[U-Boot] [PATCH v5 01/18] include: Add log2 header from the kernel
Use the log2 header files from the kernel.
Imported from kernel 4.2.3.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Jagan Teki jteki@openedev.com --- Changes since v4: - None
include/linux/log2.h | 205 +++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 205 insertions(+) create mode 100644 include/linux/log2.h
diff --git a/include/linux/log2.h b/include/linux/log2.h new file mode 100644 index 0000000..aa1de63 --- /dev/null +++ b/include/linux/log2.h @@ -0,0 +1,205 @@ +/* Integer base 2 logarithm calculation + * + * Copyright (C) 2006 Red Hat, Inc. All Rights Reserved. + * Written by David Howells (dhowells@redhat.com) + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _LINUX_LOG2_H +#define _LINUX_LOG2_H + +#include <linux/types.h> +#include <linux/bitops.h> + +/* + * deal with unrepresentable constant logarithms + */ +extern __attribute__((const, noreturn)) +int ____ilog2_NaN(void); + +/* + * non-constant log of base 2 calculators + * - the arch may override these in asm/bitops.h if they can be implemented + * more efficiently than using fls() and fls64() + * - the arch is not required to handle n==0 if implementing the fallback + */ +#ifndef CONFIG_ARCH_HAS_ILOG2_U32 +static inline __attribute__((const)) +int __ilog2_u32(u32 n) +{ + return fls(n) - 1; +} +#endif + +#ifndef CONFIG_ARCH_HAS_ILOG2_U64 +static inline __attribute__((const)) +int __ilog2_u64(u64 n) +{ + return fls64(n) - 1; +} +#endif + +/* + * Determine whether some value is a power of two, where zero is + * *not* considered a power of two. + */ + +static inline __attribute__((const)) +bool is_power_of_2(unsigned long n) +{ + return (n != 0 && ((n & (n - 1)) == 0)); +} + +/* + * round up to nearest power of two + */ +static inline __attribute__((const)) +unsigned long __roundup_pow_of_two(unsigned long n) +{ + return 1UL << fls_long(n - 1); +} + +/* + * round down to nearest power of two + */ +static inline __attribute__((const)) +unsigned long __rounddown_pow_of_two(unsigned long n) +{ + return 1UL << (fls_long(n) - 1); +} + +/** + * ilog2 - log of base 2 of 32-bit or a 64-bit unsigned value + * @n - parameter + * + * constant-capable log of base 2 calculation + * - this can be used to initialise global variables from constant data, hence + * the massive ternary operator construction + * + * selects the appropriately-sized optimised version depending on sizeof(n) + */ +#define ilog2(n) \ +( \ + __builtin_constant_p(n) ? ( \ + (n) < 1 ? ____ilog2_NaN() : \ + (n) & (1ULL << 63) ? 63 : \ + (n) & (1ULL << 62) ? 62 : \ + (n) & (1ULL << 61) ? 61 : \ + (n) & (1ULL << 60) ? 60 : \ + (n) & (1ULL << 59) ? 59 : \ + (n) & (1ULL << 58) ? 58 : \ + (n) & (1ULL << 57) ? 57 : \ + (n) & (1ULL << 56) ? 56 : \ + (n) & (1ULL << 55) ? 55 : \ + (n) & (1ULL << 54) ? 54 : \ + (n) & (1ULL << 53) ? 53 : \ + (n) & (1ULL << 52) ? 52 : \ + (n) & (1ULL << 51) ? 51 : \ + (n) & (1ULL << 50) ? 50 : \ + (n) & (1ULL << 49) ? 49 : \ + (n) & (1ULL << 48) ? 48 : \ + (n) & (1ULL << 47) ? 47 : \ + (n) & (1ULL << 46) ? 46 : \ + (n) & (1ULL << 45) ? 45 : \ + (n) & (1ULL << 44) ? 44 : \ + (n) & (1ULL << 43) ? 43 : \ + (n) & (1ULL << 42) ? 42 : \ + (n) & (1ULL << 41) ? 41 : \ + (n) & (1ULL << 40) ? 40 : \ + (n) & (1ULL << 39) ? 39 : \ + (n) & (1ULL << 38) ? 38 : \ + (n) & (1ULL << 37) ? 37 : \ + (n) & (1ULL << 36) ? 36 : \ + (n) & (1ULL << 35) ? 35 : \ + (n) & (1ULL << 34) ? 34 : \ + (n) & (1ULL << 33) ? 33 : \ + (n) & (1ULL << 32) ? 32 : \ + (n) & (1ULL << 31) ? 31 : \ + (n) & (1ULL << 30) ? 30 : \ + (n) & (1ULL << 29) ? 29 : \ + (n) & (1ULL << 28) ? 28 : \ + (n) & (1ULL << 27) ? 27 : \ + (n) & (1ULL << 26) ? 26 : \ + (n) & (1ULL << 25) ? 25 : \ + (n) & (1ULL << 24) ? 24 : \ + (n) & (1ULL << 23) ? 23 : \ + (n) & (1ULL << 22) ? 22 : \ + (n) & (1ULL << 21) ? 21 : \ + (n) & (1ULL << 20) ? 20 : \ + (n) & (1ULL << 19) ? 19 : \ + (n) & (1ULL << 18) ? 18 : \ + (n) & (1ULL << 17) ? 17 : \ + (n) & (1ULL << 16) ? 16 : \ + (n) & (1ULL << 15) ? 15 : \ + (n) & (1ULL << 14) ? 14 : \ + (n) & (1ULL << 13) ? 13 : \ + (n) & (1ULL << 12) ? 12 : \ + (n) & (1ULL << 11) ? 11 : \ + (n) & (1ULL << 10) ? 10 : \ + (n) & (1ULL << 9) ? 9 : \ + (n) & (1ULL << 8) ? 8 : \ + (n) & (1ULL << 7) ? 7 : \ + (n) & (1ULL << 6) ? 6 : \ + (n) & (1ULL << 5) ? 5 : \ + (n) & (1ULL << 4) ? 4 : \ + (n) & (1ULL << 3) ? 3 : \ + (n) & (1ULL << 2) ? 2 : \ + (n) & (1ULL << 1) ? 1 : \ + (n) & (1ULL << 0) ? 0 : \ + ____ilog2_NaN() \ + ) : \ + (sizeof(n) <= 4) ? \ + __ilog2_u32(n) : \ + __ilog2_u64(n) \ + ) + +/** + * roundup_pow_of_two - round the given value up to nearest power of two + * @n - parameter + * + * round the given value up to the nearest power of two + * - the result is undefined when n == 0 + * - this can be used to initialise global variables from constant data + */ +#define roundup_pow_of_two(n) \ +( \ + __builtin_constant_p(n) ? ( \ + (n == 1) ? 1 : \ + (1UL << (ilog2((n) - 1) + 1)) \ + ) : \ + __roundup_pow_of_two(n) \ + ) + +/** + * rounddown_pow_of_two - round the given value down to nearest power of two + * @n - parameter + * + * round the given value down to the nearest power of two + * - the result is undefined when n == 0 + * - this can be used to initialise global variables from constant data + */ +#define rounddown_pow_of_two(n) \ +( \ + __builtin_constant_p(n) ? ( \ + (1UL << ilog2(n))) : \ + __rounddown_pow_of_two(n) \ + ) + +/** + * order_base_2 - calculate the (rounded up) base 2 order of the argument + * @n: parameter + * + * The first few values calculated by this routine: + * ob2(0) = 0 + * ob2(1) = 0 + * ob2(2) = 1 + * ob2(3) = 2 + * ob2(4) = 2 + * ob2(5) = 3 + * ... and so on. + */ + +#define order_base_2(n) ilog2(roundup_pow_of_two(n)) + +#endif /* _LINUX_LOG2_H */
Use the generic bitops header files from the kernel.
include/asm-generic/bitops/__ffs.h | 43 ++++++++++++++++++++++++++++++++++++++ include/asm-generic/bitops/__fls.h | 43 ++++++++++++++++++++++++++++++++++++++ include/asm-generic/bitops/fls.h | 41 ++++++++++++++++++++++++++++++++++++ include/asm-generic/bitops/fls64.h | 36 +++++++++++++++++++++++++++++++ include/linux/bitops.h | 27 ++++++++++++++++++++++++ 5 files changed, 190 insertions(+) create mode 100644 include/asm-generic/bitops/__ffs.h create mode 100644 include/asm-generic/bitops/__fls.h create mode 100644 include/asm-generic/bitops/fls.h create mode 100644 include/asm-generic/bitops/fls64.h
diff --git a/include/asm-generic/bitops/__ffs.h b/include/asm-generic/bitops/__ffs.h new file mode 100644 index 0000000..937d7c4 --- /dev/null +++ b/include/asm-generic/bitops/__ffs.h @@ -0,0 +1,43 @@ +#ifndef _ASM_GENERIC_BITOPS___FFS_H_ +#define _ASM_GENERIC_BITOPS___FFS_H_ + +#include <asm/types.h> + +/** + * __ffs - find first bit in word. + * @word: The word to search + * + * Undefined if no bit exists, so code should check against 0 first. + */ +static __always_inline unsigned long __ffs(unsigned long word) +{ + int num = 0; + +#if BITS_PER_LONG == 64 + if ((word & 0xffffffff) == 0) { + num += 32; + word >>= 32; + } +#endif + if ((word & 0xffff) == 0) { + num += 16; + word >>= 16; + } + if ((word & 0xff) == 0) { + num += 8; + word >>= 8; + } + if ((word & 0xf) == 0) { + num += 4; + word >>= 4; + } + if ((word & 0x3) == 0) { + num += 2; + word >>= 2; + } + if ((word & 0x1) == 0) + num += 1; + return num; +} + +#endif /* _ASM_GENERIC_BITOPS___FFS_H_ */ diff --git a/include/asm-generic/bitops/__fls.h b/include/asm-generic/bitops/__fls.h new file mode 100644 index 0000000..a60a7cc --- /dev/null +++ b/include/asm-generic/bitops/__fls.h @@ -0,0 +1,43 @@ +#ifndef _ASM_GENERIC_BITOPS___FLS_H_ +#define _ASM_GENERIC_BITOPS___FLS_H_ + +#include <asm/types.h> + +/** + * __fls - find last (most-significant) set bit in a long word + * @word: the word to search + * + * Undefined if no set bit exists, so code should check against 0 first. + */ +static __always_inline unsigned long __fls(unsigned long word) +{ + int num = BITS_PER_LONG - 1; + +#if BITS_PER_LONG == 64 + if (!(word & (~0ul << 32))) { + num -= 32; + word <<= 32; + } +#endif + if (!(word & (~0ul << (BITS_PER_LONG-16)))) { + num -= 16; + word <<= 16; + } + if (!(word & (~0ul << (BITS_PER_LONG-8)))) { + num -= 8; + word <<= 8; + } + if (!(word & (~0ul << (BITS_PER_LONG-4)))) { + num -= 4; + word <<= 4; + } + if (!(word & (~0ul << (BITS_PER_LONG-2)))) { + num -= 2; + word <<= 2; + } + if (!(word & (~0ul << (BITS_PER_LONG-1)))) + num -= 1; + return num; +} + +#endif /* _ASM_GENERIC_BITOPS___FLS_H_ */ diff --git a/include/asm-generic/bitops/fls.h b/include/asm-generic/bitops/fls.h new file mode 100644 index 0000000..0576d1f --- /dev/null +++ b/include/asm-generic/bitops/fls.h @@ -0,0 +1,41 @@ +#ifndef _ASM_GENERIC_BITOPS_FLS_H_ +#define _ASM_GENERIC_BITOPS_FLS_H_ + +/** + * fls - find last (most-significant) bit set + * @x: the word to search + * + * This is defined the same way as ffs. + * Note fls(0) = 0, fls(1) = 1, fls(0x80000000) = 32. + */ + +static __always_inline int fls(int x) +{ + int r = 32; + + if (!x) + return 0; + if (!(x & 0xffff0000u)) { + x <<= 16; + r -= 16; + } + if (!(x & 0xff000000u)) { + x <<= 8; + r -= 8; + } + if (!(x & 0xf0000000u)) { + x <<= 4; + r -= 4; + } + if (!(x & 0xc0000000u)) { + x <<= 2; + r -= 2; + } + if (!(x & 0x80000000u)) { + x <<= 1; + r -= 1; + } + return r; +} + +#endif /* _ASM_GENERIC_BITOPS_FLS_H_ */ diff --git a/include/asm-generic/bitops/fls64.h b/include/asm-generic/bitops/fls64.h new file mode 100644 index 0000000..b097cf8 --- /dev/null +++ b/include/asm-generic/bitops/fls64.h @@ -0,0 +1,36 @@ +#ifndef _ASM_GENERIC_BITOPS_FLS64_H_ +#define _ASM_GENERIC_BITOPS_FLS64_H_ + +#include <asm/types.h> + +/** + * fls64 - find last set bit in a 64-bit word + * @x: the word to search + * + * This is defined in a similar way as the libc and compiler builtin + * ffsll, but returns the position of the most significant set bit. + * + * fls64(value) returns 0 if value is 0 or the position of the last + * set bit if value is nonzero. The last (most significant) bit is + * at position 64. + */ +#if BITS_PER_LONG == 32 +static __always_inline int fls64(__u64 x) +{ + __u32 h = x >> 32; + if (h) + return fls(h) + 32; + return fls(x); +} +#elif BITS_PER_LONG == 64 +static __always_inline int fls64(__u64 x) +{ + if (x == 0) + return 0; + return __fls(x) + 1; +} +#else +#error BITS_PER_LONG not 32 or 64 +#endif + +#endif /* _ASM_GENERIC_BITOPS_FLS64_H_ */ diff --git a/include/linux/bitops.h b/include/linux/bitops.h index 7b4011f..1b2e491 100644 --- a/include/linux/bitops.h +++ b/include/linux/bitops.h @@ -2,6 +2,7 @@ #define _LINUX_BITOPS_H
#include <asm/types.h> +#include <linux/compiler.h>
#define BIT(nr) (1UL << (nr)) #define BIT_MASK(nr) (1UL << ((nr) % BITS_PER_LONG)) @@ -139,6 +140,32 @@ static inline unsigned int generic_hweight8(unsigned int w) # define fls generic_fls #endif
+static inline unsigned fls_long(unsigned long l) +{ + if (sizeof(l) == 4) + return fls(l); + return fls64(l); +} + +/** + * __ffs64 - find first set bit in a 64 bit word + * @word: The 64 bit word + * + * On 64 bit arches this is a synomyn for __ffs + * The result is not defined if no bits are set, so check that @word + * is non-zero before calling this. + */ +static inline unsigned long __ffs64(u64 word) +{ +#if BITS_PER_LONG == 32 + if (((u32)word) == 0UL) + return __ffs((u32)(word >> 32)) + 32; +#elif BITS_PER_LONG != 64 +#error BITS_PER_LONG not 32 or 64 +#endif + return __ffs((unsigned long)word); +} + /** * __set_bit - Set a bit in memory * @nr: the bit to set
The generic bitops headers are required when calling logarithimic functions, such as ilog2().
arch/arm/include/asm/bitops.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/include/asm/bitops.h b/arch/arm/include/asm/bitops.h index 9b78043..d479a38 100644 --- a/arch/arm/include/asm/bitops.h +++ b/arch/arm/include/asm/bitops.h @@ -190,4 +190,9 @@ found_middle:
#endif /* __KERNEL__ */
+#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/__ffs.h> +#include <asm-generic/bitops/fls.h> +#include <asm-generic/bitops/fls64.h> + #endif /* _ARM_BITOPS_H */
Use the generic bitops and also add custom __ffs() implementation as per the kernel.
Also align the ffs() implementation with the kernel.
arch/x86/include/asm/bitops.h | 21 ++++++++++++++++++++- 1 file changed, 20 insertions(+), 1 deletion(-)
diff --git a/arch/x86/include/asm/bitops.h b/arch/x86/include/asm/bitops.h index 5a7e4cb..f97dc66 100644 --- a/arch/x86/include/asm/bitops.h +++ b/arch/x86/include/asm/bitops.h @@ -14,6 +14,10 @@ * bit 0 is the LSB of addr; bit 32 is the LSB of (addr+1). */
+#include <asm-generic/bitops/fls.h> +#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/fls64.h> + #ifdef CONFIG_SMP #define LOCK_PREFIX "lock ; " #else @@ -332,6 +336,20 @@ static __inline__ unsigned long ffz(unsigned long word) #ifdef __KERNEL__
/** + * __ffs - find first set bit in word + * @word: The word to search + * + * Undefined if no bit exists, so code should check against 0 first. + */ +static inline unsigned long __ffs(unsigned long word) +{ + __asm__("rep; bsf %1,%0" + : "=r" (word) + : "rm" (word)); + return word; +} + +/** * ffs - find first bit set * @x: the word to search * @@ -346,7 +364,8 @@ static __inline__ int ffs(int x) __asm__("bsfl %1,%0\n\t" "jnz 1f\n\t" "movl $-1,%0\n" - "1:" : "=r" (r) : "g" (x)); + "1:" : "=r" (r) : "rm" (x)); + return r+1; } #define PLATFORM_FFS
arch/m68k/include/asm/bitops.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/m68k/include/asm/bitops.h b/arch/m68k/include/asm/bitops.h index f9c434b..69ea26a 100644 --- a/arch/m68k/include/asm/bitops.h +++ b/arch/m68k/include/asm/bitops.h @@ -6,6 +6,10 @@ #define _M68K_BITOPS_H
#include <asm/byteorder.h> +#include <asm-generic/bitops/fls.h> +#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/fls64.h> +#include <asm-generic/bitops/__ffs.h>
extern void set_bit(int nr, volatile void *addr); extern void clear_bit(int nr, volatile void *addr);
arch/blackfin/include/asm/bitops.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/blackfin/include/asm/bitops.h b/arch/blackfin/include/asm/bitops.h index cd7e356..6cde6db 100644 --- a/arch/blackfin/include/asm/bitops.h +++ b/arch/blackfin/include/asm/bitops.h @@ -15,6 +15,10 @@
#include <asm/byteorder.h> #include <asm/system.h> +#include <asm-generic/bitops/fls.h> +#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/fls64.h> +#include <asm-generic/bitops/__ffs.h>
#ifdef __KERNEL__ /*
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Heiko Schocher hs@denx.de --- Changes since v4: - None
arch/sh/include/asm/bitops.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/sh/include/asm/bitops.h b/arch/sh/include/asm/bitops.h index c57d628..8cb8385 100644 --- a/arch/sh/include/asm/bitops.h +++ b/arch/sh/include/asm/bitops.h @@ -1,6 +1,11 @@ #ifndef __ASM_SH_BITOPS_H #define __ASM_SH_BITOPS_H
+#include <asm-generic/bitops/fls.h> +#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/fls64.h> +#include <asm-generic/bitops/__ffs.h> + #ifdef __KERNEL__ #include <asm/irqflags.h> /* For __swab32 */
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v4: - Split the sh and microblaze changes in two patches (Jagan)
arch/microblaze/include/asm/bitops.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/microblaze/include/asm/bitops.h b/arch/microblaze/include/asm/bitops.h index 0ac78d7..d24f2cf 100644 --- a/arch/microblaze/include/asm/bitops.h +++ b/arch/microblaze/include/asm/bitops.h @@ -7,6 +7,10 @@
#include <asm/byteorder.h> /* swab32 */ #include <asm/system.h> /* save_flags */ +#include <asm-generic/bitops/fls.h> +#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/fls64.h> +#include <asm-generic/bitops/__ffs.h>
arch/sandbox/include/asm/bitops.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/sandbox/include/asm/bitops.h b/arch/sandbox/include/asm/bitops.h index f1a7aee..f27d5e9 100644 --- a/arch/sandbox/include/asm/bitops.h +++ b/arch/sandbox/include/asm/bitops.h @@ -21,6 +21,10 @@
#include <linux/compiler.h> #include <asm/system.h> +#include <asm-generic/bitops/fls.h> +#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/fls64.h> +#include <asm-generic/bitops/__ffs.h>
#ifdef __KERNEL__
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Reviewed-by: Jagan Teki jteki@openedev.com --- Changes since v4: - None
arch/sparc/include/asm/bitops.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/sparc/include/asm/bitops.h b/arch/sparc/include/asm/bitops.h index fa39fa3..c66f730 100644 --- a/arch/sparc/include/asm/bitops.h +++ b/arch/sparc/include/asm/bitops.h @@ -9,4 +9,9 @@ #ifndef _SPARC_BITOPS_H #define _SPARC_BITOPS_H
+#include <asm-generic/bitops/fls.h> +#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/fls64.h> +#include <asm-generic/bitops/__ffs.h> + #endif /* _SPARC_BITOPS_H */
arch/openrisc/include/asm/bitops.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/openrisc/include/asm/bitops.h b/arch/openrisc/include/asm/bitops.h index 6d0b57c..28c4658 100644 --- a/arch/openrisc/include/asm/bitops.h +++ b/arch/openrisc/include/asm/bitops.h @@ -12,6 +12,10 @@ #define PLATFORM_FFS #include <asm/bitops/ffs.h>
+#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/fls64.h> +#include <asm-generic/bitops/__ffs.h> + #define hweight32(x) generic_hweight32(x) #define hweight16(x) generic_hweight16(x) #define hweight8(x) generic_hweight8(x)
arch/nds32/include/asm/bitops.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/nds32/include/asm/bitops.h b/arch/nds32/include/asm/bitops.h index f1aa9a3..7ee37c3 100644 --- a/arch/nds32/include/asm/bitops.h +++ b/arch/nds32/include/asm/bitops.h @@ -21,6 +21,10 @@ #ifdef __KERNEL__
#define smp_mb__before_clear_bit() do { } while (0) #define smp_mb__after_clear_bit() do { } while (0)
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Acked-by: Thomas Chou thomas@wytron.com.tw Reviewed-by: Jagan Teki jteki@openedev.com --- Changes since v4: - None
arch/nios2/include/asm/bitops.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/nios2/include/asm/bitops.h b/arch/nios2/include/asm/bitops.h index 3e17964..ee46f37 100644 --- a/arch/nios2/include/asm/bitops.h +++ b/arch/nios2/include/asm/bitops.h @@ -13,4 +13,9 @@ #include <asm/bitops/non-atomic.h> #include <asm/bitops/ffs.h>
+#include <asm-generic/bitops/fls.h> +#include <asm-generic/bitops/__fls.h> +#include <asm-generic/bitops/fls64.h> +#include <asm-generic/bitops/__ffs.h> + #endif /* __ASM_NIOS2_BITOPS_H */
Use the is_power_of_2() definition from log2.h to align with the kernel implementation.
arch/arm/mach-mvebu/mbus.c | 2 +- drivers/mtd/mtdcore.c | 2 +- drivers/mtd/ubi/build.c | 2 +- fs/ubifs/super.c | 2 +- include/linux/compat.h | 6 ------ 5 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/arch/arm/mach-mvebu/mbus.c b/arch/arm/mach-mvebu/mbus.c index 771cce6..346278e 100644 --- a/arch/arm/mach-mvebu/mbus.c +++ b/arch/arm/mach-mvebu/mbus.c @@ -52,7 +52,7 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/soc.h> -#include <linux/compat.h> +#include <linux/log2.h> #include <linux/mbus.h>
/* DDR target is the same on all platforms */ diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c index 2f2172b..81be0f7 100644 --- a/drivers/mtd/mtdcore.c +++ b/drivers/mtd/mtdcore.c @@ -27,8 +27,8 @@ #include <linux/gfp.h> #include <linux/slab.h> #else -#include <linux/compat.h> #include <linux/err.h> +#include <linux/log2.h> #include <ubi_uboot.h> #endif
diff --git a/drivers/mtd/ubi/build.c b/drivers/mtd/ubi/build.c index f0a3b67..f484e62 100644 --- a/drivers/mtd/ubi/build.c +++ b/drivers/mtd/ubi/build.c @@ -30,7 +30,7 @@ #include <linux/slab.h> #include <linux/major.h> #else -#include <linux/compat.h> +#include <linux/log2.h> #endif #include <linux/err.h> #include <ubi_uboot.h> diff --git a/fs/ubifs/super.c b/fs/ubifs/super.c index c474313..abe861a 100644 --- a/fs/ubifs/super.c +++ b/fs/ubifs/super.c @@ -31,7 +31,7 @@ #include <common.h> #include <malloc.h> #include <memalign.h> -#include <linux/compat.h> +#include <linux/log2.h> #include <linux/stat.h> #include <linux/err.h> #include "ubifs.h" diff --git a/include/linux/compat.h b/include/linux/compat.h index 59937de..e561ee3 100644 --- a/include/linux/compat.h +++ b/include/linux/compat.h @@ -130,12 +130,6 @@ static inline void led_trigger_unregister_simple(struct led_trigger *trigger) {} static inline void led_trigger_event(struct led_trigger *trigger, enum led_brightness event) {}
-/* include/linux/log2.h */ -static inline int is_power_of_2(unsigned long n) -{ - return (n != 0 && ((n & (n - 1)) == 0)); -} - /* uapi/linux/limits.h */ #define XATTR_LIST_MAX 65536 /* size of extended attribute namelist (64k) */
Remove __ilog2_u64 and ffs4 from powerpc bitops to align with the kernel implementation.
Use the generic __ffs64 instead of a custom powerpc implementation.
Cc: York Sun yorksun@freescale.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Jagan Teki jteki@openedev.com --- Changes since v4: - None
arch/powerpc/cpu/mpc83xx/law.c | 5 +++-- arch/powerpc/cpu/mpc85xx/tlb.c | 2 ++ arch/powerpc/cpu/mpc8xxx/law.c | 5 +++-- arch/powerpc/include/asm/bitops.h | 11 +---------- arch/powerpc/include/asm/fsl_law.h | 1 + arch/powerpc/include/asm/fsl_srio.h | 2 ++ 6 files changed, 12 insertions(+), 14 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/law.c b/arch/powerpc/cpu/mpc83xx/law.c index 66c88b6..262ae7f 100644 --- a/arch/powerpc/cpu/mpc83xx/law.c +++ b/arch/powerpc/cpu/mpc83xx/law.c @@ -9,6 +9,7 @@ #include <common.h> #include <asm/fsl_law.h> #include <asm/mmu.h> +#include <linux/log2.h>
int set_ddr_laws(u64 start, u64 sz, enum law_trgt_if id) { @@ -20,7 +21,7 @@ int set_ddr_laws(u64 start, u64 sz, enum law_trgt_if id) if (start == 0) start_align = 1ull << (LAW_SIZE_2G + 1); else - start_align = 1ull << (ffs64(start) - 1); + start_align = 1ull << (__ffs64(start) - 1); law_sz = min(start_align, sz); law_sz_enc = __ilog2_u64(law_sz) - 1;
@@ -40,7 +41,7 @@ int set_ddr_laws(u64 start, u64 sz, enum law_trgt_if id) if (sz) { start += law_sz;
- start_align = 1ull << (ffs64(start) - 1); + start_align = 1ull << (__ffs64(start) - 1); law_sz = min(start_align, sz); law_sz_enc = __ilog2_u64(law_sz) - 1; ecm = &immap->sysconf.ddrlaw[1]; diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index 8e0508f..cf31eb2 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -14,6 +14,8 @@ #include <addr_map.h> #endif
+#include <linux/log2.h> + DECLARE_GLOBAL_DATA_PTR;
void invalidate_tlb(u8 tlb) diff --git a/arch/powerpc/cpu/mpc8xxx/law.c b/arch/powerpc/cpu/mpc8xxx/law.c index 33d53a8..24baad4 100644 --- a/arch/powerpc/cpu/mpc8xxx/law.c +++ b/arch/powerpc/cpu/mpc8xxx/law.c @@ -11,6 +11,7 @@ #include <linux/compiler.h> #include <asm/fsl_law.h> #include <asm/io.h> +#include <linux/log2.h>
@@ -187,7 +188,7 @@ int set_ddr_laws(u64 start, u64 sz, enum law_trgt_if id) if (start == 0) start_align = 1ull << (LAW_SIZE_32G + 1); else - start_align = 1ull << (ffs64(start) - 1); + start_align = 1ull << (__ffs64(start) - 1); law_sz = min(start_align, sz); law_sz_enc = __ilog2_u64(law_sz) - 1;
@@ -202,7 +203,7 @@ int set_ddr_laws(u64 start, u64 sz, enum law_trgt_if id) if (sz) { start += law_sz;
diff --git a/arch/powerpc/include/asm/bitops.h b/arch/powerpc/include/asm/bitops.h index a6bcf3c..14217ef 100644 --- a/arch/powerpc/include/asm/bitops.h +++ b/arch/powerpc/include/asm/bitops.h @@ -6,6 +6,7 @@ #define _PPC_BITOPS_H
#include <asm/byteorder.h> +#include <asm-generic/bitops/__ffs.h>
extern void set_bit(int nr, volatile void *addr); extern void clear_bit(int nr, volatile void *addr); @@ -209,16 +210,6 @@ static inline int fls64(__u64 x) #error BITS_PER_LONG not 32 or 64 #endif
-static inline int __ilog2_u64(u64 n) -{ - return fls64(n) - 1; -} - -static inline int ffs64(u64 x) -{ - return __ilog2_u64(x & -x) + 1ull; -} - #ifdef __KERNEL__
/* diff --git a/arch/powerpc/include/asm/fsl_law.h b/arch/powerpc/include/asm/fsl_law.h index 3b50487..8e1d22a 100644 --- a/arch/powerpc/include/asm/fsl_law.h +++ b/arch/powerpc/include/asm/fsl_law.h @@ -10,6 +10,7 @@ #define _FSL_LAW_H_
#define LAW_EN 0x80000000
diff --git a/arch/powerpc/include/asm/fsl_srio.h b/arch/powerpc/include/asm/fsl_srio.h index e5aab2a..ec25e16 100644 --- a/arch/powerpc/include/asm/fsl_srio.h +++ b/arch/powerpc/include/asm/fsl_srio.h @@ -7,6 +7,8 @@ #ifndef _FSL_SRIO_H_ #define _FSL_SRIO_H_
+#include <linux/log2.h> + enum atmu_size { ATMU_SIZE_4K = 0xb, ATMU_SIZE_8K,
________________________________________ From: Fabio Estevam festevam@gmail.com Sent: Monday, November 2, 2015 3:38 PM To: jteki@openedev.com Cc: trini@konsulko.com; otavio@ossystems.com.br; u-boot@lists.denx.de; Estevam Fabio-R49496; Sun York-R58495 Subject: [PATCH v5 15/18] powerpc: Remove __ilog2_u64 and ffs4 from bitops
Reviewed-by: York Sun yorksun@freescale.com
Add the SPI NOR protection mechanism from the kernel.
This code is based on the work from Brian Norris computersforpeace@gmail.com
https://git.kernel.org/cgit/linux/kernel/git/next/linux-next.git/commit/driv...
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Jagan Teki jteki@openedev.com --- Changes since v4: - Place SR_BP bits into "sf_internal.h" (Jagan)
drivers/mtd/spi/sf_internal.h | 4 + drivers/mtd/spi/sf_ops.c | 170 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 174 insertions(+)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 8a3e5ec..adfcd89 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -106,6 +106,10 @@ enum spi_nor_option_flags { #define STATUS_QEB_MXIC (1 << 6) #define STATUS_PEC (1 << 7)
+#define SR_BP0 BIT(2) /* Block protect 0 */ +#define SR_BP1 BIT(3) /* Block protect 1 */ +#define SR_BP2 BIT(4) /* Block protect 2 */ + /* Flash timeout values */ #define SPI_FLASH_PROG_TIMEOUT (2 * CONFIG_SYS_HZ) #define SPI_FLASH_PAGE_ERASE_TIMEOUT (5 * CONFIG_SYS_HZ) diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index f2a9244..4ada13f 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -15,6 +15,7 @@ #include <spi_flash.h> #include <watchdog.h> #include <linux/compiler.h> +#include <linux/log2.h>
#include "sf_internal.h"
@@ -565,3 +566,172 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, return ret; } #endif + +#ifdef CONFIG_SPI_FLASH_STMICRO +static void stm_get_locked_range(struct spi_flash *flash, u8 sr, loff_t *ofs, + u32 *len) +{ + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + int shift = ffs(mask) - 1; + int pow; + + if (!(sr & mask)) { + /* No protection */ + *ofs = 0; + *len = 0; + } else { + pow = ((sr & mask) ^ mask) >> shift; + *len = flash->size >> pow; + *ofs = flash->size - *len; + } +} + +/* + * Return 1 if the entire region is locked, 0 otherwise + */ +static int stm_is_locked_sr(struct spi_flash *flash, loff_t ofs, u32 len, + u8 sr) +{ + loff_t lock_offs; + u32 lock_len; + + stm_get_locked_range(flash, sr, &lock_offs, &lock_len); + + return (ofs + len <= lock_offs + lock_len) && (ofs >= lock_offs); +} + +/* + * Check if a region of the flash is (completely) locked. See stm_lock() for + * more info. + * + * Returns 1 if entire region is locked, 0 if any portion is unlocked, and + * negative on errors. + */ +int stm_is_locked(struct spi_flash *flash, loff_t ofs, u32 len) +{ + int status; + u8 sr; + + status = spi_flash_cmd_read_status(flash, &sr); + if (status < 0) + return status; + + return stm_is_locked_sr(flash, ofs, len, sr); +} + +/* + * Lock a region of the flash. Compatible with ST Micro and similar flash. + * Supports only the block protection bits BP{0,1,2} in the status register + * (SR). Does not support these features found in newer SR bitfields: + * - TB: top/bottom protect - only handle TB=0 (top protect) + * - SEC: sector/block protect - only handle SEC=0 (block protect) + * - CMP: complement protect - only support CMP=0 (range is not complemented) + * + * Sample table portion for 8MB flash (Winbond w25q64fw): + * + * SEC | TB | BP2 | BP1 | BP0 | Prot Length | Protected Portion + * -------------------------------------------------------------------------- + * X | X | 0 | 0 | 0 | NONE | NONE + * 0 | 0 | 0 | 0 | 1 | 128 KB | Upper 1/64 + * 0 | 0 | 0 | 1 | 0 | 256 KB | Upper 1/32 + * 0 | 0 | 0 | 1 | 1 | 512 KB | Upper 1/16 + * 0 | 0 | 1 | 0 | 0 | 1 MB | Upper 1/8 + * 0 | 0 | 1 | 0 | 1 | 2 MB | Upper 1/4 + * 0 | 0 | 1 | 1 | 0 | 4 MB | Upper 1/2 + * X | X | 1 | 1 | 1 | 8 MB | ALL + * + * Returns negative on errors, 0 on success. + */ +int stm_lock(struct spi_flash *flash, u32 ofs, u32 len) +{ + u8 status_old, status_new; + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + u8 shift = ffs(mask) - 1, pow, val; + + spi_flash_cmd_read_status(flash, &status_old); + + /* SPI NOR always locks to the end */ + if (ofs + len != flash->size) { + /* Does combined region extend to end? */ + if (!stm_is_locked_sr(flash, ofs + len, flash->size - ofs - len, + status_old)) + return -EINVAL; + len = flash->size - ofs; + } + + /* + * Need smallest pow such that: + * + * 1 / (2^pow) <= (len / size) + * + * so (assuming power-of-2 size) we do: + * + * pow = ceil(log2(size / len)) = log2(size) - floor(log2(len)) + */ + pow = ilog2(flash->size) - ilog2(len); + val = mask - (pow << shift); + if (val & ~mask) + return -EINVAL; + + /* Don't "lock" with no region! */ + if (!(val & mask)) + return -EINVAL; + + status_new = (status_old & ~mask) | val; + + /* Only modify protection if it will not unlock other areas */ + if ((status_new & mask) <= (status_old & mask)) + return -EINVAL; + + spi_flash_cmd_write_status(flash, status_new); + + return 0; +} + +/* + * Unlock a region of the flash. See stm_lock() for more info + * + * Returns negative on errors, 0 on success. + */ +int stm_unlock(struct spi_flash *flash, u32 ofs, u32 len) +{ + uint8_t status_old, status_new; + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + u8 shift = ffs(mask) - 1, pow, val; + + spi_flash_cmd_read_status(flash, &status_old); + + /* Cannot unlock; would unlock larger region than requested */ + if (stm_is_locked_sr(flash, status_old, ofs - flash->erase_size, + flash->erase_size)) + return -EINVAL; + /* + * Need largest pow such that: + * + * 1 / (2^pow) >= (len / size) + * + * so (assuming power-of-2 size) we do: + * + * pow = floor(log2(size / len)) = log2(size) - ceil(log2(len)) + */ + pow = ilog2(flash->size) - order_base_2(flash->size - (ofs + len)); + if (ofs + len == flash->size) { + val = 0; /* fully unlocked */ + } else { + val = mask - (pow << shift); + /* Some power-of-two sizes are not supported */ + if (val & ~mask) + return -EINVAL; + } + + status_new = (status_old & ~mask) | val; + + /* Only modify protection if it will not lock other areas */ + if ((status_new & mask) >= (status_old & mask)) + return -EINVAL; + + spi_flash_cmd_write_status(flash, status_new); + + return 0; +} +#endif /* CONFIG_SPI_FLASH_STMICRO */
Many SPI flashes have protection bits (BP2, BP1 and BP0) in the status register that can protect selected regions of the SPI NOR.
Take these bits into account when performing erase operations, making sure that the protected areas are skipped.
Tested on a mx6qsabresd:
=> sf probe SF: Detected M25P32 with page size 256 Bytes, erase size 64 KiB, total 4 MiB => sf protect lock 0x3f0000 0x10000 => sf erase 0x3f0000 0x10000 offset 0x3f0000 is protected and cannot be erased SF: 65536 bytes @ 0x3f0000 Erased: ERROR => sf protect unlock 0x3f0000 0x10000 => sf erase 0x3f0000 0x10000 SF: 65536 bytes @ 0x3f0000 Erased: OK
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v4: - Only apply lock operations if the SPI NOR flash ID matches STMicro (Jagan)
common/cmd_sf.c | 35 +++++++++++++++++++++++++ drivers/mtd/spi/sf-uclass.c | 8 ++++++ drivers/mtd/spi/sf_internal.h | 8 ++++++ drivers/mtd/spi/sf_ops.c | 25 ++++++++++++++++++ drivers/mtd/spi/sf_probe.c | 61 +++++++++++++++++++++++++++++++++++++++++++ include/spi_flash.h | 41 +++++++++++++++++++++++++++++ 6 files changed, 178 insertions(+)
diff --git a/common/cmd_sf.c b/common/cmd_sf.c index ac7f5df..42862d9 100644 --- a/common/cmd_sf.c +++ b/common/cmd_sf.c @@ -348,6 +348,37 @@ static int do_spi_flash_erase(int argc, char * const argv[]) return ret == 0 ? 0 : 1; }
+static int do_spi_protect(int argc, char * const argv[]) +{ + int ret = 0; + loff_t start, len; + bool prot = false; + + if (argc != 4) + return -1; + + if (!str2off(argv[2], &start)) { + puts("start sector is not a valid number\n"); + return 1; + } + + if (!str2off(argv[3], &len)) { + puts("len is not a valid number\n"); + return 1; + } + + if (strcmp(argv[1], "lock") == 0) + prot = true; + else if (strcmp(argv[1], "unlock") == 0) + prot = false; + else + return -1; /* Unknown parameter */ + + ret = spi_flash_protect(flash, start, len, prot); + + return ret == 0 ? 0 : 1; +} + #ifdef CONFIG_CMD_SF_TEST enum { STAGE_ERASE, @@ -540,6 +571,8 @@ static int do_spi_flash(cmd_tbl_t *cmdtp, int flag, int argc, ret = do_spi_flash_read_write(argc, argv); else if (strcmp(cmd, "erase") == 0) ret = do_spi_flash_erase(argc, argv); + else if (strcmp(cmd, "protect") == 0) + ret = do_spi_protect(argc, argv); #ifdef CONFIG_CMD_SF_TEST else if (!strcmp(cmd, "test")) ret = do_spi_flash_test(argc, argv); @@ -579,5 +612,7 @@ U_BOOT_CMD( "sf update addr offset|partition len - erase and write `len' bytes from memory\n" " at `addr' to flash at `offset'\n" " or to start of mtd `partition'\n" + "sf protect lock/unlock sector len - protect/unprotect 'len' bytes starting\n" + " at address 'sector'\n" SF_TEST_HELP ); diff --git a/drivers/mtd/spi/sf-uclass.c b/drivers/mtd/spi/sf-uclass.c index 350e21a..7663885 100644 --- a/drivers/mtd/spi/sf-uclass.c +++ b/drivers/mtd/spi/sf-uclass.c @@ -27,6 +27,14 @@ int spi_flash_erase_dm(struct udevice *dev, u32 offset, size_t len) return sf_get_ops(dev)->erase(dev, offset, len); }
+int spi_flash_protect_dm(struct udevice *dev, u32 offset, size_t len, bool prot) +{ + if (prot) + return sf_get_ops(dev)->lock(dev, offset, len); + else + return sf_get_ops(dev)->unlock(dev, offset, len); +} + /* * TODO(sjg@chromium.org): This is an old-style function. We should remove * it when all SPI flash drivers use dm diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index adfcd89..db46aa8 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -177,6 +177,10 @@ int spi_flash_cmd_read_status(struct spi_flash *flash, u8 *rs); /* Program the status register */ int spi_flash_cmd_write_status(struct spi_flash *flash, u8 ws);
+int stm_is_locked(struct spi_flash *nor, loff_t ofs, u32 len); +int stm_lock(struct spi_flash *nor, u32 ofs, u32 len); +int stm_unlock(struct spi_flash *nor, u32 ofs, u32 len); + /* Read the config register */ int spi_flash_cmd_read_config(struct spi_flash *flash, u8 *rc);
@@ -231,6 +235,10 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, size_t len, void *data);
+int spi_flash_cmd_lock_ops(struct spi_flash *flash, u32 offset, size_t len); +int spi_flash_cmd_unlock_ops(struct spi_flash *flash, u32 offset, size_t len); +int spi_flash_cmd_is_locked_ops(struct spi_flash *flash, u32 offset, size_t len); + #ifdef CONFIG_SPI_FLASH_MTD int spi_flash_mtd_register(struct spi_flash *flash); void spi_flash_mtd_unregister(void); diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c index 4ada13f..99fc7f9 100644 --- a/drivers/mtd/spi/sf_ops.c +++ b/drivers/mtd/spi/sf_ops.c @@ -268,6 +268,11 @@ int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) return -1; }
+ if (flash->is_locked(flash, offset, len) > 0) { + printf("offset 0x%x is protected and cannot be erased\n", offset); + return -EINVAL; + } + cmd[0] = flash->erase_cmd; while (len) { erase_addr = offset; @@ -310,6 +315,11 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset,
page_size = flash->page_size;
+ if (flash->is_locked(flash, offset, len) > 0) { + printf("offset 0x%x is protected and cannot be written\n", offset); + return -EINVAL; + } + cmd[0] = flash->write_cmd; for (actual = 0; actual < len; actual += chunk_len) { write_addr = offset; @@ -348,6 +358,21 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, return ret; }
+int spi_flash_cmd_lock_ops(struct spi_flash *flash, u32 offset, size_t len) +{ + return stm_lock(flash, offset, len); +} + +int spi_flash_cmd_unlock_ops(struct spi_flash *flash, u32 offset, size_t len) +{ + return stm_unlock(flash, offset, len); +} + +int spi_flash_cmd_is_locked_ops(struct spi_flash *flash, u32 offset, size_t len) +{ + return stm_is_locked(flash, offset, len); +} + int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, size_t cmd_len, void *data, size_t data_len) { diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index c000c53..3626433 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -130,6 +130,22 @@ bank_end: } #endif
+int static is_stm(struct spi_slave *spi, struct spi_flash *flash) +{ + u8 idcode[5]; + int ret; + + /* Read the ID codes */ + ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); + if (ret < 0) + return ret; + + if (idcode[0] == SPI_FLASH_CFI_MFR_STMICRO) + return 1; + else + return 0; +} + static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode, struct spi_flash *flash) { @@ -180,6 +196,13 @@ static int spi_flash_validate_params(struct spi_slave *spi, u8 *idcode, #endif flash->erase = spi_flash_cmd_erase_ops; flash->read = spi_flash_cmd_read_ops; +#if defined(CONFIG_SPI_FLASH_STMICRO) + if (is_stm(spi, flash) > 0) { + flash->lock = spi_flash_cmd_lock_ops; + flash->unlock = spi_flash_cmd_unlock_ops; + flash->is_locked = spi_flash_cmd_is_locked_ops; + } +#endif #endif
/* Compute the flash size */ @@ -482,6 +505,39 @@ int spi_flash_std_erase(struct udevice *dev, u32 offset, size_t len) return spi_flash_cmd_erase_ops(flash, offset, len); }
+int spi_flash_std_lock(struct udevice *dev, u32 offset, size_t len) +{ + struct spi_flash *flash = dev_get_uclass_priv(dev); + struct spi_slave *spi = dev_get_parent_priv(dev); + + if (is_stm(spi, flash) <= 0) + return -EOPNOTSUPP; + + return spi_flash_cmd_lock_ops(flash, offset, len); +} + +int spi_flash_std_unlock(struct udevice *dev, u32 offset, size_t len) +{ + struct spi_flash *flash = dev_get_uclass_priv(dev); + struct spi_slave *spi = dev_get_parent_priv(dev); + + if (is_stm(spi, flash) <= 0) + return -EOPNOTSUPP; + + return spi_flash_cmd_unlock_ops(flash, offset, len); +} + +int spi_flash_std_is_locked(struct udevice *dev, u32 offset, size_t len) +{ + struct spi_flash *flash = dev_get_uclass_priv(dev); + struct spi_slave *spi = dev_get_parent_priv(dev); + + if (is_stm(spi, flash) <= 0) + return -EOPNOTSUPP; + + return spi_flash_cmd_is_locked_ops(flash, offset, len); +} + int spi_flash_std_probe(struct udevice *dev) { struct spi_slave *slave = dev_get_parent_priv(dev); @@ -498,6 +554,11 @@ static const struct dm_spi_flash_ops spi_flash_std_ops = { .read = spi_flash_std_read, .write = spi_flash_std_write, .erase = spi_flash_std_erase, +#if defined(CONFIG_SPI_FLASH_STMICRO) + .lock = spi_flash_std_lock, + .unlock = spi_flash_std_unlock, + .is_locked = spi_flash_std_is_locked, +#endif };
static const struct udevice_id spi_flash_std_ids[] = { diff --git a/include/spi_flash.h b/include/spi_flash.h index 4312d3d..23f30a5 100644 --- a/include/spi_flash.h +++ b/include/spi_flash.h @@ -104,6 +104,9 @@ struct spi_flash { const void *buf); int (*erase)(struct spi_flash *flash, u32 offset, size_t len); #endif + int (*lock)(struct spi_flash *flash, u32 offset, size_t len); + int (*unlock)(struct spi_flash *flash, u32 offset, size_t len); + int (*is_locked)(struct spi_flash *flash, u32 offset, size_t len); };
struct dm_spi_flash_ops { @@ -111,6 +114,9 @@ struct dm_spi_flash_ops { int (*write)(struct udevice *dev, u32 offset, size_t len, const void *buf); int (*erase)(struct udevice *dev, u32 offset, size_t len); + int (*lock)(struct udevice *dev, u32 offset, size_t len); + int (*unlock)(struct udevice *dev, u32 offset, size_t len); + int (*is_locked)(struct udevice *dev, u32 offset, size_t len); };
/* Access the serial operations for a device */ @@ -152,6 +158,20 @@ int spi_flash_write_dm(struct udevice *dev, u32 offset, size_t len, */ int spi_flash_erase_dm(struct udevice *dev, u32 offset, size_t len);
+/** + * spi_flash_protect_dm() - Protect/unprotect blocks of the SPI flash + * + * Note that @len must be a muiltiple of the flash sector size. + * + * @dev: SPI flash device + * @offset: Offset into device in bytes to start erasing + * @len: Number of bytes to erase + * @prot: True: lock the block or False: unlock the block + * @return 0 if OK, -ve on error + */ +int spi_flash_protect_dm(struct udevice *dev, u32 offset, size_t len, + bool prot); + int spi_flash_probe_bus_cs(unsigned int busnum, unsigned int cs, unsigned int max_hz, unsigned int spi_mode, struct udevice **devp); @@ -183,6 +203,15 @@ static inline int spi_flash_erase(struct spi_flash *flash, u32 offset, return spi_flash_erase_dm(flash->dev, offset, len); }
+static inline int spi_flash_protect(struct spi_flash *flash, loff_t ofs, + u32 len, bool prot) +{ + if (!flash->lock) + return -EOPNOTSUPP; + + return spi_flash_protect_dm(flash->dev, ofs, len, prot); +} + struct sandbox_state;
int sandbox_sf_bind_emul(struct sandbox_state *state, int busnum, int cs, @@ -225,6 +254,18 @@ static inline int spi_flash_erase(struct spi_flash *flash, u32 offset, { return flash->erase(flash, offset, len); } + +static inline int spi_flash_protect(struct spi_flash *flash, u32 ofs, u32 len, + bool prot) +{ + if (!flash->lock) + return -EOPNOTSUPP; + + if (prot) + return flash->lock(flash, ofs, len); + else + return flash->unlock(flash, ofs, len); +} #endif
void spi_boot(void) __noreturn;
Hi Fabio,
Changes since v4:
int ret = 0;
loff_t start, len;
bool prot = false;
if (argc != 4)
return -1;
return 1;
return 1;
prot = true;
prot = false;
else
if (prot)
else
- TODO(sjg@chromium.org): This is an old-style function. We should remove
- it when all SPI flash drivers use dm
return -EINVAL;
return -EINVAL;
This flash lock check related to non-dm lock ops so it's look not good to me as we assigned lock ops for both dm and non-dm cases.
u8 idcode[5];
int ret;
if (ret < 0)
return ret;
This is duplicate we have already got the idcode.
return 1;
else
+#endif #endif
return -EOPNOTSUPP;
return -EOPNOTSUPP;
return -EOPNOTSUPP;
+#endif };
- spi_flash_protect_dm() - Protect/unprotect blocks of the SPI flash
- Note that @len must be a muiltiple of the flash sector size.
- @dev: SPI flash device
- @offset: Offset into device in bytes to start erasing
- @len: Number of bytes to erase
- @prot: True: lock the block or False: unlock the block
- @return 0 if OK, -ve on error
bool prot);
u32 len, bool prot)
if (!flash->lock)
return -EOPNOTSUPP;
bool prot)
if (!flash->lock)
return -EOPNOTSUPP;
if (prot)
else
+} #endif
1.9.1
I will come back for this patch changes what I thought, probably lock ops shouldn't be separate for dm and non-dm as we have different ops based on the flash itself.
Jagan,
return -EINVAL;
This is getting totally ridiculous: you have been seeing this patch series so many times and now you say this is not OK and you don't give me any clue as to what you would like me to change.
That's why I proposed earlier that you take the non-SPI patches first and then we can rework the SPI flash pieces.
I wish we can make progress on this. Not sure how to proceed though.
Fabio,
On 3 November 2015 at 20:29, Fabio Estevam festevam@gmail.com wrote:
Jagan,
return -EINVAL;
Nothing is worse than before or now - as spi-flash code is configured both the dm and non-dm cases and it's been thinking job as I have planning for proper design[1] to go ahead. I understand you sent multiple versions but I already told that "please don't send the next version" until the current version discussion finishes.
[1] http://git.denx.de/?p=u-boot/u-boot-spi.git;a=shortlog;h=refs/heads/next-spi...
thanks!
Jagan,
How do I know that you finished reviewing a specific version and I am ready to send another one?
Anyway, let's focus on the remaining technical issues.
What exactly do you want me to change?
You say: "This flash lock check related to non-dm lock ops so it's look not good to me as we assigned lock ops for both dm and non-dm cases."
How can I make it look good then?
On Tue, Nov 03, 2015 at 08:21:32PM +0530, Jagan Teki wrote:
[snip]
As we work on consolidation and moving everything over to DM we'll have funny cases like this. But we shouldn't let that stop us from making forward progress either. The code itself looks reasonable enough today as a starting point, so lets pick it up and move from there, thanks!
[snip]
Yes, we can always make incremental patches to improve things.
Thanks, Tom!
SST flashes have a similar SPI NOR protection scheme as STMICRO, so add support for it.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v4: - None. Newly introduced in this version
drivers/mtd/spi/sf_internal.h | 1 + drivers/mtd/spi/sf_probe.c | 3 ++- 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index db46aa8..214ceaa 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -63,6 +63,7 @@ enum spi_nor_option_flags { /* CFI Manufacture ID's */ #define SPI_FLASH_CFI_MFR_SPANSION 0x01 #define SPI_FLASH_CFI_MFR_STMICRO 0x20 +#define SPI_FLASH_CFI_MFR_SST 0xbf #define SPI_FLASH_CFI_MFR_MACRONIX 0xc2 #define SPI_FLASH_CFI_MFR_WINBOND 0xef
diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 3626433..8a736c4 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -140,7 +140,8 @@ int static is_stm(struct spi_slave *spi, struct spi_flash *flash) if (ret < 0) return ret;
- if (idcode[0] == SPI_FLASH_CFI_MFR_STMICRO) + if (idcode[0] == SPI_FLASH_CFI_MFR_STMICRO || + idcode[0] == SPI_FLASH_CFI_MFR_SST) return 1; else return 0;
Fabio Estevam
Jagan Teki
York Sun
