[U-Boot] [PATCH 1/3] sunxi:Added NAND Flash defines and MMC2 IO defines for sun6i
From 5c6f29ec1882c9f87c6e789e0ae06a974f6c32e0 Mon Sep 17 00:00:00 2001 From: Zhi Yuan Wan dv.xw@qq.com Date: Thu, 25 Jun 2015 19:59:39 +0800 Subject: [PATCH 1/3] sunxi:Added NAND Flash defines and MMC2 IO defines for sun6i Signed-off-by: Zhi Yuan Wan dv.xw@qq.com
--- arch/arm/dts/sun6i-a31.dtsi | 85 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 85 insertions(+)
diff --git a/arch/arm/dts/sun6i-a31.dtsi b/arch/arm/dts/sun6i-a31.dtsi index 008047a..a9100b9 100644 --- a/arch/arm/dts/sun6i-a31.dtsi +++ b/arch/arm/dts/sun6i-a31.dtsi @@ -306,6 +306,14 @@ "apb2_uart4", "apb2_uart5"; };
+ nand_clk: clk@01c20080 { + #clock-cells = <0>; + compatible = "allwinner,sun4i-a10-mod0-clk"; + reg = <0x01c20080 0x4>; + clocks = <&osc24M>, <&pll6 1>; + clock-output-names = "nand"; + }; + mmc0_clk: clk@01c20088 { #clock-cells = <1>; compatible = "allwinner,sun4i-a10-mmc-clk"; @@ -427,6 +435,17 @@ #size-cells = <1>; ranges;
+ nfc: nand@01c03000 { + compatible = "allwinner,sunxi-nand"; + reg = <0x01c03000 0x1000>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ahb1_gates 13>, <&nand_clk>; + clock-names = "ahb", "mod"; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + dma: dma-controller@01c02000 { compatible = "allwinner,sun6i-a31-dma"; reg = <0x01c02000 0x1000>; @@ -647,6 +666,14 @@ allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; };
+ mmc2_pins_a: mmc2@0 { + allwinner,pins = "PC6", "PC7", "PC8", "PC9", + "PC10", "PC11"; + allwinner,function = "mmc2"; + allwinner,drive = <SUN4I_PINCTRL_30_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; + gmac_pins_mii_a: gmac_mii@0 { allwinner,pins = "PA0", "PA1", "PA2", "PA3", "PA8", "PA9", "PA11", @@ -688,6 +715,59 @@ allwinner,drive = <SUN4I_PINCTRL_40_MA>; allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; }; + + nand_pins_a: nand_base0@0 { + allwinner,pins = "PC0", "PC1", "PC2", + "PC5", "PC8", "PC9", "PC10", + "PC11", "PC12", "PC13", "PC14", + "PC15", "PC16"; + allwinner,function = "nand0"; + allwinner,drive = <0>; + allwinner,pull = <0>; + }; + + nand_cs0_pins_a: nand_cs@0 { + allwinner,pins = "PC4"; + allwinner,function = "nand0"; + allwinner,drive = <0>; + allwinner,pull = <0>; + }; + + nand_cs1_pins_a: nand_cs@1 { + allwinner,pins = "PC3"; + allwinner,function = "nand0"; + allwinner,drive = <0>; + allwinner,pull = <0>; + }; + + nand_cs2_pins_a: nand_cs@2 { + allwinner,pins = "PC25"; + allwinner,function = "nand0"; + allwinner,drive = <0>; + allwinner,pull = <0>; + }; + + nand_cs3_pins_a: nand_cs@3 { + allwinner,pins = "PC26"; + allwinner,function = "nand0"; + allwinner,drive = <0>; + allwinner,pull = <0>; + }; + + nand_rb0_pins_a: nand_rb@0 { + allwinner,pins = "PC6"; + allwinner,function = "nand0"; + allwinner,drive = <0>; + allwinner,pull = <0>; + }; + + nand_rb1_pins_a: nand_rb@1 { + allwinner,pins = "PC7"; + allwinner,function = "nand0"; + allwinner,drive = <0>; + allwinner,pull = <0>; + }; + };
ahb1_rst: reset@01c202c0 { @@ -948,6 +1028,11 @@ <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; };
+ sid: eeprom@01c23800 { + compatible = "allwinner,sun6i-a31-sid"; + reg = <0x01c23800 0x200>; + }; + nmi_intc: interrupt-controller@01f00c0c { compatible = "allwinner,sun6i-a31-sc-nmi"; interrupt-controller;
First of all thanks for the patches.
I've a question about this series in general, this series is for the Mele i7 board, correct?
AFAIK that board has regular NAND, not an eMMC.
It seems your version has an eMMC though, so it seems that there are 2 versions of the board. Are you sure you have an I7 and not some other Mele model?
Either way please create a new dts file and defconfig for your board with emmc, if it really is an I7 use Mele_I7_eMMC_defconfig as defconfig file name, and sun6i-a31-mele-i7-emmc.dts as dts filename.
I've added some further comments to these patches inline.
Please submit dts file patches to the upstream linux kernel first, using the standard kernel patch submission process.
#clock-cells = <0>;
You are only making nand related additions here, yet your subject talks about mmc2 io-defines, please fix your commit message to not mention the mmc2 io-defines.
This is wrong, the correct compatible would be: "allwinner,sun4i-a10-nand" have you tested this at all ?
Since you say you've a board with eMMC I believe this is untested. Please do not submit untested changes.
If you are not using the nand bits, please drop this patch from your patchset.
#size-cells = <0>;
"PC10", "PC11";
"PC15", "PC16";
}; ahb1_rst: reset@01c202c0 {
This addition of the sid node is completely unrelated to the other changes on this commit.
Also this is wrong, the A31 does not have a SID, contrary to what the datasheets say there is nothing at address 1c23800.
Please drop this part of this patch.
Regards,
Hans
Hans de Goede
加特技的肖特基
