[PATCH v5 18/20] mips: mtmips: add SPL support
This patch adds SPL support for mtmips platform. The lowlevel architecture is split into SPL and the rest parts are built into a memory loadable u-boot image. Optional SPL_DM and OF_CONTROL are also supported.
The increment of size is very small (< 10 KiB) if SPL_DM and OF_CONTROL are not enabled and the memory bootable u-boot (u-boot.img) is generated automatically so there is not need to add a separate config for it.
A lzma compressed payload (u-boot-lzma.img) is also generated and it will be combined with u-boot-spl.bin to form the unified ROM bootable binary u-boot-mtmips.bin.
A spl loader is added to support uncompress the payload.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v3: generate output file using u-boot-with-spl.bin --- Makefile | 6 +++ arch/mips/Kconfig | 3 ++ arch/mips/dts/mt7628-u-boot.dtsi | 56 +++++++++++++++++++++ arch/mips/dts/mt7628a.dtsi | 2 +- arch/mips/mach-mtmips/Kconfig | 26 ++++++++++ arch/mips/mach-mtmips/Makefile | 1 + arch/mips/mach-mtmips/include/mach/serial.h | 13 +++++ arch/mips/mach-mtmips/mt7628/Makefile | 1 + arch/mips/mach-mtmips/mt7628/serial.c | 34 +++++++++++++ arch/mips/mach-mtmips/spl.c | 44 ++++++++++++++++ 10 files changed, 185 insertions(+), 1 deletion(-) create mode 100644 arch/mips/dts/mt7628-u-boot.dtsi create mode 100644 arch/mips/mach-mtmips/include/mach/serial.h create mode 100644 arch/mips/mach-mtmips/mt7628/serial.c create mode 100644 arch/mips/mach-mtmips/spl.c
diff --git a/Makefile b/Makefile index 8aed5bbca4..28abd72724 100644 --- a/Makefile +++ b/Makefile @@ -898,6 +898,12 @@ endif
ALL-$(CONFIG_ARCH_MEDIATEK) += u-boot-mtk.bin
+ifeq ($(CONFIG_SPL),y) +ALL-$(CONFIG_ARCH_MTMIPS) += u-boot-with-spl.bin +else +ALL-$(CONFIG_ARCH_MTMIPS) += u-boot.bin +endif + # Add optional build target if defined in board/cpu/soc headers ifneq ($(CONFIG_BUILD_TARGET),) ALL-y += $(CONFIG_BUILD_TARGET:"%"=%) diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 7b9d0072eb..4c1eea1ccc 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -98,6 +98,9 @@ config ARCH_MTMIPS select SUPPORTS_CPU_MIPS32_R2 select SUPPORTS_LITTLE_ENDIAN select SYSRESET + select SUPPORT_SPL + select SPL_LZMA + select BINMAN
config ARCH_JZ47XX bool "Support Ingenic JZ47xx" diff --git a/arch/mips/dts/mt7628-u-boot.dtsi b/arch/mips/dts/mt7628-u-boot.dtsi new file mode 100644 index 0000000000..9149187762 --- /dev/null +++ b/arch/mips/dts/mt7628-u-boot.dtsi @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +/ { + binman { + filename = "u-boot-mips.bin"; + pad-byte = <0xff>; + +#ifdef CONFIG_SPL + u-boot-spl { + }; + + u-boot-lzma-img { + }; +#else + u-boot { + }; +#endif + }; +}; + +&palmbus { + u-boot,dm-pre-reloc; +}; + +&reboot { + u-boot,dm-pre-reloc; +}; + +&clkctrl { + u-boot,dm-pre-reloc; +}; + +&rstctrl { + u-boot,dm-pre-reloc; +}; + +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&uart1 { + u-boot,dm-pre-reloc; +}; + +&uart2 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 2200135a77..6baa63add3 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -33,7 +33,7 @@ #clock-cells = <0>; };
- palmbus@10000000 { + palmbus: palmbus@10000000 { compatible = "palmbus", "simple-bus"; reg = <0x10000000 0x200000>; ranges = <0x0 0x10000000 0x1FFFFF>; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 3f25de8b85..81cec53e72 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -20,8 +20,18 @@ config SYS_ICACHE_LINE_SIZE default 32
config SYS_TEXT_BASE + default 0x9c000000 if !SPL + default 0x80200000 if SPL + +config SPL_TEXT_BASE default 0x9c000000
+config SPL_LOADER_SUPPORT + default y + +config SPL_PAYLOAD + default "u-boot-lzma.img" + choice prompt "MediaTek MIPS SoC select"
@@ -34,6 +44,14 @@ config SOC_MT7628 select PINCTRL_MT7628 select MTK_SERIAL select SYSRESET_RESETCTL + select SPL_SEPARATE_BSS if SPL + select SPL_INIT_STACK_WITHOUT_MALLOC_F if SPL + select SPL_OF_CONTROL if SPL_DM + select SPL_SIMPLE_BUS if SPL_DM + select SPL_DM_SERIAL if SPL_DM + select SPL_CLK if SPL_DM && SPL_SERIAL_SUPPORT + select SPL_SYSRESET if SPL_DM + select SPL_OF_LIBFDT if SPL_OF_CONTROL help This supports MediaTek MT7628/MT7688.
@@ -88,6 +106,14 @@ endchoice config SUPPORTS_BOOT_RAM bool
+config SPL_UART2_SPIS_PINMUX + bool "Use alternative pinmux for UART2 in SPL stage" + depends on SPL_SERIAL_SUPPORT + default n + help + Select this if the UART2 of your board is connected to GPIO 16/17 + (shared with SPIS) rather than the usual GPIO 20/21. + source "board/gardena/smart-gateway-mt7688/Kconfig" source "board/seeed/linkit-smart-7688/Kconfig"
diff --git a/arch/mips/mach-mtmips/Makefile b/arch/mips/mach-mtmips/Makefile index 72f0369030..a7e6a66304 100644 --- a/arch/mips/mach-mtmips/Makefile +++ b/arch/mips/mach-mtmips/Makefile @@ -3,5 +3,6 @@ obj-y += cpu.o obj-y += ddr_init.o obj-y += ddr_cal.o +obj-$(CONFIG_SPL_BUILD) += spl.o
obj-$(CONFIG_SOC_MT7628) += mt7628/ diff --git a/arch/mips/mach-mtmips/include/mach/serial.h b/arch/mips/mach-mtmips/include/mach/serial.h new file mode 100644 index 0000000000..bfa246b428 --- /dev/null +++ b/arch/mips/mach-mtmips/include/mach/serial.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _MTMIPS_SERIAL_H_ +#define _MTMIPS_SERIAL_H_ + +void mtmips_spl_serial_init(void); + +#endif /* _MTMIPS_SERIAL_H_ */ diff --git a/arch/mips/mach-mtmips/mt7628/Makefile b/arch/mips/mach-mtmips/mt7628/Makefile index db62e90d77..7e139d5adf 100644 --- a/arch/mips/mach-mtmips/mt7628/Makefile +++ b/arch/mips/mach-mtmips/mt7628/Makefile @@ -3,3 +3,4 @@ obj-y += lowlevel_init.o obj-y += init.o obj-y += ddr.o +obj-$(CONFIG_SPL_BUILD) += serial.o diff --git a/arch/mips/mach-mtmips/mt7628/serial.c b/arch/mips/mach-mtmips/mt7628/serial.c new file mode 100644 index 0000000000..a7d324792d --- /dev/null +++ b/arch/mips/mach-mtmips/mt7628/serial.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <asm/io.h> +#include "mt7628.h" + +void mtmips_spl_serial_init(void) +{ +#ifdef CONFIG_SPL_SERIAL_SUPPORT + void __iomem *base = ioremap_nocache(SYSCTL_BASE, SYSCTL_SIZE); + +#if CONFIG_CONS_INDEX == 1 + clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART0_MODE_M); +#elif CONFIG_CONS_INDEX == 2 + clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART1_MODE_M); +#elif CONFIG_CONS_INDEX == 3 + setbits_32(base + SYSCTL_AGPIO_CFG_REG, EPHY_GPIO_AIO_EN_M); +#ifdef CONFIG_SPL_UART2_SPIS_PINMUX + setbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M); + clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M, + 1 << UART2_MODE_S); +#else + clrbits_32(base + SYSCTL_GPIO_MODE1_REG, UART2_MODE_M); + clrsetbits_32(base + SYSCTL_GPIO_MODE1_REG, SPIS_MODE_M, + 1 << SPIS_MODE_S); +#endif /* CONFIG_SPL_UART2_SPIS_PINMUX */ +#endif /* CONFIG_CONS_INDEX */ +#endif /* CONFIG_SPL_SERIAL_SUPPORT */ +} diff --git a/arch/mips/mach-mtmips/spl.c b/arch/mips/mach-mtmips/spl.c new file mode 100644 index 0000000000..2a24af70c3 --- /dev/null +++ b/arch/mips/mach-mtmips/spl.c @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2020 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <fdt.h> +#include <spl.h> +#include <asm/sections.h> +#include <linux/sizes.h> +#include <mach/serial.h> + +void __noreturn board_init_f(ulong dummy) +{ + spl_init(); + +#ifdef CONFIG_SPL_SERIAL_SUPPORT + /* + * mtmips_spl_serial_init() is useful if debug uart is enabled, + * or DM based serial is not enabled. + */ + mtmips_spl_serial_init(); + preloader_console_init(); +#endif + + board_init_r(NULL, 0); +} + +void board_boot_order(u32 *spl_boot_list) +{ + spl_boot_list[0] = BOOT_DEVICE_NOR; +} + +unsigned long spl_nor_get_uboot_base(void) +{ + void *uboot_base = __image_copy_end; + + if (fdt_magic(uboot_base) == FDT_MAGIC) + return (unsigned long)uboot_base + fdt_totalsize(uboot_base); + + return (unsigned long)uboot_base; +}
Weijie Gao
