[U-Boot] [PATCH v1] serial: ns16550: Add fractional divider for Intel MID
The change introduces three integer Kconfig options SERIAL_DIV_M multiplier SERIAL_DIV_N divisor SERIAL_DIV_PS prescaler divisor to set default configuration of prescaler.
The UART clock is calculated as
UART clock = XTAL * SERIAL_DIV_M / SERIAL_DIV_N
The baudrate is calculated as
baud rate = UART clock / SERIAL_DIV_PS
In the future the options can be used on any UART where fractional divider is implemented.
In particular, Intel MID platforms have additional registers in UART to configure a fractional divider.
Initialize fractional divider correctly for Intel Edison platform.
For backward compatibility we have to set initial DLAB value to 16 and speed to 115200 baud, where initial frequency is 29491200Hz, and XTAL frequency is 38.4MHz.
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- drivers/serial/Kconfig | 12 ++++++++++++ drivers/serial/ns16550.c | 21 +++++++++++++++++++++ 2 files changed, 33 insertions(+)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index b11f3ff89e..7860009a4b 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -268,6 +268,18 @@ config DEBUG_UART_SKIP_INIT Select this if the UART you want to use for debug output is already initialized by the time U-Boot starts its execution.
+config SERIAL_DIV_M + int + default 96 + +config SERIAL_DIV_N + int + default 125 + +config SERIAL_DIV_PS + int + default 16 + config ALTERA_JTAG_UART bool "Altera JTAG UART support" depends on DM_SERIAL diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 1f819d487b..34e39a2873 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -48,6 +48,22 @@ DECLARE_GLOBAL_DATA_PTR; #endif #endif
+#if defined(CONFIG_INTEL_MID) +#define UART_MUL 0x34 +#define UART_DIV 0x38 + +static void ns16550_writel(NS16550_t port, int offset, int value) +{ + struct ns16550_platdata *plat = port->plat; + unsigned char *addr; + + offset *= 1 << plat->reg_shift; + addr = (unsigned char *)plat->base + offset; + + writel(value, addr + plat->reg_offset); +} +#endif + #ifndef CONFIG_SYS_NS16550_IER #define CONFIG_SYS_NS16550_IER 0x00 #endif /* CONFIG_SYS_NS16550_IER */ @@ -181,6 +197,11 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) #endif serial_out(UART_MCRVAL, &com_port->mcr); serial_out(ns16550_getfcr(com_port), &com_port->fcr); +#if defined(CONFIG_INTEL_MID) + ns16550_writel(com_port, UART_MUL, CONFIG_SERIAL_DIV_M); + ns16550_writel(com_port, UART_DIV, CONFIG_SERIAL_DIV_N); + NS16550_setbrg(com_port, CONFIG_SERIAL_DIV_PS); +#endif if (baud_divisor != -1) NS16550_setbrg(com_port, baud_divisor); #if defined(CONFIG_OMAP) || \
Hi Andy,
On 21 February 2017 at 05:59, Andy Shevchenko andriy.shevchenko@linux.intel.com wrote:
This should somehow be encoded in the device tree so you don't need an #ifdef in the driver. One day this driver will be clean, and this is heading in the wrong direction unfortunately.
Can the values not be calculated from the clock? If not, then we need new device-tree properties.
Another approach would be to create your own driver which calls into ns16550 in some cases. For example serial_rockchip does this.
int
default 96
int
default 125
int
default 16
+} +#endif
2.11.0
REgards, Simon
Andy Shevchenko
