[U-Boot] Pull request: u-boot-rockchip/master
Tom,
With the new merge window open, I’d like to sync some of changes accumulated for Rockchip. Please pull into u-boot/master. Thanks!
Thanks, Phil.
The following changes since commit d85ca029f257b53a96da6c2fb421e78a003a9943:
Prepare v2017.07 (2017-07-10 13:07:38 -0400)
git://git.denx.de/u-boot-rockchip.git master
for you to fetch changes up to 2454b719fb874120e06e4aa64bfb9450d091e56c:
rockchip: rk3288: Add pinctrl support for the gmac ethernet interface (2017-07-11 15:23:38 +0200)
---------------------------------------------------------------- Kever Yang (28): rockchip: rk3328: correct mem_region rockchip: add sdram_common for common functions rockchip: use common sdram function rockchip: rk3328: add sdram driver in U-Boot rockchip: rk3368: add sdram driver for U-Boot rockchip: dts: rk3328: add dmc node rockchip: dts: rk3368: add dmc node rockchip: correct the bank0 ram size rockchip: rv1108: disable CONFIG_RAM before we have driver rockchip: mkimage: add support for rk322x soc rockchip: rk322x: add clock driver rockchip: rk322x: add pinctrl driver rockchip: rk322x: add dts file rockchip: rk322x: add basic soc support rockchip: rk322x: add sysreset driver rockchip: add evb_rk3229 board rockchip: rk3036: dtsi use max-frequency for mmc node rockchip: rk3288: dtsi use max-frequency for mmc node rockchip: rk3328: dtsi use max-frequency for mmc node rockchip: dwmmc: use max-frequency when OF_PLATDATA enabled rockchip: firefly-rk3399: dts: enable sdmmc device rockchip: firefly-rk3399: enable dwmmc driver for the board Revert "mmc: dw_mmc: rockchip: select proper card clock" rockchip: rk3036 remove CONFIG_RAM from defconfig rockchip: rk3036: sync os_reg2 define with other soc rockchip: pinctrl: rk3328: use gpio instead of sdmmc-pwren rockchip: dts: rk3328-evb: add sdmmc-pwren regulator rockchip: evb-rk3328: enable boot on regulator
Meng Dongyang (8): usb: Kconfig: config USB_XHCI_ROCKCHIP depends on DM_REGULATOR and DM_USB usb: host: xhci-rockchip: use fixed regulator to control vbus rockchip: dts: rk3328: add fixed regulator node for xhci rockchip: dts: rk3328: add fixed regulator node for xhci usb: dwc2: use dev_read_bool() instead of fdt_getprop() rockchip: rk3328: board: add support of dwc2 gadget rockchip: dts: rk3328: support and enable dwc2 rockchip: dts: rk3399: control vbus of typec by fixed regulator
Philipp Tomsich (8): rockchip: pinctrl: dm: convert fdt_get to dev_read rockchip: spi: dm: convert fdt_get to dev_read rockchip: xhci: dm: convert fdt_get to dev_read rockchip: mmc: dm: convert fdt_get to dev_read rockchip: net: dm: convert fdt_get to dev_read rockchip: ns16550: dm: convert fdt_get to dev_read rockchip: dm: convert fdt_get to dev_read usb: Kconfig: migrate USB_DWC2 to Kconfig
Sjoerd Simons (1): rockchip: rk3288: Add pinctrl support for the gmac ethernet interface
Wadim Egorov (4): power: regulator: rk8xx: Build get_ldo_reg only for SPL power: regulator: rk8xx: Allow input current/charger shutdown configuration rockchip: Add basic support for phyCORE-RK3288 SoM based carrier board doc: rockchip: Add phyCORE-RK3288 RDK to board list
eric.gao@rock-chips.com (3): rockchip: pwm: fix the register layout for the PWM controller rockchip: video: mipi: Modify variable type for arm32 compatibility rockchip: video: mipi: Modify format type for debug message
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3036.dtsi | 2 +- arch/arm/dts/rk3229-evb.dts | 77 ++++++++++++ arch/arm/dts/rk322x.dtsi | 710 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/rk3288-phycore-rdk.dts | 294 ++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/rk3288-phycore-som.dtsi | 506 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/rk3288.dtsi | 8 +- arch/arm/dts/rk3328-evb.dts | 33 ++++- arch/arm/dts/rk3328.dtsi | 25 +++- arch/arm/dts/rk3368.dtsi | 7 ++ arch/arm/dts/rk3399-evb.dts | 16 ++- arch/arm/dts/rk3399-firefly.dts | 7 ++ arch/arm/include/asm/arch-rockchip/clock.h | 1 + arch/arm/include/asm/arch-rockchip/cru_rk322x.h | 215 ++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-rockchip/ddr_rk3288.h | 48 -------- arch/arm/include/asm/arch-rockchip/grf_rk322x.h | 519 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-rockchip/grf_rk3288.h | 178 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-rockchip/grf_rk3368.h | 4 +- arch/arm/include/asm/arch-rockchip/pwm.h | 2 +- arch/arm/include/asm/arch-rockchip/sdram_common.h | 58 +++++++++ arch/arm/mach-rockchip/Kconfig | 14 +++ arch/arm/mach-rockchip/Makefile | 6 + arch/arm/mach-rockchip/rk3036-board.c | 6 + arch/arm/mach-rockchip/rk3036/sdram_rk3036.c | 5 +- arch/arm/mach-rockchip/rk3188-board.c | 22 ---- arch/arm/mach-rockchip/rk3188/sdram_rk3188.c | 82 +++---------- arch/arm/mach-rockchip/rk322x-board-spl.c | 77 ++++++++++++ arch/arm/mach-rockchip/rk322x-board.c | 136 ++++++++++++++++++++ arch/arm/mach-rockchip/rk322x/Kconfig | 18 +++ arch/arm/mach-rockchip/rk322x/Makefile | 9 ++ arch/arm/mach-rockchip/rk322x/clk_rk322x.c | 32 +++++ arch/arm/mach-rockchip/rk322x/syscon_rk322x.c | 22 ++++ arch/arm/mach-rockchip/rk3288-board-spl.c | 40 ++++++ arch/arm/mach-rockchip/rk3288-board.c | 22 ---- arch/arm/mach-rockchip/rk3288/Kconfig | 10 ++ arch/arm/mach-rockchip/rk3288/sdram_rk3288.c | 86 +++---------- arch/arm/mach-rockchip/rk3328/Makefile | 1 + arch/arm/mach-rockchip/rk3328/rk3328.c | 21 +++- arch/arm/mach-rockchip/rk3328/sdram_rk3328.c | 60 +++++++++ arch/arm/mach-rockchip/rk3368/Makefile | 1 + arch/arm/mach-rockchip/rk3368/rk3368.c | 13 ++ arch/arm/mach-rockchip/rk3368/sdram_rk3368.c | 60 +++++++++ arch/arm/mach-rockchip/rk3399/rk3399.c | 13 ++ arch/arm/mach-rockchip/rk3399/sdram_rk3399.c | 102 ++------------- arch/arm/mach-rockchip/sdram_common.c | 83 +++++++++++++ board/geekbuying/geekbox/geekbox.c | 14 --- board/phytec/phycore_rk3288/Kconfig | 15 +++ board/phytec/phycore_rk3288/MAINTAINERS | 6 + board/phytec/phycore_rk3288/Makefile | 8 ++ board/phytec/phycore_rk3288/phycore-rk3288.c | 8 ++ board/rockchip/evb_px5/evb-px5.c | 16 --- board/rockchip/evb_rk3229/Kconfig | 15 +++ board/rockchip/evb_rk3229/MAINTAINERS | 6 + board/rockchip/evb_rk3229/Makefile | 7 ++ board/rockchip/evb_rk3229/evb_rk3229.c | 12 ++ board/rockchip/evb_rk3328/evb-rk3328.c | 58 +++++++-- board/rockchip/evb_rk3399/evb-rk3399.c | 31 ----- board/rockchip/sheep_rk3368/sheep_rk3368.c | 15 --- board/theobroma-systems/puma_rk3399/puma-rk3399.c | 31 ----- configs/evb-rk3036_defconfig | 1 - configs/evb-rk3229_defconfig | 44 +++++++ configs/evb-rk3328_defconfig | 20 ++- configs/evb-rv1108_defconfig | 1 - configs/fennec-rk3288_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/firefly-rk3399_defconfig | 2 +- configs/hikey_defconfig | 1 + configs/kylin-rk3036_defconfig | 2 +- configs/miqi-rk3288_defconfig | 1 + configs/phycore-rk3288_defconfig | 70 +++++++++++ configs/popmetal-rk3288_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + configs/tinker-rk3288_defconfig | 1 + doc/README.rockchip | 3 +- drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rk322x.c | 413 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/mmc/rockchip_dw_mmc.c | 25 ++-- drivers/mmc/rockchip_sdhci.c | 3 +- drivers/net/designware.c | 7 +- drivers/net/gmac_rockchip.c | 10 +- drivers/pinctrl/Kconfig | 10 ++ drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl_rk3036.c | 3 +- drivers/pinctrl/rockchip/pinctrl_rk3188.c | 3 +- drivers/pinctrl/rockchip/pinctrl_rk322x.c | 294 ++++++++++++++++++++++++++++++++++++++++++++ drivers/pinctrl/rockchip/pinctrl_rk3288.c | 121 +++++++++++++++++- drivers/pinctrl/rockchip/pinctrl_rk3328.c | 9 +- drivers/pinctrl/rockchip/pinctrl_rk3399.c | 3 +- drivers/pinctrl/rockchip/pinctrl_rv1108.c | 3 +- drivers/power/regulator/rk8xx.c | 74 ++++++++--- drivers/serial/ns16550.c | 11 +- drivers/spi/rk_spi.c | 15 ++- drivers/sysreset/sysreset_rk322x.c | 45 +++++++ drivers/usb/host/Kconfig | 12 ++ drivers/usb/host/dwc2.c | 16 +-- drivers/usb/host/xhci-rockchip.c | 49 ++++---- drivers/video/rockchip/rk_mipi.c | 22 ++-- include/configs/evb_rk3229.h | 60 +++++++++ include/configs/hikey.h | 1 - include/configs/phycore_rk3288.h | 23 ++++ include/configs/rk3036_common.h | 2 +- include/configs/rk3188_common.h | 2 +- include/configs/rk322x_common.h | 92 ++++++++++++++ include/configs/rk3288_common.h | 2 +- include/configs/rk3328_common.h | 2 +- include/configs/rk3368_common.h | 2 + include/configs/rk3399_common.h | 1 + include/configs/rpi.h | 1 - include/configs/socfpga_common.h | 3 - include/dt-bindings/clock/rk3228-cru.h | 238 +++++++++++++++++++++++++++++++++++ include/power/rk8xx_pmic.h | 2 + scripts/config_whitelist.txt | 1 - tools/rkcommon.c | 1 + 125 files changed, 5044 insertions(+), 595 deletions(-) create mode 100644 arch/arm/dts/rk3229-evb.dts create mode 100644 arch/arm/dts/rk322x.dtsi create mode 100644 arch/arm/dts/rk3288-phycore-rdk.dts create mode 100644 arch/arm/dts/rk3288-phycore-som.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rk322x.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rk322x.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_common.h create mode 100644 arch/arm/mach-rockchip/rk322x-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk322x-board.c create mode 100644 arch/arm/mach-rockchip/rk322x/Kconfig create mode 100644 arch/arm/mach-rockchip/rk322x/Makefile create mode 100644 arch/arm/mach-rockchip/rk322x/clk_rk322x.c create mode 100644 arch/arm/mach-rockchip/rk322x/syscon_rk322x.c create mode 100644 arch/arm/mach-rockchip/rk3328/sdram_rk3328.c create mode 100644 arch/arm/mach-rockchip/rk3368/sdram_rk3368.c create mode 100644 arch/arm/mach-rockchip/sdram_common.c create mode 100644 board/phytec/phycore_rk3288/Kconfig create mode 100644 board/phytec/phycore_rk3288/MAINTAINERS create mode 100644 board/phytec/phycore_rk3288/Makefile create mode 100644 board/phytec/phycore_rk3288/phycore-rk3288.c create mode 100644 board/rockchip/evb_rk3229/Kconfig create mode 100644 board/rockchip/evb_rk3229/MAINTAINERS create mode 100644 board/rockchip/evb_rk3229/Makefile create mode 100644 board/rockchip/evb_rk3229/evb_rk3229.c create mode 100644 configs/evb-rk3229_defconfig create mode 100644 configs/phycore-rk3288_defconfig create mode 100644 drivers/clk/rockchip/clk_rk322x.c create mode 100644 drivers/pinctrl/rockchip/pinctrl_rk322x.c create mode 100644 drivers/sysreset/sysreset_rk322x.c create mode 100644 include/configs/evb_rk3229.h create mode 100644 include/configs/phycore_rk3288.h create mode 100644 include/configs/rk322x_common.h create mode 100644 include/dt-bindings/clock/rk3228-cru.h
On Tue, Jul 11, 2017 at 08:06:33PM +0200, Dr. Philipp Tomsich wrote:
Tom,
Thanks, Phil.
Applied to u-boot/master, thanks! Please note that evb-rk3328 has some warnings now here with gcc-6.3, please look into them, thanks!
Dr. Philipp Tomsich
