[U-Boot] [PATCH] mgcoge, mgsuvd: added support for the IVM EEprom.
The EEprom contains some Manufacturerinformation, which are read from u-boot at boot time, and saved in same Environmentvars.
Signed-off-by: Heiko Schocher hs@denx.de --- board/keymile/common/common.c | 285 +++++++++++++++++++++++++++++++++++++++++ include/configs/mgcoge.h | 5 + include/configs/mgsuvd.h | 5 + lib_ppc/board.c | 6 + 4 files changed, 301 insertions(+), 0 deletions(-)
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index a6ed379..25c5900 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -38,6 +38,291 @@ extern int i2c_mgsuvd_read (void); #endif
+int ivm_calc_crc (unsigned char *buf, int len) +{ + const unsigned short cCrc16Table[16] = { + 0x0000, 0xCC01, 0xD801, 0x1400, + 0xF001, 0x3C00, 0x2800, 0xE401, + 0xA001, 0x6C00, 0x7800, 0xB401, + 0x5000, 0x9C01, 0x8801, 0x4400}; + + unsigned short crc = 0; /* final result */ + unsigned short r1 = 0; /* temp */ + unsigned char byte = 0; /* input buffer */ + int i; + + /* calculate CRC from array data */ + for (i = 0; i < len; i++) { + byte = buf[i]; + + /* lower 4 bits */ + r1 = cCrc16Table[crc & 0xF]; + crc = ((crc) >> 4) & 0x0FFF; + crc = crc ^ r1 ^ cCrc16Table[byte & 0xF]; + + /* upper 4 bits */ + r1 = cCrc16Table[crc & 0xF]; + crc = (crc >> 4) & 0x0FFF; + crc = crc ^ r1 ^ cCrc16Table[(byte >> 4) & 0xF]; + } + return crc; +} + + +static int ivm_get_value (unsigned char *buf, int len, char *name, int off, int check) +{ + unsigned short val; + unsigned char valbuf[30]; + + if ((buf[off + 0] != buf[off + 2]) && (buf[off + 2] != buf[off + 4])) { + printf ("%s Error corrupted %s\n", __FUNCTION__, name); + val = -1; + } else { + val = buf[off + 0] + (buf[off + 1] << 8); + if ((val == 0) && (check == 1)) + val = -1; + } + sprintf ((char *)valbuf, "%x", val); + setenv (name, (char *)valbuf); + return val; +} + +#define BTChar unsigned char + +#define INVENTORYBLOCKSIZE 0x100 +#define INVENTORYDATAADDRESS 0x21 +#define INVENTORYDATASIZE (INVENTORYBLOCKSIZE - INVENTORYDATAADDRESS - 3) +typedef enum { + eSymbolShortText = 0, /* Symbol;ShortText */ + eManufId = 1, /* ManufacturerId */ + eManufSerialNumber = 2, /* ManufacturerSerialNumber */ + eManufPartNumber = 3, /* ManufacturerPartNumber */ + eManufBuildState = 4, /* ManufacturerBuildState */ + eSuplierPartNumber = 5, /* SuplierPartNumber */ + eDeliveryDate = 6, /* DeliveryDate */ + eSupplierBuildState = 7, /* SupplierBuildState */ + eCustomerId = 8, /* CustomerId */ + eCustomerProdId = 9, /* CustomerProdId */ + eChangeHistory = 10, /* ChangeHistory (not used) */ + eSymbolOnly +} InventoryData; + +static char toAscii(char c) +{ + return (c<' ' || c>'~') ? '.' : c; +} + +static int ivm_findInventoryString (InventoryData aType, BTChar* const aString, + unsigned long maxLength, unsigned char *buf) +{ + int xcode = 0; + BTChar cr = '\r'; + /* Semikolon char */ + BTChar sc = ';'; + /* Number of CR found */ + unsigned long crFound = 0; + /* Current address */ + unsigned long address = INVENTORYDATAADDRESS; + /* String length */ + unsigned long strSize = 0; + /* Number of CR to skip */ + unsigned long nbrOfCR = aType; + /* Semicolon to end */ + int endWithSemikolon = 0; + + /* initialise string */ + memset(aString, '\0', maxLength); + + switch (aType) + { + case eSymbolOnly: + nbrOfCR = 0; + endWithSemikolon = 1; + break; + default: + nbrOfCR = aType; + endWithSemikolon = 0; + } + + /* Look for the requested number of CR. */ + while ((crFound != nbrOfCR) && (address < INVENTORYDATASIZE)) + { + if ((buf[address] == cr)) { + crFound++; + } + address++; + } + + /* the expected number of CR was found until the end of the IVM + * content --> fill string */ + if (address < INVENTORYDATASIZE) + { + /* Copy the IVM string in the corresponding string */ + for (; (buf[address] != cr) && /* not cr found */ + ((buf[address] != sc) || (!endWithSemikolon)) && /* not semikolon found */ + (strSize < (maxLength-1) && + (address < INVENTORYDATASIZE)); address++) + { + strSize += sprintf((char *)aString + strSize, "%c", toAscii(buf[address])); + } + + /* copy phase is done: check if everything is ok. If not, the inventory + * data is most probably corrupted: tell the world there is a problem! */ + if (address == INVENTORYDATASIZE) + { + xcode = -1; + printf ("Error end of string not found\n"); + } else if ((strSize >= (maxLength-1)) && (buf[address] != cr)) { + xcode = -1; + printf ("string too long till next CR\n"); + } + } else { + /* some CR are missing... the inventory data is most probably corrupted */ + xcode = -1; + printf ("not enough cr found\n"); + } + return xcode; +} + +#define GET_STRING(name, which, len) \ + if (ivm_findInventoryString (which, valbuf, len, buf) == 0) { \ + setenv (name, (char *)valbuf); \ + } + +static int ivm_check_crc (unsigned char *buf, int block) +{ + unsigned long crc; + unsigned long crceeprom; + + crc = ivm_calc_crc (buf, CFG_IVM_EEPROM_PAGE_LEN - 2); + crceeprom = (buf[CFG_IVM_EEPROM_PAGE_LEN - 1] + \ + buf[CFG_IVM_EEPROM_PAGE_LEN - 2] * 256); + if (crc != crceeprom) { + printf ("Error CRC Block: %d EEprom: calculated: %lx EEprom: %lx\n", + block, crc, crceeprom); + return -1; + } + return 0; +} + +static int ivm_analyse_block2 (unsigned char *buf, int len) +{ + unsigned char valbuf[CFG_IVM_EEPROM_PAGE_LEN]; + unsigned long nbrsAdrs; + + /* IVM_MacAddress */ + sprintf ((char *)valbuf, "%02X:%02X:%02X:%02X:%02X:%02X", + buf[1], + buf[2], + buf[3], + buf[4], + buf[5], + buf[6]); + setenv ("IVM_MacAddress", (char *)valbuf); + if (getenv ("ethaddr") == NULL) + setenv ((char *)"ethaddr", (char *)valbuf); + /* IVM_MacCount */ + nbrsAdrs = (buf[10] << 24) + + (buf[11] << 16) + + (buf[12] << 8) + + buf[13]; + if (nbrsAdrs == 0xffffffff) + nbrsAdrs = 1; + sprintf ((char *)valbuf, "%lx", nbrsAdrs); + setenv ("IVM_MacCount", (char *)valbuf); + return 0; +} + +int ivm_analyse_eeprom (unsigned char *buf, int len) +{ + unsigned short val; + unsigned char valbuf[CFG_IVM_EEPROM_PAGE_LEN]; + unsigned char *tmp; + + /* used Code from ivm/src/devsrv_baseproductdata.cpp */ + if (ivm_check_crc (buf, 0) != 0) + return -1; + + ivm_get_value (buf, CFG_IVM_EEPROM_PAGE_LEN, "IVM_BoardId", 0, 1); + val = ivm_get_value (buf, CFG_IVM_EEPROM_PAGE_LEN, "IVM_HWKey", 6, 1); + if (val != 0xffff) { + sprintf ((char *)valbuf, "%x", ((val /100) % 10)); + setenv ("IVM_HWVariant", (char *)valbuf); + sprintf ((char *)valbuf, "%x", (val % 100)); + setenv ("IVM_HWVersion", (char *)valbuf); + } + ivm_get_value (buf, CFG_IVM_EEPROM_PAGE_LEN, "IVM_Functions", 12, 0); + + GET_STRING("IVM_Symbol", eSymbolOnly, 8) + GET_STRING("IVM_DeviceName", eSymbolShortText, 64) + tmp = (unsigned char *) getenv("IVM_DeviceName"); + if (tmp) { + int len = strlen ((char *)tmp); + int i = 0; + + while (i < len) { + if (tmp[i] == ';') { + setenv ("IVM_ShortText", (char *)&tmp[i + 1]); + break; + } + i++; + } + if (i >= len) + setenv ("IVM_ShortText", NULL); + } else { + setenv ("IVM_ShortText", NULL); + } + GET_STRING("IVM_ManufacturerID", eManufId, 32) + GET_STRING("IVM_ManufacturerSerialNumber", eManufSerialNumber, 20) + GET_STRING("IVM_ManufacturerPartNumber", eManufPartNumber, 32) + GET_STRING("IVM_ManufacturerBuildState", eManufBuildState, 32) + GET_STRING("IVM_SupplierPartNumber", eSuplierPartNumber, 32) + GET_STRING("IVM_DelieveryDate", eDeliveryDate, 32) + GET_STRING("IVM_SupplierBuildState", eSupplierBuildState, 32) + GET_STRING("IVM_CustomerID", eCustomerId, 32) + GET_STRING("IVM_CustomerProductID", eCustomerProdId, 32) + + if (ivm_check_crc (&buf[CFG_IVM_EEPROM_PAGE_LEN * 2], 2) != 0) + return -2; + ivm_analyse_block2 (&buf[CFG_IVM_EEPROM_PAGE_LEN * 2], CFG_IVM_EEPROM_PAGE_LEN); + + return 0; +} + +int ivm_read_eeprom(void) +{ + I2C_MUX_DEVICE *dev = NULL; + uchar i2c_buffer[CFG_IVM_EEPROM_MAX_LEN]; + uchar *buf; + unsigned dev_addr = CFG_IVM_EEPROM_ADR; + + /* First init the Bus, select the Bus */ +#if defined(CFG_I2C_IVM_BUS) + dev = i2c_mux_ident_muxstring ((uchar *)CFG_I2C_IVM_BUS); +#else + buf = (unsigned char *) getenv ("EEprom_ivm"); + if (buf != NULL) + dev = i2c_mux_ident_muxstring (buf); +#endif + if (dev == NULL) { + printf ("Error couldnt add Bus for IVM\n"); + return -1; + } + i2c_set_bus_num (dev->busid); + + buf = (unsigned char *) getenv ("EEprom_ivm_addr"); + if (buf != NULL) + dev_addr = simple_strtoul ((char *)buf, NULL, 16); + + if (eeprom_read (dev_addr, 0, i2c_buffer, CFG_IVM_EEPROM_MAX_LEN) != 0) { + printf ("Error reading EEprom\n"); + return -2; + } + + return ivm_analyse_eeprom (i2c_buffer, CFG_IVM_EEPROM_MAX_LEN); + +} + #if defined(CFG_I2C_INIT_BOARD) #define DELAY_ABORT_SEQ 62 #define DELAY_HALF_PERIOD (500 / (CFG_I2C_SPEED / 1000)) diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index 6564c15..b32eb80 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -212,6 +212,11 @@ #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
+/* Support the IVM EEprom */ +#define CFG_IVM_EEPROM_ADR 0x50 +#define CFG_IVM_EEPROM_MAX_LEN 0x400 +#define CFG_IVM_EEPROM_PAGE_LEN 0x100 + /* I2C SYSMON (LM75, AD7414 is almost compatible) */ #define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ #define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ diff --git a/include/configs/mgsuvd.h b/include/configs/mgsuvd.h index 79954fe..36c7f26 100644 --- a/include/configs/mgsuvd.h +++ b/include/configs/mgsuvd.h @@ -382,6 +382,11 @@ #define CFG_EEPROM_PAGE_WRITE_BITS 3 #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10
+/* Support the IVM EEprom */ +#define CFG_IVM_EEPROM_ADR 0x50 +#define CFG_IVM_EEPROM_MAX_LEN 0x400 +#define CFG_IVM_EEPROM_PAGE_LEN 0x100 + /* I2C SYSMON (LM75, AD7414 is almost compatible) */ #define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ #define CONFIG_DTT_SENSORS {0, 2, 4, 6} /* Sensor addresses */ diff --git a/lib_ppc/board.c b/lib_ppc/board.c index c02ac62..9b5ff41 100644 --- a/lib_ppc/board.c +++ b/lib_ppc/board.c @@ -79,6 +79,9 @@ extern int update_flash_size (int flash_size); #endif
+#if defined(CONFIG_MGCOGE) || defined(CONFIG_MGSUVD) +extern int ivm_read_eeprom(void); +#endif #if defined(CONFIG_SC3) extern void sc3_read_eeprom(void); #endif @@ -869,6 +872,9 @@ void board_init_r (gd_t *id, ulong dest_addr) #endif /* CONFIG_405GP, CONFIG_405EP */ #endif /* CFG_EXTBDINFO */
+#if defined(CONFIG_MGCOGE) || defined(CONFIG_MGSUVD) + ivm_read_eeprom(); +#endif #if defined(CONFIG_SC3) sc3_read_eeprom(); #endif
Dear Heiko Schocher,
- const unsigned short cCrc16Table[16] = {
If we need support for CRC16, it should be factored out and move to lib_generic.
Please get rid of this #define.
- return (c<' ' || c>'~') ? '.' : c;
Mixed case identifiers like "toAscii" are deprecated.
Also, the name is misleading as it can be easily confised with the standard function toascii() which implements a different function.
- int xcode = 0;
- BTChar cr = '\r';
- /* Semikolon char */
- BTChar sc = ';';
Come on. Do we really need variables for these? And do you think that "sc" is easier to read or understand than ';'?
Please drop these.
- /* Number of CR found */
- unsigned long crFound = 0;
- /* Current address */
- unsigned long address = INVENTORYDATAADDRESS;
- /* String length */
- unsigned long strSize = 0;
- /* Number of CR to skip */
- unsigned long nbrOfCR = aType;
- /* Semicolon to end */
- int endWithSemikolon = 0;
This is difficult to read. Please put the comments in the same line as the variable declarations, and get rid of these mixed case identifiers.
- switch (aType)
Incorrect brace style. See also rest of file.
Maximum line length exceeded.
- /* IVM_MacAddress */
- sprintf ((char *)valbuf, "%02X:%02X:%02X:%02X:%02X:%02X",
buf[1],
buf[2],
buf[3],
buf[4],
buf[5],
buf[6]);
- setenv ("IVM_MacAddress", (char *)valbuf);
Do we really need this? We already have "ethaddr" ?
- if (getenv ("ethaddr") == NULL)
Oops? You are even aware of this.
Please avoid duplicate data.
...analyze...
- unsigned short val;
- unsigned char valbuf[CFG_IVM_EEPROM_PAGE_LEN];
- unsigned char *tmp;
- /* used Code from ivm/src/devsrv_baseproductdata.cpp */
What is ivm/src/devsrv_baseproductdata.cpp ?
- ivm_get_value (buf, CFG_IVM_EEPROM_PAGE_LEN, "IVM_BoardId", 0, 1);
- val = ivm_get_value (buf, CFG_IVM_EEPROM_PAGE_LEN, "IVM_HWKey", 6, 1);
- if (val != 0xffff) {
You're really polluting the environment here.
Is this reasonable?
Hello Wolfgang,
OK.
Hmm... I got a source from the Boardmanufacturer, and I wanted to stay in sync with this code as close as possible, so this looked as the best way for me ... this affects also the most comments from you. What to do with such code in common?
buf[1],
buf[2],
buf[3],
buf[4],
buf[5],
buf[6]);
We dont need this, but the manufacturer of the Hardware wants explicitly such a Environmentvariable.
Yes.
Hmm... the boardmanufacturer wants explicitly a "IVM_" before all of "his" variables from the EEprom.
Thats the source from the boardmanufacturer ...
I know.
Is this reasonable?
Hmm... I think so, because the manufacturer wants all of this vars, and if I am right, you or Detlev arranged it.
bye, Heiko
[snip]
- int xcode = 0;
- BTChar cr = '\r';
- BTChar sc = ';';
Please drop these.
Nitpick: s/kolon/colon/ (several places). The mixture of English and German is jarring.
Best regards, gvb
Does not apply:
Applying mgcoge, mgsuvd: added support for the IVM EEprom. .dotest/patch:195: trailing whitespace. buf[6]); .dotest/patch:296: trailing whitespace.
error: board/keymile/common/common.c: does not exist in index fatal: sha1 information is lacking or useless (board/keymile/common/common.c). Repository lacks necessary blobs to fall back on 3-way merge. Cannot fall back to three-way merge. Patch failed at 0007.
Please rebase and resubmit.
Heiko Schocher
Jerry Van Baren
