[PATCH v5 0/2] J7200 device tree sync from v6.6-rc1 to u-boot
This series tries to sync device tree files from Linux v6.6-rc1 while making changes to the u-boot.dtsi and r5-common-proc-board.dts files in order to remove duplicate nodes and achieve successful boot.
DMA fixes [0] are currently being upstreamed to Linux. They'll be fixed in U-boot post their merge in Linux.
Previous versions (v1-v3) of patch no longer boot in next branch due to a recent change with how bootph-pre-ram now works [1]. Changes have been in this version to avoid future issues with that.
Boot log is included in [2]
[0]: https://lore.kernel.org/all/20230810174356.3322583-1-vigneshr@ti.com/ [1]: https://lore.kernel.org/u-boot/CAPnjgZ3MgWX8T0A0SofphEr_Xd77pE3hte9DNye1RuBV... [2]: https://gist.github.com/reidt1/809bafbab561bb148513e2b55ba11a56 --- Changes in v5: - Replaced bootph-all's in r5.dts with bootph-pre-ram - Link to v4: https://lore.kernel.org/u-boot/20231004165629.506664-1-reidt@ti.com/
Reid Tonking (2): arm: mach-k3: j7200: Add mcu_timer0 id to the dev list arm: dts: j7200: dts sync with Linux 6.6-rc1
.../k3-j7200-common-proc-board-u-boot.dtsi | 208 +++---- arch/arm/dts/k3-j7200-common-proc-board.dts | 186 +++--- arch/arm/dts/k3-j7200-main.dtsi | 535 +++++++++++++++++- arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 286 +++++++++- .../arm/dts/k3-j7200-r5-common-proc-board.dts | 301 +--------- arch/arm/dts/k3-j7200-som-p0.dtsi | 154 +++-- arch/arm/dts/k3-j7200-thermal.dtsi | 47 ++ arch/arm/dts/k3-j7200.dtsi | 30 +- arch/arm/mach-k3/j7200/dev-data.c | 1 + 9 files changed, 1207 insertions(+), 541 deletions(-) create mode 100644 arch/arm/dts/k3-j7200-thermal.dtsi
mcu_timer0 is now used as the tick timer in u-boot, so this adds the timer to the soc device list so it can be enabled via the k3 power controller.
Reviewed-by: Nishanth Menon nm@ti.com Signed-off-by: Reid Tonking reidt@ti.com --- arch/arm/mach-k3/j7200/dev-data.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-k3/j7200/dev-data.c b/arch/arm/mach-k3/j7200/dev-data.c index 4ddc34210e..8ce6796fd0 100644 --- a/arch/arm/mach-k3/j7200/dev-data.c +++ b/arch/arm/mach-k3/j7200/dev-data.c @@ -46,6 +46,7 @@ static struct ti_lpsc soc_lpsc_list[] = {
static struct ti_dev soc_dev_list[] = { PSC_DEV(30, &soc_lpsc_list[0]), + PSC_DEV(35, &soc_lpsc_list[0]), PSC_DEV(61, &soc_lpsc_list[1]), PSC_DEV(90, &soc_lpsc_list[2]), PSC_DEV(8, &soc_lpsc_list[3]),
Sync j7200 dts with Linux 6.6-rc1
- k3-j7200-r5-common-proc-board.dts now inherits from k3-j7200-common-proc-board.dts instead of k3-j7200-som-p0.dtsi. This allows us to trim down the r5 file considerably by using existing properties
- remove pimux nodes from r5 file
- remove duplicate nodes & node properties from r5/u-boot files
- mcu_timer0 now used instead of timer1
mcu_timer0 device id added to dev-data.c file in order to work
- remove cpsw node
This node is no longer required since the compatible is now fixed
- remove dummy_clock_19_2_mhz
This node wasn't being used anyhere, so it was removed
- remove dummy_clock_200mhz
main_sdhci0 & main_sdhci1 no longer need dummy clock for eMMC/SD
- fix secure proxy node
mcu_secproxy changed to used secure_prxy_mcu which is already defined in k3-j7200-mcu-wakeup.dtsi
- removed &mcu_ringacc property override since they're present in v6.6-rc1
Signed-off-by: Reid Tonking reidt@ti.com --- .../k3-j7200-common-proc-board-u-boot.dtsi | 208 +++---- arch/arm/dts/k3-j7200-common-proc-board.dts | 186 +++--- arch/arm/dts/k3-j7200-main.dtsi | 535 +++++++++++++++++- arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 286 +++++++++- .../arm/dts/k3-j7200-r5-common-proc-board.dts | 301 +--------- arch/arm/dts/k3-j7200-som-p0.dtsi | 154 +++-- arch/arm/dts/k3-j7200-thermal.dtsi | 47 ++ arch/arm/dts/k3-j7200.dtsi | 30 +- 8 files changed, 1206 insertions(+), 541 deletions(-) create mode 100644 arch/arm/dts/k3-j7200-thermal.dtsi
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index f25c7136c9..60ca6d21ab 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -1,200 +1,210 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2020-2023 Texas Instruments Incorporated - https://www.ti.com/ */
#include "k3-j7200-binman.dtsi"
/ { chosen { - stdout-path = "serial2:115200n8"; - tick-timer = &timer1; - }; - - aliases { - ethernet0 = &cpsw_port1; - i2c0 = &wkup_i2c0; - i2c1 = &mcu_i2c0; - i2c2 = &mcu_i2c1; - i2c3 = &main_i2c0; + tick-timer = &mcu_timer0; }; };
&cbass_main { - bootph-pre-ram; + bootph-all; };
&main_navss { - bootph-pre-ram; + bootph-all; +}; + +&main_esm { + bootph-all; };
&cbass_mcu_wakeup { - bootph-pre-ram; - - timer1: timer@40400000 { - compatible = "ti,omap5430-timer"; - reg = <0x0 0x40400000 0x0 0x80>; - ti,timer-alwon; - clock-frequency = <250000000>; - bootph-pre-ram; - }; + bootph-all;
chipid@43000014 { - bootph-pre-ram; + bootph-all; }; +};
- mcu_navss: bus@28380000 { - bootph-pre-ram; - #address-cells = <2>; - #size-cells = <2>; - - ringacc@2b800000 { - reg = <0x0 0x2b800000 0x0 0x400000>, - <0x0 0x2b000000 0x0 0x400000>, - <0x0 0x28590000 0x0 0x100>, - <0x0 0x2a500000 0x0 0x40000>, - <0x0 0x28440000 0x0 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; - bootph-pre-ram; - }; - - dma-controller@285c0000 { - reg = <0x0 0x285c0000 0x0 0x100>, - <0x0 0x284c0000 0x0 0x4000>, - <0x0 0x2a800000 0x0 0x40000>, - <0x0 0x284a0000 0x0 0x4000>, - <0x0 0x2aa00000 0x0 0x40000>, - <0x0 0x28400000 0x0 0x2000>; - reg-names = "gcfg", "rchan", "rchanrt", "tchan", - "tchanrt", "rflow"; - bootph-pre-ram; - }; - }; +&mcu_navss { + bootph-all; +}; + +&mcu_ringacc { + bootph-all; +}; + +&mcu_udmap { + reg = <0x0 0x285c0000 0x0 0x100>, + <0x0 0x284c0000 0x0 0x4000>, + <0x0 0x2a800000 0x0 0x40000>, + <0x0 0x284a0000 0x0 0x4000>, + <0x0 0x2aa00000 0x0 0x40000>, + <0x0 0x28400000 0x0 0x2000>; + reg-names = "gcfg", "rchan", "rchanrt", "tchan", + "tchanrt", "rflow"; + bootph-all; };
&secure_proxy_main { - bootph-pre-ram; + bootph-all; };
&dmsc { - bootph-pre-ram; + bootph-all; k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset"; - bootph-pre-ram; + bootph-all; }; };
&k3_pds { - bootph-pre-ram; + bootph-all; };
&k3_clks { - bootph-pre-ram; + bootph-all; };
&k3_reset { - bootph-pre-ram; + bootph-all; };
&wkup_pmx0 { - bootph-pre-ram; + bootph-all; +}; + +&wkup_pmx2 { + bootph-all; };
&main_pmx0 { - bootph-pre-ram; + bootph-all; };
&main_uart0 { - bootph-pre-ram; + bootph-all; +}; + +&main_uart2 { + bootph-all; };
&mcu_uart0 { - bootph-pre-ram; + bootph-all; };
&main_sdhci0 { - bootph-pre-ram; + bootph-all; };
&main_sdhci1 { - bootph-pre-ram; + bootph-all; };
&wkup_i2c0 { - bootph-pre-ram; + bootph-all; };
&main_i2c0 { - bootph-pre-ram; + bootph-all; };
-&main_i2c0_pins_default { - bootph-pre-ram; +&exp1 { + bootph-all; };
&exp2 { - bootph-pre-ram; + bootph-all; };
&mcu_cpsw { - reg = <0x0 0x46000000 0x0 0x200000>, - <0x0 0x40f00200 0x0 0x8>; - reg-names = "cpsw_nuss", "mac_efuse"; - /delete-property/ ranges; - - cpsw-phy-sel@40f04040 { - compatible = "ti,am654-cpsw-phy-sel"; - reg= <0x0 0x40f04040 0x0 0x4>; - reg-names = "gmii-sel"; - }; + bootph-all; };
-&main_usbss0_pins_default { - bootph-pre-ram; +&mcu_uart0 { + bootph-all; };
-&usbss0 { - bootph-pre-ram; - ti,usb2-only; +&wkup_i2c0 { + bootph-all; };
-&usb0 { - dr_mode = "peripheral"; - bootph-pre-ram; +&wkup_uart0 { + bootph-all; };
-&mcu_fss0_hpb0_pins_default { - bootph-pre-ram; +&fss { + bootph-all; };
-&fss { - bootph-pre-ram; +&main_uart0_pins_default { + bootph-all; +}; + +&main_mmc1_pins_default { + bootph-all; +}; + +&main_i2c0_pins_default { + bootph-all; +}; + +&wkup_i2c0_pins_default { + bootph-all; +}; + +&wkup_uart0_pins_default { + bootph-all; +}; + +&wkup_gpio_pins_default { + bootph-all; +}; + +&wkup_gpio0 { + bootph-all; };
&hbmc { - bootph-pre-ram; + bootph-all;
flash@0,0 { - bootph-pre-ram; + bootph-all; }; };
&hbmc_mux { - bootph-pre-ram; + bootph-all; +}; + +&usbss0 { + bootph-all; + ti,usb2-only; +}; + +&usb0 { + dr_mode = "peripheral"; + bootph-all; +}; + +&ospi0 { + bootph-all; };
&serdes_ln_ctrl { - u-boot,mux-autoprobe; + bootph-all; };
&usb_serdes_mux { - u-boot,mux-autoprobe; + bootph-all; };
&serdes0 { - bootph-pre-ram; -}; - -&main_r5fss0 { - ti,cluster-mode = <0>; + bootph-all; }; diff --git a/arch/arm/dts/k3-j7200-common-proc-board.dts b/arch/arm/dts/k3-j7200-common-proc-board.dts index ef5e807a80..cee2b4b0eb 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-common-proc-board.dts @@ -9,12 +9,25 @@ #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/net/ti-dp83867.h> #include <dt-bindings/phy/phy.h> + #include "k3-serdes.h"
/ { + compatible = "ti,j7200-evm", "ti,j7200"; + model = "Texas Instruments J7200 EVM"; + + aliases { + serial0 = &wkup_uart0; + serial1 = &mcu_uart0; + serial2 = &main_uart0; + serial3 = &main_uart1; + serial5 = &main_uart3; + mmc0 = &main_sdhci0; + mmc1 = &main_sdhci1; + }; + chosen { stdout-path = "serial2:115200n8"; - bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000"; };
evm_12v0: fixedregulator-evm12v0 { @@ -78,47 +91,87 @@ };
&wkup_pmx0 { - mcu_cpsw_pins_default: mcu-cpsw-pins-default { + mcu_uart0_pins_default: mcu-uart0-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xf4, PIN_INPUT, 0) /* (D20) MCU_UART0_RXD */ + J721E_WKUP_IOPAD(0xf0, PIN_OUTPUT, 0) /* (D19) MCU_UART0_TXD */ + J721E_WKUP_IOPAD(0xf8, PIN_INPUT, 0) /* (E20) MCU_UART0_CTSn */ + J721E_WKUP_IOPAD(0xfc, PIN_OUTPUT, 0) /* (E21) MCU_UART0_RTSn */ + >; + }; + + wkup_uart0_pins_default: wkup-uart0-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 0) /* (B14) WKUP_UART0_RXD */ + J721E_WKUP_IOPAD(0xb4, PIN_OUTPUT, 0) /* (A14) WKUP_UART0_TXD */ + >; + }; +}; + +&wkup_pmx2 { + mcu_cpsw_pins_default: mcu-cpsw-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x0000, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */ + J721E_WKUP_IOPAD(0x0004, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */ + J721E_WKUP_IOPAD(0x0008, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */ + J721E_WKUP_IOPAD(0x000c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */ + J721E_WKUP_IOPAD(0x0010, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */ + J721E_WKUP_IOPAD(0x0014, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */ + J721E_WKUP_IOPAD(0x0020, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */ + J721E_WKUP_IOPAD(0x0024, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */ + J721E_WKUP_IOPAD(0x0028, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */ + J721E_WKUP_IOPAD(0x002c, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */ + J721E_WKUP_IOPAD(0x0018, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */ + J721E_WKUP_IOPAD(0x001c, PIN_INPUT, 0) /* MCU_RGMII1_RXC */ + >; + }; + + wkup_gpio_pins_default: wkup-gpio-default-pins { pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0068, PIN_OUTPUT, 0) /* MCU_RGMII1_TX_CTL */ - J721E_WKUP_IOPAD(0x006c, PIN_INPUT, 0) /* MCU_RGMII1_RX_CTL */ - J721E_WKUP_IOPAD(0x0070, PIN_OUTPUT, 0) /* MCU_RGMII1_TD3 */ - J721E_WKUP_IOPAD(0x0074, PIN_OUTPUT, 0) /* MCU_RGMII1_TD2 */ - J721E_WKUP_IOPAD(0x0078, PIN_OUTPUT, 0) /* MCU_RGMII1_TD1 */ - J721E_WKUP_IOPAD(0x007c, PIN_OUTPUT, 0) /* MCU_RGMII1_TD0 */ - J721E_WKUP_IOPAD(0x0088, PIN_INPUT, 0) /* MCU_RGMII1_RD3 */ - J721E_WKUP_IOPAD(0x008c, PIN_INPUT, 0) /* MCU_RGMII1_RD2 */ - J721E_WKUP_IOPAD(0x0090, PIN_INPUT, 0) /* MCU_RGMII1_RD1 */ - J721E_WKUP_IOPAD(0x0094, PIN_INPUT, 0) /* MCU_RGMII1_RD0 */ - J721E_WKUP_IOPAD(0x0080, PIN_OUTPUT, 0) /* MCU_RGMII1_TXC */ - J721E_WKUP_IOPAD(0x0084, PIN_INPUT, 0) /* MCU_RGMII1_RXC */ + J721E_WKUP_IOPAD(0x70, PIN_INPUT, 7) /* (C14) WKUP_GPIO0_6 */ >; };
- mcu_mdio_pins_default: mcu-mdio1-pins-default { + mcu_mdio_pins_default: mcu-mdio1-default-pins { pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x009c, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */ - J721E_WKUP_IOPAD(0x0098, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */ + J721E_WKUP_IOPAD(0x0034, PIN_OUTPUT, 0) /* (L1) MCU_MDIO0_MDC */ + J721E_WKUP_IOPAD(0x0030, PIN_INPUT, 0) /* (L4) MCU_MDIO0_MDIO */ >; }; };
&main_pmx0 { - main_i2c0_pins_default: main-i2c0-pins-default { + main_uart0_pins_default: main-uart0-default-pins { pinctrl-single,pins = < - J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ - J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ + J721E_IOPAD(0xb0, PIN_INPUT, 0) /* (T16) UART0_RXD */ + J721E_IOPAD(0xb4, PIN_OUTPUT, 0) /* (T17) UART0_TXD */ + J721E_IOPAD(0xc0, PIN_INPUT, 2) /* (W3) SPI0_CS0.UART0_CTSn */ + J721E_IOPAD(0xc4, PIN_OUTPUT, 2) /* (U5) SPI0_CS1.UART0_RTSn */ >; };
- main_i2c1_pins_default: main-i2c1-pins-default { + main_uart1_pins_default: main-uart1-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0xb8, PIN_INPUT, 0) /* (T18) UART1_RXD */ + J721E_IOPAD(0xbc, PIN_INPUT, 0) /* (T20) UART1_TXD */ + >; + }; + + main_uart3_pins_default: main-uart3-default-pins { + pinctrl-single,pins = < + J721E_IOPAD(0x60, PIN_INPUT, 11) /* (T15) MCAN8_TX.UART3_CTSn */ + J721E_IOPAD(0x30, PIN_INPUT, 11) /* (Y18) MCAN2_TX.UART3_RXD */ + >; + }; + + main_i2c1_pins_default: main-i2c1-default-pins { pinctrl-single,pins = < J721E_IOPAD(0xdc, PIN_INPUT_PULLUP, 3) /* (U3) ECAP0_IN_APWM_OUT.I2C1_SCL */ J721E_IOPAD(0xe0, PIN_INPUT_PULLUP, 3) /* (T3) EXT_REFCLK1.I2C1_SDA */ >; };
- main_mmc1_pins_default: main-mmc1-pins-default { + main_mmc1_pins_default: main-mmc1-default-pins { pinctrl-single,pins = < J721E_IOPAD(0x104, PIN_INPUT, 0) /* (M20) MMC1_CMD */ J721E_IOPAD(0x100, PIN_INPUT, 0) /* (P21) MMC1_CLK */ @@ -131,15 +184,17 @@ >; };
- main_usbss0_pins_default: main-usbss0-pins-default { + vdd_sd_dv_pins_default: vdd-sd-dv-default-pins { pinctrl-single,pins = < - J721E_IOPAD(0x120, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ + J721E_IOPAD(0xd0, PIN_OUTPUT, 7) /* (T5) SPI0_D1.GPIO0_55 */ >; }; +};
- vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { +&main_pmx1 { + main_usbss0_pins_default: main-usbss0-default-pins { pinctrl-single,pins = < - J721E_IOPAD(0xd0, PIN_OUTPUT, 7) /* (T5) SPI0_D1.GPIO0_55 */ + J721E_IOPAD(0x04, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ >; }; }; @@ -147,11 +202,30 @@ &wkup_uart0 { /* Wakeup UART is used by System firmware */ status = "reserved"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; +}; + +&mcu_uart0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&mcu_uart0_pins_default>; + clock-frequency = <96000000>; };
&main_uart0 { + status = "okay"; /* Shared with ATF on this platform */ power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; +}; + +&main_uart1 { + status = "okay"; + /* Default pinmux */ + pinctrl-names = "default"; + pinctrl-0 = <&main_uart1_pins_default>; };
&main_uart2 { @@ -160,59 +234,25 @@ };
&main_uart3 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart4 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart5 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart6 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart7 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart8 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_uart9 { - /* UART not brought out */ - status = "disabled"; -}; - -&main_gpio2 { - status = "disabled"; -}; - -&main_gpio4 { - status = "disabled"; + /* Shared with MCAN Interface */ + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_uart3_pins_default>; };
-&main_gpio6 { - status = "disabled"; +&main_gpio0 { + status = "okay"; };
-&wkup_gpio1 { - status = "disabled"; +&wkup_gpio0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_gpio_pins_default>; };
&mcu_cpsw { pinctrl-names = "default"; - pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; + pinctrl-0 = <&mcu_cpsw_pins_default>, <&mcu_mdio_pins_default>; };
&davinci_mdio { @@ -229,6 +269,7 @@ };
&main_i2c0 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c0_pins_default>; clock-frequency = <400000>; @@ -256,6 +297,7 @@ * The i2c1 of the CPB (as it is labeled) is not connected to j7200. */ &main_i2c1 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&main_i2c1_pins_default>; clock-frequency = <400000>; @@ -273,6 +315,7 @@
&main_sdhci0 { /* eMMC */ + status = "okay"; non-removable; ti,driver-strength-ohm = <50>; disable-wp; @@ -280,6 +323,7 @@
&main_sdhci1 { /* SD card */ + status = "okay"; pinctrl-0 = <&main_mmc1_pins_default>; pinctrl-names = "default"; vmmc-supply = <&vdd_mmc1>; diff --git a/arch/arm/dts/k3-j7200-main.dtsi b/arch/arm/dts/k3-j7200-main.dtsi index e8a41d09b4..cdb1d6b2a9 100644 --- a/arch/arm/dts/k3-j7200-main.dtsi +++ b/arch/arm/dts/k3-j7200-main.dtsi @@ -32,13 +32,20 @@ #size-cells = <1>; ranges = <0x00 0x00 0x00100000 0x1c000>;
- serdes_ln_ctrl: serdes-ln-ctrl@4080 { + serdes_ln_ctrl: mux-controller@4080 { compatible = "mmio-mux"; #mux-control-cells = <1>; mux-reg-masks = <0x4080 0x3>, <0x4084 0x3>, /* SERDES0 lane0/1 select */ <0x4088 0x3>, <0x408c 0x3>; /* SERDES0 lane2/3 select */ };
+ cpsw0_phy_gmii_sel: phy@4044 { + compatible = "ti,j7200-cpsw5g-phy-gmii-sel"; + ti,qsgmii-main-ports = <1>; + reg = <0x4044 0x10>; + #phy-cells = <1>; + }; + usb_serdes_mux: mux-controller@4000 { compatible = "mmio-mux"; #mux-control-cells = <1>; @@ -54,7 +61,10 @@ #interrupt-cells = <3>; interrupt-controller; reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */ - <0x00 0x01900000 0x00 0x100000>; /* GICR */ + <0x00 0x01900000 0x00 0x100000>, /* GICR */ + <0x00 0x6f000000 0x00 0x2000>, /* GICC */ + <0x00 0x6f010000 0x00 0x1000>, /* GICH */ + <0x00 0x6f020000 0x00 0x2000>; /* GICV */
/* vcpumntirq: virtual CPU interface maintenance interrupt */ interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; @@ -139,6 +149,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster1: mailbox@31f81000 { @@ -148,6 +159,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster2: mailbox@31f82000 { @@ -157,6 +169,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster3: mailbox@31f83000 { @@ -166,6 +179,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster4: mailbox@31f84000 { @@ -175,6 +189,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster5: mailbox@31f85000 { @@ -184,6 +199,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster6: mailbox@31f86000 { @@ -193,6 +209,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster7: mailbox@31f87000 { @@ -202,6 +219,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster8: mailbox@31f88000 { @@ -211,6 +229,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster9: mailbox@31f89000 { @@ -220,6 +239,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster10: mailbox@31f8a000 { @@ -229,6 +249,7 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
mailbox0_cluster11: mailbox@31f8b000 { @@ -238,15 +259,17 @@ ti,mbox-num-users = <4>; ti,mbox-num-fifos = <16>; interrupt-parent = <&main_navss_intr>; + status = "disabled"; };
main_ringacc: ringacc@3c000000 { compatible = "ti,am654-navss-ringacc"; - reg = <0x00 0x3c000000 0x00 0x400000>, - <0x00 0x38000000 0x00 0x400000>, - <0x00 0x31120000 0x00 0x100>, - <0x00 0x33000000 0x00 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target"; + reg = <0x00 0x3c000000 0x00 0x400000>, + <0x00 0x38000000 0x00 0x400000>, + <0x00 0x31120000 0x00 0x100>, + <0x00 0x33000000 0x00 0x40000>, + <0x00 0x31080000 0x00 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; ti,num-rings = <1024>; ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */ ti,sci = <&dmsc>; @@ -256,9 +279,9 @@
main_udmap: dma-controller@31150000 { compatible = "ti,j721e-navss-main-udmap"; - reg = <0x00 0x31150000 0x00 0x100>, - <0x00 0x34000000 0x00 0x100000>, - <0x00 0x35000000 0x00 0x100000>; + reg = <0x00 0x31150000 0x00 0x100>, + <0x00 0x34000000 0x00 0x100000>, + <0x00 0x35000000 0x00 0x100000>; reg-names = "gcfg", "rchanrt", "tchanrt"; msi-parent = <&main_udmass_inta>; #dma-cells = <1>; @@ -289,10 +312,118 @@ }; };
+ cpsw0: ethernet@c000000 { + compatible = "ti,j7200-cpswxg-nuss"; + #address-cells = <2>; + #size-cells = <2>; + reg = <0x00 0xc000000 0x00 0x200000>; + reg-names = "cpsw_nuss"; + ranges = <0x00 0x00 0x00 0xc000000 0x00 0x200000>; + clocks = <&k3_clks 19 33>; + clock-names = "fck"; + power-domains = <&k3_pds 19 TI_SCI_PD_EXCLUSIVE>; + + dmas = <&main_udmap 0xca00>, + <&main_udmap 0xca01>, + <&main_udmap 0xca02>, + <&main_udmap 0xca03>, + <&main_udmap 0xca04>, + <&main_udmap 0xca05>, + <&main_udmap 0xca06>, + <&main_udmap 0xca07>, + <&main_udmap 0x4a00>; + dma-names = "tx0", "tx1", "tx2", "tx3", + "tx4", "tx5", "tx6", "tx7", + "rx"; + + status = "disabled"; + + ethernet-ports { + #address-cells = <1>; + #size-cells = <0>; + cpsw0_port1: port@1 { + reg = <1>; + ti,mac-only; + label = "port1"; + status = "disabled"; + }; + + cpsw0_port2: port@2 { + reg = <2>; + ti,mac-only; + label = "port2"; + status = "disabled"; + }; + + cpsw0_port3: port@3 { + reg = <3>; + ti,mac-only; + label = "port3"; + status = "disabled"; + }; + + cpsw0_port4: port@4 { + reg = <4>; + ti,mac-only; + label = "port4"; + status = "disabled"; + }; + }; + + cpsw5g_mdio: mdio@f00 { + compatible = "ti,cpsw-mdio","ti,davinci_mdio"; + reg = <0x00 0xf00 0x00 0x100>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&k3_clks 19 33>; + clock-names = "fck"; + bus_freq = <1000000>; + status = "disabled"; + }; + + cpts@3d000 { + compatible = "ti,j721e-cpts"; + reg = <0x00 0x3d000 0x00 0x400>; + clocks = <&k3_clks 19 16>; + clock-names = "cpts"; + interrupts-extended = <&gic500 GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "cpts"; + ti,cpts-ext-ts-inputs = <4>; + ti,cpts-periodic-outputs = <2>; + }; + }; + + /* TIMERIO pad input CTRLMMR_TIMER*_CTRL registers */ + main_timerio_input: pinctrl@104200 { + compatible = "pinctrl-single"; + reg = <0x0 0x104200 0x0 0x50>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x000001ff>; + }; + + /* TIMERIO pad output CTCTRLMMR_TIMERIO*_CTRL registers */ + main_timerio_output: pinctrl@104280 { + compatible = "pinctrl-single"; + reg = <0x0 0x104280 0x0 0x20>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000001f>; + }; + main_pmx0: pinctrl@11c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */ - reg = <0x00 0x11c000 0x00 0x2b4>; + reg = <0x00 0x11c000 0x00 0x10c>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + main_pmx1: pinctrl@11c11c { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x11c11c 0x00 0xc>; #pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>; @@ -307,6 +438,7 @@ power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 146 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart1: serial@2810000 { @@ -318,6 +450,7 @@ power-domains = <&k3_pds 278 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 278 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart2: serial@2820000 { @@ -329,6 +462,7 @@ power-domains = <&k3_pds 279 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 279 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart3: serial@2830000 { @@ -340,6 +474,7 @@ power-domains = <&k3_pds 280 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 280 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart4: serial@2840000 { @@ -351,6 +486,7 @@ power-domains = <&k3_pds 281 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 281 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart5: serial@2850000 { @@ -362,6 +498,7 @@ power-domains = <&k3_pds 282 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 282 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart6: serial@2860000 { @@ -373,6 +510,7 @@ power-domains = <&k3_pds 283 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 283 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart7: serial@2870000 { @@ -384,6 +522,7 @@ power-domains = <&k3_pds 284 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 284 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart8: serial@2880000 { @@ -395,6 +534,7 @@ power-domains = <&k3_pds 285 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 285 2>; clock-names = "fclk"; + status = "disabled"; };
main_uart9: serial@2890000 { @@ -406,6 +546,7 @@ power-domains = <&k3_pds 286 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 286 2>; clock-names = "fclk"; + status = "disabled"; };
main_i2c0: i2c@2000000 { @@ -417,6 +558,7 @@ clock-names = "fck"; clocks = <&k3_clks 187 1>; power-domains = <&k3_pds 187 TI_SCI_PD_SHARED>; + status = "disabled"; };
main_i2c1: i2c@2010000 { @@ -428,6 +570,7 @@ clock-names = "fck"; clocks = <&k3_clks 188 1>; power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c2: i2c@2020000 { @@ -439,6 +582,7 @@ clock-names = "fck"; clocks = <&k3_clks 189 1>; power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c3: i2c@2030000 { @@ -450,6 +594,7 @@ clock-names = "fck"; clocks = <&k3_clks 190 1>; power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c4: i2c@2040000 { @@ -461,6 +606,7 @@ clock-names = "fck"; clocks = <&k3_clks 191 1>; power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c5: i2c@2050000 { @@ -472,6 +618,7 @@ clock-names = "fck"; clocks = <&k3_clks 192 1>; power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_i2c6: i2c@2060000 { @@ -483,6 +630,7 @@ clock-names = "fck"; clocks = <&k3_clks 193 1>; power-domains = <&k3_pds 193 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
main_sdhci0: mmc@4f80000 { @@ -507,6 +655,7 @@ mmc-hs200-1_8v; mmc-hs400-1_8v; dma-coherent; + status = "disabled"; };
main_sdhci1: mmc@4fb0000 { @@ -530,6 +679,7 @@ ti,clkbuf-sel = <0x7>; ti,trm-icp = <0x8>; dma-coherent; + status = "disabled"; };
serdes_wiz0: wiz@5060000 { @@ -606,10 +756,10 @@ clock-names = "fck"; #address-cells = <3>; #size-cells = <2>; - bus-range = <0x0 0xf>; + bus-range = <0x0 0xff>; cdns,no-bar-match-nbits = <64>; - vendor-id = /bits/ 16 <0x104c>; - device-id = /bits/ 16 <0xb00f>; + vendor-id = <0x104c>; + device-id = <0xb00f>; msi-map = <0x0 &gic_its 0x0 0x10000>; dma-coherent; ranges = <0x01000000 0x0 0x18001000 0x00 0x18001000 0x0 0x0010000>, @@ -633,6 +783,7 @@ clocks = <&k3_clks 240 6>; clock-names = "fck"; max-functions = /bits/ 8 <6>; + max-virtual-functions = /bits/ 8 <4 4 4 4 0 0>; dma-coherent; };
@@ -682,6 +833,7 @@ power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 105 0>; clock-names = "gpio"; + status = "disabled"; };
main_gpio2: gpio@610000 { @@ -699,6 +851,7 @@ power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 107 0>; clock-names = "gpio"; + status = "disabled"; };
main_gpio4: gpio@620000 { @@ -716,6 +869,7 @@ power-domains = <&k3_pds 109 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 109 0>; clock-names = "gpio"; + status = "disabled"; };
main_gpio6: gpio@630000 { @@ -733,6 +887,353 @@ power-domains = <&k3_pds 111 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 111 0>; clock-names = "gpio"; + status = "disabled"; + }; + + main_spi0: spi@2100000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02100000 0x00 0x400>; + interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 266 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 266 1>; + status = "disabled"; + }; + + main_spi1: spi@2110000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02110000 0x00 0x400>; + interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 267 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 267 1>; + status = "disabled"; + }; + + main_spi2: spi@2120000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02120000 0x00 0x400>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 268 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 268 1>; + status = "disabled"; + }; + + main_spi3: spi@2130000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02130000 0x00 0x400>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 269 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 269 1>; + status = "disabled"; + }; + + main_spi4: spi@2140000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02140000 0x00 0x400>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 270 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 270 1>; + status = "disabled"; + }; + + main_spi5: spi@2150000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02150000 0x00 0x400>; + interrupts = <GIC_SPI 189 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 271 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 271 1>; + status = "disabled"; + }; + + main_spi6: spi@2160000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02160000 0x00 0x400>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 272 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 272 1>; + status = "disabled"; + }; + + main_spi7: spi@2170000 { + compatible = "ti,am654-mcspi","ti,omap4-mcspi"; + reg = <0x00 0x02170000 0x00 0x400>; + interrupts = <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 273 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 273 1>; + status = "disabled"; + }; + + watchdog0: watchdog@2200000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x0 0x2200000 0x0 0x100>; + clocks = <&k3_clks 252 1>; + power-domains = <&k3_pds 252 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 252 1>; + assigned-clock-parents = <&k3_clks 252 5>; + }; + + watchdog1: watchdog@2210000 { + compatible = "ti,j7-rti-wdt"; + reg = <0x0 0x2210000 0x0 0x100>; + clocks = <&k3_clks 253 1>; + power-domains = <&k3_pds 253 TI_SCI_PD_EXCLUSIVE>; + assigned-clocks = <&k3_clks 253 1>; + assigned-clock-parents = <&k3_clks 253 5>; + }; + + main_timer0: timer@2400000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2400000 0x00 0x400>; + interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 49 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 49 1>; + assigned-clock-parents = <&k3_clks 49 2>; + power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer1: timer@2410000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2410000 0x00 0x400>; + interrupts = <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 50 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 50 1>, <&k3_clks 313 0>; + assigned-clock-parents = <&k3_clks 50 2>, <&k3_clks 313 1>; + power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer2: timer@2420000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2420000 0x00 0x400>; + interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 51 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 51 1>; + assigned-clock-parents = <&k3_clks 51 2>; + power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer3: timer@2430000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2430000 0x00 0x400>; + interrupts = <GIC_SPI 227 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 52 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 52 1>, <&k3_clks 314 0>; + assigned-clock-parents = <&k3_clks 52 2>, <&k3_clks 314 1>; + power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer4: timer@2440000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2440000 0x00 0x400>; + interrupts = <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 53 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 53 1>; + assigned-clock-parents = <&k3_clks 53 2>; + power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer5: timer@2450000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2450000 0x00 0x400>; + interrupts = <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 54 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 54 1>, <&k3_clks 315 0>; + assigned-clock-parents = <&k3_clks 54 2>, <&k3_clks 315 1>; + power-domains = <&k3_pds 54 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer6: timer@2460000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2460000 0x00 0x400>; + interrupts = <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 55 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 55 1>; + assigned-clock-parents = <&k3_clks 55 2>; + power-domains = <&k3_pds 55 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer7: timer@2470000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2470000 0x00 0x400>; + interrupts = <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 57 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 57 1>, <&k3_clks 316 0>; + assigned-clock-parents = <&k3_clks 57 2>, <&k3_clks 316 1>; + power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer8: timer@2480000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2480000 0x00 0x400>; + interrupts = <GIC_SPI 232 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 58 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 58 1>; + assigned-clock-parents = <&k3_clks 58 2>; + power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer9: timer@2490000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2490000 0x00 0x400>; + interrupts = <GIC_SPI 233 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 59 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 59 1>, <&k3_clks 317 0>; + assigned-clock-parents = <&k3_clks 59 2>, <&k3_clks 317 1>; + power-domains = <&k3_pds 59 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer10: timer@24a0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24a0000 0x00 0x400>; + interrupts = <GIC_SPI 234 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 60 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 60 1>; + assigned-clock-parents = <&k3_clks 60 2>; + power-domains = <&k3_pds 60 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer11: timer@24b0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24b0000 0x00 0x400>; + interrupts = <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 62 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 62 1>, <&k3_clks 318 0>; + assigned-clock-parents = <&k3_clks 62 2>, <&k3_clks 318 1>; + power-domains = <&k3_pds 62 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer12: timer@24c0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24c0000 0x00 0x400>; + interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 63 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 63 1>; + assigned-clock-parents = <&k3_clks 63 2>; + power-domains = <&k3_pds 63 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer13: timer@24d0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24d0000 0x00 0x400>; + interrupts = <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 64 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 64 1>, <&k3_clks 319 0>; + assigned-clock-parents = <&k3_clks 64 2>, <&k3_clks 319 1>; + power-domains = <&k3_pds 64 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer14: timer@24e0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24e0000 0x00 0x400>; + interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 65 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 65 1>; + assigned-clock-parents = <&k3_clks 65 2>; + power-domains = <&k3_pds 65 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer15: timer@24f0000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x24f0000 0x00 0x400>; + interrupts = <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 66 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 66 1>, <&k3_clks 320 0>; + assigned-clock-parents = <&k3_clks 66 2>, <&k3_clks 320 1>; + power-domains = <&k3_pds 66 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer16: timer@2500000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2500000 0x00 0x400>; + interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 67 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 67 1>; + assigned-clock-parents = <&k3_clks 67 2>; + power-domains = <&k3_pds 67 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer17: timer@2510000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2510000 0x00 0x400>; + interrupts = <GIC_SPI 241 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 68 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 68 1>, <&k3_clks 321 0>; + assigned-clock-parents = <&k3_clks 68 2>, <&k3_clks 321 1>; + power-domains = <&k3_pds 68 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer18: timer@2520000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2520000 0x00 0x400>; + interrupts = <GIC_SPI 242 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 69 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 69 1>; + assigned-clock-parents = <&k3_clks 69 2>; + power-domains = <&k3_pds 69 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + main_timer19: timer@2530000 { + compatible = "ti,am654-timer"; + reg = <0x00 0x2530000 0x00 0x400>; + interrupts = <GIC_SPI 243 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 70 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 70 1>, <&k3_clks 322 0>; + assigned-clock-parents = <&k3_clks 70 2>, <&k3_clks 322 1>; + power-domains = <&k3_pds 70 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; };
main_r5fss0: r5fss@5c00000 { @@ -774,4 +1275,10 @@ ti,loczrama = <1>; }; }; + + main_esm: esm@700000 { + compatible = "ti,j721e-esm"; + reg = <0x0 0x700000 0x0 0x1000>; + ti,esm-pins = <656>, <657>; + }; }; diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi index 1044ec6c4b..6ffaf85fa6 100644 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi @@ -12,8 +12,8 @@
mbox-names = "rx", "tx";
- mboxes= <&secure_proxy_main 11>, - <&secure_proxy_main 13>; + mboxes = <&secure_proxy_main 11>, + <&secure_proxy_main 13>;
reg-names = "debug_messages"; reg = <0x00 0x44083000 0x00 0x1000>; @@ -34,6 +34,136 @@ }; };
+ mcu_timer0: timer@40400000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40400000 0x00 0x400>; + interrupts = <GIC_SPI 816 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 35 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 35 1>; + assigned-clock-parents = <&k3_clks 35 2>; + power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer1: timer@40410000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40410000 0x00 0x400>; + interrupts = <GIC_SPI 817 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 71 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 71 1>, <&k3_clks 308 0>; + assigned-clock-parents = <&k3_clks 71 2>, <&k3_clks 308 1>; + power-domains = <&k3_pds 71 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer2: timer@40420000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40420000 0x00 0x400>; + interrupts = <GIC_SPI 818 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 72 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 72 1>; + assigned-clock-parents = <&k3_clks 72 2>; + power-domains = <&k3_pds 72 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer3: timer@40430000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40430000 0x00 0x400>; + interrupts = <GIC_SPI 819 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 73 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 73 1>, <&k3_clks 309 0>; + assigned-clock-parents = <&k3_clks 73 2>, <&k3_clks 309 1>; + power-domains = <&k3_pds 73 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer4: timer@40440000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40440000 0x00 0x400>; + interrupts = <GIC_SPI 820 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 74 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 74 1>; + assigned-clock-parents = <&k3_clks 74 2>; + power-domains = <&k3_pds 74 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer5: timer@40450000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40450000 0x00 0x400>; + interrupts = <GIC_SPI 821 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 75 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 75 1>, <&k3_clks 310 0>; + assigned-clock-parents = <&k3_clks 75 2>, <&k3_clks 310 1>; + power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer6: timer@40460000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40460000 0x00 0x400>; + interrupts = <GIC_SPI 822 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 76 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 76 1>; + assigned-clock-parents = <&k3_clks 76 2>; + power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer7: timer@40470000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40470000 0x00 0x400>; + interrupts = <GIC_SPI 823 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 77 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 77 1>, <&k3_clks 311 0>; + assigned-clock-parents = <&k3_clks 77 2>, <&k3_clks 311 1>; + power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer8: timer@40480000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40480000 0x00 0x400>; + interrupts = <GIC_SPI 824 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 78 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 78 1>; + assigned-clock-parents = <&k3_clks 78 2>; + power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + + mcu_timer9: timer@40490000 { + status = "reserved"; + compatible = "ti,am654-timer"; + reg = <0x00 0x40490000 0x00 0x400>; + interrupts = <GIC_SPI 825 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&k3_clks 79 1>; + clock-names = "fck"; + assigned-clocks = <&k3_clks 79 1>, <&k3_clks 312 0>; + assigned-clock-parents = <&k3_clks 79 2>, <&k3_clks 312 1>; + power-domains = <&k3_pds 79 TI_SCI_PD_EXCLUSIVE>; + ti,timer-pwm; + }; + mcu_conf: syscon@40f00000 { compatible = "syscon", "simple-mfd"; reg = <0x00 0x40f00000 0x00 0x20000>; @@ -53,10 +183,57 @@ reg = <0x00 0x43000014 0x00 0x4>; };
+ /* MCU_TIMERIO pad input CTRLMMR_MCU_TIMER*_CTRL registers */ + mcu_timerio_input: pinctrl@40f04200 { + compatible = "pinctrl-single"; + reg = <0x0 0x40f04200 0x0 0x28>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000F>; + status = "reserved"; + }; + + /* MCU_TIMERIO pad output CTRLMMR_MCU_TIMERIO*_CTRL registers */ + mcu_timerio_output: pinctrl@40f04280 { + compatible = "pinctrl-single"; + reg = <0x0 0x40f04280 0x0 0x28>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0x0000000F>; + status = "reserved"; + }; + wkup_pmx0: pinctrl@4301c000 { compatible = "pinctrl-single"; /* Proxy 0 addressing */ - reg = <0x00 0x4301c000 0x00 0x178>; + reg = <0x00 0x4301c000 0x00 0x34>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx1: pinctrl@4301c038 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c038 0x00 0x8>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx2: pinctrl@4301c068 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c068 0x00 0xec>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + wkup_pmx3: pinctrl@4301c174 { + compatible = "pinctrl-single"; + /* Proxy 0 addressing */ + reg = <0x00 0x4301c174 0x00 0x20>; #pinctrl-cells = <1>; pinctrl-single,register-width = <32>; pinctrl-single,function-mask = <0xffffffff>; @@ -79,6 +256,7 @@ power-domains = <&k3_pds 287 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 287 2>; clock-names = "fclk"; + status = "disabled"; };
mcu_uart0: serial@40a00000 { @@ -90,6 +268,7 @@ power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 149 2>; clock-names = "fclk"; + status = "disabled"; };
wkup_gpio_intr: interrupt-controller@42200000 { @@ -118,6 +297,7 @@ power-domains = <&k3_pds 113 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 113 0>; clock-names = "gpio"; + status = "disabled"; };
wkup_gpio1: gpio@42100000 { @@ -134,6 +314,7 @@ power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>; clocks = <&k3_clks 114 0>; clock-names = "gpio"; + status = "disabled"; };
mcu_navss: bus@28380000 { @@ -147,11 +328,13 @@
mcu_ringacc: ringacc@2b800000 { compatible = "ti,am654-navss-ringacc"; - reg = <0x00 0x2b800000 0x00 0x400000>, - <0x00 0x2b000000 0x00 0x400000>, - <0x00 0x28590000 0x00 0x100>, - <0x00 0x2a500000 0x00 0x40000>; - reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target"; + reg = <0x00 0x2b800000 0x00 0x400000>, + <0x00 0x2b000000 0x00 0x400000>, + <0x00 0x28590000 0x00 0x100>, + <0x00 0x2a500000 0x00 0x40000>, + <0x00 0x28440000 0x00 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", + "proxy_target", "cfg"; ti,num-rings = <286>; ti,sci-rm-range-gp-rings = <0x1>; /* GP ring range */ ti,sci = <&dmsc>; @@ -161,9 +344,9 @@
mcu_udmap: dma-controller@285c0000 { compatible = "ti,j721e-navss-mcu-udmap"; - reg = <0x00 0x285c0000 0x00 0x100>, - <0x00 0x2a800000 0x00 0x40000>, - <0x00 0x2aa00000 0x00 0x40000>; + reg = <0x00 0x285c0000 0x00 0x100>, + <0x00 0x2a800000 0x00 0x40000>, + <0x00 0x2aa00000 0x00 0x40000>; reg-names = "gcfg", "rchanrt", "tchanrt"; msi-parent = <&main_udmass_inta>; #dma-cells = <1>; @@ -180,6 +363,21 @@ }; };
+ secure_proxy_mcu: mailbox@2a480000 { + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "target_data", "rt", "scfg"; + reg = <0x0 0x2a480000 0x0 0x80000>, + <0x0 0x2a380000 0x0 0x80000>, + <0x0 0x2a400000 0x0 0x80000>; + /* + * Marked Disabled: + * Node is incomplete as it is meant for bootloaders and + * firmware on non-MPU processors + */ + status = "disabled"; + }; + mcu_cpsw: ethernet@46000000 { compatible = "ti,j721e-cpsw-nuss"; #address-cells = <2>; @@ -249,6 +447,7 @@ clock-names = "fck"; clocks = <&k3_clks 194 1>; power-domains = <&k3_pds 194 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
mcu_i2c1: i2c@40b10000 { @@ -260,6 +459,7 @@ clock-names = "fck"; clocks = <&k3_clks 195 1>; power-domains = <&k3_pds 195 TI_SCI_PD_EXCLUSIVE>; + status = "disabled"; };
wkup_i2c0: i2c@42120000 { @@ -271,6 +471,40 @@ clock-names = "fck"; clocks = <&k3_clks 197 1>; power-domains = <&k3_pds 197 TI_SCI_PD_SHARED>; + status = "disabled"; + }; + + mcu_spi0: spi@40300000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040300000 0x00 0x400>; + interrupts = <GIC_SPI 848 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 274 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 274 0>; + status = "disabled"; + }; + + mcu_spi1: spi@40310000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040310000 0x00 0x400>; + interrupts = <GIC_SPI 849 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 275 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 275 0>; + status = "disabled"; + }; + + mcu_spi2: spi@40320000 { + compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; + reg = <0x00 0x040320000 0x00 0x400>; + interrupts = <GIC_SPI 850 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + power-domains = <&k3_pds 276 TI_SCI_PD_EXCLUSIVE>; + clocks = <&k3_clks 276 0>; + status = "disabled"; };
fss: syscon@47000000 { @@ -314,6 +548,7 @@ power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>; #address-cells = <1>; #size-cells = <0>; + status = "disabled"; }; };
@@ -325,7 +560,7 @@ clocks = <&k3_clks 0 1>; assigned-clocks = <&k3_clks 0 3>; assigned-clock-rates = <60000000>; - clock-names = "adc_tsc_fck"; + clock-names = "fck"; dmas = <&main_udmap 0x7400>, <&main_udmap 0x7401>; dma-names = "fifo0", "fifo1"; @@ -375,4 +610,31 @@ ti,loczrama = <1>; }; }; + + mcu_crypto: crypto@40900000 { + compatible = "ti,j721e-sa2ul"; + reg = <0x00 0x40900000 0x00 0x1200>; + power-domains = <&k3_pds 265 TI_SCI_PD_SHARED>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x00 0x40900000 0x00 0x40900000 0x00 0x30000>; + dmas = <&mcu_udmap 0xf501>, <&mcu_udmap 0x7502>, + <&mcu_udmap 0x7503>; + dma-names = "tx", "rx1", "rx2"; + + rng: rng@40910000 { + compatible = "inside-secure,safexcel-eip76"; + reg = <0x00 0x40910000 0x00 0x7d>; + interrupts = <GIC_SPI 945 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; /* Used by OP-TEE */ + }; + }; + + wkup_vtm0: temperature-sensor@42040000 { + compatible = "ti,j7200-vtm"; + reg = <0x00 0x42040000 0x00 0x350>, + <0x00 0x42050000 0x00 0x350>; + power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; + #thermal-sensor-cells = <1>; + }; }; diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index e62f9218e8..f0a7360502 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -1,13 +1,14 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020 Texas Instruments Incorporated - https://www.ti.com/ + * Copyright (C) 2020-2023 Texas Instruments Incorporated - https://www.ti.com/ */
/dts-v1/;
-#include "k3-j7200-som-p0.dtsi" +#include "k3-j7200-common-proc-board.dts" #include "k3-j7200-ddr-evm-lp4-2666.dtsi" #include "k3-j721e-ddr.dtsi" +#include "k3-j7200-common-proc-board-u-boot.dtsi"
/ { aliases { @@ -15,17 +16,6 @@ remoteproc1 = &a72_0; };
- chosen { - stdout-path = &main_uart0; - tick-timer = &timer1; - firmware-loader = &fs_loader0; - }; - - fs_loader0: fs_loader@0 { - bootph-all; - compatible = "u-boot,fs-loader"; - }; - a72_0: a72@0 { compatible = "ti,am654-rproc"; reg = <0x0 0x00a90000 0x0 0x10>; @@ -42,17 +32,13 @@ bootph-pre-ram; };
- clk_200mhz: dummy_clock_200mhz { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <200000000>; - bootph-pre-ram; - }; - - clk_19_2mhz: dummy_clock_19_2mhz { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <19200000>; + dm_tifs: dm-tifs { + compatible = "ti,j721e-dm-sci"; + ti,host-id = <3>; + ti,secure-host; + mbox-names = "rx", "tx"; + mboxes = <&secure_proxy_mcu 21>, + <&secure_proxy_mcu 23>; bootph-pre-ram; }; }; @@ -61,275 +47,38 @@ power-domains = <&k3_pds 8 TI_SCI_PD_SHARED>, <&k3_pds 90 TI_SCI_PD_SHARED>; clocks = <&k3_clks 8 5>, <&k3_clks 30 9>; + bootph-pre-ram; };
-&cbass_mcu_wakeup { - mcu_secproxy: secproxy@2a380000 { - bootph-pre-ram; - compatible = "ti,am654-secure-proxy"; - reg = <0x0 0x2a380000 0x0 0x80000>, - <0x0 0x2a400000 0x0 0x80000>, - <0x0 0x2a480000 0x0 0x80000>; - reg-names = "rt", "scfg", "target_data"; - #mbox-cells = <1>; - }; +&mcu_timer0 { + clock-frequency = <25000000>; + bootph-pre-ram; +};
+&secure_proxy_mcu { + bootph-pre-ram; + status = "okay"; +}; + +&cbass_mcu_wakeup { sysctrler: sysctrler { - bootph-pre-ram; compatible = "ti,am654-system-controller"; - mboxes= <&mcu_secproxy 4>, <&mcu_secproxy 5>; + mboxes= <&secure_proxy_mcu 4>, + <&secure_proxy_mcu 5>; mbox-names = "tx", "rx"; - }; - - dm_tifs: dm-tifs { - compatible = "ti,j721e-dm-sci"; - ti,host-id = <3>; - ti,secure-host; - mbox-names = "rx", "tx"; - mboxes= <&mcu_secproxy 21>, - <&mcu_secproxy 23>; bootph-pre-ram; }; - - wkup_vtm0: vtm@42040000 { - compatible = "ti,am654-vtm", "ti,j721e-avs"; - reg = <0x0 0x42040000 0x0 0x330>; - power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; - #thermal-sensor-cells = <1>; - }; };
&dmsc { - mboxes= <&mcu_secproxy 8>, <&mcu_secproxy 6>, <&mcu_secproxy 5>; + mboxes = <&secure_proxy_mcu 8>, + <&secure_proxy_mcu 6>, <&secure_proxy_mcu 5>; mbox-names = "tx", "rx", "notify"; ti,host-id = <4>; ti,secure-host; -}; - -&wkup_pmx0 { - bootph-pre-ram; - wkup_uart0_pins_default: wkup_uart0_pins_default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xb0, PIN_INPUT, 0) /* (B14) WKUP_UART0_RXD */ - J721E_WKUP_IOPAD(0xb4, PIN_OUTPUT, 0) /* (A14) WKUP_UART0_TXD */ - >; - }; - - mcu_uart0_pins_default: mcu_uart0_pins_default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xf4, PIN_INPUT, 0) /* (D20) WKUP_GPIO0_13.MCU_UART0_RXD */ - J721E_WKUP_IOPAD(0xf0, PIN_OUTPUT, 0) /* (D19) WKUP_GPIO0_12.MCU_UART0_TXD */ - J721E_WKUP_IOPAD(0xf8, PIN_INPUT, 0) /* (E20) WKUP_GPIO0_14.MCU_UART0_CTSn */ - J721E_WKUP_IOPAD(0xfc, PIN_OUTPUT, 0) /* (E21) WKUP_GPIO0_15.MCU_UART0_RTSn */ - >; - }; - - wkup_i2c0_pins_default: wkup-i2c0-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x100, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */ - J721E_WKUP_IOPAD(0x104, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */ - >; - }; - - mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (E20) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */ - J721E_WKUP_IOPAD(0x4, PIN_OUTPUT, 1) /* (C21) MCU_OSPI0_LBCLKO.MCU_HYPERBUS0_CKn */ - J721E_WKUP_IOPAD(0x2c, PIN_OUTPUT, 1) /* (F19) MCU_OSPI0_CSn0.MCU_HYPERBUS0_CSn0 */ - J721E_WKUP_IOPAD(0x54, PIN_OUTPUT, 3) /* (E22) MCU_OSPI1_CSn1.MCU_HYPERBUS0_CSn1 */ - J721E_WKUP_IOPAD(0x30, PIN_OUTPUT, 1) /* (E19) MCU_OSPI0_CSn1.MCU_HYPERBUS0_RESETn */ - J721E_WKUP_IOPAD(0x8, PIN_INPUT, 1) /* (D21) MCU_OSPI0_DQS.MCU_HYPERBUS0_RWDS */ - J721E_WKUP_IOPAD(0xc, PIN_INPUT, 1) /* (D20) MCU_OSPI0_D0.MCU_HYPERBUS0_DQ0 */ - J721E_WKUP_IOPAD(0x10, PIN_INPUT, 1) /* (G19) MCU_OSPI0_D1.MCU_HYPERBUS0_DQ1 */ - J721E_WKUP_IOPAD(0x14, PIN_INPUT, 1) /* (G20) MCU_OSPI0_D2.MCU_HYPERBUS0_DQ2 */ - J721E_WKUP_IOPAD(0x18, PIN_INPUT, 1) /* (F20) MCU_OSPI0_D3.MCU_HYPERBUS0_DQ3 */ - J721E_WKUP_IOPAD(0x1c, PIN_INPUT, 1) /* (F21) MCU_OSPI0_D4.MCU_HYPERBUS0_DQ4 */ - J721E_WKUP_IOPAD(0x20, PIN_INPUT, 1) /* (E21) MCU_OSPI0_D5.MCU_HYPERBUS0_DQ5 */ - J721E_WKUP_IOPAD(0x24, PIN_INPUT, 1) /* (B22) MCU_OSPI0_D6.MCU_HYPERBUS0_DQ6 */ - J721E_WKUP_IOPAD(0x28, PIN_INPUT, 1) /* (G21) MCU_OSPI0_D7.MCU_HYPERBUS0_DQ7 */ - >; - }; - - wkup_gpio_pins_default: wkup-gpio-pins-default { - pinctrl-single,pins = < - J721E_WKUP_IOPAD(0xd8, PIN_INPUT, 7) /* (C14) WKUP_GPIO0_6 */ - >; - }; -}; - -&main_pmx0 { - bootph-pre-ram; - - main_uart0_pins_default: main_uart0_pins_default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_IOPAD(0xb0, PIN_INPUT, 0) /* (T16) UART0_RXD */ - J721E_IOPAD(0xb4, PIN_OUTPUT, 0) /* (T17) UART0_TXD */ - J721E_IOPAD(0xc0, PIN_INPUT, 2) /* (W3) SPI0_CS0.UART0_CTSn */ - J721E_IOPAD(0xc4, PIN_OUTPUT, 2) /* (U5) SPI0_CS1.UART0_RTSn */ - >; - }; - - main_i2c0_pins_default: main-i2c0-pins-default { - bootph-pre-ram; - pinctrl-single,pins = < - J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ - J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ - >; - }; - - main_mmc1_pins_default: main_mmc1_pins_default { - pinctrl-single,pins = < - J721E_IOPAD(0x104, PIN_INPUT, 0) /* (M20) MMC1_CMD */ - J721E_IOPAD(0x100, PIN_INPUT, 0) /* (P21) MMC1_CLK */ - J721E_IOPAD(0xfc, PIN_INPUT, 0) /* (P25) MMC1_CLKLB */ - J721E_IOPAD(0xf8, PIN_INPUT, 0) /* (M19) MMC1_DAT0 */ - J721E_IOPAD(0xf4, PIN_INPUT, 0) /* (N21) MMC1_DAT1 */ - J721E_IOPAD(0xf0, PIN_INPUT, 0) /* (N20) MMC1_DAT2 */ - J721E_IOPAD(0xec, PIN_INPUT, 0) /* (N19) MMC1_DAT3 */ - J721E_IOPAD(0xe4, PIN_INPUT, 8) /* (V1) TIMER_IO0.MMC1_SDCD */ - >; - }; - - main_usbss0_pins_default: main_usbss0_pins_default { - pinctrl-single,pins = < - J721E_IOPAD(0x120, PIN_OUTPUT, 0) /* (T4) USB0_DRVVBUS */ - >; - }; -}; - -&wkup_uart0 { bootph-pre-ram; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_uart0_pins_default>; - status = "okay"; -}; - -&mcu_uart0 { - /delete-property/ power-domains; - /delete-property/ clocks; - /delete-property/ clock-names; - pinctrl-names = "default"; - pinctrl-0 = <&mcu_uart0_pins_default>; - status = "okay"; - clock-frequency = <96000000>; -}; - -&main_uart0 { - status = "okay"; - power-domains = <&k3_pds 146 TI_SCI_PD_SHARED>; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart0_pins_default>; - status = "okay"; -}; - -&main_sdhci0 { - /delete-property/ power-domains; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - pinctrl-0 = <&main_mmc1_pins_default>; - pinctrl-names = "default"; - clock-names = "clk_xin"; - clocks = <&clk_200mhz>; - ti,driver-strength-ohm = <50>; - non-removable; - bus-width = <8>; -}; - -&main_sdhci1 { - /delete-property/ power-domains; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - clock-names = "clk_xin"; - clocks = <&clk_200mhz>; - ti,driver-strength-ohm = <50>; -}; - -&wkup_i2c0 { - bootph-pre-ram; - lp876441: lp876441@4c { - compatible = "ti,lp876441"; - reg = <0x4c>; - bootph-pre-ram; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_i2c0_pins_default>; - clock-frequency = <400000>; - - regulators: regulators { - bootph-pre-ram; - buck1_reg: buck1 { - /*VDD_CPU_AVS_REG*/ - regulator-name = "buck1"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1250000>; - regulator-always-on; - regulator-boot-on; - bootph-pre-ram; - }; - }; - }; - };
&wkup_vtm0 { - vdd-supply-2 = <&buck1_reg>; bootph-pre-ram; }; - -&main_i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c0_pins_default>; - clock-frequency = <400000>; - - exp1: gpio@20 { - compatible = "ti,tca6416"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - }; - - exp2: gpio@22 { - compatible = "ti,tca6424"; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&usbss0 { - pinctrl-names = "default"; - pinctrl-0 = <&main_usbss0_pins_default>; - ti,vbus-divider; - ti,usb2-only; -}; - -&usb0 { - dr_mode = "otg"; - maximum-speed = "high-speed"; -}; - -&hbmc { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mcu_fss0_hpb0_pins_default>; - reg = <0x0 0x47040000 0x0 0x100>, - <0x0 0x50000000 0x0 0x8000000>; - ranges = <0x0 0x0 0x0 0x50000000 0x4000000>, /* 64MB Flash on CS0 */ - <0x1 0x0 0x0 0x54000000 0x800000>; /* 8MB flash on CS1 */ - - flash@0,0 { - compatible = "cypress,hyperflash", "cfi-flash"; - reg = <0x0 0x0 0x4000000>; - }; -}; - -&mcu_ringacc { - ti,sci = <&dm_tifs>; -}; - -&mcu_udmap { - ti,sci = <&dm_tifs>; -}; -#include "k3-j7200-common-proc-board-u-boot.dtsi" diff --git a/arch/arm/dts/k3-j7200-som-p0.dtsi b/arch/arm/dts/k3-j7200-som-p0.dtsi index 3472444017..5a300d4c8b 100644 --- a/arch/arm/dts/k3-j7200-som-p0.dtsi +++ b/arch/arm/dts/k3-j7200-som-p0.dtsi @@ -83,7 +83,7 @@ };
&wkup_pmx0 { - mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-pins-default { + mcu_fss0_hpb0_pins_default: mcu-fss0-hpb0-default-pins { pinctrl-single,pins = < J721E_WKUP_IOPAD(0x0, PIN_OUTPUT, 1) /* (B6) MCU_OSPI0_CLK.MCU_HYPERBUS0_CK */ J721E_WKUP_IOPAD(0x4, PIN_OUTPUT, 1) /* (C8) MCU_OSPI0_LBCLKO.MCU_HYPERBUS0_CKn */ @@ -101,7 +101,7 @@ >; };
- mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-pins-default { + mcu_fss0_ospi0_pins_default: mcu-fss0-ospi0-default-pins { pinctrl-single,pins = < J721E_WKUP_IOPAD(0x0000, PIN_OUTPUT, 0) /* MCU_OSPI0_CLK */ J721E_WKUP_IOPAD(0x002c, PIN_OUTPUT, 0) /* MCU_OSPI0_CSn0 */ @@ -118,8 +118,17 @@ }; };
+&wkup_pmx2 { + wkup_i2c0_pins_default: wkup-i2c0-default-pins { + pinctrl-single,pins = < + J721E_WKUP_IOPAD(0x98, PIN_INPUT_PULLUP, 0) /* (F20) WKUP_I2C0_SCL */ + J721E_WKUP_IOPAD(0x9c, PIN_INPUT_PULLUP, 0) /* (H21) WKUP_I2C0_SDA */ + >; + }; +}; + &main_pmx0 { - main_i2c0_pins_default: main-i2c0-pins-default { + main_i2c0_pins_default: main-i2c0-default-pins { pinctrl-single,pins = < J721E_IOPAD(0xd4, PIN_INPUT_PULLUP, 0) /* (V3) I2C0_SCL */ J721E_IOPAD(0xd8, PIN_INPUT_PULLUP, 0) /* (W2) I2C0_SDA */ @@ -140,10 +149,42 @@ flash@0,0 { compatible = "cypress,hyperflash", "cfi-flash"; reg = <0x00 0x00 0x4000000>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "hbmc.tiboot3"; + reg = <0x0 0x100000>; + }; + + partition@100000 { + label = "hbmc.tispl"; + reg = <0x100000 0x200000>; + }; + + partition@300000 { + label = "hbmc.u-boot"; + reg = <0x300000 0x400000>; + }; + + partition@700000 { + label = "hbmc.env"; + reg = <0x700000 0x40000>; + }; + + partition@800000 { + label = "hbmc.rootfs"; + reg = <0x800000 0x3800000>; + }; + }; }; };
&mailbox0_cluster0 { + status = "okay"; interrupts = <436>;
mbox_mcu_r5fss0_core0: mbox-mcu-r5fss0-core0 { @@ -158,6 +199,7 @@ };
&mailbox0_cluster1 { + status = "okay"; interrupts = <432>;
mbox_main_r5fss0_core0: mbox-main-r5fss0-core0 { @@ -171,66 +213,26 @@ }; };
-&mailbox0_cluster2 { - status = "disabled"; -}; - -&mailbox0_cluster3 { - status = "disabled"; -}; - -&mailbox0_cluster4 { - status = "disabled"; -}; - -&mailbox0_cluster5 { - status = "disabled"; -}; - -&mailbox0_cluster6 { - status = "disabled"; -}; - -&mailbox0_cluster7 { - status = "disabled"; -}; - -&mailbox0_cluster8 { - status = "disabled"; -}; - -&mailbox0_cluster9 { - status = "disabled"; -}; - -&mailbox0_cluster10 { - status = "disabled"; -}; - -&mailbox0_cluster11 { - status = "disabled"; -}; - &mcu_r5fss0_core0 { - mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core0>; + mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core0>; memory-region = <&mcu_r5fss0_core0_dma_memory_region>, <&mcu_r5fss0_core0_memory_region>; };
&mcu_r5fss0_core1 { - mboxes = <&mailbox0_cluster0 &mbox_mcu_r5fss0_core1>; + mboxes = <&mailbox0_cluster0>, <&mbox_mcu_r5fss0_core1>; memory-region = <&mcu_r5fss0_core1_dma_memory_region>, <&mcu_r5fss0_core1_memory_region>; };
&main_r5fss0_core0 { - mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core0>; + mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core0>; memory-region = <&main_r5fss0_core0_dma_memory_region>, <&main_r5fss0_core0_memory_region>; };
&main_r5fss0_core1 { - mboxes = <&mailbox0_cluster1 &mbox_main_r5fss0_core1>; + mboxes = <&mailbox0_cluster1>, <&mbox_main_r5fss0_core1>; memory-region = <&main_r5fss0_core1_dma_memory_region>, <&main_r5fss0_core1_memory_region>; }; @@ -252,11 +254,24 @@ }; };
+&wkup_i2c0 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>; + + eeprom@50 { + compatible = "atmel,24c256"; + reg = <0x50>; + }; +}; + &ospi0 { + status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&mcu_fss0_ospi0_pins_default>;
- flash@0{ + flash@0 { compatible = "jedec,spi-nor"; reg = <0x0>; spi-tx-bus-width = <8>; @@ -267,7 +282,46 @@ cdns,tchsh-ns = <60>; cdns,tslch-ns = <60>; cdns,read-delay = <4>; - #address-cells = <1>; - #size-cells = <1>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "ospi.tiboot3"; + reg = <0x0 0x100000>; + }; + + partition@100000 { + label = "ospi.tispl"; + reg = <0x100000 0x200000>; + }; + + partition@300000 { + label = "ospi.u-boot"; + reg = <0x300000 0x400000>; + }; + + partition@700000 { + label = "ospi.env"; + reg = <0x700000 0x40000>; + }; + + partition@740000 { + label = "ospi.env.backup"; + reg = <0x740000 0x40000>; + }; + + partition@800000 { + label = "ospi.rootfs"; + reg = <0x800000 0x37c0000>; + }; + + partition@3fc0000 { + label = "ospi.phypattern"; + reg = <0x3fc0000 0x40000>; + }; + }; }; }; diff --git a/arch/arm/dts/k3-j7200-thermal.dtsi b/arch/arm/dts/k3-j7200-thermal.dtsi new file mode 100644 index 0000000000..e7e3a643a6 --- /dev/null +++ b/arch/arm/dts/k3-j7200-thermal.dtsi @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include <dt-bindings/thermal/thermal.h> + +thermal_zones: thermal-zones { + mcu_thermal: mcu-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 0>; + + trips { + wkup_crit: wkup-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; + }; + + mpu_thermal: mpu-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 1>; + + trips { + mpu_crit: mpu-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; + }; + + main_thermal: main-thermal { + polling-delay-passive = <250>; /* milliseconds */ + polling-delay = <500>; /* milliseconds */ + thermal-sensors = <&wkup_vtm0 2>; + + trips { + c7x_crit: c7x-crit { + temperature = <125000>; /* milliCelsius */ + hysteresis = <2000>; /* milliCelsius */ + type = "critical"; + }; + }; + }; +}; diff --git a/arch/arm/dts/k3-j7200.dtsi b/arch/arm/dts/k3-j7200.dtsi index b7005b8031..ef73e6d7e8 100644 --- a/arch/arm/dts/k3-j7200.dtsi +++ b/arch/arm/dts/k3-j7200.dtsi @@ -7,9 +7,10 @@
#include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/pinctrl/k3.h> #include <dt-bindings/soc/ti,sci_pm_domain.h>
+#include "k3-pinctrl.h" + / { model = "Texas Instruments K3 J7200 SoC"; compatible = "ti,j7200"; @@ -17,21 +18,6 @@ #address-cells = <2>; #size-cells = <2>;
- aliases { - serial0 = &wkup_uart0; - serial1 = &mcu_uart0; - serial2 = &main_uart0; - serial3 = &main_uart1; - serial4 = &main_uart2; - serial5 = &main_uart3; - serial6 = &main_uart4; - serial7 = &main_uart5; - serial8 = &main_uart6; - serial9 = &main_uart7; - serial10 = &main_uart8; - serial11 = &main_uart9; - }; - chosen { };
cpus { @@ -60,7 +46,7 @@ i-cache-sets = <256>; d-cache-size = <0x8000>; d-cache-line-size = <64>; - d-cache-sets = <128>; + d-cache-sets = <256>; next-level-cache = <&L2_0>; };
@@ -74,7 +60,7 @@ i-cache-sets = <256>; d-cache-size = <0x8000>; d-cache-line-size = <64>; - d-cache-sets = <128>; + d-cache-sets = <256>; next-level-cache = <&L2_0>; }; }; @@ -82,15 +68,17 @@ L2_0: l2-cache0 { compatible = "cache"; cache-level = <2>; + cache-unified; cache-size = <0x100000>; cache-line-size = <64>; - cache-sets = <2048>; + cache-sets = <1024>; next-level-cache = <&msmc_l3>; };
msmc_l3: l3-cache0 { compatible = "cache"; cache-level = <3>; + cache-unified; };
firmware { @@ -124,9 +112,11 @@ #size-cells = <2>; ranges = <0x00 0x00100000 0x00 0x00100000 0x00 0x00020000>, /* ctrl mmr */ <0x00 0x00600000 0x00 0x00600000 0x00 0x00031100>, /* GPIO */ + <0x00 0x00700000 0x00 0x00700000 0x00 0x00001000>, /* ESM */ <0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* timesync router */ <0x00 0x01000000 0x00 0x01000000 0x00 0x0d000000>, /* Most peripherals */ <0x00 0x30000000 0x00 0x30000000 0x00 0x0c400000>, /* MAIN NAVSS */ + <0x00 0x6f000000 0x00 0x6f000000 0x00 0x00310000>, /* A72 PERIPHBASE */ <0x00 0x70000000 0x00 0x70000000 0x00 0x00800000>, /* MSMC RAM */ <0x00 0x18000000 0x00 0x18000000 0x00 0x08000000>, /* PCIe1 DAT0 */ <0x41 0x00000000 0x41 0x00000000 0x01 0x00000000>, /* PCIe1 DAT1 */ @@ -165,6 +155,8 @@ <0x07 0x00000000 0x07 0x00000000 0x01 0x00000000>; /* FSS OSPI1 data region 3 */ }; }; + + #include "k3-j7200-thermal.dtsi" };
/* Now include the peripherals for each bus segments */
On 13:12-20231005, Reid Tonking wrote:
Sync j7200 dts with Linux 6.6-rc1
k3-j7200-r5-common-proc-board.dts now inherits from k3-j7200-common-proc-board.dts instead of k3-j7200-som-p0.dtsi. This allows us to trim down the r5 file considerably by using existing properties
remove pimux nodes from r5 file
remove duplicate nodes & node properties from r5/u-boot files
mcu_timer0 now used instead of timer1
mcu_timer0 device id added to dev-data.c file in order to work
remove cpsw node
This node is no longer required since the compatible is now fixed
remove dummy_clock_19_2_mhz
This node wasn't being used anyhere, so it was removed
remove dummy_clock_200mhz
main_sdhci0 & main_sdhci1 no longer need dummy clock for eMMC/SD
fix secure proxy node
mcu_secproxy changed to used secure_prxy_mcu which is already defined in k3-j7200-mcu-wakeup.dtsi
removed &mcu_ringacc property override since they're present in v6.6-rc1
Signed-off-by: Reid Tonking reidt@ti.com
Reviewed-by: Nishanth Menon nm@ti.com [...]
remove cpsw node
Signed-off-by: Reid Tonking reidt@ti.com Reviewed-by: Nishanth Menon nm@ti.com
Nishanth Menon
Reid Tonking
