Re: [U-Boot-Users] U-Boot-1.1.4 using STUART
Dear Kontakt:
If I recall, there is something slightly unusual about the STUART compared with the FFUART in the PXA. You might look carefully at the hardware differences in the PXA pdf file from Intel and see if you can discern that difference.
Charles
-----Original Message----- From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of kontakt@download-privat.de Sent: Monday, January 15, 2007 2:30 AM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] U-Boot-1.1.4 using STUART
Hi all,
my System is a PXA based board. First i used the FFUart Port for bootmessages from bootloader and i can then display the kernelbootmessages on FFUART und STUART. But if i use STUART for Bootloader bootmessages then my Kernel is not starting.
What is the problem with the STUART?
Thank you for you help!
Hi Charles,
I think the same as you about my problem.Is this problem only on my PXA-based board schematic or is it a PXA problem?
Thank you for your request!
Dear Kontakt:
Charles
Hi all,
Charles Krinke
