[U-Boot] [RFC 0/3] rsa: extend rsa_verify() for UEFI secure boot
The current rsa_verify() requires five parameters for a RSA public key for efficiency while RSA, in theory, requires only two. In addition, those parameters are expected to come from FIT image.
So this function won't fit very well when we want to use it for the purpose of implementing UEFI secure boot, in particular, image authentication as well as variable authentication, where the essential two parameters are set to be retrieved from one of X509 certificates in signature database.
So, in this patch, additional three parameters will be calculated on the fly when rsa_verify() is called without fdt which should contain parameters above.
This calculation heavily relies on "big-number (or multi-precision) library." Therefore some routines from BearSSL[1] under MIT license are imported in this implementation. See Patch#2. # Please let me know if this is not appropriate.
# Checkpatch will complain with lots of warnings/errors, but # I intentionally don't fix them for maximum maintainability.
AKASHI Takahiro (3): lib: rsa: decouple rsa from FIT image verification lib: rsa: generate additional parameters for public key lib: rsa: add rsa_verify_with_pkey()
include/u-boot/rsa-mod-exp.h | 3 + lib/rsa/Kconfig | 14 + lib/rsa/Makefile | 3 +- lib/rsa/rsa-keyprop.c | 631 +++++++++++++++++++++++++++++++++++ lib/rsa/rsa-verify.c | 63 +++- 5 files changed, 705 insertions(+), 9 deletions(-) create mode 100644 lib/rsa/rsa-keyprop.c
Introduce new configuration, CONFIG_RSA_VERIFY which will decouple building RSA functions from FIT verification and allow for adding a RSA-based signature verification for other file formats, in particular PE file for UEFI secure boot.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/rsa/Kconfig | 7 +++++++ lib/rsa/Makefile | 2 +- 2 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/lib/rsa/Kconfig b/lib/rsa/Kconfig index 2b33f323bccc..338c8124da59 100644 --- a/lib/rsa/Kconfig +++ b/lib/rsa/Kconfig @@ -1,5 +1,6 @@ config RSA bool "Use RSA Library" + select RSA_VERIFY select RSA_FREESCALE_EXP if FSL_CAAM && !ARCH_MX7 && !ARCH_MX6 && !ARCH_MX5 select RSA_SOFTWARE_EXP if !RSA_FREESCALE_EXP help @@ -17,6 +18,12 @@ if RSA
config SPL_RSA bool "Use RSA Library within SPL" + select RSA_VERIFY + +config RSA_VERIFY + bool + help + Add RSA signature verification support.
config RSA_SOFTWARE_EXP bool "Enable driver for RSA Modular Exponentiation in software" diff --git a/lib/rsa/Makefile b/lib/rsa/Makefile index a51c6e1685fb..226d8f3514a9 100644 --- a/lib/rsa/Makefile +++ b/lib/rsa/Makefile @@ -5,5 +5,5 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_$(SPL_)FIT_SIGNATURE) += rsa-verify.o rsa-checksum.o +obj-$(CONFIG_RSA_VERIFY) += rsa-verify.o rsa-checksum.o obj-$(CONFIG_RSA_SOFTWARE_EXP) += rsa-mod-exp.o
- select RSA_VERIFY select RSA_FREESCALE_EXP if FSL_CAAM && !ARCH_MX7 && !ARCH_MX6 && !ARCH_MX5 select RSA_SOFTWARE_EXP if !RSA_FREESCALE_EXP help
- select RSA_VERIFY
+config RSA_VERIFY
bool
help
pine64-lts_defconfig with CONFIG_RSA=y compiles fine without this patch. But with this patch:
lib/rsa/rsa-verify.c:60:5: error: redefinition of ‘padding_pkcs_15_verify’ 60 | int padding_pkcs_15_verify(struct image_sign_info *info, | ^~~~~~~~~~~~~~~~~~~~~~ In file included from lib/rsa/rsa-verify.c:21: include/u-boot/rsa.h:118:19: note: previous definition of ‘padding_pkcs_15_verify’ was here 118 | static inline int padding_pkcs_15_verify(struct image_sign_info *info, | ^~~~~~~~~~~~~~~~~~~~~~ lib/rsa/rsa-verify.c:399:5: error: redefinition of ‘rsa_verify’ 399 | int rsa_verify(struct image_sign_info *info, | ^~~~~~~~~~ CC lib/efi_loader/efi_hii.o In file included from lib/rsa/rsa-verify.c:21: include/u-boot/rsa.h:111:19: note: previous definition of ‘rsa_verify’ was here 111 | static inline int rsa_verify(struct image_sign_info *info, | ^~~~~~~~~~
Best regards
Heinrich
- select RSA_VERIFY
+config RSA_VERIFY
- bool
- help
Right. It seems that include/image.h will also have to be modified.
Thanks, -Takahiro Akashi
Best regards
Heinrich
In the current implementation of FIT_SIGNATURE, five parameters for a RSA public key are required while only two of them are essential. (See rsa-mod-exp.h and uImage.FIT/signature.txt) This is a result of considering relatively limited computer power and resources on embedded systems, while such a assumption may not be quite practical for other use cases.
In this patch, added is a function, rsa_gen_key_prop(), which will generate additional parameters for other uses, in particular UEFI secure boot, on the fly.
Note: the current code uses some "big number" routines from BearSSL for the calculation.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- include/u-boot/rsa-mod-exp.h | 3 + lib/rsa/Makefile | 2 +- lib/rsa/rsa-keyprop.c | 631 +++++++++++++++++++++++++++++++++++ 3 files changed, 635 insertions(+), 1 deletion(-) create mode 100644 lib/rsa/rsa-keyprop.c
diff --git a/include/u-boot/rsa-mod-exp.h b/include/u-boot/rsa-mod-exp.h index 8a428c4b6a1a..ca189292d869 100644 --- a/include/u-boot/rsa-mod-exp.h +++ b/include/u-boot/rsa-mod-exp.h @@ -26,6 +26,9 @@ struct key_prop { uint32_t exp_len; /* Exponent length in number of uint8_t */ };
+struct key_prop *rsa_gen_key_prop(const void *key, uint32_t keylen); +void rsa_free_key_prop(struct key_prop *prop); + /** * rsa_mod_exp_sw() - Perform RSA Modular Exponentiation in sw * diff --git a/lib/rsa/Makefile b/lib/rsa/Makefile index 226d8f3514a9..d66eef74c514 100644 --- a/lib/rsa/Makefile +++ b/lib/rsa/Makefile @@ -5,5 +5,5 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_RSA_VERIFY) += rsa-verify.o rsa-checksum.o +obj-$(CONFIG_RSA_VERIFY) += rsa-verify.o rsa-checksum.o rsa-keyprop.o obj-$(CONFIG_RSA_SOFTWARE_EXP) += rsa-mod-exp.o diff --git a/lib/rsa/rsa-keyprop.c b/lib/rsa/rsa-keyprop.c new file mode 100644 index 000000000000..e650a931dff9 --- /dev/null +++ b/lib/rsa/rsa-keyprop.c @@ -0,0 +1,631 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * RSA library - generate parameters for a public key + * + * Copyright (c) 2019 Linaro Limited + * Author: AKASHI Takahiro + * + * Big number routines in this file come from BearSSL. + * See the original copyright below. + * + * Copyright (c) 2016 Thomas Pornin pornin@bolet.org + * + * Permission is hereby granted, free of charge, to any person obtaining + * a copy of this software and associated documentation files (the + * "Software"), to deal in the Software without restriction, including + * without limitation the rights to use, copy, modify, merge, publish, + * distribute, sublicense, and/or sell copies of the Software, and to + * permit persons to whom the Software is furnished to do so, subject to + * the following conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF + * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS + * BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN + * ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN + * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE + * SOFTWARE. + */ +#include <stdio.h> + +#include <image.h> +#include <malloc.h> +#include <crypto/internal/rsa.h> +#include <u-boot/rsa-mod-exp.h> + +/* stripped version of src/inner.h */ + +static inline unsigned +br_dec16be(const void *src) +{ +#if 0 /* BR_BE_UNALIGNED */ + return ((const br_union_u16 *)src)->u; +#else + const unsigned char *buf; + + buf = src; + return ((unsigned)buf[0] << 8) | (unsigned)buf[1]; +#endif +} + +static inline uint32_t +br_dec32be(const void *src) +{ +#if 0 /* BR_BE_UNALIGNED */ + return ((const br_union_u32 *)src)->u; +#else + const unsigned char *buf; + + buf = src; + return ((uint32_t)buf[0] << 24) + | ((uint32_t)buf[1] << 16) + | ((uint32_t)buf[2] << 8) + | (uint32_t)buf[3]; +#endif +} + +static inline void +br_enc32be(void *dst, uint32_t x) +{ +#if 0 /* BR_BE_UNALIGNED */ + ((br_union_u32 *)dst)->u = x; +#else + unsigned char *buf; + + buf = dst; + buf[0] = (unsigned char)(x >> 24); + buf[1] = (unsigned char)(x >> 16); + buf[2] = (unsigned char)(x >> 8); + buf[3] = (unsigned char)x; +#endif +} + +static inline uint32_t +NOT(uint32_t ctl) +{ + return ctl ^ 1; +} + +static inline uint32_t +MUX(uint32_t ctl, uint32_t x, uint32_t y) +{ + return y ^ (-ctl & (x ^ y)); +} + +static inline uint32_t +EQ(uint32_t x, uint32_t y) +{ + uint32_t q; + + q = x ^ y; + return NOT((q | -q) >> 31); +} + +static inline uint32_t +NEQ(uint32_t x, uint32_t y) +{ + uint32_t q; + + q = x ^ y; + return (q | -q) >> 31; +} + +static inline uint32_t +GT(uint32_t x, uint32_t y) +{ + /* + * If both x < 2^31 and x < 2^31, then y-x will have its high + * bit set if x > y, cleared otherwise. + * + * If either x >= 2^31 or y >= 2^31 (but not both), then the + * result is the high bit of x. + * + * If both x >= 2^31 and y >= 2^31, then we can virtually + * subtract 2^31 from both, and we are back to the first case. + * Since (y-2^31)-(x-2^31) = y-x, the subtraction is already + * fine. + */ + uint32_t z; + + z = y - x; + return (z ^ ((x ^ y) & (x ^ z))) >> 31; +} + +static inline uint32_t +BIT_LENGTH(uint32_t x) +{ + uint32_t k, c; + + k = NEQ(x, 0); + c = GT(x, 0xFFFF); x = MUX(c, x >> 16, x); k += c << 4; + c = GT(x, 0x00FF); x = MUX(c, x >> 8, x); k += c << 3; + c = GT(x, 0x000F); x = MUX(c, x >> 4, x); k += c << 2; + c = GT(x, 0x0003); x = MUX(c, x >> 2, x); k += c << 1; + k += GT(x, 0x0001); + return k; +} + +#define GE(x, y) NOT(GT(y, x)) +#define LT(x, y) GT(y, x) +#define MUL(x, y) ((uint64_t)(x) * (uint64_t)(y)) + +static inline uint32_t +br_i32_word(const uint32_t *a, uint32_t off) +{ + size_t u; + unsigned j; + + u = (size_t)(off >> 5) + 1; + j = (unsigned)off & 31; + if (j == 0) { + return a[u]; + } else { + return (a[u] >> j) | (a[u + 1] << (32 - j)); + } +} + +/* src/int/i32_bitlen.c */ + +static uint32_t +br_i32_bit_length(uint32_t *x, size_t xlen) +{ + uint32_t tw, twk; + + tw = 0; + twk = 0; + while (xlen -- > 0) { + uint32_t w, c; + + c = EQ(tw, 0); + w = x[xlen]; + tw = MUX(c, w, tw); + twk = MUX(c, (uint32_t)xlen, twk); + } + return (twk << 5) + BIT_LENGTH(tw); +} + +/* src/int/i32_decode.c */ + +static void +br_i32_decode(uint32_t *x, const void *src, size_t len) +{ + const unsigned char *buf; + size_t u, v; + + buf = src; + u = len; + v = 1; + for (;;) { + if (u < 4) { + uint32_t w; + + if (u < 2) { + if (u == 0) { + break; + } else { + w = buf[0]; + } + } else { + if (u == 2) { + w = br_dec16be(buf); + } else { + w = ((uint32_t)buf[0] << 16) + | br_dec16be(buf + 1); + } + } + x[v ++] = w; + break; + } else { + u -= 4; + x[v ++] = br_dec32be(buf + u); + } + } + x[0] = br_i32_bit_length(x + 1, v - 1); +} + +/* src/int/i32_encode.c */ + +static void +br_i32_encode(void *dst, size_t len, const uint32_t *x) +{ + unsigned char *buf; + size_t k; + + buf = dst; + + /* + * Compute the announced size of x in bytes; extra bytes are + * filled with zeros. + */ + k = (x[0] + 7) >> 3; + while (len > k) { + *buf ++ = 0; + len --; + } + + /* + * Now we use k as index within x[]. That index starts at 1; + * we initialize it to the topmost complete word, and process + * any remaining incomplete word. + */ + k = (len + 3) >> 2; + switch (len & 3) { + case 3: + *buf ++ = x[k] >> 16; + /* fall through */ + case 2: + *buf ++ = x[k] >> 8; + /* fall through */ + case 1: + *buf ++ = x[k]; + k --; + } + + /* + * Encode all complete words. + */ + while (k > 0) { + br_enc32be(buf, x[k]); + k --; + buf += 4; + } +} + +/* src/int/i32_ninv32.c */ + +static uint32_t +br_i32_ninv32(uint32_t x) +{ + uint32_t y; + + y = 2 - x; + y *= 2 - y * x; + y *= 2 - y * x; + y *= 2 - y * x; + y *= 2 - y * x; + return MUX(x & 1, -y, 0); +} + +/* src/int/i32_add.c */ + +static uint32_t +br_i32_add(uint32_t *a, const uint32_t *b, uint32_t ctl) +{ + uint32_t cc; + size_t u, m; + + cc = 0; + m = (a[0] + 63) >> 5; + for (u = 1; u < m; u ++) { + uint32_t aw, bw, naw; + + aw = a[u]; + bw = b[u]; + naw = aw + bw + cc; + + /* + * Carry is 1 if naw < aw. Carry is also 1 if naw == aw + * AND the carry was already 1. + */ + cc = (cc & EQ(naw, aw)) | LT(naw, aw); + a[u] = MUX(ctl, naw, aw); + } + return cc; +} + +/* src/int/i32_sub.c */ + +static uint32_t +br_i32_sub(uint32_t *a, const uint32_t *b, uint32_t ctl) +{ + uint32_t cc; + size_t u, m; + + cc = 0; + m = (a[0] + 63) >> 5; + for (u = 1; u < m; u ++) { + uint32_t aw, bw, naw; + + aw = a[u]; + bw = b[u]; + naw = aw - bw - cc; + + /* + * Carry is 1 if naw > aw. Carry is 1 also if naw == aw + * AND the carry was already 1. + */ + cc = (cc & EQ(naw, aw)) | GT(naw, aw); + a[u] = MUX(ctl, naw, aw); + } + return cc; +} + +/* src/int/i32_div32.c */ + +static uint32_t +br_divrem(uint32_t hi, uint32_t lo, uint32_t d, uint32_t *r) +{ + /* TODO: optimize this */ + uint32_t q; + uint32_t ch, cf; + int k; + + q = 0; + ch = EQ(hi, d); + hi = MUX(ch, 0, hi); + for (k = 31; k > 0; k --) { + int j; + uint32_t w, ctl, hi2, lo2; + + j = 32 - k; + w = (hi << j) | (lo >> k); + ctl = GE(w, d) | (hi >> k); + hi2 = (w - d) >> j; + lo2 = lo - (d << k); + hi = MUX(ctl, hi2, hi); + lo = MUX(ctl, lo2, lo); + q |= ctl << k; + } + cf = GE(lo, d) | hi; + q |= cf; + *r = MUX(cf, lo - d, lo); + return q; +} + +static inline uint32_t +br_rem(uint32_t hi, uint32_t lo, uint32_t d) +{ + uint32_t r; + + br_divrem(hi, lo, d, &r); + return r; +} + +static inline uint32_t +br_div(uint32_t hi, uint32_t lo, uint32_t d) +{ + uint32_t r; + + return br_divrem(hi, lo, d, &r); +} + +/* src/int/i32_muladd.c */ + +static void +br_i32_muladd_small(uint32_t *x, uint32_t z, const uint32_t *m) +{ + uint32_t m_bitlen; + size_t u, mlen; + uint32_t a0, a1, b0, hi, g, q, tb; + uint32_t chf, clow, under, over; + uint64_t cc; + + /* + * We can test on the modulus bit length since we accept to + * leak that length. + */ + m_bitlen = m[0]; + if (m_bitlen == 0) { + return; + } + if (m_bitlen <= 32) { + x[1] = br_rem(x[1], z, m[1]); + return; + } + mlen = (m_bitlen + 31) >> 5; + + /* + * Principle: we estimate the quotient (x*2^32+z)/m by + * doing a 64/32 division with the high words. + * + * Let: + * w = 2^32 + * a = (w*a0 + a1) * w^N + a2 + * b = b0 * w^N + b2 + * such that: + * 0 <= a0 < w + * 0 <= a1 < w + * 0 <= a2 < w^N + * w/2 <= b0 < w + * 0 <= b2 < w^N + * a < w*b + * I.e. the two top words of a are a0:a1, the top word of b is + * b0, we ensured that b0 is "full" (high bit set), and a is + * such that the quotient q = a/b fits on one word (0 <= q < w). + * + * If a = b*q + r (with 0 <= r < q), we can estimate q by + * doing an Euclidean division on the top words: + * a0*w+a1 = b0*u + v (with 0 <= v < w) + * Then the following holds: + * 0 <= u <= w + * u-2 <= q <= u + */ + a0 = br_i32_word(x, m_bitlen - 32); + hi = x[mlen]; + memmove(x + 2, x + 1, (mlen - 1) * sizeof *x); + x[1] = z; + a1 = br_i32_word(x, m_bitlen - 32); + b0 = br_i32_word(m, m_bitlen - 32); + + /* + * We estimate a divisor q. If the quotient returned by br_div() + * is g: + * -- If a0 == b0 then g == 0; we want q = 0xFFFFFFFF. + * -- Otherwise: + * -- if g == 0 then we set q = 0; + * -- otherwise, we set q = g - 1. + * The properties described above then ensure that the true + * quotient is q-1, q or q+1. + */ + g = br_div(a0, a1, b0); + q = MUX(EQ(a0, b0), 0xFFFFFFFF, MUX(EQ(g, 0), 0, g - 1)); + + /* + * We subtract q*m from x (with the extra high word of value 'hi'). + * Since q may be off by 1 (in either direction), we may have to + * add or subtract m afterwards. + * + * The 'tb' flag will be true (1) at the end of the loop if the + * result is greater than or equal to the modulus (not counting + * 'hi' or the carry). + */ + cc = 0; + tb = 1; + for (u = 1; u <= mlen; u ++) { + uint32_t mw, zw, xw, nxw; + uint64_t zl; + + mw = m[u]; + zl = MUL(mw, q) + cc; + cc = (uint32_t)(zl >> 32); + zw = (uint32_t)zl; + xw = x[u]; + nxw = xw - zw; + cc += (uint64_t)GT(nxw, xw); + x[u] = nxw; + tb = MUX(EQ(nxw, mw), tb, GT(nxw, mw)); + } + + /* + * If we underestimated q, then either cc < hi (one extra bit + * beyond the top array word), or cc == hi and tb is true (no + * extra bit, but the result is not lower than the modulus). In + * these cases we must subtract m once. + * + * Otherwise, we may have overestimated, which will show as + * cc > hi (thus a negative result). Correction is adding m once. + */ + chf = (uint32_t)(cc >> 32); + clow = (uint32_t)cc; + over = chf | GT(clow, hi); + under = ~over & (tb | (~chf & LT(clow, hi))); + br_i32_add(x, m, over); + br_i32_sub(x, m, under); +} + +/* src/int/i32_reduce.c */ + +static void +br_i32_reduce(uint32_t *x, const uint32_t *a, const uint32_t *m) +{ + uint32_t m_bitlen, a_bitlen; + size_t mlen, alen, u; + + m_bitlen = m[0]; + mlen = (m_bitlen + 31) >> 5; + + x[0] = m_bitlen; + if (m_bitlen == 0) { + return; + } + + /* + * If the source is shorter, then simply copy all words from a[] + * and zero out the upper words. + */ + a_bitlen = a[0]; + alen = (a_bitlen + 31) >> 5; + if (a_bitlen < m_bitlen) { + memcpy(x + 1, a + 1, alen * sizeof *a); + for (u = alen; u < mlen; u ++) { + x[u + 1] = 0; + } + return; + } + + /* + * The source length is at least equal to that of the modulus. + * We must thus copy N-1 words, and input the remaining words + * one by one. + */ + memcpy(x + 1, a + 2 + (alen - mlen), (mlen - 1) * sizeof *a); + x[mlen] = 0; + for (u = 1 + alen - mlen; u > 0; u --) { + br_i32_muladd_small(x, a[u], m); + } +} + +void rsa_free_key_prop(struct key_prop *prop) +{ + if (!prop) + return; + + free((void *)prop->modulus); + free((void *)prop->public_exponent); + free((void *)prop->rr); + + free(prop); +} + +struct key_prop *rsa_gen_key_prop(const void *key, uint32_t keylen) +{ + struct key_prop *prop; + struct rsa_key rsa_key; +#define BR_MAX_RSA_SIZE 4096 + uint32_t *n, *rr, *rrtmp; + int rlen, i, ret; + + prop = calloc(sizeof(*prop), 1); + if (!prop) + return NULL; + n = calloc(sizeof(uint32_t), 1 + (BR_MAX_RSA_SIZE >> 5)); + rr = calloc(sizeof(uint32_t), 1 + (BR_MAX_RSA_SIZE >> 5)); + rrtmp = calloc(sizeof(uint32_t), 1 + (BR_MAX_RSA_SIZE >> 5)); + if (!n || !rr || !rrtmp) + return NULL; + + ret = rsa_parse_pub_key(&rsa_key, key, keylen); + if (ret) + goto err; + + /* modulus */ + /* removing leading 0's */ + for (i = 0; i < rsa_key.n_sz && !rsa_key.n[i]; i++) + ; + prop->num_bits = (rsa_key.n_sz - i) * 8; + prop->modulus = malloc(rsa_key.n_sz - i); + if (!prop->modulus) + goto err; + memcpy((void *)prop->modulus, &rsa_key.n[i], rsa_key.n_sz - i); + + /* exponent */ + /* FIXME: fdt64 expected, not rsa_key.e_sz. See rsa_mod_exp_sw() */ + prop->public_exponent = calloc(1, sizeof(uint64_t)); + if (!prop->public_exponent) + goto err; + memcpy((void *)prop->public_exponent + sizeof(uint64_t) - rsa_key.e_sz, + rsa_key.e, rsa_key.e_sz); + prop->exp_len = rsa_key.e_sz; + + /* n0 inverse */ + br_i32_decode(n, &rsa_key.n[i], rsa_key.n_sz - i); + prop->n0inv = br_i32_ninv32(n[1]); + + /* R^2 mod n; R = 2^(num_bits) */ + rlen = prop->num_bits * 2; /* #bits of R^2 = (2^num_bits)^2 */ + rr[0] = 0; + *(uint8_t *)&rr[0] = (1 << (rlen % 8)); + for (i = 1; i < (((rlen + 31) >> 5) + 1); i++) + rr[i] = 0; + br_i32_decode(rrtmp, rr, ((rlen + 7) >> 3) + 1); + br_i32_reduce(rr, rrtmp, n); + + rlen = (prop->num_bits + 7) >> 3; /* #bytes of R^2 mod n */ + prop->rr = malloc(rlen); + if (!prop->rr) + goto err; + br_i32_encode((void *)prop->rr, rlen, rr); + + return prop; + +err: + free(n); + free(rr); + free(rrtmp); + rsa_free_key_prop(prop); + return NULL; +}
Hi AKASHI,
On Fri, 6 Sep 2019 at 00:05, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
- rsa_mod_exp_sw() - Perform RSA Modular Exponentiation in sw
Can this code only be included when needed? It seems a bit large,
- RSA library - generate parameters for a public key
- Copyright (c) 2019 Linaro Limited
- Author: AKASHI Takahiro
- Big number routines in this file come from BearSSL.
- See the original copyright below.
- Copyright (c) 2016 Thomas Pornin pornin@bolet.org
- Permission is hereby granted, free of charge, to any person obtaining
Can you use SPDX?
- a copy of this software and associated documentation files (the
- "Software"), to deal in the Software without restriction, including
- without limitation the rights to use, copy, modify, merge, publish,
- distribute, sublicense, and/or sell copies of the Software, and to
- permit persons to whom the Software is furnished to do so, subject to
- the following conditions:
- The above copyright notice and this permission notice shall be
- included in all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
- EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
- MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
- NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS
- BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN
- ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
- CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
- SOFTWARE.
+#include <stdio.h>
Should this include common.h?
Hmm this seems to be for running on the host?
Hi Simon,
On Mon, Sep 16, 2019 at 10:48:05PM -0700, Simon Glass wrote:
Hi AKASHI,
Okay, compiled in only if CONFIG_RSA_VERIFY_WITH_PKEY.
Can you use SPDX?
I'm not sure this license is listed in SPDX, but will ask the author.
- SOFTWARE.
+#include <stdio.h>
Okay.
rsa.h? No. It was imported from linux kernel to use rsa_parse_pub_key() in rsa_gen_key_prop().
- return ((const br_union_u16 *)src)->u;
+#else
- const unsigned char *buf;
- buf = src;
- return ((unsigned)buf[0] << 8) | (unsigned)buf[1];
+#endif +}
- return ((const br_union_u32 *)src)->u;
+#else
- buf = src;
- return ((uint32_t)buf[0] << 24)
| (uint32_t)buf[3];
+#endif +}
- ((br_union_u32 *)dst)->u = x;
+#else
- unsigned char *buf;
- buf = dst;
- buf[0] = (unsigned char)(x >> 24);
- buf[1] = (unsigned char)(x >> 16);
- buf[2] = (unsigned char)(x >> 8);
- buf[3] = (unsigned char)x;
+#endif +}
There's no U-Boot API for the above?
- return ctl ^ 1;
Ditto
- return y ^ (-ctl & (x ^ y));
- uint32_t q;
- q = x ^ y;
- return NOT((q | -q) >> 31);
- uint32_t q;
- q = x ^ y;
- return (q | -q) >> 31;
second one should be y^31
- struct key_prop *prop;
- struct rsa_key rsa_key;
- uint32_t *n, *rr, *rrtmp;
- int rlen, i, ret;
- prop->n0inv = br_i32_ninv32(n[1]);
-- 2.21.0
Regards /Ilias
Ilias,
+#else
- buf = src;
+#endif +}
+#else
- buf = src;
| (uint32_t)buf[3];
+#endif +}
+#else
- buf = dst;
+#endif +}
Do you mean dec32be() and enc32be()? Yes, there are similar functions but I intentionally don't use them as I want to keep the difference between BearSSL's original code and imported one in this file to a minimum.
Anyhow, this code won't work for big-endian. We should manage it.
- return ctl ^ 1;
Ditto
- uint32_t q;
- q = x ^ y;
- uint32_t q;
- q = x ^ y;
Do you mean that the second "x < 2^31" be "y < 2^31"? You're right.
- int rlen, i, ret;
-- 2.21.0
Regards /Ilias
On 10/3/19 10:58 AM, AKASHI Takahiro wrote:
Ilias,
+#else
- buf = src;
+#endif +}
+#else
- buf = src;
| (uint32_t)buf[3];
+#endif +}
+#else
- buf = dst;
+#endif +}
htonl() does the conversion both for big- and little-endian for properly aligned fields.
Tom is always unhappy when we unnecessarily enlarge the U-Boot binary.
Best regards
Heinrich
- return ctl ^ 1;
Ditto
- uint32_t q;
- q = x ^ y;
- uint32_t q;
- q = x ^ y;
- int rlen, i, ret;
-- 2.21.0
Regards /Ilias
This function, and hence rsa_verify(), will perform RSA verification with two essential parameters for a RSA public key in contract of rsa_verify_with_keynode(), which requires additional three parameters stored in FIT image.
It will be used in implementing UEFI secure boot, i.e. image authentication and variable authentication.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/rsa/Kconfig | 7 +++++ lib/rsa/Makefile | 3 ++- lib/rsa/rsa-verify.c | 63 ++++++++++++++++++++++++++++++++++++++------ 3 files changed, 64 insertions(+), 9 deletions(-)
diff --git a/lib/rsa/Kconfig b/lib/rsa/Kconfig index 338c8124da59..3c1986a26f8c 100644 --- a/lib/rsa/Kconfig +++ b/lib/rsa/Kconfig @@ -25,6 +25,13 @@ config RSA_VERIFY help Add RSA signature verification support.
+config RSA_VERIFY_WITH_PKEY + bool "Execute RSA verification without key parameters from FDT" + depends on RSA + help + This options enables RSA signature verification without + using public key parameters which is embedded control FDT. + config RSA_SOFTWARE_EXP bool "Enable driver for RSA Modular Exponentiation in software" depends on DM diff --git a/lib/rsa/Makefile b/lib/rsa/Makefile index d66eef74c514..fd4592fd6a8a 100644 --- a/lib/rsa/Makefile +++ b/lib/rsa/Makefile @@ -5,5 +5,6 @@ # (C) Copyright 2000-2007 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_RSA_VERIFY) += rsa-verify.o rsa-checksum.o rsa-keyprop.o +obj-$(CONFIG_RSA_VERIFY) += rsa-verify.o rsa-checksum.o +obj-$(CONFIG_RSA_VERIFY_WITH_PKEY) += rsa-keyprop.o obj-$(CONFIG_RSA_SOFTWARE_EXP) += rsa-mod-exp.o diff --git a/lib/rsa/rsa-verify.c b/lib/rsa/rsa-verify.c index 287fcc4d234d..80eabff3e940 100644 --- a/lib/rsa/rsa-verify.c +++ b/lib/rsa/rsa-verify.c @@ -17,9 +17,14 @@ #include "mkimage.h" #include <fdt_support.h> #endif +#include <linux/kconfig.h> #include <u-boot/rsa-mod-exp.h> #include <u-boot/rsa.h>
+#ifndef __UBOOT__ /* for host tools */ +#undef CONFIG_RSA_VERIFY_WITH_PKEY +#endif + /* Default public exponent for backward compatibility */ #define RSA_DEFAULT_PUBEXP 65537
@@ -342,6 +347,34 @@ static int rsa_verify_key(struct image_sign_info *info, return 0; }
+#ifdef CONFIG_RSA_VERIFY_WITH_PKEY +/** + * rsa_verify_with_pkey() + * + */ +static int rsa_verify_with_pkey(struct image_sign_info *info, + const void *hash, uint8_t *sig, uint sig_len) +{ + struct key_prop *prop; + int ret; + + /* Public key is self-described to fill key_prop */ + prop = rsa_gen_key_prop(info->key, info->keylen); + if (!prop) { + debug("Generating necessary parameter for decoding failed\n"); + return -EACCES; + } + + ret = rsa_verify_key(info, prop, sig, sig_len, hash, + info->crypto->key_len); + + rsa_free_key_prop(prop); + + return ret; +} +#endif + +#if CONFIG_IS_ENABLED(FIT_SIGNATURE) /** * rsa_verify_with_keynode() - Verify a signature against some data using * information in node with prperties of RSA Key like modulus, exponent etc. @@ -395,18 +428,21 @@ static int rsa_verify_with_keynode(struct image_sign_info *info,
return ret; } +#endif
int rsa_verify(struct image_sign_info *info, const struct image_region region[], int region_count, uint8_t *sig, uint sig_len) { - const void *blob = info->fdt_blob; /* Reserve memory for maximum checksum-length */ uint8_t hash[info->crypto->key_len]; + int ret = -EACCES; +#if CONFIG_IS_ENABLED(FIT_SIGNATURE) + const void *blob = info->fdt_blob; int ndepth, noffset; int sig_node, node; char name[100]; - int ret; +#endif
/* * Verify that the checksum-length does not exceed the @@ -419,12 +455,6 @@ int rsa_verify(struct image_sign_info *info, return -EINVAL; }
- sig_node = fdt_subnode_offset(blob, 0, FIT_SIG_NODENAME); - if (sig_node < 0) { - debug("%s: No signature node found\n", __func__); - return -ENOENT; - } - /* Calculate checksum with checksum-algorithm */ ret = info->checksum->calculate(info->checksum->name, region, region_count, hash); @@ -433,6 +463,22 @@ int rsa_verify(struct image_sign_info *info, return -EINVAL; }
+#ifdef CONFIG_RSA_VERIFY_WITH_PKEY + if (!info->fdt_blob) { + /* don't rely on fdt properties */ + ret = rsa_verify_with_pkey(info, hash, sig, sig_len); + + return ret; + } +#endif + +#if CONFIG_IS_ENABLED(FIT_SIGNATURE) + sig_node = fdt_subnode_offset(blob, 0, FIT_SIG_NODENAME); + if (sig_node < 0) { + debug("%s: No signature node found\n", __func__); + return -ENOENT; + } + /* See if we must use a particular key */ if (info->required_keynode != -1) { ret = rsa_verify_with_keynode(info, hash, sig, sig_len, @@ -459,6 +505,7 @@ int rsa_verify(struct image_sign_info *info, break; } } +#endif
return ret; }
Hi AKASHI,
On Fri, 6 Sep 2019 at 00:06, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
depends on RSA
help
Please expand this, a lot. It is too brief.
- rsa_verify_with_pkey()
int ret;
if (!prop) {
return -EACCES;
return ret;
+} +#endif
- rsa_verify_with_keynode() - Verify a signature against some data using
- information in node with prperties of RSA Key like modulus, exponent etc.
return ret;
} +#endif
int ret = -EACCES;
int ret;
if (sig_node < 0) {
return -ENOENT;
Can this use if() instead of #ifdef?
Does this support required_keynode?
Please add to the documentation for secure boot in uImage, as this seems to be a new case.
Also, how do we test this new code?
return ret;
if (sig_node < 0) {
return -ENOENT;
return ret;
2.21.0
Simon,
Overall, do you agree to my approach here?
On Mon, Sep 16, 2019 at 10:48:07PM -0700, Simon Glass wrote:
Hi AKASHI,
depends on RSA
help
Will add more description.
int ret;
if (!prop) {
return -EACCES;
return ret;
+} +#endif
return ret;
} +#endif
int ret = -EACCES;
int ret;
if (sig_node < 0) {
return -ENOENT;
Do you mean if (IS_ENABLED(CONFIG_RSA_VERIFY_WITH_PKEY) && !info->fdt_blob) ?
IICU, no because required_keynode is an offset into fdt.
It may work with FIT in case of no extra key parameters, I intended that the feature is used only by UEFI. So I don't think it appropriate to add a doc under doc/uImage.FIT.
The code is exercised and tested only through UEFI's verification code and relevant pytest (in my secure boot patch[1]). Like test_vboot?
[1] https://lists.denx.de/pipermail/u-boot/2019-September/383897.html
return ret;
if (sig_node < 0) {
return -ENOENT;
return ret;
2.21.0
Simon,
On Wed, Sep 18, 2019 at 12:03:25PM +0900, AKASHI Takahiro wrote:
Simon,
Ping. Do you mind my sending out v2?
-Takahiro Akashi
Hi AKASHI,
depends on RSA
help
int ret;
if (!prop) {
return -EACCES;
return ret;
+} +#endif
return ret;
} +#endif
int ret = -EACCES;
int ret;
if (sig_node < 0) {
return -ENOENT;
return ret;
if (sig_node < 0) {
return -ENOENT;
return ret;
2.21.0
Hi Takahiro,
On Tue, 17 Sep 2019 at 20:59, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
Simon,
Hi AKASHI,
depends on RSA
help
int ret;
if (!prop) {
return -EACCES;
return ret;
+} +#endif
return ret;
} +#endif
int ret = -EACCES;
Can you use if() instead of #if ?
int ret;
if (sig_node < 0) {
return -ENOENT;
Yes
Sounds good.
OK good.
On Tue, Oct 22, 2019 at 07:50:20AM -0600, Simon Glass wrote:
Hi Takahiro,
Simon,
Hi AKASHI,
depends on RSA
help
int ret;
if (!prop) {
return -EACCES;
return ret;
+} +#endif
return ret;
} +#endif
int ret = -EACCES;
This code is for local variable declaration, and so changing as you suggested can be difficult. Or do you accept moving this stuff further down to the next "#if CONFIG_IS_ENABLED(FIT_SIGNATURE)": === 8< === if (IS_ENABLED(CONFIG_RSA_VERIFY_WITH_PKEY) && !info->fdt_blob) { /* don't rely on fdt properties */ ret = rsa_verify_with_pkey(info, hash, sig, sig_len);
return ret; }
if (CONFIG_IS_ENABLED(FIT_SIGNATURE)) { /* * declare variables here! */ const void *blob = info->fdt_blob; int ndepth, noffset; int sig_node, node; char name[100];
sig_node = fdt_subnode_offset(blob, 0, FIT_SIG_NODENAME); if (sig_node < 0) { debug("%s: No signature node found\n", __func__); return -ENOENT; }
/* See if we must use a particular key */ ... } === >8 ===
Otherwise, we will have to introduce another function, rsa_verify_with_fdt?, just for this purpose.
int ret;
if (sig_node < 0) {
return -ENOENT;
Yes
Sounds good.
OK good.
Hi Takahiro,
On Tue, 22 Oct 2019 at 23:43, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
Hi Takahiro,
Simon,
Hi AKASHI,
depends on RSA
help
int ret;
if (!prop) {
return -EACCES;
return ret;
+} +#endif
return ret;
} +#endif
int ret = -EACCES;
Yes if you use if() then you don't need to #ifdef the variables.
return ret;
sig_node = fdt_subnode_offset(blob, 0, FIT_SIG_NODENAME); if (sig_node < 0) { debug("%s: No signature node found\n", __func__); return -ENOENT; } /* See if we must use a particular key */ ...
} === >8 ===
Simon,
On Sun, Oct 27, 2019 at 10:31:59AM -0600, Simon Glass wrote:
Hi Takahiro,
Hi Takahiro,
Simon,
Hi AKASHI,
depends on RSA
help
int ret;
if (!prop) {
return -EACCES;
return ret;
+} +#endif
return ret;
} +#endif
int ret = -EACCES;
Okay, I will change the code as below. -Takahiro Akashi
return ret;
} === >8 ===
AKASHI Takahiro
Ilias Apalodimas
