[U-Boot] [PATCH v2 0/6] Add 3GiB DRAM support to 64-bit Allwinner SoCs
Allwinner 64-bit SoCs have allocated 3GiB space in the memory map for DRAM. If memory bigger than 3GiB is installed (as memory usually come as pow of 2 and they are not known to support 3GiB LPDDR3 modules, it means 4GiB memory is installed), the whole 3GiB space can be all used.
However, in many situations we still only defined 2GiB for the DRAM.
Add support for 3GiB DRAM. Tested on a customized Pine A64-LTS with 4GiB LPDDR3 memory installed.
Icenowy Zheng (6): sunxi: map DRAM part with 3G size on AArch64 sunxi: add Kconfig option for the maximum accessible DRAM sunxi: let sunxi_dram_init return unsigned long long sunxi: restrict the ram_size to the accessible range in SPL sunxi: add code for recalculating the DRAM size in U-Boot sunxi: add size recalculation code for common DesignWare DRAM driver
arch/arm/include/asm/arch-sunxi/dram.h | 5 ++++- arch/arm/mach-sunxi/Kconfig | 15 +++++++++++++++ arch/arm/mach-sunxi/Makefile | 2 +- arch/arm/mach-sunxi/board.c | 2 +- arch/arm/mach-sunxi/dram_sun6i.c | 2 +- arch/arm/mach-sunxi/dram_sun8i_a23.c | 2 +- arch/arm/mach-sunxi/dram_sun8i_a33.c | 2 +- arch/arm/mach-sunxi/dram_sun8i_a83t.c | 2 +- arch/arm/mach-sunxi/dram_sun9i.c | 4 ++-- arch/arm/mach-sunxi/dram_sunxi_dw.c | 30 +++++++++++++++++++++++++++--- board/sunxi/board.c | 21 +++++++++++++++++++-- board/sunxi/dram_sun4i_auto.c | 2 +- board/sunxi/dram_sun5i_auto.c | 2 +- 13 files changed, 75 insertions(+), 16 deletions(-)
All Allwinner 64-bit SoCs now are known to be able to access 3GiB of external DRAM, however the size of DRAM part in the MMU translation table is still 2GiB.
Change the size of DRAM part in MMU table to 3GiB.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- No changes in v2.
arch/arm/mach-sunxi/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 1753faec1d..89696e0890 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -53,7 +53,7 @@ static struct mm_region sunxi_mem_map[] = { /* RAM */ .virt = 0x40000000UL, .phys = 0x40000000UL, - .size = 0x80000000UL, + .size = 0xC0000000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE }, {
Allwinner 64-bit SoCs can use 4GiB DRAM chip, however their memory map has only allocated 3GiB for DRAM, so only 3GiB of the DRAM is accessible.
Add a Kconfig option for the maximum accessible DRAM.
For A80 it should be a much higher value (8GiB), but as I have no A80 device to test and originally U-Boot only supports 2GiB DRAM on A80, it currently still falls under the 2GiB situation.
arch/arm/mach-sunxi/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index b868f0e350..029821c82d 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -130,6 +130,13 @@ config MACH_SUNXI_H3_H5 select SUNXI_GEN_SUN6I select SUPPORT_SPL
+# TODO: try out A80's 8GiB DRAM space +config SUNXI_DRAM_MAX_SIZE + hex + default 0xC0000000 if MACH_SUN50I + default 0xC0000000 if MACH_SUN50I_H5 + default 0x80000000 + choice prompt "Sunxi SoC Variant" optional
How would that work in Linux?
I guess we have LPAE on armv7 to deal with this nicely.
Maxime
On Fri, Mar 23, 2018 at 5:39 PM, Maxime Ripard maxime.ripard@bootlin.com wrote:
AFAIK even though we do have LPAE, the hardware bus is not wired up to take advantage of it. :(
ChenYu
于 2018年3月23日 GMT+08:00 下午5:39:25, Maxime Ripard maxime.ripard@bootlin.com 写到:
map
From CPU's view only 3GiB DRAM is attached, so Linux can use the 3GiB space only.
Only the DRAM controller knows that 4GiB DRAM is connected :-)
it
Maxime
As 4GiB capacity is above the range of 32-bit unsigned integer, raise the return type of sunxi_dram_init() to unsigned long long, thus it can hold 4GiB capacity (or maybe more on A80).
Some controllers that are possible to use 4GiB+ memory module are also changed to calculate its memory capacity in unsigned long long.
arch/arm/include/asm/arch-sunxi/dram.h | 2 +- arch/arm/mach-sunxi/dram_sun6i.c | 2 +- arch/arm/mach-sunxi/dram_sun8i_a23.c | 2 +- arch/arm/mach-sunxi/dram_sun8i_a33.c | 2 +- arch/arm/mach-sunxi/dram_sun8i_a83t.c | 2 +- arch/arm/mach-sunxi/dram_sun9i.c | 4 ++-- arch/arm/mach-sunxi/dram_sunxi_dw.c | 4 ++-- board/sunxi/board.c | 2 +- board/sunxi/dram_sun4i_auto.c | 2 +- board/sunxi/dram_sun5i_auto.c | 2 +- 10 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/dram.h b/arch/arm/include/asm/arch-sunxi/dram.h index 80abac95b8..d08b82371d 100644 --- a/arch/arm/include/asm/arch-sunxi/dram.h +++ b/arch/arm/include/asm/arch-sunxi/dram.h @@ -32,7 +32,7 @@ #include <asm/arch/dram_sun4i.h> #endif
-unsigned long sunxi_dram_init(void); +unsigned long long sunxi_dram_init(void); void mctl_await_completion(u32 *reg, u32 mask, u32 val); bool mctl_mem_matches(u32 offset);
diff --git a/arch/arm/mach-sunxi/dram_sun6i.c b/arch/arm/mach-sunxi/dram_sun6i.c index 5dbbf6186f..bdf52a2c38 100644 --- a/arch/arm/mach-sunxi/dram_sun6i.c +++ b/arch/arm/mach-sunxi/dram_sun6i.c @@ -326,7 +326,7 @@ static void mctl_port_cfg(void) writel(0x00000307, &mctl_com->mbagcr[5]); }
-unsigned long sunxi_dram_init(void) +unsigned long long sunxi_dram_init(void) { struct sunxi_mctl_com_reg * const mctl_com = (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; diff --git a/arch/arm/mach-sunxi/dram_sun8i_a23.c b/arch/arm/mach-sunxi/dram_sun8i_a23.c index c53671a0e9..169ccff41a 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a23.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a23.c @@ -264,7 +264,7 @@ static void mctl_init(u32 *bus_width) writel(0x00000000, &mctl_ctl->rfshctl3); }
-unsigned long sunxi_dram_init(void) +unsigned long long sunxi_dram_init(void) { struct sunxi_mctl_com_reg * const mctl_com = (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; diff --git a/arch/arm/mach-sunxi/dram_sun8i_a33.c b/arch/arm/mach-sunxi/dram_sun8i_a33.c index fa1620cb39..dfbbe6f39c 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a33.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a33.c @@ -325,7 +325,7 @@ static void mctl_sys_init(struct dram_para *para) udelay(250); }
-unsigned long sunxi_dram_init(void) +unsigned long long sunxi_dram_init(void) { struct sunxi_mctl_com_reg * const mctl_com = (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; diff --git a/arch/arm/mach-sunxi/dram_sun8i_a83t.c b/arch/arm/mach-sunxi/dram_sun8i_a83t.c index 55df1b9d54..ec4bccd635 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a83t.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a83t.c @@ -423,7 +423,7 @@ static void mctl_sys_init(struct dram_para *para) udelay(250); }
-unsigned long sunxi_dram_init(void) +unsigned long long sunxi_dram_init(void) { struct sunxi_mctl_com_reg * const mctl_com = (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; diff --git a/arch/arm/mach-sunxi/dram_sun9i.c b/arch/arm/mach-sunxi/dram_sun9i.c index 8c681f3541..dcb20f763e 100644 --- a/arch/arm/mach-sunxi/dram_sun9i.c +++ b/arch/arm/mach-sunxi/dram_sun9i.c @@ -854,7 +854,7 @@ signed int DRAMC_get_dram_size(void) return 1 << dram_size; }
-unsigned long sunxi_dram_init(void) +unsigned long long sunxi_dram_init(void) { struct sunxi_mctl_com_reg * const mctl_com = (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; @@ -957,5 +957,5 @@ unsigned long sunxi_dram_init(void) mctl_com_init(¶);
/* return the proper RAM size */ - return DRAMC_get_dram_size() << 20; + return ((unsigned long long)DRAMC_get_dram_size()) << 20; } diff --git a/arch/arm/mach-sunxi/dram_sunxi_dw.c b/arch/arm/mach-sunxi/dram_sunxi_dw.c index 78b4ffb9c3..3bff1c46cd 100644 --- a/arch/arm/mach-sunxi/dram_sunxi_dw.c +++ b/arch/arm/mach-sunxi/dram_sunxi_dw.c @@ -682,7 +682,7 @@ static void mctl_auto_detect_dram_size(uint16_t socid, struct dram_para *para) 3, 3, 3, 3, 3, 3, 3, 3, \ 3, 3, 3, 3, 2, 0, 0 }
-unsigned long sunxi_dram_init(void) +unsigned long long sunxi_dram_init(void) { struct sunxi_mctl_com_reg * const mctl_com = (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; @@ -763,6 +763,6 @@ unsigned long sunxi_dram_init(void) mctl_auto_detect_dram_size(socid, ¶); mctl_set_cr(socid, ¶);
- return (1UL << (para.row_bits + para.bank_bits)) * para.page_size * + return (1ULL << (para.row_bits + para.bank_bits)) * para.page_size * (para.dual_rank ? 2 : 1); } diff --git a/board/sunxi/board.c b/board/sunxi/board.c index e08e22f30c..1c5e1f380a 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -578,7 +578,7 @@ void sunxi_board_init(void) #endif #endif printf("DRAM:"); - gd->ram_size = sunxi_dram_init(); + gd->ram_size = (phys_size_t)sunxi_dram_init(); printf(" %d MiB\n", (int)(gd->ram_size >> 20)); if (!gd->ram_size) hang(); diff --git a/board/sunxi/dram_sun4i_auto.c b/board/sunxi/dram_sun4i_auto.c index 7d4409b51e..293c968f6b 100644 --- a/board/sunxi/dram_sun4i_auto.c +++ b/board/sunxi/dram_sun4i_auto.c @@ -29,7 +29,7 @@ static struct dram_para dram_para = { .dqs_gating_delay = CONFIG_DRAM_DQS_GATING_DELAY, };
-unsigned long sunxi_dram_init(void) +unsigned long long sunxi_dram_init(void) { return dramc_init(&dram_para); } diff --git a/board/sunxi/dram_sun5i_auto.c b/board/sunxi/dram_sun5i_auto.c index e3fa243267..02e29b215f 100644 --- a/board/sunxi/dram_sun5i_auto.c +++ b/board/sunxi/dram_sun5i_auto.c @@ -32,7 +32,7 @@ static struct dram_para dram_para = { .dqs_gating_delay = CONFIG_DRAM_DQS_GATING_DELAY, };
On newer Allwinner SoCs with the BROM start at 0x0 and the DRAM space at <0x40000000 0xc0000000>, some parts of DRAM will be inaccessible when 4GiB module is used.
Restrict the ram_size written to global_data in SPL.
board/sunxi/board.c | 13 +++++++++++-- 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 1c5e1f380a..73dd41437d 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -518,6 +518,7 @@ int board_mmc_init(bd_t *bis) void sunxi_board_init(void) { int power_failed = 0; + unsigned long long dram_real_size;
#ifdef CONFIG_SY8106A_POWER power_failed = sy8106a_set_vout1(CONFIG_SY8106A_VOUT1_VOLT); @@ -578,8 +579,16 @@ void sunxi_board_init(void) #endif #endif printf("DRAM:"); - gd->ram_size = (phys_size_t)sunxi_dram_init(); - printf(" %d MiB\n", (int)(gd->ram_size >> 20)); + dram_real_size = sunxi_dram_init(); + printf(" %d MiB", (int)(dram_real_size >> 20)); + if (dram_real_size > CONFIG_SUNXI_DRAM_MAX_SIZE) { + gd->ram_size = CONFIG_SUNXI_DRAM_MAX_SIZE; + printf(", %d MiB usable\n", (int)(gd->ram_size >> 20)); + } else { + gd->ram_size = (phys_size_t)dram_real_size; + printf("\n"); + } + if (!gd->ram_size) hang();
No changes in v2.
- unsigned long long dram_real_size;
- dram_real_size = sunxi_dram_init();
- printf(" %d MiB", (int)(dram_real_size >> 20));
- if (dram_real_size > CONFIG_SUNXI_DRAM_MAX_SIZE) {
- } else {
printf("\n");
This really look like something that should be addressed generically and not in one board.
Maxime
The get_ram_size() function in U-Boot can only deal with memory size smaller than 2GiB. To enable the support of 3GiB DRAM on newer 64-bit SoCs, an alternative way to detect DRAM size is needed.
Add the possibility to use some DRAM size recalculating code in DRAM driver.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- New patch in v2.
arch/arm/include/asm/arch-sunxi/dram.h | 3 +++ arch/arm/mach-sunxi/Kconfig | 7 +++++++ board/sunxi/board.c | 8 ++++++++ 3 files changed, 18 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/dram.h b/arch/arm/include/asm/arch-sunxi/dram.h index d08b82371d..7443fc3507 100644 --- a/arch/arm/include/asm/arch-sunxi/dram.h +++ b/arch/arm/include/asm/arch-sunxi/dram.h @@ -35,5 +35,8 @@ unsigned long long sunxi_dram_init(void); void mctl_await_completion(u32 *reg, u32 mask, u32 val); bool mctl_mem_matches(u32 offset); +#if defined(CONFIG_DRAM_CAN_RECALCULATE_SIZE) +unsigned long long sunxi_dram_recalculate_size(void); +#endif
#endif /* _SUNXI_DRAM_H */ diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 029821c82d..b206472ead 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -6,6 +6,13 @@ config SPL_LDSCRIPT config IDENT_STRING default " Allwinner Technology"
+config DRAM_CAN_RECALCULATE_SIZE + bool + help + Select this if the DRAM controller driver is capable of + re-calculating the size in main U-Boot. It's usable for + size bigger than 2GiB. + config DRAM_SUN4I bool help diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 73dd41437d..96192a7ec3 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -256,7 +256,16 @@ int board_init(void)
int dram_init(void) { +#ifndef CONFIG_DRAM_CAN_RECALCULATE_SIZE gd->ram_size = get_ram_size((long *)PHYS_SDRAM_0, PHYS_SDRAM_0_SIZE); +#else + unsigned long long real_dram_size = sunxi_dram_recalculate_size(); + + if (real_dram_size > CONFIG_SUNXI_DRAM_MAX_SIZE) + gd->ram_size = CONFIG_SUNXI_DRAM_MAX_SIZE; + else + gd->ram_size = (phys_size_t)real_dram_size; +#endif
return 0; }
Why not just fixing get_ram_size then?
Maxime
于 2018年3月23日 GMT+08:00 下午5:40:41, Maxime Ripard maxime.ripard@bootlin.com 写到:
Even if it's fixed it won't support 3GiB DRAM at all.
Maxime
Why?
Maxime
于 2018年3月26日 GMT+08:00 下午3:06:33, Maxime Ripard maxime.ripard@bootlin.com 写到:
size
64-bit
Why?
It has an assumption that the size is pow of 2.
Maxime
size
64-bit
Why?
I guess this would be fixable too? (or one could create a variant without that assumption).
Maxime
于 2018年3月28日 GMT+08:00 下午7:28:07, Maxime Ripard maxime.ripard@bootlin.com 写到:
size
64-bit
Why?
I don't think its principle allows such kind of fix, as it just checks writing then reading at some offset that is pow if 2.
For hacking it, see my implementation in v1, which assumes the only size supported bigger than 2GiB is 3GiB (which is acceptable on sunxi, but might not work on other platforms).
As Andre said, that function has another big problem -- it detects memory with writing to it. This is risky.
Maxime
On Fri, Mar 23, 2018 at 04:18:56PM +0800, Icenowy Zheng wrote: > The get_ram_size() function in U-Boot can only deal with memory
size
64-bit
Why?
You could do have a bunch of algorithm actually. One would be to write the address in memory and try to detect where exactly it starts to loop.
You could do a bisection in the opposite direction once you settled for the upper limit (so you would have for example a workable 2G, a non-workable 4G, and then you try intervals that you always divide by two, so testing then 3G (that works), then halfway between 3G and 4G, etc.
How is it risky when it's done by the SPL?
Maxime
> On Fri, Mar 23, 2018 at 04:18:56PM +0800, Icenowy Zheng wrote: >> The get_ram_size() function in U-Boot can only deal with memory
size
64-bit
>> SoCs, an alternative way to detect DRAM size is needed. > > Why not just fixing get_ram_size then?
Why?
Originally that was my confusion as well: It's not the SPL calling that function. The DRAM controller init function in there knows very precisely how much DRAM we have, but we don't communicate this to U-Boot proper. So U-Boot *proper* goes ahead and probes the DRAM. This means it could step into secure memory, for instance. On sunxi64 we have the ATF running between SPL and U-Boot, also all kind of secure payloads could already have been registered. So I wonder if it would be easier to somehow pass on this *one* word of information between SPL and U-Boot proper to avoid calling this function altogether?
Cheers, Andre.
On Fri, Mar 23, 2018 at 05:41:43PM +0800, Icenowy Zheng wrote: > > > 于 2018年3月23日 GMT+08:00 下午5:40:41, Maxime Ripard maxime.ripard@bootlin.com 写到: >> On Fri, Mar 23, 2018 at 04:18:56PM +0800, Icenowy Zheng wrote: >>> The get_ram_size() function in U-Boot can only deal with memory size >>> smaller than 2GiB. To enable the support of 3GiB DRAM on newer 64-bit >>> SoCs, an alternative way to detect DRAM size is needed. >> >> Why not just fixing get_ram_size then? > > Even if it's fixed it won't support 3GiB DRAM at all.
Why?
That would definitely make sense yes.
Maxime
> On Fri, Mar 23, 2018 at 05:41:43PM +0800, Icenowy Zheng wrote: >> >> >> 于 2018年3月23日 GMT+08:00 下午5:40:41, Maxime Ripard > maxime.ripard@bootlin.com 写到: >>> On Fri, Mar 23, 2018 at 04:18:56PM +0800, Icenowy Zheng wrote: >>>> The get_ram_size() function in U-Boot can only deal with memory > size >>>> smaller than 2GiB. To enable the support of 3GiB DRAM on newer > 64-bit >>>> SoCs, an alternative way to detect DRAM size is needed. >>> >>> Why not just fixing get_ram_size then? >> >> Even if it's fixed it won't support 3GiB DRAM at all. > > Why?
So since the SPL loads the DT anyway (from the FIT image) and puts it at the end of the U-Boot (proper) binary, wouldn't it be the easiest to just patch the actual DRAM size in there? IIRC we don't have any FDT write code in the SPL at the moment, and pulling it in would probably push it over the edge again, but: We should be able to somewhat short-cut it, if it's just about to actually *patch* an existing value, as of: - make sure we have a memory node and a reg property in the DT - in the SPL learn the fdt offset of that reg property - <hack> patch in the memory size into the second word </hack> - teach U-Boot proper to read the memory size from the DT - optionally look at #address-cells and #size-cells to make this "second word hack" more robust
This could actually be a rather generic patch, just with some "avoid libfdt write library" hack to address our size issue. Maybe we already have something like that for some platform (Rockchip comes to mind?)
How does that sound?
Cheers, Andre.
于 2018年4月3日 GMT+08:00 下午6:13:17, Andre Przywara andre.przywara@arm.com 写到:
On Mon, Mar 26, 2018 at 03:11:04PM +0800, Icenowy Zheng wrote: > > > 于 2018年3月26日 GMT+08:00 下午3:06:33, Maxime Ripard maxime.ripard@bootlin.com 写到: >> On Fri, Mar 23, 2018 at 05:41:43PM +0800, Icenowy Zheng wrote: >>> >>> >>> 于 2018年3月23日 GMT+08:00 下午5:40:41, Maxime Ripard >> maxime.ripard@bootlin.com 写到: >>>> On Fri, Mar 23, 2018 at 04:18:56PM +0800, Icenowy Zheng
memory
>> size >>>>> smaller than 2GiB. To enable the support of 3GiB DRAM on
newer
>> 64-bit >>>>> SoCs, an alternative way to detect DRAM size is needed. >>>> >>>> Why not just fixing get_ram_size then? >>> >>> Even if it's fixed it won't support 3GiB DRAM at all. >> >> Why? > > It has an assumption that the size is pow of 2.
write
by
4G,
etc.
that
U-Boot
means it
ATF
could
of
function
altogether?
Rockchip recalculates the memory size with the parameters in GRF when running the main U-Boot, so both TPL/SPL and miniloader can load mainline U-Boot.
Cheers, Andre.
On 3 Apr 2018, at 12:39, Icenowy Zheng icenowy@aosc.io wrote:
于 2018年4月3日 GMT+08:00 下午6:13:17, Andre Przywara <andre.przywara@arm.com mailto:andre.przywara@arm.com> 写到:
> On Mon, Mar 26, 2018 at 03:11:04PM +0800, Icenowy Zheng wrote: >> >> >> 于 2018年3月26日 GMT+08:00 下午3:06:33, Maxime Ripard > maxime.ripard@bootlin.com 写到: >>> On Fri, Mar 23, 2018 at 05:41:43PM +0800, Icenowy Zheng wrote: >>>> >>>> >>>> 于 2018年3月23日 GMT+08:00 下午5:40:41, Maxime Ripard >>> maxime.ripard@bootlin.com 写到: >>>>> On Fri, Mar 23, 2018 at 04:18:56PM +0800, Icenowy Zheng
memory
>>> size >>>>>> smaller than 2GiB. To enable the support of 3GiB DRAM on
newer
>>> 64-bit >>>>>> SoCs, an alternative way to detect DRAM size is needed. >>>>> >>>>> Why not just fixing get_ram_size then? >>>> >>>> Even if it's fixed it won't support 3GiB DRAM at all. >>> >>> Why? >> >> It has an assumption that the size is pow of 2. > > I guess this would be fixable too? (or one could create a variant > without that assumption).
write
by
4G,
etc.
that
U-Boot
means it
ATF
could
of
function
altogether?
More accurately, the GRF currently is used to store an encoded DRAM configuration and the next stage can rely on this being there.
If the memory is initialised by miniloader, U-Boot reads the GRF and calculates the memory size from that. If U-Boot sets up DRAM, then it also populates the GRF registers.
With more and more SOCs moving away from miniloader, there’s a good chance that this will change at some point in the future and the GRF may not necessarily be populated anymore.
—Philipp.
That assumes that you are loading a FIT image, which might or might not be the case, and on most arm32 chips, most likely won't.
I guess we'd need to find another way (put some information in an SRAM somewhere?) to try to do that for all variants.
Maxime
That's true, but my understanding is that this >4GB is only relevant for 64-bit SoCs, where we mandate FIT images, don't we?
Oh, so your aim at getting rid of the call to the memory probing function at all? I was just assuming that we change it for the purpose of this 3GB support, which would be 64-bit only?
Cheers, Andre
于 2018年4月3日 GMT+08:00 下午7:41:41, Andre Przywara andre.przywara@arm.com 写到:
> For hacking it, see my implementation in v1, which assumes the > only size supported bigger than 2GiB is 3GiB (which is > acceptable on sunxi, but might not work on other platforms). > > As Andre said, that function has another big problem -- it
detects
that
U-Boot
means it
the ATF
could
word of
function
altogether?
it at
It's also relevant with A80, theortically.
And Allwinner is continously producing Cortex-A7 SoCs, which might use this design.
Cheers, Andre
于 2018年4月3日 GMT+08:00 下午7:34:55, Maxime Ripard maxime.ripard@bootlin.com 写到:
detects
that
U-Boot
means it
the ATF
could
word of
function
altogether?
at
Extend the SPL header again? If we found SPL v3+, use the DRAM size encoded and bypass ram_get_size, otherwise fallback to ram_get_size?
(Although it will lead to some days of mess on sunxi-tools, this is a reasonable choice.)
Maxime
Hi Icenowy,
detects
that
U-Boot
means it
the ATF
could
word of
function
altogether?
at
Yes, that would be a possibility as well. Though I believe at the moment we don't access the SPL header from U-Boot proper, do we? Not a real show-stopper, but we probably need to document that the SPL header would need to stay around. But if we have a fallback anyway ...
True, but actually I wonder why we have SPL_MAX_VERSION in there in the first place. Can't we just postulate that every new SPL version stays backwards compatible? So if sunxi-tools can deal with v2, a v3 SPL would still be fine, you would just loose the v3 features (if at all)? We can just put a warning in there, to ask users to upgrade. That would have worked already with the v1/v2 transition, I believe.
Probably worth a separate discussion with some sunxi-tools stakeholders.
Cheers, Andre.
On Tue, 3 Apr 2018 13:43:43 +0100 Andre Przywara andre.przywara@arm.com wrote:
Hi Icenowy,
>> For hacking it, see my implementation in v1, which assumes the >> only size supported bigger than 2GiB is 3GiB (which is >> acceptable on sunxi, but might not work on other platforms). >> >> As Andre said, that function has another big problem -- it
detects
>> memory with writing to it. This is risky. > > How is it risky when it's done by the SPL?
that
U-Boot
means it
the ATF
could
word of
function
altogether?
at
We do. The boot device and also the boot.scr location (in the case of FEL boot) is read from the SPL header by the main U-Boot part.
Maybe.
Which fallback? Do you mean calling things like ram_get_size() from U-Boot? We should never do this because this is very wrong.
The D-Cache may be already enabled, causing all kinds of weird effects. Also modifying data in DRAM (even temporarily) while our code is already running from DRAM is dangerous.
Yes, that's more or less how this was supposed to work in sunxi-tools from the very beginning. Except that we unfortunately got a bug in this code, which has been reported back in July 2017 and is still not resolved due to various reasons:
https://github.com/linux-sunxi/sunxi-tools/issues/104
But hopefully it can be fixed sooner or later.
On the U-Boot side we can just increase the version number as long as the new header is a backwards compatible superset of the old one.
In the unlikely case if we suddenly have to introduce a compatibility breaking change to the SPL header format, we can always change the SPL header signature from 'SPL' to something else.
On 03/04/18 15:13, Siarhei Siamashka wrote:
Hi Siarhei,
thanks for chiming in!
Ah, true, forgot about that. Even better then.
Maybe.
Yes, that was what Icenowy suggested: If SPL version > 2, we use the information from there, otherwise we fall back to the current behaviour, which is to ride through the DRAM and hope for the best. Though I am not sure this is really needed, as I don't see a strong reason to combine different versions of SPL and U-Boot proper (apart from FEL, maybe).
I mostly agree, though it's not too bad, since we have quite a controlled environment. But if we can get rid of it: Yes, we should.
I don't see immediately how the D$ could get nasty here, but as I said above, we should do it.
Well, that sounds more like a design issue to me: Defining the latest currently supported version as the maximum.
I think we can do it now, see below.
Or we could introduce some major/minor scheme, with a major change breaking compatibility, whereas a minor change does not. Then we split the uint8_t version into 2 bits of major and 6 bits of minor, for instance. So we just document this and bump SPL_MAX_VERSION now to 0x3f and are good for a while.
Thoughts?
Cheers, Andre.
The Allwinner A64 and H5 SoCs are both capable of use 3GiB capacity of 4GiB modules, and they both use the common DesignWare DRAM driver code.
Add size recalculation code for the driver.
arch/arm/mach-sunxi/Kconfig | 1 + arch/arm/mach-sunxi/Makefile | 2 +- arch/arm/mach-sunxi/dram_sunxi_dw.c | 28 ++++++++++++++++++++++++++-- 3 files changed, 28 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index b206472ead..0cdc34ea9a 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -108,6 +108,7 @@ config SUNXI_GEN_SUN6I
config SUNXI_DRAM_DW bool + select DRAM_CAN_RECALCULATE_SIZE ---help--- Select this for sunxi SoCs which uses a DRAM controller like the DesignWare controller used in H3, mainly SoCs after H3, which do diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index 183175340a..b403045272 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -32,6 +32,7 @@ obj-$(CONFIG_MACH_SUN8I) += clock_sun6i.o endif obj-$(CONFIG_MACH_SUN9I) += clock_sun9i.o gtbus_sun9i.o
+obj-$(CONFIG_SUNXI_DRAM_DW) += dram_sunxi_dw.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_DRAM_SUN4I) += dram_sun4i.o obj-$(CONFIG_DRAM_SUN6I) += dram_sun6i.o @@ -40,6 +41,5 @@ obj-$(CONFIG_DRAM_SUN8I_A33) += dram_sun8i_a33.o obj-$(CONFIG_DRAM_SUN8I_A83T) += dram_sun8i_a83t.o obj-$(CONFIG_DRAM_SUN9I) += dram_sun9i.o obj-$(CONFIG_SPL_SPI_SUNXI) += spl_spi_sunxi.o -obj-$(CONFIG_SUNXI_DRAM_DW) += dram_sunxi_dw.o obj-$(CONFIG_SUNXI_DRAM_DW) += dram_timings/ endif diff --git a/arch/arm/mach-sunxi/dram_sunxi_dw.c b/arch/arm/mach-sunxi/dram_sunxi_dw.c index 3bff1c46cd..f0232e63e7 100644 --- a/arch/arm/mach-sunxi/dram_sunxi_dw.c +++ b/arch/arm/mach-sunxi/dram_sunxi_dw.c @@ -16,6 +16,30 @@ #include <asm/arch/cpu.h> #include <linux/kconfig.h>
+unsigned long long sunxi_dram_recalculate_size(void) +{ + struct sunxi_mctl_com_reg * const mctl_com = + (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; + u32 cr_reg = readl(&mctl_com->cr); + u32 temp; + unsigned int dram_size_shift; + + temp = (cr_reg >> 8) & 0xf; /* page size code */ + dram_size_shift = (temp + 3); + + temp = (cr_reg >> 4) & 0xf; /* row width code */ + dram_size_shift += (temp + 1); + + temp = (cr_reg >> 2) & 0x3; /* bank number code */ + dram_size_shift += (temp + 2); + + temp = cr_reg & 0x3; /* rank number code */ + dram_size_shift += temp; + + return 1ULL << dram_size_shift; +} + +#ifdef CONFIG_SPL_BUILD static void mctl_phy_init(u32 val) { struct sunxi_mctl_ctl_reg * const mctl_ctl = @@ -763,6 +787,6 @@ unsigned long long sunxi_dram_init(void) mctl_auto_detect_dram_size(socid, ¶); mctl_set_cr(socid, ¶);
- return (1ULL << (para.row_bits + para.bank_bits)) * para.page_size * - (para.dual_rank ? 2 : 1); + return sunxi_dram_recalculate_size(); } +#endif
participants (7)
Andre Przywara
André Przywara
Chen-Yu Tsai
Dr. Philipp Tomsich
Icenowy Zheng
Maxime Ripard
Siarhei Siamashka
