_set_pull(pin, pull); }
if (!i) { - printf("WARNING: emac: cannot find allwinner,pins property\n"); + printf("WARNING: emac: cannot find pins property\n"); return -2; }
The Ethernet MAC used in newer Allwinner SoCs (H3, A64, H5) got an upstream Linux driver in v4.15. This one uses a slightly different binding from the original one used by the U-Boot driver. The differences to the old binding are: - The "syscon" address is held in a separate node, referenced via a phandle in the "syscon" property. - The reference to the PHY is held in a property called "phy-handle", not "phy". - The PHY register is at offset 0x30 in the syscon device, not at 0. - The internal PHY is activated when the node, which phy-handle points to, is a child node of an "allwinner,sun8i-h3-mdio-internal" node.
Teach the U-Boot driver how to find its resources in a "new-style" DT, so that we can use a Linux kernel compatible DT for U-Boot as well. This keeps support for the old binding for now, to allow a smooth transition.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- drivers/net/sun8i_emac.c | 55 ++++++++++++++++++++++++++++++++++++++++++------ 1 file changed, 48 insertions(+), 7 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index df2b857310..4ba8959239 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -279,7 +279,7 @@ static int sun8i_emac_set_syscon(struct emac_eth_dev *priv) int ret; u32 reg;
- reg = readl(priv->sysctl_reg); + reg = readl(priv->sysctl_reg + 0x30);
if (priv->variant == H3_EMAC) { ret = sun8i_emac_set_syscon_ephy(priv, ®); @@ -310,7 +310,7 @@ static int sun8i_emac_set_syscon(struct emac_eth_dev *priv) return -EINVAL; }
- writel(reg, priv->sysctl_reg); + writel(reg, priv->sysctl_reg + 0x30);
return 0; } @@ -806,17 +806,50 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) #endif
pdata->iobase = devfdt_get_addr_name(dev, "emac"); + if (pdata->iobase == FDT_ADDR_T_NONE) + pdata->iobase = devfdt_get_addr(dev); + if (pdata->iobase == FDT_ADDR_T_NONE) { + debug("%s: Cannot find MAC base address\n", __func__); + return -EINVAL; + } + priv->sysctl_reg = devfdt_get_addr_name(dev, "syscon"); + if (priv->sysctl_reg == FDT_ADDR_T_NONE) { + const fdt32_t *reg; + + offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "syscon"); + if (offset < 0) { + debug("%s: cannot find syscon node\n", __func__); + return -EINVAL; + } + reg = fdt_getprop(gd->fdt_blob, offset, "reg", NULL); + if (!reg) { + debug("%s: cannot find reg property in syscon node\n", + __func__); + return -EINVAL; + } + priv->sysctl_reg = fdt_translate_address((void *)gd->fdt_blob, + offset, reg); + } else + priv->sysctl_reg -= 0x30; + if (priv->sysctl_reg == FDT_ADDR_T_NONE) { + debug("%s: Cannot find syscon base address\n", __func__); + return -EINVAL; + }
pdata->phy_interface = -1; priv->phyaddr = -1; priv->use_internal_phy = false;
- offset = fdtdec_lookup_phandle(gd->fdt_blob, node, - "phy"); - if (offset > 0) - priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", - -1); + offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "phy"); + if (offset < 0) + offset = fdtdec_lookup_phandle(gd->fdt_blob, node, + "phy-handle"); + if (offset < 0) { + debug("%s: Cannot find PHY address\n", __func__); + return -EINVAL; + } + priv->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, "reg", -1);
phy_mode = fdt_getprop(gd->fdt_blob, node, "phy-mode", NULL);
@@ -841,6 +874,14 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) if (fdt_getprop(gd->fdt_blob, node, "allwinner,use-internal-phy", NULL)) priv->use_internal_phy = true; + else { + int parent = fdt_parent_offset(gd->fdt_blob, offset); + + if (parent >= 0 && + !fdt_node_check_compatible(gd->fdt_blob, parent, + "allwinner,sun8i-h3-mdio-internal")) + priv->use_internal_phy = true; + } }
priv->interface = pdata->phy_interface;
The U-Boot driver for the sun8i-emac was using some preliminary DT binding. Now since Linux got its own driver in v4.15 and our driver can now cope with both bindings, let's convert the DT nodes used for the Pine64+ board over to the new bindings used by the kernel.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi | 51 +++++++++++++++---------- 1 file changed, 30 insertions(+), 21 deletions(-)
diff --git a/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi b/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi index 9c61beac01..32a263ce3d 100644 --- a/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi +++ b/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi @@ -4,25 +4,38 @@ };
soc { - emac: ethernet@01c30000 { + syscon: syscon@1c00000 { + compatible = "allwinner,sun50i-a64-system-controller", + "syscon"; + reg = <0x01c00000 0x1000>; + }; + + emac: ethernet@1c30000 { compatible = "allwinner,sun50i-a64-emac"; - reg = <0x01c30000 0x2000>, <0x01c00030 0x4>; - reg-names = "emac", "syscon"; + syscon = <&syscon>; + reg = <0x01c30000 0x10000>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; resets = <&ccu RST_BUS_EMAC>; - reset-names = "ahb"; + reset-names = "stmmaceth"; clocks = <&ccu CLK_BUS_EMAC>; - clock-names = "ahb"; + clock-names = "stmmaceth"; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&rgmii_pins>; phy-mode = "rgmii"; - phy = <&phy1>; + phy-handle = <&ext_rgmii_phy>; status = "okay";
- phy1: ethernet-phy@1 { - reg = <1>; + mdio: mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; }; }; }; @@ -30,21 +43,17 @@
&pio { rmii_pins: rmii_pins { - allwinner,pins = "PD10", "PD11", "PD13", "PD14", - "PD17", "PD18", "PD19", "PD20", - "PD22", "PD23"; - allwinner,function = "emac"; - allwinner,drive = <3>; - allwinner,pull = <0>; + pins = "PD10", "PD11", "PD13", "PD14", "PD17", + "PD18", "PD19", "PD20", "PD22", "PD23"; + function = "emac"; + drive-strength = <40>; };
rgmii_pins: rgmii_pins { - allwinner,pins = "PD8", "PD9", "PD10", "PD11", - "PD12", "PD13", "PD15", - "PD16", "PD17", "PD18", "PD19", - "PD20", "PD21", "PD22", "PD23"; - allwinner,function = "emac"; - allwinner,drive = <3>; - allwinner,pull = <0>; + pins = "PD8", "PD9", "PD10", "PD11", "PD12", + "PD13", "PD15", "PD16", "PD17", "PD18", + "PD19", "PD20", "PD21", "PD22", "PD23"; + function = "emac"; + drive-strength = <40>; }; };
The U-Boot driver for the sun8i-emac was using some preliminary DT binding. Now since Linux got its own driver in v4.15 and our driver can now cope with both bindings, let's convert the DT nodes used by the various H3 boards over to the new bindings used by the kernel.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts | 6 +-- arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts | 7 +-- arch/arm/dts/sun8i-h3-nanopi-neo.dts | 6 +-- arch/arm/dts/sun8i-h3-orangepi-2.dts | 7 +-- arch/arm/dts/sun8i-h3-orangepi-one.dts | 7 +-- arch/arm/dts/sun8i-h3-orangepi-pc.dts | 7 +-- arch/arm/dts/sun8i-h3-orangepi-plus.dts | 8 +++- arch/arm/dts/sun8i-h3-orangepi-plus2e.dts | 9 +++- arch/arm/dts/sun8i-h3.dtsi | 69 ++++++++++++++++++++------- 9 files changed, 75 insertions(+), 51 deletions(-)
diff --git a/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts b/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts index 20d489cb2a..e0efcb3ba3 100644 --- a/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts +++ b/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts @@ -100,14 +100,10 @@ };
&emac { - phy = <&phy1>; + phy-handle = <&int_mii_phy>; phy-mode = "mii"; - allwinner,use-internal-phy; allwinner,leds-active-low; status = "okay"; - phy1: ethernet-phy@1 { - reg = <1>; - }; };
&mmc0 { diff --git a/arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts b/arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts index 97b993f636..c8fd69f0a4 100644 --- a/arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts +++ b/arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts @@ -125,15 +125,10 @@ };
&emac { - phy = <&phy1>; + phy-handle = <&int_mii_phy>; phy-mode = "mii"; - allwinner,use-internal-phy; allwinner,leds-active-low; status = "okay"; - - phy1: ethernet-phy@1 { - reg = <1>; - }; };
&ir { diff --git a/arch/arm/dts/sun8i-h3-nanopi-neo.dts b/arch/arm/dts/sun8i-h3-nanopi-neo.dts index 5113059098..78f6c24952 100644 --- a/arch/arm/dts/sun8i-h3-nanopi-neo.dts +++ b/arch/arm/dts/sun8i-h3-nanopi-neo.dts @@ -48,12 +48,8 @@ };
&emac { - phy = <&phy1>; + phy-handle = <&int_mii_phy>; phy-mode = "mii"; - allwinner,use-internal-phy; allwinner,leds-active-low; status = "okay"; - phy1: ethernet-phy@1 { - reg = <1>; - }; }; diff --git a/arch/arm/dts/sun8i-h3-orangepi-2.dts b/arch/arm/dts/sun8i-h3-orangepi-2.dts index caa1a6959c..d97fdacb35 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-2.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-2.dts @@ -55,6 +55,7 @@ aliases { serial0 = &uart0; /* ethernet0 is the H3 emac, defined in sun8i-h3.dtsi */ + ethernet0 = &emac; ethernet1 = &rtl8189; };
@@ -110,14 +111,10 @@ };
&ir { diff --git a/arch/arm/dts/sun8i-h3-orangepi-one.dts b/arch/arm/dts/sun8i-h3-orangepi-one.dts index 8df5c74f04..adab1cbfc9 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-one.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-one.dts @@ -53,6 +53,7 @@ compatible = "xunlong,orangepi-one", "allwinner,sun8i-h3";
aliases { + ethernet0 = &emac; serial0 = &uart0; };
@@ -95,14 +96,10 @@ };
&mmc0 { diff --git a/arch/arm/dts/sun8i-h3-orangepi-pc.dts b/arch/arm/dts/sun8i-h3-orangepi-pc.dts index b8340f74e7..afba264ea5 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-pc.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-pc.dts @@ -53,6 +53,7 @@ compatible = "xunlong,orangepi-pc", "allwinner,sun8i-h3";
@@ -167,12 +168,8 @@ };
&emac { - phy = <&phy1>; + phy-handle = <&int_mii_phy>; phy-mode = "mii"; - allwinner,use-internal-phy; allwinner,leds-active-low; status = "okay"; - phy1: ethernet-phy@1 { - reg = <1>; - }; }; diff --git a/arch/arm/dts/sun8i-h3-orangepi-plus.dts b/arch/arm/dts/sun8i-h3-orangepi-plus.dts index e7079b26bc..136e4414a4 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-plus.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-plus.dts @@ -82,7 +82,13 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-mode = "rgmii"; - /delete-property/allwinner,use-internal-phy; +}; + +&external_mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; };
&mmc2 { diff --git a/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts b/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts index f97b040b35..51aaf49b6d 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts @@ -69,8 +69,15 @@ pinctrl-names = "default"; pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; + phy-handle = <&ext_rgmii_phy>; phy-mode = "rgmii"; - /delete-property/allwinner,use-internal-phy; +}; + +&external_mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; };
&pio { diff --git a/arch/arm/dts/sun8i-h3.dtsi b/arch/arm/dts/sun8i-h3.dtsi index afa60793a2..39a6438ec4 100644 --- a/arch/arm/dts/sun8i-h3.dtsi +++ b/arch/arm/dts/sun8i-h3.dtsi @@ -144,9 +144,10 @@ #size-cells = <1>; ranges;
- syscon: syscon@01c00000 { - compatible = "allwinner,sun8i-h3-syscon","syscon"; - reg = <0x01c00000 0x34>; + syscon: syscon@1c00000 { + compatible = "allwinner,sun8i-h3-system-controller", + "syscon"; + reg = <0x01c00000 0x1000>; };
dma: dma-controller@01c02000 { @@ -339,15 +340,12 @@ interrupt-controller; #interrupt-cells = <3>;
- emac_rgmii_pins: emac0@0 { - allwinner,pins = "PD0", "PD1", "PD2", "PD3", - "PD4", "PD5", "PD7", - "PD8", "PD9", "PD10", - "PD12", "PD13", "PD15", - "PD16", "PD17"; - allwinner,function = "emac"; - allwinner,drive = <SUN4I_PINCTRL_40_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + emac_rgmii_pins: emac0 { + pins = "PD0", "PD1", "PD2", "PD3", "PD4", + "PD5", "PD7", "PD8", "PD9", "PD10", + "PD12", "PD13", "PD15", "PD16", "PD17"; + function = "emac"; + drive-strength = <40>; };
mmc0_pins_a: mmc0@0 { @@ -466,16 +464,51 @@
emac: ethernet@1c30000 { compatible = "allwinner,sun8i-h3-emac"; - reg = <0x01c30000 0x104>, <0x01c00030 0x4>; - reg-names = "emac", "syscon"; + syscon = <&syscon>; + reg = <0x01c30000 0x10000>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - resets = <&ccu RST_BUS_EMAC>, <&ccu RST_BUS_EPHY>; - reset-names = "ahb", "ephy"; - clocks = <&ccu CLK_BUS_EMAC>, <&ccu CLK_BUS_EPHY>; - clock-names = "ahb", "ephy"; + interrupt-names = "macirq"; + resets = <&ccu RST_BUS_EMAC>; + reset-names = "stmmaceth"; + clocks = <&ccu CLK_BUS_EMAC>; + clock-names = "stmmaceth"; #address-cells = <1>; #size-cells = <0>; status = "disabled"; + + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + }; + + mdio-mux { + compatible = "allwinner,sun8i-h3-mdio-mux"; + #address-cells = <1>; + #size-cells = <0>; + + mdio-parent-bus = <&mdio>; + /* Only one MDIO is usable at the time */ + internal_mdio: mdio@1 { + compatible = "allwinner,sun8i-h3-mdio-internal"; + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + int_mii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + clocks = <&ccu CLK_BUS_EPHY>; + resets = <&ccu RST_BUS_EPHY>; + }; + }; + + external_mdio: mdio@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; };
gic: interrupt-controller@01c81000 {
The U-Boot driver for the sun8i-emac was using some preliminary DT binding. Now since Linux got its own driver in v4.15 and our driver can now cope with both bindings, let's convert the DT nodes used by the OrangePi PC2 over to the new bindings used by the kernel.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-h5-orangepi-pc2.dts | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/sun50i-h5-orangepi-pc2.dts b/arch/arm/dts/sun50i-h5-orangepi-pc2.dts index 780d59a096..d1c347d2b8 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-pc2.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-pc2.dts @@ -108,10 +108,13 @@ pinctrl-names = "default"; pinctrl-0 = <&emac_rgmii_pins>; phy-mode = "rgmii"; - phy = <&phy1>; + phy-handle = <&ext_rgmii_phy>; status = "okay"; +};
- phy1: ethernet-phy@1 { +&external_mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; reg = <1>; }; };
The original DT binding used by U-Boot's sun8i-emac driver was not really agreed upon, and deviated from the "official" binding now used by the kernel. Since now all U-Boot users have been converted to the new binding, we can remove support for the old DT nodes from the driver.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- drivers/net/sun8i_emac.c | 78 ++++++++++++++++-------------------------------- 1 file changed, 26 insertions(+), 52 deletions(-)
diff --git a/drivers/net/sun8i_emac.c b/drivers/net/sun8i_emac.c index 4ba8959239..fd13b6bf95 100644 --- a/drivers/net/sun8i_emac.c +++ b/drivers/net/sun8i_emac.c @@ -456,7 +456,7 @@ static int parse_phy_pins(struct udevice *dev) { int offset; const char *pin_name; - int drive, pull, i; + int drive, pull = SUN4I_PINCTRL_NO_PULL, i;
offset = fdtdec_lookup_phandle(gd->fdt_blob, dev_of_offset(dev), "pinctrl-0"); @@ -476,31 +476,20 @@ static int parse_phy_pins(struct udevice *dev) drive = SUN4I_PINCTRL_30_MA; else drive = SUN4I_PINCTRL_40_MA; - } else { - drive = fdt_getprop_u32_default_node(gd->fdt_blob, offset, 0, - "allwinner,drive", 4); }
if (fdt_get_property(gd->fdt_blob, offset, "bias-pull-up", NULL)) pull = SUN4I_PINCTRL_PULL_UP; - else if (fdt_get_property(gd->fdt_blob, offset, "bias-disable", NULL)) - pull = SUN4I_PINCTRL_NO_PULL; else if (fdt_get_property(gd->fdt_blob, offset, "bias-pull-down", NULL)) pull = SUN4I_PINCTRL_PULL_DOWN; - else - pull = fdt_getprop_u32_default_node(gd->fdt_blob, offset, 0, - "allwinner,pull", 0); + for (i = 0; ; i++) { int pin;
pin_name = fdt_stringlist_get(gd->fdt_blob, offset, - "allwinner,pins", i, NULL); - if (!pin_name) { - pin_name = fdt_stringlist_get(gd->fdt_blob, offset, - "pins", i, NULL); - if (!pin_name) - break; - } + "pins", i, NULL); + if (!pin_name) + break;
pin = sunxi_name_to_gpio(pin_name); if (pin < 0) @@ -798,6 +787,7 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) struct eth_pdata *pdata = &sun8i_pdata->eth_pdata; struct emac_eth_dev *priv = dev_get_priv(dev); const char *phy_mode; + const fdt32_t *reg; int node = dev_of_offset(dev); int offset = 0; #ifdef CONFIG_DM_GPIO @@ -805,33 +795,25 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) int ret = 0; #endif
- pdata->iobase = devfdt_get_addr_name(dev, "emac"); - if (pdata->iobase == FDT_ADDR_T_NONE) - pdata->iobase = devfdt_get_addr(dev); + pdata->iobase = devfdt_get_addr(dev); if (pdata->iobase == FDT_ADDR_T_NONE) { debug("%s: Cannot find MAC base address\n", __func__); return -EINVAL; }
- priv->sysctl_reg = devfdt_get_addr_name(dev, "syscon"); - if (priv->sysctl_reg == FDT_ADDR_T_NONE) { - const fdt32_t *reg; - - offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "syscon"); - if (offset < 0) { - debug("%s: cannot find syscon node\n", __func__); - return -EINVAL; - } - reg = fdt_getprop(gd->fdt_blob, offset, "reg", NULL); - if (!reg) { - debug("%s: cannot find reg property in syscon node\n", - __func__); - return -EINVAL; - } - priv->sysctl_reg = fdt_translate_address((void *)gd->fdt_blob, - offset, reg); - } else - priv->sysctl_reg -= 0x30; + offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "syscon"); + if (offset < 0) { + debug("%s: cannot find syscon node\n", __func__); + return -EINVAL; + } + reg = fdt_getprop(gd->fdt_blob, offset, "reg", NULL); + if (!reg) { + debug("%s: cannot find reg property in syscon node\n", + __func__); + return -EINVAL; + } + priv->sysctl_reg = fdt_translate_address((void *)gd->fdt_blob, + offset, reg); if (priv->sysctl_reg == FDT_ADDR_T_NONE) { debug("%s: Cannot find syscon base address\n", __func__); return -EINVAL; @@ -841,10 +823,7 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) priv->phyaddr = -1; priv->use_internal_phy = false;
- offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "phy"); - if (offset < 0) - offset = fdtdec_lookup_phandle(gd->fdt_blob, node, - "phy-handle"); + offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "phy-handle"); if (offset < 0) { debug("%s: Cannot find PHY address\n", __func__); return -EINVAL; @@ -871,17 +850,12 @@ static int sun8i_emac_eth_ofdata_to_platdata(struct udevice *dev) }
if (priv->variant == H3_EMAC) { - if (fdt_getprop(gd->fdt_blob, node, - "allwinner,use-internal-phy", NULL)) - priv->use_internal_phy = true; - else { - int parent = fdt_parent_offset(gd->fdt_blob, offset); + int parent = fdt_parent_offset(gd->fdt_blob, offset);
- if (parent >= 0 && - !fdt_node_check_compatible(gd->fdt_blob, parent, - "allwinner,sun8i-h3-mdio-internal")) - priv->use_internal_phy = true; - } + if (parent >= 0 && + !fdt_node_check_compatible(gd->fdt_blob, parent, + "allwinner,sun8i-h3-mdio-internal")) + priv->use_internal_phy = true; }
Since the dawn of time for the Allwinner support in mainline U-Boot we store the environment to the SD card and write directly at 544KB from the beginning of the device. This leads to problems when the U-Boot proper image grows beyond 504KB and eventually overlaps. With one release of having the environment preferably in a FAT partition, let's now turn off the MMC variant fallback, so we get back all the space we need to implement features. In case someone desperately needs to turn direct MMC environment back on, let's move that to 896KB (128K below 1MB), so that we won't be easily limited anymore.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- env/Kconfig | 5 +++-- include/configs/sunxi-common.h | 2 +- 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/env/Kconfig b/env/Kconfig index a3c6298273..b404855542 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -152,7 +152,7 @@ config ENV_IS_IN_MMC bool "Environment in an MMC device" depends on !CHAIN_OF_TRUST depends on MMC - default y if ARCH_SUNXI + default y if ARCH_SUNXI && !ARM64 default y if ARCH_EXYNOS4 default y if MX6SX || MX7D default y if TEGRA30 || TEGRA124 @@ -443,7 +443,8 @@ config ENV_OFFSET hex "Environment Offset" depends on !ENV_IS_IN_UBI depends on !ENV_IS_NOWHERE - default 0x88000 if ARCH_SUNXI + default 0x88000 if ARCH_SUNXI && !ARM64 + default 0xe0000 if ARCH_SUNXI && ARM64 help Offset from the start of the device (or partition)
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index e4e7c22778..1c881286dd 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -148,7 +148,7 @@ * (CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)), but the value will be used * directly in a makefile, without the preprocessor expansion. */ -#define CONFIG_BOARD_SIZE_LIMIT 0x7e000 +#define CONFIG_BOARD_SIZE_LIMIT 0xd6000 #endif
#if CONFIG_MMC_SUNXI_SLOT_EXTRA != -1
- default y if ARCH_SUNXI && !ARM64
I'd go even further and remove it for everyone.
- default 0x88000 if ARCH_SUNXI && !ARM64
- default 0xe0000 if ARCH_SUNXI && ARM64
However, I'm not sure why that would be needed. I would rather keep the old value to have an easy fallback to the old environment, given that you disable a few things afterwards.
Maxime
Fine, if you say so!
Yeah, fair enough. Wasn't so sure about it anyway.
Cheers, Andre.
In January some commits were introduced to mitigate the U-Boot image size issues we encountered on sunxi builds. Now with the MMC environment removed we can bring them back, as we practically don't have a size limit anymore.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- cmd/Kconfig | 5 ----- drivers/video/Kconfig | 2 -- lib/Kconfig | 1 - 3 files changed, 8 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 136836d146..27086df09b 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -426,7 +426,6 @@ menu "Memory commands" config CMD_CRC32 bool "crc32" select HASH - default n if ARCH_SUNXI default y help Compute CRC32. @@ -568,7 +567,6 @@ config CMD_LZMADEC
config CMD_UNZIP bool "unzip" - default n if ARCH_SUNXI default y if CMD_BOOTI help Uncompress a zip-compressed memory region. @@ -780,14 +778,12 @@ config CMD_I2C
config CMD_LOADB bool "loadb" - default n if ARCH_SUNXI default y help Load a binary file over serial line.
config CMD_LOADS bool "loads" - default n if ARCH_SUNXI default y help Load an S-Record file over serial line @@ -1187,7 +1183,6 @@ config CMD_GETTIME # TODO: rename to CMD_SLEEP config CMD_MISC bool "sleep" - default n if ARCH_SUNXI default y help Delay execution for some time diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 2fc0defcd0..45a105db06 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -38,7 +38,6 @@ config BACKLIGHT_GPIO config VIDEO_BPP8 bool "Support 8-bit-per-pixel displays" depends on DM_VIDEO - default n if ARCH_SUNXI default y if DM_VIDEO help Support drawing text and bitmaps onto a 8-bit-per-pixel display. @@ -49,7 +48,6 @@ config VIDEO_BPP8 config VIDEO_BPP16 bool "Support 16-bit-per-pixel displays" depends on DM_VIDEO - default n if ARCH_SUNXI default y if DM_VIDEO help Support drawing text and bitmaps onto a 16-bit-per-pixel display. diff --git a/lib/Kconfig b/lib/Kconfig index 4fd41c4282..ab581f172f 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -66,7 +66,6 @@ config PANIC_HANG
config REGEX bool "Enable regular expression support" - default n if ARCH_SUNXI default y if NET help If this variable is defined, U-Boot is linked against the
Updates the device tree file from the the Linux tree as of v4.15-rc9, exactly Linux commit: commit 16416084e06e1ebff51a9e7721a8cc4ccc186f28 Author: Corentin Labbe clabbe.montjoie@gmail.com Date: Tue Oct 31 09:19:15 2017 +0100 arm64: dts: allwinner: add snps,dwmac-mdio compatible to emac/mdio
This also pulls in the newly required include files for the clock and reset bindings.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi | 61 ++----- arch/arm/dts/sun50i-a64.dtsi | 204 ++++++++++++++++++++---- include/dt-bindings/clock/sun8i-r-ccu.h | 59 +++++++ include/dt-bindings/reset/sun8i-r-ccu.h | 53 ++++++ 4 files changed, 299 insertions(+), 78 deletions(-) create mode 100644 include/dt-bindings/clock/sun8i-r-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-r-ccu.h
diff --git a/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi b/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi index 32a263ce3d..1b8aa3d8dc 100644 --- a/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi +++ b/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi @@ -2,58 +2,19 @@ aliases { ethernet0 = &emac; }; - - soc { - syscon: syscon@1c00000 { - compatible = "allwinner,sun50i-a64-system-controller", - "syscon"; - reg = <0x01c00000 0x1000>; - }; - - emac: ethernet@1c30000 { - compatible = "allwinner,sun50i-a64-emac"; - syscon = <&syscon>; - reg = <0x01c30000 0x10000>; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq"; - resets = <&ccu RST_BUS_EMAC>; - reset-names = "stmmaceth"; - clocks = <&ccu CLK_BUS_EMAC>; - clock-names = "stmmaceth"; - #address-cells = <1>; - #size-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - phy-mode = "rgmii"; - phy-handle = <&ext_rgmii_phy>; - status = "okay"; - - mdio: mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - ext_rgmii_phy: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; - }; - }; - }; };
-&pio { - rmii_pins: rmii_pins { - pins = "PD10", "PD11", "PD13", "PD14", "PD17", - "PD18", "PD19", "PD20", "PD22", "PD23"; - function = "emac"; - drive-strength = <40>; - }; +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + status = "okay"; +};
- rgmii_pins: rgmii_pins { - pins = "PD8", "PD9", "PD10", "PD11", "PD12", - "PD13", "PD15", "PD16", "PD17", "PD18", - "PD19", "PD20", "PD21", "PD22", "PD23"; - function = "emac"; - drive-strength = <40>; +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; }; }; diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index 65a344d9ce..d783d164b9 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -43,6 +43,7 @@ */
#include <dt-bindings/clock/sun50i-a64-ccu.h> +#include <dt-bindings/clock/sun8i-r-ccu.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/reset/sun50i-a64-ccu.h>
@@ -129,6 +130,23 @@ #size-cells = <1>; ranges;
+ syscon: syscon@1c00000 { + compatible = "allwinner,sun50i-a64-system-controller", + "syscon"; + reg = <0x01c00000 0x1000>; + }; + + dma: dma-controller@1c02000 { + compatible = "allwinner,sun50i-a64-dma"; + reg = <0x01c02000 0x1000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DMA>; + dma-channels = <8>; + dma-requests = <27>; + resets = <&ccu RST_BUS_DMA>; + #dma-cells = <1>; + }; + mmc0: mmc@1c0f000 { compatible = "allwinner,sun50i-a64-mmc"; reg = <0x01c0f000 0x1000>; @@ -171,7 +189,7 @@ #size-cells = <0>; };
- usb_otg: usb@01c19000 { + usb_otg: usb@1c19000 { compatible = "allwinner,sun8i-a33-musb"; reg = <0x01c19000 0x0400>; clocks = <&ccu CLK_BUS_OTG>; @@ -184,7 +202,7 @@ status = "disabled"; };
- usbphy: phy@01c19400 { + usbphy: phy@1c19400 { compatible = "allwinner,sun50i-a64-usb-phy"; reg = <0x01c19400 0x14>, <0x01c1a800 0x4>, @@ -204,7 +222,7 @@ #phy-cells = <1>; };
- ehci0: usb@01c1a000 { + ehci0: usb@1c1a000 { compatible = "allwinner,sun50i-a64-ehci", "generic-ehci"; reg = <0x01c1a000 0x100>; interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; @@ -216,7 +234,7 @@ status = "disabled"; };
- ohci0: usb@01c1a400 { + ohci0: usb@1c1a400 { compatible = "allwinner,sun50i-a64-ohci", "generic-ohci"; reg = <0x01c1a400 0x100>; interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; @@ -226,7 +244,7 @@ status = "disabled"; };
- ehci1: usb@01c1b000 { + ehci1: usb@1c1b000 { compatible = "allwinner,sun50i-a64-ehci", "generic-ehci"; reg = <0x01c1b000 0x100>; interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; @@ -240,7 +258,7 @@ status = "disabled"; };
- ohci1: usb@01c1b400 { + ohci1: usb@1c1b400 { compatible = "allwinner,sun50i-a64-ohci", "generic-ohci"; reg = <0x01c1b400 0x100>; interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; @@ -252,7 +270,7 @@ status = "disabled"; };
- ccu: clock@01c20000 { + ccu: clock@1c20000 { compatible = "allwinner,sun50i-a64-ccu"; reg = <0x01c20000 0x400>; clocks = <&osc24M>, <&osc32k>; @@ -303,7 +321,32 @@ bias-pull-up; };
- uart0_pins_a: uart0@0 { + rmii_pins: rmii_pins { + pins = "PD10", "PD11", "PD13", "PD14", "PD17", + "PD18", "PD19", "PD20", "PD22", "PD23"; + function = "emac"; + drive-strength = <40>; + }; + + rgmii_pins: rgmii_pins { + pins = "PD8", "PD9", "PD10", "PD11", "PD12", + "PD13", "PD15", "PD16", "PD17", "PD18", + "PD19", "PD20", "PD21", "PD22", "PD23"; + function = "emac"; + drive-strength = <40>; + }; + + spi0_pins: spi0 { + pins = "PC0", "PC1", "PC2", "PC3"; + function = "spi0"; + }; + + spi1_pins: spi1 { + pins = "PD0", "PD1", "PD2", "PD3"; + function = "spi1"; + }; + + uart0_pins_a: uart0 { pins = "PB8", "PB9"; function = "uart0"; }; @@ -317,6 +360,26 @@ pins = "PG8", "PG9"; function = "uart1"; }; + + uart2_pins: uart2-pins { + pins = "PB0", "PB1"; + function = "uart2"; + }; + + uart3_pins: uart3-pins { + pins = "PD0", "PD1"; + function = "uart3"; + }; + + uart4_pins: uart4-pins { + pins = "PD2", "PD3"; + function = "uart4"; + }; + + uart4_rts_cts_pins: uart4-rts-cts-pins { + pins = "PD4", "PD5"; + function = "uart4"; + }; };
uart0: serial@1c28000 { @@ -325,8 +388,8 @@ interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&ccu 67>; - resets = <&ccu 46>; + clocks = <&ccu CLK_BUS_UART0>; + resets = <&ccu RST_BUS_UART0>; status = "disabled"; };
@@ -336,8 +399,8 @@ interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&ccu 68>; - resets = <&ccu 47>; + clocks = <&ccu CLK_BUS_UART1>; + resets = <&ccu RST_BUS_UART1>; status = "disabled"; };
@@ -347,8 +410,8 @@ interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&ccu 69>; - resets = <&ccu 48>; + clocks = <&ccu CLK_BUS_UART2>; + resets = <&ccu RST_BUS_UART2>; status = "disabled"; };
@@ -358,8 +421,8 @@ interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&ccu 70>; - resets = <&ccu 49>; + clocks = <&ccu CLK_BUS_UART3>; + resets = <&ccu RST_BUS_UART3>; status = "disabled"; };
@@ -369,8 +432,8 @@ interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&ccu 71>; - resets = <&ccu 50>; + clocks = <&ccu CLK_BUS_UART4>; + resets = <&ccu RST_BUS_UART4>; status = "disabled"; };
@@ -378,8 +441,8 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2ac00 0x400>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu 63>; - resets = <&ccu 42>; + clocks = <&ccu CLK_BUS_I2C0>; + resets = <&ccu RST_BUS_I2C0>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -389,8 +452,8 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b000 0x400>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu 64>; - resets = <&ccu 43>; + clocks = <&ccu CLK_BUS_I2C1>; + resets = <&ccu RST_BUS_I2C1>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -400,11 +463,67 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b400 0x400>; interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu 65>; - resets = <&ccu 44>; + clocks = <&ccu CLK_BUS_I2C2>; + resets = <&ccu RST_BUS_I2C2>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + + spi0: spi@1c68000 { + compatible = "allwinner,sun8i-h3-spi"; + reg = <0x01c68000 0x1000>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>; + clock-names = "ahb", "mod"; + dmas = <&dma 23>, <&dma 23>; + dma-names = "rx", "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spi0_pins>; + resets = <&ccu RST_BUS_SPI0>; + status = "disabled"; + num-cs = <1>; + #address-cells = <1>; + #size-cells = <0>; + }; + + spi1: spi@1c69000 { + compatible = "allwinner,sun8i-h3-spi"; + reg = <0x01c69000 0x1000>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_SPI1>; + clock-names = "ahb", "mod"; + dmas = <&dma 24>, <&dma 24>; + dma-names = "rx", "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spi1_pins>; + resets = <&ccu RST_BUS_SPI1>; + status = "disabled"; + num-cs = <1>; + #address-cells = <1>; + #size-cells = <0>; + }; + + emac: ethernet@1c30000 { + compatible = "allwinner,sun50i-a64-emac"; + syscon = <&syscon>; + reg = <0x01c30000 0x10000>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + resets = <&ccu RST_BUS_EMAC>; + reset-names = "stmmaceth"; + clocks = <&ccu CLK_BUS_EMAC>; + clock-names = "stmmaceth"; status = "disabled"; #address-cells = <1>; #size-cells = <0>; + + mdio: mdio { + compatible = "snps,dwmac-mdio"; + #address-cells = <1>; + #size-cells = <0>; + }; };
gic: interrupt-controller@1c81000 { @@ -425,25 +544,54 @@ <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; };
+ r_intc: interrupt-controller@1f00c00 { + compatible = "allwinner,sun50i-a64-r-intc", + "allwinner,sun6i-a31-r-intc"; + interrupt-controller; + #interrupt-cells = <2>; + reg = <0x01f00c00 0x400>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + }; + r_ccu: clock@1f01400 { compatible = "allwinner,sun50i-a64-r-ccu"; reg = <0x01f01400 0x100>; - clocks = <&osc24M>, <&osc32k>, <&iosc>; - clock-names = "hosc", "losc", "iosc"; + clocks = <&osc24M>, <&osc32k>, <&iosc>, + <&ccu 11>; + clock-names = "hosc", "losc", "iosc", "pll-periph"; #clock-cells = <1>; #reset-cells = <1>; };
- r_pio: pinctrl@01f02c00 { + r_pio: pinctrl@1f02c00 { compatible = "allwinner,sun50i-a64-r-pinctrl"; reg = <0x01f02c00 0x400>; interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&r_ccu 3>, <&osc24M>, <&osc32k>; + clocks = <&r_ccu CLK_APB0_PIO>, <&osc24M>, <&osc32k>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <3>; interrupt-controller; #interrupt-cells = <3>; + + r_rsb_pins: rsb { + pins = "PL0", "PL1"; + function = "s_rsb"; + }; + }; + + r_rsb: rsb@1f03400 { + compatible = "allwinner,sun8i-a23-rsb"; + reg = <0x01f03400 0x400>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu 6>; + clock-frequency = <3000000>; + resets = <&r_ccu 2>; + pinctrl-names = "default"; + pinctrl-0 = <&r_rsb_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; }; }; }; diff --git a/include/dt-bindings/clock/sun8i-r-ccu.h b/include/dt-bindings/clock/sun8i-r-ccu.h new file mode 100644 index 0000000000..779d20aa0d --- /dev/null +++ b/include/dt-bindings/clock/sun8i-r-ccu.h @@ -0,0 +1,59 @@ +/* + * Copyright (c) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLK_SUN8I_R_CCU_H_ +#define _DT_BINDINGS_CLK_SUN8I_R_CCU_H_ + +#define CLK_AR100 0 + +#define CLK_APB0_PIO 3 +#define CLK_APB0_IR 4 +#define CLK_APB0_TIMER 5 +#define CLK_APB0_RSB 6 +#define CLK_APB0_UART 7 +/* 8 is reserved for CLK_APB0_W1 on A31 */ +#define CLK_APB0_I2C 9 +#define CLK_APB0_TWD 10 + +#define CLK_IR 11 + +#endif /* _DT_BINDINGS_CLK_SUN8I_R_CCU_H_ */ diff --git a/include/dt-bindings/reset/sun8i-r-ccu.h b/include/dt-bindings/reset/sun8i-r-ccu.h new file mode 100644 index 0000000000..4ba64f3d6f --- /dev/null +++ b/include/dt-bindings/reset/sun8i-r-ccu.h @@ -0,0 +1,53 @@ +/* + * Copyright (C) 2016 Icenowy Zheng icenowy@aosc.xyz + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_RST_SUN8I_R_CCU_H_ +#define _DT_BINDINGS_RST_SUN8I_R_CCU_H_ + +#define RST_APB0_IR 0 +#define RST_APB0_TIMER 1 +#define RST_APB0_RSB 2 +#define RST_APB0_UART 3 +/* 4 is reserved for RST_APB0_W1 on A31 */ +#define RST_APB0_I2C 5 + +#endif /* _DT_BINDINGS_RST_SUN8I_R_CCU_H_ */
Update the .dts files for the various boards with an Allwinner A64 SoC. This is as of v4.15-rc9, exactly Linux commit: commit bdfe4cebea11476d278b1b98dd0f7cdac8269d62 Author: Icenowy Zheng icenowy@aosc.io Date: Fri Nov 10 17:26:54 2017 +0800 arm64: allwinner: a64: add Ethernet PHY regulator for several boards
It updates the existing DT files, adds the newly added axp803.dtsi and removes our temporary kludge file to get Ethernet support in U-Boot.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/axp803.dtsi | 150 ++++++++++++++++++++ arch/arm/dts/sun50i-a64-bananapi-m64.dts | 161 +++++++++++++++++++-- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 108 ++++++++++++-- arch/arm/dts/sun50i-a64-olinuxino.dts | 131 +++++++++++++++-- arch/arm/dts/sun50i-a64-orangepi-win.dts | 7 +- arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi | 20 --- arch/arm/dts/sun50i-a64-pine64-plus.dts | 17 ++- arch/arm/dts/sun50i-a64-pine64.dts | 178 +++++++++++++++++++++++- 8 files changed, 716 insertions(+), 56 deletions(-) create mode 100644 arch/arm/dts/axp803.dtsi delete mode 100644 arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi
diff --git a/arch/arm/dts/axp803.dtsi b/arch/arm/dts/axp803.dtsi new file mode 100644 index 0000000000..ff8af52743 --- /dev/null +++ b/arch/arm/dts/axp803.dtsi @@ -0,0 +1,150 @@ +/* + * Copyright 2017 Icenowy Zheng icenowy@aosc.xyz + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/* + * AXP803 Integrated Power Management Chip + * http://files.pine64.org/doc/datasheet/pine64/AXP803_Datasheet_V1.0.pdf + */ + +&axp803 { + interrupt-controller; + #interrupt-cells = <1>; + + regulators { + /* Default work frequency for buck regulators */ + x-powers,dcdc-freq = <3000>; + + reg_aldo1: aldo1 { + regulator-name = "aldo1"; + }; + + reg_aldo2: aldo2 { + regulator-name = "aldo2"; + }; + + reg_aldo3: aldo3 { + regulator-name = "aldo3"; + }; + + reg_dc1sw: dc1sw { + regulator-name = "dc1sw"; + }; + + reg_dcdc1: dcdc1 { + regulator-name = "dcdc1"; + }; + + reg_dcdc2: dcdc2 { + regulator-name = "dcdc2"; + }; + + reg_dcdc3: dcdc3 { + regulator-name = "dcdc3"; + }; + + reg_dcdc4: dcdc4 { + regulator-name = "dcdc4"; + }; + + reg_dcdc5: dcdc5 { + regulator-name = "dcdc5"; + }; + + reg_dcdc6: dcdc6 { + regulator-name = "dcdc6"; + }; + + reg_dldo1: dldo1 { + regulator-name = "dldo1"; + }; + + reg_dldo2: dldo2 { + regulator-name = "dldo2"; + }; + + reg_dldo3: dldo3 { + regulator-name = "dldo3"; + }; + + reg_dldo4: dldo4 { + regulator-name = "dldo4"; + }; + + reg_eldo1: eldo1 { + regulator-name = "eldo1"; + }; + + reg_eldo2: eldo2 { + regulator-name = "eldo2"; + }; + + reg_eldo3: eldo3 { + regulator-name = "eldo3"; + }; + + reg_fldo1: fldo1 { + regulator-name = "fldo1"; + }; + + reg_fldo2: fldo2 { + regulator-name = "fldo2"; + }; + + reg_ldo_io0: ldo-io0 { + regulator-name = "ldo-io0"; + status = "disabled"; + }; + + reg_ldo_io1: ldo-io1 { + regulator-name = "ldo-io1"; + status = "disabled"; + }; + + reg_rtc_ldo: rtc-ldo { + /* RTC_LDO is a fixed, always-on regulator */ + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "rtc-ldo"; + }; + }; +}; diff --git a/arch/arm/dts/sun50i-a64-bananapi-m64.dts b/arch/arm/dts/sun50i-a64-bananapi-m64.dts index 02db114113..4a8d3f83a3 100644 --- a/arch/arm/dts/sun50i-a64-bananapi-m64.dts +++ b/arch/arm/dts/sun50i-a64-bananapi-m64.dts @@ -1,6 +1,5 @@ /* * Copyright (c) 2016 ARM Ltd. - * Copyright (C) 2017 Jagan Teki jteki@openedev.com * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual @@ -52,6 +51,7 @@ compatible = "sinovoip,bananapi-m64", "allwinner,sun50i-a64";
aliases { + ethernet0 = &emac; serial0 = &uart0; serial1 = &uart1; }; @@ -60,14 +60,25 @@ stdout-path = "serial0:115200n8"; };
- reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ }; };
+&ehci1 { + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_dc1sw>; + status = "okay"; +}; + &i2c1 { pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; @@ -78,10 +89,17 @@ bias-pull-up; };
+&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; - vmmc-supply = <®_vcc3v3>; + vmmc-supply = <®_dcdc1>; cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; cd-inverted; disable-wp; @@ -92,22 +110,143 @@ &mmc1 { pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; - vmmc-supply = <®_vcc3v3>; + vmmc-supply = <®_dldo2>; + vqmmc-supply = <®_dldo4>; + mmc-pwrseq = <&wifi_pwrseq>; bus-width = <4>; non-removable; status = "okay"; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <0 3 IRQ_TYPE_LEVEL_LOW>; /* PL3 */ + interrupt-names = "host-wake"; + }; };
&mmc2 { pinctrl-names = "default"; pinctrl-0 = <&mmc2_pins>; - vmmc-supply = <®_vcc3v3>; + vmmc-supply = <®_dcdc1>; bus-width = <8>; non-removable; cap-mmc-hw-reset; status = "okay"; };
+&ohci1 { + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +#include "axp803.dtsi" + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dc1sw { + regulator-name = "vcc-phy"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi-dsi"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +®_dldo4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-io"; +}; + +®_eldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +/* + * The A64 chip cannot work without this regulator off, although + * it seems to be only driving the AR100 core. + * Maybe we don't still know well about CPUs domain. + */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; @@ -119,3 +258,7 @@ pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; status = "okay"; }; + +&usbphy { + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-a64-nanopi-a64.dts b/arch/arm/dts/sun50i-a64-nanopi-a64.dts index 778636c73a..2beef9e6cb 100644 --- a/arch/arm/dts/sun50i-a64-nanopi-a64.dts +++ b/arch/arm/dts/sun50i-a64-nanopi-a64.dts @@ -57,13 +57,6 @@ chosen { stdout-path = "serial0:115200n8"; }; - - reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; };
&ehci0 { @@ -88,7 +81,7 @@ &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; - vmmc-supply = <®_vcc3v3>; + vmmc-supply = <®_dcdc1>; cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; cd-inverted; disable-wp; @@ -104,6 +97,105 @@ status = "okay"; };
+&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +#include "axp803.dtsi" + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-3v"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi-dsi"; +}; + +®_dldo4 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pg-wifi-io"; +}; + +®_eldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +/* + * The A64 chip cannot work without this regulator off, although + * it seems to be only driving the AR100 core. + * Maybe we don't still know well about CPUs domain. + */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; diff --git a/arch/arm/dts/sun50i-a64-olinuxino.dts b/arch/arm/dts/sun50i-a64-olinuxino.dts index 7bd4730c93..338e786155 100644 --- a/arch/arm/dts/sun50i-a64-olinuxino.dts +++ b/arch/arm/dts/sun50i-a64-olinuxino.dts @@ -57,19 +57,12 @@ chosen { stdout-path = "serial0:115200n8"; }; - - reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; };
&mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; - vmmc-supply = <®_vcc3v3>; + vmmc-supply = <®_dcdc1>; cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; cd-inverted; disable-wp; @@ -77,6 +70,128 @@ status = "okay"; };
+&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +#include "axp803.dtsi" + +®_aldo1 { + regulator-always-on; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vcc-pe"; +}; + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vcc-ddr3"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mipi"; +}; + +®_dldo3 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vcc-avdd-csi"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi-io"; +}; + +®_eldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_eldo2 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-dvdd-csi"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +/* + * The A64 chip cannot work without this regulator off, although + * it seems to be only driving the AR100 core. + * Maybe we don't still know well about CPUs domain. + */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; diff --git a/arch/arm/dts/sun50i-a64-orangepi-win.dts b/arch/arm/dts/sun50i-a64-orangepi-win.dts index cf76c35237..5f8ff4017d 100644 --- a/arch/arm/dts/sun50i-a64-orangepi-win.dts +++ b/arch/arm/dts/sun50i-a64-orangepi-win.dts @@ -67,7 +67,7 @@ };
&ehci1 { - status = "okay"; + status = "okay"; };
&mmc0 { @@ -80,7 +80,7 @@ };
&ohci1 { - status = "okay"; + status = "okay"; };
&uart0 { @@ -90,5 +90,6 @@ };
&usbphy { - status = "okay"; + status = "okay"; }; + diff --git a/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi b/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi deleted file mode 100644 index 1b8aa3d8dc..0000000000 --- a/arch/arm/dts/sun50i-a64-pine64-plus-u-boot.dtsi +++ /dev/null @@ -1,20 +0,0 @@ -/ { - aliases { - ethernet0 = &emac; - }; -}; - -&emac { - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - phy-mode = "rgmii"; - phy-handle = <&ext_rgmii_phy>; - status = "okay"; -}; - -&mdio { - ext_rgmii_phy: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; -}; diff --git a/arch/arm/dts/sun50i-a64-pine64-plus.dts b/arch/arm/dts/sun50i-a64-pine64-plus.dts index 790d14daaa..24f1aac366 100644 --- a/arch/arm/dts/sun50i-a64-pine64-plus.dts +++ b/arch/arm/dts/sun50i-a64-pine64-plus.dts @@ -46,5 +46,20 @@ model = "Pine64+"; compatible = "pine64,pine64-plus", "allwinner,sun50i-a64";
- /* TODO: Camera, Ethernet PHY, touchscreen, etc. */ + /* TODO: Camera, touchscreen, etc. */ +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + status = "okay"; +}; + +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; }; diff --git a/arch/arm/dts/sun50i-a64-pine64.dts b/arch/arm/dts/sun50i-a64-pine64.dts index c680ed385d..604cdaedac 100644 --- a/arch/arm/dts/sun50i-a64-pine64.dts +++ b/arch/arm/dts/sun50i-a64-pine64.dts @@ -51,25 +51,37 @@ compatible = "pine64,pine64", "allwinner,sun50i-a64";
aliases { + ethernet0 = &emac; serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + serial4 = &uart4; };
chosen { stdout-path = "serial0:115200n8"; }; +};
- reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; +&ehci0 { + status = "okay"; };
&ehci1 { status = "okay"; };
+&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rmii_pins>; + phy-mode = "rmii"; + phy-handle = <&ext_rmii_phy1>; + phy-supply = <®_dc1sw>; + status = "okay"; + +}; + &i2c1 { pinctrl-names = "default"; pinctrl-0 = <&i2c1_pins>; @@ -80,10 +92,17 @@ bias-pull-up; };
+&mdio { + ext_rmii_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; - vmmc-supply = <®_vcc3v3>; + vmmc-supply = <®_dcdc1>; cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; cd-inverted; disable-wp; @@ -91,16 +110,161 @@ status = "okay"; };
+&ohci0 { + status = "okay"; +}; + &ohci1 { status = "okay"; };
+&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +#include "axp803.dtsi" + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dc1sw { + regulator-name = "vcc-phy"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +/* + * The DRAM chips used by Pine64 boards are DDR3L-compatible, so they can + * work at 1.35V with less power consumption. + * As AXP803 DCDC5 cannot reach 1.35V accurately, use 1.36V instead. + */ +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1360000>; + regulator-max-microvolt = <1360000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mipi"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +®_eldo1 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "cpvdd"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +/* + * The A64 chip cannot work without this regulator off, although + * it seems to be only driving the AR100 core. + * Maybe we don't still know well about CPUs domain. + */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; + +/* On Exp and Euler connectors */ &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; status = "okay"; };
+/* On Wifi/BT connector, with RTS/CTS */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; + status = "disabled"; +}; + +/* On Pi-2 connector */ +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "disabled"; +}; + +/* On Euler connector */ +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>; + status = "disabled"; +}; + +/* On Euler connector, RTS/CTS optional */ +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins>; + status = "disabled"; +}; + &usb_otg { dr_mode = "host"; status = "okay";
Linux kernels before 4.12-rc1 don't know about the AXP803 PMIC, so can't enable the MMC driver with the current DT anymore, because that now depends on this regulator. To restore compatiblity with older kernels (where MMC worked fine without explicit AXP support), restore the former fixed-regulator. This is no technical disadvantage, as the MMC power rail is actually VDD-SYS, which drives most of the rest of the board, so can't be turned off anyway. To underline this, this DCDC1 rail is marked as "regulator-always-on" in the DT.
This reverts Linux commit 3f241bfa60bdc9c4fde63fa6664a8ce00fd668c6. Author: Jagan Teki jagan@amarulasolutions.com Date: Sat Aug 12 11:10:02 2017 +0530 arm64: allwinner: a64: pine64: Use dcdc1 regulator for mmc0
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-pine64.dts | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/sun50i-a64-pine64.dts b/arch/arm/dts/sun50i-a64-pine64.dts index 604cdaedac..122b5d8e54 100644 --- a/arch/arm/dts/sun50i-a64-pine64.dts +++ b/arch/arm/dts/sun50i-a64-pine64.dts @@ -62,6 +62,13 @@ chosen { stdout-path = "serial0:115200n8"; }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; };
&ehci0 { @@ -102,7 +109,7 @@ &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; - vmmc-supply = <®_dcdc1>; + vmmc-supply = <®_vcc3v3>; cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; cd-inverted; disable-wp;
Given that only I2C, USB and MMC were supported at the time, is it really worth it? There's a lot of incentive to move to a newer kernel given the minimal support it had at the time.
Maxime
Yeah, this is somewhat true, although serial, USB and MMC are somewhat enough if one uses a USB Ethernet or WiFi adapter. And the kernel choice might not always a decision of the user (thinking of distributions here). But I was actually unsure about this as well, and wanted to hear some opinions.
One thing that comes to mind is other OSes. Does anyone know how if for instance FreeBSD supports the AXP and its Linux bindings? The whole goal of this series is to allow booting OSes with U-Boot's DT copy ($fdtcontroladdr), so if this patch would make their life easier, it might be worth it.
Regarding the whole forward/backward compatibility: I clearly see the difficulty in coming up with a "perfect" DT from day one, especially for badly documented SoCs, where mainlining is driven by hobbyists. So I was wondering if we introduce a grace period, where we declare the DT "unstable" or "subject to incompatible changes" for some releases (not too many). In hindsight we might declare 4.12 the stable DT base for the A64, for instance. This would allow us to start upstreaming early, with a small feature set only (just serial + clocks + pinctrl, as for the H6). Additional features (PMIC) might then add small incompatibilities (like this one here), until we are reasonably confident about the DT. Does that sound useful?
So I am not insisting on this patch, but wanted to point out the problems that those seemingly innocent DT changes create and would be happy if we can at least try to avoid them in the future.
Cheers, Andre.
Kind of "staging" for DT ?
Yeah, somewhat, though I would like to see this moved out of the Linux context ;-) Actually this would also simplify collaboration with other stakeholders (U-Boot, *BSD, Your-toy-OS), as they can participate in the discussion without being bound to some particular release cycle or special upstreaming process. And ideally the DT would not be in the Linux tree in the first place, to not give people the idea of it being a "Linux config file".
Cheers, Andre.
On Fri, 2 Mar 2018 16:24:22 +0000 Andre Przywara andre.przywara@arm.com wrote:
Not yet but I started the work a few days ago and we should have a driver soon.
Cheers, Andre. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
I thought the DT was only about the hardware (and the firmware to some extent) and not about a particular implementation?
Well, yeah. It's one of reasons I listed when the DT stability was discussed. I'm glad we reached an agreement on this :)
On a more serious basis, while that would sound reasonable, there's also the issue that you're basically never done, so that period might extend indefinitely.
Even on the older SoCs that we first introduce 5 years ago we have to deal with remodelling the bindings, for mostly three reasons: - We have some bindings that we were aware were suboptimal, and the stability lockdown took us by surprise, and we got stuck with bindings no one really liked.
- We have been ignoring some issues for quite some time that will need to get fixed eventually. For example, the power domains in the A31 are in this situation: since we didn't have any device that would allow us to test it, and since we couldn't use the genpd code for the CPUs in Linux at the time, we don't have any power domains described. However, there will probably be a time where we will actually need it for example to deal with the GPU.
- We are still discovering some quirks that need to remodel the DT. The DMA bus offset is a good example of that.
For the first one, I guess you could say that it's a bullet we have to bite. No binding will ever be perfect, and we'll always have to remodel things as we discover new usecases.
However, the two others are really the one that prevent you from saying "that's it, we're done" at a particular moment in time.
Maxime
Linux kernels before 4.12-rc1 don't know about the AXP803 PMIC, so can't enable the MMC driver with the current DT anymore, because that now depends on a driver for this regulator. To restore compatiblity with older kernels (where MMC worked fine without explicit AXP support), restore the former fixed-regulator. This is no technical disadvantage, as the MMC power rail is actually VDD-SYS, which drives most of the rest of the board, so can't be turned off anyway. To underline this, this DCDC1 rail is marked as "regulator-always-on" in the DT. This affects the BananaPi-M64, NanoPi-A64, Olinuxo-A64.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-bananapi-m64.dts | 11 +++++++++-- arch/arm/dts/sun50i-a64-nanopi-a64.dts | 9 ++++++++- arch/arm/dts/sun50i-a64-olinuxino.dts | 9 ++++++++- 3 files changed, 25 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/sun50i-a64-bananapi-m64.dts b/arch/arm/dts/sun50i-a64-bananapi-m64.dts index 4a8d3f83a3..e84855d633 100644 --- a/arch/arm/dts/sun50i-a64-bananapi-m64.dts +++ b/arch/arm/dts/sun50i-a64-bananapi-m64.dts @@ -60,6 +60,13 @@ stdout-path = "serial0:115200n8"; };
+ reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + wifi_pwrseq: wifi_pwrseq { compatible = "mmc-pwrseq-simple"; reset-gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>; /* PL2 */ @@ -99,7 +106,7 @@ &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; - vmmc-supply = <®_dcdc1>; + vmmc-supply = <®_vcc3v3>; cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; cd-inverted; disable-wp; @@ -129,7 +136,7 @@ &mmc2 { pinctrl-names = "default"; pinctrl-0 = <&mmc2_pins>; - vmmc-supply = <®_dcdc1>; + vmmc-supply = <®_vcc3v3>; bus-width = <8>; non-removable; cap-mmc-hw-reset; diff --git a/arch/arm/dts/sun50i-a64-nanopi-a64.dts b/arch/arm/dts/sun50i-a64-nanopi-a64.dts index 2beef9e6cb..6dedbfe609 100644 --- a/arch/arm/dts/sun50i-a64-nanopi-a64.dts +++ b/arch/arm/dts/sun50i-a64-nanopi-a64.dts @@ -57,6 +57,13 @@ chosen { stdout-path = "serial0:115200n8"; }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; };
&ehci0 { @@ -81,7 +88,7 @@ &mmc0 { pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; - vmmc-supply = <®_dcdc1>; + vmmc-supply = <®_vcc3v3>; cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; cd-inverted; disable-wp; diff --git a/arch/arm/dts/sun50i-a64-olinuxino.dts b/arch/arm/dts/sun50i-a64-olinuxino.dts index 338e786155..c88ec4e281 100644 --- a/arch/arm/dts/sun50i-a64-olinuxino.dts +++ b/arch/arm/dts/sun50i-a64-olinuxino.dts @@ -57,12 +57,19 @@ chosen { stdout-path = "serial0:115200n8"; }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; };
Update the device tree files from the Linux tree as of: commit 776245ae02f63ba2b94596b892c597676e190e78 Author: Corentin Labbe clabbe.montjoie@gmail.com Date: Tue Oct 31 09:19:11 2017 +0100 ARM: dts: sunxi: h3/h5: represent the mdio switch used by sun8i-h3-emac
Since the H3 and H5 are very similar (aside from the actual ARM cores), they share most the SoC .dtsi and thus have to be updated together. One tiny change is the removal of the "arm/" prefix from the include path in the sun50i-h5.dtsi, which is needed because we don't share the same sophisticated DT directory layout of Linux. Also we need to (temporarily) fix up the BananaPi-M2 board .dts, to maintain bisectability.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-h5.dtsi | 36 +- arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts | 2 +- arch/arm/dts/sun8i-h3.dtsi | 521 ++------------------- arch/arm/dts/sunxi-h3-h5.dtsi | 698 +++++++++++++++++++++++++++++ 4 files changed, 766 insertions(+), 491 deletions(-) create mode 100644 arch/arm/dts/sunxi-h3-h5.dtsi
diff --git a/arch/arm/dts/sun50i-h5.dtsi b/arch/arm/dts/sun50i-h5.dtsi index c052f31131..18d45a96db 100644 --- a/arch/arm/dts/sun50i-h5.dtsi +++ b/arch/arm/dts/sun50i-h5.dtsi @@ -1,17 +1,17 @@ /* - * Copyright (c) 2016 ARM Ltd. + * Copyright (C) 2016 ARM Ltd. * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual * licensing only applies to this file, and not this project as a * whole. * - * a) This library is free software; you can redistribute it and/or + * a) This file is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of the * License, or (at your option) any later version. * - * This library is distributed in the hope that it will be useful, + * This file is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. @@ -40,24 +40,38 @@ * OTHER DEALINGS IN THE SOFTWARE. */
-#include "sun8i-h3.dtsi" +#include <sunxi-h3-h5.dtsi>
/ { cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu@0 { compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + reg = <0>; enable-method = "psci"; }; + cpu@1 { compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + reg = <1>; enable-method = "psci"; }; + cpu@2 { compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + reg = <2>; enable-method = "psci"; }; + cpu@3 { compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + reg = <3>; enable-method = "psci"; }; }; @@ -69,6 +83,14 @@
timer { compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 + (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; }; };
@@ -76,10 +98,6 @@ compatible = "allwinner,sun50i-h5-ccu"; };
-&gic { - compatible = "arm,gic-400"; -}; - &mmc0 { compatible = "allwinner,sun50i-h5-mmc", "allwinner,sun50i-a64-mmc"; @@ -104,6 +122,6 @@ &pio { interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; compatible = "allwinner,sun50i-h5-pinctrl"; }; diff --git a/arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts b/arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts index f3b1d5f6db..06fddaae8e 100644 --- a/arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts +++ b/arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts @@ -185,7 +185,7 @@
&uart1 { pinctrl-names = "default"; - pinctrl-0 = <&uart1_pins_a>; + pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; status = "okay"; };
diff --git a/arch/arm/dts/sun8i-h3.dtsi b/arch/arm/dts/sun8i-h3.dtsi index 39a6438ec4..b36f9f423c 100644 --- a/arch/arm/dts/sun8i-h3.dtsi +++ b/arch/arm/dts/sun8i-h3.dtsi @@ -40,20 +40,9 @@ * OTHER DEALINGS IN THE SOFTWARE. */
-#include "skeleton.dtsi" - -#include <dt-bindings/clock/sun8i-h3-ccu.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/pinctrl/sun4i-a10.h> -#include <dt-bindings/reset/sun8i-h3-ccu.h> +#include "sunxi-h3-h5.dtsi"
/ { - interrupt-parent = <&gic>; - - aliases { - ethernet0 = &emac; - }; - cpus { #address-cells = <1>; #size-cells = <0>; @@ -90,478 +79,48 @@ <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; }; +};
- clocks { - #address-cells = <1>; - #size-cells = <1>; - ranges; - - osc24M: osc24M_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <24000000>; - clock-output-names = "osc24M"; - }; - - osc32k: osc32k_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <32768>; - clock-output-names = "osc32k"; - }; - - apb0: apb0_clk { - compatible = "fixed-factor-clock"; - #clock-cells = <0>; - clock-div = <1>; - clock-mult = <1>; - clocks = <&osc24M>; - clock-output-names = "apb0"; - }; - - apb0_gates: clk@01f01428 { - compatible = "allwinner,sun8i-h3-apb0-gates-clk", - "allwinner,sun4i-a10-gates-clk"; - reg = <0x01f01428 0x4>; - #clock-cells = <1>; - clocks = <&apb0>; - clock-indices = <0>, <1>; - clock-output-names = "apb0_pio", "apb0_ir"; - }; - - ir_clk: ir_clk@01f01454 { - compatible = "allwinner,sun4i-a10-mod0-clk"; - reg = <0x01f01454 0x4>; - #clock-cells = <0>; - clocks = <&osc32k>, <&osc24M>; - clock-output-names = "ir"; - }; - }; - - soc { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges; - - syscon: syscon@1c00000 { - compatible = "allwinner,sun8i-h3-system-controller", - "syscon"; - reg = <0x01c00000 0x1000>; - }; - - dma: dma-controller@01c02000 { - compatible = "allwinner,sun8i-h3-dma"; - reg = <0x01c02000 0x1000>; - interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_DMA>; - resets = <&ccu RST_BUS_DMA>; - #dma-cells = <1>; - }; - - mmc0: mmc@01c0f000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; - reg = <0x01c0f000 0x1000>; - clocks = <&ccu CLK_BUS_MMC0>, - <&ccu CLK_MMC0>, - <&ccu CLK_MMC0_OUTPUT>, - <&ccu CLK_MMC0_SAMPLE>; - clock-names = "ahb", - "mmc", - "output", - "sample"; - resets = <&ccu RST_BUS_MMC0>; - reset-names = "ahb"; - interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - #address-cells = <1>; - #size-cells = <0>; - }; - - mmc1: mmc@01c10000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; - reg = <0x01c10000 0x1000>; - clocks = <&ccu CLK_BUS_MMC1>, - <&ccu CLK_MMC1>, - <&ccu CLK_MMC1_OUTPUT>, - <&ccu CLK_MMC1_SAMPLE>; - clock-names = "ahb", - "mmc", - "output", - "sample"; - resets = <&ccu RST_BUS_MMC1>; - reset-names = "ahb"; - interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - #address-cells = <1>; - #size-cells = <0>; - }; - - mmc2: mmc@01c11000 { - compatible = "allwinner,sun7i-a20-mmc", - "allwinner,sun5i-a13-mmc"; - reg = <0x01c11000 0x1000>; - clocks = <&ccu CLK_BUS_MMC2>, - <&ccu CLK_MMC2>, - <&ccu CLK_MMC2_OUTPUT>, - <&ccu CLK_MMC2_SAMPLE>; - clock-names = "ahb", - "mmc", - "output", - "sample"; - resets = <&ccu RST_BUS_MMC2>; - reset-names = "ahb"; - interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - #address-cells = <1>; - #size-cells = <0>; - }; - - usbphy: phy@01c19400 { - compatible = "allwinner,sun8i-h3-usb-phy"; - reg = <0x01c19400 0x2c>, - <0x01c1a800 0x4>, - <0x01c1b800 0x4>, - <0x01c1c800 0x4>, - <0x01c1d800 0x4>; - reg-names = "phy_ctrl", - "pmu0", - "pmu1", - "pmu2", - "pmu3"; - clocks = <&ccu CLK_USB_PHY0>, - <&ccu CLK_USB_PHY1>, - <&ccu CLK_USB_PHY2>, - <&ccu CLK_USB_PHY3>; - clock-names = "usb0_phy", - "usb1_phy", - "usb2_phy", - "usb3_phy"; - resets = <&ccu RST_USB_PHY0>, - <&ccu RST_USB_PHY1>, - <&ccu RST_USB_PHY2>, - <&ccu RST_USB_PHY3>; - reset-names = "usb0_reset", - "usb1_reset", - "usb2_reset", - "usb3_reset"; - status = "disabled"; - #phy-cells = <1>; - }; - - ehci1: usb@01c1b000 { - compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; - reg = <0x01c1b000 0x100>; - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_EHCI1>, <&ccu CLK_BUS_OHCI1>; - resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_BUS_OHCI1>; - phys = <&usbphy 1>; - phy-names = "usb"; - status = "disabled"; - }; - - ohci1: usb@01c1b400 { - compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; - reg = <0x01c1b400 0x100>; - interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_EHCI1>, <&ccu CLK_BUS_OHCI1>, - <&ccu CLK_USB_OHCI1>; - resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_BUS_OHCI1>; - phys = <&usbphy 1>; - phy-names = "usb"; - status = "disabled"; - }; - - ehci2: usb@01c1c000 { - compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; - reg = <0x01c1c000 0x100>; - interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_EHCI2>, <&ccu CLK_BUS_OHCI2>; - resets = <&ccu RST_BUS_EHCI2>, <&ccu RST_BUS_OHCI2>; - phys = <&usbphy 2>; - phy-names = "usb"; - status = "disabled"; - }; - - ohci2: usb@01c1c400 { - compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; - reg = <0x01c1c400 0x100>; - interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_EHCI2>, <&ccu CLK_BUS_OHCI2>, - <&ccu CLK_USB_OHCI2>; - resets = <&ccu RST_BUS_EHCI2>, <&ccu RST_BUS_OHCI2>; - phys = <&usbphy 2>; - phy-names = "usb"; - status = "disabled"; - }; - - ehci3: usb@01c1d000 { - compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; - reg = <0x01c1d000 0x100>; - interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_EHCI3>, <&ccu CLK_BUS_OHCI3>; - resets = <&ccu RST_BUS_EHCI3>, <&ccu RST_BUS_OHCI3>; - phys = <&usbphy 3>; - phy-names = "usb"; - status = "disabled"; - }; - - ohci3: usb@01c1d400 { - compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; - reg = <0x01c1d400 0x100>; - interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_EHCI3>, <&ccu CLK_BUS_OHCI3>, - <&ccu CLK_USB_OHCI3>; - resets = <&ccu RST_BUS_EHCI3>, <&ccu RST_BUS_OHCI3>; - phys = <&usbphy 3>; - phy-names = "usb"; - status = "disabled"; - }; - - ccu: clock@01c20000 { - compatible = "allwinner,sun8i-h3-ccu"; - reg = <0x01c20000 0x400>; - clocks = <&osc24M>, <&osc32k>; - clock-names = "hosc", "losc"; - #clock-cells = <1>; - #reset-cells = <1>; - }; - - pio: pinctrl@01c20800 { - compatible = "allwinner,sun8i-h3-pinctrl"; - reg = <0x01c20800 0x400>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_BUS_PIO>; - gpio-controller; - #gpio-cells = <3>; - interrupt-controller; - #interrupt-cells = <3>; - - emac_rgmii_pins: emac0 { - pins = "PD0", "PD1", "PD2", "PD3", "PD4", - "PD5", "PD7", "PD8", "PD9", "PD10", - "PD12", "PD13", "PD15", "PD16", "PD17"; - function = "emac"; - drive-strength = <40>; - }; - - mmc0_pins_a: mmc0@0 { - allwinner,pins = "PF0", "PF1", "PF2", "PF3", - "PF4", "PF5"; - allwinner,function = "mmc0"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - mmc0_cd_pin: mmc0_cd_pin@0 { - allwinner,pins = "PF6"; - allwinner,function = "gpio_in"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; - }; - - mmc1_pins_a: mmc1@0 { - allwinner,pins = "PG0", "PG1", "PG2", "PG3", - "PG4", "PG5"; - allwinner,function = "mmc1"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - mmc2_8bit_pins: mmc2_8bit { - allwinner,pins = "PC5", "PC6", "PC8", - "PC9", "PC10", "PC11", - "PC12", "PC13", "PC14", - "PC15", "PC16"; - allwinner,function = "mmc2"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart0_pins_a: uart0@0 { - allwinner,pins = "PA4", "PA5"; - allwinner,function = "uart0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart1_pins_a: uart1@0 { - allwinner,pins = "PG6", "PG7", "PG8", "PG9"; - allwinner,function = "uart1"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - }; - - timer@01c20c00 { - compatible = "allwinner,sun4i-a10-timer"; - reg = <0x01c20c00 0xa0>; - interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&osc24M>; - }; - - wdt0: watchdog@01c20ca0 { - compatible = "allwinner,sun6i-a31-wdt"; - reg = <0x01c20ca0 0x20>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - }; - - uart0: serial@01c28000 { - compatible = "snps,dw-apb-uart"; - reg = <0x01c28000 0x400>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <4>; - clocks = <&ccu CLK_BUS_UART0>; - resets = <&ccu RST_BUS_UART0>; - dmas = <&dma 6>, <&dma 6>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - uart1: serial@01c28400 { - compatible = "snps,dw-apb-uart"; - reg = <0x01c28400 0x400>; - interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <4>; - clocks = <&ccu CLK_BUS_UART1>; - resets = <&ccu RST_BUS_UART1>; - dmas = <&dma 7>, <&dma 7>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - uart2: serial@01c28800 { - compatible = "snps,dw-apb-uart"; - reg = <0x01c28800 0x400>; - interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <4>; - clocks = <&ccu CLK_BUS_UART2>; - resets = <&ccu RST_BUS_UART2>; - dmas = <&dma 8>, <&dma 8>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - uart3: serial@01c28c00 { - compatible = "snps,dw-apb-uart"; - reg = <0x01c28c00 0x400>; - interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - reg-shift = <2>; - reg-io-width = <4>; - clocks = <&ccu CLK_BUS_UART3>; - resets = <&ccu RST_BUS_UART3>; - dmas = <&dma 9>, <&dma 9>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - emac: ethernet@1c30000 { - compatible = "allwinner,sun8i-h3-emac"; - syscon = <&syscon>; - reg = <0x01c30000 0x10000>; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq"; - resets = <&ccu RST_BUS_EMAC>; - reset-names = "stmmaceth"; - clocks = <&ccu CLK_BUS_EMAC>; - clock-names = "stmmaceth"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - - mdio: mdio { - #address-cells = <1>; - #size-cells = <0>; - compatible = "snps,dwmac-mdio"; - }; - - mdio-mux { - compatible = "allwinner,sun8i-h3-mdio-mux"; - #address-cells = <1>; - #size-cells = <0>; - - mdio-parent-bus = <&mdio>; - /* Only one MDIO is usable at the time */ - internal_mdio: mdio@1 { - compatible = "allwinner,sun8i-h3-mdio-internal"; - reg = <1>; - #address-cells = <1>; - #size-cells = <0>; - - int_mii_phy: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - clocks = <&ccu CLK_BUS_EPHY>; - resets = <&ccu RST_BUS_EPHY>; - }; - }; - - external_mdio: mdio@2 { - reg = <2>; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - }; - - gic: interrupt-controller@01c81000 { - compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic"; - reg = <0x01c81000 0x1000>, - <0x01c82000 0x1000>, - <0x01c84000 0x2000>, - <0x01c86000 0x2000>; - interrupt-controller; - #interrupt-cells = <3>; - interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - }; - - rtc: rtc@01f00000 { - compatible = "allwinner,sun6i-a31-rtc"; - reg = <0x01f00000 0x54>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; - }; +&ccu { + compatible = "allwinner,sun8i-h3-ccu"; +};
- apb0_reset: reset@01f014b0 { - reg = <0x01f014b0 0x4>; - compatible = "allwinner,sun6i-a31-clock-reset"; - #reset-cells = <1>; - }; +&mmc0 { + compatible = "allwinner,sun7i-a20-mmc"; + clocks = <&ccu CLK_BUS_MMC0>, + <&ccu CLK_MMC0>, + <&ccu CLK_MMC0_OUTPUT>, + <&ccu CLK_MMC0_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; +};
- ir: ir@01f02000 { - compatible = "allwinner,sun5i-a13-ir"; - clocks = <&apb0_gates 1>, <&ir_clk>; - clock-names = "apb", "ir"; - resets = <&apb0_reset 1>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x01f02000 0x40>; - status = "disabled"; - }; +&mmc1 { + compatible = "allwinner,sun7i-a20-mmc"; + clocks = <&ccu CLK_BUS_MMC1>, + <&ccu CLK_MMC1>, + <&ccu CLK_MMC1_OUTPUT>, + <&ccu CLK_MMC1_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; +};
- r_pio: pinctrl@01f02c00 { - compatible = "allwinner,sun8i-h3-r-pinctrl"; - reg = <0x01f02c00 0x400>; - interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&apb0_gates 0>; - resets = <&apb0_reset 0>; - gpio-controller; - #gpio-cells = <3>; - interrupt-controller; - #interrupt-cells = <3>; +&mmc2 { + compatible = "allwinner,sun7i-a20-mmc"; + clocks = <&ccu CLK_BUS_MMC2>, + <&ccu CLK_MMC2>, + <&ccu CLK_MMC2_OUTPUT>, + <&ccu CLK_MMC2_SAMPLE>; + clock-names = "ahb", + "mmc", + "output", + "sample"; +};
- ir_pins_a: ir@0 { - allwinner,pins = "PL11"; - allwinner,function = "s_cir_rx"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - }; - }; +&pio { + compatible = "allwinner,sun8i-h3-pinctrl"; }; diff --git a/arch/arm/dts/sunxi-h3-h5.dtsi b/arch/arm/dts/sunxi-h3-h5.dtsi new file mode 100644 index 0000000000..8d40c00d64 --- /dev/null +++ b/arch/arm/dts/sunxi-h3-h5.dtsi @@ -0,0 +1,698 @@ +/* + * Copyright (C) 2015 Jens Kuske jenskuske@gmail.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/clock/sun8i-h3-ccu.h> +#include <dt-bindings/clock/sun8i-r-ccu.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/sun8i-h3-ccu.h> +#include <dt-bindings/reset/sun8i-r-ccu.h> + +/ { + interrupt-parent = <&gic>; + #address-cells = <1>; + #size-cells = <1>; + + clocks { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + osc24M: osc24M_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "osc24M"; + }; + + osc32k: osc32k_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "osc32k"; + }; + + iosc: internal-osc-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <16000000>; + clock-accuracy = <300000000>; + clock-output-names = "iosc"; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + syscon: syscon@1c00000 { + compatible = "allwinner,sun8i-h3-system-controller", + "syscon"; + reg = <0x01c00000 0x1000>; + }; + + dma: dma-controller@1c02000 { + compatible = "allwinner,sun8i-h3-dma"; + reg = <0x01c02000 0x1000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_DMA>; + resets = <&ccu RST_BUS_DMA>; + #dma-cells = <1>; + }; + + mmc0: mmc@1c0f000 { + /* compatible and clocks are in per SoC .dtsi file */ + reg = <0x01c0f000 0x1000>; + resets = <&ccu RST_BUS_MMC0>; + reset-names = "ahb"; + interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc1: mmc@1c10000 { + /* compatible and clocks are in per SoC .dtsi file */ + reg = <0x01c10000 0x1000>; + resets = <&ccu RST_BUS_MMC1>; + reset-names = "ahb"; + interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + mmc2: mmc@1c11000 { + /* compatible and clocks are in per SoC .dtsi file */ + reg = <0x01c11000 0x1000>; + resets = <&ccu RST_BUS_MMC2>; + reset-names = "ahb"; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + usb_otg: usb@1c19000 { + compatible = "allwinner,sun8i-h3-musb"; + reg = <0x01c19000 0x400>; + clocks = <&ccu CLK_BUS_OTG>; + resets = <&ccu RST_BUS_OTG>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@1c19400 { + compatible = "allwinner,sun8i-h3-usb-phy"; + reg = <0x01c19400 0x2c>, + <0x01c1a800 0x4>, + <0x01c1b800 0x4>, + <0x01c1c800 0x4>, + <0x01c1d800 0x4>; + reg-names = "phy_ctrl", + "pmu0", + "pmu1", + "pmu2", + "pmu3"; + clocks = <&ccu CLK_USB_PHY0>, + <&ccu CLK_USB_PHY1>, + <&ccu CLK_USB_PHY2>, + <&ccu CLK_USB_PHY3>; + clock-names = "usb0_phy", + "usb1_phy", + "usb2_phy", + "usb3_phy"; + resets = <&ccu RST_USB_PHY0>, + <&ccu RST_USB_PHY1>, + <&ccu RST_USB_PHY2>, + <&ccu RST_USB_PHY3>; + reset-names = "usb0_reset", + "usb1_reset", + "usb2_reset", + "usb3_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + + ehci0: usb@1c1a000 { + compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; + reg = <0x01c1a000 0x100>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>; + resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_BUS_OHCI0>; + status = "disabled"; + }; + + ohci0: usb@1c1a400 { + compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; + reg = <0x01c1a400 0x100>; + interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>, + <&ccu CLK_USB_OHCI0>; + resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_BUS_OHCI0>; + status = "disabled"; + }; + + ehci1: usb@1c1b000 { + compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; + reg = <0x01c1b000 0x100>; + interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI1>, <&ccu CLK_BUS_OHCI1>; + resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_BUS_OHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci1: usb@1c1b400 { + compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; + reg = <0x01c1b400 0x100>; + interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI1>, <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_BUS_OHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ehci2: usb@1c1c000 { + compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; + reg = <0x01c1c000 0x100>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI2>, <&ccu CLK_BUS_OHCI2>; + resets = <&ccu RST_BUS_EHCI2>, <&ccu RST_BUS_OHCI2>; + phys = <&usbphy 2>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci2: usb@1c1c400 { + compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; + reg = <0x01c1c400 0x100>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI2>, <&ccu CLK_BUS_OHCI2>, + <&ccu CLK_USB_OHCI2>; + resets = <&ccu RST_BUS_EHCI2>, <&ccu RST_BUS_OHCI2>; + phys = <&usbphy 2>; + phy-names = "usb"; + status = "disabled"; + }; + + ehci3: usb@1c1d000 { + compatible = "allwinner,sun8i-h3-ehci", "generic-ehci"; + reg = <0x01c1d000 0x100>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI3>, <&ccu CLK_BUS_OHCI3>; + resets = <&ccu RST_BUS_EHCI3>, <&ccu RST_BUS_OHCI3>; + phys = <&usbphy 3>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci3: usb@1c1d400 { + compatible = "allwinner,sun8i-h3-ohci", "generic-ohci"; + reg = <0x01c1d400 0x100>; + interrupts = <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_EHCI3>, <&ccu CLK_BUS_OHCI3>, + <&ccu CLK_USB_OHCI3>; + resets = <&ccu RST_BUS_EHCI3>, <&ccu RST_BUS_OHCI3>; + phys = <&usbphy 3>; + phy-names = "usb"; + status = "disabled"; + }; + + ccu: clock@1c20000 { + /* compatible is in per SoC .dtsi file */ + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc32k>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + pio: pinctrl@1c20800 { + /* compatible is in per SoC .dtsi file */ + reg = <0x01c20800 0x400>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_PIO>, <&osc24M>, <&osc32k>; + clock-names = "apb", "hosc", "losc"; + gpio-controller; + #gpio-cells = <3>; + interrupt-controller; + #interrupt-cells = <3>; + + emac_rgmii_pins: emac0 { + pins = "PD0", "PD1", "PD2", "PD3", "PD4", + "PD5", "PD7", "PD8", "PD9", "PD10", + "PD12", "PD13", "PD15", "PD16", "PD17"; + function = "emac"; + drive-strength = <40>; + }; + + i2c0_pins: i2c0 { + pins = "PA11", "PA12"; + function = "i2c0"; + }; + + i2c1_pins: i2c1 { + pins = "PA18", "PA19"; + function = "i2c1"; + }; + + i2c2_pins: i2c2 { + pins = "PE12", "PE13"; + function = "i2c2"; + }; + + mmc0_pins_a: mmc0 { + pins = "PF0", "PF1", "PF2", "PF3", + "PF4", "PF5"; + function = "mmc0"; + drive-strength = <30>; + bias-pull-up; + }; + + mmc0_cd_pin: mmc0_cd_pin { + pins = "PF6"; + function = "gpio_in"; + bias-pull-up; + }; + + mmc1_pins_a: mmc1 { + pins = "PG0", "PG1", "PG2", "PG3", + "PG4", "PG5"; + function = "mmc1"; + drive-strength = <30>; + bias-pull-up; + }; + + mmc2_8bit_pins: mmc2_8bit { + pins = "PC5", "PC6", "PC8", + "PC9", "PC10", "PC11", + "PC12", "PC13", "PC14", + "PC15", "PC16"; + function = "mmc2"; + drive-strength = <30>; + bias-pull-up; + }; + + spdif_tx_pins_a: spdif { + pins = "PA17"; + function = "spdif"; + }; + + spi0_pins: spi0 { + pins = "PC0", "PC1", "PC2", "PC3"; + function = "spi0"; + }; + + spi1_pins: spi1 { + pins = "PA15", "PA16", "PA14", "PA13"; + function = "spi1"; + }; + + uart0_pins_a: uart0 { + pins = "PA4", "PA5"; + function = "uart0"; + }; + + uart1_pins: uart1 { + pins = "PG6", "PG7"; + function = "uart1"; + }; + + uart1_rts_cts_pins: uart1_rts_cts { + pins = "PG8", "PG9"; + function = "uart1"; + }; + + uart2_pins: uart2 { + pins = "PA0", "PA1"; + function = "uart2"; + }; + + uart3_pins: uart3 { + pins = "PA13", "PA14"; + function = "uart3"; + }; + + uart3_rts_cts_pins: uart3_rts_cts { + pins = "PA15", "PA16"; + function = "uart3"; + }; + }; + + timer@1c20c00 { + compatible = "allwinner,sun4i-a10-timer"; + reg = <0x01c20c00 0xa0>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; + }; + + emac: ethernet@1c30000 { + compatible = "allwinner,sun8i-h3-emac"; + syscon = <&syscon>; + reg = <0x01c30000 0x10000>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + resets = <&ccu RST_BUS_EMAC>; + reset-names = "stmmaceth"; + clocks = <&ccu CLK_BUS_EMAC>; + clock-names = "stmmaceth"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + + mdio: mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + }; + + mdio-mux { + compatible = "allwinner,sun8i-h3-mdio-mux"; + #address-cells = <1>; + #size-cells = <0>; + + mdio-parent-bus = <&mdio>; + /* Only one MDIO is usable at the time */ + internal_mdio: mdio@1 { + compatible = "allwinner,sun8i-h3-mdio-internal"; + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + int_mii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + clocks = <&ccu CLK_BUS_EPHY>; + resets = <&ccu RST_BUS_EPHY>; + }; + }; + + external_mdio: mdio@2 { + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + }; + + spi0: spi@1c68000 { + compatible = "allwinner,sun8i-h3-spi"; + reg = <0x01c68000 0x1000>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>; + clock-names = "ahb", "mod"; + dmas = <&dma 23>, <&dma 23>; + dma-names = "rx", "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spi0_pins>; + resets = <&ccu RST_BUS_SPI0>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + spi1: spi@1c69000 { + compatible = "allwinner,sun8i-h3-spi"; + reg = <0x01c69000 0x1000>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_SPI1>; + clock-names = "ahb", "mod"; + dmas = <&dma 24>, <&dma 24>; + dma-names = "rx", "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spi1_pins>; + resets = <&ccu RST_BUS_SPI1>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + wdt0: watchdog@1c20ca0 { + compatible = "allwinner,sun6i-a31-wdt"; + reg = <0x01c20ca0 0x20>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + }; + + spdif: spdif@1c21000 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-h3-spdif"; + reg = <0x01c21000 0x400>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPDIF>, <&ccu CLK_SPDIF>; + resets = <&ccu RST_BUS_SPDIF>; + clock-names = "apb", "spdif"; + dmas = <&dma 2>; + dma-names = "tx"; + status = "disabled"; + }; + + pwm: pwm@1c21400 { + compatible = "allwinner,sun8i-h3-pwm"; + reg = <0x01c21400 0x8>; + clocks = <&osc24M>; + #pwm-cells = <3>; + status = "disabled"; + }; + + i2s0: i2s@1c22000 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-h3-i2s"; + reg = <0x01c22000 0x400>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S0>, <&ccu CLK_I2S0>; + clock-names = "apb", "mod"; + dmas = <&dma 3>, <&dma 3>; + resets = <&ccu RST_BUS_I2S0>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + i2s1: i2s@1c22400 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-h3-i2s"; + reg = <0x01c22400 0x400>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S1>, <&ccu CLK_I2S1>; + clock-names = "apb", "mod"; + dmas = <&dma 4>, <&dma 4>; + resets = <&ccu RST_BUS_I2S1>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + codec: codec@1c22c00 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-h3-codec"; + reg = <0x01c22c00 0x400>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_CODEC>, <&ccu CLK_AC_DIG>; + clock-names = "apb", "codec"; + resets = <&ccu RST_BUS_CODEC>; + dmas = <&dma 15>, <&dma 15>; + dma-names = "rx", "tx"; + allwinner,codec-analog-controls = <&codec_analog>; + status = "disabled"; + }; + + uart0: serial@1c28000 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28000 0x400>; + interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART0>; + resets = <&ccu RST_BUS_UART0>; + dmas = <&dma 6>, <&dma 6>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart1: serial@1c28400 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28400 0x400>; + interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART1>; + resets = <&ccu RST_BUS_UART1>; + dmas = <&dma 7>, <&dma 7>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart2: serial@1c28800 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28800 0x400>; + interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART2>; + resets = <&ccu RST_BUS_UART2>; + dmas = <&dma 8>, <&dma 8>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + uart3: serial@1c28c00 { + compatible = "snps,dw-apb-uart"; + reg = <0x01c28c00 0x400>; + interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + clocks = <&ccu CLK_BUS_UART3>; + resets = <&ccu RST_BUS_UART3>; + dmas = <&dma 9>, <&dma 9>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + + i2c0: i2c@1c2ac00 { + compatible = "allwinner,sun6i-a31-i2c"; + reg = <0x01c2ac00 0x400>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C0>; + resets = <&ccu RST_BUS_I2C0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1: i2c@1c2b000 { + compatible = "allwinner,sun6i-a31-i2c"; + reg = <0x01c2b000 0x400>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C1>; + resets = <&ccu RST_BUS_I2C1>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c2: i2c@1c2b400 { + compatible = "allwinner,sun6i-a31-i2c"; + reg = <0x01c2b400 0x400>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C2>; + resets = <&ccu RST_BUS_I2C2>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + gic: interrupt-controller@1c81000 { + compatible = "arm,gic-400"; + reg = <0x01c81000 0x1000>, + <0x01c82000 0x2000>, + <0x01c84000 0x2000>, + <0x01c86000 0x2000>; + interrupt-controller; + #interrupt-cells = <3>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + }; + + rtc: rtc@1f00000 { + compatible = "allwinner,sun6i-a31-rtc"; + reg = <0x01f00000 0x54>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + }; + + r_ccu: clock@1f01400 { + compatible = "allwinner,sun8i-h3-r-ccu"; + reg = <0x01f01400 0x100>; + clocks = <&osc24M>, <&osc32k>, <&iosc>, + <&ccu 9>; + clock-names = "hosc", "losc", "iosc", "pll-periph"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + codec_analog: codec-analog@1f015c0 { + compatible = "allwinner,sun8i-h3-codec-analog"; + reg = <0x01f015c0 0x4>; + }; + + ir: ir@1f02000 { + compatible = "allwinner,sun5i-a13-ir"; + clocks = <&r_ccu CLK_APB0_IR>, <&r_ccu CLK_IR>; + clock-names = "apb", "ir"; + resets = <&r_ccu RST_APB0_IR>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + reg = <0x01f02000 0x40>; + status = "disabled"; + }; + + r_pio: pinctrl@1f02c00 { + compatible = "allwinner,sun8i-h3-r-pinctrl"; + reg = <0x01f02c00 0x400>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_APB0_PIO>, <&osc24M>, <&osc32k>; + clock-names = "apb", "hosc", "losc"; + gpio-controller; + #gpio-cells = <3>; + interrupt-controller; + #interrupt-cells = <3>; + + ir_pins_a: ir { + pins = "PL11"; + function = "s_cir_rx"; + }; + }; + }; +};
Update the .dts file for the various boards with an Allwinner H5 SoC. This is as of v4.15-rc9, exactly Linux commit: commit f88e9301948173dd35afad4a6939092c7f269aed Author: Sergey Matyukevich geomatsi@gmail.com Date: Fri Nov 3 22:58:54 2017 +0300 arm64: dts: orange-pi-zero-plus2: fix sdcard detect
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts | 105 ++++++++++++++-- arch/arm/dts/sun50i-h5-nanopi-neo2.dts | 89 +++++++++++-- arch/arm/dts/sun50i-h5-orangepi-pc2.dts | 165 +++++++++++++++++++------ arch/arm/dts/sun50i-h5-orangepi-prime.dts | 164 +++++++++++++++++++++--- arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts | 7 +- 5 files changed, 455 insertions(+), 75 deletions(-)
diff --git a/arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts b/arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts index f1406c224b..7c028af58f 100644 --- a/arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts +++ b/arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts @@ -1,18 +1,18 @@ /* * Copyright (C) 2017 Antony Antony antony@phenome.org - * Copyright (c) 2016 ARM Ltd. + * Copyright (C) 2016 ARM Ltd. * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual * licensing only applies to this file, and not this project as a * whole. * - * a) This library is free software; you can redistribute it and/or + * a) This file is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of the * License, or (at your option) any later version. * - * This library is distributed in the hope that it will be useful, + * This file is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. @@ -42,13 +42,14 @@ */
/dts-v1/; - #include "sun50i-h5.dtsi"
#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/pinctrl/sun4i-a10.h>
/ { - model = "FriendlyARM NanoPi NEO Plus 2"; + model = "FriendlyARM NanoPi NEO Plus2"; compatible = "friendlyarm,nanopi-neo-plus2", "allwinner,sun50i-h5";
aliases { @@ -59,15 +60,76 @@ stdout-path = "serial0:115200n8"; };
+ leds { + compatible = "gpio-leds"; + + pwr { + label = "nanopi:green:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + status { + label = "nanopi:red:status"; + gpios = <&pio 0 20 GPIO_ACTIVE_HIGH>; + }; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; + }; + reg_vcc3v3: vcc3v3 { compatible = "regulator-fixed"; regulator-name = "vcc3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; }; + + vdd_cpux: gpio-regulator { + compatible = "regulator-gpio"; + pinctrl-names = "default"; + regulator-name = "vdd-cpux"; + regulator-type = "voltage"; + regulator-boot-on; + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1300000>; + regulator-ramp-delay = <50>; /* 4ms */ + gpios = <&r_pio 0 6 GPIO_ACTIVE_HIGH>; + gpios-states = <0x1>; + states = <1100000 0x0 + 1300000 0x1>; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + pinctrl-names = "default"; + reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */ + post-power-on-delay-ms = <200>; + }; };
-&ehci1 { +&codec { + allwinner,audio-routing = + "Line Out", "LINEOUT", + "MIC1", "Mic", + "Mic", "MBIAS"; + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci3 { status = "okay"; };
@@ -76,11 +138,26 @@ pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; - cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; - cd-inverted; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ status = "okay"; };
+&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins_a>; + vmmc-supply = <®_vcc3v3>; + vqmmc-supply = <®_vcc3v3>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + }; +}; + &mmc2 { pinctrl-names = "default"; pinctrl-0 = <&mmc2_8bit_pins>; @@ -91,7 +168,11 @@ status = "okay"; };
-&ohci1 { +&ohci0 { + status = "okay"; +}; + +&ohci3 { status = "okay"; };
@@ -101,6 +182,12 @@ status = "okay"; };
+&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + &usbphy { + /* USB Type-A ports' VBUS is always on */ status = "okay"; }; diff --git a/arch/arm/dts/sun50i-h5-nanopi-neo2.dts b/arch/arm/dts/sun50i-h5-nanopi-neo2.dts index c08af7881b..6eb8092d8e 100644 --- a/arch/arm/dts/sun50i-h5-nanopi-neo2.dts +++ b/arch/arm/dts/sun50i-h5-nanopi-neo2.dts @@ -1,18 +1,17 @@ /* * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.io - * Copyright (C) 2017 Jagan Teki jteki@openedev.com * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual * licensing only applies to this file, and not this project as a * whole. * - * a) This library is free software; you can redistribute it and/or + * a) This file is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of the * License, or (at your option) any later version. * - * This library is distributed in the hope that it will be useful, + * This file is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. @@ -42,7 +41,6 @@ */
#include <dt-bindings/gpio/gpio.h> @@ -52,6 +50,7 @@ compatible = "friendlyarm,nanopi-neo2", "allwinner,sun50i-h5";
aliases { + ethernet0 = &emac; serial0 = &uart0; };
@@ -59,18 +58,74 @@ stdout-path = "serial0:115200n8"; };
+ leds { + compatible = "gpio-leds"; + + pwr { + label = "nanopi:green:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + status { + label = "nanopi:blue:status"; + gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; + }; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; + }; + reg_vcc3v3: vcc3v3 { compatible = "regulator-fixed"; regulator-name = "vcc3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; }; + + reg_usb0_vbus: usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */ + status = "okay"; + }; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci3 { + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&emac_rgmii_pins>; + phy-supply = <®_gmac_3v3>; + phy-handle = <&ext_rgmii_phy>; + phy-mode = "rgmii"; + status = "okay"; +}; + +&external_mdio { + ext_rgmii_phy: ethernet-phy@7 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <7>; + }; };
&mmc0 { - compatible = "allwinner,sun50i-h5-mmc", - "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; vmmc-supply = <®_vcc3v3>; @@ -79,8 +134,28 @@ status = "okay"; };
+&ohci0 { + status = "okay"; +}; + +&ohci3 { + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; status = "okay"; }; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + /* USB Type-A port's VBUS is always on */ + usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ + usb0_vbus-supply = <®_usb0_vbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-h5-orangepi-pc2.dts b/arch/arm/dts/sun50i-h5-orangepi-pc2.dts index d1c347d2b8..a0ca925175 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-pc2.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-pc2.dts @@ -1,17 +1,17 @@ /* - * Copyright (c) 2016 ARM Ltd. + * Copyright (C) 2016 ARM Ltd. * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual * licensing only applies to this file, and not this project as a * whole. * - * a) This library is free software; you can redistribute it and/or + * a) This file is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of the * License, or (at your option) any later version. * - * This library is distributed in the hope that it will be useful, + * This file is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. @@ -41,74 +41,108 @@ */
/ { - model = "OrangePi PC 2"; - compatible = "xunlong,orangepi-pc-2", "allwinner,sun50i-h5"; + model = "Xunlong Orange Pi PC 2"; + compatible = "xunlong,orangepi-pc2", "allwinner,sun50i-h5"; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + aliases { + ethernet0 = &emac; + serial0 = &uart0; + };
- memory { - reg = <0x40000000 0x40000000>; - }; + leds { + compatible = "gpio-leds";
- aliases { - serial0 = &uart0; - ethernet0 = &emac; + pwr { + label = "orangepi:green:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + status { + label = "orangepi:red:status"; + gpios = <&pio 0 20 GPIO_ACTIVE_HIGH>; + }; };
- soc { - reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; + r-gpio-keys { + compatible = "gpio-keys"; + + sw4 { + label = "sw4"; + linux,code = <BTN_0>; + gpios = <&r_pio 0 3 GPIO_ACTIVE_LOW>; }; }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; + }; + + reg_usb0_vbus: usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */ + status = "okay"; + }; };
-&mmc0 { - compatible = "allwinner,sun50i-h5-mmc", - "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; - vmmc-supply = <®_vcc3v3>; - bus-width = <4>; - cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; - cd-inverted; +&codec { + allwinner,audio-routing = + "Line Out", "LINEOUT", + "MIC1", "Mic", + "Mic", "MBIAS"; status = "okay"; };
-&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; +&ehci0 { status = "okay"; };
-&usbphy { +&ehci1 { status = "okay"; };
-&ohci1 { +&ehci2 { status = "okay"; };
-&ehci1 { +&ehci3 { status = "okay"; };
&emac { pinctrl-names = "default"; pinctrl-0 = <&emac_rgmii_pins>; - phy-mode = "rgmii"; + phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; + phy-mode = "rgmii"; status = "okay"; };
@@ -118,3 +152,64 @@ reg = <1>; }; }; + +&ir { + pinctrl-names = "default"; + pinctrl-0 = <&ir_pins_a>; + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&ohci2 { + status = "okay"; +}; + +&ohci3 { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "disabled"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "disabled"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + +&usbphy { + /* USB Type-A ports' VBUS is always on */ + usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ + usb0_vbus-supply = <®_usb0_vbus>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-h5-orangepi-prime.dts b/arch/arm/dts/sun50i-h5-orangepi-prime.dts index d4577dfae1..b477906501 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-prime.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-prime.dts @@ -1,17 +1,20 @@ /* - * Copyright (C) 2017 Jagan Teki jteki@openedev.com + * Copyright (C) 2017 Icenowy Zheng icenowy@aosc.xyz + * + * Based on sun50i-h5-orangepi-pc2.dts, which is: + * Copyright (C) 2016 ARM Ltd. * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual * licensing only applies to this file, and not this project as a * whole. * - * a) This library is free software; you can redistribute it and/or + * a) This file is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of the * License, or (at your option) any later version. * - * This library is distributed in the hope that it will be useful, + * This file is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. @@ -41,16 +44,17 @@ */
/ { - model = "OrangePi Prime"; + model = "Xunlong Orange Pi Prime"; compatible = "xunlong,orangepi-prime", "allwinner,sun50i-h5";
@@ -58,34 +62,130 @@ stdout-path = "serial0:115200n8"; };
- memory { - reg = <0x40000000 0x80000000>; + leds { + compatible = "gpio-leds"; + + pwr { + label = "orangepi:green:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + status { + label = "orangepi:red:status"; + gpios = <&pio 0 20 GPIO_ACTIVE_HIGH>; + }; };
- soc { - reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; + r-gpio-keys { + compatible = "gpio-keys"; + + sw4 { + label = "sw4"; + linux,code = <BTN_0>; + gpios = <&r_pio 0 3 GPIO_ACTIVE_LOW>; }; }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; + }; + + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_usb0_vbus: usb0-vbus { + compatible = "regulator-fixed"; + regulator-name = "usb0-vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */ + status = "okay"; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&pio 2 14 GPIO_ACTIVE_LOW>; /* PC14 */ + }; +}; + +&codec { + allwinner,audio-routing = + "Line Out", "LINEOUT", + "MIC1", "Mic", + "Mic", "MBIAS"; + status = "okay"; +}; + +&ehci0 { + status = "okay"; };
+&ehci2 { + status = "okay"; +}; + +&ehci3 { + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&emac_rgmii_pins>; + phy-supply = <®_gmac_3v3>; + phy-handle = <&ext_rgmii_phy>; + phy-mode = "rgmii"; + status = "okay"; +}; + +&external_mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + +&ir { + pinctrl-names = "default"; + pinctrl-0 = <&ir_pins_a>; + status = "okay"; +}; + &mmc0 { - compatible = "allwinner,sun50i-h5-mmc", - "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; - cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; - cd-inverted; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins_a>; + vmmc-supply = <®_vcc3v3>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; +}; + +&ohci0 { status = "okay"; };
@@ -93,12 +193,40 @@ status = "okay"; };
+&ohci2 { + status = "okay"; +}; + +&ohci3 { + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; status = "okay"; };
+&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "disabled"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "disabled"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { + /* USB Type-A ports' VBUS is always on */ + usb0_id_det-gpios = <&pio 0 21 GPIO_ACTIVE_HIGH>; /* PA21 */ + usb0_vbus-supply = <®_usb0_vbus>; status = "okay"; }; diff --git a/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts b/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts index 3f4baba310..a42fd79a62 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts @@ -46,7 +46,6 @@
- / { model = "OrangePi Zero Plus2"; compatible = "xunlong,orangepi-zero-plus2", "allwinner,sun50i-h5"; @@ -68,15 +67,11 @@ };
&mmc0 { - compatible = "allwinner,sun50i-h5-mmc", - "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>; vmmc-supply = <®_vcc3v3>; bus-width = <4>; - cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; - cd-inverted; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; status = "okay"; };
Update the .dts file for the various boards with an Allwinner H3 SoC. This is as of v4.15-rc9, exactly Linux commit: commit 4904337fe34fa7fc529d6f4d9ee8b96fe7db310a Author: Corentin Labbe clabbe.montjoie@gmail.com Date: Tue Oct 31 09:19:12 2017 +0100 ARM: dts: sunxi: Restore EMAC changes (boards)
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts | 76 +++++++++++++++++---------- arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts | 71 +++++++++++++++++++++++++ arch/arm/dts/sun8i-h3-nanopi-m1.dts | 6 +++ arch/arm/dts/sun8i-h3-nanopi-neo-air.dts | 1 - arch/arm/dts/sun8i-h3-orangepi-2.dts | 60 ++++++++++++--------- arch/arm/dts/sun8i-h3-orangepi-lite.dts | 25 ++++----- arch/arm/dts/sun8i-h3-orangepi-one.dts | 65 +++++++++++++++++------ arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts | 9 +++- arch/arm/dts/sun8i-h3-orangepi-pc.dts | 83 ++++++++++++++++++++++-------- arch/arm/dts/sun8i-h3-orangepi-plus.dts | 29 +++++------ arch/arm/dts/sun8i-h3-orangepi-plus2e.dts | 15 +----- 11 files changed, 302 insertions(+), 138 deletions(-)
diff --git a/arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts b/arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts index 06fddaae8e..f2292deaa5 100644 --- a/arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts +++ b/arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts @@ -46,13 +46,13 @@
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> -#include <dt-bindings/pinctrl/sun4i-a10.h>
/ { model = "Banana Pi BPI-M2-Plus"; compatible = "sinovoip,bpi-m2-plus", "allwinner,sun8i-h3";
aliases { + ethernet0 = &emac; serial0 = &uart0; serial1 = &uart1; }; @@ -64,7 +64,6 @@ leds { compatible = "gpio-leds"; pinctrl-names = "default"; - pinctrl-0 = <&pwr_led_bpi_m2p>;
pwr_led { label = "bananapi-m2-plus:red:pwr"; @@ -76,7 +75,6 @@ gpio_keys { compatible = "gpio-keys"; pinctrl-names = "default"; - pinctrl-0 = <&sw_r_bpi_m2p>;
sw4 { label = "power"; @@ -85,14 +83,27 @@ }; };
+ reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; + }; + wifi_pwrseq: wifi_pwrseq { compatible = "mmc-pwrseq-simple"; pinctrl-names = "default"; - pinctrl-0 = <&wifi_en_bpi_m2p>; reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */ }; };
+&ehci0 { + status = "okay"; +}; + &ehci1 { status = "okay"; }; @@ -101,6 +112,24 @@ status = "okay"; };
+&emac { + pinctrl-names = "default"; + pinctrl-0 = <&emac_rgmii_pins>; + phy-supply = <®_gmac_3v3>; + phy-handle = <&ext_rgmii_phy>; + phy-mode = "rgmii"; + + allwinner,leds-active-low; + status = "okay"; +}; + +&external_mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + }; +}; + &ir { pinctrl-names = "default"; pinctrl-0 = <&ir_pins_a>; @@ -127,7 +156,7 @@ non-removable; status = "okay";
- brcmf: bcrmf@1 { + brcmf: wifi@1 { reg = <1>; compatible = "brcm,bcm4329-fmac"; interrupt-parent = <&pio>; @@ -146,6 +175,10 @@ status = "okay"; };
+&ohci0 { + status = "okay"; +}; + &ohci1 { status = "okay"; }; @@ -154,27 +187,9 @@ status = "okay"; };
-&r_pio { - pwr_led_bpi_m2p: led_pins@0 { - allwinner,pins = "PL10"; - allwinner,function = "gpio_out"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - sw_r_bpi_m2p: key_pins@0 { - allwinner,pins = "PL3"; - allwinner,function = "gpio_in"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - wifi_en_bpi_m2p: wifi_en_pin { - allwinner,pins = "PL7"; - allwinner,function = "gpio_out"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; +®_usb0_vbus { + gpio = <&pio 3 11 GPIO_ACTIVE_HIGH>; /* PD11 */ + status = "okay"; };
&uart0 { @@ -189,7 +204,14 @@ status = "okay"; };
+&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { - /* USB VBUS is on as long as VCC-IO is on */ + usb0_id_det-gpios = <&r_pio 0 6 GPIO_ACTIVE_HIGH>; /* PL6 */ + usb0_vbus-supply = <®_usb0_vbus>; + /* USB host VBUS is on as long as VCC-IO is on */ status = "okay"; }; diff --git a/arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts b/arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts index 8ddd1b2cc0..0a8b79cf59 100644 --- a/arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts +++ b/arch/arm/dts/sun8i-h3-nanopi-m1-plus.dts @@ -45,6 +45,27 @@ / { model = "FriendlyArm NanoPi M1 Plus"; compatible = "friendlyarm,nanopi-m1-plus", "allwinner,sun8i-h3"; + + aliases { + serial1 = &uart3; + ethernet1 = &sdio_wifi; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + pinctrl-names = "default"; + reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */ + }; };
&ehci1 { @@ -55,6 +76,50 @@ status = "okay"; };
+&emac { + pinctrl-names = "default"; + pinctrl-0 = <&emac_rgmii_pins>; + phy-supply = <®_gmac_3v3>; + phy-handle = <&ext_rgmii_phy>; + phy-mode = "rgmii"; + + allwinner,leds-active-low; + + status = "okay"; +}; + +&external_mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <7>; + }; +}; + +&ir { + pinctrl-names = "default"; + pinctrl-0 = <&ir_pins_a>; + status = "okay"; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins_a>; + vmmc-supply = <®_vcc3v3>; + vqmmc-supply = <®_vcc3v3>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + sdio_wifi: sdio_wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&pio>; + interrupts = <6 10 IRQ_TYPE_LEVEL_LOW>; /* PG10 / EINT10 */ + interrupt-names = "host-wake"; + }; +}; + &ohci1 { status = "okay"; }; @@ -62,3 +127,9 @@ &ohci2 { status = "okay"; }; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>, <&uart3_rts_cts_pins>; + status = "okay"; +}; diff --git a/arch/arm/dts/sun8i-h3-nanopi-m1.dts b/arch/arm/dts/sun8i-h3-nanopi-m1.dts index ec63d104b4..3a2ccdb28a 100644 --- a/arch/arm/dts/sun8i-h3-nanopi-m1.dts +++ b/arch/arm/dts/sun8i-h3-nanopi-m1.dts @@ -55,6 +55,12 @@ status = "okay"; };
+&ir { + pinctrl-names = "default"; + pinctrl-0 = <&ir_pins_a>; + status = "okay"; +}; + &ohci1 { status = "okay"; }; diff --git a/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts b/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts index 3ba081c1f5..03ff6f8b93 100644 --- a/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts +++ b/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts @@ -45,7 +45,6 @@ #include "sunxi-common-regulators.dtsi"
#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/sun4i-a10.h>
/ { model = "FriendlyARM NanoPi NEO Air"; diff --git a/arch/arm/dts/sun8i-h3-orangepi-2.dts b/arch/arm/dts/sun8i-h3-orangepi-2.dts index d97fdacb35..b20be95b49 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-2.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-2.dts @@ -46,7 +46,6 @@
/ { model = "Xunlong Orange Pi 2"; @@ -106,6 +105,15 @@ }; };
+&codec { + allwinner,pa-gpios = <&pio 0 16 GPIO_ACTIVE_HIGH>; /* PA16 */ + allwinner,audio-routing = + "Speaker", "LINEOUT", + "MIC1", "Mic", + "Mic", "MBIAS"; + status = "okay"; +}; + &ehci1 { status = "okay"; }; @@ -152,34 +160,26 @@ };
&pio { - leds_opc: led_pins@0 { - allwinner,pins = "PA15"; - allwinner,function = "gpio_out"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + leds_opc: led_pins { + pins = "PA15"; + function = "gpio_out"; }; };
&r_pio { - leds_r_opc: led_pins@0 { - allwinner,pins = "PL10"; - allwinner,function = "gpio_out"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + leds_r_opc: led_pins { + pins = "PL10"; + function = "gpio_out"; };
- sw_r_opc: key_pins@0 { - allwinner,pins = "PL3", "PL4"; - allwinner,function = "gpio_in"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + sw_r_opc: key_pins { + pins = "PL3", "PL4"; + function = "gpio_in"; };
- wifi_pwrseq_pin_orangepi: wifi_pwrseq_pin@0 { - allwinner,pins = "PL7"; - allwinner,function = "gpio_out"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + wifi_pwrseq_pin_orangepi: wifi_pwrseq_pin { + pins = "PL7"; + function = "gpio_out"; }; };
@@ -194,8 +194,22 @@ status = "okay"; };
-&usb1_vbus_pin_a { - allwinner,pins = "PG13"; +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "disabled"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "disabled"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>; + status = "disabled"; };
&usbphy { diff --git a/arch/arm/dts/sun8i-h3-orangepi-lite.dts b/arch/arm/dts/sun8i-h3-orangepi-lite.dts index 1550fee1ec..a70a1daf4e 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-lite.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-lite.dts @@ -46,7 +46,6 @@
/ { model = "Xunlong Orange Pi Lite"; @@ -142,27 +141,21 @@ };
- sw_r_opc: key_pins@0 { - allwinner,pins = "PL3"; - allwinner,function = "gpio_in"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + sw_r_opc: key_pins { + pins = "PL3"; + function = "gpio_in"; }; };
diff --git a/arch/arm/dts/sun8i-h3-orangepi-one.dts b/arch/arm/dts/sun8i-h3-orangepi-one.dts index adab1cbfc9..82e5d28cd6 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-one.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-one.dts @@ -46,7 +46,6 @@
/ { model = "Xunlong Orange Pi One"; @@ -91,6 +90,10 @@ }; };
+&ehci0 { + status = "okay"; +}; + &ehci1 { status = "okay"; }; @@ -112,42 +115,70 @@ status = "okay"; };
+®_usb0_vbus { + gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */ + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; status = "okay"; };
+&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "disabled"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "disabled"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>; + status = "disabled"; +}; + +&usb_otg { + dr_mode = "otg"; + status = "okay"; +}; + &usbphy { - /* USB VBUS is always on */ + /* USB Type-A port's VBUS is always on */ + usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ + usb0_vbus-supply = <®_usb0_vbus>; status = "okay"; }; diff --git a/arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts b/arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts index 851fd2c2cc..a10281b455 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts @@ -53,6 +53,11 @@ }; };
+&emac { + /* LEDs changed to active high on the plus */ + /delete-property/ allwinner,leds-active-low; +}; + &mmc1 { pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins_a>; @@ -82,7 +87,7 @@
&mmc2_8bit_pins { /* Increase drive strength for DDR modes */ - allwinner,drive = <SUN4I_PINCTRL_40_MA>; + drive-strength = <40>; /* eMMC is missing pull-ups */ - allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; + bias-pull-up; }; diff --git a/arch/arm/dts/sun8i-h3-orangepi-pc.dts b/arch/arm/dts/sun8i-h3-orangepi-pc.dts index afba264ea5..d22546df1b 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-pc.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-pc.dts @@ -46,7 +46,6 @@
/ { model = "Xunlong Orange Pi PC"; @@ -91,6 +90,18 @@ }; };
+&codec { + allwinner,audio-routing = + "Line Out", "LINEOUT", + "MIC1", "Mic", + "Mic", "MBIAS"; + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + &ehci1 { status = "okay"; }; @@ -103,6 +114,13 @@ status = "okay"; };
+&emac { + phy-handle = <&int_mii_phy>; + phy-mode = "mii"; + allwinner,leds-active-low; + status = "okay"; +}; + &ir { pinctrl-names = "default"; pinctrl-0 = <&ir_pins_a>; @@ -119,6 +137,10 @@ status = "okay"; };
+&ohci0 { + status = "okay"; +}; + &ohci1 { status = "okay"; }; @@ -132,44 +154,61 @@ };
-&usbphy { - /* USB VBUS is always on */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "disabled"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "disabled"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>; + status = "disabled"; +}; + +&usb_otg { + dr_mode = "otg"; status = "okay"; };
-&emac { - phy-handle = <&int_mii_phy>; - phy-mode = "mii"; - allwinner,leds-active-low; +&usbphy { + usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ + usb0_vbus-supply = <®_usb0_vbus>; + /* VBUS on USB host ports are always on */ status = "okay"; }; diff --git a/arch/arm/dts/sun8i-h3-orangepi-plus.dts b/arch/arm/dts/sun8i-h3-orangepi-plus.dts index 136e4414a4..b403e5d787 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-plus.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-plus.dts @@ -47,10 +47,12 @@ model = "Xunlong Orange Pi Plus / Plus 2"; compatible = "xunlong,orangepi-plus", "allwinner,sun8i-h3";
+ aliases { + ethernet0 = &emac; + }; + reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_power_pin_orangepi>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; @@ -77,11 +79,13 @@ };
&emac { - /* The Orange Pi Plus uses an external phy */ pinctrl-names = "default"; pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; + phy-handle = <&ext_rgmii_phy>; phy-mode = "rgmii"; + + status = "okay"; };
&external_mdio { @@ -103,24 +107,15 @@
&pio { - gmac_power_pin_orangepi: gmac_power_pin@0 { - allwinner,pins = "PD6"; - allwinner,function = "gpio_out"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - usb3_vbus_pin_a: usb3_vbus_pin@0 { - allwinner,pins = "PG11"; - allwinner,function = "gpio_out"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + usb3_vbus_pin_a: usb3_vbus_pin { + pins = "PG11"; + function = "gpio_out"; }; };
diff --git a/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts b/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts index 51aaf49b6d..6dbf7b2e0c 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts @@ -53,24 +53,22 @@
reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac_power_pin_orangepi>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; startup-delay-us = <100000>; enable-active-high; - gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; /* PD6 */ }; };
&emac { - /* The Orange Pi Plus 2E uses an external gbit phy */ pinctrl-names = "default"; pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; phy-mode = "rgmii"; + status = "okay"; };
&external_mdio { @@ -79,12 +77,3 @@ reg = <1>; }; }; - -&pio { - gmac_power_pin_orangepi: gmac_power_pin@0 { - allwinner,pins = "PD6"; - allwinner,function = "gpio_out"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; -};
Update the board DT file to match the updated h3.dtsi base. This file is not (yet?) in Linux, so we can't update from there directly.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts b/arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts index c8fd69f0a4..cb3ecddb33 100644 --- a/arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts +++ b/arch/arm/dts/sun8i-h3-libretech-all-h3-cc.dts @@ -112,6 +112,10 @@ }; };
+&ehci0 { + status = "okay"; +}; + &ehci1 { status = "okay"; }; @@ -147,6 +151,10 @@ status = "okay"; };
Update the .dts file for the OrangePi Zero board, using the H2+ SoC. This is as of v4.15-rc9, exactly Linux commit: commit 4904337fe34fa7fc529d6f4d9ee8b96fe7db310a Author: Corentin Labbe clabbe.montjoie@gmail.com Date: Tue Oct 31 09:19:12 2017 +0100 ARM: dts: sunxi: Restore EMAC changes (boards)
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts | 52 ++++++++++++++++++++++++++-- 1 file changed, 50 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts b/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts index e0efcb3ba3..6713d0f2b3 100644 --- a/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts +++ b/arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts @@ -49,7 +49,6 @@
/ { model = "Xunlong Orange Pi Zero"; @@ -58,6 +57,7 @@ aliases { serial0 = &uart0; /* ethernet0 is the H3 emac, defined in sun8i-h3.dtsi */ + ethernet0 = &emac; ethernet1 = &xr819; };
@@ -92,9 +92,14 @@ wifi_pwrseq: wifi_pwrseq { compatible = "mmc-pwrseq-simple"; reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; + post-power-on-delay-ms = <200>; }; };
+&ehci0 { + status = "okay"; +}; + &ehci1 { status = "okay"; }; @@ -134,17 +139,60 @@ }; };
+&mmc1_pins_a { + bias-pull-up; +}; + +&ohci0 { + status = "okay"; +}; + &ohci1 { status = "okay"; };
+&spi0 { + /* Disable SPI NOR by default: it optional on Orange Pi Zero boards */ + status = "disabled"; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mxicy,mx25l1606e", "winbond,w25q128"; + reg = <0>; + spi-max-frequency = <40000000>; + }; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_a>; status = "okay"; };
+&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + status = "disabled"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "disabled"; +}; + +&usb_otg { + dr_mode = "peripheral"; + status = "okay"; +}; + &usbphy { - /* USB VBUS is always on */ + /* + * USB Type-A port VBUS is always on. However, MicroUSB VBUS can only + * power up the board; when it's used as OTG port, this VBUS is + * always off even if the board is powered via GPIO pins. + */ status = "okay"; + usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */ };
When the defconfig for the SoPine baseboard was added, there wasn't any proper DT for the board yet, so we used the Pine64 DT as a placeholder. Copy the DT file(s) meanwhile added in Linux over to U-Boot, and use them in our defconfig.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun50i-a64-sopine-baseboard.dts | 150 +++++++++++++++++++++++++++ arch/arm/dts/sun50i-a64-sopine.dtsi | 142 +++++++++++++++++++++++++ configs/sopine_baseboard_defconfig | 2 +- 4 files changed, 295 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/sun50i-a64-sopine-baseboard.dts create mode 100644 arch/arm/dts/sun50i-a64-sopine.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e9fe71431c..429c757fa0 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -367,7 +367,8 @@ dtb-$(CONFIG_MACH_SUN50I) += \ sun50i-a64-olinuxino.dtb \ sun50i-a64-orangepi-win.dtb \ sun50i-a64-pine64-plus.dtb \ - sun50i-a64-pine64.dtb + sun50i-a64-pine64.dtb \ + sun50i-a64-sopine-baseboard.dtb dtb-$(CONFIG_MACH_SUN9I) += \ sun9i-a80-optimus.dtb \ sun9i-a80-cubieboard4.dtb \ diff --git a/arch/arm/dts/sun50i-a64-sopine-baseboard.dts b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts new file mode 100644 index 0000000000..abe179de35 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-sopine-baseboard.dts @@ -0,0 +1,150 @@ +/* + * Copyright (c) 2017 Icenowy Zheng icenowy@aosc.xyz + * + * Based on sun50i-a64-pine64.dts, which is: + * Copyright (c) 2016 ARM Ltd. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include "sun50i-a64-sopine.dtsi" + +/ { + model = "SoPine with baseboard"; + compatible = "pine64,sopine-baseboard", "pine64,sopine", + "allwinner,sun50i-a64"; + + aliases { + ethernet0 = &emac; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + reg_vcc1v8: vcc1v8 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy-handle = <&ext_rgmii_phy>; + phy-supply = <®_dc1sw>; + status = "okay"; +}; + +&mdio { + ext_rgmii_phy: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + }; +}; + +&mmc2 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + vmmc-supply = <®_dcdc1>; + vqmmc-supply = <®_vcc1v8>; + bus-width = <8>; + non-removable; + cap-mmc-hw-reset; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +®_dc1sw { + regulator-name = "vcc-phy"; +}; + +®_dldo1 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-hdmi"; +}; + +®_dldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-mipi"; +}; + +®_dldo4 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-wifi"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-a64-sopine.dtsi b/arch/arm/dts/sun50i-a64-sopine.dtsi new file mode 100644 index 0000000000..43418bd881 --- /dev/null +++ b/arch/arm/dts/sun50i-a64-sopine.dtsi @@ -0,0 +1,142 @@ +/* + * Copyright (c) 2017 Icenowy Zheng icenowy@aosc.xyz + * + * Based on sun50i-a64-pine64.dts, which is: + * Copyright (c) 2016 ARM Ltd. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This library is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This library is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "sun50i-a64.dtsi" + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_dcdc1>; + non-removable; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&r_rsb { + status = "okay"; + + axp803: pmic@3a3 { + compatible = "x-powers,axp803"; + reg = <0x3a3>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +#include "axp803.dtsi" + +®_aldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl"; +}; + +®_aldo3 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "vcc-pll-avcc"; +}; + +®_dcdc1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-3v3"; +}; + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1040000>; + regulator-max-microvolt = <1300000>; + regulator-name = "vdd-cpux"; +}; + +/* DCDC3 is polyphased with DCDC2 */ + +®_dcdc5 { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-dram"; +}; + +®_dcdc6 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-sys"; +}; + +®_eldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vdd-1v8-lpddr"; +}; + +®_fldo1 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-1v2-hsic"; +}; + +/* + * The A64 chip cannot work without this regulator off, although + * it seems to be only driving the AR100 core. + * Maybe we don't still know well about CPUs domain. + */ +®_fldo2 { + regulator-always-on; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-name = "vdd-cpus"; +}; + +®_rtc_ldo { + regulator-name = "vcc-rtc"; +}; diff --git a/configs/sopine_baseboard_defconfig b/configs/sopine_baseboard_defconfig index 8ca43a6eac..cba392fb6c 100644 --- a/configs/sopine_baseboard_defconfig +++ b/configs/sopine_baseboard_defconfig @@ -9,7 +9,7 @@ CONFIG_DRAM_ZQ=3881949 CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-pine64-plus" +CONFIG_DEFAULT_DEVICE_TREE="sun50i-a64-sopine-baseboard" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y # CONFIG_CMD_FLASH is not set
On Fri, Mar 02, 2018 at 12:56:39AM +0000, Andre Przywara wrote:
This is an extended version of the EMAC DT binding update, this time including the full Linux DTs for all H3, H5 and A64 boards. Patch 01 should be merged *now*, to leave some hint in the README for the v2018.03 release. Without building ARM Trusted Firmware with DEBUG=0 many H5 boards and the Pine64 can't be built successfully at the moment.
The old v2 EMAC DT update series is in patches 02-08, it prepares U-Boot's EMAC driver for using the new DT binding used in Linux, also updates the DTs to the new EMAC DT node already.
This time I added patches to sync the whole U-Boot DT files for the mentioned SoCs with those from Linux. However this first requires lifting the space limit we currently have due to the raw MMC environment. Patch 09 disables that for 64 bit sunxi boards, to give us finally some space. Patch 10 consequently reverts the disabling of features we saw a few weeks ago to migitate the size problem.
Patches 11-20 then brings in the Linux DTs, split by SoCs, with the .dtsi files first, then the board files.
Merging the H3 and H5 device tree files brings in significant changes, also to the structure of the .dtsi files. However U-Boot's own DT usage is pretty limited, so it doesn't matter.
The huge benefit of syncing the DTs is that we can use U-Boot's DT copy to directly pass it to the kernel, avoiding to actually load a .dtb file from somewhere. To allows seamless and automatic UEFI booting, so distribution installer images should just work (TM).
As a goodie the final patch brings in the actual SoPine + baseboard DT files, which we were completely missing so far.
Please let me know if that looks good. I am happy to rearrange or squash patches, but I tried to avoid huge commits, for the sake of reviewability.
Apart from the comments on the two patches I already sent, Acked-by: Maxime Ripard maxime.ripard@bootlin.com
Maxime
Andre Przywara
Emmanuel Vadot
Maxime Ripard
Vincent Legoll
