[U-Boot] [PATCH] TCP and wget implementation. Patch V5, 3 of 3.
This is the wget, tftp and Kconfig files for introducing TCP and wget into u-boot.
tftp.c was enhanced to check a downloaded kernel by being able to compile it as a verification tool. The switch detween download program and tool is by c #define directive in tftp.c. Should this directive be configured by Kconfig?
All the code is new, and not copied from any source.
Signed-off-by: Duncan Hare DuncanCHare@yahoo.com ---
cmd/Kconfig | 6 + cmd/net.c | 13 ++ net/tftp.c | 35 ++++- net/wget.c | 417 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ net/wget.h | 22 ++++ 5 files changed, 487 insertions(+), 6 deletions(-) create mode 100644 net/wget.c create mode 100644 net/wget.h
diff --git a/cmd/Kconfig b/cmd/Kconfig index 5a6afab99b..46b489a966 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1035,6 +1035,12 @@ config CMD_ETHSW operations such as enabling / disabling a port and viewing/maintaining the filtering database (FDB)
+config CMD_WGET + bool "wget" + select TCP + help + Download a kernel, or other files, from a web server over TCP. + endmenu
menu "Misc commands" diff --git a/cmd/net.c b/cmd/net.c index d7c776aacf..f5c2d0f8ed 100644 --- a/cmd/net.c +++ b/cmd/net.c @@ -110,6 +110,19 @@ U_BOOT_CMD( ); #endif
+#if defined(CONFIG_CMD_WGET) +static int do_wget(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return netboot_common(WGET, cmdtp, argc, argv); +} + +U_BOOT_CMD( + wget, 3, 1, do_wget, + "boot image via network using HTTP protocol", + "[loadAddress] [[hostIPaddr:]bootfilename]" +); +#endif + static void netboot_update_env(void) { char tmp[22]; diff --git a/net/tftp.c b/net/tftp.c index 6671b1f7ca..c3f8fd3053 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -6,6 +6,9 @@ * Luca Ceresoli luca.ceresoli@comelit.it */
+/* define if kernel load or verify kernal from a previous load */ +#define K_LOAD 1 + #include <common.h> #include <command.h> #include <efi_loader.h> @@ -16,6 +19,9 @@ #ifdef CONFIG_SYS_DIRECT_FLASH_TFTP #include <flash.h> #endif +#ifndef K_LOAD +#include "tcp.h" +#endif
/* Well known TFTP port # */ #define WELL_KNOWN_PORT 69 @@ -29,7 +35,6 @@ #endif /* Number of "loading" hashes per line (for checking the image size) */ #define HASHES_PER_LINE 65 - /* * TFTP operations. */ @@ -166,7 +171,7 @@ static void mcast_cleanup(void)
static inline void store_block(int block, uchar *src, unsigned len) { - ulong offset = block * tftp_block_size + tftp_block_wrap_offset; + uint offset = block * tftp_block_size + tftp_block_wrap_offset; ulong newsize = offset + len; #ifdef CONFIG_SYS_DIRECT_FLASH_TFTP int i, rc = 0; @@ -188,14 +193,29 @@ static inline void store_block(int block, uchar *src, unsigned len) net_set_state(NETLOOP_FAIL); return; } - } else + } else { #endif /* CONFIG_SYS_DIRECT_FLASH_TFTP */ - { - void *ptr = map_sysmem(load_addr + offset, len);
+ void *ptr = map_sysmem(load_addr + offset, len); +#ifdef K_LOAD memcpy(ptr, src, len); +#endif +#ifndef K_LOAD + if (memcmp(ptr, src, len) != 0) { + debug_cond(1, + "File Xfer Mismatch, offset=%d, error=%d\n", + offset, memcmp(ptr, src, len)); + printf("TFTP Download Verification - Memory\n"); + tcp_print_buffer(ptr, len, len, -1, 0); + printf("TFTP Download Verification - Packet\n"); + tcp_print_buffer(src, len, len, -1, 0); + net_set_state(NETLOOP_FAIL); + } +#endif unmap_sysmem(ptr); +#ifdef CONFIG_SYS_DIRECT_FLASH_TFTP } +#endif #ifdef CONFIG_MCAST_TFTP if (tftp_mcast_active) ext2_set_bit(block, tftp_mcast_bitmap); @@ -761,6 +781,7 @@ void tftp_start(enum proto_t protocol) }
printf("Using %s device\n", eth_get_name()); + printf("TFTP %s server %pI4; our IP address is %pI4", #ifdef CONFIG_CMD_TFTPPUT protocol == TFTPPUT ? "to" : "from", @@ -780,7 +801,9 @@ void tftp_start(enum proto_t protocol) printf("; sending through gateway %pI4", &net_gateway); } putc('\n'); - +#ifndef K_LOAD + printf("TFTP Download Verification\n"); +#endif printf("Filename '%s'.", tftp_filename);
if (net_boot_file_expected_size_in_blocks) { diff --git a/net/wget.c b/net/wget.c new file mode 100644 index 0000000000..859fd91e91 --- /dev/null +++ b/net/wget.c @@ -0,0 +1,417 @@ +/* + * FILE support driver - based on etherboot and U-BOOT's tftp.c + * + * Copyright Duncan Hare dh@synoia.com 2017 + * + * SPDX-License-Identifier:<TAB>GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <mapmem.h> +#include <net.h> +#include "wget.h" +#include "tcp.h" + +char bootfile1[] = "GET "; +char bootfile3[] = " HTTP/1.0\r\n\r\n"; +const char http_eom[] = "\r\n\r\n"; +const char http_ok[] = "200"; +const char content_len[] = "Content-Length"; +const char linefeed[] = "\r\n"; +static struct in_addr file_server_ip; +static int our_port; +static int file_timeout_count; + +struct pkt_qd { + uchar *pkt; + unsigned int tcp_seq_num; + unsigned int len; +}; + +struct pkt_qd pkt_q[PKTBUFSRX / 4]; +int pkt_q_idx; +unsigned int content_length; +unsigned int packets; + +static unsigned int initial_data_seq_num; + +static enum FILE_STATE file_state; + +static char *file_filename; +static char *file_path; +static char file_path_buff[2048]; +static unsigned int file_timeout = FILE_TIMEOUT; + +static void file_timeout_handler(void); + +enum net_loop_state loop_state; + +static inline int store_block(uchar *src, unsigned int offset, unsigned int len) +{ + ulong newsize = offset + len; + +#ifdef CONFIG_SYS_DIRECT_FLASH_WGET + int i, rc = 0; + + for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { + /* start address in flash? */ + if (load_addr + offset >= flash_info[i].start[0]) { + rc = 1; + break; + } + } + + if (rc) { /* Flash is destination for this packet */ + rc = flash_write((uchar *)src, + (ulong)(load_addr + offset), len); + if (rc) { + flash_perror(rc); + return -1; + } + } else { +#endif /* CONFIG_SYS_DIRECT_FLASH_NFS */ + + uchar *ptr = map_sysmem(load_addr + offset, len); + memcpy(ptr, src, len); + unmap_sysmem(ptr); + +#ifdef CONFIG_SYS_DIRECT_FLASH_WGET + } +#endif + if (net_boot_file_size < (offset + len)) + net_boot_file_size = newsize; + return 0; +} + +/* + * File request dispatcher + * WARNING, This, and only this, is the place in wget,c where + * SEQUENCE NUMBERS are swapped between incoming (RX) + * and outgoing (TX). + * Procedure file_handler() is correct for RX traffic. + */ +static void file_send(u8 action, unsigned int tcp_ack_num, + unsigned int tcp_seq_num, int len) +{ + uchar *ptr; + uchar *offset; + + tcp_ack_num = tcp_ack_num + len; + + switch (file_state) { + case FILE_CLOSED: + debug_cond(FILE_TEST, "File send: send SYN\n"); + file_state = FILE_CONNECTING; + net_send_tcp_packet(0, SERVER_PORT, our_port, action, + tcp_seq_num, tcp_ack_num); + packets = 0; + break; + case FILE_CONNECTING: + pkt_q_idx = 0; + net_send_tcp_packet(0, SERVER_PORT, our_port, action, + tcp_seq_num, tcp_ack_num); + + ptr = net_tx_packet + net_eth_hdr_size() + + IP_TCP_HDR_SIZE + TCP_TSOPT_SIZE + 2; + offset = ptr; + + memcpy(offset, &bootfile1, strlen(bootfile1)); + offset = offset + strlen(bootfile1); + + memcpy(offset, file_path, strlen(file_path)); + offset = offset + strlen(file_path); + + memcpy(offset, &bootfile3, strlen(bootfile3)); + offset = offset + strlen(bootfile3); + net_send_tcp_packet((offset - ptr), SERVER_PORT, our_port, + TCP_PUSH, tcp_seq_num, tcp_ack_num); + file_state = FILE_CONNECTED; + break; + case FILE_CONNECTED: + case FILE_TRANSFERRING: + case FILE_TRANSFERRED: + net_send_tcp_packet(0, SERVER_PORT, our_port, action, + tcp_seq_num, tcp_ack_num); + break; + } +} + +void file_fail(char *error_message, unsigned int tcp_seq_num, + unsigned int tcp_ack_num, u8 action) +{ + printf("%s", error_message); + printf("%s", "File Transfer Fail\n"); + net_set_timeout_handler(0, NULL); + file_send(action, tcp_seq_num, tcp_ack_num, 0); +} + +void file_success(u8 action, unsigned int tcp_seq_num, + unsigned int tcp_ack_num, int len, int packets) +{ + printf("Packets received %d, File Send Success\n", packets); + file_send(action, tcp_seq_num, tcp_ack_num, len); +} + +/* + * Interfaces of U-BOOT + */ +static void file_timeout_handler(void) +{ + if (++file_timeout_count > FILE_RETRY_COUNT) { + puts("\nRetry count exceeded; starting again\n"); + net_start_again(); + } else { + puts("T "); + net_set_timeout_handler(file_timeout + + FILE_TIMEOUT * file_timeout_count, + file_timeout_handler); + file_state = FILE_CLOSED; + file_send(TCP_RST, 0, 0, 0); + file_send(TCP_SYN, 0, 0, 0); + } +} + +static void file_connected(uchar *pkt, unsigned int tcp_seq_num, + struct in_addr action_and_state, + unsigned int tcp_ack_num, unsigned int len) +{ + u8 action = action_and_state.s_addr; + uchar *pkt_in_q; + char *pos; + int hlen; + char *clen; + int i, j; + + pkt[len] = '\0'; + pos = strstr((char *)pkt, http_eom); + + if (pos == 0) { + debug_cond(FILE_TEST, + "File Connected data before Header %p\n", pkt); + pkt_in_q = (void *)load_addr + 0x20000 + (pkt_q_idx * 0x800); + memcpy(pkt_in_q, pkt, len); + pkt_q[pkt_q_idx].pkt = pkt_in_q; + pkt_q[pkt_q_idx].tcp_seq_num = tcp_seq_num; + pkt_q[pkt_q_idx].len = len; + pkt_q_idx++; + } else { + debug_cond(FILE_TEST, "File Connected HTTP Header %p\n", pkt); + hlen = pos - (char *)pkt + sizeof(http_eom) - 1; + pos = strstr((char *)pkt, linefeed); + if (pos > 0) + i = pos - (char *)pkt; + else + i = hlen; + tcp_print_buffer(pkt, i, i, -1, 0); + + file_state = FILE_TRANSFERRING; + + if (strstr((char *)pkt, http_ok) == 0) { + debug_cond(FILE_TEST, + "File Connected Bad Xfer\n"); + loop_state = NETLOOP_FAIL; + file_send(action, tcp_seq_num, tcp_ack_num, len); + } else { + debug_cond(FILE_TEST, "File Connctd pkt %p hlen %x\n", + pkt, hlen); + initial_data_seq_num = tcp_seq_num + hlen; + + pos = strstr((char *)pkt, content_len); + if (!pos) { + content_length = -1; + } else { + pos = pos + sizeof(content_len); + clen = strstr(pos + 3, linefeed) - 1; + j = clen - pos; + content_length = 0x0f & pos[j]; + i = 10; + for (j = (clen - pos - 1); j > 0; j--) { + content_length += (0x0f & pos[j]) * i; + i = i * 10; + } + debug_cond(FILE_TEST, "File Connected Len %d\n", + content_length); + } + + net_boot_file_size = 0; + + if (len > hlen) + store_block(pkt + hlen, 0, len - hlen); + debug_cond(FILE_TEST, "File Connected Pkt %p hlen %x\n", + pkt, hlen); + + for (i = 0; i < pkt_q_idx; i++) { + store_block(pkt_q[i].pkt, + pkt_q[i].tcp_seq_num - + initial_data_seq_num, + pkt_q[i].len); + debug_cond(FILE_TEST, "File Connctd pkt Q %p len %x\n", + pkt_q[i].pkt, pkt_q[i].len); + } + } + } + file_send(action, tcp_seq_num, tcp_ack_num, len); +} + + /* + * In the "application push" invocation the TCP header with all its + * information is the packet pointer, and the other variable + * "repurposed" (or misused) to carry sequence numbers and TCP state. + * + */ + +static void file_handler(uchar *pkt, unsigned int tcp_seq_num, + struct in_addr action_and_state, + unsigned int tcp_ack_num, unsigned int len) +{ + enum TCP_STATE file_tcp_state = tcp_get_tcp_state(); + u8 action = action_and_state.s_addr; + + net_set_timeout_handler(file_timeout, file_timeout_handler); + packets++; + + switch (file_state) { + case FILE_CLOSED: + debug_cond(FILE_TEST, "File Handler: Error!, State wrong\n"); + break; + case FILE_CONNECTING: + debug_cond(FILE_TEST, + "File Connecting In len=%x, Seq=%x, Ack=%x\n", + len, tcp_seq_num, tcp_ack_num); + if (len == 0) { + if (file_tcp_state == TCP_ESTABLISHED) { + debug_cond(FILE_TEST, + "File Cting, send, len=%x\n", len); + file_send(action, tcp_seq_num, tcp_ack_num, len); + } else { + tcp_print_buffer(pkt, len, len, -1, 0); + file_fail("File Handler Connected Fail\n", + tcp_seq_num, tcp_ack_num, action); + } + } + break; + case FILE_CONNECTED: + debug_cond(FILE_TEST, "File Connected seq=%x, len=%x\n", + tcp_seq_num, len); + if (len == 0) { + file_fail("File not found, no data returned\n", + tcp_seq_num, tcp_ack_num, action); + } else { + file_connected(pkt, tcp_seq_num, action_and_state, + tcp_ack_num, len); + } + break; + case FILE_TRANSFERRING: + debug_cond(FILE_TEST, + "File Transferring, seq=%x, ack=%x,len=%x\n", + tcp_seq_num, tcp_ack_num, len); + + if (store_block(pkt, + tcp_seq_num - initial_data_seq_num, len) != 0) { + file_fail("File store error\n", + tcp_seq_num, tcp_ack_num, action); + } else { + switch (file_tcp_state) { + case TCP_FIN_WAIT_2: + file_send(TCP_ACK, tcp_seq_num, tcp_ack_num, + len); + case TCP_SYN_SENT: + case TCP_CLOSING: + case TCP_FIN_WAIT_1: + case TCP_CLOSED: + net_set_state(NETLOOP_FAIL); + break; + case TCP_ESTABLISHED: + file_send(TCP_ACK, tcp_seq_num, tcp_ack_num, + len); + loop_state = NETLOOP_SUCCESS; + break; + case TCP_CLOSE_WAIT: /* End of file */ + file_state = FILE_TRANSFERRED; + file_send(action | TCP_ACK | TCP_FIN, + tcp_seq_num, tcp_ack_num, len); + break; + } + } + break; + case FILE_TRANSFERRED: + printf("Packets received %d, File Send Success\n", packets); + net_set_state(loop_state); + break; + } +} + +void wget_start(void) +{ + debug("%s\n", __func__); + + file_server_ip = net_server_ip; + file_path = (char *)file_path_buff; + + if (!file_path) { + net_set_state(NETLOOP_FAIL); + debug("*** ERROR: Fail allocate memory\n"); + return; + } + + if (net_boot_file_name[0] == '\0') { + sprintf(file_path, "/fileroot/%02X%02X%02X%02X.img", + net_ip.s_addr & 0xFF, + (net_ip.s_addr >> 8) & 0xFF, + (net_ip.s_addr >> 16) & 0xFF, + (net_ip.s_addr >> 24) & 0xFF); + + debug("*** Warning: no boot file name; using '%s'\n", + file_path); + } else { + char *p = net_boot_file_name; + + p = strchr(p, ':'); + + if (p) { + file_server_ip = string_to_ip(net_boot_file_name); + ++p; + strcpy(file_path, p); + } else { + strcpy(file_path, net_boot_file_name); + } + } + + debug_cond(FILE_TEST, "Using %s device\n", eth_get_name()); + debug_cond(FILE_TEST, "File transfer HTTP Server %pI4; our IP %pI4\n", + &file_server_ip, &net_ip); + + /* Check if we need to send across this subnet */ + if (net_gateway.s_addr && net_netmask.s_addr) { + struct in_addr our_net; + struct in_addr server_net; + + our_net.s_addr = net_ip.s_addr & net_netmask.s_addr; + server_net.s_addr = net_server_ip.s_addr & net_netmask.s_addr; + if (our_net.s_addr != server_net.s_addr) + debug("; sending through gateway %pI4", + &net_gateway); + } + debug_cond(FILE_TEST, "Filename '%s, %s'.\n", file_path, file_filename); + + if (net_boot_file_expected_size_in_blocks) { + debug(" Size is 0x%x Bytes = ", + net_boot_file_expected_size_in_blocks << 9); + print_size(net_boot_file_expected_size_in_blocks << 9, ""); + } + debug("\nLoad address: 0x%lx\nLoading: *\b", load_addr); + + net_set_timeout_handler(file_timeout, file_timeout_handler); + tcp_set_tcp_handler(file_handler); + + file_timeout_count = 0; + file_state = FILE_CLOSED; + + our_port = 4096 + (get_ticks() % 3072); + + /* zero out server ether in case the server ip has changed */ + memset(net_server_ethaddr, 0, 6); + + file_send(TCP_SYN, 0, 0, 0); +} diff --git a/net/wget.h b/net/wget.h new file mode 100644 index 0000000000..504943d9c8 --- /dev/null +++ b/net/wget.h @@ -0,0 +1,22 @@ +/* + * Duncan Hare Copyright 2017 + */ + +void wget_start(void); /* Begin wget */ + +enum FILE_STATE { + FILE_CLOSED, + FILE_CONNECTING, + FILE_CONNECTED, + FILE_TRANSFERRING, + FILE_TRANSFERRED}; + +#define K_LOAD 1 /* Load and run kernel */ + +#define FILE_TEST 0 /* Set to 1 for debug messges */ +#define SERVER_PORT 80 +#define FILE_RETRY_COUNT 30 +#define FILE_TIMEOUT 2000UL + +void file_fail(char *error_message, unsigned int tcp_seq_num, + unsigned int tcp_ack_num, u8 action);
Hi Duncan Hare,
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of DH@synoia.com Sent: Monday, January 29, 2018 9:24 AM To: DuncanCHare@yahoo.com Cc: u-boot@lists.denx.de; Joe Hershberger joe.hershberger@ni.com; Maxime Ripard maxime.ripard@free-electrons.com; Jagan Teki jagan@openedev.com Subject: [U-Boot] [PATCH] TCP and wget implementation. Patch V5, 3 of 3.
I guess you are manually adding the patch version and number. If so, I would suggest to use the following command, to allow git to prefix "PATCH v5" tag to the series and to prepare a cover letter.
git format-patch --subject-prefix="PATCH v5" -3 --cover-letter
While using git send-email command the following command can be used:
git send-email --to=u-boot@linux.freescale.net *.patch
Refer:- https://www.denx.de/wiki/U-Boot/Patches
Patman is a nice tool for all this.
http://git.denx.de/?p=u-boot.git;a=blob;f=tools/patman/README
regards Calvin
Calvin Johnson
DH@synoia.com
