[U-Boot] [PATCH v6] spi: Add support SH Quad SPI driver
This patch adds a driver for Renesas SoC's Quad SPI bus. This supports with 8 bits per transfer to use with SPI flash.
Signed-off-by: Kouei Abe kouei.abe.cp@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com ---
Changes for v6: - Update Makefile to new style. Changes for v5: - Add print abort when call ctrlc(). - Move source code in spi_xfer() which should be processed by spi_cs_activate(). - Move source code in spi_xfer() which should be processed by spi_cs_deactivate(). - Remove sh_qspi_xfer, move to spi_xfer(). Changes for v4: - Added tabs - Added comments - Added sh_qspi_init() Changes for v3: - Change Queued to Quad. - Remove path of file from file header. - Use read* and write* directly instead of sh_qspi_write* sh_qspi_read*. - Change driver format. Changes for v2: - "SH QSPI" to "SH QSPI (Queued SPI)". - Remove magic number.
drivers/spi/Makefile | 1 + drivers/spi/sh_qspi.c | 244 ++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 245 insertions(+) create mode 100644 drivers/spi/sh_qspi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 27902fe..914e71f 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -29,6 +29,7 @@ obj-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o obj-$(CONFIG_SOFT_SPI) += soft_spi.o obj-$(CONFIG_SH_SPI) += sh_spi.o +obj-$(CONFIG_SH_QSPI) += sh_qspi.o obj-$(CONFIG_FSL_ESPI) += fsl_espi.o obj-$(CONFIG_FDT_SPI) += fdt_spi.o obj-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o diff --git a/drivers/spi/sh_qspi.c b/drivers/spi/sh_qspi.c new file mode 100644 index 0000000..8f53552 --- /dev/null +++ b/drivers/spi/sh_qspi.c @@ -0,0 +1,244 @@ +/* + * SH QSPI (Quad SPI) driver + * + * Copyright (C) 2013 Renesas Electronics Corporation + * Copyright (C) 2013 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <asm/io.h> + +/* SH QSPI register bit masks <REG>_<BIT> */ +#define SPCR_MSTR 0x08 +#define SPCR_SPE 0x40 +#define SPSR_SPRFF 0x80 +#define SPSR_SPTEF 0x20 +#define SPPCR_IO3FV 0x04 +#define SPPCR_IO2FV 0x02 +#define SPPCR_IO1FV 0x01 +#define SPBDCR_RXBC0 (1 << 0) +#define SPCMD_SCKDEN (1 << 15) +#define SPCMD_SLNDEN (1 << 14) +#define SPCMD_SPNDEN (1 << 13) +#define SPCMD_SSLKP (1 << 7) +#define SPCMD_BRDV0 (1 << 2) +#define SPCMD_INIT1 SPCMD_SCKDEN | SPCMD_SLNDEN | \ + SPCMD_SPNDEN | SPCMD_SSLKP | \ + SPCMD_BRDV0 +#define SPCMD_INIT2 SPCMD_SPNDEN | SPCMD_SSLKP | \ + SPCMD_BRDV0 +#define SPBFCR_TXRST (1 << 7) +#define SPBFCR_RXRST (1 << 6) + +/* SH QSPI register set */ +struct sh_qspi_regs { + unsigned char spcr; + unsigned char sslp; + unsigned char sppcr; + unsigned char spsr; + unsigned long spdr; + unsigned char spscr; + unsigned char spssr; + unsigned char spbr; + unsigned char spdcr; + unsigned char spckd; + unsigned char sslnd; + unsigned char spnd; + unsigned char dummy0; + unsigned short spcmd0; + unsigned short spcmd1; + unsigned short spcmd2; + unsigned short spcmd3; + unsigned char spbfcr; + unsigned char dummy1; + unsigned short spbdcr; + unsigned long spbmul0; + unsigned long spbmul1; + unsigned long spbmul2; + unsigned long spbmul3; +}; + +struct sh_qspi_slave { + struct spi_slave slave; + struct sh_qspi_regs *regs; +}; + +static inline struct sh_qspi_slave *to_sh_qspi(struct spi_slave *slave) +{ + return container_of(slave, struct sh_qspi_slave, slave); +} + +static void sh_qspi_init(struct sh_qspi_slave *ss) +{ + /* QSPI initialize */ + writeb(SPCR_MSTR, &ss->regs->spcr); + writeb(0x00, &ss->regs->sslp); + writeb(SPPCR_IO3FV|SPPCR_IO2FV, &ss->regs->sppcr); + + /* Set bit rate. See 58.3.8 Quad Serial Peripheral Interface */ + writeb(0x01, &ss->regs->spbr); + + writeb(0x00, &ss->regs->spdcr); + writeb(0x00, &ss->regs->spckd); + writeb(0x00, &ss->regs->sslnd); + writeb(0x00, &ss->regs->spnd); + writew(SPCMD_INIT1, &ss->regs->spcmd0); + writew(SPCMD_INIT2, &ss->regs->spcmd0); + writeb(SPBFCR_TXRST|SPBFCR_RXRST, &ss->regs->spbfcr); + writeb(0x00, &ss->regs->spbfcr); + writeb(0x00, &ss->regs->spscr); + writeb(SPCR_SPE|SPCR_MSTR, &ss->regs->spcr); +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return 1; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + struct sh_qspi_slave *ss = to_sh_qspi(slave); + + writeb(SPCR_MSTR, &ss->regs->spcr); + writew(SPCMD_INIT1, &ss->regs->spcmd0); + writeb(SPBFCR_TXRST|SPBFCR_RXRST, &ss->regs->spbfcr); + writeb(0x00, &ss->regs->spbfcr); + writeb(0x00, &ss->regs->spscr); + writeb(SPCR_SPE|SPCR_MSTR, &ss->regs->spcr); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct sh_qspi_slave *ss = to_sh_qspi(slave); + + writeb(SPCR_MSTR, &ss->regs->spcr); +} + +void spi_init(void) +{ + /* nothing to do */ +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct sh_qspi_slave *ss; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + ss = spi_alloc_slave(struct sh_qspi_slave, bus, cs); + if (!ss) { + printf("SPI_error: Fail to allocate sh_qspi_slave\n"); + return NULL; + } + + ss->regs = (struct sh_qspi_regs *)CONFIG_SH_QSPI_BASE; + + /* Init SH QSPI */ + sh_qspi_init(ss); + + return &ss->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct sh_qspi_slave *spi = to_sh_qspi(slave); + + free(spi); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct sh_qspi_slave *ss = to_sh_qspi(slave); + unsigned long nbyte; + int ret = 0; + unsigned char dtdata = 0, drdata; + unsigned char *tdata = &dtdata, *rdata = &drdata; + unsigned long *spbmul0 = &ss->regs->spbmul0; + + if (dout == NULL && din == NULL) { + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + return 0; + } + + if (bitlen % 8) { + printf("%s: bitlen is not 8bit alined %d", __func__, bitlen); + return 1; + } + + nbyte = bitlen / 8; + + if (flags & SPI_XFER_BEGIN) { + spi_cs_activate(slave); + + /* Set 1048576 byte */ + writel(0x100000, spbmul0); + } + + if (flags & SPI_XFER_END) + writel(nbyte, spbmul0); + + if (dout != NULL) + tdata = (unsigned char *)dout; + + if (din != NULL) + rdata = din; + + while (nbyte > 0) { + while (!(readb(&ss->regs->spsr) & SPSR_SPTEF)) { + if (ctrlc()) { + puts("abort\n"); + return 1; + } + udelay(10); + } + + writeb(*tdata, (unsigned char *)(&ss->regs->spdr)); + + while ((readw(&ss->regs->spbdcr) != SPBDCR_RXBC0)) { + if (ctrlc()) { + puts("abort\n"); + return 1; + } + udelay(1); + } + + while (!(readb(&ss->regs->spsr) & SPSR_SPRFF)) { + if (ctrlc()) { + puts("abort\n"); + return 1; + } + udelay(10); + } + + *rdata = readb((unsigned char *)(&ss->regs->spdr)); + + if (dout != NULL) + tdata++; + if (din != NULL) + rdata++; + + nbyte--; + } + + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return ret; +}
ping.
2013/12/2 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com:
Changes for v6:
Changes for v5:
Changes for v4:
- Added tabs
- Added comments
Changes for v3:
Changes for v2:
- SH QSPI (Quad SPI) driver
- Copyright (C) 2013 Renesas Electronics Corporation
- Copyright (C) 2013 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com
- SPDX-License-Identifier: GPL-2.0
SPCMD_BRDV0
SPCMD_BRDV0
unsigned char spcr;
unsigned char sslp;
unsigned char spsr;
unsigned long spdr;
unsigned char spbr;
unsigned char spnd;
return 1;
/* nothing to do */
return NULL;
if (!ss) {
return NULL;
/* Init SH QSPI */
sh_qspi_init(ss);
return &ss->slave;
free(spi);
int ret = 0;
if (bitlen % 8) {
return 1;
nbyte = bitlen / 8;
if (dout != NULL)
if (din != NULL)
rdata = din;
while (nbyte > 0) {
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(10);
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(1);
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(10);
if (dout != NULL)
tdata++;
if (din != NULL)
rdata++;
nbyte--;
return ret;
1.8.4.2
On Mon, Dec 2, 2013 at 1:42 PM, Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote:
Changes for v6:
Changes for v5:
Changes for v4:
- Added tabs
- Added comments
Changes for v3:
Changes for v2:
SPCMD_BRDV0
SPCMD_BRDV0
unsigned char spcr;
unsigned char sslp;
unsigned char spsr;
unsigned long spdr;
unsigned char spbr;
unsigned char spnd;
Please try to write comments on each initialization steps. - refer code in drivers/spi/zynq_spi.c
return 1;
Better to use clrbits_le* and comments too.. - refer code in drivers/spi/zynq_spi.c
Better to use setbits_le* - refer code in drivers/spi/zynq_spi.c
/* nothing to do */
return NULL;
if (!ss) {
return NULL;
/* Init SH QSPI */
sh_qspi_init(ss);
return &ss->slave;
free(spi);
int ret = 0;
if (bitlen % 8) {
return 1;
nbyte = bitlen / 8;
if (dout != NULL)
if (din != NULL)
rdata = din;
while (nbyte > 0) {
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(10);
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(1);
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(10);
if (dout != NULL)
tdata++;
if (din != NULL)
rdata++;
nbyte--;
return ret;
Did you tested this - please add test documentation on doc folder. That might give you good insight in future.
Hi, Jagan.
Thanks for your review.
2013/12/16 Jagan Teki jagannadh.teki@gmail.com:
Changes for v6:
Changes for v5:
Changes for v4:
- Added tabs
- Added comments
Changes for v3:
Changes for v2:
SPCMD_BRDV0
SPCMD_BRDV0
unsigned char spcr;
unsigned char sslp;
unsigned char spsr;
unsigned long spdr;
unsigned char spbr;
unsigned char spnd;
OK. I add comment each steps.
return 1;
Indeed.
Indeed. I will rewrite.
/* nothing to do */
return NULL;
if (!ss) {
return NULL;
/* Init SH QSPI */
sh_qspi_init(ss);
return &ss->slave;
free(spi);
int ret = 0;
if (bitlen % 8) {
return 1;
nbyte = bitlen / 8;
if (dout != NULL)
if (din != NULL)
rdata = din;
while (nbyte > 0) {
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(10);
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(1);
if (ctrlc()) {
puts("abort\n");
return 1;
udelay(10);
if (dout != NULL)
tdata++;
if (din != NULL)
rdata++;
nbyte--;
return ret;
I see. I will resend with update patch and document.
-- Thanks, Jagan.
Best regards, Nobuhiro
Jagan Teki
Nobuhiro Iwamatsu
