[U-Boot] [PATCH 0/6] x86: General cleanup
The following is a series of relative minor x86 patches. Patch 4 (rename i386 to x86) is far more trivial than it looks :)
In theory they could be submitted as six mutually independent patches, but the order becomes important due to the rename and they are all 'cleanup' patches with no significant functional changes
NOTE: checkpatch does complain a bit about the Daniel Engström's name and the '%' used to designate registers in asm files plus there is one long line picked up in the i386 to x86 rename
Graeme Russ (6): eNET: Fix saveenv crash eNET: Remove config.mk x86: Code cleanup x86: Rename i386 to x86 sc520: Move reset to stand-alone file x86: Update MAINTAINERS and delete README files
MAINTAINERS | 4 +- MAKEALL | 4 +- Makefile | 4 +- README | 2 +- arch/{i386 => x86}/config.mk | 0 arch/{i386 => x86}/cpu/Makefile | 0 arch/{i386 => x86}/cpu/config.mk | 2 +- arch/{i386 => x86}/cpu/cpu.c | 33 ++++----- arch/{i386 => x86}/cpu/interrupts.c | 8 +- arch/{i386 => x86}/cpu/resetvec.S | 5 +- arch/{i386 => x86}/cpu/sc520/Makefile | 1 + arch/{i386 => x86}/cpu/sc520/sc520.c | 18 +---- arch/{i386 => x86}/cpu/sc520/sc520_car.S | 5 +- arch/{i386 => x86}/cpu/sc520/sc520_pci.c | 14 ++-- .../processor.h => x86/cpu/sc520/sc520_reset.c} | 24 ++++-- arch/{i386 => x86}/cpu/sc520/sc520_sdram.c | 4 +- arch/{i386 => x86}/cpu/sc520/sc520_ssi.c | 5 +- arch/{i386 => x86}/cpu/sc520/sc520_timer.c | 7 +- arch/{i386 => x86}/cpu/start.S | 34 ++++----- arch/{i386 => x86}/cpu/start16.S | 8 ++- arch/{i386 => x86}/cpu/u-boot.lds | 5 +- arch/{i386 => x86}/include/asm/bitops.h | 0 arch/{i386 => x86}/include/asm/bootparam.h | 0 arch/{i386 => x86}/include/asm/byteorder.h | 0 arch/{i386 => x86}/include/asm/config.h | 0 arch/{i386 => x86}/include/asm/e820.h | 0 arch/{i386 => x86}/include/asm/errno.h | 0 arch/{i386 => x86}/include/asm/global_data.h | 0 arch/{i386 => x86}/include/asm/i8254.h | 0 arch/{i386 => x86}/include/asm/i8259.h | 0 arch/{i386 => x86}/include/asm/ibmpc.h | 0 arch/{i386 => x86}/include/asm/ic/pci.h | 0 arch/{i386 => x86}/include/asm/ic/sc520.h | 0 arch/{i386 => x86}/include/asm/ic/ssi.h | 0 arch/{i386 => x86}/include/asm/interrupt.h | 4 +- arch/{i386 => x86}/include/asm/io.h | 0 arch/{i386 => x86}/include/asm/ioctl.h | 0 arch/{i386 => x86}/include/asm/ist.h | 0 arch/{i386 => x86}/include/asm/pci.h | 0 arch/{i386 => x86}/include/asm/posix_types.h | 0 arch/{i386 => x86}/include/asm/processor-flags.h | 0 arch/{i386 => x86}/include/asm/processor.h | 0 arch/{i386 => x86}/include/asm/ptrace.h | 0 arch/{i386 => x86}/include/asm/realmode.h | 0 arch/{i386 => x86}/include/asm/string.h | 0 arch/{i386 => x86}/include/asm/types.h | 0 .../u-boot-i386.h => x86/include/asm/u-boot-x86.h} | 4 +- arch/{i386 => x86}/include/asm/u-boot.h | 0 arch/{i386 => x86}/include/asm/unaligned.h | 0 arch/{i386 => x86}/include/asm/video/edid.h | 0 arch/{i386 => x86}/include/asm/zimage.h | 0 arch/{i386 => x86}/lib/Makefile | 0 arch/{i386 => x86}/lib/bios.S | 3 +- arch/{i386 => x86}/lib/bios.h | 12 ++-- arch/{i386 => x86}/lib/bios_pci.S | 0 arch/{i386 => x86}/lib/bios_setup.c | 3 +- arch/{i386 => x86}/lib/board.c | 23 +++---- arch/{i386 => x86}/lib/bootm.c | 15 +++-- arch/{i386 => x86}/lib/interrupts.c | 16 ++-- arch/{i386 => x86}/lib/pcat_interrupts.c | 4 +- arch/{i386 => x86}/lib/pcat_timer.c | 2 +- arch/{i386 => x86}/lib/pci.c | 18 ++--- arch/{i386 => x86}/lib/pci_type1.c | 27 ++++++-- arch/{i386 => x86}/lib/realmode.c | 10 +-- arch/{i386 => x86}/lib/realmode_switch.S | 1 - arch/{i386 => x86}/lib/timer.c | 5 +- arch/{i386 => x86}/lib/video.c | 27 +++----- arch/{i386 => x86}/lib/video_bios.c | 2 +- arch/{i386 => x86}/lib/zimage.c | 4 +- board/eNET/config.mk | 24 ------ board/eNET/eNET_pci.c | 7 +- boards.cfg | 4 +- common/exports.c | 2 +- doc/README-i386 | 74 -------------------- doc/TODO-i386 | 29 -------- examples/standalone/stubs.c | 4 +- include/common.h | 6 +- include/configs/eNET.h | 23 ++++-- include/exports.h | 2 +- 79 files changed, 209 insertions(+), 333 deletions(-) rename arch/{i386 => x86}/config.mk (100%) rename arch/{i386 => x86}/cpu/Makefile (100%) rename arch/{i386 => x86}/cpu/config.mk (94%) rename arch/{i386 => x86}/cpu/cpu.c (89%) rename arch/{i386 => x86}/cpu/interrupts.c (99%) rename arch/{i386 => x86}/cpu/resetvec.S (89%) rename arch/{i386 => x86}/cpu/sc520/Makefile (96%) rename arch/{i386 => x86}/cpu/sc520/sc520.c (82%) rename arch/{i386 => x86}/cpu/sc520/sc520_car.S (97%) rename arch/{i386 => x86}/cpu/sc520/sc520_pci.c (94%) copy arch/{i386/include/asm/processor.h => x86/cpu/sc520/sc520_reset.c} (67%) rename arch/{i386 => x86}/cpu/sc520/sc520_sdram.c (99%) rename arch/{i386 => x86}/cpu/sc520/sc520_ssi.c (94%) rename arch/{i386 => x86}/cpu/sc520/sc520_timer.c (94%) rename arch/{i386 => x86}/cpu/start.S (84%) rename arch/{i386 => x86}/cpu/start16.S (93%) rename arch/{i386 => x86}/cpu/u-boot.lds (90%) rename arch/{i386 => x86}/include/asm/bitops.h (100%) rename arch/{i386 => x86}/include/asm/bootparam.h (100%) rename arch/{i386 => x86}/include/asm/byteorder.h (100%) rename arch/{i386 => x86}/include/asm/config.h (100%) rename arch/{i386 => x86}/include/asm/e820.h (100%) rename arch/{i386 => x86}/include/asm/errno.h (100%) rename arch/{i386 => x86}/include/asm/global_data.h (100%) rename arch/{i386 => x86}/include/asm/i8254.h (100%) rename arch/{i386 => x86}/include/asm/i8259.h (100%) rename arch/{i386 => x86}/include/asm/ibmpc.h (100%) rename arch/{i386 => x86}/include/asm/ic/pci.h (100%) rename arch/{i386 => x86}/include/asm/ic/sc520.h (100%) rename arch/{i386 => x86}/include/asm/ic/ssi.h (100%) rename arch/{i386 => x86}/include/asm/interrupt.h (95%) rename arch/{i386 => x86}/include/asm/io.h (100%) rename arch/{i386 => x86}/include/asm/ioctl.h (100%) rename arch/{i386 => x86}/include/asm/ist.h (100%) rename arch/{i386 => x86}/include/asm/pci.h (100%) rename arch/{i386 => x86}/include/asm/posix_types.h (100%) rename arch/{i386 => x86}/include/asm/processor-flags.h (100%) rename arch/{i386 => x86}/include/asm/processor.h (100%) rename arch/{i386 => x86}/include/asm/ptrace.h (100%) rename arch/{i386 => x86}/include/asm/realmode.h (100%) rename arch/{i386 => x86}/include/asm/string.h (100%) rename arch/{i386 => x86}/include/asm/types.h (100%) rename arch/{i386/include/asm/u-boot-i386.h => x86/include/asm/u-boot-x86.h} (93%) rename arch/{i386 => x86}/include/asm/u-boot.h (100%) rename arch/{i386 => x86}/include/asm/unaligned.h (100%) rename arch/{i386 => x86}/include/asm/video/edid.h (100%) rename arch/{i386 => x86}/include/asm/zimage.h (100%) rename arch/{i386 => x86}/lib/Makefile (100%) rename arch/{i386 => x86}/lib/bios.S (99%) rename arch/{i386 => x86}/lib/bios.h (90%) rename arch/{i386 => x86}/lib/bios_pci.S (100%) rename arch/{i386 => x86}/lib/bios_setup.c (99%) rename arch/{i386 => x86}/lib/board.c (95%) rename arch/{i386 => x86}/lib/bootm.c (86%) rename arch/{i386 => x86}/lib/interrupts.c (88%) rename arch/{i386 => x86}/lib/pcat_interrupts.c (96%) rename arch/{i386 => x86}/lib/pcat_timer.c (97%) rename arch/{i386 => x86}/lib/pci.c (94%) rename arch/{i386 => x86}/lib/pci_type1.c (61%) rename arch/{i386 => x86}/lib/realmode.c (95%) rename arch/{i386 => x86}/lib/realmode_switch.S (99%) rename arch/{i386 => x86}/lib/timer.c (94%) rename arch/{i386 => x86}/lib/video.c (94%) rename arch/{i386 => x86}/lib/video_bios.c (99%) rename arch/{i386 => x86}/lib/zimage.c (98%) delete mode 100644 board/eNET/config.mk delete mode 100644 doc/README-i386 delete mode 100644 doc/TODO-i386
CONFIG_ENV_SIZE = CONFIG_ENV_SECT_SIZE = 128kB but CONFIG_SYS_STACK_SIZE is only 32kB resulting in saveenv causing a stack overflow and crashing U-Boot. Resolve by reducing CONFIG_ENV_SIZE to 4kB
Also fix up CONFIG_SYS_MALLOC_LEN to correctly use environment sector size and add some comments to the memory organisation configuration
Signed-off-by: Graeme Russ graeme.russ@gmail.com --- include/configs/eNET.h | 23 +++++++++++++++++------ 1 files changed, 17 insertions(+), 6 deletions(-)
diff --git a/include/configs/eNET.h b/include/configs/eNET.h index 34a9d68..f3ef7d2 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -158,16 +158,19 @@ /*----------------------------------------------------------------------- * Memory organization: * 32kB Stack + * 16kB Cache-As-RAM @ 0x19200000 * 256kB Monitor + * (128kB + Environment Sector Size) malloc pool */ -#define CONFIG_SYS_STACK_SIZE 0x8000 +#define CONFIG_SYS_STACK_SIZE (32 * 1024) #define CONFIG_SYS_CAR_ADDR 0x19200000 -#define CONFIG_SYS_CAR_SIZE 0x00004000 +#define CONFIG_SYS_CAR_SIZE (16 * 1024) #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_CAR_ADDR + \ CONFIG_SYS_CAR_SIZE) #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MONITOR_LEN (256 * 1024) -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SECT_SIZE + \ + 128*1024) /* Address of temporary Global Data */ #define CONFIG_SYS_INIT_GD_ADDR CONFIG_SYS_CAR_ADDR
@@ -198,17 +201,25 @@ #define CONFIG_SYS_FLASH_LEGACY_512Kx8 #define CONFIG_SYS_FLASH_ERASE_TOUT 2000 /* ms */ #define CONFIG_SYS_FLASH_WRITE_TOUT 2000 /* ms */ + /*----------------------------------------------------------------------- * Environment configuration + * - Boot flash is 512kB with 64kB sectors + * - StrataFlash is 32MB with 128kB sectors + * - Redundant embedded environment is 25% of the Boot flash + * - Redundant StrataFlash environment is <1% of the StrataFlash + * - Environment is therefore located in StrataFlash + * - Primary copy is located in first sector of first flash + * - Redundant copy is located in second sector of first flash + * - Stack is only 32kB, so environment size is limited to 4kB */ #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_SIZE 0x01000 #define CONFIG_ENV_ADDR CONFIG_SYS_FLASH_BASE_1 -/* Redundant Copy */ #define CONFIG_ENV_ADDR_REDUND (CONFIG_SYS_FLASH_BASE_1 + \ CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
/*----------------------------------------------------------------------- * PCI configuration
Applied to u-boot-x86, master branch, thanks.
Regards,
Graeme Russ
By including <config.h> in the ld script, CONFIG_SYS_MONITOR_LEN (defined in the boards config file) can be used in lieu of FLASH_SIZE (defined in the board specific config.mk)
As this is the last remaining entry in the board specific config.mk, this file can now be removed
Signed-off-by: Graeme Russ graeme.russ@gmail.com --- arch/i386/cpu/u-boot.lds | 5 +++-- board/eNET/config.mk | 24 ------------------------ 2 files changed, 3 insertions(+), 26 deletions(-) delete mode 100644 board/eNET/config.mk
diff --git a/arch/i386/cpu/u-boot.lds b/arch/i386/cpu/u-boot.lds index 98a548d..5597422 100644 --- a/arch/i386/cpu/u-boot.lds +++ b/arch/i386/cpu/u-boot.lds @@ -21,6 +21,7 @@ * MA 02111-1307 USA */
+#include <config.h> OUTPUT_FORMAT("elf32-i386", "elf32-i386", "elf32-i386") OUTPUT_ARCH(i386) ENTRY(_start) @@ -89,8 +90,8 @@ SECTIONS * Reset Vector at the end of the Flash ROM */ . = START_16; - .start16 : AT (CONFIG_SYS_TEXT_BASE + (FLASH_SIZE - RESET_SEG_SIZE + START_16)) { KEEP(*(.start16)); } + .start16 : AT (CONFIG_SYS_TEXT_BASE + (CONFIG_SYS_MONITOR_LEN - RESET_SEG_SIZE + START_16)) { KEEP(*(.start16)); }
. = RESET_VEC_LOC; - .resetvec : AT (CONFIG_SYS_TEXT_BASE + (FLASH_SIZE - RESET_SEG_SIZE + RESET_VEC_LOC)) { KEEP(*(.resetvec)); } + .resetvec : AT (CONFIG_SYS_TEXT_BASE + (CONFIG_SYS_MONITOR_LEN - RESET_SEG_SIZE + RESET_VEC_LOC)) { KEEP(*(.resetvec)); } } diff --git a/board/eNET/config.mk b/board/eNET/config.mk deleted file mode 100644 index 9d2dfa5..0000000 --- a/board/eNET/config.mk +++ /dev/null @@ -1,24 +0,0 @@ -# -# (C) Copyright 2002 -# Daniel Engström, Omicron Ceti AB, daniel@omicron.se. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -LDPPFLAGS += -DFLASH_SIZE=0x40000
Regards,
Graeme Russ
Make the copyright notices in the x86 files consistent and update them with proper attributions for recent updates
Also fix a few comment style/accuracy and whitespace/blank line issues
Signed-off-by: Graeme Russ graeme.russ@gmail.com --- arch/i386/cpu/cpu.c | 31 +++++++++++------------ arch/i386/cpu/interrupts.c | 8 +++--- arch/i386/cpu/resetvec.S | 3 +- arch/i386/cpu/sc520/sc520.c | 8 +++--- arch/i386/cpu/sc520/sc520_car.S | 5 +-- arch/i386/cpu/sc520/sc520_pci.c | 14 ++++------ arch/i386/cpu/sc520/sc520_sdram.c | 4 +- arch/i386/cpu/sc520/sc520_ssi.c | 5 +--- arch/i386/cpu/sc520/sc520_timer.c | 7 +++-- arch/i386/cpu/start.S | 28 ++++++++------------- arch/i386/cpu/start16.S | 6 ++++- arch/i386/lib/bios.S | 3 +- arch/i386/lib/bios.h | 44 ++++++++++++++++----------------- arch/i386/lib/bios_setup.c | 3 +- arch/i386/lib/board.c | 21 ++++++---------- arch/i386/lib/bootm.c | 15 +++++++---- arch/i386/lib/interrupts.c | 16 ++++++------ arch/i386/lib/pcat_interrupts.c | 4 +- arch/i386/lib/pcat_timer.c | 2 +- arch/i386/lib/pci.c | 18 ++++++------- arch/i386/lib/pci_type1.c | 27 ++++++++++++++++---- arch/i386/lib/realmode.c | 10 ++----- arch/i386/lib/realmode_switch.S | 1 - arch/i386/lib/timer.c | 5 +++- arch/i386/lib/video.c | 48 +++++++++++++++--------------------- arch/i386/lib/video_bios.c | 2 +- arch/i386/lib/zimage.c | 4 +- board/eNET/eNET_pci.c | 7 +++-- 28 files changed, 170 insertions(+), 179 deletions(-)
diff --git a/arch/i386/cpu/cpu.c b/arch/i386/cpu/cpu.c index 2339cd4..5ca0c91 100644 --- a/arch/i386/cpu/cpu.c +++ b/arch/i386/cpu/cpu.c @@ -1,6 +1,9 @@ /* + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com + * * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * (C) Copyright 2002 * Sysgo Real-Time Solutions, GmbH <www.elinos.com> @@ -29,18 +32,16 @@ * MA 02111-1307 USA */
-/* - * CPU specific code - */ - #include <common.h> #include <command.h> #include <asm/processor.h> #include <asm/processor-flags.h> #include <asm/interrupt.h>
-/* Constructor for a conventional segment GDT (or LDT) entry */ -/* This is a macro so it can be used in initializers */ +/* + * Constructor for a conventional segment GDT (or LDT) entry + * This is a macro so it can be used in initialisers + */ #define GDT_ENTRY(flags, base, limit) \ ((((base) & 0xff000000ULL) << (56-24)) | \ (((flags) & 0x0000f0ffULL) << 40) | \ @@ -48,10 +49,6 @@ (((base) & 0x00ffffffULL) << 16) | \ (((limit) & 0x0000ffffULL)))
-/* - * Set up the GDT - */ - struct gdt_ptr { u16 len; u32 ptr; @@ -59,8 +56,10 @@ struct gdt_ptr {
static void reload_gdt(void) { - /* There are machines which are known to not boot with the GDT - being 8-byte unaligned. Intel recommends 16 byte alignment. */ + /* + * There are machines which are known to not boot with the GDT + * being 8-byte unaligned. Intel recommends 16 byte alignment + */ static const u64 boot_gdt[] __attribute__((aligned(16))) = { /* CS: code, read/execute, 4 GB, base 0 */ [GDT_ENTRY_32BIT_CS] = GDT_ENTRY(0xc09b, 0, 0xfffff), @@ -86,7 +85,6 @@ static void reload_gdt(void) : : "m" (gdt) : "ecx"); }
- int x86_cpu_init_f(void) { const u32 em_rst = ~X86_CR0_EM; @@ -125,7 +123,9 @@ int cpu_init_r(void) __attribute__((weak, alias("x86_cpu_init_r"))); int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { printf ("resetting ...\n"); - udelay(50000); /* wait 50 ms */ + + /* wait 50 ms */ + udelay(50000); disable_interrupts(); reset_cpu(0);
@@ -136,7 +136,6 @@ int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) void flush_cache (unsigned long dummy1, unsigned long dummy2) { asm("wbinvd\n"); - return; }
void __attribute__ ((regparm(0))) generate_gpf(void); diff --git a/arch/i386/cpu/interrupts.c b/arch/i386/cpu/interrupts.c index 1cefe02..62bcadc 100644 --- a/arch/i386/cpu/interrupts.c +++ b/arch/i386/cpu/interrupts.c @@ -1,9 +1,9 @@ /* - * (C) Copyright 2008 - * Graeme Russ, graeme.russ@gmail.com. + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com * * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * Portions of this file are derived from the Linux kernel source * Copyright (C) 1991, 1992 Linus Torvalds @@ -45,7 +45,7 @@ * read/write functions for the control registers and messing everything up. * A memory clobber would solve the problem, but would prevent reordering of * all loads stores around it, which can hurt performance. Solution is to - * use a variable and mimic reads and writes to it to enforce serialization + * use a variable and mimic reads and writes to it to enforce serialisation */ static unsigned long __force_order;
diff --git a/arch/i386/cpu/resetvec.S b/arch/i386/cpu/resetvec.S index d9222dd..27021bd 100644 --- a/arch/i386/cpu/resetvec.S +++ b/arch/i386/cpu/resetvec.S @@ -1,7 +1,8 @@ /* * U-boot - i386 Startup Code * - * Copyright (c) 2002 Omicron Ceti AB, Daniel Engström denaiel@omicron.se + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. diff --git a/arch/i386/cpu/sc520/sc520.c b/arch/i386/cpu/sc520/sc520.c index d0c313b..edc1a5c 100644 --- a/arch/i386/cpu/sc520/sc520.c +++ b/arch/i386/cpu/sc520/sc520.c @@ -1,6 +1,9 @@ /* + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com + * * (C) Copyright 2002 - * Daniel Engstrᅵm, Omicron Ceti AB daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -21,9 +24,6 @@ * MA 02111-1307 USA */
-/* stuff specific for the sc520, - * but idependent of implementation */ - #include <common.h> #include <asm/io.h> #include <asm/processor-flags.h> diff --git a/arch/i386/cpu/sc520/sc520_car.S b/arch/i386/cpu/sc520/sc520_car.S index 22f5225..a33f94f 100644 --- a/arch/i386/cpu/sc520/sc520_car.S +++ b/arch/i386/cpu/sc520/sc520_car.S @@ -1,6 +1,6 @@ /* - * (C) Copyright 2010 - * Graeme Russ graeme.russ@gmail.com. + * (C) Copyright 2010-2011 + * Graeme Russ, graeme.russ@gmail.com * * See file CREDITS for list of people who contributed to this * project. @@ -21,7 +21,6 @@ * MA 02111-1307 USA */
- #include <config.h> #include <asm/processor-flags.h> #include <asm/ic/sc520.h> diff --git a/arch/i386/cpu/sc520/sc520_pci.c b/arch/i386/cpu/sc520/sc520_pci.c index b917734..8cd7ffe 100644 --- a/arch/i386/cpu/sc520/sc520_pci.c +++ b/arch/i386/cpu/sc520/sc520_pci.c @@ -1,6 +1,9 @@ /* + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com + * * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -21,8 +24,6 @@ * MA 02111-1307 USA */
-/* stuff specific for the sc520, but independent of implementation */ - #include <common.h> #include <pci.h> #include <asm/io.h> @@ -54,7 +55,6 @@ static struct { { SC520_IRQ15, 1, 0x80 } };
- /* The interrupt used for PCI INTA-INTD */ int sc520_pci_ints[15] = { -1, -1, -1, -1, -1, -1, -1, -1, @@ -68,9 +68,8 @@ int pci_sc520_set_irq(int pci_pin, int irq) u8 tmpb; u16 tmpw;
-# if 1 - printf("set_irq(): map INT%c to IRQ%d\n", pci_pin + 'A', irq); -#endif + debug("set_irq(): map INT%c to IRQ%d\n", pci_pin + 'A', irq); + if (irq < 0 || irq > 15) { return -1; /* illegal irq */ } @@ -138,5 +137,4 @@ void pci_sc520_init(struct pci_controller *hose) /* enable target memory acceses on host brige */ pci_write_config_word(0, PCI_COMMAND, PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); - } diff --git a/arch/i386/cpu/sc520/sc520_sdram.c b/arch/i386/cpu/sc520/sc520_sdram.c index d5ab55d..f3623f5 100644 --- a/arch/i386/cpu/sc520/sc520_sdram.c +++ b/arch/i386/cpu/sc520/sc520_sdram.c @@ -1,6 +1,6 @@ /* - * (C) Copyright 2010 - * Graeme Russ graeme.russ@gmail.com. + * (C) Copyright 2010,2011 + * Graeme Russ, graeme.russ@gmail.com * * See file CREDITS for list of people who contributed to this * project. diff --git a/arch/i386/cpu/sc520/sc520_ssi.c b/arch/i386/cpu/sc520/sc520_ssi.c index 6e5e346..ac58d25 100644 --- a/arch/i386/cpu/sc520/sc520_ssi.c +++ b/arch/i386/cpu/sc520/sc520_ssi.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -21,8 +21,6 @@ * MA 02111-1307 USA */
-/* stuff specific for the sc520, but independent of implementation */ - #include <common.h> #include <asm/io.h> #include <asm/ic/ssi.h> @@ -77,7 +75,6 @@ u8 ssi_txrx_byte(u8 data) return readb(&sc520_mmcr->ssircv); }
- void ssi_tx_byte(u8 data) { writeb(data, &sc520_mmcr->ssixmit); diff --git a/arch/i386/cpu/sc520/sc520_timer.c b/arch/i386/cpu/sc520/sc520_timer.c index d5617e9..1bcfe67 100644 --- a/arch/i386/cpu/sc520/sc520_timer.c +++ b/arch/i386/cpu/sc520/sc520_timer.c @@ -1,6 +1,9 @@ /* + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com + * * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -21,8 +24,6 @@ * MA 02111-1307 USA */
-/* stuff specific for the sc520, but independent of implementation */ - #include <common.h> #include <asm/io.h> #include <asm/interrupt.h> diff --git a/arch/i386/cpu/start.S b/arch/i386/cpu/start.S index 0031389..2124a42 100644 --- a/arch/i386/cpu/start.S +++ b/arch/i386/cpu/start.S @@ -1,7 +1,11 @@ /* * U-boot - i386 Startup Code * - * Copyright (c) 2002 Omicron Ceti AB, Daniel Engström denaiel@omicron.se + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com + * + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -22,13 +26,11 @@ * MA 02111-1307 USA */
- #include <config.h> #include <version.h> #include <asm/global_data.h> #include <asm/processor-flags.h>
- .section .text .code32 .globl _start @@ -56,8 +58,8 @@ _i386boot_start: _start: /* This is the 32-bit cold-reset entry point */
- movl $0x18, %eax /* Load our segement registes, the - * gdt have already been loaded by start16.S */ + /* Load the segement registes to match the gdt loaded in start16.S */ + movl $0x18, %eax movw %ax, %fs movw %ax, %ds movw %ax, %gs @@ -82,21 +84,13 @@ car_init_ret: * starting at CONFIG_SYS_CAR_ADDR to be used as a temporary stack */ movl $CONFIG_SYS_INIT_SP_ADDR, %esp - movl $CONFIG_SYS_INIT_GD_ADDR, %ebp - - /* Set Boot Flags in Global Data */ - movl %ebx, (GD_FLAGS * 4)(%ebp) - - /* Determine our load offset (and put in Global Data) */ - call 1f -1: popl %ecx - subl $1b, %ecx - movl %ecx, (GD_LOAD_OFF * 4)(%ebp)
/* Set parameter to board_init_f() to boot flags */ - movl (GD_FLAGS * 4)(%ebp), %eax + xorl %eax, %eax + movw %bx, %ax
- call board_init_f /* Enter, U-boot! */ + /* Enter, U-boot! */ + call board_init_f
/* indicate (lack of) progress */ movw $0x85, %ax diff --git a/arch/i386/cpu/start16.S b/arch/i386/cpu/start16.S index 7dc5358..d2e5d13 100644 --- a/arch/i386/cpu/start16.S +++ b/arch/i386/cpu/start16.S @@ -1,7 +1,11 @@ /* * U-boot - i386 Startup Code * - * Copyright (c) 2002, 2003 Omicron Ceti AB, Daniel Engström denaiel@omicron.se + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com + * + * (C) Copyright 2002,2003 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. diff --git a/arch/i386/lib/bios.S b/arch/i386/lib/bios.S index 48f1b81..660a244 100644 --- a/arch/i386/lib/bios.S +++ b/arch/i386/lib/bios.S @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -42,7 +42,6 @@ * a general purpose replacement for a real BIOS !! */
- .section .bios, "ax" .code16 .org 0 diff --git a/arch/i386/lib/bios.h b/arch/i386/lib/bios.h index 4901f89..3c8d61a 100644 --- a/arch/i386/lib/bios.h +++ b/arch/i386/lib/bios.h @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -57,7 +57,7 @@ #define OFFS_FLAGS 44 /* 16bit */
#define SEGMENT 0x40 -#define STACK 0x800 /* stack at 0x40:0x800 -> 0x800 */ +#define STACK 0x800 /* stack at 0x40:0x800 -> 0x800 */
/* save general registers */ /* save some segments */ @@ -67,28 +67,26 @@ /* setup BIOS stackpointer */
#define MAKE_BIOS_STACK \ - pushal ; \ - pushw %ds ; \ - pushw %gs ; \ - pushw %es ; \ - pushw %ss ; \ - popw %gs ; \ - movw $SEGMENT,%ax ; \ - movw %ax,%ds ; \ - movw %ax,%es ; \ - movw %ax,%ss ; \ - movw %sp,%bp ; \ - movw $STACK,%sp + pushal; \ + pushw %ds; \ + pushw %gs; \ + pushw %es; \ + pushw %ss; \ + popw %gs; \ + movw $SEGMENT, %ax; \ + movw %ax, %ds; \ + movw %ax, %es; \ + movw %ax, %ss; \ + movw %sp, %bp; \ + movw $STACK, %sp
#define RESTORE_CALLERS_STACK \ - pushw %gs ; /* restore callers stack segment */ \ - popw %ss ; \ - movw %bp,%sp ; /* restore stackpointer */ \ - \ - popw %es ; /* restore segment selectors */ \ - popw %gs ; \ - popw %ds ; \ - \ - popal /* restore GP registers */ + pushw %gs; /* restore callers stack segment */ \ + popw %ss; \ + movw %bp, %sp; /* restore stackpointer */ \ + popw %es; /* restore segment selectors */ \ + popw %gs; \ + popw %ds; \ + popal /* restore GP registers */
#endif diff --git a/arch/i386/lib/bios_setup.c b/arch/i386/lib/bios_setup.c index 75407c1..6949b35 100644 --- a/arch/i386/lib/bios_setup.c +++ b/arch/i386/lib/bios_setup.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -21,7 +21,6 @@ * MA 02111-1307 USA */
- /* * Partly based on msbios.c from rolo 1.6: *---------------------------------------------------------------------- diff --git a/arch/i386/lib/board.c b/arch/i386/lib/board.c index e0f9803..6d947c6 100644 --- a/arch/i386/lib/board.c +++ b/arch/i386/lib/board.c @@ -1,9 +1,12 @@ /* + * (C) Copyright 2008-2011 + * Graeme Russ, graeme.russ@gmail.com + * * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * (C) Copyright 2002 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * Wolfgang Denk, DENX Software Engineering, wd@denx.de * * (C) Copyright 2002 * Sysgo Real-Time Solutions, GmbH <www.elinos.com> @@ -103,13 +106,6 @@ static int display_banner (void) return (0); }
-/* - * WARNING: this code looks "cleaner" than the PowerPC version, but - * has the disadvantage that you either get nothing, or everything. - * On PowerPC, you might see "DRAM: " before the system hangs - which - * gives a simple yet clear indication which part of the - * initialization if failing. - */ static int display_dram_config (void) { int i; @@ -141,7 +137,6 @@ static void display_flash_config (ulong size) * can relocate the monitor code to RAM. */
- /* * All attempts to come up with a "common" initialization sequence * that works for all boards and architectures failed: some of the @@ -251,13 +246,13 @@ static int do_elf_reloc_fixups(void) return 0; }
-/* - * Load U-Boot into RAM, initialize BSS, perform relocation adjustments - */ +/* Load U-Boot into RAM, initialize BSS, perform relocation adjustments */ void board_init_f(ulong boot_flags) { init_fnc_t **init_fnc_ptr;
+ gd->flags = boot_flags; + for (init_fnc_ptr = init_sequence_f; *init_fnc_ptr; ++init_fnc_ptr) { if ((*init_fnc_ptr)() != 0) hang(); diff --git a/arch/i386/lib/bootm.c b/arch/i386/lib/bootm.c index b36e58d..a21a21f 100644 --- a/arch/i386/lib/bootm.c +++ b/arch/i386/lib/bootm.c @@ -5,10 +5,13 @@ * * Copyright (C) 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of @@ -17,8 +20,8 @@ * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA - * + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA */
#include <common.h> diff --git a/arch/i386/lib/interrupts.c b/arch/i386/lib/interrupts.c index 5a28278..a2c598f 100644 --- a/arch/i386/lib/interrupts.c +++ b/arch/i386/lib/interrupts.c @@ -1,21 +1,21 @@ /* * (C) Copyright 2009 - * Graeme Russ, graeme.russ@gmail.com + * Graeme Russ, graeme.russ@gmail.com * * (C) Copyright 2007 - * Daniel Hellstrom, Gaisler Research, daniel@gaisler.com + * Daniel Hellstrom, Gaisler Research, daniel@gaisler.com * * (C) Copyright 2006 - * Detlev Zundel, DENX Software Engineering, dzu@denx.de + * Detlev Zundel, DENX Software Engineering, dzu@denx.de * * (C) Copyright -2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * Wolfgang Denk, DENX Software Engineering, wd@denx.de * * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * (C) Copyright 2001 - * Josh Huber huber@mclx.com, Mission Critical Linux, Inc. + * Josh Huber, Mission Critical Linux, Inc, huber@mclx.com * * See file CREDITS for list of people who contributed to this * project. @@ -38,11 +38,11 @@
/* * This file contains the high-level API for the interrupt sub-system - * of the i386 port of U-Boot. Most of the functionality has been + * of the x86 port of U-Boot. Most of the functionality has been * shamelessly stolen from the leon2 / leon3 ports of U-Boot. * Daniel Hellstrom, Detlev Zundel, Wolfgang Denk and Josh Huber are * credited for the corresponding work on those ports. The original - * interrupt handling routines for the i386 port were written by + * interrupt handling routines for the x86 port were written by * Daniel Engström */
diff --git a/arch/i386/lib/pcat_interrupts.c b/arch/i386/lib/pcat_interrupts.c index 67e6e97..364c435 100644 --- a/arch/i386/lib/pcat_interrupts.c +++ b/arch/i386/lib/pcat_interrupts.c @@ -1,9 +1,9 @@ /* * (C) Copyright 2009 - * Graeme Russ, graeme.russ@gmail.com + * Graeme Russ, graeme.russ@gmail.com * * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. diff --git a/arch/i386/lib/pcat_timer.c b/arch/i386/lib/pcat_timer.c index 1373fd1..1911c6c 100644 --- a/arch/i386/lib/pcat_timer.c +++ b/arch/i386/lib/pcat_timer.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. diff --git a/arch/i386/lib/pci.c b/arch/i386/lib/pci.c index 9020e7c..e791e88 100644 --- a/arch/i386/lib/pci.c +++ b/arch/i386/lib/pci.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -54,10 +54,9 @@ int pci_shadow_rom(pci_dev_t dev, unsigned char *dest) class_code &= 0xffffff00; class_code >>= 8;
-#if 0 - printf("PCI Header Vendor %04x device %04x class %06x\n", + debug("PCI Header Vendor %04x device %04x class %06x\n", vendor, device, class_code); -#endif + /* Enable the rom addess decoder */ pci_write_config_dword(dev, PCI_ROM_ADDRESS, (u32)PCI_ROM_ADDRESS_MASK); pci_read_config_dword(dev, PCI_ROM_ADDRESS, &addr_reg); @@ -70,13 +69,12 @@ int pci_shadow_rom(pci_dev_t dev, unsigned char *dest)
size = (~(addr_reg&PCI_ROM_ADDRESS_MASK))+1;
-#if 0 - printf("ROM is %d bytes\n", size); -#endif + debug("ROM is %d bytes\n", size); + rom_addr = pci_get_rom_window(hose, size); -#if 0 - printf("ROM mapped at %x \n", rom_addr); -#endif + + debug("ROM mapped at %x\n", rom_addr); + pci_write_config_dword(dev, PCI_ROM_ADDRESS, pci_phys_to_mem(dev, rom_addr) |PCI_ROM_ADDRESS_ENABLE); diff --git a/arch/i386/lib/pci_type1.c b/arch/i386/lib/pci_type1.c index 225ae4a..8ce5b33 100644 --- a/arch/i386/lib/pci_type1.c +++ b/arch/i386/lib/pci_type1.c @@ -1,15 +1,30 @@ /* - * Support for type PCI configuration cycles. - * based on pci_indirect.c + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * - * Copyright (C) 2002 Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * See file CREDITS for list of people who contributed to this + * project. * * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * as published by the Free Software Foundation; either version - * 2 of the License, or (at your option) any later version. + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA */
+/* + * Support for type PCI configuration cycles. + * based on pci_indirect.c + */ #include <common.h> #include <asm/io.h> #include <pci.h> diff --git a/arch/i386/lib/realmode.c b/arch/i386/lib/realmode.c index 2dda95b..5be827c 100644 --- a/arch/i386/lib/realmode.c +++ b/arch/i386/lib/realmode.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -26,10 +26,8 @@ #include <asm/ptrace.h> #include <asm/realmode.h>
- #define REALMODE_MAILBOX ((char*)0xe00)
- extern ulong __realmode_start; extern ulong __realmode_size; extern char realmode_enter; @@ -57,13 +55,11 @@ int enter_realmode(u16 seg, u16 off, struct pt_regs *in, struct pt_regs *out) {
/* setup out thin bios emulation */ - if (bios_setup()) { + if (bios_setup()) return -1; - }
- if (realmode_setup()) { + if (realmode_setup()) return -1; - }
in->eip = off; in->xcs = seg; diff --git a/arch/i386/lib/realmode_switch.S b/arch/i386/lib/realmode_switch.S index d6c74ec..fce4ecc 100644 --- a/arch/i386/lib/realmode_switch.S +++ b/arch/i386/lib/realmode_switch.S @@ -21,7 +21,6 @@ * MA 02111-1307 USA */
- /* 32bit -> 16bit -> 32bit mode switch code */
/* diff --git a/arch/i386/lib/timer.c b/arch/i386/lib/timer.c index 5cb1f54..8fc68cd 100644 --- a/arch/i386/lib/timer.c +++ b/arch/i386/lib/timer.c @@ -1,6 +1,9 @@ /* + * (C) Copyright 2008,2009 + * Graeme Russ, graeme.russ@gmail.com + * * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. diff --git a/arch/i386/lib/video.c b/arch/i386/lib/video.c index c58ed10..b29075c 100644 --- a/arch/i386/lib/video.c +++ b/arch/i386/lib/video.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -30,7 +30,6 @@ #include <asm/io.h> #include <asm/pci.h>
- /* basic textmode I/O from linux kernel */ static char *vidmem = (char *)0xb8000; static int vidport; @@ -42,9 +41,9 @@ static void beep(int dur) int i;
outb_p(3, 0x61); - for (i=0;i<10*dur;i++) { + for (i = 0; i < 10*dur; i++) udelay(1000); - } + outb_p(0, 0x61); }
@@ -52,8 +51,8 @@ static void scroll(void) { int i;
- memcpy ( vidmem, vidmem + cols * 2, ( lines - 1 ) * cols * 2 ); - for ( i = ( lines - 1 ) * cols * 2; i < lines * cols * 2; i += 2 ) + memcpy(vidmem, vidmem + cols * 2, (lines - 1) * cols * 2); + for (i = (lines - 1) * cols * 2; i < lines * cols * 2; i += 2) vidmem[i] = ' '; }
@@ -61,14 +60,14 @@ static void __video_putc(const char c, int *x, int *y) { if (c == '\n') { (*x) = 0; - if ( ++(*y) >= lines ) { + if (++(*y) >= lines) { scroll(); (*y)--; } } else if (c == '\b') { if ((*x) != 0) { --(*x); - vidmem [ ( (*x) + cols * (*y) ) * 2 ] = ' '; + vidmem[((*x) + cols * (*y)) * 2] = ' '; } } else if (c == '\r') { (*x) = 0; @@ -106,16 +105,15 @@ static void __video_putc(const char c, int *x, int *y) } } else if (c == '\f') { int i; - for (i=0;i<lines*cols*2;i+=2) { + for (i = 0; i < lines * cols * 2; i += 2) vidmem[i] = 0; - } (*x) = 0; (*y) = 0; } else { - vidmem [ ( (*x) + cols * (*y) ) * 2 ] = c; - if ( ++(*x) >= cols ) { + vidmem[((*x) + cols * (*y)) * 2] = c; + if (++(*x) >= cols) { (*x) = 0; - if ( ++(*y) >= lines ) { + if (++(*y) >= lines) { scroll(); (*y)--; } @@ -150,9 +148,8 @@ static void video_puts(const char *s) x = orig_x; y = orig_y;
- while ( ( c = *s++ ) != '\0' ) { + while ((c = *s++) != '\0') __video_putc(c, &x, &y); - }
orig_x = x; orig_y = y; @@ -189,10 +186,8 @@ int video_init(void) #if 0 printf("pos %x %d %d\n", pos, orig_x, orig_y); #endif - if (orig_y > lines) { + if (orig_y > lines) orig_x = orig_y =0; - } -
memset(&vga_dev, 0, sizeof(vga_dev)); strcpy(vga_dev.name, "vga"); @@ -203,13 +198,11 @@ int video_init(void) vga_dev.tstc = NULL; /* 'tstc' function */ vga_dev.getc = NULL; /* 'getc' function */
- if (stdio_register(&vga_dev) == 0) { - return 1; - } + if (stdio_register(&vga_dev) == 0) + return 1;
- if (i8042_kbd_init()) { + if (i8042_kbd_init()) return 1; - }
memset(&kbd_dev, 0, sizeof(kbd_dev)); strcpy(kbd_dev.name, "kbd"); @@ -220,18 +213,17 @@ int video_init(void) kbd_dev.tstc = i8042_tstc; /* 'tstc' function */ kbd_dev.getc = i8042_getc; /* 'getc' function */
- if (stdio_register(&kbd_dev) == 0) { - return 1; - } + if (stdio_register(&kbd_dev) == 0) + return 1; + return 0; }
int drv_video_init(void) { - if (video_bios_init()) { + if (video_bios_init()) return 1; - }
return video_init(); } diff --git a/arch/i386/lib/video_bios.c b/arch/i386/lib/video_bios.c index c8060e6..6bc4335 100644 --- a/arch/i386/lib/video_bios.c +++ b/arch/i386/lib/video_bios.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. diff --git a/arch/i386/lib/zimage.c b/arch/i386/lib/zimage.c index 0c42072..cc4b40e 100644 --- a/arch/i386/lib/zimage.c +++ b/arch/i386/lib/zimage.c @@ -1,6 +1,6 @@ /* * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -22,7 +22,7 @@ */
/* - * Linux i386 zImage and bzImage loading + * Linux x86 zImage and bzImage loading * * based on the procdure described in * linux/Documentation/i386/boot.txt diff --git a/board/eNET/eNET_pci.c b/board/eNET/eNET_pci.c index fefb1a4..a03090e 100644 --- a/board/eNET/eNET_pci.c +++ b/board/eNET/eNET_pci.c @@ -1,9 +1,9 @@ /* - * (C) Copyright 2008 - * Graeme Russ, graeme.russ@gmail.com. + * (C) Copyright 2008,2009 + * Graeme Russ, graeme.russ@gmail.com * * (C) Copyright 2002 - * Daniel Engström, Omicron Ceti AB daniel@omicron.se. + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se * * See file CREDITS for list of people who contributed to this * project. @@ -23,6 +23,7 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ + #include <common.h> #include <pci.h> #include <asm/pci.h>
Regards,
Graeme Russ
Signed-off-by: Graeme Russ graeme.russ@gmail.com --- MAKEALL | 4 ++-- Makefile | 4 ++-- README | 2 +- arch/{i386 => x86}/config.mk | 0 arch/{i386 => x86}/cpu/Makefile | 0 arch/{i386 => x86}/cpu/config.mk | 2 +- arch/{i386 => x86}/cpu/cpu.c | 2 +- arch/{i386 => x86}/cpu/interrupts.c | 0 arch/{i386 => x86}/cpu/resetvec.S | 2 +- arch/{i386 => x86}/cpu/sc520/Makefile | 0 arch/{i386 => x86}/cpu/sc520/sc520.c | 0 arch/{i386 => x86}/cpu/sc520/sc520_car.S | 0 arch/{i386 => x86}/cpu/sc520/sc520_pci.c | 0 arch/{i386 => x86}/cpu/sc520/sc520_sdram.c | 0 arch/{i386 => x86}/cpu/sc520/sc520_ssi.c | 0 arch/{i386 => x86}/cpu/sc520/sc520_timer.c | 0 arch/{i386 => x86}/cpu/start.S | 6 +++--- arch/{i386 => x86}/cpu/start16.S | 2 +- arch/{i386 => x86}/cpu/u-boot.lds | 0 arch/{i386 => x86}/include/asm/bitops.h | 0 arch/{i386 => x86}/include/asm/bootparam.h | 0 arch/{i386 => x86}/include/asm/byteorder.h | 0 arch/{i386 => x86}/include/asm/config.h | 0 arch/{i386 => x86}/include/asm/e820.h | 0 arch/{i386 => x86}/include/asm/errno.h | 0 arch/{i386 => x86}/include/asm/global_data.h | 0 arch/{i386 => x86}/include/asm/i8254.h | 0 arch/{i386 => x86}/include/asm/i8259.h | 0 arch/{i386 => x86}/include/asm/ibmpc.h | 0 arch/{i386 => x86}/include/asm/ic/pci.h | 0 arch/{i386 => x86}/include/asm/ic/sc520.h | 0 arch/{i386 => x86}/include/asm/ic/ssi.h | 0 arch/{i386 => x86}/include/asm/interrupt.h | 4 ++-- arch/{i386 => x86}/include/asm/io.h | 0 arch/{i386 => x86}/include/asm/ioctl.h | 0 arch/{i386 => x86}/include/asm/ist.h | 0 arch/{i386 => x86}/include/asm/pci.h | 0 arch/{i386 => x86}/include/asm/posix_types.h | 0 arch/{i386 => x86}/include/asm/processor-flags.h | 0 arch/{i386 => x86}/include/asm/processor.h | 0 arch/{i386 => x86}/include/asm/ptrace.h | 0 arch/{i386 => x86}/include/asm/realmode.h | 0 arch/{i386 => x86}/include/asm/string.h | 0 arch/{i386 => x86}/include/asm/types.h | 0 .../u-boot-i386.h => x86/include/asm/u-boot-x86.h} | 4 ++-- arch/{i386 => x86}/include/asm/u-boot.h | 0 arch/{i386 => x86}/include/asm/unaligned.h | 0 arch/{i386 => x86}/include/asm/video/edid.h | 0 arch/{i386 => x86}/include/asm/zimage.h | 0 arch/{i386 => x86}/lib/Makefile | 0 arch/{i386 => x86}/lib/bios.S | 0 arch/{i386 => x86}/lib/bios.h | 0 arch/{i386 => x86}/lib/bios_pci.S | 0 arch/{i386 => x86}/lib/bios_setup.c | 0 arch/{i386 => x86}/lib/board.c | 2 +- arch/{i386 => x86}/lib/bootm.c | 0 arch/{i386 => x86}/lib/interrupts.c | 0 arch/{i386 => x86}/lib/pcat_interrupts.c | 0 arch/{i386 => x86}/lib/pcat_timer.c | 0 arch/{i386 => x86}/lib/pci.c | 0 arch/{i386 => x86}/lib/pci_type1.c | 0 arch/{i386 => x86}/lib/realmode.c | 0 arch/{i386 => x86}/lib/realmode_switch.S | 0 arch/{i386 => x86}/lib/timer.c | 0 arch/{i386 => x86}/lib/video.c | 0 arch/{i386 => x86}/lib/video_bios.c | 0 arch/{i386 => x86}/lib/zimage.c | 0 boards.cfg | 4 ++-- common/exports.c | 2 +- doc/{README-i386 => README-x86} | 2 +- examples/standalone/stubs.c | 4 ++-- include/common.h | 6 +++--- include/configs/eNET.h | 1 - include/exports.h | 2 +- 74 files changed, 27 insertions(+), 28 deletions(-) rename arch/{i386 => x86}/config.mk (100%) rename arch/{i386 => x86}/cpu/Makefile (100%) rename arch/{i386 => x86}/cpu/config.mk (94%) rename arch/{i386 => x86}/cpu/cpu.c (98%) rename arch/{i386 => x86}/cpu/interrupts.c (100%) rename arch/{i386 => x86}/cpu/resetvec.S (97%) rename arch/{i386 => x86}/cpu/sc520/Makefile (100%) rename arch/{i386 => x86}/cpu/sc520/sc520.c (100%) rename arch/{i386 => x86}/cpu/sc520/sc520_car.S (100%) rename arch/{i386 => x86}/cpu/sc520/sc520_pci.c (100%) rename arch/{i386 => x86}/cpu/sc520/sc520_sdram.c (100%) rename arch/{i386 => x86}/cpu/sc520/sc520_ssi.c (100%) rename arch/{i386 => x86}/cpu/sc520/sc520_timer.c (100%) rename arch/{i386 => x86}/cpu/start.S (97%) rename arch/{i386 => x86}/cpu/start16.S (98%) rename arch/{i386 => x86}/cpu/u-boot.lds (100%) rename arch/{i386 => x86}/include/asm/bitops.h (100%) rename arch/{i386 => x86}/include/asm/bootparam.h (100%) rename arch/{i386 => x86}/include/asm/byteorder.h (100%) rename arch/{i386 => x86}/include/asm/config.h (100%) rename arch/{i386 => x86}/include/asm/e820.h (100%) rename arch/{i386 => x86}/include/asm/errno.h (100%) rename arch/{i386 => x86}/include/asm/global_data.h (100%) rename arch/{i386 => x86}/include/asm/i8254.h (100%) rename arch/{i386 => x86}/include/asm/i8259.h (100%) rename arch/{i386 => x86}/include/asm/ibmpc.h (100%) rename arch/{i386 => x86}/include/asm/ic/pci.h (100%) rename arch/{i386 => x86}/include/asm/ic/sc520.h (100%) rename arch/{i386 => x86}/include/asm/ic/ssi.h (100%) rename arch/{i386 => x86}/include/asm/interrupt.h (95%) rename arch/{i386 => x86}/include/asm/io.h (100%) rename arch/{i386 => x86}/include/asm/ioctl.h (100%) rename arch/{i386 => x86}/include/asm/ist.h (100%) rename arch/{i386 => x86}/include/asm/pci.h (100%) rename arch/{i386 => x86}/include/asm/posix_types.h (100%) rename arch/{i386 => x86}/include/asm/processor-flags.h (100%) rename arch/{i386 => x86}/include/asm/processor.h (100%) rename arch/{i386 => x86}/include/asm/ptrace.h (100%) rename arch/{i386 => x86}/include/asm/realmode.h (100%) rename arch/{i386 => x86}/include/asm/string.h (100%) rename arch/{i386 => x86}/include/asm/types.h (100%) rename arch/{i386/include/asm/u-boot-i386.h => x86/include/asm/u-boot-x86.h} (93%) rename arch/{i386 => x86}/include/asm/u-boot.h (100%) rename arch/{i386 => x86}/include/asm/unaligned.h (100%) rename arch/{i386 => x86}/include/asm/video/edid.h (100%) rename arch/{i386 => x86}/include/asm/zimage.h (100%) rename arch/{i386 => x86}/lib/Makefile (100%) rename arch/{i386 => x86}/lib/bios.S (100%) rename arch/{i386 => x86}/lib/bios.h (100%) rename arch/{i386 => x86}/lib/bios_pci.S (100%) rename arch/{i386 => x86}/lib/bios_setup.c (100%) rename arch/{i386 => x86}/lib/board.c (99%) rename arch/{i386 => x86}/lib/bootm.c (100%) rename arch/{i386 => x86}/lib/interrupts.c (100%) rename arch/{i386 => x86}/lib/pcat_interrupts.c (100%) rename arch/{i386 => x86}/lib/pcat_timer.c (100%) rename arch/{i386 => x86}/lib/pci.c (100%) rename arch/{i386 => x86}/lib/pci_type1.c (100%) rename arch/{i386 => x86}/lib/realmode.c (100%) rename arch/{i386 => x86}/lib/realmode_switch.S (100%) rename arch/{i386 => x86}/lib/timer.c (100%) rename arch/{i386 => x86}/lib/video.c (100%) rename arch/{i386 => x86}/lib/video_bios.c (100%) rename arch/{i386 => x86}/lib/zimage.c (100%) rename doc/{README-i386 => README-x86} (97%)
diff --git a/MAKEALL b/MAKEALL index e1b928f..6acece7 100755 --- a/MAKEALL +++ b/MAKEALL @@ -544,10 +544,10 @@ LIST_mips_el=" \ "
######################################################################### -## i386 Systems +## x86 Systems #########################################################################
-LIST_x86="$(boards_by_arch i386)" +LIST_x86="$(boards_by_arch x86)"
######################################################################### ## Nios-II Systems diff --git a/Makefile b/Makefile index 10a856a..5bbb014 100644 --- a/Makefile +++ b/Makefile @@ -34,7 +34,7 @@ TIMESTAMP_FILE = $(obj)include/timestamp_autogenerated.h VERSION_FILE = $(obj)include/version_autogenerated.h
HOSTARCH := $(shell uname -m | \ - sed -e s/i.86/i386/ \ + sed -e s/i.86/x86/ \ -e s/sun4u/sparc64/ \ -e s/arm.*/arm/ \ -e s/sa110/arm/ \ @@ -167,7 +167,7 @@ include $(TOPDIR)/config.mk # U-Boot objects....order is important (i.e. start must be first)
OBJS = $(CPUDIR)/start.o -ifeq ($(CPU),i386) +ifeq ($(CPU),x86) OBJS += $(CPUDIR)/start16.o OBJS += $(CPUDIR)/resetvec.o endif diff --git a/README b/README index bd03523..8d85db7 100644 --- a/README +++ b/README @@ -164,7 +164,7 @@ Directory Hierarchy: /blackfin Files generic to Analog Devices Blackfin architecture /cpu CPU specific files /lib Architecture specific library files - /i386 Files generic to i386 architecture + /x86 Files generic to x86 architecture /cpu CPU specific files /lib Architecture specific library files /m68k Files generic to m68k architecture diff --git a/arch/i386/config.mk b/arch/x86/config.mk similarity index 100% rename from arch/i386/config.mk rename to arch/x86/config.mk diff --git a/arch/i386/cpu/Makefile b/arch/x86/cpu/Makefile similarity index 100% rename from arch/i386/cpu/Makefile rename to arch/x86/cpu/Makefile diff --git a/arch/i386/cpu/config.mk b/arch/x86/cpu/config.mk similarity index 94% rename from arch/i386/cpu/config.mk rename to arch/x86/cpu/config.mk index 9b2e2c9..d1b528a 100644 --- a/arch/i386/cpu/config.mk +++ b/arch/x86/cpu/config.mk @@ -23,7 +23,7 @@
CROSS_COMPILE ?= i386-linux-
-PLATFORM_CPPFLAGS += -DCONFIG_I386 -D__I386__ -march=i386 -Werror +PLATFORM_CPPFLAGS += -DCONFIG_X86 -D__I386__ -march=i386 -Werror
# DO NOT MODIFY THE FOLLOWING UNLESS YOU REALLY KNOW WHAT YOU ARE DOING! LDPPFLAGS += -DRESET_SEG_START=0xffff0000 diff --git a/arch/i386/cpu/cpu.c b/arch/x86/cpu/cpu.c similarity index 98% rename from arch/i386/cpu/cpu.c rename to arch/x86/cpu/cpu.c index 5ca0c91..0c5d7c3 100644 --- a/arch/i386/cpu/cpu.c +++ b/arch/x86/cpu/cpu.c @@ -149,7 +149,7 @@ asm(".globl generate_gpf\n"
void __reset_cpu(ulong addr) { - printf("Resetting using i386 Triple Fault\n"); + printf("Resetting using x86 Triple Fault\n"); set_vector(13, generate_gpf); /* general protection fault handler */ set_vector(8, generate_gpf); /* double fault handler */ generate_gpf(); /* start the show */ diff --git a/arch/i386/cpu/interrupts.c b/arch/x86/cpu/interrupts.c similarity index 100% rename from arch/i386/cpu/interrupts.c rename to arch/x86/cpu/interrupts.c diff --git a/arch/i386/cpu/resetvec.S b/arch/x86/cpu/resetvec.S similarity index 97% rename from arch/i386/cpu/resetvec.S rename to arch/x86/cpu/resetvec.S index 27021bd..c690d25 100644 --- a/arch/i386/cpu/resetvec.S +++ b/arch/x86/cpu/resetvec.S @@ -1,5 +1,5 @@ /* - * U-boot - i386 Startup Code + * U-boot - x86 Startup Code * * (C) Copyright 2002 * Daniel Engström, Omicron Ceti AB, daniel@omicron.se diff --git a/arch/i386/cpu/sc520/Makefile b/arch/x86/cpu/sc520/Makefile similarity index 100% rename from arch/i386/cpu/sc520/Makefile rename to arch/x86/cpu/sc520/Makefile diff --git a/arch/i386/cpu/sc520/sc520.c b/arch/x86/cpu/sc520/sc520.c similarity index 100% rename from arch/i386/cpu/sc520/sc520.c rename to arch/x86/cpu/sc520/sc520.c diff --git a/arch/i386/cpu/sc520/sc520_car.S b/arch/x86/cpu/sc520/sc520_car.S similarity index 100% rename from arch/i386/cpu/sc520/sc520_car.S rename to arch/x86/cpu/sc520/sc520_car.S diff --git a/arch/i386/cpu/sc520/sc520_pci.c b/arch/x86/cpu/sc520/sc520_pci.c similarity index 100% rename from arch/i386/cpu/sc520/sc520_pci.c rename to arch/x86/cpu/sc520/sc520_pci.c diff --git a/arch/i386/cpu/sc520/sc520_sdram.c b/arch/x86/cpu/sc520/sc520_sdram.c similarity index 100% rename from arch/i386/cpu/sc520/sc520_sdram.c rename to arch/x86/cpu/sc520/sc520_sdram.c diff --git a/arch/i386/cpu/sc520/sc520_ssi.c b/arch/x86/cpu/sc520/sc520_ssi.c similarity index 100% rename from arch/i386/cpu/sc520/sc520_ssi.c rename to arch/x86/cpu/sc520/sc520_ssi.c diff --git a/arch/i386/cpu/sc520/sc520_timer.c b/arch/x86/cpu/sc520/sc520_timer.c similarity index 100% rename from arch/i386/cpu/sc520/sc520_timer.c rename to arch/x86/cpu/sc520/sc520_timer.c diff --git a/arch/i386/cpu/start.S b/arch/x86/cpu/start.S similarity index 97% rename from arch/i386/cpu/start.S rename to arch/x86/cpu/start.S index 2124a42..7ccc076 100644 --- a/arch/i386/cpu/start.S +++ b/arch/x86/cpu/start.S @@ -1,5 +1,5 @@ /* - * U-boot - i386 Startup Code + * U-boot - x86 Startup Code * * (C) Copyright 2008-2011 * Graeme Russ, graeme.russ@gmail.com @@ -35,8 +35,8 @@ .code32 .globl _start .type _start, @function -.globl _i386boot_start -_i386boot_start: +.globl _x86boot_start +_x86boot_start: /* * This is the fail safe 32-bit bootstrap entry point. The * following code is not executed from a cold-reset (actually, a diff --git a/arch/i386/cpu/start16.S b/arch/x86/cpu/start16.S similarity index 98% rename from arch/i386/cpu/start16.S rename to arch/x86/cpu/start16.S index d2e5d13..f1b9d0a 100644 --- a/arch/i386/cpu/start16.S +++ b/arch/x86/cpu/start16.S @@ -1,5 +1,5 @@ /* - * U-boot - i386 Startup Code + * U-boot - x86 Startup Code * * (C) Copyright 2008-2011 * Graeme Russ, graeme.russ@gmail.com diff --git a/arch/i386/cpu/u-boot.lds b/arch/x86/cpu/u-boot.lds similarity index 100% rename from arch/i386/cpu/u-boot.lds rename to arch/x86/cpu/u-boot.lds diff --git a/arch/i386/include/asm/bitops.h b/arch/x86/include/asm/bitops.h similarity index 100% rename from arch/i386/include/asm/bitops.h rename to arch/x86/include/asm/bitops.h diff --git a/arch/i386/include/asm/bootparam.h b/arch/x86/include/asm/bootparam.h similarity index 100% rename from arch/i386/include/asm/bootparam.h rename to arch/x86/include/asm/bootparam.h diff --git a/arch/i386/include/asm/byteorder.h b/arch/x86/include/asm/byteorder.h similarity index 100% rename from arch/i386/include/asm/byteorder.h rename to arch/x86/include/asm/byteorder.h diff --git a/arch/i386/include/asm/config.h b/arch/x86/include/asm/config.h similarity index 100% rename from arch/i386/include/asm/config.h rename to arch/x86/include/asm/config.h diff --git a/arch/i386/include/asm/e820.h b/arch/x86/include/asm/e820.h similarity index 100% rename from arch/i386/include/asm/e820.h rename to arch/x86/include/asm/e820.h diff --git a/arch/i386/include/asm/errno.h b/arch/x86/include/asm/errno.h similarity index 100% rename from arch/i386/include/asm/errno.h rename to arch/x86/include/asm/errno.h diff --git a/arch/i386/include/asm/global_data.h b/arch/x86/include/asm/global_data.h similarity index 100% rename from arch/i386/include/asm/global_data.h rename to arch/x86/include/asm/global_data.h diff --git a/arch/i386/include/asm/i8254.h b/arch/x86/include/asm/i8254.h similarity index 100% rename from arch/i386/include/asm/i8254.h rename to arch/x86/include/asm/i8254.h diff --git a/arch/i386/include/asm/i8259.h b/arch/x86/include/asm/i8259.h similarity index 100% rename from arch/i386/include/asm/i8259.h rename to arch/x86/include/asm/i8259.h diff --git a/arch/i386/include/asm/ibmpc.h b/arch/x86/include/asm/ibmpc.h similarity index 100% rename from arch/i386/include/asm/ibmpc.h rename to arch/x86/include/asm/ibmpc.h diff --git a/arch/i386/include/asm/ic/pci.h b/arch/x86/include/asm/ic/pci.h similarity index 100% rename from arch/i386/include/asm/ic/pci.h rename to arch/x86/include/asm/ic/pci.h diff --git a/arch/i386/include/asm/ic/sc520.h b/arch/x86/include/asm/ic/sc520.h similarity index 100% rename from arch/i386/include/asm/ic/sc520.h rename to arch/x86/include/asm/ic/sc520.h diff --git a/arch/i386/include/asm/ic/ssi.h b/arch/x86/include/asm/ic/ssi.h similarity index 100% rename from arch/i386/include/asm/ic/ssi.h rename to arch/x86/include/asm/ic/ssi.h diff --git a/arch/i386/include/asm/interrupt.h b/arch/x86/include/asm/interrupt.h similarity index 95% rename from arch/i386/include/asm/interrupt.h rename to arch/x86/include/asm/interrupt.h index d32ef8b..be52fe4 100644 --- a/arch/i386/include/asm/interrupt.h +++ b/arch/x86/include/asm/interrupt.h @@ -29,10 +29,10 @@
#include <asm/types.h>
-/* arch/i386/cpu/interrupts.c */ +/* arch/x86/cpu/interrupts.c */ void set_vector(u8 intnum, void *routine);
-/* arch/i386/lib/interupts.c */ +/* arch/x86/lib/interupts.c */ void disable_irq(int irq); void enable_irq(int irq);
diff --git a/arch/i386/include/asm/io.h b/arch/x86/include/asm/io.h similarity index 100% rename from arch/i386/include/asm/io.h rename to arch/x86/include/asm/io.h diff --git a/arch/i386/include/asm/ioctl.h b/arch/x86/include/asm/ioctl.h similarity index 100% rename from arch/i386/include/asm/ioctl.h rename to arch/x86/include/asm/ioctl.h diff --git a/arch/i386/include/asm/ist.h b/arch/x86/include/asm/ist.h similarity index 100% rename from arch/i386/include/asm/ist.h rename to arch/x86/include/asm/ist.h diff --git a/arch/i386/include/asm/pci.h b/arch/x86/include/asm/pci.h similarity index 100% rename from arch/i386/include/asm/pci.h rename to arch/x86/include/asm/pci.h diff --git a/arch/i386/include/asm/posix_types.h b/arch/x86/include/asm/posix_types.h similarity index 100% rename from arch/i386/include/asm/posix_types.h rename to arch/x86/include/asm/posix_types.h diff --git a/arch/i386/include/asm/processor-flags.h b/arch/x86/include/asm/processor-flags.h similarity index 100% rename from arch/i386/include/asm/processor-flags.h rename to arch/x86/include/asm/processor-flags.h diff --git a/arch/i386/include/asm/processor.h b/arch/x86/include/asm/processor.h similarity index 100% rename from arch/i386/include/asm/processor.h rename to arch/x86/include/asm/processor.h diff --git a/arch/i386/include/asm/ptrace.h b/arch/x86/include/asm/ptrace.h similarity index 100% rename from arch/i386/include/asm/ptrace.h rename to arch/x86/include/asm/ptrace.h diff --git a/arch/i386/include/asm/realmode.h b/arch/x86/include/asm/realmode.h similarity index 100% rename from arch/i386/include/asm/realmode.h rename to arch/x86/include/asm/realmode.h diff --git a/arch/i386/include/asm/string.h b/arch/x86/include/asm/string.h similarity index 100% rename from arch/i386/include/asm/string.h rename to arch/x86/include/asm/string.h diff --git a/arch/i386/include/asm/types.h b/arch/x86/include/asm/types.h similarity index 100% rename from arch/i386/include/asm/types.h rename to arch/x86/include/asm/types.h diff --git a/arch/i386/include/asm/u-boot-i386.h b/arch/x86/include/asm/u-boot-x86.h similarity index 93% rename from arch/i386/include/asm/u-boot-i386.h rename to arch/x86/include/asm/u-boot-x86.h index 7b39bd2..944e1a2 100644 --- a/arch/i386/include/asm/u-boot-i386.h +++ b/arch/x86/include/asm/u-boot-x86.h @@ -35,7 +35,7 @@ void timer_isr(void *); typedef void (timer_fnc_t) (void); int register_timer_isr (timer_fnc_t *isr_func);
-/* Architecture specific - can be in arch/i386/cpu/, arch/i386/lib/, or $(BOARD)/ */ +/* Architecture specific - can be in arch/x86/cpu/, arch/x86/lib/, or $(BOARD)/ */ int timer_init(void); int dram_init_f(void);
@@ -51,7 +51,7 @@ void setup_pcat_compatibility(void); void isa_unmap_rom(u32 addr); u32 isa_map_rom(u32 bus_addr, int size);
-/* arch/i386/lib/... */ +/* arch/x86/lib/... */ int video_bios_init(void); int video_init(void);
diff --git a/arch/i386/include/asm/u-boot.h b/arch/x86/include/asm/u-boot.h similarity index 100% rename from arch/i386/include/asm/u-boot.h rename to arch/x86/include/asm/u-boot.h diff --git a/arch/i386/include/asm/unaligned.h b/arch/x86/include/asm/unaligned.h similarity index 100% rename from arch/i386/include/asm/unaligned.h rename to arch/x86/include/asm/unaligned.h diff --git a/arch/i386/include/asm/video/edid.h b/arch/x86/include/asm/video/edid.h similarity index 100% rename from arch/i386/include/asm/video/edid.h rename to arch/x86/include/asm/video/edid.h diff --git a/arch/i386/include/asm/zimage.h b/arch/x86/include/asm/zimage.h similarity index 100% rename from arch/i386/include/asm/zimage.h rename to arch/x86/include/asm/zimage.h diff --git a/arch/i386/lib/Makefile b/arch/x86/lib/Makefile similarity index 100% rename from arch/i386/lib/Makefile rename to arch/x86/lib/Makefile diff --git a/arch/i386/lib/bios.S b/arch/x86/lib/bios.S similarity index 100% rename from arch/i386/lib/bios.S rename to arch/x86/lib/bios.S diff --git a/arch/i386/lib/bios.h b/arch/x86/lib/bios.h similarity index 100% rename from arch/i386/lib/bios.h rename to arch/x86/lib/bios.h diff --git a/arch/i386/lib/bios_pci.S b/arch/x86/lib/bios_pci.S similarity index 100% rename from arch/i386/lib/bios_pci.S rename to arch/x86/lib/bios_pci.S diff --git a/arch/i386/lib/bios_setup.c b/arch/x86/lib/bios_setup.c similarity index 100% rename from arch/i386/lib/bios_setup.c rename to arch/x86/lib/bios_setup.c diff --git a/arch/i386/lib/board.c b/arch/x86/lib/board.c similarity index 99% rename from arch/i386/lib/board.c rename to arch/x86/lib/board.c index 6d947c6..df54222 100644 --- a/arch/i386/lib/board.c +++ b/arch/x86/lib/board.c @@ -41,7 +41,7 @@ #include <net.h> #include <ide.h> #include <serial.h> -#include <asm/u-boot-i386.h> +#include <asm/u-boot-x86.h> #include <elf.h>
#ifdef CONFIG_BITBANGMII diff --git a/arch/i386/lib/bootm.c b/arch/x86/lib/bootm.c similarity index 100% rename from arch/i386/lib/bootm.c rename to arch/x86/lib/bootm.c diff --git a/arch/i386/lib/interrupts.c b/arch/x86/lib/interrupts.c similarity index 100% rename from arch/i386/lib/interrupts.c rename to arch/x86/lib/interrupts.c diff --git a/arch/i386/lib/pcat_interrupts.c b/arch/x86/lib/pcat_interrupts.c similarity index 100% rename from arch/i386/lib/pcat_interrupts.c rename to arch/x86/lib/pcat_interrupts.c diff --git a/arch/i386/lib/pcat_timer.c b/arch/x86/lib/pcat_timer.c similarity index 100% rename from arch/i386/lib/pcat_timer.c rename to arch/x86/lib/pcat_timer.c diff --git a/arch/i386/lib/pci.c b/arch/x86/lib/pci.c similarity index 100% rename from arch/i386/lib/pci.c rename to arch/x86/lib/pci.c diff --git a/arch/i386/lib/pci_type1.c b/arch/x86/lib/pci_type1.c similarity index 100% rename from arch/i386/lib/pci_type1.c rename to arch/x86/lib/pci_type1.c diff --git a/arch/i386/lib/realmode.c b/arch/x86/lib/realmode.c similarity index 100% rename from arch/i386/lib/realmode.c rename to arch/x86/lib/realmode.c diff --git a/arch/i386/lib/realmode_switch.S b/arch/x86/lib/realmode_switch.S similarity index 100% rename from arch/i386/lib/realmode_switch.S rename to arch/x86/lib/realmode_switch.S diff --git a/arch/i386/lib/timer.c b/arch/x86/lib/timer.c similarity index 100% rename from arch/i386/lib/timer.c rename to arch/x86/lib/timer.c diff --git a/arch/i386/lib/video.c b/arch/x86/lib/video.c similarity index 100% rename from arch/i386/lib/video.c rename to arch/x86/lib/video.c diff --git a/arch/i386/lib/video_bios.c b/arch/x86/lib/video_bios.c similarity index 100% rename from arch/i386/lib/video_bios.c rename to arch/x86/lib/video_bios.c diff --git a/arch/i386/lib/zimage.c b/arch/x86/lib/zimage.c similarity index 100% rename from arch/i386/lib/zimage.c rename to arch/x86/lib/zimage.c diff --git a/boards.cfg b/boards.cfg index d25f3f2..949f9f1 100644 --- a/boards.cfg +++ b/boards.cfg @@ -202,8 +202,8 @@ ibf-dsp561 blackfin blackfin ip04 blackfin blackfin tcm-bf518 blackfin blackfin tcm-bf537 blackfin blackfin -eNET i386 i386 eNET - sc520 eNET:SYS_TEXT_BASE=0x38040000 -eNET_SRAM i386 i386 eNET - sc520 eNET:SYS_TEXT_BASE=0x19000000 +eNET x86 x86 eNET - sc520 eNET:SYS_TEXT_BASE=0x38040000 +eNET_SRAM x86 x86 eNET - sc520 eNET:SYS_TEXT_BASE=0x19000000 idmr m68k mcf52x2 TASREG m68k mcf52x2 tasreg esd M5208EVBE m68k mcf52x2 m5208evbe freescale diff --git a/common/exports.c b/common/exports.c index 3dff735..717e4af 100644 --- a/common/exports.c +++ b/common/exports.c @@ -15,7 +15,7 @@ unsigned long get_version(void) /* Reuse _exports.h with a little trickery to avoid bitrot */ #define EXPORT_FUNC(sym) gd->jt[XF_##sym] = (void *)sym;
-#if !defined(CONFIG_I386) && !defined(CONFIG_PPC) +#if !defined(CONFIG_X86) && !defined(CONFIG_PPC) # define install_hdlr dummy # define free_hdlr dummy #else /* kludge for non-standard function naming */ diff --git a/doc/README-i386 b/doc/README-x86 similarity index 97% rename from doc/README-i386 rename to doc/README-x86 index c560d22..e8c2fc9 100644 --- a/doc/README-i386 +++ b/doc/README-x86 @@ -1,4 +1,4 @@ -This is my attempt to port U-Boot to the i386 platform. This +This is my attempt to port U-Boot to the x86 platform. This work was sponsored by my emplyer, Omicron Ceti AB. http://www.omicron.se
It is currently capable of booting a linux bzImage from flash on diff --git a/examples/standalone/stubs.c b/examples/standalone/stubs.c index 2d2e709..507d38c 100644 --- a/examples/standalone/stubs.c +++ b/examples/standalone/stubs.c @@ -4,7 +4,7 @@ #define GCC_VERSION (__GNUC__ * 1000 + __GNUC_MINOR__) #endif /* GCC_VERSION */
-#if defined(CONFIG_I386) +#if defined(CONFIG_X86) /* * x86 does not have a dedicated register to store the pointer to * the global_data. Thus the jump table address is stored in a @@ -198,7 +198,7 @@ void app_startup(char * const *argv) *cp++ = 0; }
-#if defined(CONFIG_I386) +#if defined(CONFIG_X86) /* x86 does not have a dedicated register for passing global_data */ global_data = (gd_t *)argv[-1]; jt = global_data->jt; diff --git a/include/common.h b/include/common.h index 54503ed..edcf9f5 100644 --- a/include/common.h +++ b/include/common.h @@ -270,9 +270,9 @@ int setenv (char *, char *); # include <asm/setup.h> # include <asm/u-boot-arm.h> /* ARM version to be fixed! */ #endif /* CONFIG_ARM */ -#ifdef CONFIG_I386 /* x86 version to be fixed! */ -# include <asm/u-boot-i386.h> -#endif /* CONFIG_I386 */ +#ifdef CONFIG_X86 /* x86 version to be fixed! */ +# include <asm/u-boot-x86.h> +#endif /* CONFIG_X86 */
#ifdef CONFIG_AUTO_COMPLETE int env_complete(char *var, int maxv, char *cmdv[], int maxsz, char *buf); diff --git a/include/configs/eNET.h b/include/configs/eNET.h index f3ef7d2..548d52c 100644 --- a/include/configs/eNET.h +++ b/include/configs/eNET.h @@ -33,7 +33,6 @@ * High Level Configuration Options * (easy to change) */ -#define CONFIG_X86 #define CONFIG_SYS_SC520 #define CONFIG_SYS_SC520_SSI #define CONFIG_SHOW_BOOT_PROGRESS diff --git a/include/exports.h b/include/exports.h index 6382311..ddd1bf4 100644 --- a/include/exports.h +++ b/include/exports.h @@ -45,7 +45,7 @@ enum {
#define XF_VERSION 6
-#if defined(CONFIG_I386) +#if defined(CONFIG_X86) extern gd_t *global_data; #endif
Regards,
Graeme Russ
Partial linking allows weak functions to be overridden in files containing only one function. Moving the sc520 override of reset_cpu gets rid of an ugly #ifdef
Signed-off-by: Graeme Russ graeme.russ@gmail.com --- arch/x86/cpu/sc520/Makefile | 1 + arch/x86/cpu/sc520/sc520.c | 10 --------- arch/x86/cpu/sc520/sc520_reset.c | 40 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 41 insertions(+), 10 deletions(-) create mode 100644 arch/x86/cpu/sc520/sc520_reset.c
diff --git a/arch/x86/cpu/sc520/Makefile b/arch/x86/cpu/sc520/Makefile index 54260b6..694b61e 100644 --- a/arch/x86/cpu/sc520/Makefile +++ b/arch/x86/cpu/sc520/Makefile @@ -33,6 +33,7 @@ LIB := $(obj)lib$(SOC).o
COBJS-$(CONFIG_SYS_SC520) += sc520.o COBJS-$(CONFIG_PCI) += sc520_pci.o +COBJS-$(CONFIG_SYS_SC520_RESET) += sc520_reset.o COBJS-$(CONFIG_SYS_SC520) += sc520_sdram.o COBJS-$(CONFIG_SYS_SC520_SSI) += sc520_ssi.o COBJS-$(CONFIG_SYS_SC520_TIMER) += sc520_timer.o diff --git a/arch/x86/cpu/sc520/sc520.c b/arch/x86/cpu/sc520/sc520.c index edc1a5c..8c410a2 100644 --- a/arch/x86/cpu/sc520/sc520.c +++ b/arch/x86/cpu/sc520/sc520.c @@ -65,13 +65,3 @@ int cpu_init_r(void) return x86_cpu_init_r(); }
-#ifdef CONFIG_SYS_SC520_RESET -void reset_cpu(ulong addr) -{ - printf("Resetting using SC520 MMCR\n"); - /* Write a '1' to the SYS_RST of the RESCFG MMCR */ - writeb(0x01, &sc520_mmcr->rescfg); - - /* NOTREACHED */ -} -#endif diff --git a/arch/x86/cpu/sc520/sc520_reset.c b/arch/x86/cpu/sc520/sc520_reset.c new file mode 100644 index 0000000..79ef976 --- /dev/null +++ b/arch/x86/cpu/sc520/sc520_reset.c @@ -0,0 +1,40 @@ +/* + * (C) Copyright 2011 + * Graeme Russ, graeme.russ@gmail.com + * + * (C) Copyright 2002 + * Daniel Engström, Omicron Ceti AB, daniel@omicron.se + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/ic/sc520.h> + +DECLARE_GLOBAL_DATA_PTR; + +void reset_cpu(ulong addr) +{ + printf("Resetting using SC520 MMCR\n"); + /* Write a '1' to the SYS_RST of the RESCFG MMCR */ + writeb(0x01, &sc520_mmcr->rescfg); + + /* NOTREACHED */ +}
Regards,
Graeme Russ
The README files are totally out-of-date to the point where they do more harm than good
Signed-off-by: Graeme Russ graeme.russ@gmail.com --- MAINTAINERS | 4 +- doc/README-x86 | 74 -------------------------------------------------------- doc/TODO-i386 | 29 ---------------------- 3 files changed, 2 insertions(+), 105 deletions(-) delete mode 100644 doc/README-x86 delete mode 100644 doc/TODO-i386
diff --git a/MAINTAINERS b/MAINTAINERS index 1d7e1f4..f3525a8 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -905,9 +905,9 @@ Unknown / orphaned boards: # Board CPU # #########################################################################
-Daniel Engström daniel@omicron.se +Graeme Russ graeme.russ@gmail.com
- sc520_cdp x86 + eNET AMD SC520
######################################################################### # MIPS Systems: # diff --git a/doc/README-x86 b/doc/README-x86 deleted file mode 100644 index e8c2fc9..0000000 --- a/doc/README-x86 +++ /dev/null @@ -1,74 +0,0 @@ -This is my attempt to port U-Boot to the x86 platform. This -work was sponsored by my emplyer, Omicron Ceti AB. http://www.omicron.se - -It is currently capable of booting a linux bzImage from flash on -the AMD SC520 CDP platform. - -It was originally based on PPCBoot taken from the CVS October 28 2002. - -To compile: - -1) Unpack the source tree, either from the complete tarball or - from the virgin snapshot + the patch - -2) Configure the source - $ make sc520_cdp_comfig - $ make - -To use this code on the CDP: -1) Make a suitable kernel, I used 2.4.19 with the mtd-support updated - from the MTD CVS and a patch to allow root=/dev/mtdblock1 which I - included at the end of this file. - The following options in the MTD section might be useful: - - CONFIG_MTD_PHYSMAP=y - CONFIG_MTD_PHYSMAP_START=38100000 - CONFIG_MTD_PHYSMAP_LEN=7a0000 - CONFIG_MTD_PHYSMAP_BUSWIDTH=2 - - -2) Program it in to the CDP flashbank with remon - u-boot.bin should be programmed att offset 0x7e000 and the kernel at - offset 0. If you want to use a jffs2 root file system (not included here), - it should be programmed to offset 0x100000. - - remon> z - remon> yi - remon> ns u-boot.bin 7e0000 - remon> ns bzImage 0 - remon> ns image.jffs2 100000 - -3) Connect a terminal to the 25pin serial port at 9600bps, and start the CDP. - - remon> z - remon> g - -4) U-Boot should output some message and a prompt on the terminal, to - start the kernel issue the following command: - - BOOT> bootm - -5) The kernel should boot, and mount the root filesystem if present. - -We hope you find this stuff useful -Daniel Engström, Omicron Ceti AB, daniel@omicron.se - - ---- linux-2.4.19-orig/init/do_mounts.c Sat Aug 3 02:39:46 2002 -+++ linux-2.4.19/init/do_mounts.c Mon Sep 23 16:21:33 2002 -@@ -224,6 +224,14 @@ - { "ftlc", 0x2c10 }, - { "ftld", 0x2c18 }, - { "mtdblock", 0x1f00 }, -+ { "mtdblock0", 0x1f00 }, -+ { "mtdblock1", 0x1f01 }, -+ { "mtdblock2", 0x1f02 }, -+ { "mtdblock3", 0x1f03 }, -+ { "mtdblock4", 0x1f04 }, -+ { "mtdblock5", 0x1f05 }, -+ { "mtdblock6", 0x1f06 }, -+ { "mtdblock7", 0x1f07 }, - { NULL, 0 } - }; - -------------------- diff --git a/doc/TODO-i386 b/doc/TODO-i386 deleted file mode 100644 index 9b6c5d4..0000000 --- a/doc/TODO-i386 +++ /dev/null @@ -1,29 +0,0 @@ -i386 port missing features: -* i386 cleaness (wbinvld is 486+ ... ) -* Pentium TSC timer/udelay -* setup the BIOS data area and BIOS equipment word to reflect machine config. -* Make reset work (from Linux and from the boot prompt) -* DMA, FDC, RTC, KBC initialization -* split of part of arch/i386/cpu/interrupt.c to cpu/i385/entry.c? -* re-entry of protected mode from real mode, should be added to realmode_switch.S - (and used by INT 10h and INT 16h handlers for console I/O during early - linux boot...) -* missing functions in arch/i386/lib and arch/i386/cpu -* speaker beep interface - - -SC520 missing features: -* Watchdog -* SC520 timer/udelay -* SC520 3rd PIC -* SC520 ICE serial -* SC520 MMCR reset - -SC520 CDP board support missing features: -* environment in sram - -SC520 CDP board support bugs: -* SPI EEPROM support does not work -* 0x680 LEDS dos not work for me -* is it possible to make both the internal serial ports and the - ports on the sio work at the same time?
Applied to u-boot-x86, master branch, thanks.
Regards,
Graeme Russ
Graeme Russ
