[PATCH 1/1] imx: Kconfig: fix references to doc/README.mxc_hab
doc/README.mxc_hab was moved to doc/imx/habv4/guides/encrypted_boot.txt by commit df11b0c4d4e3 ("doc: imx: reorganize i.MX documentation"), commit dfe9ff9cc79b ("doc: imx: hab: Reorganize High Assurance Boot documentation"), commit 8a23fc9c94bf ("doc: imx: habv4: Remove extra hab, directory for a cleaner documentation structure"), and commit 364c0a89bcfa ("doc: imx: habv4: Move encrypted boot guide").
Fixes: df11b0c4d4e3 ("doc: imx: reorganize i.MX documentation") Fixes: dfe9ff9cc79b ("doc: imx: hab: Reorganize High Assurance Boot documentation") Fixes: 8a23fc9c94bf ("doc: imx: habv4: Remove extra hab, directory for a cleaner documentation structure") Fixes: commit 364c0a89bcfa ("doc: imx: habv4: Move encrypted boot guide"). Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/arm/mach-imx/Kconfig | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig index aa140c4798..44b47780ee 100644 --- a/arch/arm/mach-imx/Kconfig +++ b/arch/arm/mach-imx/Kconfig @@ -41,7 +41,7 @@ config IMX_HAB imply CMD_DEKBLOB help This option enables the support for secure boot (HAB). - See doc/README.mxc_hab for more details. + See doc/imx/habv4/guides/encrypted_boot.txt for more details.
config CSF_SIZE hex "Maximum size for Command Sequence File (CSF) binary" @@ -69,8 +69,8 @@ config CMD_DEKBLOB help This enables the 'dek_blob' command which is used with the Freescale secure boot mechanism. This command encapsulates and - creates a blob of data. See also CMD_BLOB and doc/README.mxc_hab for - more information. + creates a blob of data. See also CMD_BLOB and + doc/imx/habv4/guides/encrypted_boot.txt for more information.
config CMD_HDMIDETECT bool "Support the 'hdmidet' command" -- 2.20.1
Hi Heinrich,
On Sun, Apr 12, 2020 at 11:23 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Thanks for your patch.
Indeed, doc/README.mxc_hab is gone and we should replace it, but I was wondering if we should point the file to doc/imx/habv4/guides/mx6_mx7_secure_boot.txt instead.
Breno,
What do you think?
Thanks
Hi Heinrich,
Em dom., 12 de abr. de 2020 às 12:15, Fabio Estevam festevam@gmail.com escreveu:
Hi Heinrich,
Breno,
What do you think?
Thanks for the fix.
Yes, IMX_HAB is also used for encrypted boot but as Fabio mentioned it would be better to point users to doc/imx/habv4/guides/mx6_mx7_secure_boot.txt.
Thanks, Breno Lima
On 4/12/20 6:16 PM, Fabio Estevam wrote:
Hi Heinrich,
Breno,
What do you think?
It is doc/imx/habv4/guides/encrypted_boot.txt that mentions CONFIG_IMX_HAB and CONFIG_CMD_DEKBLOB.
Maybe both files can be merged. Anyway the imx directory should move to doc/board and be integrated into doc/board/index.rst.
Shouldn't the content of folder doc/imx be moved to doc/board/freescale/ and linked in doc/board/freescale/index.rst?
We should be able to generate HTML documentation for imx using 'make htmldocs'.
Best regards
Heinrich
Hi Heinrich,
Em dom., 12 de abr. de 2020 às 17:35, Heinrich Schuchardt xypron.glpk@gmx.de escreveu:
Hi Heinrich,
Breno,
What do you think?
Thanks for your feedback.
Do you think we can convert this documentation to sphinx format and create an index.rst at doc/imx/? The HABv4 documentation is SoC specific and not board related.
Thanks, Breno Lima
Am April 13, 2020 2:49:00 PM UTC schrieb Breno Matheus Lima brenomatheus@gmail.com:
Hi Heinrich,
Hi Heinrich,
commit
extra hab,
364c0a89bcfa
Boot
guide").
details.
was
Breno,
What do you think?
to
Maybe besides an arch and a board folder we should have a doc/soc/ folder.
Thanks, Breno Lima
Hi Heinrich,
Em seg., 13 de abr. de 2020 às 11:04, Heinrich Schuchardt xypron.glpk@gmx.de escreveu:
Hi Heinrich,
Hi Heinrich,
commit
extra hab,
364c0a89bcfa
Boot
guide").
details.
was
Breno,
What do you think?
to
Thanks for your suggestion, do we have similar documentation for other SoCs?
Please take a look in commit df11b0c4 ("doc: imx: reorganize i.MX documentation") all i.MX documentation that were located at U-Boot doc root directory.
Thanks, Breno Lima
On 4/14/20 3:28 AM, Breno Matheus Lima wrote:
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
commit
extra hab,
364c0a89bcfa
Boot
guide").
details.
was
Breno,
What do you think?
to
df11b0c4 was a good step forward.
doc/mvebu/armada-8k-memory.txt seems to be another SoC related file.
A lot of other SoC files are at doc/README.*.
Overall the doc/ directory is not in a good state yet. Many documents are not yet integrated into the generated documentation.
Best regards
Heinrich
Thanks, Breno Lima
Hi everybody,
Hi Heinrich,
Hi Heinrich,
Hi Heinrich,
commit
> dfe9ff9cc79b ("doc: imx: hab: Reorganize High Assurance Boot > documentation"), commit 8a23fc9c94bf ("doc: imx: habv4: Remove
extra hab,
364c0a89bcfa
> ("doc: imx: habv4: Move encrypted boot guide"). > > Fixes: df11b0c4d4e3 ("doc: imx: reorganize i.MX documentation") > Fixes: dfe9ff9cc79b ("doc: imx: hab: Reorganize High Assurance
Boot
> documentation") > Fixes: 8a23fc9c94bf ("doc: imx: habv4: Remove extra hab, directory > for a cleaner documentation structure") > Fixes: commit 364c0a89bcfa ("doc: imx: habv4: Move encrypted boot
guide").
> Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de > --- > arch/arm/mach-imx/Kconfig | 6 +++--- > 1 file changed, 3 insertions(+), 3 deletions(-) > > diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig > index aa140c4798..44b47780ee 100644 > --- a/arch/arm/mach-imx/Kconfig > +++ b/arch/arm/mach-imx/Kconfig > @@ -41,7 +41,7 @@ config IMX_HAB > imply CMD_DEKBLOB > help > This option enables the support for secure boot (HAB). > - See doc/README.mxc_hab for more details. > + See doc/imx/habv4/guides/encrypted_boot.txt for more
details.
was
Breno,
What do you think?
to
Agree that doc/ is in a bad state - nevertheless we should try to move on to the right direction. As Breno says, this is not related to a single board. doc/README.soc was done years ago, without generating documentation. I think we should go away from this model. I see also very positive the switch to rst for any i.MX documentation.
Regards, Stefano
Best regards
Heinrich
Thanks, Breno Lima
On 4/17/20 6:47 PM, Stefano Babic wrote:
Hi everybody,
Hi Heinrich,
Hi Heinrich,
On 4/12/20 6:16 PM, Fabio Estevam wrote: > Hi Heinrich, > > On Sun, Apr 12, 2020 at 11:23 AM Heinrich Schuchardt
commit
>> dfe9ff9cc79b ("doc: imx: hab: Reorganize High Assurance Boot >> documentation"), commit 8a23fc9c94bf ("doc: imx: habv4: Remove
extra hab,
364c0a89bcfa
>> ("doc: imx: habv4: Move encrypted boot guide"). >> >> Fixes: df11b0c4d4e3 ("doc: imx: reorganize i.MX documentation") >> Fixes: dfe9ff9cc79b ("doc: imx: hab: Reorganize High Assurance
Boot
>> documentation") >> Fixes: 8a23fc9c94bf ("doc: imx: habv4: Remove extra hab, directory >> for a cleaner documentation structure") >> Fixes: commit 364c0a89bcfa ("doc: imx: habv4: Move encrypted boot
guide").
>> Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de >> --- >> arch/arm/mach-imx/Kconfig | 6 +++--- >> 1 file changed, 3 insertions(+), 3 deletions(-) >> >> diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig >> index aa140c4798..44b47780ee 100644 >> --- a/arch/arm/mach-imx/Kconfig >> +++ b/arch/arm/mach-imx/Kconfig >> @@ -41,7 +41,7 @@ config IMX_HAB >> imply CMD_DEKBLOB >> help >> This option enables the support for secure boot (HAB). >> - See doc/README.mxc_hab for more details. >> + See doc/imx/habv4/guides/encrypted_boot.txt for more
details.
> > Thanks for your patch. > > Indeed, doc/README.mxc_hab is gone and we should replace it, but I
was
> wondering if we should point the file to > doc/imx/habv4/guides/mx6_mx7_secure_boot.txt instead. > > Breno, > > What do you think?
to
If it is SoC related and not board related, doc/soc/imx/ would be good place to put the files. We should provide links from the main index, e.g.
doc/index.rst -> doc/soc/index.rst -> doc/soc/imx/index.rst -> imx_encrypted_boot.rst
Best regards
Heinrich
Hi everybody,
Hi Heinrich,
Hi Heinrich,
Em dom., 12 de abr. de 2020 às 17:35, Heinrich Schuchardt xypron.glpk@gmx.de escreveu: > > On 4/12/20 6:16 PM, Fabio Estevam wrote: >> Hi Heinrich, >> >> On Sun, Apr 12, 2020 at 11:23 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote: >>> >>> doc/README.mxc_hab was moved to doc/imx/habv4/guides/encrypted_boot.txt by >>> commit df11b0c4d4e3 ("doc: imx: reorganize i.MX documentation"), commit >>> dfe9ff9cc79b ("doc: imx: hab: Reorganize High Assurance Boot >>> documentation"), commit 8a23fc9c94bf ("doc: imx: habv4: Remove extra hab, >>> directory for a cleaner documentation structure"), and commit 364c0a89bcfa >>> ("doc: imx: habv4: Move encrypted boot guide"). >>> >>> Fixes: df11b0c4d4e3 ("doc: imx: reorganize i.MX documentation") >>> Fixes: dfe9ff9cc79b ("doc: imx: hab: Reorganize High Assurance Boot >>> documentation") >>> Fixes: 8a23fc9c94bf ("doc: imx: habv4: Remove extra hab, directory >>> for a cleaner documentation structure") >>> Fixes: commit 364c0a89bcfa ("doc: imx: habv4: Move encrypted boot guide"). >>> Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de >>> --- >>> arch/arm/mach-imx/Kconfig | 6 +++--- >>> 1 file changed, 3 insertions(+), 3 deletions(-) >>> >>> diff --git a/arch/arm/mach-imx/Kconfig b/arch/arm/mach-imx/Kconfig >>> index aa140c4798..44b47780ee 100644 >>> --- a/arch/arm/mach-imx/Kconfig >>> +++ b/arch/arm/mach-imx/Kconfig >>> @@ -41,7 +41,7 @@ config IMX_HAB >>> imply CMD_DEKBLOB >>> help >>> This option enables the support for secure boot (HAB). >>> - See doc/README.mxc_hab for more details. >>> + See doc/imx/habv4/guides/encrypted_boot.txt for more details. >> >> Thanks for your patch. >> >> Indeed, doc/README.mxc_hab is gone and we should replace it, but I was >> wondering if we should point the file to >> doc/imx/habv4/guides/mx6_mx7_secure_boot.txt instead. >> >> Breno, >> >> What do you think? > > It is doc/imx/habv4/guides/encrypted_boot.txt that mentions > CONFIG_IMX_HAB and CONFIG_CMD_DEKBLOB. > > Maybe both files can be merged. Anyway the imx directory should move to > doc/board and be integrated into doc/board/index.rst. > > Shouldn't the content of folder doc/imx be moved to doc/board/freescale/ > and linked in doc/board/freescale/index.rst? > > We should be able to generate HTML documentation for imx using 'make > htmldocs'.
I am not again this.
Stefano
Best regards
Heinrich
Hi Heinrich,
On Fri, Apr 17, 2020 at 1:58 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Just realized that your original patch is no longer needed after this one from Patrick got applied: https://gitlab.denx.de/u-boot/u-boot/-/commit/9d82cbd39a75f4388f3705efa99832...
Of course, the conversion to .rst is welcome and if someone is willing to work on it, that will be helpful indeed.
Breno Matheus Lima
Fabio Estevam
Stefano Babic
