[PATCH] arm: mvebu: Enable NAND flash for Thecus N2350 board
Enable 512MB PXA3XX NAND flash when u-boot is running.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
configs/n2350_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/n2350_defconfig b/configs/n2350_defconfig index b85ef0dfeb..247533ebb8 100644 --- a/configs/n2350_defconfig +++ b/configs/n2350_defconfig @@ -69,6 +69,9 @@ CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_PXA3XX=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y
Acked-by: Pali Rohár
diff --git a/configs/n2350_defconfig b/configs/n2350_defconfig index b85ef0dfeb..247533ebb8 100644 --- a/configs/n2350_defconfig +++ b/configs/n2350_defconfig @@ -69,6 +69,9 @@ CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_PXA3XX=y +CONFIG_SYS_NAND_ONFI_DETECTION=y CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y -- 2.30.2
Applied to u-boot-marvell/next
Thanks, Stefan
Viele Grüße, Stefan Roese
Pali Rohár
Stefan Roese
Tony Dinh
