[PATCH 01/15] xtensa: Switch to using CONFIG_XTENSA for building device trees
The only use of CONFIG_XTFPGA was to build all of the in-tree device trees. Switch to using CONFIG_XTENSA instead of a non-Kconfig symbol.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/xtensa/dts/Makefile | 2 +- include/configs/xtfpga.h | 6 ------ 2 files changed, 1 insertion(+), 7 deletions(-)
diff --git a/arch/xtensa/dts/Makefile b/arch/xtensa/dts/Makefile index fbbdefaf2cf1..c22c50ac4e5d 100644 --- a/arch/xtensa/dts/Makefile +++ b/arch/xtensa/dts/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-dtb-$(CONFIG_XTFPGA) += ml605.dtb ml605_nommu.dtb kc705.dtb kc705_nommu.dtb +dtb-$(CONFIG_XTENSA) += ml605.dtb ml605_nommu.dtb kc705.dtb kc705_nommu.dtb
include $(srctree)/scripts/Makefile.dts
diff --git a/include/configs/xtfpga.h b/include/configs/xtfpga.h index 7392582b5e46..f1ea47654671 100644 --- a/include/configs/xtfpga.h +++ b/include/configs/xtfpga.h @@ -16,12 +16,6 @@ * differences. */
-/*=====================*/ -/* Board and Processor */ -/*=====================*/ - -#define CONFIG_XTFPGA - /*===================*/ /* RAM Layout */ /*===================*/
The migration deadline for this has passed and all boards have been updated, remove this legacy code and references for it.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/ata/dwc_ahsata.c | 133 ----------------------------------- include/configs/cm_fx6.h | 2 - include/configs/ge_bx50v3.h | 2 - include/configs/gw_ventana.h | 2 - include/configs/m53menlo.h | 2 - include/configs/mx53loco.h | 2 - include/configs/mx6cuboxi.h | 2 - include/configs/nitrogen6x.h | 2 - include/configs/tbs2910.h | 2 - include/configs/wandboard.h | 2 - 10 files changed, 151 deletions(-)
diff --git a/drivers/ata/dwc_ahsata.c b/drivers/ata/dwc_ahsata.c index d9fd850c6fae..1a2c3c2fe707 100644 --- a/drivers/ata/dwc_ahsata.c +++ b/drivers/ata/dwc_ahsata.c @@ -844,138 +844,6 @@ static ulong sata_write_common(struct ahci_uc_priv *uc_priv, return rc; }
-#if !CONFIG_IS_ENABLED(AHCI) -static int ahci_init_one(int pdev) -{ - int rc; - struct ahci_uc_priv *uc_priv = NULL; - - uc_priv = malloc(sizeof(struct ahci_uc_priv)); - if (!uc_priv) - return -ENOMEM; - - memset(uc_priv, 0, sizeof(struct ahci_uc_priv)); - uc_priv->dev = pdev; - - uc_priv->host_flags = ATA_FLAG_SATA - | ATA_FLAG_NO_LEGACY - | ATA_FLAG_MMIO - | ATA_FLAG_PIO_DMA - | ATA_FLAG_NO_ATAPI; - - uc_priv->mmio_base = (void __iomem *)CONFIG_DWC_AHSATA_BASE_ADDR; - - /* initialize adapter */ - rc = ahci_host_init(uc_priv); - if (rc) - goto err_out; - - ahci_print_info(uc_priv); - - /* Save the uc_private struct to block device struct */ - sata_dev_desc[pdev].priv = uc_priv; - - return 0; - -err_out: - if (uc_priv) - free(uc_priv); - return rc; -} - -int init_sata(int dev) -{ - struct ahci_uc_priv *uc_priv = NULL; - -#if defined(CONFIG_MX6) - if (!is_mx6dq() && !is_mx6dqp()) - return 1; -#endif - if (dev < 0 || dev > (CONFIG_SYS_SATA_MAX_DEVICE - 1)) { - printf("The sata index %d is out of ranges\n\r", dev); - return -1; - } - - ahci_init_one(dev); - - uc_priv = sata_dev_desc[dev].priv; - - return dwc_ahci_start_ports(uc_priv) ? 1 : 0; -} - -int reset_sata(int dev) -{ - struct ahci_uc_priv *uc_priv; - struct sata_host_regs *host_mmio; - - if (dev < 0 || dev > (CONFIG_SYS_SATA_MAX_DEVICE - 1)) { - printf("The sata index %d is out of ranges\n\r", dev); - return -1; - } - - uc_priv = sata_dev_desc[dev].priv; - if (NULL == uc_priv) - /* not initialized, so nothing to reset */ - return 0; - - host_mmio = uc_priv->mmio_base; - setbits_le32(&host_mmio->ghc, SATA_HOST_GHC_HR); - while (readl(&host_mmio->ghc) & SATA_HOST_GHC_HR) - udelay(100); - - free(uc_priv); - memset(&sata_dev_desc[dev], 0, sizeof(struct blk_desc)); - - return 0; -} - -int sata_port_status(int dev, int port) -{ - struct sata_port_regs *port_mmio; - struct ahci_uc_priv *uc_priv = NULL; - - if (dev < 0 || dev > (CONFIG_SYS_SATA_MAX_DEVICE - 1)) - return -EINVAL; - - if (sata_dev_desc[dev].priv == NULL) - return -ENODEV; - - uc_priv = sata_dev_desc[dev].priv; - port_mmio = uc_priv->port[port].port_mmio; - - return readl(&port_mmio->ssts) & SATA_PORT_SSTS_DET_MASK; -} - -/* - * SATA interface between low level driver and command layer - */ -ulong sata_read(int dev, ulong blknr, lbaint_t blkcnt, void *buffer) -{ - struct ahci_uc_priv *uc_priv = sata_dev_desc[dev].priv; - - return sata_read_common(uc_priv, &sata_dev_desc[dev], blknr, blkcnt, - buffer); -} - -ulong sata_write(int dev, ulong blknr, lbaint_t blkcnt, const void *buffer) -{ - struct ahci_uc_priv *uc_priv = sata_dev_desc[dev].priv; - - return sata_write_common(uc_priv, &sata_dev_desc[dev], blknr, blkcnt, - buffer); -} - -int scan_sata(int dev) -{ - struct ahci_uc_priv *uc_priv = sata_dev_desc[dev].priv; - struct blk_desc *pdev = &sata_dev_desc[dev]; - - return dwc_ahsata_scan_common(uc_priv, pdev); -} -#endif /* CONFIG_IS_ENABLED(AHCI) */ - -#if CONFIG_IS_ENABLED(AHCI) - int dwc_ahsata_port_status(struct udevice *dev, int port) { struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev); @@ -1109,4 +977,3 @@ U_BOOT_DRIVER(dwc_ahsata_ahci) = { .probe = dwc_ahsata_probe, }; #endif -#endif diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 07ad6fde28d0..a0bbb409cff4 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -151,8 +151,6 @@
/* SATA */ #define CONFIG_LBA48 -#define CONFIG_DWC_AHSATA_PORT_ID 0 -#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR
/* Boot */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 74a2eaa78962..66ea80982b6c 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -19,8 +19,6 @@
/* SATA Configs */ #ifdef CONFIG_CMD_SATA -#define CONFIG_DWC_AHSATA_PORT_ID 0 -#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR #define CONFIG_LBA48 #endif
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 6aa6c6262e3f..53954cee3b3c 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -32,8 +32,6 @@ * SATA Configs */ #ifdef CONFIG_CMD_SATA - #define CONFIG_DWC_AHSATA_PORT_ID 0 - #define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR #define CONFIG_LBA48 #endif
diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index ed44f355da81..66230f0bf17e 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -86,8 +86,6 @@ * SATA */ #ifdef CONFIG_CMD_SATA -#define CONFIG_DWC_AHSATA_PORT_ID 0 -#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_BASE_ADDR #define CONFIG_LBA48 #endif
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 0268a48c86f4..0afd68b880e4 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -101,8 +101,6 @@ #define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE)
#ifdef CONFIG_CMD_SATA - #define CONFIG_DWC_AHSATA_PORT_ID 0 - #define CONFIG_DWC_AHSATA_BASE_ADDR SATA_BASE_ADDR #define CONFIG_LBA48 #endif
diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 76fbbf42daff..5b4fbba023f9 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -18,8 +18,6 @@
/* SATA Configuration */ #ifdef CONFIG_CMD_SATA -#define CONFIG_DWC_AHSATA_PORT_ID 0 -#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR #define CONFIG_LBA48 #endif
diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 72f2dfb5daca..9b84c36f5145 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -23,8 +23,6 @@ * SATA Configs */ #ifdef CONFIG_CMD_SATA -#define CONFIG_DWC_AHSATA_PORT_ID 0 -#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR #define CONFIG_LBA48 #endif
diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index eb63e75cddf5..3d0c856103e7 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -36,8 +36,6 @@
/* SATA */ #ifdef CONFIG_CMD_SATA -#define CONFIG_DWC_AHSATA_PORT_ID 0 -#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR #define CONFIG_LBA48 #define CONFIG_SYS_64BIT_LBA #endif diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index d4224127146e..eb0778d072a5 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -17,8 +17,6 @@ /* SATA Configs */
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/ata/fsl_sata.c | 70 ++------------------------------ drivers/ata/fsl_sata.h | 2 - include/configs/MPC837XERDB.h | 9 ---- include/configs/P1010RDB.h | 7 ---- include/configs/P2041RDB.h | 7 ---- include/configs/T104xRDB.h | 4 -- include/configs/T208xQDS.h | 6 --- include/configs/T208xRDB.h | 6 --- include/configs/T4240RDB.h | 14 ------- include/configs/corenet_ds.h | 7 ---- include/configs/ls1028aqds.h | 1 - include/configs/ls1028ardb.h | 1 - include/configs/ls1088a_common.h | 5 --- include/configs/ls2080aqds.h | 5 --- include/configs/ls2080ardb.h | 5 --- include/configs/lx2160a_common.h | 7 ---- 16 files changed, 3 insertions(+), 153 deletions(-)
diff --git a/drivers/ata/fsl_sata.c b/drivers/ata/fsl_sata.c index d1bab931895a..6db4247368eb 100644 --- a/drivers/ata/fsl_sata.c +++ b/drivers/ata/fsl_sata.c @@ -6,10 +6,13 @@ */
#include <common.h> +#include <ahci.h> #include <blk.h> #include <command.h> #include <console.h> #include <cpu_func.h> +#include <dm.h> +#include <dm/device-internal.h> #include <log.h> #include <asm/io.h> #include <asm/processor.h> @@ -21,33 +24,6 @@ #include <linux/delay.h> #include "fsl_sata.h"
-#if CONFIG_IS_ENABLED(BLK) -#include <dm.h> -#include <ahci.h> -#include <blk.h> -#include <dm/device-internal.h> -#else -#ifndef CONFIG_SYS_SATA1_FLAGS - #define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA -#endif -#ifndef CONFIG_SYS_SATA2_FLAGS - #define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA -#endif - -static struct fsl_sata_info fsl_sata_info[] = { -#ifdef CONFIG_SATA1 - {CONFIG_SYS_SATA1, CONFIG_SYS_SATA1_FLAGS}, -#else - {0, 0}, -#endif -#ifdef CONFIG_SATA2 - {CONFIG_SYS_SATA2, CONFIG_SYS_SATA2_FLAGS}, -#else - {0, 0}, -#endif -}; -#endif - static inline void sdelay(unsigned long sec) { unsigned long i; @@ -86,11 +62,7 @@ static int ata_wait_register(unsigned __iomem *addr, u32 mask, return (i < timeout_msec) ? 0 : -1; }
-#if !CONFIG_IS_ENABLED(BLK) -int init_sata(int dev) -#else static int init_sata(struct fsl_ata_priv *priv, int dev) -#endif { u32 length, align; cmd_hdr_tbl_t *cmd_hdr; @@ -129,15 +101,9 @@ static int init_sata(struct fsl_ata_priv *priv, int dev) snprintf(sata->name, 12, "SATA%d:", dev);
/* Set the controller register base address to device struct */ -#if !CONFIG_IS_ENABLED(BLK) - sata_dev_desc[dev].priv = (void *)sata; - reg = (fsl_sata_reg_t *)(fsl_sata_info[dev].sata_reg_base); - sata->dma_flag = fsl_sata_info[dev].flags; -#else reg = (fsl_sata_reg_t *)(priv->base + priv->offset * dev); sata->dma_flag = priv->flag; priv->fsl_sata = sata; -#endif sata->reg_base = reg;
/* Allocate the command header table, 4 bytes aligned */ @@ -738,17 +704,11 @@ static u32 ata_low_level_rw_lba28(fsl_sata_t *sata, u32 blknr, u32 blkcnt, /* * SATA interface between low level driver and command layer */ -#if !CONFIG_IS_ENABLED(BLK) -ulong sata_read(int dev, ulong blknr, lbaint_t blkcnt, void *buffer) -{ - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; -#else static ulong sata_read(struct udevice *dev, lbaint_t blknr, lbaint_t blkcnt, void *buffer) { struct fsl_ata_priv *priv = dev_get_plat(dev); fsl_sata_t *sata = priv->fsl_sata; -#endif u32 rc;
if (sata->lba48) @@ -760,17 +720,11 @@ static ulong sata_read(struct udevice *dev, lbaint_t blknr, lbaint_t blkcnt, return rc; }
-#if !CONFIG_IS_ENABLED(BLK) -ulong sata_write(int dev, ulong blknr, lbaint_t blkcnt, const void *buffer) -{ - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; -#else static ulong sata_write(struct udevice *dev, lbaint_t blknr, lbaint_t blkcnt, const void *buffer) { struct fsl_ata_priv *priv = dev_get_plat(dev); fsl_sata_t *sata = priv->fsl_sata; -#endif u32 rc;
if (sata->lba48) { @@ -801,17 +755,11 @@ static void fsl_sata_identify(fsl_sata_t *sata, u16 *id) ata_swap_buf_le16(id, ATA_ID_WORDS); }
-#if !CONFIG_IS_ENABLED(BLK) -int scan_sata(int dev) -{ - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; -#else static int scan_sata(struct udevice *dev) { struct blk_desc *desc = dev_get_uclass_plat(dev); struct fsl_ata_priv *priv = dev_get_plat(dev); fsl_sata_t *sata = priv->fsl_sata; -#endif
unsigned char serial[ATA_ID_SERNO_LEN + 1]; unsigned char firmware[ATA_ID_FW_REV_LEN + 1]; @@ -853,22 +801,12 @@ static int scan_sata(struct udevice *dev) debug("Device supports LBA28\n\r"); #endif
-#if !CONFIG_IS_ENABLED(BLK) - memcpy(sata_dev_desc[dev].product, serial, sizeof(serial)); - memcpy(sata_dev_desc[dev].revision, firmware, sizeof(firmware)); - memcpy(sata_dev_desc[dev].vendor, product, sizeof(product)); - sata_dev_desc[dev].lba = (u32)n_sectors; -#ifdef CONFIG_LBA48 - sata_dev_desc[dev].lba48 = sata->lba48; -#endif -#else memcpy(desc->product, serial, sizeof(serial)); memcpy(desc->revision, firmware, sizeof(firmware)); memcpy(desc->vendor, product, sizeof(product)); desc->lba = n_sectors; #ifdef CONFIG_LBA48 desc->lba48 = sata->lba48; -#endif #endif
/* Get the NCQ queue depth from device */ @@ -890,7 +828,6 @@ static int scan_sata(struct udevice *dev) return 0; }
-#if CONFIG_IS_ENABLED(BLK) static const struct blk_ops sata_fsl_blk_ops = { .read = sata_read, .write = sata_write, @@ -1042,4 +979,3 @@ U_BOOT_DRIVER(fsl_ahci) = { .remove = fsl_ata_remove, .priv_auto = sizeof(struct fsl_ata_priv), }; -#endif diff --git a/drivers/ata/fsl_sata.h b/drivers/ata/fsl_sata.h index 5b9daa79e023..e1ea8eb3a183 100644 --- a/drivers/ata/fsl_sata.h +++ b/drivers/ata/fsl_sata.h @@ -319,7 +319,6 @@ typedef struct fsl_sata { #define READ_CMD 0 #define WRITE_CMD 1
-#if CONFIG_IS_ENABLED(BLK) struct fsl_ata_priv { u32 base; u32 flag; @@ -327,6 +326,5 @@ struct fsl_ata_priv { u32 offset; fsl_sata_t *fsl_sata; }; -#endif
#endif /* __FSL_SATA_H__ */ diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 4995bcee856d..de197a0bd117 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -265,15 +265,6 @@ /* * SATA */ -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1_OFFSET 0x18000 -#define CONFIG_SYS_SATA1 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA1_OFFSET) -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA -#define CONFIG_SATA2 -#define CONFIG_SYS_SATA2_OFFSET 0x19000 -#define CONFIG_SYS_SATA2 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA2_OFFSET) -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA - #ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 #endif diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index d5b8cfaea397..15add282d706 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -476,13 +476,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_FSL_SATA_V2
#ifdef CONFIG_FSL_SATA -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA -#define CONFIG_SATA2 -#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA - #define CONFIG_LBA48 #endif /* #ifdef CONFIG_FSL_SATA */
diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 38acb38690d8..8a7123921bb2 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -340,13 +340,6 @@ #define CONFIG_FSL_SATA_V2
#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA -#define CONFIG_SATA2 -#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA - #define CONFIG_LBA48 #endif
diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index bb05b2ed7c98..e7ebf795451d 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -393,10 +393,6 @@ /* SATA */ #define CONFIG_FSL_SATA_V2 #ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA - #define CONFIG_LBA48 #endif
diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index e46488b3c0ed..06be25bf5a75 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -462,12 +462,6 @@ * SATA */ #ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA -#define CONFIG_SATA2 -#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA #define CONFIG_LBA48 #endif
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index d4bf938ac6f6..f96208d26579 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -418,12 +418,6 @@ * SATA */ #ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA -#define CONFIG_SATA2 -#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA #define CONFIG_LBA48 #endif
diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index ebdd47edf952..542786aeef18 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -155,13 +155,6 @@
/* SATA */ #ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA -#define CONFIG_SATA2 -#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA - #define CONFIG_LBA48 #endif
@@ -435,13 +428,6 @@
diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 56b56e8a2e2c..6006f7638220 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -339,13 +339,6 @@
diff --git a/include/configs/ls1028aqds.h b/include/configs/ls1028aqds.h index 35363ccda1aa..52703632a7e3 100644 --- a/include/configs/ls1028aqds.h +++ b/include/configs/ls1028aqds.h @@ -60,7 +60,6 @@
/* SATA */
-#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 #ifndef SPL_NO_ENV #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/ls1028ardb.h b/include/configs/ls1028ardb.h index 91223789b839..665723b15116 100644 --- a/include/configs/ls1028ardb.h +++ b/include/configs/ls1028ardb.h @@ -53,7 +53,6 @@ #define SCSI_VEND_ID 0x1b4b #define SCSI_DEV_ID 0x9170 #define CONFIG_SCSI_DEV_LIST {SCSI_VEND_ID, SCSI_DEV_ID} -#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1
/* Initial environment variables */ #ifndef SPL_NO_ENV diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 9a29bb6ca1ea..ff85f1eb4ac8 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -115,11 +115,6 @@ unsigned long long get_qixis_addr(void);
/* Miscellaneous configurable options */
-/* SATA */ -#ifdef CONFIG_SCSI -#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 -#endif - /* Physical Memory Map */
#define CONFIG_HWCONFIG diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 9ce48a09602e..f2eae073810b 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -29,11 +29,6 @@ #define CONFIG_DP_DDR_DIMM_SLOTS_PER_CTLR 1 #endif
-/* SATA */ - -#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 -#define CONFIG_SYS_SATA2 AHCI_BASE_ADDR2 - #define CONFIG_SYS_NOR0_CSPR_EXT (0x0) #define CONFIG_SYS_NOR_AMASK IFC_AMASK(128*1024*1024) #define CONFIG_SYS_NOR_AMASK_EARLY IFC_AMASK(64*1024*1024) diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index cdfc9fd82e84..43bcc5a9b11c 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -34,11 +34,6 @@ #define CONFIG_DP_DDR_DIMM_SLOTS_PER_CTLR 1 #endif
-/* SATA */ - -#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 -#define CONFIG_SYS_SATA2 AHCI_BASE_ADDR2 - #if !defined(CONFIG_FSL_QSPI) || defined(CONFIG_TFABOOT)
#define CONFIG_SYS_NOR0_CSPR_EXT (0x0) diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 56096682c06e..f8c3a0923abd 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -95,13 +95,6 @@ #define CONFIG_PCI_SCAN_SHOW #endif
-/* SATA */ - -#ifdef CONFIG_SCSI -#define CONFIG_SYS_SATA1 AHCI_BASE_ADDR1 -#define CONFIG_SYS_SATA2 AHCI_BASE_ADDR2 -#endif - /* USB */ #ifdef CONFIG_USB_HOST #ifndef CONFIG_TARGET_LX2162AQDS
This converts the following to Kconfig: CONFIG_FSL_SATA_V2
Signed-off-by: Tom Rini trini@konsulko.com --- configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2080RDB_revD_NAND_defconfig | 1 + configs/T2080RDB_revD_SDCARD_defconfig | 1 + configs/T2080RDB_revD_SPIFLASH_defconfig | 1 + configs/T2080RDB_revD_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + drivers/ata/Kconfig | 7 +++++++ include/configs/P1010RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/P3041DS.h | 1 - include/configs/P5040DS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240RDB.h | 1 - 53 files changed, 51 insertions(+), 8 deletions(-)
diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 6c4142c200b5..85fa20534637 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -73,6 +73,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index fb74f9bd5b4f..1972f140f90d 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -42,6 +42,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 324ad908bb09..b057d1fad3d8 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -63,6 +63,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 2299f450a972..da5041068af3 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -66,6 +66,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 5813c75f10a6..b5ec62d3f9ae 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -72,6 +72,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 31cf6037e2fe..2e3dc8f5e701 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -41,6 +41,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index a51f9acd5861..ed63b5e936ba 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -62,6 +62,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index c2b5d7762ce3..4c22687db87b 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -65,6 +65,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 4caf43dade2a..4291cbf9c233 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -74,6 +74,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index d5a9287678a1..367632894b1c 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -43,6 +43,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 50053876f8ec..7182e0b33077 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -64,6 +64,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 6f0cd359abbf..45ef797b89fd 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -67,6 +67,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 16b52196aeb8..5e052733f57f 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -73,6 +73,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 9529d97bccfa..2cd571443da6 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -42,6 +42,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 6d3be4303a28..d8e872bd6d0e 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -63,6 +63,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index a54f7eab5f20..b9887e3e3e2f 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -66,6 +66,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=66666666 diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 9389d992562f..fac2bef7e6af 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -46,6 +46,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 31d5814d55c4..5516850bb3c2 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -46,6 +46,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 7e913c81366b..a42d21093c43 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -48,6 +48,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 23165b83f74f..8265602bcc7a 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -43,6 +43,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 7c5b6d288b04..0c07556ef242 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -44,6 +44,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 41ec73a6be44..2c5e5da15fb2 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -44,6 +44,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index bdbf2e959e3d..b8a1d6790998 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -46,6 +46,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 953cbd4b0b77..bce873a0bcc2 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -41,6 +41,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 6e0bdb2e1303..ac4bb3b19b44 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -45,6 +45,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index e040fab7cb8d..06214ca5c35f 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -44,6 +44,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 1e1a2f803657..0c9d564a12c3 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -46,6 +46,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index ec897c33231e..7e543872a16c 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -41,6 +41,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index b71659a6600d..6f3af93e8832 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -72,6 +72,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DYNAMIC_DDR_CLK_FREQ=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 1b8ef0cb365f..4314c924fac2 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -72,6 +72,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DYNAMIC_DDR_CLK_FREQ=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index f4a64abfb22d..4a4c6cde5cae 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -47,6 +47,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_DYNAMIC_DDR_CLK_FREQ=y CONFIG_DIMM_SLOTS_PER_CTLR=2 diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index bcef31a665fc..9d275b75fed8 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -75,6 +75,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DYNAMIC_DDR_CLK_FREQ=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 6158be76fe50..b5e0a539becd 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -45,6 +45,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DYNAMIC_DDR_CLK_FREQ=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index fd658454c4a0..1c14aedae2c2 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -48,6 +48,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DYNAMIC_DDR_CLK_FREQ=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 9e8e3ea8b5af..80c7b18634c6 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -74,6 +74,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133330000 diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index b6a0b857a725..80b33a9ed5b1 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -74,6 +74,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133330000 diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index b0f0d165cdd2..810eea042d94 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -77,6 +77,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133330000 diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 66d043309b36..18d9d547372d 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -50,6 +50,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133330000 diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index feba8e54b5cb..2a68163b5685 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -75,6 +75,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133330000 diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index 0495786bc5f9..a9af2951cb9b 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -75,6 +75,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133330000 diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index bb7c711d5575..a3cda0da8050 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -78,6 +78,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133330000 diff --git a/configs/T2080RDB_revD_defconfig b/configs/T2080RDB_revD_defconfig index 56b174fad742..c300b82ea8d8 100644 --- a/configs/T2080RDB_revD_defconfig +++ b/configs/T2080RDB_revD_defconfig @@ -51,6 +51,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC3" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133330000 diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index fb35c83f1b6c..2bc568939360 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -66,6 +66,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133333333 diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 4f19024a6be5..67061d03d564 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -42,6 +42,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_FSL_SATA_V2=y CONFIG_SYS_SATA_MAX_DEVICE=2 CONFIG_FSL_CAAM=y CONFIG_DDR_CLK_FREQ=133333333 diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index ce6907e69008..9c9641d2ed95 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -113,12 +113,19 @@ config SATA_CEVA
config FSL_SATA bool "Enable Freescale SATA controller driver support" + depends on PPC select AHCI select LIBATA help Enable this driver to support the SATA controller found in some Freescale PowerPC SoCs.
+config FSL_SATA_V2 + bool "Enable support for V2 of the Freescale SATA controller" + depends on FSL_SATA + help + Enable support for V2 of this controller, rather than V1. + config SATA_MV bool "Enable Marvell SATA controller driver support" select AHCI diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 15add282d706..287236f70f28 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -473,7 +473,6 @@ extern unsigned long get_sdram_size(void); #endif /* CONFIG_TSEC_ENET */
/* SATA */ -#define CONFIG_FSL_SATA_V2
#ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 8a7123921bb2..3c92a3e405b7 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -337,7 +337,6 @@ #endif /* CONFIG_PCI */
#ifdef CONFIG_FSL_SATA_V2 #define CONFIG_LBA48 diff --git a/include/configs/P3041DS.h b/include/configs/P3041DS.h index f1417b1bfc15..6063113634c7 100644 --- a/include/configs/P3041DS.h +++ b/include/configs/P3041DS.h @@ -9,7 +9,6 @@ */ #define CONFIG_FSL_NGPIXIS /* use common ngPIXIS code */
-#define CONFIG_FSL_SATA_V2 #define CONFIG_PCIE3 #define CONFIG_PCIE4 #define CONFIG_SYS_DPAA_RMAN diff --git a/include/configs/P5040DS.h b/include/configs/P5040DS.h index fc2a07b97410..6e6e5bec66be 100644 --- a/include/configs/P5040DS.h +++ b/include/configs/P5040DS.h @@ -10,7 +10,6 @@ #define CONFIG_FSL_NGPIXIS /* use common ngPIXIS code */
#define CONFIG_PCIE3 -#define CONFIG_FSL_SATA_V2 #define CONFIG_SYS_FSL_RAID_ENGINE
#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index e7ebf795451d..b832fb33d207 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -391,7 +391,6 @@ #endif /* CONFIG_PCI */
/* SATA */ -#define CONFIG_FSL_SATA_V2 #ifdef CONFIG_FSL_SATA_V2 #define CONFIG_LBA48 #endif diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 06be25bf5a75..a96c5bbd095e 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -15,7 +15,6 @@
#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */ #if defined(CONFIG_ARCH_T2080) -#define CONFIG_FSL_SATA_V2 #define CONFIG_SYS_SRIO /* Enable Serial RapidIO Support */ #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index f96208d26579..82531f69c440 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -14,7 +14,6 @@ #include <linux/stringify.h>
#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */ -#define CONFIG_FSL_SATA_V2
/* High Level Configuration Options */ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 542786aeef18..436f6d0fc8ef 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -12,7 +12,6 @@
-#define CONFIG_FSL_SATA_V2 #define CONFIG_PCIE4
This converts the following to Kconfig: CONFIG_LBA48 CONFIG_SYS_64BIT_LBA
Signed-off-by: Tom Rini trini@konsulko.com --- README | 12 ------------ arch/arm/mach-kirkwood/include/mach/config.h | 2 -- configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO-eMMC_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 + configs/A20-Olimex-SOM204-EVB_defconfig | 1 + configs/Bananapi_M2_Ultra_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 1 + configs/Lamobo_R1_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/bananapi_m1_plus_defconfig | 1 + configs/bananapi_m2_berry_defconfig | 1 + configs/bayleybay_defconfig | 2 ++ configs/cherryhill_defconfig | 2 ++ configs/chromebook_coral_defconfig | 2 ++ configs/chromebook_link64_defconfig | 2 ++ configs/chromebook_link_defconfig | 2 ++ configs/chromebook_samus_defconfig | 2 ++ configs/chromebook_samus_tpl_defconfig | 2 ++ configs/chromebox_panther_defconfig | 2 ++ configs/clearfog_gt_8k_defconfig | 2 ++ configs/cm_fx6_defconfig | 1 + ...nga-qeval20-qa3-e3845-internal-uart_defconfig | 2 ++ configs/conga-qeval20-qa3-e3845_defconfig | 2 ++ configs/coreboot64_defconfig | 2 ++ configs/coreboot_defconfig | 2 ++ configs/cougarcanyon2_defconfig | 2 ++ configs/crownbay_defconfig | 2 ++ configs/d2net_v2_defconfig | 2 ++ configs/db-mv784mp-gp_defconfig | 1 + configs/dfi-bt700-q7x-151_defconfig | 2 ++ configs/dh_imx6_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dreamplug_defconfig | 1 + configs/ds109_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/efi-x86_payload32_defconfig | 2 ++ configs/efi-x86_payload64_defconfig | 2 ++ configs/goflexhome_defconfig | 1 + configs/guruplug_defconfig | 1 + configs/gwventana_emmc_defconfig | 1 + configs/gwventana_gw5904_defconfig | 1 + configs/gwventana_nand_defconfig | 1 + configs/highbank_defconfig | 1 + configs/ib62x0_defconfig | 1 + configs/inetspace_v2_defconfig | 2 ++ configs/lschlv2_defconfig | 2 ++ configs/lsxhl_defconfig | 2 ++ configs/minnowmax_defconfig | 2 ++ configs/mvebu_crb_cn9130_defconfig | 2 ++ configs/mvebu_db-88f3720_defconfig | 2 ++ configs/mvebu_db_armada8k_defconfig | 2 ++ configs/mvebu_db_cn9130_defconfig | 2 ++ configs/mvebu_espressobin-88f3720_defconfig | 2 ++ configs/mvebu_mcbin-88f8040_defconfig | 2 ++ configs/mvebu_puzzle-m801-88f8040_defconfig | 2 ++ configs/mx6cuboxi_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/nas220_defconfig | 1 + configs/net2big_v2_defconfig | 2 ++ configs/netspace_lite_v2_defconfig | 2 ++ configs/netspace_max_v2_defconfig | 2 ++ configs/netspace_mini_v2_defconfig | 2 ++ configs/netspace_v2_defconfig | 2 ++ configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/novena_defconfig | 1 + configs/nsa310s_defconfig | 2 ++ configs/octeon_nic23_defconfig | 2 ++ configs/octeontx_81xx_defconfig | 2 ++ configs/octeontx_83xx_defconfig | 2 ++ configs/openrd_base_defconfig | 1 + configs/openrd_client_defconfig | 1 + configs/openrd_ultimate_defconfig | 1 + configs/pogo_v4_defconfig | 2 ++ configs/qemu-ppce500_defconfig | 1 + configs/qemu-x86_64_defconfig | 2 ++ configs/qemu-x86_defconfig | 2 ++ configs/sheevaplug_defconfig | 2 ++ configs/slimbootloader_defconfig | 2 ++ configs/som-db5800-som-6867_defconfig | 2 ++ configs/tbs2910_defconfig | 2 ++ ...dorable-x86-conga-qa3-e3845-pcie-x4_defconfig | 2 ++ .../theadorable-x86-conga-qa3-e3845_defconfig | 2 ++ configs/theadorable-x86-dfi-bt700_defconfig | 2 ++ configs/theadorable_debug_defconfig | 1 + configs/uDPU_defconfig | 2 ++ configs/udoo_defconfig | 1 + configs/wandboard_defconfig | 1 + drivers/ata/Kconfig | 1 + drivers/block/Kconfig | 16 ++++++++++++++++ include/configs/M5253DEMO.h | 1 - include/configs/MPC837XERDB.h | 7 ------- include/configs/P1010RDB.h | 6 ------ include/configs/P2041RDB.h | 6 ------ include/configs/P4080DS.h | 2 -- include/configs/T104xRDB.h | 5 ----- include/configs/T208xQDS.h | 7 ------- include/configs/T208xRDB.h | 7 ------- include/configs/T4240RDB.h | 10 ---------- include/configs/apalis_imx6.h | 7 ------- include/configs/cm_fx6.h | 3 --- include/configs/corenet_ds.h | 5 ----- include/configs/db-mv784mp-gp.h | 3 --- include/configs/dh_imx6.h | 3 --- include/configs/dreamplug.h | 5 ----- include/configs/edminiv2.h | 2 -- include/configs/ge_bx50v3.h | 5 ----- include/configs/goflexhome.h | 3 --- include/configs/gw_ventana.h | 7 ------- include/configs/highbank.h | 2 -- include/configs/lacie_kw.h | 12 ------------ include/configs/lsxl.h | 5 ----- include/configs/m53menlo.h | 7 ------- include/configs/mvebu_armada-37xx.h | 6 ------ include/configs/mvebu_armada-8k.h | 6 ------ include/configs/mx53loco.h | 4 ---- include/configs/mx6cuboxi.h | 5 ----- include/configs/nitrogen6x.h | 7 ------- include/configs/novena.h | 3 --- include/configs/nsa310s.h | 4 ---- include/configs/octeon_nic23.h | 9 --------- include/configs/octeontx_common.h | 8 -------- include/configs/p1_p2_rdb_pc.h | 2 -- include/configs/pogo_v4.h | 6 ------ include/configs/qemu-ppce500.h | 2 -- include/configs/sheevaplug.h | 6 ------ include/configs/sunxi-common.h | 4 ---- include/configs/tbs2910.h | 6 ------ include/configs/theadorable.h | 3 --- include/configs/udoo.h | 3 --- include/configs/wandboard.h | 6 ------ include/configs/x86-common.h | 7 ------- 174 files changed, 195 insertions(+), 231 deletions(-)
diff --git a/README b/README index 3603a9a46a37..c95f4334199e 100644 --- a/README +++ b/README @@ -664,18 +664,6 @@ The following options need to be configured: CONFIG_SCSI) you must configure support for at least one non-MTD partition type as well.
-- LBA48 Support - CONFIG_LBA48 - - Set this to enable support for disks larger than 137GB - Also look at CONFIG_SYS_64BIT_LBA. - Whithout these , LBA48 support uses 32bit variables and will 'only' - support disks up to 2.1TB. - - CONFIG_SYS_64BIT_LBA: - When enabled, makes the IDE subsystem use 64bit sector addresses. - Default is 32bit. - - NETWORK Support (PCI): CONFIG_E1000_SPI Utility code for direct access to the SPI bus on Intel 8257x. diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index 45ee0272f77f..ca341570544b 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -49,8 +49,6 @@ #define __io /* Data, registers and alternate blocks are at the same offset */ /* Each 8-bit ATA register is aligned to a 4-bytes address */ -/* Controller supports 48-bits LBA addressing */ -#define CONFIG_LBA48 /* CONFIG_IDE requires some #defines for ATA registers */ /* ATA registers base is at SATA controller base */ #endif /* CONFIG_IDE */ diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 026668b0bd06..26a921279b5b 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index e0db1e673882..b5802818ec3e 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_PBSIZE=1024 CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index a78cbfb1391a..de4f6311f2d4 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -17,6 +17,7 @@ CONFIG_SYS_PBSIZE=1024 CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index da3532ccc463..ebb3a02b824a 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/A20-OLinuXino_MICRO-eMMC_defconfig b/configs/A20-OLinuXino_MICRO-eMMC_defconfig index 0563a5188e65..c8802435b412 100644 --- a/configs/A20-OLinuXino_MICRO-eMMC_defconfig +++ b/configs/A20-OLinuXino_MICRO-eMMC_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 4993cf7d2d71..f44964124564 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 0db97ae8415a..67b47f51f1b7 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig index 91d29e44469b..e02d67da5e71 100644 --- a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig +++ b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f diff --git a/configs/A20-Olimex-SOM204-EVB_defconfig b/configs/A20-Olimex-SOM204-EVB_defconfig index 893f2e627d5c..317a1e695d8b 100644 --- a/configs/A20-Olimex-SOM204-EVB_defconfig +++ b/configs/A20-Olimex-SOM204-EVB_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f diff --git a/configs/Bananapi_M2_Ultra_defconfig b/configs/Bananapi_M2_Ultra_defconfig index 7d9c688171d4..be5be9ae2fbd 100644 --- a/configs/Bananapi_M2_Ultra_defconfig +++ b/configs/Bananapi_M2_Ultra_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 6cc2d5b64720..053ba1376525 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_NETCONSOLE=y CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 19b644613a6c..36f9bf8b32e3 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_NETCONSOLE=y CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index 794d6668d2f8..315c52f3448d 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 1027c5e3bf95..49eb01869533 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 560248dc5b17..62668df01ecb 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_PBSIZE=1024 CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DFU_RAM=y CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 42cb24e88ef7..1a161555842d 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index d4692f8184a5..3627e4dd3afa 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index dbafdd5bd80c..41ed46a7b5a1 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index ff6a4e8b3794..44a3901e22de 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index c88cfd6aa321..1584778dc744 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -8,6 +8,7 @@ CONFIG_AHCI=y CONFIG_SPL_STACK=0x8000 CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 429baf3faf29..eb3e79880058 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index a426729700e9..2e6d5dd46049 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index e7cf38ac7d1f..ba976f8f5f3c 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 494edf0625ea..720e9e5df4c6 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 80bfe31d79a5..51d4510d7388 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -73,6 +73,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 2619ef0fb17f..ec5c8a7821ec 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -64,6 +64,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index e37c74bd1f16..3da39efb4375 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -67,6 +67,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index e43c605b4e0a..b9632026a271 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -44,6 +44,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 860636292d2f..27d155dea74d 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -72,6 +72,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index c0d78c9f486d..e3068f5f0ce6 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -63,6 +63,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index debd83ed93ed..c0e8ab8042df 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -66,6 +66,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 02580c8e0dfc..5c6d27ade4e7 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -43,6 +43,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index d770fc7ba7ee..a6b9e047e6d1 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -75,6 +75,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=2 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index db484c0d1892..84be176fb41c 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -66,6 +66,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=2 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index d9d630761239..ded22f273b22 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -69,6 +69,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=2 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 473a596672f4..8b90ac554156 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -46,6 +46,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=2 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index ac4d4579bb72..ec1a07945596 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -77,6 +77,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index b2a5a72143d3..6c5c064db3b5 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -68,6 +68,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 42e31b4e22ce..e6a00a737acd 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -71,6 +71,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index dcf5b21ff0f3..73b626879242 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -48,6 +48,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 69ca044e5a22..0d213054bf6b 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -76,6 +76,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 621e5b035f2c..190d6ceb4b36 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -67,6 +67,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 04b10d36c52a..61763b50b83a 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -70,6 +70,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 0ae8394a105a..dd92833f6b63 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -47,6 +47,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_DDR_CLK_FREQ=66666666 CONFIG_CHIP_SELECTS_PER_CTRL=1 CONFIG_SYS_BR0_PRELIM_BOOL=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index e603f81287e7..b4917b9a032f 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -44,6 +44,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index 90b4688ea2e4..79a3b95eda43 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -46,6 +46,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index 85acd7e427f3..d1de95152231 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -41,6 +41,7 @@ CONFIG_BOOTFILE="uImage" CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="FM1@DTSEC1" CONFIG_DM=y +CONFIG_LBA48=y CONFIG_FSL_CAAM=y CONFIG_DDR_ECC=y CONFIG_ECC_INIT_VIA_DDRCONTROLLER=y diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 09608dd1cc2a..c9d22534d5c1 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 89e9971ea3cf..62891557040a 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -79,6 +79,7 @@ CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_ENV=y CONFIG_DM_I2C=y diff --git a/configs/bananapi_m1_plus_defconfig b/configs/bananapi_m1_plus_defconfig index 955a60ddc34d..290e9c17e211 100644 --- a/configs/bananapi_m1_plus_defconfig +++ b/configs/bananapi_m1_plus_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_NETCONSOLE=y CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/bananapi_m2_berry_defconfig b/configs/bananapi_m2_berry_defconfig index 08f7683233cf..e6b8f0f8a3f8 100644 --- a/configs/bananapi_m2_berry_defconfig +++ b/configs/bananapi_m2_berry_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_STACK=0x8000 CONFIG_SPL_I2C=y CONFIG_SYS_PBSIZE=1024 CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 80602fbbff99..d1a467dfe79e 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -55,6 +55,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_E1000=y CONFIG_SPI=y diff --git a/configs/cherryhill_defconfig b/configs/cherryhill_defconfig index 1d4256e37ba5..9c3d26a36e13 100644 --- a/configs/cherryhill_defconfig +++ b/configs/cherryhill_defconfig @@ -45,6 +45,8 @@ CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_ACPIGEN is not set +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_RTL8169=y CONFIG_SPI=y diff --git a/configs/chromebook_coral_defconfig b/configs/chromebook_coral_defconfig index a06f8e21ae02..c8e2c3b86bee 100644 --- a/configs/chromebook_coral_defconfig +++ b/configs/chromebook_coral_defconfig @@ -87,6 +87,8 @@ CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 28206ee8cec2..eb808dbce20f 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -70,6 +70,8 @@ CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_ACPIGEN is not set +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_INTEL=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 46ac5d5272e8..0f9de6080124 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -60,6 +60,8 @@ CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_ACPIGEN is not set +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_INTEL=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index e6d37307b095..5fc4be036a52 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -62,6 +62,8 @@ CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_ACPIGEN is not set +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/chromebook_samus_tpl_defconfig b/configs/chromebook_samus_tpl_defconfig index 5ad17d217b18..0ecd2799deab 100644 --- a/configs/chromebook_samus_tpl_defconfig +++ b/configs/chromebook_samus_tpl_defconfig @@ -80,6 +80,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_ACPIGEN is not set +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index c909d316a341..870843ada580 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -53,6 +53,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CROS_EC=y CONFIG_CROS_EC_LPC=y CONFIG_RTL8169=y diff --git a/configs/clearfog_gt_8k_defconfig b/configs/clearfog_gt_8k_defconfig index a45c02061ee7..cf35307937f6 100644 --- a/configs/clearfog_gt_8k_defconfig +++ b/configs/clearfog_gt_8k_defconfig @@ -47,6 +47,8 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_MISC=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 16e619b38a55..4d8788099f49 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -75,6 +75,7 @@ CONFIG_SPL_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y # CONFIG_DWC_AHSATA_AHCI is not set +CONFIG_LBA48=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y diff --git a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig index c41b83121e7d..8b6957da1629 100644 --- a/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig +++ b/configs/conga-qeval20-qa3-e3845-internal-uart_defconfig @@ -62,6 +62,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_INTEL=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 84ba5cadfec6..286abe2f8297 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -58,6 +58,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_INTEL=y diff --git a/configs/coreboot64_defconfig b/configs/coreboot64_defconfig index 3bd099e7231e..a42fc3974aa1 100644 --- a/configs/coreboot64_defconfig +++ b/configs/coreboot64_defconfig @@ -58,6 +58,8 @@ CONFIG_SYS_ATA_DATA_OFFSET=0 CONFIG_SYS_ATA_REG_OFFSET=0 CONFIG_SYS_ATA_ALT_OFFSET=0 CONFIG_ATAPI=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y # CONFIG_PCI_PNP is not set CONFIG_SOUND=y CONFIG_SOUND_I8254=y diff --git a/configs/coreboot_defconfig b/configs/coreboot_defconfig index 792d35eec581..fcd48148f126 100644 --- a/configs/coreboot_defconfig +++ b/configs/coreboot_defconfig @@ -52,6 +52,8 @@ CONFIG_SYS_ATA_DATA_OFFSET=0 CONFIG_SYS_ATA_REG_OFFSET=0 CONFIG_SYS_ATA_ALT_OFFSET=0 CONFIG_ATAPI=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y # CONFIG_PCI_PNP is not set CONFIG_SOUND=y CONFIG_SOUND_I8254=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 09a6e4bc001d..7ee0cb746e40 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -48,6 +48,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_SYS_NS16550=y CONFIG_SPI=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index addaf3b7f790..fdd0d2badb07 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -53,6 +53,8 @@ CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_ACPIGEN is not set +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_E1000=y CONFIG_SOUND=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 4eb74f759f55..05f0d4bb35ed 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -54,6 +54,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=2 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 4fe0d3ec24e5..49c616852b24 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -61,6 +61,7 @@ CONFIG_NET_RETRY_COUNT=50 CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=2 +CONFIG_LBA48=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set diff --git a/configs/dfi-bt700-q7x-151_defconfig b/configs/dfi-bt700-q7x-151_defconfig index 177764ef80c1..35e2c1a326fe 100644 --- a/configs/dfi-bt700-q7x-151_defconfig +++ b/configs/dfi-bt700-q7x-151_defconfig @@ -56,6 +56,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_NUVOTON_NCT6102D=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index a659e996b5c0..7cb4f417e7eb 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -67,6 +67,7 @@ CONFIG_ETHPRIME="FEC" CONFIG_ARP_TIMEOUT=200 CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x1000000 CONFIG_DM_I2C=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 585f44d85d31..511ca2f64736 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_ATA_STRIDE=4 CONFIG_SYS_ATA_DATA_OFFSET=0x100 CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 +CONFIG_LBA48=y CONFIG_KIRKWOOD_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 80be9b853cbd..d6b55636ba5b 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -50,6 +50,7 @@ CONFIG_SYS_ATA_STRIDE=4 CONFIG_SYS_ATA_DATA_OFFSET=0x100 CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 +CONFIG_LBA48=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index aeea352e2587..529d7569476e 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -48,6 +48,7 @@ CONFIG_SYS_ATA_STRIDE=4 CONFIG_SYS_ATA_DATA_OFFSET=0x100 CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 +CONFIG_LBA48=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 9eb5ee116ea7..563c4787a753 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -56,6 +56,7 @@ CONFIG_SYS_ATA_DATA_OFFSET=0x100 CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 CONFIG_SYS_ATA_IDE0_OFFSET=0x4000 +CONFIG_LBA48=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/efi-x86_payload32_defconfig b/configs/efi-x86_payload32_defconfig index 42fb89d5b3e0..83f532d6e543 100644 --- a/configs/efi-x86_payload32_defconfig +++ b/configs/efi-x86_payload32_defconfig @@ -49,6 +49,8 @@ CONFIG_SYS_ATA_DATA_OFFSET=0 CONFIG_SYS_ATA_REG_OFFSET=0 CONFIG_SYS_ATA_ALT_OFFSET=0 CONFIG_ATAPI=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y # CONFIG_PCI_PNP is not set # CONFIG_GZIP is not set CONFIG_EFI=y diff --git a/configs/efi-x86_payload64_defconfig b/configs/efi-x86_payload64_defconfig index eef51e8efc39..28aaff69e978 100644 --- a/configs/efi-x86_payload64_defconfig +++ b/configs/efi-x86_payload64_defconfig @@ -49,6 +49,8 @@ CONFIG_SYS_ATA_DATA_OFFSET=0 CONFIG_SYS_ATA_REG_OFFSET=0 CONFIG_SYS_ATA_ALT_OFFSET=0 CONFIG_ATAPI=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y # CONFIG_PCI_PNP is not set # CONFIG_GZIP is not set CONFIG_EFI=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index cdd71b36ddb9..1ef4d6c881e2 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -51,6 +51,7 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 +CONFIG_LBA48=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 02c59c3f31d0..c5cbce52a9b7 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -54,6 +54,7 @@ CONFIG_SYS_ATA_STRIDE=4 CONFIG_SYS_ATA_DATA_OFFSET=0x100 CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 +CONFIG_LBA48=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 0effee6d30fd..0044d893128e 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -96,6 +96,7 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_DM_I2C=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 28e08788b65d..08580255f79d 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -96,6 +96,7 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_DM_I2C=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index f46440bf560e..e2eab2bb3815 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -99,6 +99,7 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_DM_I2C=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index 8a7d0fd8a9f4..4fc735601022 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -31,6 +31,7 @@ CONFIG_MISC_INIT_R=y # CONFIG_CMD_SETEXPR is not set CONFIG_ENV_IS_IN_NVRAM=y CONFIG_SCSI_AHCI=y +CONFIG_SYS_64BIT_LBA=y CONFIG_BOOTCOUNT_LIMIT=y # CONFIG_MMC is not set CONFIG_CALXEDA_XGMAC=y diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index 3d4bd5145ff8..4771e720c9b7 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 CONFIG_SYS_ATA_IDE0_OFFSET=0x2000 CONFIG_SYS_ATA_IDE1_OFFSET=0x4000 +CONFIG_LBA48=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 908e50dab135..160a0898f2ed 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -54,6 +54,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 4fe9f6d3a6bf..0da058302c34 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -44,6 +44,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index e57f93ebd14e..d847255d5ecf 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -45,6 +45,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 87eb82a79af1..2e9edc6c4ee6 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -61,6 +61,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_RTL8169=y CONFIG_SPI=y diff --git a/configs/mvebu_crb_cn9130_defconfig b/configs/mvebu_crb_cn9130_defconfig index 86e8b75e61bf..2541b8a22aee 100644 --- a/configs/mvebu_crb_cn9130_defconfig +++ b/configs/mvebu_crb_cn9130_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_MISC=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index 7b7382216ba5..437d438f8ff6 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -47,6 +47,8 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CLK=y CONFIG_CLK_MVEBU=y # CONFIG_MVEBU_GPIO is not set diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig index 0b4afbe59e84..d3633d04dcb3 100644 --- a/configs/mvebu_db_armada8k_defconfig +++ b/configs/mvebu_db_armada8k_defconfig @@ -43,6 +43,8 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_MISC=y diff --git a/configs/mvebu_db_cn9130_defconfig b/configs/mvebu_db_cn9130_defconfig index 9f6196095b3e..7563873ef2e4 100644 --- a/configs/mvebu_db_cn9130_defconfig +++ b/configs/mvebu_db_cn9130_defconfig @@ -48,6 +48,8 @@ CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DM_GPIO_LOOKUP_LABEL=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 8368e4c028b1..dd1f91215065 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -58,6 +58,8 @@ CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_AHCI_PCI=y CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CLK=y CONFIG_CLK_MVEBU=y CONFIG_DM_I2C=y diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig index be4bbe87ca23..d334c89ed315 100644 --- a/configs/mvebu_mcbin-88f8040_defconfig +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -47,6 +47,8 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_MISC=y diff --git a/configs/mvebu_puzzle-m801-88f8040_defconfig b/configs/mvebu_puzzle-m801-88f8040_defconfig index c05beef8f946..5cec3d8a682a 100644 --- a/configs/mvebu_puzzle-m801-88f8040_defconfig +++ b/configs/mvebu_puzzle-m801-88f8040_defconfig @@ -50,6 +50,8 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index d68335b5b68d..66d72a3a25c3 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -55,6 +55,7 @@ CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 551057fcfa29..fa2c280a8d40 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -54,6 +54,7 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_SYS_I2C_LEGACY=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index ca482ce745ea..5d105522dd12 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -52,6 +52,7 @@ CONFIG_SYS_ATA_STRIDE=4 CONFIG_SYS_ATA_DATA_OFFSET=0x100 CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 +CONFIG_LBA48=y CONFIG_KIRKWOOD_GPIO=y # CONFIG_MMC is not set CONFIG_MTD=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 32308a04f65c..68d1eeff11e0 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -55,6 +55,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=2 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 2a1c3ac2d343..98d8e59119f0 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -55,6 +55,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 3c847316f6f7..11fd496e6d38 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -55,6 +55,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=2 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index 8239d45a8453..1025ca30ad93 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -54,6 +54,8 @@ CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 CONFIG_BLK=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 673e0a42a3f3..1bb9915cc1ed 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -55,6 +55,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 2bf3e3a9614a..ec75ead6e20c 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -62,6 +62,7 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_SYS_I2C_LEGACY=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index e169350f55d4..1b999ecc9c17 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -62,6 +62,7 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_SYS_I2C_LEGACY=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 77d7afa6df80..6b0f17628dcd 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -63,6 +63,7 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_SYS_I2C_LEGACY=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index 8b525eb5ff5d..0c1d808f127f 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -52,6 +52,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/octeon_nic23_defconfig b/configs/octeon_nic23_defconfig index 533091523012..23cdef3316c0 100644 --- a/configs/octeon_nic23_defconfig +++ b/configs/octeon_nic23_defconfig @@ -45,6 +45,8 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_TFTP_TSIZE=y CONFIG_SATA=y CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CLK=y # CONFIG_INPUT is not set CONFIG_MISC=y diff --git a/configs/octeontx_81xx_defconfig b/configs/octeontx_81xx_defconfig index 72e7c6ff5394..38ef7f41632d 100644 --- a/configs/octeontx_81xx_defconfig +++ b/configs/octeontx_81xx_defconfig @@ -82,6 +82,8 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_TFTP_TSIZE=y CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y CONFIG_MISC=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/octeontx_83xx_defconfig b/configs/octeontx_83xx_defconfig index fbdf1cb846b8..371f61866970 100644 --- a/configs/octeontx_83xx_defconfig +++ b/configs/octeontx_83xx_defconfig @@ -79,6 +79,8 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_TFTP_TSIZE=y CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y CONFIG_MISC=y CONFIG_SUPPORT_EMMC_RPMB=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 967246a9db94..ba5d3a6bfc32 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -56,6 +56,7 @@ CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 CONFIG_SYS_ATA_IDE0_OFFSET=0x2000 CONFIG_SYS_ATA_IDE1_OFFSET=0x4000 +CONFIG_LBA48=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index f1dbed87d699..0ee6ce3a65e1 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -57,6 +57,7 @@ CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 CONFIG_SYS_ATA_IDE0_OFFSET=0x2000 CONFIG_SYS_ATA_IDE1_OFFSET=0x4000 +CONFIG_LBA48=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index 49668150fb94..f7e8a3ee4e7d 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -57,6 +57,7 @@ CONFIG_SYS_ATA_REG_OFFSET=0x100 CONFIG_SYS_ATA_ALT_OFFSET=0x100 CONFIG_SYS_ATA_IDE0_OFFSET=0x2000 CONFIG_SYS_ATA_IDE1_OFFSET=0x4000 +CONFIG_LBA48=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/pogo_v4_defconfig b/configs/pogo_v4_defconfig index 6f928edf41bf..c62c88f1b5ac 100644 --- a/configs/pogo_v4_defconfig +++ b/configs/pogo_v4_defconfig @@ -64,6 +64,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_KIRKWOOD_GPIO=y # CONFIG_MMC_HW_PARTITIONING is not set CONFIG_MVEBU_MMC=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index 55444b69a7ad..322fe12ae9a7 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -39,6 +39,7 @@ CONFIG_DM=y CONFIG_SIMPLE_BUS_CORRECT_RANGE=y CONFIG_BLK=y CONFIG_HAVE_BLOCK_DEVICE=y +CONFIG_LBA48=y CONFIG_CHIP_SELECTS_PER_CTRL=0 CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index 66192734d553..b81e60658fd8 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -65,6 +65,8 @@ CONFIG_SYS_ATA_DATA_OFFSET=0 CONFIG_SYS_ATA_REG_OFFSET=0 CONFIG_SYS_ATA_ALT_OFFSET=0 CONFIG_ATAPI=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_NVME_PCI=y CONFIG_SPL_DM_RTC=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index b9ab1805ab27..c65b5868cd29 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -46,6 +46,8 @@ CONFIG_SYS_ATA_DATA_OFFSET=0 CONFIG_SYS_ATA_REG_OFFSET=0 CONFIG_SYS_ATA_ALT_OFFSET=0 CONFIG_ATAPI=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_NVME_PCI=y CONFIG_SPI=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index d014b2a81442..fa1e7bd2c0cb 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -53,6 +53,8 @@ CONFIG_SYS_FAULT_ECHO_LINK_DOWN=y CONFIG_DM=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=2 +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_MVEBU_MMC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y diff --git a/configs/slimbootloader_defconfig b/configs/slimbootloader_defconfig index 2e938b648670..b6b9f88c00bb 100644 --- a/configs/slimbootloader_defconfig +++ b/configs/slimbootloader_defconfig @@ -28,6 +28,8 @@ CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_ACPIGEN is not set +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y # CONFIG_PCI_PNP is not set CONFIG_CONSOLE_SCROLL_LINES=5 # CONFIG_GZIP is not set diff --git a/configs/som-db5800-som-6867_defconfig b/configs/som-db5800-som-6867_defconfig index 3b96d64b3b67..d912ac70bc18 100644 --- a/configs/som-db5800-som-6867_defconfig +++ b/configs/som-db5800-som-6867_defconfig @@ -56,6 +56,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_E1000=y CONFIG_SPI=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 1519f7dbce5f..4b304f8c7f58 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -71,6 +71,8 @@ CONFIG_SYS_MMC_ENV_PART=1 CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y diff --git a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig index daaefba36421..afb1957ddd23 100644 --- a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig @@ -58,6 +58,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_INTEL=y diff --git a/configs/theadorable-x86-conga-qa3-e3845_defconfig b/configs/theadorable-x86-conga-qa3-e3845_defconfig index a62ce3e0a5cb..113c0dae2e68 100644 --- a/configs/theadorable-x86-conga-qa3-e3845_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845_defconfig @@ -57,6 +57,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_INTEL=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index a54f34a6cf79..95ff9d763ff0 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -55,6 +55,8 @@ CONFIG_BOOTFILE="bzImage" CONFIG_TFTP_TSIZE=y CONFIG_REGMAP=y CONFIG_SYSCON=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CPU=y CONFIG_DM_I2C=y CONFIG_NUVOTON_NCT6102D=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index a3d6313f0200..25eb2e88ec17 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -67,6 +67,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y CONFIG_SYS_SATA_MAX_DEVICE=1 +CONFIG_LBA48=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_FPGA_ALTERA=y diff --git a/configs/uDPU_defconfig b/configs/uDPU_defconfig index 81f0f8800794..2b2dc1664621 100644 --- a/configs/uDPU_defconfig +++ b/configs/uDPU_defconfig @@ -54,6 +54,8 @@ CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_AHCI_MVEBU=y +CONFIG_LBA48=y +CONFIG_SYS_64BIT_LBA=y CONFIG_CLK=y CONFIG_CLK_MVEBU=y CONFIG_DM_I2C=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index e5bacb1bb8e0..a1d2d7f2e475 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -44,6 +44,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 595176190a79..8b0533ce585c 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -59,6 +59,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_BOUNCE_BUFFER=y CONFIG_DWC_AHSATA=y +CONFIG_LBA48=y CONFIG_DM_I2C=y CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 9c9641d2ed95..7715c4036562 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -116,6 +116,7 @@ config FSL_SATA depends on PPC select AHCI select LIBATA + imply LBA48 help Enable this driver to support the SATA controller found in some Freescale PowerPC SoCs. diff --git a/drivers/block/Kconfig b/drivers/block/Kconfig index d6d1c6e32ccc..b5b482086af3 100644 --- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -218,3 +218,19 @@ config IDE_RESET must be defined in a board-specific file.
endif # IDE + +config LBA48 + bool "Enable LBA support for disks larger than 137GB" + depends on HAVE_BLOCK_DEVICE + help + Set this to enable support for disks larger than 137GB. + Also look at CONFIG_SYS_64BIT_LBA. Without both of these, LBA48 + support uses 32bit variables and will 'only' support disks up to + 2.1TB. + +config SYS_64BIT_LBA + bool "Enable 64bit number of blocks on a block device" + depends on HAVE_BLOCK_DEVICE + help + Make the block subsystem use 64bit sector addresses, rather than the + default of 32bit. diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 4c1348c79dcc..384217a0d989 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -22,7 +22,6 @@ #ifdef CONFIG_IDE /* ATA */ # define CONFIG_IDE_PREINIT 1 -# undef CONFIG_LBA48 #endif
#ifdef CONFIG_DRIVER_DM9000 diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index de197a0bd117..8e75d779c418 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -262,13 +262,6 @@ #endif #endif
-/* - * SATA - */ -#ifdef CONFIG_FSL_SATA -#define CONFIG_LBA48 -#endif - /* * Environment */ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 287236f70f28..fce4bfb3dd93 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -472,12 +472,6 @@ extern unsigned long get_sdram_size(void);
#endif /* CONFIG_TSEC_ENET */
-/* SATA */ - -#ifdef CONFIG_FSL_SATA -#define CONFIG_LBA48 -#endif /* #ifdef CONFIG_FSL_SATA */ - #ifdef CONFIG_MMC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR #endif diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 3c92a3e405b7..df16319de4a9 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -336,12 +336,6 @@ #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
-/* SATA */ - -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_LBA48 -#endif - #ifdef CONFIG_FMAN_ENET #define CONFIG_SYS_FM1_DTSEC1_PHY_ADDR 0x2 #define CONFIG_SYS_FM1_DTSEC2_PHY_ADDR 0x3 diff --git a/include/configs/P4080DS.h b/include/configs/P4080DS.h index 8a0c7039f667..6615dd091e20 100644 --- a/include/configs/P4080DS.h +++ b/include/configs/P4080DS.h @@ -11,8 +11,6 @@
#define CONFIG_PCIE3
-#define CONFIG_LBA48 - #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */ #define CONFIG_SRIO2 /* SRIO port 2 */ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index b832fb33d207..767c360b36c0 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -390,11 +390,6 @@ #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
-/* SATA */ -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_LBA48 -#endif - /* * USB */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index a96c5bbd095e..55b9260d9317 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -457,13 +457,6 @@ #define SGMII_CARD_PORT4_PHY_ADDR 0x1F #endif
-/* - * SATA - */ -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_LBA48 -#endif - /* * USB */ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 82531f69c440..642099bd098d 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -413,13 +413,6 @@ #define AQR113C_PHY_ADDR2 0x08 #endif
-/* - * SATA - */ -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_LBA48 -#endif - /* * USB */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 436f6d0fc8ef..757fb054a807 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -152,11 +152,6 @@ #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
-/* SATA */ -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_LBA48 -#endif - /* * Environment */ @@ -425,11 +420,6 @@ #define CORTINA_PHY_ADDR4 FM2_10GEC2_PHY_ADDR #endif
-/* SATA */ -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_LBA48 -#endif - /* * USB */ diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index d0e0e65d85f9..5db8b2be2cb8 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -25,13 +25,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 3
-/* - * SATA Configs - */ -#ifdef CONFIG_CMD_SATA -#define CONFIG_LBA48 -#endif - /* Network */ #define PHY_ANEG_TIMEOUT 15000 /* PHY needs longer aneg time */
diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index a0bbb409cff4..fbe1e35e001a 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -149,9 +149,6 @@ #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
-/* SATA */ -#define CONFIG_LBA48 - /* Boot */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20)
diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 6006f7638220..f563a5f38162 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -337,11 +337,6 @@ #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
-/* SATA */ -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_LBA48 -#endif - #ifdef CONFIG_FMAN_ENET #define CONFIG_SYS_FM1_DTSEC1_PHY_ADDR 0x1c #define CONFIG_SYS_FM1_DTSEC2_PHY_ADDR 0x1d diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index 808debc6f501..b4cfa61d4e75 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -22,9 +22,6 @@
#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
-/* SATA support */ -#define CONFIG_LBA48 - /* PCIe support */ #ifndef CONFIG_SPL_BUILD #define CONFIG_PCI_SCAN_SHOW diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 298a88c92eda..6fe45a86dcc0 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -33,9 +33,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 3
-/* SATA Configs */ -#define CONFIG_LBA48 - /* UART */ #define CONFIG_MXC_UART_BASE UART1_BASE
diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index 07e2b8781fd2..fbd83d629c02 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -30,9 +30,4 @@ #define CONFIG_MVGBE_PORTS {1, 1} /* enable both ports */ #define CONFIG_PHY_BASE_ADR 0
-/* - * SATA Driver configuration - */ -#define CONFIG_LBA48 - #endif /* _CONFIG_DREAMPLUG_H */ diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 1d6e6bcc4345..86257016824f 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -101,8 +101,6 @@ #define __io /* Data, registers and alternate blocks are at the same offset */ /* Each 8-bit ATA register is aligned to a 4-bytes address */ -/* Controller supports 48-bits LBA addressing */ -#define CONFIG_LBA48 /* A single bus, a single device */ /* ATA registers base is at SATA controller base */ /* ATA bus 0 is orion5x port 1 on ED Mini V2 */ diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 66ea80982b6c..d813c6c22e78 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -17,11 +17,6 @@ #include "mx6_common.h" #include <linux/sizes.h>
-/* SATA Configs */ -#ifdef CONFIG_CMD_SATA -#define CONFIG_LBA48 -#endif - #ifdef CONFIG_CMD_NFS #define NETWORKBOOT \ "setnetworkboot=" \ diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index 832441a7b721..d335a42e99c1 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -44,7 +44,4 @@ #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 0
-/* SATA driver configuration */ -#define CONFIG_LBA48 - #endif /* _CONFIG_GOFLEXHOME_H */ diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 53954cee3b3c..251e360daa9c 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -28,13 +28,6 @@ /* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-/* - * SATA Configs - */ -#ifdef CONFIG_CMD_SATA - #define CONFIG_LBA48 -#endif - /* * PCI express */ diff --git a/include/configs/highbank.h b/include/configs/highbank.h index d8e712693661..1fc38cfa0cc6 100644 --- a/include/configs/highbank.h +++ b/include/configs/highbank.h @@ -20,8 +20,6 @@ * Miscellaneous configurable options */
-#define CONFIG_SYS_64BIT_LBA - /* Environment data setup */ #define CONFIG_SYS_NVRAM_BASE_ADDR 0xfff88000 /* NVRAM base address */ diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 0a988e2fadf2..5e0f1c90934e 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -21,18 +21,6 @@ #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ #endif
-/* - * SATA Driver configuration - */ - -#ifdef CONFIG_SATA -#define CONFIG_SYS_64BIT_LBA -#define CONFIG_LBA48 -#if defined(CONFIG_NETSPACE_MAX_V2) || defined(CONFIG_D2NET_V2) || \ - defined(CONFIG_NET2BIG_V2) -#endif -#endif /* CONFIG_SATA */ - /* * Enable GPI0 support */ diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 19fd702ab245..81c93375e2ef 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -94,9 +94,4 @@ #define CONFIG_PHY_BASE_ADR 7 #endif /* CONFIG_CMD_NET */
-#ifdef CONFIG_SATA -#define CONFIG_SYS_64BIT_LBA -#define CONFIG_LBA48 -#endif - #endif /* _CONFIG_LSXL_H */ diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 66230f0bf17e..b8ad0c3a2164 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -82,13 +82,6 @@ #define CONFIG_MXC_USB_FLAGS 0 #endif
-/* - * SATA - */ -#ifdef CONFIG_CMD_SATA -#define CONFIG_LBA48 -#endif - /* * LCD */ diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index cae70760bcb5..b497ada06551 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -36,12 +36,6 @@
#define CONFIG_USB_MAX_CONTROLLER_COUNT (3 + 3)
-/* - * SATA/SCSI/AHCI configuration - */ -#define CONFIG_LBA48 -#define CONFIG_SYS_64BIT_LBA - #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \ diff --git a/include/configs/mvebu_armada-8k.h b/include/configs/mvebu_armada-8k.h index 7d7c218bc6a3..52d88f705895 100644 --- a/include/configs/mvebu_armada-8k.h +++ b/include/configs/mvebu_armada-8k.h @@ -31,12 +31,6 @@
/* USB ethernet */
-/* - * SATA/SCSI/AHCI configuration - */ -#define CONFIG_LBA48 -#define CONFIG_SYS_64BIT_LBA - /* * PCI configuration */ diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 0afd68b880e4..9ceed12e4872 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -100,10 +100,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) #define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE)
-#ifdef CONFIG_CMD_SATA - #define CONFIG_LBA48 -#endif - /* Framebuffer and LCD */
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 5b4fbba023f9..c6744e970f68 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -16,11 +16,6 @@ /* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR
-/* SATA Configuration */ -#ifdef CONFIG_CMD_SATA -#define CONFIG_LBA48 -#endif - /* Framebuffer */ #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 9b84c36f5145..0305aecb1438 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -19,13 +19,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 2
-/* - * SATA Configs - */ -#ifdef CONFIG_CMD_SATA -#define CONFIG_LBA48 -#endif - #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 6
diff --git a/include/configs/novena.h b/include/configs/novena.h index 327dde56970d..9c67a3a77750 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -59,9 +59,6 @@ #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
-/* SATA Configs */ -#define CONFIG_LBA48 - /* UART */ #define CONFIG_MXC_UART_BASE UART2_BASE
diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index 1e6b8d8b0e73..46fd6e6e3b52 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -25,8 +25,4 @@ #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 1
-/* Support large HDDs for USB and SATA */ -#define CONFIG_LBA48 -#define CONFIG_SYS_64BIT_LBA - #endif /* _CONFIG_NSA310S_H */ diff --git a/include/configs/octeon_nic23.h b/include/configs/octeon_nic23.h index 0a7b4d8f93e2..7d99fd1b0195 100644 --- a/include/configs/octeon_nic23.h +++ b/include/configs/octeon_nic23.h @@ -7,15 +7,6 @@ #ifndef __CONFIG_H__ #define __CONFIG_H__
-/* - * SATA/SCSI/AHCI configuration - */ -/* AHCI support Definitions */ -/** Enable 48-bit SATA addressing */ -#define CONFIG_LBA48 -/** Enable 64-bit addressing */ -#define CONFIG_SYS_64BIT_LBA - #include "octeon_common.h"
#endif /* __CONFIG_H__ */ diff --git a/include/configs/octeontx_common.h b/include/configs/octeontx_common.h index 22d38588780d..2697a703cea5 100644 --- a/include/configs/octeontx_common.h +++ b/include/configs/octeontx_common.h @@ -44,14 +44,6 @@
/** Heap size for U-Boot */
-/* AHCI support Definitions */ -#ifdef CONFIG_DM_SCSI -/** Enable 48-bit SATA addressing */ -# define CONFIG_LBA48 -/** Enable 64-bit addressing */ -# define CONFIG_SYS_64BIT_LBA -#endif - #define CONFIG_SYS_MMC_MAX_BLK_COUNT 8192
/** EMMC specific defines */ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 41009cb6a3b8..202697ec646f 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -112,8 +112,6 @@ #define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ #define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */
-#define CONFIG_LBA48 - #define CONFIG_HWCONFIG /* * These can be toggled for performance analysis, otherwise use default. diff --git a/include/configs/pogo_v4.h b/include/configs/pogo_v4.h index 3365ebe3d2fa..24cbf6b72ea7 100644 --- a/include/configs/pogo_v4.h +++ b/include/configs/pogo_v4.h @@ -39,10 +39,4 @@ #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 0
-/* - * Support large disk for SATA and USB - */ -#define CONFIG_SYS_64BIT_LBA -#define CONFIG_LBA48 - #endif /* _CONFIG_POGO_V4_H */ diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 60a17dbcdcdd..e427b854fced 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -60,8 +60,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void);
#define CONFIG_SYS_MONITOR_LEN (512 * 1024)
-#define CONFIG_LBA48 - /* RTC */ #define CONFIG_RTC_PT7C4338
diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 58345e4e1be7..19701ccce22e 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -27,10 +27,4 @@ #define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ #define CONFIG_PHY_BASE_ADR 0
-/* - * Support large disk for SATA and USB - */ -#define CONFIG_SYS_64BIT_LBA -#define CONFIG_LBA48 - #endif /* _CONFIG_SHEEVAPLUG_H */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 5b543fd2db1c..327bf98ddb23 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -75,10 +75,6 @@ #define PHYS_SDRAM_0 CONFIG_SYS_SDRAM_BASE #define PHYS_SDRAM_0_SIZE 0x80000000 /* 2 GiB */
-#ifdef CONFIG_AHCI -#define CONFIG_SYS_64BIT_LBA -#endif - #ifdef CONFIG_NAND_SUNXI #define CONFIG_SYS_NAND_MAX_ECCPOS 1664 #define CONFIG_SYS_MAX_NAND_DEVICE 8 diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 3d0c856103e7..b160f33dbfc6 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -34,12 +34,6 @@ #define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(7, 12) #endif
-/* SATA */ -#ifdef CONFIG_CMD_SATA -#define CONFIG_LBA48 -#define CONFIG_SYS_64BIT_LBA -#endif - /* USB */ #ifdef CONFIG_CMD_USB #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index c81e89eed8b2..4f7c9647e292 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -40,9 +40,6 @@ "fdt_high=0x10000000\0" \ "initrd_high=0x10000000\0"
-/* SATA support */ -#define CONFIG_LBA48 - /* FPGA programming support */ #define CONFIG_FPGA_STRATIX_V
diff --git a/include/configs/udoo.h b/include/configs/udoo.h index c8d1ed4da684..03e5c04af6ee 100644 --- a/include/configs/udoo.h +++ b/include/configs/udoo.h @@ -14,9 +14,6 @@
-/* SATA Configs */ -#define CONFIG_LBA48 - /* MMC Configuration */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index eb0778d072a5..899b8ca470e2 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -14,12 +14,6 @@
-/* SATA Configs */ - -#ifdef CONFIG_CMD_SATA -#define CONFIG_LBA48 -#endif - /* MMC Configuration */ #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0 diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 48091b95ca70..f28fafe15c63 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -16,13 +16,6 @@ */ #define CONFIG_SYS_BOOTM_LEN (16 << 20)
-/* SATA AHCI storage */ -#ifdef CONFIG_SCSI_AHCI -#define CONFIG_LBA48 -#define CONFIG_SYS_64BIT_LBA - -#endif - /* Generic TPM interfaced through LPC bus */ #define CONFIG_TPM_TIS_BASE_ADDRESS 0xfed40000
Now that the driver only supports CONFIG_BLK, remove the useless guard in sata_sil.h.
Signed-off-by: Tom Rini trini@konsulko.com --- drivers/ata/sata_sil.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/drivers/ata/sata_sil.h b/drivers/ata/sata_sil.h index bea4322c919d..9ad09e5461d2 100644 --- a/drivers/ata/sata_sil.h +++ b/drivers/ata/sata_sil.h @@ -212,12 +212,10 @@ enum { CMD_ERR = 0x21, };
-#if CONFIG_IS_ENABLED(BLK) #define ATA_MAX_PORTS 32 struct sil_sata_priv { int port_num; struct sil_sata *sil_sata_desc[ATA_MAX_PORTS]; }; -#endif
#endif
The only platform currently that defines an ide_preinit function has an empty one that immediately returns. Remove this hook.
Signed-off-by: Tom Rini trini@konsulko.com --- board/freescale/m5253demo/m5253demo.c | 5 ----- drivers/block/ide.c | 9 --------- include/configs/M5253DEMO.h | 5 ----- include/ide.h | 4 ---- 4 files changed, 23 deletions(-)
diff --git a/board/freescale/m5253demo/m5253demo.c b/board/freescale/m5253demo/m5253demo.c index 2a4703579dab..85f5f0c03409 100644 --- a/board/freescale/m5253demo/m5253demo.c +++ b/board/freescale/m5253demo/m5253demo.c @@ -93,11 +93,6 @@ int testdram(void)
#ifdef CONFIG_IDE #include <ata.h> -int ide_preinit(void) -{ - return (0); -} - void ide_set_reset(int idereset) { atac_t *ata = (atac_t *) CONFIG_SYS_ATA_BASE_ADDR; diff --git a/drivers/block/ide.c b/drivers/block/ide.c index e8518ff3a11a..3270a9f032f3 100644 --- a/drivers/block/ide.c +++ b/drivers/block/ide.c @@ -695,15 +695,6 @@ void ide_init(void) unsigned char c; int i, bus;
-#ifdef CONFIG_IDE_PREINIT - WATCHDOG_RESET(); - - if (ide_preinit()) { - puts("ide_preinit failed\n"); - return; - } -#endif /* CONFIG_IDE_PREINIT */ - WATCHDOG_RESET();
/* ATAPI Drives seems to need a proper IDE Reset */ diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index 384217a0d989..840d3b4672e6 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -19,11 +19,6 @@ . = DEFINED(env_offset) ? env_offset : .; \ env/embedded.o(.text*);
-#ifdef CONFIG_IDE -/* ATA */ -# define CONFIG_IDE_PREINIT 1 -#endif - #ifdef CONFIG_DRIVER_DM9000 # define CONFIG_DM9000_BASE (CONFIG_SYS_CS1_BASE | 0x300) # define DM9000_IO CONFIG_DM9000_BASE diff --git a/include/ide.h b/include/ide.h index 2994b7a76226..426cef4e39e0 100644 --- a/include/ide.h +++ b/include/ide.h @@ -33,10 +33,6 @@ ulong ide_write(struct blk_desc *block_dev, lbaint_t blknr, lbaint_t blkcnt, const void *buffer); #endif
-#ifdef CONFIG_IDE_PREINIT -int ide_preinit(void); -#endif - #if defined(CONFIG_OF_IDE_FIXUP) int ide_device_present(int dev); #endif
Since bb5930d5c97f ("exynos: video: Convert several boards to driver model for video") there have been no callers of any of the exynos_lcd_* family of functions. Remove these from the boards, and then remove unused logo and related code as well.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-exynos/include/mach/system.h | 1 - board/samsung/trats/trats.c | 23 - board/samsung/trats2/trats2.c | 35 - board/samsung/universal_c210/universal.c | 107 - drivers/video/Makefile | 1 - drivers/video/s6e8ax0.c | 265 - include/configs/s5pc210_universal.h | 2 - include/configs/trats.h | 2 - include/configs/trats2.h | 2 - lib/Makefile | 1 - lib/tizen/Makefile | 6 - lib/tizen/tizen.c | 34 - lib/tizen/tizen_logo_16bpp.h | 7934 -------------------- lib/tizen/tizen_logo_16bpp_gzip.h | 647 -- 14 files changed, 9060 deletions(-) delete mode 100644 drivers/video/s6e8ax0.c delete mode 100644 lib/tizen/Makefile delete mode 100644 lib/tizen/tizen.c delete mode 100644 lib/tizen/tizen_logo_16bpp.h delete mode 100644 lib/tizen/tizen_logo_16bpp_gzip.h
diff --git a/arch/arm/mach-exynos/include/mach/system.h b/arch/arm/mach-exynos/include/mach/system.h index 48f13c76481b..5d0bebac5733 100644 --- a/arch/arm/mach-exynos/include/mach/system.h +++ b/arch/arm/mach-exynos/include/mach/system.h @@ -116,6 +116,5 @@ struct exynos5_sysreg {
void set_usbhost_mode(unsigned int mode); void set_system_display_ctrl(void); -int exynos_lcd_early_init(const void *blob);
#endif /* _EXYNOS4_SYSTEM_H */ diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index d06687620cf4..24bf355ef6ec 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -403,16 +403,6 @@ int exynos_early_init_f(void) return 0; }
-void exynos_reset_lcd(void) -{ - gpio_request(EXYNOS4_GPIO_Y45, "lcd_reset"); - gpio_direction_output(EXYNOS4_GPIO_Y45, 1); - udelay(10000); - gpio_direction_output(EXYNOS4_GPIO_Y45, 0); - udelay(10000); - gpio_direction_output(EXYNOS4_GPIO_Y45, 1); -} - int lcd_power(void) { #if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ @@ -460,16 +450,3 @@ int mipi_power(void) #endif return 0; } - -#ifdef CONFIG_LCD -void exynos_lcd_misc_init(vidinfo_t *vid) -{ -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif -#ifdef CONFIG_S6E8AX0 - s6e8ax0_init(); - env_set("lcdinfo", "lcd=s6e8ax0"); -#endif -} -#endif diff --git a/board/samsung/trats2/trats2.c b/board/samsung/trats2/trats2.c index a03dc8738579..da7f0dc02290 100644 --- a/board/samsung/trats2/trats2.c +++ b/board/samsung/trats2/trats2.c @@ -302,39 +302,4 @@ int mipi_power(void) return 0; }
-void exynos_lcd_power_on(void) -{ -#if !CONFIG_IS_ENABLED(DM_I2C) /* TODO(maintainer): Convert to driver model */ - struct pmic *p = pmic_get("MAX77686_PMIC"); - - /* LCD_2.2V_EN: GPC0[1] */ - gpio_request(EXYNOS4X12_GPIO_C01, "lcd_2v2_en"); - gpio_set_pull(EXYNOS4X12_GPIO_C01, S5P_GPIO_PULL_UP); - gpio_direction_output(EXYNOS4X12_GPIO_C01, 1); - - /* LDO25 VCC_3.1V_LCD */ - pmic_probe(p); - max77686_set_ldo_voltage(p, 25, 3100000); - max77686_set_ldo_mode(p, 25, OPMODE_LPM); -#endif -} - -void exynos_reset_lcd(void) -{ - /* reset lcd */ - gpio_request(EXYNOS4X12_GPIO_F21, "lcd_reset"); - gpio_direction_output(EXYNOS4X12_GPIO_F21, 0); - udelay(10); - gpio_set_value(EXYNOS4X12_GPIO_F21, 1); -} - -void exynos_lcd_misc_init(vidinfo_t *vid) -{ -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif -#ifdef CONFIG_S6E8AX0 - s6e8ax0_init(); -#endif -} #endif /* LCD */ diff --git a/board/samsung/universal_c210/universal.c b/board/samsung/universal_c210/universal.c index 3764b5478b79..1dde2f799b5e 100644 --- a/board/samsung/universal_c210/universal.c +++ b/board/samsung/universal_c210/universal.c @@ -267,98 +267,6 @@ static int init_pmic_lcd(void) return 0; }
-void exynos_cfg_lcd_gpio(void) -{ - unsigned int i, f3_end = 4; - - for (i = 0; i < 8; i++) { - /* set GPF0,1,2[0:7] for RGB Interface and Data lines (32bit) */ - gpio_cfg_pin(EXYNOS4_GPIO_F00 + i, S5P_GPIO_FUNC(2)); - gpio_cfg_pin(EXYNOS4_GPIO_F10 + i, S5P_GPIO_FUNC(2)); - gpio_cfg_pin(EXYNOS4_GPIO_F20 + i, S5P_GPIO_FUNC(2)); - /* pull-up/down disable */ - gpio_set_pull(EXYNOS4_GPIO_F00 + i, S5P_GPIO_PULL_NONE); - gpio_set_pull(EXYNOS4_GPIO_F10 + i, S5P_GPIO_PULL_NONE); - gpio_set_pull(EXYNOS4_GPIO_F20 + i, S5P_GPIO_PULL_NONE); - - /* drive strength to max (24bit) */ - gpio_set_drv(EXYNOS4_GPIO_F00 + i, S5P_GPIO_DRV_4X); - gpio_set_rate(EXYNOS4_GPIO_F00 + i, S5P_GPIO_DRV_SLOW); - gpio_set_drv(EXYNOS4_GPIO_F10 + i, S5P_GPIO_DRV_4X); - gpio_set_rate(EXYNOS4_GPIO_F10 + i, S5P_GPIO_DRV_SLOW); - gpio_set_drv(EXYNOS4_GPIO_F20 + i, S5P_GPIO_DRV_4X); - gpio_set_rate(EXYNOS4_GPIO_F00 + i, S5P_GPIO_DRV_SLOW); - } - - for (i = EXYNOS4_GPIO_F30; i < (EXYNOS4_GPIO_F30 + f3_end); i++) { - /* set GPF3[0:3] for RGB Interface and Data lines (32bit) */ - gpio_cfg_pin(i, S5P_GPIO_FUNC(2)); - /* pull-up/down disable */ - gpio_set_pull(i, S5P_GPIO_PULL_NONE); - /* drive strength to max (24bit) */ - gpio_set_drv(i, S5P_GPIO_DRV_4X); - gpio_set_rate(i, S5P_GPIO_DRV_SLOW); - } - - /* gpio pad configuration for LCD reset. */ - gpio_request(EXYNOS4_GPIO_Y45, "lcd_reset"); - gpio_cfg_pin(EXYNOS4_GPIO_Y45, S5P_GPIO_OUTPUT); -} - -int mipi_power(void) -{ - return 0; -} - -void exynos_reset_lcd(void) -{ - gpio_set_value(EXYNOS4_GPIO_Y45, 1); - udelay(10000); - gpio_set_value(EXYNOS4_GPIO_Y45, 0); - udelay(10000); - gpio_set_value(EXYNOS4_GPIO_Y45, 1); - udelay(100); -} - -void exynos_lcd_power_on(void) -{ - struct udevice *dev; - int ret; - u8 reg; - - ret = pmic_get("max8998-pmic", &dev); - if (ret) { - puts("Failed to get MAX8998!\n"); - return; - } - - reg = pmic_reg_read(dev, MAX8998_REG_ONOFF3); - reg |= MAX8998_LDO17; - ret = pmic_reg_write(dev, MAX8998_REG_ONOFF3, reg); - if (ret) { - puts("MAX8998 LDO setting error\n"); - return; - } - - reg = pmic_reg_read(dev, MAX8998_REG_ONOFF2); - reg |= MAX8998_LDO7; - ret = pmic_reg_write(dev, MAX8998_REG_ONOFF2, reg); - if (ret) { - puts("MAX8998 LDO setting error\n"); - return; - } -} - -void exynos_cfg_ldo(void) -{ - ld9040_cfg_ldo(); -} - -void exynos_enable_ldo(unsigned int onoff) -{ - ld9040_enable_ldo(onoff); -} - int exynos_init(void) { gd->bd->bi_arch_number = MACH_TYPE_UNIVERSAL_C210; @@ -390,18 +298,3 @@ int exynos_init(void)
return 0; } - -#ifdef CONFIG_LCD -void exynos_lcd_misc_init(vidinfo_t *vid) -{ -#ifdef CONFIG_TIZEN - get_tizen_logo_info(vid); -#endif - - /* for LD9040. */ - vid->pclk_name = 1; /* MPLL */ - vid->sclk_div = 1; - - env_set("lcdinfo", "lcd=ld9040"); -} -#endif diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 259658074bc1..63d8dbe3c85f 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -38,7 +38,6 @@ obj-$(CONFIG_NXP_TDA19988) += tda19988.o obj-$(CONFIG_OSD) += video_osd-uclass.o obj-$(CONFIG_PXA_LCD) += pxa_lcd.o obj-$(CONFIG_SANDBOX_OSD) += sandbox_osd.o -obj-$(CONFIG_S6E8AX0) += s6e8ax0.o obj-$(CONFIG_SCF0403_LCD) += scf0403_lcd.o obj-$(CONFIG_VIDEO_ARM_MALIDP) += mali_dp.o obj-$(CONFIG_VIDEO_BCM2835) += bcm2835.o diff --git a/drivers/video/s6e8ax0.c b/drivers/video/s6e8ax0.c deleted file mode 100644 index 497258f3de92..000000000000 --- a/drivers/video/s6e8ax0.c +++ /dev/null @@ -1,265 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2012 Samsung Electronics - * - * Author: Donghwa Lee dh09.lee@samsung.com - */ - -#include <common.h> -#include <asm/arch/mipi_dsim.h> -#include <linux/delay.h> - -#include "exynos/exynos_mipi_dsi_lowlevel.h" -#include "exynos/exynos_mipi_dsi_common.h" - -static void s6e8ax0_panel_cond(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - int reverse = dsim_dev->dsim_lcd_dev->reverse_panel; - static const unsigned char data_to_send[] = { - 0xf8, 0x3d, 0x35, 0x00, 0x00, 0x00, 0x8d, 0x00, 0x4c, - 0x6e, 0x10, 0x27, 0x7d, 0x3f, 0x10, 0x00, 0x00, 0x20, - 0x04, 0x08, 0x6e, 0x00, 0x00, 0x00, 0x02, 0x08, 0x08, - 0x23, 0x23, 0xc0, 0xc8, 0x08, 0x48, 0xc1, 0x00, 0xc3, - 0xff, 0xff, 0xc8 - }; - - static const unsigned char data_to_send_reverse[] = { - 0xf8, 0x19, 0x35, 0x00, 0x00, 0x00, 0x93, 0x00, 0x3c, - 0x7d, 0x08, 0x27, 0x7d, 0x3f, 0x00, 0x00, 0x00, 0x20, - 0x04, 0x08, 0x6e, 0x00, 0x00, 0x00, 0x02, 0x08, 0x08, - 0x23, 0x23, 0xc0, 0xc1, 0x01, 0x41, 0xc1, 0x00, 0xc1, - 0xf6, 0xf6, 0xc1 - }; - - if (reverse) { - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send_reverse, - ARRAY_SIZE(data_to_send_reverse)); - } else { - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); - } -} - -static void s6e8ax0_display_cond(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xf2, 0x80, 0x03, 0x0d - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_gamma_cond(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - /* 7500K 2.2 Set : 30cd */ - static const unsigned char data_to_send[] = { - 0xfa, 0x01, 0x60, 0x10, 0x60, 0xf5, 0x00, 0xff, 0xad, - 0xaf, 0xba, 0xc3, 0xd8, 0xc5, 0x9f, 0xc6, 0x9e, 0xc1, - 0xdc, 0xc0, 0x00, 0x61, 0x00, 0x5a, 0x00, 0x74, - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_gamma_update(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xf7, 0x03 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_SHORT_WRITE_PARAM, data_to_send, - ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_etc_source_control(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xf6, 0x00, 0x02, 0x00 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_etc_pentile_control(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xb6, 0x0c, 0x02, 0x03, 0x32, 0xff, 0x44, 0x44, 0xc0, - 0x00 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_etc_mipi_control1(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xe1, 0x10, 0x1c, 0x17, 0x08, 0x1d - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_etc_mipi_control2(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xe2, 0xed, 0x07, 0xc3, 0x13, 0x0d, 0x03 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_etc_power_control(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xf4, 0xcf, 0x0a, 0x12, 0x10, 0x19, 0x33, 0x02 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_etc_mipi_control3(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xe3, 0x40 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_SHORT_WRITE_PARAM, data_to_send, - ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_etc_mipi_control4(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xe4, 0x00, 0x00, 0x14, 0x80, 0x00, 0x00, 0x00 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_elvss_set(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xb1, 0x04, 0x00 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_display_on(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0x29, 0x00 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_SHORT_WRITE, data_to_send, - ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_sleep_out(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0x11, 0x00 - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_SHORT_WRITE, data_to_send, - ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_apply_level1_key(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xf0, 0x5a, 0x5a - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_apply_mtp_key(struct mipi_dsim_device *dsim_dev) -{ - struct mipi_dsim_master_ops *ops = dsim_dev->master_ops; - static const unsigned char data_to_send[] = { - 0xf1, 0x5a, 0x5a - }; - - ops->cmd_write(dsim_dev, MIPI_DSI_DCS_LONG_WRITE, - data_to_send, ARRAY_SIZE(data_to_send)); -} - -static void s6e8ax0_panel_init(struct mipi_dsim_device *dsim_dev) -{ - /* - * in case of setting gamma and panel condition at first, - * it shuold be setting like below. - * set_gamma() -> set_panel_condition() - */ - - s6e8ax0_apply_level1_key(dsim_dev); - s6e8ax0_apply_mtp_key(dsim_dev); - - s6e8ax0_sleep_out(dsim_dev); - mdelay(5); - s6e8ax0_panel_cond(dsim_dev); - s6e8ax0_display_cond(dsim_dev); - s6e8ax0_gamma_cond(dsim_dev); - s6e8ax0_gamma_update(dsim_dev); - - s6e8ax0_etc_source_control(dsim_dev); - s6e8ax0_elvss_set(dsim_dev); - s6e8ax0_etc_pentile_control(dsim_dev); - s6e8ax0_etc_mipi_control1(dsim_dev); - s6e8ax0_etc_mipi_control2(dsim_dev); - s6e8ax0_etc_power_control(dsim_dev); - s6e8ax0_etc_mipi_control3(dsim_dev); - s6e8ax0_etc_mipi_control4(dsim_dev); -} - -static int s6e8ax0_panel_set(struct mipi_dsim_device *dsim_dev) -{ - s6e8ax0_panel_init(dsim_dev); - - return 0; -} - -static void s6e8ax0_display_enable(struct mipi_dsim_device *dsim_dev) -{ - s6e8ax0_display_on(dsim_dev); -} - -static struct mipi_dsim_lcd_driver s6e8ax0_dsim_ddi_driver = { - .name = "s6e8ax0", - .id = -1, - - .mipi_panel_init = s6e8ax0_panel_set, - .mipi_display_on = s6e8ax0_display_enable, -}; - -void s6e8ax0_init(void) -{ - exynos_mipi_dsi_register_lcd_driver(&s6e8ax0_dsim_ddi_driver); -} diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 8df7377a0f2f..3b94b17ff788 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -11,8 +11,6 @@
#include <configs/exynos4-common.h>
-#define CONFIG_TIZEN /* TIZEN lib */ - /* Keep L2 Cache Disabled */
/* Universal has 2 banks of DRAM */ diff --git a/include/configs/trats.h b/include/configs/trats.h index db33560f0db4..118ceb525010 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -13,8 +13,6 @@
#define CONFIG_TRATS
-#define CONFIG_TIZEN /* TIZEN lib */ - #ifndef CONFIG_SYS_L2CACHE_OFF #define CONFIG_SYS_L2_PL310 #define CONFIG_SYS_PL310_BASE 0x10502000 diff --git a/include/configs/trats2.h b/include/configs/trats2.h index a4d598d0851a..2d644a8b231d 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -12,8 +12,6 @@
-#define CONFIG_TIZEN /* TIZEN lib */ - #ifndef CONFIG_SYS_L2CACHE_OFF #define CONFIG_SYS_L2_PL310 #define CONFIG_SYS_PL310_BASE 0x10502000 diff --git a/lib/Makefile b/lib/Makefile index d9b1811f7506..e3deb1528794 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -11,7 +11,6 @@ obj-$(CONFIG_EFI_LOADER) += efi_loader/ obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += efi_selftest/ obj-$(CONFIG_LZMA) += lzma/ obj-$(CONFIG_BZIP2) += bzip2/ -obj-$(CONFIG_TIZEN) += tizen/ obj-$(CONFIG_FIT) += libfdt/ obj-$(CONFIG_OF_LIVE) += of_live.o obj-$(CONFIG_CMD_DHRYSTONE) += dhry/ diff --git a/lib/tizen/Makefile b/lib/tizen/Makefile deleted file mode 100644 index 3651ea21fbe5..000000000000 --- a/lib/tizen/Makefile +++ /dev/null @@ -1,6 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# (C) Copyright 2012 Samsung Electronics -# Donghwa Lee dh09.lee@samsung.com - -obj-$(CONFIG_TIZEN) += tizen.o diff --git a/lib/tizen/tizen.c b/lib/tizen/tizen.c deleted file mode 100644 index 916b2597569c..000000000000 --- a/lib/tizen/tizen.c +++ /dev/null @@ -1,34 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2012 Samsung Electronics - * Donghwa Lee dh09.lee@samsung.com - */ - -#include <common.h> -#include <lcd.h> -#include <libtizen.h> - -#include "tizen_logo_16bpp.h" -#include "tizen_logo_16bpp_gzip.h" - -#ifdef CONFIG_LCD -void get_tizen_logo_info(vidinfo_t *vid) -{ - switch (vid->vl_bpix) { - case 4: - vid->logo_width = TIZEN_LOGO_16BPP_WIDTH; - vid->logo_height = TIZEN_LOGO_16BPP_HEIGHT; - vid->logo_x_offset = TIZEN_LOGO_16BPP_X_OFFSET; - vid->logo_y_offset = TIZEN_LOGO_16BPP_Y_OFFSET; -#if defined(CONFIG_VIDEO_BMP_GZIP) - vid->logo_addr = (ulong)tizen_logo_16bpp_gzip; -#else - vid->logo_addr = (ulong)tizen_logo_16bpp; -#endif - break; - default: - vid->logo_addr = 0; - break; - } -} -#endif diff --git a/lib/tizen/tizen_logo_16bpp.h b/lib/tizen/tizen_logo_16bpp.h deleted file mode 100644 index 12e86269c451..000000000000 --- a/lib/tizen/tizen_logo_16bpp.h +++ /dev/null @@ -1,7934 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2013 Samsung Electronics - * Przemyslaw Marczak p.marczak@samsung.com - */ - -#ifndef __TIZEN_LOGO_16BPP__ -#define __TIZEN_LOGO_16BPP__ - -#define TIZEN_LOGO_16BPP_WIDTH 452 -#define TIZEN_LOGO_16BPP_HEIGHT 140 - -/* Center align offsets for word "TIZEN" */ -#define TIZEN_LOGO_16BPP_X_OFFSET (16) -#define TIZEN_LOGO_16BPP_Y_OFFSET (-20) - -/* Format: BMP RGB565 16BPP 452x140 */ -unsigned char tizen_logo_16bpp[] = { -0x42,0x4d,0xa6,0xee,0x01,0x00,0x00,0x00,0x00,0x00,0x46,0x00,0x00,0x00,0x38,0x00, -0x00,0x00,0xc4,0x01,0x00,0x00,0x8c,0x00,0x00,0x00,0x01,0x00,0x10,0x00,0x03,0x00, -0x00,0x00,0x60,0xee,0x01,0x00,0x01,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf8,0x00,0x00,0xe0,0x07,0x00,0x00,0x1f,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x21,0x08,0x86,0x31,0x65,0x29,0x41,0x08,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x20,0x00,0x20,0x08,0x20,0x00, -0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x08,0x20,0x00,0x20,0x00,0x20,0x00, -0x20,0x00,0x21,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xaa,0x52,0x34,0xa5,0xb6,0xb5, -0x96,0xb5,0x34,0xa5,0xd2,0x94,0xef,0x7b,0xeb,0x5a,0x08,0x42,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x61,0x08, -0x6e,0x6b,0x71,0x8c,0x51,0x8c,0x51,0x8c,0x51,0x8c,0x71,0x8c,0x51,0x8c,0x71,0x8c, -0x71,0x8c,0x71,0x8c,0x51,0x8c,0x51,0x8c,0x71,0x8c,0x51,0x8c,0x51,0x8c,0x71,0x8c, -0x71,0x8c,0x51,0x8c,0x8a,0x52,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x28,0x42, -0x10,0x84,0xb2,0x94,0xb2,0x94,0xd2,0x94,0xb2,0x94,0xd2,0x94,0xb2,0x94,0xb2,0x94, -0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xd2,0x94, -0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xd2,0x94,0xb2,0x94, -0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xd2,0x94,0xd2,0x94, -0xb2,0x94,0xd2,0x94,0xb2,0x94,0xd2,0x94,0xb2,0x94,0xd2,0x94,0xd2,0x9c,0xd2,0x94, -0xb2,0x94,0xd2,0x94,0xb2,0x9c,0xd2,0x94,0xd2,0x94,0xd2,0x94,0xb3,0x94,0xd2,0x94, -0xb3,0x94,0xd2,0x94,0xb3,0x94,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c, -0x92,0x94,0x08,0x42,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe3,0x18,0x30,0x84, -0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c, -0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c, -0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c, -0xf3,0x9c,0xf3,0x9c,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5, -0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5, -0x14,0xa5,0x14,0x9d,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0x9d, -0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0x9d, -0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x34,0xa5, -0x30,0x84,0x62,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x10,0x84,0x34,0xa5, -0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5, -0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5, -0x30,0x8c,0x62,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xe7,0x39,0x14,0xa5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0x75,0xad,0x13,0x9d,0x72,0x94,0x8e,0x73,0x8a,0x52,0xa6,0x31, -0xa2,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xb2,0x94,0xf3,0x9c, -0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c, -0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0x14,0xa5,0x14,0xa5,0xf3,0x9c, -0x2c,0x6b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x92,0x94,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xab,0x5a, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xef,0x7b,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xb6,0xb5,0xc7,0x39,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xd3,0x9c,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x51,0x8c,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x30,0x84,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd6,0xbd,0xf7,0xbd,0x51,0x8c,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0x92,0x94,0x14,0xa5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0x55,0xa5,0xd3,0x9c,0x30,0x84,0x2c,0x63, -0x28,0x42,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xc3,0x18,0x55,0xad,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x8a,0x52,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x31,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd6,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5, -0xd7,0xb5,0xf7,0xbd,0xae,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x45,0x29,0x96,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5, -0xb6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5, -0xb6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xb7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5, -0xb7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xb6,0xb5,0xd7,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd7,0xbd,0x54,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xd7,0xbd,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0x55,0xad,0x62,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x84, -0xf3,0x9c,0xf3,0x9c,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0x91,0x94,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x49,0x4a,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0xd6,0xb5,0x10,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xbd,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x21,0x08,0x54,0xad,0xd6,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xbd,0xb6,0xb5,0xb7,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xbd, -0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5, -0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd6,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xb6,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xb6,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd, -0xd7,0xb5,0xb6,0xb5,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb7,0xb5, -0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd6,0xbd, -0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb6,0xb5,0xd7,0xbd,0x54,0xad,0x41,0x08,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x21,0x00,0x34,0xa5,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd7,0xbd,0x55,0xad,0xa2,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x4d,0x6b,0x14,0xa5,0xd3,0x9c,0xf3,0x9c,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd7,0xbd,0xae,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x49,0x4a,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x10,0x84,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4d,0x6b,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xbd,0xb6,0xb5,0xd7,0xb5,0xd6,0xb5, -0xd6,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5, -0xb6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb7,0xb5,0xf7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd6,0xb5,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd, -0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5, -0xd7,0xbd,0x55,0xad,0xa2,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x34,0xa5,0xd7,0xbd,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xb5,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x69,0x4a,0x14,0xa5,0xf3,0x9c, -0xd2,0x94,0xd3,0x9c,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xf3,0x9c,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x49,0x4a,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0xb6,0xb5,0x30,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x08, -0x55,0xad,0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd, -0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5, -0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5, -0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0x55,0xad,0xa2,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x20,0x00,0x34,0xa5,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd7,0xb5,0x55,0xad,0xa2,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x45,0x29,0xf3,0x9c,0x13,0x9d,0xd3,0x9c,0xd2,0x94,0xd3,0x9c,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xf3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x49,0x4a,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x10,0x84,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x6d,0x6b,0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5, -0xb7,0xb5,0xd6,0xbd,0xb6,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd7,0xb5, -0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd7,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5, -0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd6,0xbd,0xd6,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd7,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5, -0xd7,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x34,0xa5,0xd7,0xbd,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x71,0x8c,0x34,0xa5,0xf3,0x9c,0xd3,0x9c, -0xb2,0x94,0xd2,0x94,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xf3,0x9c,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x49,0x4a,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0xb6,0xb5,0x10,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x61,0x08,0x55,0xad, -0xd7,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd, -0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xd6,0xb5,0xd6,0xbd,0xb6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd6,0xbd,0xd6,0xbd,0xd6,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd6,0xb5, -0xd6,0xb5,0xd6,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0x55,0xad,0xa2,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x20,0x00,0x34,0xa5,0xd7,0xbd,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd7,0xbd,0x55,0xad,0x82,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcf,0x7b, -0x55,0xa5,0x14,0xa5,0xf3,0x9c,0xd3,0x9c,0xb2,0x94,0xd2,0x94,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xf3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x49,0x4a,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x10,0x84,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xd2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x8e,0x73,0xf7,0xbd,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5, -0xd7,0xb5,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xb5, -0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd7,0xb5, -0xd7,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xbd, -0xd7,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x34,0xa5,0xd7,0xbd,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xeb,0x5a,0x54,0xad,0x34,0xa5,0x13,0x9d,0xf3,0x9c,0xd3,0x9c, -0xb2,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xf3,0x9c,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x49,0x4a,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5, -0xd6,0xb5,0x10,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x10,0x75,0xad,0xd7,0xbd, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5, -0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb7,0xb5,0xd7,0xb5,0xd7,0xb5, -0xd6,0xbd,0xb7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd6,0xb5, -0xd7,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd7,0xbd,0x55,0xad,0xa2,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x20,0x00,0x34,0xa5,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd6,0xbd, -0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xb5,0x55,0xad,0x82,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc7,0x39,0x34,0xa5,0x54,0xa5, -0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xd3,0x9c,0xb2,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xf3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x8a,0x52,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xef,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x8e,0x73,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb7,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5, -0xd7,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xb5, -0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xb5, -0xd7,0xbd,0x75,0xad,0xa2,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x54,0xa5,0xd7,0xbd,0xd6,0xb5, -0xb7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb7,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x82,0x10,0xf3,0x9c,0x55,0xad,0x34,0xa5,0x14,0xa5,0x13,0x9d,0xf3,0x9c,0xd3,0x94, -0x92,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xf3,0x9c,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xca,0x5a,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5, -0xd6,0xb5,0x10,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd7,0xbd,0xd2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x10,0x75,0xad,0xd7,0xbd,0xb6,0xb5, -0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xb5, -0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0x75,0xad,0xa2,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x20,0x00,0x34,0xa5,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd, -0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0x55,0xad,0xa2,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x51,0x8c,0x75,0xad,0x55,0xad,0x34,0xa5, -0x34,0xa5,0x13,0x9d,0xf3,0x9c,0xd2,0x9c,0xb2,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0x13,0x9d,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xab,0x5a,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0x0f,0x7c,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xae,0x73,0xf7,0xbd,0xb7,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xbd, -0xd6,0xbd,0xd6,0xb5,0xd6,0xbd,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xb5,0xd6,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0x75,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x08,0x34,0xa5,0xd7,0xbd,0xd6,0xb5, -0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5, -0xb7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd6,0xbd,0xb6,0xb5,0xd7,0xb5,0xb6,0xb5, -0xd7,0xbd,0x75,0xad,0xc3,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6d,0x6b, -0x96,0xb5,0x55,0xad,0x55,0xa5,0x34,0xa5,0x34,0xa5,0x13,0x9d,0xf3,0x9c,0xd2,0x94, -0x92,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xf3,0x9c,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xab,0x5a,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5, -0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x10,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0x75,0xad,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd6,0xbd,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd, -0xd6,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0x75,0xad,0xa2,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x20,0x00,0x54,0xa5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5, -0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd7,0xbd,0x76,0xad,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x69,0x4a,0x76,0xad,0x75,0xad,0x55,0xad,0x54,0xad,0x34,0xa5, -0x14,0xa5,0xf3,0x9c,0xf3,0x9c,0xb2,0x94,0x92,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd7,0xbd,0xf3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xab,0x5a,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xd6,0xb5,0x0f,0x7c,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xae,0x73, -0xf7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0x75,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x00,0x54,0xa5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5, -0xb7,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0x75,0xad,0xe4,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x34,0xa5,0x96,0xad, -0x75,0xad,0x55,0xad,0x35,0xad,0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xd3,0x9c,0xb2,0x94, -0x92,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x14,0xa5,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xab,0x52,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5, -0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x10,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xc3,0x18,0x75,0xad,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xef,0x7b,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0xb6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x75,0xad,0xa3,0x18,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x20,0x00,0x34,0xad,0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd6,0xbd, -0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0x76,0xb5,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xb2,0x94,0xb6,0xb5,0x76,0xad,0x75,0xad,0x55,0xad,0x54,0xad,0x34,0xa5, -0x34,0xa5,0xf3,0x9c,0xf3,0x9c,0xd2,0x94,0x92,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0x34,0xa5,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xab,0x5a,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5, -0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x10,0x7c,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa7,0x31,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8e,0x73,0xf7,0xbd, -0xb7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd6,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0x17,0xbe,0x4d,0x6b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0xb6,0xb5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0x54,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x54,0xa5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xb7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5, -0xd7,0xbd,0x75,0xad,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcf,0x7b,0xb6,0xb5,0x96,0xb5,0x75,0xad, -0x75,0xad,0x55,0xad,0x54,0xad,0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xd3,0x9c,0xd2,0x94, -0x92,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0x34,0xa5,0x20,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xab,0x5a,0xb6,0xb5,0xb6,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xf0,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xf7,0xbd,0xd2,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xd2,0x9c,0xf7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x14,0x9d,0x62,0x08,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x66,0x29,0xb6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xb6,0xb5,0xab,0x5a,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0x76,0xb5,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x5a, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xb5,0x75,0xad,0x55,0xad,0x55,0xad,0x34,0xa5, -0x14,0xa5,0xf3,0x9c,0xd3,0x9c,0xb2,0x94,0x92,0x94,0x92,0x94,0x96,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xbd,0x34,0xa5,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xab,0x5a,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa6,0x31,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd7,0xbd,0xd2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xef,0x83,0xf7,0xbd, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x76,0xb5,0x96,0xb5, -0xf3,0x9c,0x2c,0x63,0x2c,0x6b,0x4d,0x6b,0x2d,0x6b,0x4d,0x6b,0x2d,0x6b,0x4d,0x6b, -0x2d,0x6b,0x4d,0x6b,0x2d,0x6b,0x4d,0x6b,0x2d,0x6b,0x4d,0x6b,0x2d,0x6b,0x4d,0x6b, -0x4d,0x6b,0x4d,0x6b,0x2d,0x6b,0x4d,0x6b,0x4d,0x6b,0x4d,0x6b,0x2d,0x6b,0x4d,0x6b, -0x4d,0x6b,0x4d,0x6b,0x4d,0x6b,0x4d,0x6b,0x2d,0x6b,0x4d,0x6b,0x4d,0x6b,0x4d,0x6b, -0x2d,0x6b,0x4d,0x6b,0x4d,0x6b,0x4d,0x6b,0x4d,0x6b,0x4d,0x6b,0x4d,0x6b,0x0c,0x63, -0x8a,0x52,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0xb6,0xb5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0x75,0xad,0x0c,0x63,0xcb,0x5a,0xeb,0x5a,0xeb,0x5a,0xeb,0x5a,0xeb,0x5a, -0xeb,0x5a,0xeb,0x5a,0xeb,0x5a,0xeb,0x5a,0xcb,0x5a,0xeb,0x5a,0xaa,0x52,0x6a,0x4a, -0x8a,0x52,0x69,0x52,0x8a,0x4a,0x8a,0x52,0x6a,0x4a,0x8a,0x52,0x8a,0x52,0x8a,0x52, -0x8a,0x52,0x6a,0x52,0x89,0x4a,0x8a,0x52,0x8a,0x52,0x6a,0x4a,0x8a,0x52,0x89,0x52, -0x6a,0x52,0x6a,0x52,0x8a,0x52,0x6a,0x52,0x89,0x52,0x89,0x4a,0x8a,0x52,0x89,0x4a, -0x8a,0x4a,0x8a,0x52,0x8a,0x52,0x89,0x52,0x8a,0x4a,0x8a,0x4a,0x8a,0x52,0x69,0x4a, -0x24,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd, -0xd7,0xbd,0x95,0xad,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0x95,0xad,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xad, -0x75,0xad,0x55,0xad,0x55,0xad,0x34,0xa5,0x34,0xa5,0x13,0x9d,0xd3,0x9c,0xb2,0x94, -0x92,0x94,0x92,0x94,0x96,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x34,0xa5,0x20,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x52,0xb6,0xb5,0xb6,0xb5,0x96,0xb5, -0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x39,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x92,0x94,0xd6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x76,0xb5,0x76,0xad,0x95,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x55,0xad,0x75,0xad,0x55,0xad,0x55,0xad,0x55,0xad, -0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x8a,0x52,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x45,0x29,0xb6,0xb5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x08,0x14,0xa5,0xd7,0xbd, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x76,0xad,0x75,0xad,0x55,0xad,0x55,0xad,0x34,0xa5, -0x34,0xa5,0x13,0x9d,0xf3,0x9c,0xb2,0x94,0xb2,0x94,0x92,0x94,0x96,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb7,0xbd,0x34,0xa5,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xab,0x5a,0xd6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5, -0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa7,0x31,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xbd,0xb6,0xb5,0xd7,0xbd,0xd2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x08, -0xf3,0x9c,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x75,0xad,0x95,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x55,0xad,0x75,0xad,0x55,0xad,0x75,0xad,0x55,0xad,0x55,0xad, -0x55,0xad,0x55,0xad,0x49,0x4a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd7,0xb5, -0xd7,0xbd,0x96,0xad,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x51,0x8c,0xd7,0xbd,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x95,0xb5, -0x75,0xad,0x55,0xad,0x55,0xad,0x34,0xa5,0x14,0xa5,0x13,0x9d,0xd3,0x9c,0xd2,0x94, -0x92,0x94,0x92,0x94,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0x34,0xa5,0x20,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x5a,0xb6,0xb5,0xb6,0xb5,0x96,0xb5, -0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xbd,0xf7,0xbd,0xd2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe4,0x18,0x34,0xa5,0xb6,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x95,0xb5,0x96,0xb5,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x55,0xad,0x75,0xad,0x55,0xad,0x55,0xad,0x75,0xad,0x54,0xa5,0xc7,0x39, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x6d,0x6b,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xad,0x55,0xad,0x55,0xad,0x34,0xa5, -0x34,0xa5,0x13,0x9d,0xf3,0x9c,0xd3,0x9c,0x92,0x94,0x92,0x94,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xbd,0x34,0xa5,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xab,0x5a,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5, -0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa7,0x39,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5, -0xb7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x86,0x29,0x55,0xad,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xad, -0x76,0xb5,0x95,0xb5,0x76,0xb5,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x55,0xad,0x75,0xad, -0x55,0xad,0x55,0xad,0x75,0xad,0x14,0xa5,0x45,0x29,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x28,0x42, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xad, -0x75,0xad,0x55,0xad,0x55,0xad,0x34,0xa5,0x14,0xa5,0x13,0x9d,0xd3,0x9c,0xd2,0x94, -0x92,0x94,0xb2,0x94,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0x34,0xa5,0x20,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x5a,0xd6,0xb5,0xb6,0xb5,0x96,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xb5,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x75,0xad, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xb5,0x75,0xb5, -0x95,0xad,0x75,0xb5,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x76,0xad, -0xf3,0x9c,0xa2,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xc3,0x18,0x55,0xad,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x76,0xad,0x75,0xad,0x55,0xad,0x55,0xad,0x34,0xa5, -0x34,0xa5,0x14,0x9d,0xf3,0x9c,0xb2,0x9c,0x92,0x94,0x92,0x94,0x96,0xb5,0xd7,0xbd, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xbd,0x34,0xa5,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xab,0x5a,0xd6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa7,0x31,0xd6,0xb5, -0xd6,0xbd,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd7,0xb5,0xd6,0xb5, -0xb6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd7,0xb5,0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x8a,0x52,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x76,0xb5,0x95,0xb5,0x96,0xad,0x76,0xad,0x76,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x96,0xb5,0x92,0x94,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb2,0x94,0xf7,0xbd, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xb5, -0x75,0xad,0x75,0xad,0x55,0xad,0x54,0xa5,0x34,0xa5,0x13,0x9d,0xd3,0x9c,0xd2,0x94, -0x92,0x94,0x92,0x94,0x96,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xb5,0x34,0xa5,0x20,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x5a,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5, -0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x0c,0x63,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x95,0xb5,0x96,0xb5,0x96,0xad,0x75,0xb5,0x76,0xad,0x96,0xb5, -0x75,0xad,0x75,0xb5,0x95,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x96,0xb5,0x51,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x04,0x21,0xb6,0xb5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xcf,0x7b,0xf7,0xbd,0xb7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xad,0x55,0xad,0x55,0xad,0x54,0xa5, -0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xd3,0x94,0x92,0x94,0x92,0x94,0x96,0xb5,0xd7,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd7,0xbd,0x34,0xa5,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xab,0x5a,0xd6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa7,0x39,0xd6,0xb5, -0xd6,0xbd,0xd6,0xb5,0xd6,0xbd,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xb7,0xbd,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xf7,0xbd,0xd3,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8e,0x6b,0xb6,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xad,0x96,0xb5,0x96,0xb5,0x76,0xad,0x95,0xb5,0x75,0xb5,0x75,0xb5, -0x96,0xb5,0x95,0xb5,0x75,0xad,0x75,0xad,0x75,0xb5,0x75,0xad,0x96,0xb5,0xcf,0x7b, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xaa,0x52,0xd7,0xb5,0xd7,0xbd,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xad, -0x75,0xad,0x55,0xad,0x55,0xad,0x34,0xa5,0x34,0xa5,0x13,0x9d,0xf3,0x9c,0xd2,0x94, -0x92,0x94,0x92,0x94,0x96,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0x34,0xa5,0x41,0x08, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x5a,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0xd7,0xbd,0xd6,0xbd,0xb6,0xb5,0xd6,0xb5,0xb7,0xb5, -0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5, -0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xef,0x7b,0xd6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x4d,0x6b,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x45,0x29, -0x95,0xad,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xad,0x55,0xad,0x55,0xad,0x54,0xa5, -0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xd3,0x9c,0x92,0x94,0xb2,0x94,0x96,0xb5,0xd6,0xbd, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xab,0x5a,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc7,0x39,0xd7,0xbd, -0xb7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xbd, -0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xf7,0xbd,0xd2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x51,0x8c, -0xd7,0xbd,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0xab,0x5a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x95,0xb5, -0x75,0xad,0x75,0xad,0x55,0xad,0x34,0xa5,0x34,0xa5,0x13,0x9d,0xf3,0x9c,0xd3,0x9c, -0xb2,0x94,0xb2,0x94,0x96,0xb5,0xd6,0xbd,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0x55,0xad,0x82,0x10, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x5a,0xb6,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb2,0x94,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5, -0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0x28,0x42,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x34,0xa5,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x84,0xf7,0xbd, -0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xad,0x55,0xad,0x55,0xad,0x54,0xad, -0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xd3,0x9c,0xb2,0x94,0xb2,0x94,0x96,0xb5,0xd7,0xbd, -0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd7,0xbd,0x55,0xad,0xa2,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xcb,0x5a,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe8,0x41,0xf7,0xbd, -0xd6,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd6,0xbd,0xd6,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x41,0x08,0x13,0x9d,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0x75,0xad,0xa7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xec,0x62,0xd7,0xbd,0xb6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xad, -0x75,0xad,0x75,0xad,0x55,0xad,0x34,0xa5,0x34,0xa5,0x13,0xa5,0xf3,0x9c,0xd3,0x9c, -0x92,0x94,0x92,0x94,0x96,0xb5,0xd6,0xbd,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd7,0xbd,0x55,0xad,0x82,0x10, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x5a,0xb7,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xb5,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x54,0xa5,0xd7,0xbd, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xbd,0x55,0xad, -0x25,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0x96,0xb5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x34,0xa5,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc7,0x39,0x96,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xad,0x75,0xad,0x55,0xad,0x55,0xad, -0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xd3,0x9c,0xb2,0x94,0x92,0x94,0x96,0xb5,0xd7,0xbd, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd7,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xcb,0x5a,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe8,0x41,0xf7,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xbd,0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0x75,0xad,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0x14,0xa5,0x62,0x10,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0xb6,0xb5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0x17,0xbe,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x08, -0x14,0xa5,0xd7,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xb6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x75,0xad,0x75,0xad,0x55,0xad,0x54,0xa5,0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xd2,0x94, -0xb2,0x94,0x91,0x8c,0x76,0xad,0xd6,0xbd,0xd6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5, -0xd7,0xb5,0xb6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0x55,0xad,0xa2,0x10, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcb,0x5a,0xd7,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x29,0x4a, -0xb6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd6,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb7,0xb5, -0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x04,0x21,0xb6,0xb5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x34,0xa5,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x51,0x8c,0xd7,0xbd,0xb6,0xb5,0xd6,0xb5,0xb6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x75,0xad,0x75,0xad,0x55,0xad,0x54,0xa5, -0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xd3,0x9c,0xb2,0x94,0xab,0x5a,0x34,0xa5,0xd7,0xbd, -0xd7,0xb5,0xd7,0xb5,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xbd, -0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd7,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xeb,0x5a,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe8,0x41,0xf7,0xbd, -0xd7,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xab,0x5a,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x51,0x8c,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x95,0xb5,0x4d,0x6b,0x0c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63, -0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63, -0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63, -0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63,0x2c,0x63, -0x2c,0x63,0x2c,0x63,0x2c,0x63,0x6d,0x6b,0x6e,0x73,0x8e,0x73,0x4d,0x6b,0xe7,0x39, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x4d,0x6b,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x75,0xad,0x75,0xad,0x55,0xad,0x54,0xa5,0x34,0xa5,0x14,0xa5,0xf3,0x9c,0xf3,0x9c, -0x2d,0x6b,0x00,0x00,0x34,0xa5,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5, -0xb7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xbd,0x55,0xad,0x82,0x10, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x2d,0x6b,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xef,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x04,0x21,0xb6,0xb5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x18,0xc6, -0x17,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xc6,0x18,0xbe, -0x17,0xc6,0x17,0xc6,0x17,0xc6,0x18,0xbe,0x18,0xbe,0x17,0xc6,0x18,0xc6,0x18,0xc6, -0x17,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xbe,0x17,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0xf7,0xbd,0x0c,0x63,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x28,0x42,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x95,0xad,0x75,0xad,0x55,0xad,0x55,0xad, -0x34,0xa5,0x14,0xa5,0x14,0x9d,0x30,0x84,0x00,0x00,0x00,0x00,0x54,0xa5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb7,0xb5, -0xd6,0xb5,0xd7,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x2c,0x63,0xd7,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xaf,0x7b,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd, -0x4d,0x6b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x96,0xb5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0x55,0xad,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0x34,0xa5,0xb6,0xb5,0x96,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd7,0xbd,0xb7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x75,0xb5,0x75,0xad,0x55,0xad,0x54,0xad,0x34,0xa5,0x14,0xa5,0xd3,0x9c,0x45,0x29, -0x00,0x00,0x21,0x00,0x54,0xa5,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd7,0xb5,0x55,0xad,0xa2,0x10, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x84,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xaa,0x52,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xb6,0xb5,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x55,0xad,0x41,0x08,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x71,0x8c,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x95,0xb5,0x75,0xad,0x55,0xad,0x55,0xa5, -0x34,0xa5,0x14,0xa5,0x8a,0x52,0x00,0x00,0x00,0x00,0x21,0x08,0x54,0xa5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xd7,0xbd,0x55,0xad,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x0c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xcf,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x92,0x94,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd6,0xb5,0x28,0x42,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0x96,0xb5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0x55,0xad,0x21,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0x9d,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xb6,0xb5,0x65,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x6d,0x6b,0x96,0xb5,0x95,0xad,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xbd,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x76,0xb5,0x75,0xad,0x55,0xad,0x55,0xa5,0x55,0xad,0xae,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x20,0x00,0x54,0xa5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5, -0xb6,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd7,0xbd,0x55,0xad,0xa2,0x10, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0xaf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x96,0xb5,0xa6,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xb6,0xb5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x55,0xad,0x21,0x08,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x69,0x4a,0x75,0xad, -0x75,0xad,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x75,0xb5,0x75,0xad,0x55,0xad,0x55,0xad, -0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x54,0xa5,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xb7,0xbd, -0xd6,0xb5,0xd7,0xbd,0x75,0xad,0xe4,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x0c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xaf,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x82,0x10,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x55,0xad,0xe4,0x20,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0xb6,0xb5,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0x55,0xad,0x21,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xb6,0xb5,0x66,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0x14,0xa5,0x75,0xad,0x75,0xad,0x96,0xad,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x76,0xb5,0x75,0xad,0x55,0xad,0x34,0xa5,0x66,0x31,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x20,0x08,0x35,0xa5,0xf7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd6,0xbd, -0xb7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0x76,0xad,0x04,0x21, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0xaf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0x17,0xbe,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0x75,0xad, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd, -0x14,0xa5,0x41,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x04,0x21,0xb6,0xb5,0xf7,0xc5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x75,0xad,0x82,0x10,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x71,0x94,0x75,0xad,0x55,0xad, -0x75,0xad,0x75,0xad,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x95,0xb5,0x75,0xad,0x75,0xad,0xcb,0x5a, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x55,0xa5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0x95,0xad,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x2c,0x63,0xd6,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xae,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0xc7,0x39,0x96,0xb5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xb2,0x94,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0xb6,0xb5,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0x76,0xb5,0xa3,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xc5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd6,0xb5,0x66,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x8e,0x73,0x55,0xad,0x55,0xad,0x55,0xad,0x75,0xad,0x95,0xb5,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5, -0x96,0xad,0x96,0xb5,0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x21,0x08,0x55,0xad,0xf7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5, -0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0x76,0xb5,0x04,0x21, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0xaf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x49,0x4a,0xd6,0xb5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0x30,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xb6,0xb5,0xf8,0xc5,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xbe,0x96,0xb5,0xa3,0x18,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd6,0xb5,0x65,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0xaa,0x52,0x34,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad, -0x75,0xad,0x75,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xb6,0xbd, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0xd3,0x9c,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0x95,0xad,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xae,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xeb,0x5a,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xae,0x73, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xb6,0xb5,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0x96,0xb5,0xa3,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd6,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0xf3,0x9c, -0x34,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad,0x75,0xad,0x95,0xb5,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0x55,0xad,0x86,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0x76,0xb5,0x04,0x21, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd7,0xbd,0xaf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x4d,0x6b,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0x0c,0x63,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x04,0x21,0xb6,0xb5,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x96,0xb5,0xa3,0x18,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0x18,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0x86,0x31,0x00,0x00, -0x00,0x00,0x20,0x00,0x71,0x8c,0x14,0xa5,0x14,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad, -0x75,0xad,0x76,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xeb,0x5a,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xce,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcf,0x7b, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0x89,0x52,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xb6,0xb5,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0x96,0xb5,0xa3,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xc5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xc7,0x39,0x00,0x00,0x00,0x00,0x8e,0x73,0xf3,0x9c,0xf3,0x9c, -0x14,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad,0x75,0xad,0x96,0xad,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xbd,0x10,0x84, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0x76,0xb5,0x04,0x21, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0x17,0xbe,0xd3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x50,0x84,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xb6,0xb5,0xe8,0x41,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xb6,0xb5,0x17,0xc6,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd, -0x17,0xbe,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x96,0xb5,0xa3,0x18,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0x17,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xa7,0x39,0x00,0x00, -0xaa,0x52,0xd3,0x9c,0xf3,0x9c,0xf3,0xa4,0x14,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad, -0x75,0xad,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5, -0xb6,0xb5,0xd7,0xbd,0xf3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x92,0x94,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0x75,0xad,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xb6,0xb5,0x17,0xbe, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0x96,0xb5,0xa3,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x65,0x29,0x45,0x29,0x92,0x94,0xd2,0x9c,0xd3,0x9c,0x13,0x9d, -0x14,0xa5,0x54,0xa5,0x55,0xad,0x75,0xad,0x75,0xad,0x96,0xb5,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0x96,0xb5,0x86,0x31,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0x96,0xb5,0x04,0x21, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xbd, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf3,0x9c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0xf7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xf7,0xbd,0x34,0xa5, -0xa3,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xb6,0xb5,0x18,0xc6,0x17,0xbe,0x17,0xbe,0x17,0xbe,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe, -0x17,0xbe,0x17,0xbe,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0x17,0xbe,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0x17,0xbe,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0x17,0xbe, -0x17,0xbe,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x96,0xb5,0xa3,0x18,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0x89,0x4a,0xef,0x83, -0xb2,0x94,0xd2,0x94,0xf3,0x9c,0x13,0x9d,0x34,0xa5,0x34,0xa5,0x55,0xad,0x75,0xad, -0x75,0xad,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xec,0x62,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0x96,0xb5,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa2,0x10,0x34,0xa5,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5, -0xb7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xf7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xb6,0xb5,0x18,0xc6, -0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0x17,0xbe,0x17,0xbe, -0x17,0xbe,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xc5,0xf7,0xbd,0x18,0xbe,0x17,0xbe,0xf7,0xbd,0x17,0xbe, -0x18,0xbe,0x17,0xbe,0xf8,0xc5,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf8,0xc5,0x17,0xbe, -0xf8,0xbd,0x17,0xbe,0xf8,0xc5,0x17,0xbe,0x18,0xc6,0x17,0xbe,0xf8,0xc5,0x17,0xbe, -0xf8,0xc5,0x17,0xbe,0x17,0xc6,0x17,0xbe,0xf7,0xc5,0x17,0xbe,0x17,0xbe,0x17,0xbe, -0x18,0xbe,0x17,0xbe,0x17,0xc6,0xf7,0xbd,0xf8,0xbd,0xf7,0xbd,0xf7,0xbd,0x38,0xc6, -0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0x17,0xc6,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x51,0x8c,0x71,0x8c,0x92,0x94,0xd2,0x94,0xf3,0x9c,0x13,0x9d, -0x14,0xa5,0x54,0xa5,0x55,0xad,0x75,0xad,0x75,0xad,0x96,0xb5,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x10,0x84,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0x76,0xb5,0x04,0x21, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x25,0x29, -0x55,0xad,0xd7,0xbd,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xbd,0xb6,0xb5,0xd7,0xb5, -0xf7,0xbd,0x71,0x8c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xb6,0xb5,0x18,0xc6,0x17,0xbe,0x17,0xc6,0xf7,0xbd,0xf8,0xbd, -0x17,0xbe,0xf7,0xc5,0xf7,0xbd,0x18,0xbe,0x17,0xbe,0xf7,0xc5,0xf7,0xbd,0xf8,0xbd, -0x17,0xbe,0xf7,0xc5,0x17,0xbe,0x17,0xbe,0x17,0xbe,0xf7,0xc5,0x17,0xbe,0x18,0xc6, -0x17,0xbe,0xf8,0xbd,0x17,0xbe,0x18,0xc6,0x17,0xbe,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x55,0xad,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0x18,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xb2,0x94,0x51,0x8c, -0xb2,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x34,0xa5,0x55,0xad,0x75,0xad, -0x75,0xad,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x14,0xa5, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0x96,0xb5,0x25,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xbe, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf8,0xc5,0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc7,0x39,0x75,0xad,0xd7,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xf7,0xbd,0xef,0x7b,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xb6,0xb5,0x18,0xc6, -0x17,0xbe,0xf7,0xbd,0x18,0xbe,0x17,0xbe,0x17,0xc6,0xf7,0xbd,0x18,0xbe,0x17,0xbe, -0x17,0xbe,0x17,0xbe,0x18,0xbe,0x17,0xbe,0xf7,0xc5,0xf7,0xbd,0xf8,0xbd,0x17,0xbe, -0x18,0xc6,0x96,0xb5,0x28,0x42,0xa6,0x31,0xc7,0x39,0xa7,0x39,0xc7,0x39,0xc7,0x39, -0xa6,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29, -0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29, -0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29, -0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x31,0x66,0x31,0x65,0x29,0x65,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0x18,0xc6,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xb2,0x94,0x71,0x8c,0x92,0x94,0xd3,0x9c,0xf3,0x9c,0x13,0xa5, -0x34,0xa5,0x54,0xa5,0x55,0xad,0x75,0xad,0x76,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0x96,0xb5,0x86,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xb6,0xb5,0x65,0x29, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x6b,0xd7,0xbd,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd7,0xb5,0xd7,0xbd, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xbe,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xbe,0x92,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x49,0x4a,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0x4d,0x6b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xb6,0xb5,0x18,0xc6,0x17,0xbe,0xf7,0xc5,0x17,0xbe,0x18,0xc6, -0x17,0xbe,0xf8,0xc5,0x17,0xbe,0x17,0xbe,0x17,0xbe,0xf8,0xbd,0x17,0xbe,0xf8,0xc5, -0x17,0xbe,0xf8,0xc5,0x17,0xbe,0x18,0xbe,0x18,0xc6,0x75,0xad,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xb2,0x94,0x71,0x8c, -0xb2,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad,0x75,0xad, -0x95,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xec,0x62,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x18,0xbe,0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xab,0x5a,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xaa,0x52,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xb6,0xb5,0x18,0xbe, -0xf8,0xc5,0x17,0xbe,0xf7,0xc5,0x17,0xbe,0xf8,0xc5,0x17,0xbe,0x18,0xbe,0x17,0xbe, -0x17,0xc6,0x17,0xbe,0xf8,0xc5,0x17,0xbe,0xf8,0xbd,0x17,0xbe,0xf7,0xc5,0x17,0xbe, -0x18,0xc6,0x75,0xad,0x21,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0x18,0xc6,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xb2,0x94,0x71,0x8c,0xb2,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5, -0x34,0xa5,0x54,0xa5,0x55,0xad,0x75,0xad,0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0x30,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xb6,0xb5,0x65,0x29, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb7,0xbd, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xbe,0x92,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x2d,0x63,0x96,0xb5,0x96,0xb5,0x76,0xb5,0x96,0xad, -0x96,0xb5,0x95,0xb5,0x96,0xad,0x76,0xb5,0x96,0xad,0x76,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x96,0xb5,0x28,0x42,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xd6,0xb5,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x17,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x17,0xbe,0x17,0xbe,0x17,0xbe,0x18,0xbe,0x18,0xc6,0x75,0xad,0x41,0x08,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xf3,0x9c,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd2,0x94,0x71,0x8c, -0xb2,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad,0x75,0xad, -0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x14,0xa5,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x17,0xc6,0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x8e,0x73,0x95,0xb5,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x76,0xad,0x75,0xad,0x76,0xad,0x95,0xad,0x76,0xb5,0x95,0xad, -0x96,0xb5,0x55,0xad,0xa6,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xb6,0xb5,0x18,0xc6, -0xf8,0xc5,0x17,0xbe,0x18,0xc6,0x17,0xc6,0xf8,0xc5,0x18,0xbe,0x17,0xbe,0x17,0xc6, -0xf7,0xbd,0x18,0xbe,0x18,0xc6,0x17,0xbe,0xf8,0xbd,0x17,0xbe,0x18,0xc6,0x17,0xc6, -0x18,0xc6,0x75,0xad,0x21,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xb2,0x94,0x71,0x8c,0xb2,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5, -0x34,0xa5,0x55,0xad,0x55,0xad,0x75,0xad,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xb6,0xb5, -0x86,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x34,0xa5,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xb6,0xb5,0x65,0x29, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x63,0xd7,0xbd,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x92,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcf,0x7b,0x75,0xad,0x55,0xad, -0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x75,0xad,0x55,0xad, -0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x75,0xad,0x55,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x96,0xb5,0x14,0xa5,0x04,0x21, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xd6,0xb5,0x18,0xc6,0x17,0xc6,0x17,0xc6,0x18,0xbe,0x17,0xbe, -0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x17,0xc6,0x18,0xbe,0x17,0xc6, -0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xbe,0x18,0xc6,0x75,0xad,0x41,0x08,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xf3,0x9c,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd2,0x94,0x71,0x8c, -0xb2,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x55,0xad,0x75,0xad,0x75,0xad, -0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xeb,0x5a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x4d,0x6b,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb7,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb6,0xbd,0xd7,0xb5, -0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x10,0x84,0x55,0xad,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5, -0x34,0xa5,0x34,0xa5,0x34,0xa5,0x54,0xa5,0x34,0xa5,0x54,0xa5,0x54,0xa5,0x54,0xa5, -0x35,0xad,0x54,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad, -0x75,0xad,0x75,0xad,0x96,0xb5,0xd2,0x94,0x41,0x08,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xb6,0xb5,0x18,0xc6, -0x18,0xc6,0x18,0xbe,0x17,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x75,0xad,0x21,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xd3,0x9c,0x71,0x8c,0xb2,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5, -0x34,0xa5,0x55,0xad,0x55,0xad,0x75,0xad,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0x17,0xc6,0x10,0x84,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x13,0x9d,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0x96,0xb5,0x65,0x29, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8e,0x73,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5, -0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0xf8,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xc6,0x92,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x51,0x8c, -0x34,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5, -0x34,0xa5,0x14,0xa5,0x34,0xa5,0x14,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5, -0x34,0xa5,0x34,0xa5,0x54,0xa5,0x54,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x76,0xb5, -0x71,0x8c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xd6,0xb5,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x17,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x75,0xad,0x41,0x08,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xf3,0x9c,0x18,0xc6,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xd2,0x9c,0x71,0x94, -0xd2,0x94,0xd3,0x9c,0x13,0x9d,0x34,0xa5,0x54,0xa5,0x55,0xad,0x75,0xad,0x76,0xad, -0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd, -0x17,0xbe,0x14,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0xa5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xb6,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x8e,0x73,0xf7,0xbd,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5, -0xb7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5, -0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x62,0x08,0x71,0x8c,0x14,0xa5,0xf3,0x9c,0xf3,0x9c, -0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0x13,0x9d,0xf3,0xa4,0x13,0x9d,0xf3,0x9c,0x13,0x9d, -0x14,0xa5,0x14,0x9d,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x34,0xa5,0x14,0xa5,0x34,0xa5, -0x34,0xa5,0x34,0xa5,0x34,0xa5,0x54,0xa5,0x75,0xad,0xef,0x7b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xd6,0xb5,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xbe, -0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xbe,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xbe, -0x18,0xc6,0x75,0xad,0x41,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xd3,0x9c,0x91,0x8c,0xb2,0x94,0xf3,0x9c,0xf3,0x9c,0x14,0xa5, -0x34,0xa5,0x55,0xad,0x75,0xad,0x75,0xad,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb7,0xbd,0xd6,0xbd,0xd7,0xbd,0xf7,0xbd,0xb6,0xb5,0x66,0x31,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0x96,0xb5,0x65,0x29, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8e,0x73,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x92,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xe3,0x18,0x72,0x94,0xf3,0x9c,0xd3,0x9c,0xd3,0x9c,0xd3,0x9c,0xd3,0x9c,0xd3,0x9c, -0xf3,0x9c,0xd3,0x9c,0xf3,0x9c,0xd3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c,0xf3,0x9c, -0xf3,0x9c,0xf3,0x9c,0x13,0x9d,0x14,0xa5,0x14,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5, -0x54,0xa5,0x55,0xad,0x4d,0x6b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x24,0x21,0xd6,0xb5,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x17,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x75,0xad,0x41,0x08,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xf3,0x9c,0x38,0xc6,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x17,0xbe, -0x17,0xbe,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xd3,0x9c,0x92,0x94, -0xd2,0x94,0xf3,0x9c,0x13,0x9d,0x34,0xa5,0x54,0xa5,0x55,0xad,0x75,0xad,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xeb,0x5a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0x96,0xb5,0x45,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x8e,0x73,0xf7,0xbd,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5, -0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x45,0x29,0x72,0x94,0xb2,0x94, -0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94, -0xb2,0x94,0xb2,0x94,0xb3,0x94,0xd2,0x9c,0xd3,0x9c,0xd3,0x9c,0xd3,0x9c,0xf3,0x9c, -0xf3,0x9c,0xf3,0x9c,0x14,0xa5,0x14,0xa5,0x34,0xa5,0x34,0xa5,0x55,0xad,0xcb,0x5a, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0xb6,0xb5,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6, -0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe, -0x18,0xc6,0x75,0xad,0x21,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6,0x17,0xbe, -0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0xd3,0x9c,0x92,0x94,0xb3,0x94,0xf3,0x9c,0x14,0xa5,0x34,0xa5, -0x54,0xa5,0x55,0xad,0x75,0xad,0x96,0xad,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xd7,0xb5,0xd6,0xbd,0xf7,0xbd,0xef,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0x96,0xb5,0x45,0x29, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8e,0x73,0xf7,0xbd,0xd6,0xb5,0xd6,0xbd, -0xd6,0xb5,0xd6,0xbd,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x92,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xa6,0x31,0x71,0x8c,0x92,0x94,0x71,0x94,0x71,0x8c,0x72,0x94, -0x91,0x8c,0x92,0x94,0x92,0x94,0x92,0x94,0x92,0x94,0x92,0x94,0x92,0x94,0x92,0x94, -0xb2,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x9c,0xd3,0x9c,0xd3,0x9c,0xf3,0x9c,0xf3,0x9c, -0x13,0x9d,0x14,0xa5,0x34,0xa5,0x34,0xa5,0x28,0x42,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xa3,0x18,0xb6,0xb5,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x76,0xb5,0x41,0x08,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x13,0x9d,0x38,0xc6,0x18,0xbe,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x18,0xc6,0xf3,0x9c,0x92,0x94, -0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x54,0xa5,0x55,0xad,0x75,0xad,0x96,0xb5, -0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xf7,0xbd,0x13,0x9d,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5, -0xd6,0xb5,0xd7,0xb5,0x96,0xb5,0x65,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x8e,0x73,0xf7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd, -0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe7,0x39, -0x51,0x8c,0x51,0x8c,0x51,0x8c,0x51,0x8c,0x51,0x8c,0x51,0x8c,0x51,0x8c,0x51,0x8c, -0x51,0x8c,0x51,0x8c,0x71,0x8c,0x71,0x8c,0x71,0x8c,0x92,0x94,0x92,0x94,0x92,0x94, -0x92,0x94,0xb2,0x94,0xd2,0x94,0xd2,0x9c,0xd3,0x9c,0xf3,0x9c,0xf3,0x9c,0x14,0xa5, -0x14,0xa5,0xa6,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6, -0x38,0xc6,0x75,0xad,0x41,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0x9d,0x18,0xc6,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0x18,0xbe,0xf3,0x9c,0x92,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0x34,0xa5, -0x55,0xad,0x55,0xad,0x75,0xad,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd7,0xbd,0x96,0xb5,0x45,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xa6,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8e,0x73,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe8,0x41,0x10,0x84,0x10,0x84,0x10,0x84, -0x10,0x84,0x10,0x84,0x10,0x84,0x10,0x84,0x10,0x84,0x10,0x84,0x30,0x84,0x30,0x84, -0x30,0x84,0x51,0x8c,0x51,0x8c,0x51,0x8c,0x71,0x8c,0x71,0x8c,0x92,0x94,0x92,0x94, -0xb2,0x94,0xd2,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0xd3,0x9c,0x24,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xa3,0x18,0xb6,0xb5,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x75,0xad,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xf3,0x9c,0x38,0xc6,0x18,0xc6,0x17,0xbe,0xf8,0xc5,0x17,0xbe,0x18,0xc6, -0x17,0xbe,0x17,0xc6,0x17,0xbe,0xf7,0xc5,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0x17,0xbe,0x17,0xc6,0xf3,0x9c,0x92,0x94, -0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad,0x75,0xad,0x96,0xb5, -0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xd7,0xbd,0xd7,0xbd,0xcb,0x5a,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xa6,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x6d,0x6b,0xf7,0xbd,0xb7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0x6d,0x6b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x45,0x29,0x66,0x31,0x65,0x29,0x65,0x29,0x65,0x29,0x66,0x31,0x65,0x29, -0x65,0x29,0x65,0x29,0x66,0x31,0x65,0x29,0x65,0x29,0x65,0x29,0x66,0x31,0x65,0x29, -0x65,0x29,0x65,0x29,0x66,0x31,0x65,0x29,0x65,0x31,0x65,0x29,0x66,0x31,0x65,0x29, -0x65,0x29,0x65,0x29,0x66,0x31,0x65,0x29,0x65,0x29,0x65,0x29,0x66,0x31,0x65,0x29, -0x65,0x29,0x65,0x29,0x66,0x31,0x65,0x29,0x65,0x29,0x65,0x29,0x66,0x31,0x65,0x29, -0x45,0x29,0x8d,0x6b,0x51,0x8c,0x51,0x8c,0x51,0x8c,0x71,0x8c,0x72,0x8c,0x71,0x8c, -0x72,0x94,0x92,0x94,0x92,0x94,0x92,0x94,0x92,0x94,0xb2,0x94,0xb2,0x94,0xb2,0x94, -0xb2,0x94,0xd2,0x9c,0xd3,0x9c,0xf3,0x9c,0xf3,0x9c,0x13,0x9d,0x14,0xa5,0x34,0xa5, -0x34,0xa5,0x75,0xad,0xd3,0x9c,0xc3,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0xb6,0xb5,0x69,0x4a,0xe7,0x39,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42, -0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42, -0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42, -0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42, -0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42, -0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42,0x08,0x42, -0x45,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0x9d,0x18,0xc6,0x17,0xbe, -0xf8,0xc5,0x17,0xbe,0xf7,0xc5,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd, -0x17,0xbe,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0x18,0xc6,0xf3,0x9c,0x92,0x94,0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0x34,0xa5, -0x55,0xad,0x75,0xad,0x75,0xad,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0xb6,0xb5,0xf7,0xbd, -0xcf,0x7b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xa6,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa7,0x31,0x08,0x42,0xe8,0x41,0xe8,0x41, -0xe8,0x41,0xe8,0x41,0xe8,0x41,0xe8,0x41,0x08,0x42,0xe8,0x41,0x08,0x42,0xe8,0x41, -0x08,0x42,0xe8,0x41,0x08,0x42,0xe8,0x41,0x08,0x42,0x08,0x42,0x08,0x42,0xe8,0x41, -0x08,0x42,0x08,0x42,0x08,0x42,0xc7,0x39,0x30,0x84,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0x51,0x8c,0x29,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a, -0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a, -0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a,0x69,0x4a, -0x49,0x4a,0xc3,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x45,0x29,0x14,0xa5,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x2c,0x63, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0xf7,0xbd,0x2c,0x63,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0x9d,0x38,0xc6,0x17,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xbe,0xf8,0xbd, -0x17,0xbe,0xf8,0xc5,0x17,0xbe,0xf8,0xc5,0x17,0xbe,0xf8,0xbd,0xf7,0xbd,0xf8,0xbd, -0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0xf3,0x9c,0xb2,0x94, -0xd3,0x9c,0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x55,0xad,0x75,0xad,0x75,0xad,0x96,0xb5, -0x96,0xb5,0xb6,0xb5,0xd7,0xbd,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xa6,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x92,0x94, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0x18,0xc6,0x96,0xb5,0xe7,0x39,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd3,0x9c, -0x38,0xc6,0x18,0xc6,0x18,0xbe,0x17,0xbe,0x17,0xbe,0x17,0xbe,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe, -0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x38,0xc6,0x8a,0x52,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xbe, -0x38,0xc6,0xd7,0xb5,0xe3,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0x9d,0x38,0xc6,0x17,0xc6, -0x18,0xbe,0x17,0xbe,0xf8,0xc5,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0x17,0xbe, -0x18,0xc6,0x17,0xbe,0x18,0xbe,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0x18,0xc6,0xf3,0x9c,0xb2,0x94,0xf3,0x9c,0x13,0x9d,0x34,0xa5,0x54,0xa5, -0x55,0xad,0x75,0xad,0x76,0xb5,0x96,0xb5,0x96,0xb5,0xb6,0xb5,0x75,0xad,0x45,0x29, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x14,0xa5,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0xa6,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x6d,0x6b,0xf7,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xbd, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x18,0xc6,0xd3,0x9c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x18,0xc6,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x21,0x00,0x75,0xad,0x18,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6, -0x17,0xc6,0xf8,0xbd,0x18,0xbe,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6, -0x18,0xc6,0x17,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xbe,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x75,0xad,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0xa7,0x39,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xf4,0x9c,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe, -0x18,0xc6,0xf8,0xbd,0x18,0xbe,0x18,0xbe,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf8,0xc5, -0x17,0xbe,0xf8,0xc5,0x17,0xbe,0x17,0xbe,0x17,0xbe,0x18,0xc6,0x13,0x9d,0xb2,0x94, -0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad,0x75,0xad,0x96,0xad,0x96,0xb5, -0xb6,0xb5,0xb6,0xb5,0xaa,0x52,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0xa5,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x86,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x14,0xa5,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x75,0xad, -0x18,0xc6,0x17,0xbe,0xf8,0xc5,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf8,0xc5,0x17,0xbe, -0xf8,0xbd,0x17,0xbe,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6, -0x18,0xbe,0x17,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x38,0xc6,0x2c,0x63,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xbe, -0x18,0xc6,0x18,0xc6,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0x9d,0x38,0xc6,0x18,0xbe, -0x17,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xbe,0x17,0xbe,0xf7,0xc5,0x17,0xbe, -0xf7,0xc5,0x17,0xbe,0xf7,0xc5,0x17,0xbe,0xf8,0xc5,0x17,0xbe,0x17,0xbe,0x17,0xbe, -0xf7,0xbd,0x18,0xc6,0x14,0xa5,0xd2,0x94,0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x55,0xa5, -0x55,0xad,0x75,0xad,0x96,0xb5,0x96,0xb5,0xd6,0xb5,0xaf,0x73,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xf3,0xa4,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x86,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb7,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x14,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x18,0xc6,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x41,0x08,0x75,0xad,0x18,0xc6,0x17,0xbe,0x17,0xbe,0x18,0xc6, -0x18,0xbe,0x17,0xc6,0x17,0xc6,0x18,0xc6,0x17,0xc6,0x17,0xbe,0x18,0xbe,0x18,0xc6, -0x17,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x55,0xad,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0xa7,0x39,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x13,0xa5,0x38,0xc6,0x18,0xc6,0x17,0xbe,0x17,0xc6,0x18,0xbe,0x18,0xbe, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xbe, -0x18,0xbe,0xf8,0xbd,0x17,0xbe,0xf7,0xc5,0x17,0xbe,0x18,0xc6,0x14,0xa5,0xd3,0x9c, -0x13,0x9d,0x14,0xa5,0x34,0xa5,0x55,0xad,0x75,0xad,0x75,0xad,0x96,0xb5,0xb6,0xb5, -0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x86,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5, -0xb7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x34,0xa5,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x17,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0x17,0xbe,0x18,0xc6,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x75,0xad, -0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xbe,0x18,0xc6, -0x18,0xbe,0x18,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xbe,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x38,0xc6,0x0c,0x63,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x14,0x9d,0x38,0xc6,0x18,0xbe, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xc6, -0xf8,0xbd,0x17,0xbe,0x17,0xc6,0x17,0xc6,0xf8,0xbd,0x17,0xbe,0x17,0xbe,0x17,0xbe, -0xf8,0xc5,0x18,0xbe,0x14,0xa5,0xd3,0x9c,0x13,0x9d,0x34,0xa5,0x34,0xa5,0x55,0xad, -0x75,0xad,0x75,0xad,0x96,0xb5,0x55,0xad,0x04,0x21,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xf3,0x9c,0x17,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5,0x86,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x18,0xc6,0x14,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0x38,0xc6,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x41,0x08,0x75,0xad,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6, -0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x75,0xad,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0xa7,0x39,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x14,0xa5,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x17,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xbe,0x18,0xc6,0x34,0xa5,0xd3,0x9c, -0x14,0xa5,0x34,0xa5,0x54,0xa5,0x55,0xad,0x75,0xad,0x95,0xb5,0x96,0xb5,0x8a,0x52, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xb7,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5, -0x96,0xb5,0x96,0xb5,0x75,0xad,0x86,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xb7,0xbd,0xd7,0xb5, -0xd6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xb5, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x34,0xa5,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0xf7,0xbd,0x18,0xc6,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x75,0xad, -0x18,0xc6,0x18,0xbe,0x17,0xbe,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6, -0x18,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6, -0x0c,0x63,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd3,0x9c,0x38,0xc6,0x18,0xc6, -0x18,0xc6,0x17,0xbe,0x17,0xc6,0x17,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x17,0xc6, -0x18,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xc6,0x18,0xc6,0x17,0xbe,0xf8,0xc5,0x18,0xbe, -0x17,0xbe,0x18,0xc6,0x34,0xa5,0xf3,0x9c,0x14,0xa5,0x34,0xa5,0x55,0xad,0x55,0xad, -0x75,0xad,0xb6,0xb5,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xad,0x75,0xad,0x86,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd,0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xc5,0x14,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0x17,0xbe,0x17,0xbe,0x17,0xbe,0xf7,0xbd,0x38,0xc6,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x41,0x08,0x75,0xad,0x38,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x75,0xad,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0xc7,0x39,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xb2,0x94,0x38,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x17,0xbe,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6, -0x18,0xbe,0x17,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x54,0xa5,0xf3,0x9c, -0x34,0xa5,0x54,0xa5,0x55,0xad,0x55,0xad,0x96,0xb5,0x92,0x94,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5, -0x95,0xb5,0x75,0xad,0x75,0xad,0x66,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd7,0xb5,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd7,0xb5, -0xd7,0xbd,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x14,0xa5,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x17,0xbe, -0xf7,0xbd,0x17,0xbe,0x18,0xc6,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x75,0xad, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6,0xeb,0x5a, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb2,0x94,0x38,0xc6,0x17,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xbe, -0x18,0xbe,0x18,0xc6,0x54,0xad,0x13,0xa5,0x34,0xa5,0x54,0xa5,0x55,0xad,0x75,0xad, -0x34,0xa5,0xe4,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x76,0xb5,0x75,0xad,0x75,0xad,0xa6,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd,0xb6,0xb5,0xd7,0xb5,0xd6,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd6,0xb5,0xd6,0xb5,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x17,0xc6,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x08,0x42,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xc5,0x17,0xbe,0xf7,0xc5,0x38,0xc6,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x41,0x08,0x75,0xad,0x38,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6, -0x17,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x38,0xc6,0x55,0xad,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0xa7,0x39,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xb3,0x9c,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x54,0xad,0x14,0xa5, -0x34,0xa5,0x55,0xad,0x75,0xad,0x75,0xad,0x49,0x4a,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xd7,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x96,0xb5, -0x75,0xad,0x75,0xad,0x75,0xad,0xa7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd, -0xd6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5, -0xd7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xd6,0xb5,0xd6,0xb5, -0xd6,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x14,0xa5,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x28,0x42,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0x17,0xbe,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0x18,0xc6,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x21,0x08,0x75,0xad, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0xcb,0x5a,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd2,0x94,0x38,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x17,0xbe,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x17,0xbe, -0x18,0xc6,0x18,0xc6,0x55,0xad,0x34,0xa5,0x54,0xa5,0x55,0xad,0x96,0xb5,0x6d,0x6b, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x95,0xad,0x75,0xad,0x55,0xad,0x75,0xad,0xa6,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd,0xd6,0xb5,0xd7,0xb5,0xd6,0xb5,0xb6,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd6,0xbd,0xb7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xb5, -0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x18,0xc6,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x8a,0x52,0x18,0xc6,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0x17,0xbe,0x17,0xbe,0x17,0xbe,0xf8,0xbd,0x17,0xbe,0xf8,0xbd,0x38,0xc6,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x41,0x08,0x76,0xad,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x55,0xad,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0xa7,0x39,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xd2,0x9c,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x75,0xad,0x34,0xa5, -0x55,0xad,0x76,0xb5,0x71,0x8c,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd6,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xad,0x75,0xad, -0x75,0xad,0x55,0xad,0x55,0xad,0xa6,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x84,0xf7,0xbd, -0xb6,0xb5,0xd6,0xb5,0xb7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xbd, -0xd7,0xb5,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd6,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xc6,0x14,0xa5,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8a,0x52,0x18,0xc6, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe, -0x17,0xc6,0x17,0xbe,0x38,0xc6,0xb2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x08,0x75,0xad, -0x18,0xc6,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0xcb,0x5a,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xb6,0xb5,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb2,0x94,0x38,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x17,0xc6,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x18,0xbe, -0x18,0xc6,0x18,0xc6,0x75,0xad,0x34,0xa5,0x75,0xad,0x14,0xa5,0xe3,0x18,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xf3,0x9c,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xb7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5, -0x96,0xb5,0x96,0xb5,0x76,0xb5,0x75,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0xa6,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x30,0x84,0xd7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd7,0xb5,0xd7,0xb5, -0xd7,0xbd,0xd7,0xb5,0xd6,0xb5,0xd6,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x18,0xc6,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x8a,0x52,0x18,0xc6,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xc5,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf8,0xc5, -0x17,0xbe,0xf7,0xc5,0x17,0xbe,0x18,0xc6,0x17,0xc6,0x18,0xbe,0x38,0xc6,0xb2,0x94, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x41,0x08,0x76,0xad,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x58,0xc6, -0x55,0xad,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xc3,0x18,0xd6,0xb5,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0xc7,0x39,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x0c,0x63,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x96,0xad,0x55,0xad, -0x75,0xad,0x29,0x4a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0x9d,0x18,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5,0x95,0xad,0x75,0xad, -0x55,0xad,0x55,0xad,0x55,0xad,0xa6,0x31,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x84,0xf7,0xbd, -0xb7,0xbd,0xd6,0xb5,0xb7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd6,0xb5,0xb6,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xb5,0xd6,0xbd,0xd7,0xbd,0xd6,0xbd, -0xd7,0xbd,0xd7,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xc6,0x34,0xa5,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x69,0x4a,0x38,0xc6, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd, -0x17,0xbe,0xf7,0xbd,0x17,0xc6,0xf7,0xbd,0xf7,0xc5,0x17,0xbe,0x18,0xc6,0x17,0xbe, -0xf8,0xc5,0x17,0xbe,0x38,0xc6,0xd2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x08,0x96,0xb5, -0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x58,0xc6,0xcb,0x5a,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xd6,0xb5,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x8c,0x18,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x96,0xb5,0x75,0xad,0x4d,0x6b,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0xd3,0x9c,0x18,0xc6,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd6,0xbd,0xb6,0xbd,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0x96,0xb5,0x95,0xb5,0x75,0xad,0x75,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x86,0x31, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x50,0x84,0xf7,0xbd,0xd6,0xb5,0xd6,0xbd,0xd6,0xb5,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xb5,0xd7,0xbd, -0xd6,0xb5,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0x18,0xc6,0x34,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x65,0x29,0xf7,0xbd,0x18,0xc6,0xf8,0xc5,0x17,0xbe,0x17,0xc6, -0x17,0xbe,0x18,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xc6,0x17,0xc6,0x18,0xbe,0x17,0xbe, -0x18,0xc6,0x18,0xc6,0x18,0xbe,0x18,0xc6,0x17,0xbe,0x18,0xc6,0x58,0xc6,0xcf,0x7b, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0xf3,0x9c,0x59,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6, -0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6,0x38,0xc6,0x18,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x58,0xc6,0x58,0xce,0x71,0x8c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x34,0xa5,0x59,0xce,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x58,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x58,0xc6,0x38,0xc6,0x58,0xc6,0x38,0xc6,0x58,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x58,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x58,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x59,0xc6,0xb6,0xb5,0x82,0x10,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x86,0x31,0x0c,0x63,0x30,0x84,0xf3,0x9c,0x75,0xad, -0xf7,0xbd,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x18,0xc6,0x18,0xc6, -0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0x18,0xc6,0xb6,0xb5,0x51,0x8c, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0c,0x63,0x18,0xc6, -0x18,0xc6,0x17,0xbe,0x18,0xc6,0x18,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x95,0xb5,0x75,0xad, -0x75,0xad,0x75,0xad,0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2d,0x6b,0xf7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0xf7,0xbd,0xf7,0xbd,0xf8,0xbd,0x17,0xbe, -0xf7,0xc5,0x17,0xbe,0x17,0xc6,0x17,0xbe,0x17,0xc6,0x38,0xc6,0x10,0x84,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xae,0x73, -0xd7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0x17,0xbe,0x17,0xbe,0x18,0xc6,0x17,0xbe, -0xf8,0xbd,0x17,0xbe,0x18,0xc6,0x17,0xbe,0x18,0xbe,0x18,0xc6,0x18,0xc6,0x17,0xc6, -0x18,0xc6,0xf7,0xbd,0xf3,0x9c,0x62,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29, -0x35,0xad,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd, -0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe,0xf7,0xbd,0x17,0xbe, -0xf7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd7,0xbd, -0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xd7,0xbd,0xf7,0xbd, -0xd7,0xbd,0x76,0xad,0x8e,0x73,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x86,0x31,0x54,0xa5, -0xd7,0xbd,0xd7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xf7,0xbd,0xd7,0xbd,0xd6,0xb5, -0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xd6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5, -0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0xb6,0xb5,0x96,0xb5,0x96,0xb5, -0x54,0xa5,0x08,0x42,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x45,0x29,0x29,0x4a,0x8e,0x73,0x71,0x8c, -0x34,0xa5,0x96,0xb5,0x17,0xbe,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6,0x38,0xc6, -0x18,0xc6,0x38,0xc6,0x55,0xad,0xa2,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x6d,0x6b,0x34,0xa5,0x34,0xa5,0x34,0xa5,0x34,0xa5, -0x34,0xa5,0x34,0xa5,0x14,0xa5,0x14,0xa5,0x14,0xa5,0x13,0x9d,0xf3,0x9c,0xf3,0x9c, -0xf3,0x9c,0xd3,0x9c,0xd3,0x9c,0xb2,0x94,0xb2,0x94,0xef,0x7b,0x04,0x21,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x84,0x55,0xad,0x55,0xad,0x75,0xad,0x55,0xad, -0x75,0xad,0x55,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x55,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x55,0xad,0x75,0xad,0x55,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad, -0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad, -0x55,0xad,0x55,0xad,0x75,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x55,0xad,0x75,0xad, -0x55,0xad,0x55,0xad,0x75,0xad,0x55,0xad,0x75,0xad,0x55,0xad,0x75,0xad,0x75,0xad, -0x75,0xad,0x31,0x8c,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x24,0x21,0xc7,0x39,0xc7,0x39,0xc7,0x39, -0xc7,0x39,0xc7,0x39,0xa7,0x39,0xc7,0x39,0xc7,0x39,0xc7,0x39,0xa7,0x39,0xc7,0x39, -0xc7,0x39,0xc7,0x39,0xa7,0x39,0xc7,0x39,0xc7,0x39,0x86,0x31,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0x66,0x31,0x66,0x31, -0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31, -0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31, -0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31, -0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31, -0x65,0x29,0x66,0x31,0x65,0x29,0x66,0x31,0x45,0x29,0x24,0x21,0x24,0x21,0x24,0x21, -0x24,0x21,0x24,0x21,0x24,0x21,0x24,0x21,0x24,0x21,0x24,0x21,0x24,0x21,0x24,0x21, -0x24,0x21,0x24,0x21,0x24,0x21,0x24,0x21,0x24,0x21,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21,0x24,0x21,0x24,0x21,0x24,0x21, -0x24,0x21,0x24,0x29,0x24,0x21,0xe3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18, -0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18, -0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18, -0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18, -0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18, -0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18, -0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18,0xc3,0x18, -0xc3,0x18,0xc3,0x18,0x61,0x08,0x41,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x10,0x86,0x31,0xaa,0x52, -0xef,0x7b,0xd3,0x9c,0x75,0xad,0xd6,0xb5,0xf7,0xbd,0xb6,0xb5,0x8a,0x52,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x64,0x00,0xc6,0x00,0xc5,0x00,0xc6,0x00, -0xc5,0x00,0x85,0x00,0x84,0x00,0x43,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x41,0x08,0xa2,0x10,0x82,0x10,0xa2,0x10,0x82,0x10,0xa2,0x10,0x82,0x10,0xa2,0x10, -0x82,0x10,0xa2,0x10,0x82,0x10,0xa2,0x10,0xa2,0x10,0xa2,0x10,0x82,0x10,0xa2,0x10, -0xa2,0x10,0xa2,0x10,0x82,0x10,0xa2,0x10,0xa2,0x10,0xa2,0x10,0xa2,0x10,0xa2,0x10, -0xa2,0x10,0xa2,0x10,0xa2,0x10,0xa2,0x10,0xa2,0x10,0xa2,0x10,0xa2,0x10,0xa2,0x10, -0xa3,0x10,0xa2,0x10,0xa2,0x18,0xa3,0x10,0x82,0x10,0x21,0x08,0x21,0x08,0x20,0x08, -0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08, -0x21,0x08,0x21,0x08,0x21,0x08,0x20,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08, -0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08,0x21,0x08, -0x21,0x08,0x21,0x08,0x21,0x08,0x41,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x21, -0x66,0x31,0x61,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xd6,0x33,0x99,0x44,0x78,0x44,0x78,0x44,0x58,0x44,0x58,0x44,0x98,0x4c,0x99,0x54, -0x78,0x54,0xb5,0x3b,0x6f,0x1a,0x28,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00, -0x69,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2d,0x12,0x99,0x44,0x99,0x44,0x99,0x44, -0x99,0x44,0x79,0x44,0x99,0x44,0xda,0x4c,0x1b,0x5d,0x3c,0x65,0xfb,0x4c,0x79,0x34, -0xb5,0x23,0xcb,0x11,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x12,0x23,0x79,0x3c,0xc6,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x12,0x23,0xb9,0x44,0x79,0x44,0x79,0x44,0x78,0x44,0x79,0x44,0x78,0x44, -0x99,0x4c,0xfa,0x5c,0x1b,0x65,0xfb,0x54,0x9a,0x3c,0x59,0x24,0xd1,0x22,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0d,0x0a,0x79,0x3c, -0x79,0x3c,0x4e,0x12,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0xf6,0x33,0x99,0x44, -0x78,0x44,0x79,0x44,0x78,0x44,0x78,0x44,0x78,0x44,0x99,0x44,0xda,0x54,0x1b,0x5d, -0xfb,0x54,0x9a,0x3c,0x59,0x24,0x72,0x3b,0x20,0x08,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xa6,0x00,0x37,0x34,0x79,0x3c,0x79,0x3c,0xb5,0x2b,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x07,0x01,0x58,0x44,0x79,0x44,0x78,0x44,0x78,0x44,0x78,0x44, -0x58,0x44,0x58,0x3c,0x78,0x44,0xb9,0x4c,0x1b,0x5d,0x1b,0x5d,0xba,0x44,0x79,0x2c, -0xb2,0x5b,0xa1,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x95,0x2b,0x79,0x3c,0x58,0x3c, -0x79,0x3c,0x58,0x3c,0xc6,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2d,0x12, -0x99,0x44,0x78,0x44,0x78,0x44,0x78,0x44,0x78,0x44,0x58,0x44,0x58,0x3c,0x58,0x44, -0x99,0x4c,0xfa,0x5c,0x1b,0x5d,0xba,0x44,0x78,0x4c,0xf0,0x7b,0x24,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xb0,0x1a,0x79,0x3c,0x58,0x3c,0x58,0x3c,0x78,0x3c,0x99,0x3c,0x6f,0x12,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x12,0x23,0x99,0x44,0x58,0x44,0x78,0x44, -0x58,0x44,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x79,0x44,0xda,0x54,0x1b,0x5d, -0xda,0x4c,0xd5,0x84,0x50,0x8c,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x8a,0x01,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c, -0x58,0x3c,0x79,0x3c,0xb5,0x2b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x01,0x00,0xd6,0x33,0x79,0x44,0x58,0x44,0x58,0x44,0x58,0x44,0x58,0x3c,0x58,0x3c, -0x58,0x3c,0x58,0x3c,0x79,0x44,0xda,0x54,0x1b,0x5d,0x18,0x85,0x13,0xa5,0x71,0x8c, -0x69,0x4a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x00,0xf6,0x33, -0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x78,0x3c,0x79,0x3c,0x58,0x34,0xa6,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x01,0x37,0x3c,0x58,0x44, -0x58,0x44,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x78,0x44, -0xba,0x4c,0x59,0x8d,0x96,0xb5,0x14,0xa5,0x92,0x94,0xeb,0x5a,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x33,0x23,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c, -0x58,0x3c,0x58,0x3c,0x58,0x34,0xed,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x2d,0x12,0x78,0x44,0x78,0x44,0x58,0x44,0x58,0x3c,0x58,0x3c, -0x58,0x3c,0x58,0x44,0x58,0x3c,0x58,0x3c,0x79,0x34,0x59,0x85,0x58,0xce,0xd6,0xb5, -0x34,0xa5,0xb2,0x94,0x6d,0x6b,0x20,0x00,0x00,0x00,0x2e,0x12,0x58,0x3c,0x58,0x3c, -0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x78,0x3c,0x58,0x34,0x38,0x2c,0xf2,0x12, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x8f,0x1a, -0x74,0x2b,0x94,0x2b,0xb5,0x33,0xb5,0x33,0xd5,0x33,0xd6,0x33,0xf6,0x33,0xf6,0x33, -0xd6,0x23,0xf7,0x7c,0x9a,0xd6,0x59,0xce,0xd7,0xbd,0x55,0xad,0xd3,0x9c,0xae,0x73, -0xa8,0x21,0xf7,0x33,0x38,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c, -0x58,0x3c,0x38,0x34,0xf7,0x23,0x74,0x1b,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x10,0x00,0x00,0x00,0x00,0x00,0x00, -0x01,0x00,0x02,0x00,0x23,0x00,0x23,0x00,0x01,0x00,0xec,0x5a,0xba,0xd6,0x9a,0xd6, -0x79,0xce,0xf7,0xbd,0x75,0xad,0xd3,0x9c,0x51,0x84,0x36,0x4c,0x38,0x34,0x58,0x3c, -0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x17,0x2c,0xf7,0x1b,0x95,0x23, -0x64,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x10,0xec,0x5a, -0x30,0x84,0x8e,0x73,0x20,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xe7,0x39,0xba,0xd6,0x9a,0xd6,0x9a,0xd6,0x99,0xce,0x18,0xc6,0x96,0xb5, -0xd2,0x9c,0xd4,0x43,0x38,0x34,0x38,0x3c,0x38,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c, -0x58,0x34,0x17,0x24,0xd6,0x1b,0xb5,0x23,0x85,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x69,0x4a,0x0f,0x7c,0x71,0x8c,0xd3,0x9c,0x55,0xad,0xb2,0x94,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x42,0xba,0xd6,0x9a,0xd6, -0x9a,0xd6,0x9a,0xd6,0x99,0xd6,0x59,0xce,0x0f,0x84,0xcc,0x01,0x58,0x3c,0x38,0x3c, -0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x37,0x2c,0xf6,0x23,0xb5,0x13,0x53,0x23, -0x43,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0xa7,0x39,0xae,0x73,0x51,0x8c,0xb2,0x94,0x14,0xa5, -0x75,0xad,0xf7,0xbd,0x79,0xce,0xd2,0x94,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xe7,0x39,0xba,0xd6,0x9a,0xd6,0x9a,0xd6,0x9a,0xd6,0xba,0xd6,0x38,0xc6, -0xc3,0x18,0x24,0x00,0x17,0x34,0x58,0x34,0x58,0x3c,0x58,0x3c,0x58,0x3c,0x58,0x34, -0x17,0x2c,0xd6,0x1b,0x95,0x13,0xd0,0x22,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x25,0x29,0x6d,0x6b,0x51,0x8c, -0x92,0x94,0xf3,0x9c,0x55,0xad,0xd6,0xb5,0x38,0xc6,0x79,0xce,0x9a,0xd6,0xba,0xd6, -0x0c,0x63,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc7,0x39,0x9a,0xd6,0x9a,0xd6, -0x99,0xd6,0x9a,0xd6,0x9a,0xd6,0x8a,0x52,0x00,0x00,0x00,0x00,0x74,0x23,0x58,0x3c, -0x58,0x3c,0x58,0x3c,0x58,0x3c,0x38,0x34,0xf7,0x23,0xd6,0x13,0x94,0x1b,0xa9,0x21, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x81,0x10, -0xeb,0x5a,0x30,0x84,0x71,0x94,0xd3,0x9c,0x34,0xa5,0x96,0xb5,0xf7,0xbd,0x79,0xce, -0x9a,0xd6,0x9a,0xd6,0x9a,0xd6,0xba,0xd6,0x79,0xce,0xa6,0x31,0x00,0x00,0x00,0x00, -0x00,0x00,0xc7,0x39,0x9a,0xd6,0x9a,0xd6,0x9a,0xd6,0xba,0xd6,0x51,0x8c,0x00,0x00, -0x00,0x00,0x00,0x00,0x0d,0x12,0x58,0x3c,0x58,0x34,0x58,0x3c,0x58,0x3c,0x37,0x2c, -0xd6,0x0b,0x95,0x03,0xd2,0x5b,0x41,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x08,0x8a,0x4a,0x11,0x74,0x72,0x84,0xb3,0x8c,0x14,0x9d,0x75,0xb5, -0xf7,0xbd,0x58,0xce,0x99,0xce,0x9a,0xd6,0xba,0xd6,0x9a,0xd6,0x9a,0xd6,0x9a,0xd6, -0xba,0xd6,0xd7,0xbd,0x41,0x08,0x00,0x00,0x00,0x00,0x86,0x31,0x79,0xce,0x9a,0xd6, -0xba,0xd6,0x96,0xb5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x85,0x00,0x17,0x34, -0x58,0x3c,0x58,0x34,0x38,0x24,0xd7,0x03,0x16,0x3c,0xb5,0x84,0x6d,0x6b,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x2c,0x22,0x15,0x4c,0x78,0x4c,0xb9,0x4c, -0xfa,0x54,0xfa,0x64,0xf9,0x64,0x39,0x85,0xd9,0xad,0x39,0xc6,0xba,0xd6,0xda,0xd6, -0xba,0xd6,0x9a,0xd6,0x9a,0xd6,0xba,0xd6,0x9a,0xd6,0xda,0xd6,0xd3,0x9c,0x00,0x00, -0x00,0x00,0x86,0x31,0x79,0xce,0xba,0xd6,0x59,0xce,0x65,0x29,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x13,0x13,0x58,0x2c,0x78,0x4c,0xf8,0x74,0x78,0x95, -0xb7,0xb5,0x54,0xad,0x24,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xa5,0x00,0xb5,0x33, -0x79,0x2c,0x9a,0x2c,0xdb,0x44,0xfb,0x54,0xfb,0x54,0xda,0x54,0xda,0x4c,0xba,0x4c, -0x99,0x44,0xc8,0x21,0xe8,0x41,0x92,0x94,0xd7,0xbd,0x9a,0xd6,0xda,0xd6,0xba,0xd6, -0xba,0xd6,0x9a,0xd6,0xba,0xd6,0x2c,0x63,0x00,0x00,0xe4,0x20,0xf7,0xbd,0xba,0xd6, -0x0c,0x63,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x91,0x5b, -0xb9,0x9d,0x59,0xbe,0x9a,0xd6,0x59,0xce,0xd7,0xbd,0x10,0x84,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x85,0x00,0xf7,0x2b,0x9a,0x2c,0xba,0x44,0xfb,0x54,0xfb,0x5c,0xfa,0x54, -0xda,0x54,0xda,0x54,0xba,0x54,0xda,0x54,0xf6,0x3b,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xa7,0x39,0xcf,0x7b,0x96,0xb5,0x59,0xce,0xba,0xd6,0xdb,0xde,0x96,0xb5, -0x00,0x00,0x00,0x00,0xe3,0x18,0xc7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x29,0x4a,0x92,0x94,0xf7,0xbd,0x9a,0xd6,0x9a,0xd6,0x9a,0xd6,0x79,0xce,0x18,0xbe, -0x75,0xad,0xe7,0x39,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb5,0x2b,0xbb,0x3c,0xdb,0x4c, -0x1b,0x5d,0xfb,0x5c,0xfa,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54, -0x8e,0x1a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x45,0x29,0x4d,0x6b,0x34,0xa5,0x08,0x42,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x08,0x42,0x92,0x94,0xf7,0xbd,0xba,0xd6,0xba,0xd6,0xba,0xd6,0x9a,0xd6, -0x9a,0xd6,0x9a,0xd6,0x59,0xce,0xf7,0xbd,0x92,0x94,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x8f,0x1a,0xfb,0x4c,0x1b,0x5d,0x1b,0x5d,0xfa,0x5c,0xfa,0x54,0xda,0x54,0xda,0x54, -0xda,0x54,0xda,0x54,0xda,0x54,0x99,0x4c,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x86,0x31,0x9a,0xd6,0xba,0xd6,0xba,0xd6, -0x9a,0xd6,0x9a,0xd6,0x9a,0xd6,0x9a,0xd6,0x9a,0xd6,0x99,0xce,0x38,0xc6,0xb6,0xb5, -0xab,0x5a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x22,0x00,0xb9,0x54,0x3b,0x5d,0x1b,0x5d,0xfa,0x54, -0xfa,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xb5,0x3b, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x24,0x21,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x45,0x29,0x38,0xc6,0xda,0xd6,0xba,0xd6,0xba,0xd6,0x9a,0xd6,0x9a,0xd6,0x9a,0xd6, -0x9a,0xd6,0x79,0xce,0xf7,0xbd,0x14,0xa5,0x61,0x08,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xad,0x22, -0x3c,0x5d,0x1b,0x5d,0xfa,0x54,0xfa,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54, -0xda,0x54,0xda,0x54,0xda,0x54,0x0b,0x12,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0xa6,0x31,0xae,0x73,0xb6,0xb5,0x79,0xce,0x8e,0x73, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe4,0x20,0xeb,0x5a,0x34,0xa5, -0x38,0xc6,0xba,0xd6,0xba,0xd6,0xba,0xd6,0x9a,0xd6,0x58,0xc6,0xb6,0xb5,0x8d,0x6b, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x37,0x4c,0x1b,0x5d,0xfb,0x54,0xfa,0x54,0xda,0x54, -0xfa,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0x78,0x4c,0x02,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe8,0x41,0x30,0x84,0xd7,0xb5,0x9a,0xd6, -0xda,0xd6,0xba,0xd6,0xdb,0xde,0x75,0xad,0x00,0x00,0x00,0x00,0x8a,0x52,0x8e,0x73, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xc3,0x18,0xaa,0x52,0xf3,0x9c,0x18,0xc6, -0x9a,0xd6,0x38,0xc6,0x55,0xad,0x24,0x29,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x26,0x01,0xfb,0x5c, -0xfb,0x5c,0xfb,0x54,0xfb,0x54,0xfa,0x54,0xfa,0x54,0xfa,0x54,0xda,0x54,0xfa,0x54, -0xfb,0x54,0xba,0x54,0xaf,0x22,0x00,0x00,0x00,0x00,0x49,0x4a,0x92,0x94,0x38,0xc6, -0xba,0xd6,0xda,0xd6,0xba,0xd6,0xba,0xd6,0x9a,0xd6,0xba,0xd6,0x79,0xce,0x86,0x31, -0x00,0x00,0x45,0x29,0x9a,0xd6,0xdb,0xde,0x10,0x84,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x82,0x10,0x08,0x42,0x10,0x7c,0x32,0x74,0x01,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x10,0x2b,0x1b,0x5d,0xfb,0x5c,0xfb,0x5c,0xfb,0x5c,0xfb,0x5c, -0x1b,0x55,0xfb,0x54,0x98,0x4c,0xb5,0x3b,0x4d,0x1a,0xc5,0x00,0x00,0x00,0x00,0x00, -0x10,0x84,0xf7,0xbd,0xba,0xd6,0xfb,0xde,0xdb,0xde,0xba,0xd6,0x9a,0xd6,0x9a,0xd6, -0xba,0xd6,0xba,0xd6,0x6d,0x6b,0x00,0x00,0x00,0x00,0x66,0x31,0x79,0xce,0xba,0xd6, -0xba,0xd6,0x69,0x4a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x45,0x00,0x54,0x23,0x58,0x34,0xf6,0x33,0xf2,0x22,0x69,0x01,0x02,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x57,0x4c,0x1b,0x5d, -0x1b,0x5d,0x1b,0x5d,0xfb,0x5c,0x58,0x4c,0x53,0x33,0xea,0x11,0x43,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xcf,0x7b,0x96,0xb5,0x59,0xce,0xdb,0xde, -0xdb,0xde,0xba,0xd6,0x9a,0xd6,0x9a,0xd6,0xdb,0xd6,0x34,0xa5,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0x79,0xce,0xba,0xd6,0xba,0xd6,0x58,0xc6,0x45,0x29,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x4e,0x12,0x38,0x3c,0x99,0x44,0x79,0x44,0x99,0x44, -0x99,0x44,0x99,0x44,0x17,0x3c,0x12,0x23,0x89,0x01,0x02,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x26,0x01,0x1b,0x5d,0xda,0x54,0x16,0x44,0xef,0x2a,0x47,0x09,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0xaa,0x52,0x75,0xad,0x38,0xc6,0xda,0xd6,0xfb,0xde,0xba,0xd6,0xba,0xd6,0xba,0xd6, -0x18,0xc6,0xe3,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x66,0x31,0x79,0xce,0xba,0xd6, -0x9a,0xd6,0xba,0xd6,0xb6,0xb5,0x00,0x00,0x00,0x00,0x85,0x00,0x74,0x2b,0x99,0x44, -0x79,0x44,0x79,0x44,0x79,0x44,0x79,0x44,0x79,0x44,0x79,0x44,0x99,0x44,0xba,0x44, -0xb9,0x44,0x17,0x3c,0x12,0x23,0x89,0x01,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0xea,0x11,0xc5,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x65,0x29,0x54,0xa5,0xf7,0xbd,0xba,0xd6, -0xfb,0xde,0xda,0xd6,0xba,0xd6,0xba,0xd6,0x69,0x4a,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0x79,0xce,0xba,0xd6,0x9a,0xd6,0x9a,0xd6,0xda,0xd6,0x92,0x94, -0xab,0x01,0x37,0x3c,0x99,0x44,0x78,0x44,0x79,0x44,0x79,0x44,0x79,0x44,0x79,0x44, -0x79,0x44,0x99,0x44,0x99,0x44,0x99,0x44,0x99,0x44,0x9a,0x44,0xba,0x44,0xba,0x44, -0x38,0x3c,0x53,0x23,0x84,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x41,0x08,0xb2,0x94,0xd7,0xb5,0x79,0xce,0xfb,0xde,0xdb,0xde,0xda,0xde,0x10,0x84, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x66,0x31,0x79,0xce,0xba,0xd6, -0x9a,0xd6,0x9a,0xd6,0x9a,0xd6,0xba,0xd6,0x59,0x85,0x79,0x34,0x79,0x44,0x79,0x44, -0x99,0x44,0x79,0x44,0x99,0x44,0x99,0x44,0x99,0x44,0x99,0x44,0x99,0x44,0x99,0x44, -0x99,0x44,0x99,0x44,0x99,0x44,0x9a,0x44,0xda,0x44,0x79,0x44,0x07,0x01,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x84,0x96,0xb5,0x59,0xce, -0xdb,0xde,0xfb,0xde,0x3a,0xbe,0xc9,0x19,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0x79,0xce,0xda,0xd6,0xba,0xd6,0xba,0xd6,0xba,0xd6,0xba,0xd6, -0x9a,0xce,0xf9,0x6c,0x59,0x34,0x79,0x44,0x79,0x44,0x99,0x44,0x99,0x44,0x99,0x44, -0x99,0x44,0x99,0x44,0x99,0x44,0x99,0x44,0x99,0x44,0x99,0x44,0xba,0x44,0xba,0x44, -0xb5,0x2b,0xa5,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x2c,0x63,0x75,0xad,0x18,0xc6,0xda,0xde,0xdb,0xd6,0x3a,0x75,0x99,0x44, -0x6d,0x1a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x45,0x29,0xba,0xd6,0x1c,0xe7, -0xfb,0xde,0xfb,0xde,0xfb,0xde,0xdb,0xde,0xfb,0xde,0x7a,0xc6,0x98,0x4c,0x38,0x2c, -0x58,0x34,0x58,0x34,0x58,0x34,0x79,0x3c,0x79,0x3c,0x79,0x3c,0x79,0x3c,0x79,0x3c, -0x99,0x3c,0x9a,0x44,0x79,0x44,0xb0,0x1a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xe7,0x39,0x55,0xad,0xf7,0xbd, -0xba,0xd6,0xda,0x9d,0xba,0x44,0xda,0x54,0xda,0x54,0x73,0x33,0x02,0x00,0x00,0x00, -0x00,0x00,0x65,0x29,0xda,0xde,0x1c,0xe7,0x1b,0xdf,0x1c,0xe7,0x1b,0xdf,0x1c,0xdf, -0x1c,0xe7,0x3c,0xe7,0x1a,0xb6,0xd6,0x13,0xd6,0x13,0xf6,0x23,0xf7,0x23,0x17,0x24, -0x17,0x24,0x17,0x24,0x17,0x24,0x38,0x2c,0x38,0x2c,0xb5,0x23,0x28,0x01,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0xa3,0x18,0xf3,0x9c,0xd7,0xbd,0xd9,0xa5,0xba,0x4c,0xda,0x4c,0xda,0x54, -0xda,0x54,0xda,0x54,0x37,0x44,0x07,0x01,0x00,0x00,0xa7,0x39,0x59,0xce,0x79,0xce, -0x99,0xce,0x9a,0xd6,0xba,0xd6,0xba,0xd6,0xba,0xd6,0xdb,0xde,0xfb,0xde,0x58,0x95, -0x74,0x03,0x95,0x03,0x95,0x1b,0x95,0x1b,0xb5,0x1b,0xb5,0x1b,0xd6,0x1b,0xd6,0x1b, -0x6f,0x0a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x51,0x8c,0x96,0xad, -0x98,0x54,0x99,0x3c,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0x99,0x4c, -0x48,0x01,0x00,0x00,0x0c,0x63,0x8e,0x73,0x30,0x84,0x92,0x94,0xf3,0x9c,0x34,0xa5, -0x75,0xad,0xb6,0xb5,0x18,0xbe,0x58,0xc6,0x16,0x95,0x93,0x3b,0x33,0x0b,0x53,0x13, -0x53,0x13,0x73,0x1b,0xd0,0x1a,0xe7,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x8d,0x73,0xf6,0x8c,0x17,0x0c,0x99,0x44,0xda,0x54,0xda,0x54, -0xda,0x54,0xda,0x54,0xda,0x54,0xfb,0x54,0xcf,0x22,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x08,0xe4,0x20,0x86,0x31,0x08,0x42, -0xeb,0x5a,0xcc,0x52,0x4c,0x32,0x4d,0x1a,0x0c,0x1a,0xe6,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x69,0x52,0x55,0x64, -0xf7,0x03,0x79,0x3c,0xda,0x4c,0xfa,0x54,0xda,0x54,0xda,0x54,0xda,0x54,0xfa,0x54, -0xaf,0x22,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x45,0x29,0xf5,0x4b,0xf7,0x03,0x58,0x34,0xda,0x4c,0xda,0x54, -0xda,0x54,0xda,0x54,0xfa,0x54,0xfb,0x54,0xcf,0x22,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x41,0x08,0x52,0x33, -0xd6,0x0b,0x38,0x2c,0xba,0x4c,0xfa,0x54,0xfa,0x54,0xfa,0x54,0xda,0x54,0xfb,0x54, -0xaf,0x22,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0xd0,0x2a,0xd6,0x13,0x18,0x24,0x99,0x44,0xfb,0x54, -0xfb,0x54,0xfb,0x54,0xfa,0x54,0xfb,0x54,0xcf,0x22,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x89,0x11, -0xd6,0x23,0x17,0x1c,0x79,0x3c,0xfa,0x54,0xfb,0x54,0xfb,0x54,0xfb,0x54,0x1b,0x55, -0x8e,0x22,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xb0,0x22,0x18,0x1c,0x79,0x34,0xda,0x54, -0xfb,0x54,0xfb,0x54,0xfb,0x54,0x1b,0x5d,0x8d,0x1a,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x12,0x1b,0x59,0x2c,0xda,0x4c,0xfb,0x54,0xfb,0x54,0xfb,0x54,0x1b,0x55, -0x8d,0x1a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xd1,0x1a,0xda,0x4c, -0x1b,0x55,0xfb,0x5c,0xfb,0x54,0x1b,0x5d,0x6c,0x1a,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x6d,0x1a,0xda,0x54,0x1b,0x5d,0xfb,0x54,0x1b,0x5d, -0x2b,0x1a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x67,0x09,0x78,0x4c,0x3c,0x5d,0x1c,0x5d,0x2b,0x1a,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x73,0x33,0x3c,0x5d, -0x2b,0x1a,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, -0x00,0x00,0x00,0x00,0x00,0x00}; -#endif diff --git a/lib/tizen/tizen_logo_16bpp_gzip.h b/lib/tizen/tizen_logo_16bpp_gzip.h deleted file mode 100644 index d8526f88a949..000000000000 --- a/lib/tizen/tizen_logo_16bpp_gzip.h +++ /dev/null @@ -1,647 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2013 Samsung Electronics - * Przemyslaw Marczak p.marczak@samsung.com - */ - -#ifndef __TIZEN_LOGO_16BPP_GZIP__ -#define __TIZEN_LOGO_16BPP_GZIP__ - -/* Format: GZIP: BMP RGB565 16BPP 452x140 */ -unsigned char tizen_logo_16bpp_gzip[] = { -0x1f,0x8b,0x08,0x08,0xd9,0x76,0x29,0x53,0x00,0x03,0x74,0x69,0x7a,0x65,0x6e,0x5f, -0x6c,0x6f,0x67,0x6f,0x2e,0x62,0x6d,0x70,0x00,0xed,0x9d,0x6f,0x6c,0x1b,0x67,0x7e, -0xe7,0xa9,0x4d,0x80,0x65,0xbb,0x2e,0x56,0xb1,0xd8,0x25,0xcf,0x0a,0x70,0x52,0xa4, -0x2d,0xc2,0x5a,0x39,0x58,0x35,0xf7,0x42,0x35,0x7a,0x63,0xd5,0x6a,0x1b,0x9d,0x5c, -0xd4,0x0a,0x85,0xca,0xde,0x35,0x70,0x1b,0xc7,0x29,0xbc,0xaa,0xbb,0x50,0x14,0x0a, -0xd6,0x79,0xdf,0x9c,0x2b,0x07,0x88,0xa1,0xb8,0x88,0x4a,0x11,0x2b,0x83,0x7a,0x71, -0xc9,0xd2,0x6e,0x1d,0x4c,0x76,0xa1,0x60,0x28,0x44,0xc5,0xe8,0x8d,0x6b,0xba,0xbd, -0x14,0xca,0x56,0xba,0x0e,0x51,0x05,0x70,0x0b,0x24,0xa8,0x83,0x7a,0xef,0x5c,0x54, -0x77,0x61,0x6a,0xbf,0xb9,0x79,0xe6,0x99,0xe7,0x79,0x7e,0xf3,0x87,0x9c,0x67,0x86, -0xc3,0x7f,0xca,0xf3,0x7d,0x30,0x1a,0x92,0xe2,0x9f,0x21,0x39,0x1f,0x7e,0x7f,0xcf, -0xbf,0xdf,0x33,0x72,0xe2,0xc6,0xff,0xe9,0x08,0x21,0xfd,0xb6,0xb6,0x25,0xb5,0xed, -0xaf,0xb4,0xab,0x8b,0xda,0xbe,0x23,0xd4,0x19,0x7a,0x42,0xdb,0xff,0x57,0xed,0xff, -0x1d,0xfa,0x75,0xa0,0x2f,0x43,0xa1,0x7f,0xfa,0x7a,0x28,0xf4,0x1f,0x43,0x42,0x42, -0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x5f,0x3d,0xf5,0x86,0xdf,0x18,0x3c,0x17,0x3f, -0x16,0x6e,0xf6,0x71,0x08,0x09,0xb5,0x8a,0x7a,0xc3,0x3d,0xa1,0x1e,0xb4,0x91,0x42, -0x2f,0xf7,0x6a,0x5b,0x3d,0x74,0x6b,0x22,0x91,0x2f,0xc8,0x59,0x39,0x91,0xdf,0xce, -0x3c,0xbc,0xf4,0xe0,0x74,0x78,0xe4,0xc9,0xde,0xba,0xbc,0x50,0xcb,0xab,0xa7,0x6e, -0xcf,0xfc,0xfd,0xf0,0x1f,0x4f,0xcf,0x2c,0x9e,0xd4,0xcb,0x8c,0xbe,0xcd,0x2c,0xce, -0xd0,0x6b,0x27,0x8d,0x6b,0x57,0x27,0xfc,0x3e,0xff,0xb3,0x23,0x9d,0x0b,0x6b,0x99, -0xb5,0xcc,0xb6,0xb1,0x59,0xcb,0x76,0x95,0x6b,0xe8,0xfa,0x36,0x78,0xac,0x76,0x2d, -0x67,0x5c,0xce,0x6d,0xeb,0xff,0xfb,0x80,0x6e,0x7b,0x39,0x52,0x96,0x32,0xe1,0x11, -0xde,0xa3,0xfb,0x34,0x76,0x64,0x81,0x3d,0x92,0xbf,0x44,0xf2,0x55,0xcb,0x6a,0x85, -0xcb,0x0e,0xd7,0x13,0xf9,0x23,0x0b,0x2f,0x77,0xf2,0x1d,0x6d,0x6f,0xb8,0x73,0x21, -0x91,0x77,0x2b,0x47,0x16,0x79,0x9f,0x8f,0x4f,0xf7,0x87,0x22,0x1a,0x85,0xb8,0xa8, -0x5a,0x41,0xfb,0xb4,0xd4,0xb5,0xfa,0x5a,0xe6,0xda,0xec,0xd5,0x89,0x1b,0x83,0xef, -0x04,0xfa,0x6a,0xcd,0x54,0x78,0x64,0x2d,0xe3,0xf6,0xad,0xef,0xe5,0x06,0xa6,0xeb, -0xf1,0xda,0x4b,0x99,0x92,0xa2,0xca,0x25,0xb9,0xa4,0xa0,0x0d,0x7d,0xce,0xf8,0x92, -0x7e,0xab,0xa2,0x2a,0x25,0xa3,0xbc,0x77,0xda,0xcf,0xb3,0x3f,0xbc,0x84,0x9f,0x8b, -0xb7,0x94,0xc1,0x9e,0x6f,0x2b,0x3b,0xdc,0x56,0x90,0xef,0x0e,0xf1,0x1d,0xdf,0x4e, -0xce,0xe9,0xf1,0x7c,0x5b,0x50,0xa5,0xac,0x9c,0x5c,0xe4,0x3b,0xda,0x23,0x0b,0xf0, -0x75,0xf5,0xef,0xc7,0xf8,0x74,0xf5,0xef,0x49,0xff,0xbe,0x54,0x0f,0xcf,0xc7,0xa3, -0xdb,0xb1,0xa5,0x0c,0xe3,0x10,0x16,0xd5,0xa0,0x72,0x32,0xbf,0x93,0x3b,0xb2,0x30, -0x70,0xf6,0x59,0xee,0x5f,0xbf,0xd6,0xd4,0xed,0xd8,0xa4,0xe4,0xf4,0x3e,0xed,0xc5, -0xbf,0x2b,0x55,0xd2,0xb9,0x41,0xbe,0x57,0x2e,0x29,0x4b,0x19,0xef,0xcf,0x3e,0x70, -0xb6,0xa4,0xb0,0x6f,0xad,0x60,0xfc,0x96,0xb2,0xcb,0xf0,0x36,0xf2,0xbd,0xaa,0xf4, -0xfb,0x55,0x4d,0xb7,0xb2,0xfb,0x94,0xd0,0x5f,0x05,0xef,0xf5,0x5f,0x0e,0x6d,0x2b, -0x68,0xdb,0xba,0x76,0x7d,0x5d,0xbf,0xbd,0xac,0xbc,0x3f,0xcb,0x73,0x7c,0xa3,0xf1, -0x2c,0xfd,0xed,0xc1,0xdb,0x3a,0xd9,0xcb,0x78,0xa3,0xcf,0x4d,0x36,0x19,0x5f,0x2f, -0x81,0x6d,0x5d,0x66,0x8f,0x55,0xe1,0xfd,0x8c,0xe3,0xc6,0xc7,0x8b,0xf6,0xf6,0xf7, -0x58,0xd0,0x1f,0x9b,0xca,0xf3,0x7d,0x9e,0x89,0x3c,0x7a,0x1d,0xf8,0x99,0x39,0x7f, -0x57,0x93,0x52,0x70,0x8e,0xd8,0xa9,0xc7,0x0b,0xd9,0x0a,0xaf,0x95,0xa5,0xdf,0x27, -0xfa,0xfb,0xb6,0x8f,0x73,0xa4,0x75,0xf4,0xe2,0x18,0x7a,0x3f,0xee,0x45,0x95,0x3b, -0x17,0x82,0x7e,0xed,0x1b,0x9c,0x1c,0xaa,0xca,0x9a,0xe7,0xcf,0xb8,0x37,0x9c,0x92, -0x54,0xa5,0x60,0xfa,0xa6,0xcc,0x44,0x15,0xc0,0xf5,0x02,0xbd,0x8e,0xcf,0x5a,0x72, -0x26,0xaf,0x93,0x47,0x29,0x6c,0x4f,0xa8,0xa0,0x44,0x2a,0x2a,0xf5,0xf3,0x92,0xee, -0x08,0x1f,0x5f,0xe2,0x39,0xc2,0x73,0xf1,0x02,0x79,0x1c,0xfa,0xab,0x3f,0x5b,0x89, -0xdd,0xa2,0x58,0x63,0x03,0xc3,0x7d,0x0c,0xdf,0xa1,0xf1,0x83,0xce,0x52,0xc1,0xb8, -0xbd,0x80,0x9f,0x49,0xbf,0x5f,0x41,0x66,0xc7,0x49,0x7e,0x25,0x54,0x40,0xb8,0x4e, -0x39,0xe2,0x50,0xe2,0x69,0x01,0xe9,0xd5,0x39,0x2c,0x58,0x3e,0x2f,0xfb,0x86,0x38, -0x0c,0x2a,0x56,0x3c,0x31,0x1d,0xd1,0xdc,0xae,0x32,0x87,0xd6,0x5f,0x00,0xbe,0xdf, -0xbf,0xd6,0x14,0x2f,0x87,0x85,0x26,0x72,0x58,0xf2,0xc1,0xe1,0x89,0x69,0x78,0xd6, -0x58,0xb8,0x06,0x1b,0xe4,0x52,0x2f,0xc6,0x99,0x5b,0x50,0x0a,0x94,0x34,0xea,0x75, -0xc6,0x46,0x3c,0x09,0xfa,0x55,0x81,0x9e,0xe5,0xde,0x38,0x34,0xe2,0x6f,0xd9,0x20, -0x8f,0xb2,0x57,0x32,0x6e,0x03,0xa4,0x1a,0x2c,0xaa,0xc6,0x2b,0x31,0x12,0xf5,0x7b, -0x62,0x5f,0x54,0x0a,0x32,0x38,0x46,0xe2,0xd9,0x32,0xfb,0xf5,0x20,0xbf,0x40,0xeb, -0x94,0x61,0x3e,0x6e,0x7a,0x28,0x87,0x4e,0xf4,0x81,0xef,0x4a,0x9e,0x94,0x2e,0x07, -0xc2,0xe1,0xf9,0x31,0x54,0x1f,0xda,0xce,0xec,0x70,0x71,0x88,0xee,0xb3,0x97,0x0b, -0xe2,0x75,0x9b,0x23,0x7e,0x0e,0x8f,0xb4,0x11,0x87,0xc7,0xc2,0x93,0x12,0x8e,0xa2, -0x2a,0x9c,0x39,0xc4,0x27,0x88,0xaf,0x81,0xdb,0x69,0xf4,0xa7,0x9f,0xdf,0xd4,0xf3, -0x0c,0xa7,0x61,0x6c,0x58,0x58,0x91,0x49,0x6d,0xc9,0x23,0x87,0xc4,0xf9,0x14,0xfc, -0xec,0xd8,0x05,0x55,0x40,0x3a,0x7d,0x0d,0x52,0x13,0x23,0xff,0x97,0x49,0xbd,0x8c, -0x1d,0x19,0x39,0x06,0x7a,0x8c,0x94,0x57,0xf2,0x78,0x95,0x1e,0xad,0xf1,0x1e,0x3d, -0x73,0x68,0xfd,0x35,0x2b,0xc0,0xcf,0x4f,0xe7,0x30,0x08,0x3f,0x1c,0x8d,0xef,0xe5, -0xba,0x56,0x77,0xb8,0x39,0x2c,0x7c,0x65,0x38,0x6c,0x27,0x3f,0xbc,0x30,0x6d,0xae, -0xcb,0xa8,0xc0,0xf3,0xac,0xd1,0x28,0xa8,0x05,0x5a,0x3c,0x4f,0x05,0x5e,0x42,0x23, -0x52,0x19,0x47,0x7f,0xb8,0x2e,0xe6,0xc4,0xa6,0xc7,0xb8,0x14,0x50,0xa3,0x2a,0x86, -0x37,0xca,0x46,0x9c,0x6a,0x6e,0xbf,0xa2,0x7c,0x12,0x9e,0xf0,0xfd,0x08,0x6d,0xc6, -0xa3,0x21,0xcb,0x20,0x8a,0x55,0x8d,0xcf,0x83,0x44,0xa9,0x2a,0x8d,0xaa,0xf9,0xfc, -0x8b,0x70,0xc8,0x3e,0x45,0xf3,0x67,0x48,0x2e,0xab,0x9c,0xcf,0xe7,0xa6,0x99,0xc5, -0x84,0xe6,0x86,0x3b,0x39,0xd4,0x3e,0x2d,0x38,0x6c,0x4f,0x0e,0xbf,0x8f,0xdc,0xd0, -0xc6,0x20,0xdb,0xb3,0x96,0x0d,0xd8,0x1a,0x42,0xda,0x33,0x8c,0xf3,0x96,0x9e,0xfb, -0xcc,0x8b,0x54,0x7a,0x4e,0x97,0x98,0x6b,0x11,0xa7,0xa1,0x35,0x3b,0x9f,0x1c,0x12, -0x16,0xc1,0x56,0xa2,0x64,0x99,0xdc,0x10,0xb4,0x23,0xc3,0xc7,0xc1,0xa3,0x31,0xdc, -0x19,0xd7,0x39,0x49,0x24,0xab,0x50,0x07,0x35,0xf6,0xf8,0x79,0xbc,0xf9,0xa1,0xf9, -0x73,0x34,0xd7,0xb8,0x75,0x3f,0x0c,0x84,0xc3,0x8f,0x2f,0x4d,0xea,0xad,0xf4,0x82, -0xc3,0xd6,0xe2,0x70,0xdb,0x13,0x87,0xd7,0x66,0xcb,0x0a,0xf4,0x3a,0xab,0x17,0x92, -0x36,0x46,0xd8,0x4e,0x49,0xfc,0xae,0x24,0x97,0x40,0xc4,0xa7,0x12,0xc6,0x98,0xc3, -0x18,0x11,0xa1,0xca,0xce,0x65,0xc3,0xa1,0x08,0x45,0x5e,0x39,0x84,0x54,0xa9,0x80, -0x2c,0x6b,0x31,0x51,0xc8,0xda,0x70,0xd8,0xaf,0x00,0xe5,0x0e,0x1e,0x11,0xf5,0x4e, -0x56,0x97,0x34,0x7e,0x61,0x0c,0x36,0x3d,0xf9,0x21,0x63,0x0f,0xfe,0xba,0xc1,0x88, -0x3f,0x08,0x3f,0x7c,0x70,0x3a,0x25,0x25,0xf2,0x5d,0xab,0x98,0xc3,0x35,0x4e,0x0e, -0xd5,0x7d,0xcf,0x61,0xa1,0xc9,0xed,0xa5,0xde,0xfc,0xf0,0x72,0x67,0x5a,0x22,0x67, -0x0c,0xa5,0x4d,0x86,0xed,0x85,0x98,0x34,0xdc,0xd2,0xcf,0xda,0x32,0x48,0xdb,0x24, -0x3b,0x63,0x59,0x1d,0x50,0xa5,0x64,0x98,0x48,0x01,0xad,0x2a,0xcc,0xb7,0x6a,0xf4, -0x43,0x1b,0x7f,0xe6,0xdb,0x19,0x67,0x96,0x63,0x00,0xcf,0xa5,0x5a,0x8f,0x55,0x29, -0xd9,0x8e,0xd5,0xb8,0xcd,0x63,0xfd,0xd0,0xda,0x43,0xa2,0x7f,0x3b,0xa6,0x68,0xa3, -0xf6,0x76,0x9a,0xbb,0x43,0x89,0x7c,0x2a,0x9f,0xa0,0x7e,0xc8,0xcb,0x61,0x7b,0xfb, -0xe1,0xd5,0x09,0x5e,0x3f,0x7c,0xc8,0x75,0x76,0x79,0x51,0x7d,0x38,0xbc,0x36,0x8b, -0xb9,0x2a,0x18,0xd4,0x19,0xf1,0x92,0x51,0xff,0xb3,0xb6,0x1d,0xae,0xb3,0x5e,0x68, -0x76,0xb6,0xb3,0x56,0x0d,0xd0,0x3e,0x69,0x44,0x9e,0x84,0x4f,0xd9,0x74,0xe6,0x03, -0x42,0xfc,0x70,0x68,0x25,0xc6,0xec,0xc7,0x16,0x12,0x65,0x48,0x3d,0xb8,0x6e,0xa5, -0xd3,0x46,0xa1,0x29,0xa6,0xa6,0x71,0x6c,0x9a,0x93,0xc3,0x54,0xbe,0x04,0xe8,0x5b, -0x97,0x59,0xc4,0x51,0x00,0xfb,0x5a,0xe3,0xd2,0xcb,0x9d,0x7b,0xb9,0x49,0x09,0x51, -0xa8,0xfb,0x61,0x66,0xe9,0x2b,0xc2,0xe1,0xff,0x3c,0x5d,0x9d,0xc3,0x42,0x93,0xfc, -0x10,0x7e,0xbb,0x5e,0xe2,0x52,0xec,0x86,0x05,0xe3,0x3c,0x83,0x3d,0xdb,0xb4,0x35, -0x12,0x9e,0xa5,0xe4,0xfc,0x04,0x8e,0xc7,0x28,0xb3,0xb5,0x40,0x5a,0xcf,0x6c,0x0b, -0x45,0x35,0xfb,0x61,0x1d,0x8a,0xaa,0x98,0x7f,0x25,0xec,0x85,0x97,0x43,0xe2,0x87, -0x24,0x82,0xa0,0xd1,0xbc,0x4c,0xda,0x9c,0x09,0x87,0xb5,0xb4,0x97,0x9e,0x5c,0x4c, -0x4b,0x88,0x43,0x1c,0x97,0x6e,0x7b,0x8a,0x4b,0xbb,0x56,0xfd,0xbf,0x6e,0xb3,0xf5, -0x5e,0x55,0x0e,0x0b,0x74,0x5f,0x90,0xbf,0xf9,0xa3,0xa0,0x5f,0xdb,0xdd,0x0f,0xb1, -0xab,0x79,0xe1,0xf0,0x7d,0xad,0x6e,0xb8,0x0e,0xbc,0x8f,0x9c,0x39,0x46,0x5b,0xa1, -0xa2,0xd2,0x68,0xd4,0x54,0x2f,0x93,0xa9,0x5b,0xb0,0x33,0xd7,0x4a,0x1a,0x69,0x3d, -0x91,0xab,0xd0,0xd9,0x0a,0x1c,0x5a,0xa2,0x5b,0xeb,0x31,0x93,0xf7,0x46,0xae,0xa7, -0xf9,0xea,0x87,0x61,0x5c,0x3f,0xa4,0x7d,0xaa,0xa0,0x5f,0x15,0xb7,0x2d,0x17,0xf4, -0x31,0x3b,0xe8,0xf9,0x6e,0xc7,0x78,0xbf,0x2d,0xab,0x2e,0x4c,0x67,0xb5,0xb8,0x76, -0x32,0x4f,0x39,0xf4,0xe0,0x87,0xed,0x5d,0x3f,0x74,0xe2,0xb0,0x60,0xdb,0x50,0x69, -0x8e,0x1f,0xe2,0xdf,0x58,0xde,0xb8,0xf4,0x76,0x0c,0xd7,0x0d,0x8d,0xd6,0x4d,0x19, -0xb4,0x62,0xd0,0x36,0xff,0x12,0xad,0xf1,0x39,0xd6,0xc5,0xc8,0x59,0xea,0xe0,0x2b, -0x7c,0xa5,0xe9,0x1c,0x7a,0x2c,0x5e,0xe2,0x52,0xd6,0xe2,0xca,0xfa,0x38,0x69,0x0b, -0x17,0xee,0xc9,0x51,0xe6,0x24,0xbf,0xf3,0x21,0xce,0x8f,0xcd,0x49,0xc8,0x0d,0x53, -0x12,0xae,0x1d,0xee,0x69,0x6e,0xc8,0xcf,0x61,0x49,0xd9,0x6f,0x1c,0x5a,0xbd,0x30, -0xab,0x73,0xd1,0x68,0x3f,0x54,0x65,0x56,0xe7,0xe0,0xe5,0x10,0xb9,0x21,0x1b,0x73, -0x09,0xfb,0xcc,0x20,0x49,0x74,0x0c,0x8b,0x51,0xfb,0x2b,0x99,0xfa,0xba,0x2d,0xf1, -0xa9,0x29,0xaa,0xe3,0xa1,0xb1,0xe5,0x39,0x84,0xad,0x35,0x32,0xaf,0x1f,0xf6,0x62, -0x0e,0xe9,0xc8,0x1f,0x93,0x27,0x1a,0xf1,0x07,0xfe,0x0c,0xd3,0xd2,0x67,0x3d,0x7c, -0xdf,0x96,0x59,0x4f,0xf6,0x26,0xf2,0x59,0x9d,0xc3,0xef,0x48,0xac,0x95,0xc6,0x4b, -0xfd,0x30,0xc2,0x39,0x52,0xb6,0x15,0xf5,0x9e,0xa5,0x9d,0xc6,0xd9,0x0b,0xeb,0xe7, -0x87,0xc4,0xf7,0xac,0x7b,0xf3,0x2f,0xdd,0x0e,0xd7,0x2f,0x1d,0x71,0x43,0x58,0xd7, -0xb3,0x78,0x9b,0xd9,0x03,0x2d,0x67,0xa4,0x63,0x3b,0xa3,0xe7,0x52,0x56,0xf8,0x5a, -0xb4,0x5a,0xc3,0x0f,0xcb,0x1a,0x37,0xef,0x72,0xc4,0x91,0x5a,0xfd,0x50,0x2a,0xd1, -0x7e,0x49,0xf6,0x39,0x19,0x7d,0x22,0x60,0xdc,0xcf,0x9c,0xec,0xcf,0x0f,0xd7,0x32, -0x05,0x99,0xf9,0x61,0x42,0xf7,0x43,0x2f,0x71,0x69,0x41,0x4e,0xe4,0x7b,0xfc,0xbc, -0x70,0x4b,0xc8,0xd9,0x0f,0x9d,0x48,0xec,0x0c,0xdc,0x0f,0x6f,0x52,0x3f,0x84,0xf4, -0x59,0x2f,0xf3,0xd7,0x0f,0x51,0xbf,0xe1,0x3a,0xec,0x83,0x07,0xa3,0xd1,0x60,0xed, -0xcf,0x5c,0x3f,0x82,0x6d,0x8f,0x41,0x94,0xe8,0xe6,0x09,0xae,0x39,0x62,0x88,0xc3, -0x72,0x0b,0x70,0xc8,0x37,0xdf,0xa2,0x37,0x4c,0xfc,0x90,0x7d,0x7a,0x60,0x94,0x9c, -0xc2,0xc6,0xab,0xa6,0x7d,0xc5,0xa5,0x1f,0x5f,0x42,0xe7,0x5a,0xda,0x14,0x97,0xee, -0x78,0xac,0x1f,0xb6,0x3b,0x87,0x05,0x1b,0x7d,0x05,0x8b,0x17,0xa2,0x77,0xf9,0xaf, -0x75,0xe9,0xb7,0x70,0xf2,0x3f,0xeb,0x58,0x8d,0xb2,0xb2,0xcd,0xe5,0x87,0xdb,0xb9, -0x32,0xed,0x4f,0xb0,0xf5,0xb3,0x55,0x39,0x13,0x83,0x2c,0xd1,0xcd,0xc8,0xea,0xcb, -0x5c,0x19,0x1c,0x5e,0xe5,0xf6,0xc3,0x60,0x8f,0xd0,0x5c,0x0a,0x32,0xef,0xdc,0xce, -0x44,0xbe,0x6c,0xf9,0x4c,0x61,0x9c,0x41,0x3f,0x73,0x5f,0x7e,0xf8,0x91,0xe1,0x06, -0x69,0x19,0x71,0x38,0x69,0x8a,0x4b,0x97,0x32,0x59,0xc7,0xb3,0xc4,0x56,0x94,0x76, -0xe7,0xd0,0xdd,0x0b,0x11,0x1b,0x7c,0xb5,0x1e,0x2f,0xba,0x31,0xe8,0x14,0x95,0xb2, -0x8d,0x5c,0xe2,0xf5,0xc3,0x87,0x7f,0x52,0xb6,0xcd,0xb1,0xa8,0xd6,0x27,0x33,0xa7, -0x6d,0x7b,0xb9,0x81,0xb3,0x03,0xd3,0x27,0xa6,0x9f,0xab,0xb0,0x9d,0x70,0xd8,0x57, -0xba,0xed,0xc4,0xf4,0x81,0xb3,0xfc,0xb3,0x34,0xf9,0xfc,0x10,0xc5,0x8d,0x07,0xce, -0x7e,0x74,0xfa,0x81,0xa5,0xa0,0x5b,0x6e,0x4d,0xfc,0x60,0xec,0xea,0xc4,0xf9,0x89, -0xab,0xda,0x5f,0x74,0x09,0x97,0x1f,0x4c,0xbc,0xa9,0x5f,0x46,0xb7,0xbc,0xa9,0x5d, -0xfb,0x01,0xbe,0x4d,0xbf,0x55,0xdb,0xf4,0xff,0xbd,0x89,0x1e,0x83,0x1e,0x3b,0xd6, -0xcf,0xcd,0x8c,0xc1,0xa1,0x62,0x89,0x1e,0x64,0x3a,0xc6,0xdd,0x88,0x4c,0x97,0x3d, -0xfb,0xe1,0x8d,0xc1,0x65,0xc9,0xe0,0x50,0x22,0x1c,0xa2,0xf6,0x52,0x8f,0x1c,0xb6, -0xb5,0x1f,0x7e,0x34,0x41,0xbc,0xcf,0x4a,0x9e,0xd5,0xa3,0xea,0xc0,0xe1,0x90,0x99, -0x3a,0x73,0x44,0x4a,0x7a,0xe1,0xd1,0xb9,0xc8,0x57,0x3f,0x44,0xf3,0xfb,0x55,0x13, -0x67,0x73,0xd2,0xb2,0x94,0x06,0x65,0xd2,0xf8,0x9e,0x61,0x09,0x7e,0x7e,0x33,0x9f, -0x46,0x39,0x39,0x4c,0xb4,0x48,0xeb,0x03,0xf3,0x43,0xd3,0xe8,0x02,0xd9,0xda,0xf7, -0x9a,0xf5,0xe8,0x87,0xc7,0xc2,0x11,0x7d,0xe4,0xaa,0xfe,0x8d,0x99,0x38,0xdc,0xd3, -0x7b,0x0f,0x97,0xf4,0xb8,0xd4,0x9d,0xc4,0xf5,0x36,0xf7,0x43,0xd5,0xb1,0x75,0xc6, -0x4a,0xa4,0xca,0xd9,0x0a,0xe8,0x45,0xb8,0x7e,0xc8,0x3e,0x61,0xf3,0xa8,0x61,0x83, -0x45,0xc5,0x4b,0x3f,0xfe,0xb1,0xf0,0x5e,0xce,0xec,0x81,0x69,0x0b,0x89,0x8c,0x46, -0x46,0xe4,0x8b,0x63,0x41,0xbf,0x33,0x1e,0x3d,0xd9,0x9b,0x6d,0x2b,0x0e,0x23,0x79, -0x76,0xb4,0xd6,0x96,0x2d,0x32,0xfb,0x0a,0xed,0xb3,0x1e,0xfd,0xf0,0xe4,0x22,0xa1, -0x30,0x2b,0x2f,0x83,0xb8,0x14,0xcf,0x7a,0x5a,0x32,0x38,0x74,0x2f,0xed,0x5d,0x3f, -0xfc,0xe8,0x34,0xf4,0xc3,0x6a,0xef,0xb2,0x5e,0x71,0x29,0x8b,0x41,0x01,0x83,0xa6, -0x11,0x68,0x65,0x0f,0xfd,0xf8,0x9f,0xc5,0x70,0x76,0xaf,0x2c,0xfd,0x66,0x71,0xb4, -0x63,0x2f,0x84,0xc4,0xb4,0x94,0xca,0xf3,0x66,0x94,0x09,0x52,0x98,0xc3,0xb2,0xe2, -0x96,0x8b,0xa6,0x55,0x38,0x4c,0x00,0x0e,0x61,0xad,0xd0,0x5a,0xbc,0xf9,0xe1,0x05, -0x3a,0x5f,0x9b,0xfc,0x6e,0x42,0x3f,0xdc,0xc9,0x79,0xe0,0xb0,0xcd,0xfd,0xb0,0xba, -0x0f,0x32,0xd7,0xaf,0x83,0x1f,0x0e,0x59,0x3d,0x90,0x5d,0x26,0x7d,0x52,0x38,0x32, -0xe5,0x8d,0x4b,0x91,0xde,0x88,0x4f,0x4a,0x94,0x44,0x69,0x4e,0x23,0x71,0xce,0x95, -0xc4,0x48,0x7e,0x34,0x1e,0xf4,0xbb,0x73,0x53,0xbb,0xf9,0xa1,0x89,0x43,0xa7,0x51, -0xef,0xc6,0x75,0x2f,0x1c,0x3e,0x3b,0x42,0xe2,0x21,0xf2,0x7d,0xd9,0xfd,0x90,0xb4, -0x97,0xba,0x45,0xa6,0xed,0xee,0x87,0xaa,0xab,0x17,0xa2,0x52,0xaa,0x93,0x1f,0xda, -0x0b,0xf4,0x42,0x3c,0x62,0x9b,0xbf,0x7e,0x88,0x15,0x1e,0x49,0x4b,0xd0,0x13,0xd3, -0x5a,0xd1,0xa2,0xd3,0x0a,0x34,0xa2,0x32,0x27,0xed,0xe5,0x1a,0x9d,0x81,0xaf,0xdd, -0xfc,0x30,0x62,0xf7,0x43,0x4b,0x51,0x3d,0xfa,0x21,0xca,0x51,0xc6,0xe6,0xf8,0x5b, -0xeb,0x87,0x11,0x54,0x3f,0x34,0xfc,0xb0,0x04,0xe6,0xb1,0x15,0x4c,0xfb,0xfd,0xe3, -0x87,0x2a,0x47,0x54,0x5a,0x9f,0xb8,0xf4,0xe6,0x20,0x1b,0xf3,0xa2,0xca,0x6c,0x4e, -0x04,0x99,0x49,0x63,0xf4,0x04,0x7a,0xe6,0x10,0xcd,0x22,0xc9,0xb2,0xdf,0x58,0x19, -0x79,0xa2,0xe6,0x8c,0xd2,0x5c,0x45,0x0e,0xd3,0x52,0x56,0xf6,0x93,0x13,0xae,0x16, -0x11,0x3f,0xac,0xbe,0xb5,0x0e,0x87,0x0e,0x71,0xa9,0xd9,0x0b,0x8d,0x1e,0x7e,0x7e, -0x0e,0xd7,0x32,0x6c,0x9e,0x28,0xeb,0xb7,0xd0,0x7b,0x10,0x8d,0xf6,0xd2,0x6d,0x4b, -0x7b,0x69,0x65,0x0a,0xd1,0xd9,0xd3,0xce,0x1c,0x62,0x3f,0x74,0x2f,0xa5,0x3a,0xc4, -0xa5,0x37,0x06,0xc9,0xa8,0xe3,0x02,0xd8,0xc8,0xa8,0x6b,0x95,0xfc,0xc6,0xfa,0xe0, -0x30,0x14,0x3a,0x70,0x16,0x44,0x3b,0xa0,0xae,0xa8,0x45,0x3e,0xda,0xaf,0xae,0x5e, -0x67,0x94,0x97,0x2d,0x24,0x9e,0x0c,0x7c,0xc4,0x50,0x35,0x3d,0xd9,0x5b,0x90,0x79, -0x7a,0xf8,0x5a,0x9e,0x43,0x9f,0xf5,0xc3,0x8f,0x2f,0x95,0xf5,0x39,0xa0,0x25,0x53, -0x64,0x8a,0xfd,0x90,0xce,0x3f,0x34,0x38,0x24,0x23,0xf5,0x59,0x5f,0x96,0xfd,0xac, -0x2d,0xed,0x0b,0x3f,0x74,0x2b,0x75,0x69,0x2f,0x1d,0x22,0xb3,0x93,0x58,0xdf,0x7d, -0x09,0x90,0xb8,0x6e,0xfc,0xca,0x6a,0x1c,0xfa,0xf0,0xaa,0x6b,0xd3,0x15,0x7a,0x0f, -0x25,0x1c,0x01,0x2d,0xeb,0xf1,0x2a,0x6e,0xa3,0x4b,0xeb,0x51,0x6b,0xb6,0x0e,0x9e, -0x5f,0x59,0x24,0x2e,0xb5,0xfa,0x5f,0xdb,0xf9,0xa1,0xc5,0x1b,0xf9,0x38,0xbc,0x35, -0x51,0x02,0xd1,0x26,0xe5,0xd0,0xd2,0x6f,0xc1,0xfc,0x90,0xdd,0xaf,0x12,0x89,0x88, -0xc3,0xf6,0x5d,0x03,0x03,0xb7,0x97,0x36,0x87,0x43,0xec,0x87,0xa4,0x55,0xc6,0x9a, -0x7f,0x8c,0xd5,0xfd,0xfd,0xf8,0x21,0xd2,0xc3,0x4b,0xaa,0xcd,0x13,0xdd,0x0a,0xdf, -0x98,0xb4,0x20,0xc4,0x38,0xdc,0x4f,0x7e,0x58,0xe6,0xe2,0x70,0x34,0xbe,0x2c,0x91, -0x59,0x54,0xeb,0x0e,0xed,0xa5,0x6c,0x3e,0x3e,0x6e,0xa7,0x51,0x8d,0xd9,0xc7,0xac, -0x3f,0xab,0x60,0x21,0xb3,0x10,0x58,0x86,0xaa,0xe6,0xe8,0xbd,0x26,0x72,0x78,0x77, -0xa8,0xa4,0x90,0xb9,0xf1,0xfa,0xa7,0x4b,0x32,0x31,0x19,0x3c,0x92,0x99,0x72,0x5e, -0xfa,0x2d,0xcc,0x82,0x7d,0x53,0xbc,0xc5,0x5f,0x0e,0x7f,0xef,0xda,0x9f,0x1c,0xf2, -0xf9,0xe1,0x5e,0xae,0x44,0x5b,0xe1,0xa0,0x23,0x2e,0x1b,0xf5,0x43,0xd6,0x6f,0xb1, -0x46,0x39,0x84,0xfe,0xa7,0x82,0x3d,0xbb,0xdc,0xce,0x1c,0x6a,0x7e,0x58,0x31,0xdf, -0xae,0xd9,0xf5,0x83,0xe7,0x30,0x3c,0x52,0x06,0xf5,0x7b,0xcb,0xdc,0x5b,0x30,0x6e, -0xc3,0xaf,0x1f,0x22,0xad,0x65,0x2a,0xe5,0x13,0xce,0x56,0xdc,0x1a,0xb3,0x56,0x02, -0x1f,0x87,0xd1,0xcd,0x76,0xe3,0xb0,0x20,0x9f,0x73,0xe9,0x03,0xea,0x5c,0x28,0x93, -0x3c,0x40,0xfa,0x77,0xec,0xe0,0x87,0x92,0x39,0x3f,0x0d,0x9d,0xe7,0xa8,0xc7,0x4d, -0xe6,0xe8,0x94,0xd5,0x68,0x82,0xcb,0x24,0xde,0x78,0x35,0xb3,0x9d,0xe6,0xf3,0x63, -0x65,0x45,0xa5,0x7d,0x84,0xd0,0x0d,0xcd,0x33,0x77,0xfd,0xd5,0x0f,0xb1,0x8e,0x85, -0xbb,0x56,0x2b,0x67,0xf6,0x76,0x2e,0x69,0xe9,0x66,0x03,0xfa,0xf5,0xf7,0xab,0x1f, -0xba,0x71,0xf8,0x8b,0x97,0xf5,0xef,0x83,0xcd,0xda,0x00,0xbf,0x8c,0x59,0x09,0xf8, -0x61,0x9e,0xf5,0xe3,0xab,0x8a,0xd5,0xfb,0xec,0xfe,0x18,0x4c,0xc6,0xc6,0x66,0xe9, -0xa3,0xd3,0xeb,0x7c,0x1c,0xd6,0xa1,0x0d,0x43,0xf7,0x43,0x3d,0x1e,0x65,0xe3,0xf5, -0xa1,0x3b,0xb2,0x3a,0x87,0x7f,0x3f,0x44,0xe7,0x7b,0x2a,0x0f,0xbf,0x6d,0xf7,0x82, -0x6a,0x1a,0xdf,0xae,0xfb,0x1a,0x7b,0xfd,0xfb,0xd2,0x0f,0xcb,0x2e,0x1c,0xde,0x1d, -0xca,0x1a,0xd4,0xd0,0xb9,0xda,0xa6,0x1e,0x44,0x36,0xd2,0x9b,0xcd,0xb8,0x30,0xfc, -0xd0,0xe8,0xd5,0x2a,0x80,0x36,0x56,0xc2,0x60,0xc1,0xf0,0xc3,0x76,0xe6,0xb0,0xb9, -0x7e,0x68,0xd4,0x11,0x2a,0xcf,0xdc,0xad,0xa1,0x9d,0x86,0xe8,0xc6,0x60,0x5a,0x32, -0xaf,0xcd,0xe0,0x48,0x9f,0xe9,0xdd,0x46,0xf2,0xc1,0xae,0xe3,0x67,0x17,0x5f,0xbf, -0x45,0xbb,0x71,0x58,0xdd,0x0f,0xf5,0x31,0xdd,0xc6,0xef,0x3a,0xf1,0x42,0xc6,0x14, -0xe3,0x90,0xb4,0xd3,0xa0,0xf5,0x26,0xdf,0x5e,0x9c,0x93,0xf0,0x4c,0x63,0xdc,0xcb, -0x51,0xa0,0xbd,0x18,0x05,0xd3,0x5f,0x35,0xa0,0x8c,0xfe,0xcd,0xd1,0x47,0xa7,0x4b, -0x4d,0xe3,0x10,0xd7,0x0f,0x4b,0xf6,0xb9,0xf0,0x81,0xfa,0x21,0x52,0x7c,0xac,0x40, -0xda,0x61,0x61,0xcf,0x88,0xac,0x82,0xd7,0x53,0x69,0x24,0x8c,0x57,0x8b,0xa9,0xf5, -0x35,0xdd,0xd4,0x9e,0x1c,0x5a,0x37,0x6f,0x7e,0x88,0xdb,0xcd,0x90,0xa7,0xb1,0x56, -0x80,0x6a,0x1c,0x22,0x3f,0x7c,0xef,0xb4,0x9e,0x29,0x8e,0x66,0x2f,0x21,0x59,0x4f, -0xd6,0x49,0x1d,0x13,0xd4,0x0f,0xdb,0xd7,0x0f,0x1f,0x34,0xdb,0x0f,0xe9,0x0a,0x2d, -0xd6,0x99,0xbb,0xac,0xcd,0x26,0x08,0x26,0xde,0x3b,0xcd,0xbe,0x77,0xab,0xdf,0x96, -0x40,0xae,0x79,0x7a,0x8b,0x12,0xec,0x8a,0x9a,0x76,0xf1,0xd6,0x0f,0x97,0x65,0x34, -0xaf,0x71,0xa0,0xa6,0x72,0x61,0xfa,0x8f,0x67,0xaf,0xcd,0x9e,0x98,0xbe,0x5f,0x43, -0xbd,0x17,0x71,0x58,0x89,0x3e,0x3e,0x3f,0x3c,0x31,0xcd,0x62,0x8f,0x12,0xc8,0x57, -0x59,0x99,0xc3,0xbd,0xdc,0x73,0xd3,0x21,0x96,0xb1,0x11,0x52,0x08,0x47,0x42,0xe2, -0x7d,0x5b,0x73,0x38,0x70,0xb6,0xb9,0x7e,0xc8,0x97,0x79,0x29,0x08,0x6f,0x7a,0x6e, -0x9a,0x2f,0xae,0x82,0xaf,0x1b,0x7c,0xee,0x64,0x26,0xde,0xf1,0x34,0x65,0x25,0x56, -0x8c,0x15,0xa3,0xda,0x16,0xdb,0x44,0x7b,0x54,0x62,0x9b,0x64,0x8f,0x2e,0x19,0xff, -0xdf,0x8c,0x19,0x1b,0xbe,0x45,0xbf,0xb6,0x19,0x2b,0xd2,0x47,0x6b,0xa5,0xac,0x1c, -0x38,0xeb,0xf7,0x78,0x9d,0xfd,0xb0,0x4c,0x3f,0x2b,0x37,0x3f,0x7c,0x76,0x24,0x4b, -0x29,0x5c,0x67,0x9f,0x32,0xed,0x1b,0xc4,0x1c,0x2e,0x83,0xfa,0x61,0x64,0x15,0xaf, -0x31,0x06,0x33,0x72,0xc0,0xac,0x96,0x2c,0x1b,0xd8,0x7a,0xdb,0xfb,0x61,0xb3,0x39, -0x04,0x3e,0x58,0x31,0x8b,0x45,0x50,0x31,0xe2,0x4f,0x2f,0x79,0x27,0xb1,0x7e,0xfd, -0xfa,0xbc,0x7e,0x18,0x64,0x89,0x6e,0x4e,0x4a,0x7e,0x8f,0x37,0x02,0xfc,0xd0,0x4a, -0x21,0xfc,0xc4,0x9c,0x39,0xbc,0x6d,0xcc,0x47,0x03,0x7e,0xa8,0x90,0x98,0x07,0xf6, -0xe4,0xe3,0xcc,0x18,0xb8,0xdf,0x62,0x27,0x87,0x66,0xc1,0x90,0x4c,0x71,0xec,0x3c, -0x61,0x6b,0x54,0x92,0x3a,0x26,0xae,0x67,0xb6,0x73,0xfd,0x10,0xae,0x5e,0xdd,0xb4, -0xfa,0x61,0x43,0xfc,0x10,0xc9,0xbc,0xc6,0x3b,0xcf,0x2b,0x97,0x95,0x5b,0x75,0x9a, -0xaf,0xdf,0xaf,0xf9,0x61,0x74,0xb3,0xd1,0x24,0x4e,0x72,0xad,0xfe,0xeb,0xa4,0x48, -0xde,0x7c,0xb4,0x25,0xb0,0x87,0x9b,0x33,0x87,0x33,0x8b,0xb8,0x7f,0x10,0x9f,0x4d, -0xeb,0x96,0xfc,0xe2,0xe4,0x2c,0xa3,0x33,0x81,0xf5,0xb8,0x14,0x67,0x4a,0x60,0x19, -0xaa,0x48,0x46,0x76,0x32,0xd2,0x83,0x8c,0xc1,0x22,0x44,0xb6,0xb3,0x1f,0x1e,0xe0, -0xe7,0x30,0xf0,0x55,0x8f,0x0d,0x0e,0xad,0xf3,0xba,0xeb,0xc8,0x21,0xca,0x9c,0xe1, -0x95,0x44,0xb5,0x4e,0xfd,0xfa,0x7c,0xfd,0x16,0xc1,0x73,0xd8,0xeb,0x97,0xc3,0x55, -0x48,0xa0,0xf3,0x66,0x70,0x38,0x68,0x7d,0x2c,0xca,0xd3,0xbd,0x2c,0x65,0xe9,0xd9, -0x04,0xfd,0x50,0xa5,0xa3,0x4c,0xf1,0xdc,0x18,0xcc,0xe1,0xa4,0x44,0x56,0xd9,0xee, -0x21,0x71,0x29,0x65,0xd0,0xc8,0xc2,0x67,0x59,0x97,0xb2,0xbd,0xfb,0xf1,0xf9,0xfd, -0xf0,0xa7,0xfb,0xc0,0x0f,0x91,0xf6,0x72,0x5e,0x49,0xcc,0xca,0x37,0x6c,0x67,0x56, -0xed,0xea,0xe7,0xae,0x1f,0x06,0x57,0x50,0x5c,0xea,0x9b,0xc3,0x7c,0xe5,0xe7,0x85, -0x34,0xda,0xfd,0xf0,0xfc,0x18,0x9e,0xcf,0xc2,0xfc,0xd0,0xfa,0x19,0xb3,0x1a,0x22, -0xc9,0xd8,0xc6,0x66,0xa1,0x19,0x7e,0x08,0x1f,0x43,0xf3,0x3e,0x93,0x99,0x39,0xeb, -0x35,0x65,0x30,0x6e,0x05,0xf1,0xfb,0xe1,0x4f,0xeb,0xe5,0x87,0x0d,0xe6,0xf0,0x72, -0x27,0x6f,0x4f,0x18,0x7b,0xfd,0xc9,0x3a,0x7c,0xc3,0x4f,0x36,0x29,0x2e,0xf5,0xcf, -0xa1,0xd3,0xd1,0x96,0x2c,0x24,0x22,0x0e,0x5f,0x35,0x71,0xd8,0xdf,0x1b,0xc9,0xeb, -0x1c,0x42,0x3f,0x24,0xfc,0x19,0x54,0x59,0xfd,0x30,0x91,0x7f,0x95,0xfe,0xf2,0xf5, -0x84,0xbf,0xa3,0x7f,0x5f,0xa6,0x7e,0x65,0x99,0xf4,0x35,0xad,0x83,0xf6,0x1b,0xff, -0x19,0xfd,0x9b,0xaf,0x6a,0x7e,0xa8,0x9a,0x39,0x6c,0x9a,0x1f,0x46,0x37,0x83,0xed, -0xcb,0xeb,0xef,0x4d,0x4b,0x5e,0x49,0x8c,0x04,0x3e,0xa7,0x46,0x6f,0x2f,0xbd,0xd3, -0x68,0x0e,0xf9,0xb2,0xe8,0x3b,0xc9,0x99,0x43,0x7b,0xb1,0xfa,0xe1,0x4c,0x06,0x67, -0x20,0x49,0x03,0x0e,0x2d,0xf5,0x0f,0x7a,0x3b,0x19,0xe9,0xfd,0x11,0x18,0x6b,0xdf, -0x1b,0x9e,0x34,0x7e,0x37,0x55,0xab,0x8f,0x9a,0xfb,0xbc,0x7c,0x64,0x6c,0x6c,0x1d, -0x0d,0x9c,0x55,0x5d,0xfc,0x50,0x35,0xe2,0xf9,0xf7,0xf7,0x89,0x1f,0x22,0xa1,0xd1, -0x55,0x5e,0x49,0xf4,0xb6,0x36,0xb8,0xbb,0x9a,0xe3,0x87,0x73,0xf2,0xbb,0xbe,0x39, -0x74,0xfb,0xd5,0x28,0xe9,0x7f,0x55,0xf9,0x55,0x10,0xc5,0x5f,0x9b,0x9d,0x34,0x72, -0x00,0x2d,0x83,0x79,0xae,0xd6,0x4f,0x97,0x71,0x98,0xb5,0xcd,0x02,0xd5,0x38,0x94, -0x88,0x1f,0x9a,0x0b,0x5b,0xcf,0xd1,0xf0,0x43,0x9f,0x19,0xfd,0x5b,0x41,0x95,0xfc, -0x50,0x05,0x5b,0xb3,0xfd,0xb0,0x1e,0x63,0x5b,0x5e,0x1c,0x53,0x3d,0x93,0x78,0x24, -0xd0,0xf9,0xfa,0xa8,0x7e,0xf8,0xe5,0x9d,0xc6,0x92,0x18,0xdb,0xcc,0xca,0x3c,0xab, -0x59,0x38,0x89,0xd7,0x0f,0x55,0xe0,0x87,0xb7,0x26,0xd0,0x88,0x6d,0xcc,0x61,0x1a, -0x72,0x68,0x62,0x0a,0xb5,0xb6,0x50,0x0e,0x65,0xfb,0x77,0x6d,0xcd,0x50,0x45,0xd7, -0xd8,0x80,0xb3,0x74,0xe4,0x76,0xf7,0xc3,0x6a,0xf5,0x43,0x16,0x99,0xee,0x2f,0x3f, -0x44,0x7a,0x70,0xba,0xa4,0x78,0x25,0x31,0xc8,0xcf,0xa0,0x19,0xfd,0x16,0xd1,0x9a, -0x38,0xe4,0x7b,0x0d,0xc6,0xe1,0xb9,0xf8,0x5e,0x8e,0x71,0x08,0xfd,0xd0,0xea,0x6d, -0xec,0x3c,0x9b,0x94,0xde,0xb0,0xb5,0x89,0x45,0x4c,0x99,0xc4,0x1d,0x56,0x87,0xad, -0x71,0x85,0x9b,0x56,0x90,0x5b,0x7b,0xa9,0x4a,0x3f,0xb7,0xc6,0xfb,0x61,0x99,0x6e, -0xf5,0x19,0xeb,0x79,0x62,0xba,0xec,0x89,0x44,0x74,0x6f,0xff,0xe3,0x51,0xac,0x62, -0x71,0x29,0xfa,0x5b,0x69,0x83,0xff,0x37,0x13,0x55,0x8d,0xb6,0x4a,0xff,0x89,0x15, -0x6b,0xe1,0x30,0xc6,0xf5,0xab,0x51,0x52,0x30,0x49,0x3d,0xa1,0x99,0xc5,0x48,0x3e, -0x42,0x39,0x9c,0xb3,0xf5,0xe2,0x3b,0x91,0xf8,0xc0,0x61,0x16,0xb6,0x53,0xbb,0x9a, -0xea,0xb0,0xf7,0x9a,0x49,0xbc,0x95,0x54,0x99,0x43,0x15,0xec,0xd1,0x27,0xb7,0xd5, -0x24,0x3f,0x44,0xdf,0x6d,0xbd,0x56,0x98,0xfc,0xd8,0xe3,0x08,0x1b,0x74,0xef,0x37, -0x03,0xea,0xd7,0x77,0xf2,0x43,0x2b,0x81,0xd5,0xa8,0xf2,0xe3,0xa5,0xba,0x1f,0xd6, -0xad,0x7e,0x48,0x0a,0xce,0xca,0x7c,0x6d,0x16,0x8d,0x0f,0x65,0x1c,0x92,0xf6,0x52, -0xd5,0xda,0x4a,0x43,0x29,0x54,0x15,0xe7,0xb5,0xfd,0xec,0x19,0x1b,0x4d,0xbe,0x48, -0xe7,0xa9,0xee,0x37,0x3f,0xc4,0xe4,0xa9,0xa6,0x4b,0x65,0xe5,0x5a,0x43,0x39,0x2c, -0x83,0x2d,0xe8,0xf6,0x52,0xa8,0xdf,0xf7,0x3c,0xc2,0xa6,0x20,0x7f,0x7e,0x2c,0x88, -0x57,0xd6,0x39,0x2c,0x22,0x36,0x98,0x2b,0xb2,0x3d,0xb9,0xd5,0x8d,0x40,0xab,0x6f, -0x56,0xa7,0xb5,0x36,0x3f,0x44,0x47,0xcb,0x53,0xd0,0x2c,0xea,0x5b,0x13,0x3b,0x1a, -0x85,0x7b,0x3f,0x01,0x1c,0x56,0xf1,0x43,0x55,0xaf,0xf9,0x54,0xfa,0xb5,0x0d,0x36, -0x43,0x55,0x6b,0xaa,0xba,0x1f,0xaa,0xa0,0x9d,0xa6,0x91,0x1c,0x96,0x4d,0x5b,0xfd, -0xfc,0x10,0xc9,0x75,0x84,0x8d,0x6c,0x3d,0xb6,0xb4,0xe4,0x96,0xf9,0x81,0x47,0xc4, -0x0f,0x2b,0x79,0x9f,0x9b,0x0f,0x56,0x8b,0x56,0x2b,0x91,0x59,0x9b,0x1f,0xf2,0x3a, -0xf0,0xb9,0xf8,0x68,0x7c,0x29,0xb3,0x9d,0xdb,0xc9,0x75,0xad,0x46,0xf2,0xa9,0x3c, -0xe9,0xb5,0x20,0x1c,0xda,0x57,0x44,0x47,0xed,0x9d,0x59,0xd9,0x5e,0x33,0xc4,0xaa, -0xce,0x21,0x6d,0xb5,0xd9,0x17,0x1c,0xc2,0x28,0xd4,0x3a,0x57,0x16,0x7d,0x4a,0x8d, -0xf0,0xc3,0xb2,0x6d,0x23,0x67,0x4f,0x7d,0x57,0x3e,0x47,0x23,0x6c,0x54,0xf8,0xad, -0x42,0xfa,0xc0,0x08,0x74,0x32,0x26,0x12,0xe5,0xaa,0xf0,0x7b,0x36,0x33,0x21,0x0e, -0x63,0x45,0xe4,0x7b,0x66,0xef,0xc3,0x7c,0x91,0x5b,0x19,0x51,0xe6,0x4b,0xec,0x51, -0xe4,0xbe,0xec,0x39,0x9c,0xa2,0xdb,0x40,0xfc,0x90,0xb3,0x7e,0xf8,0xe6,0xd8,0xc3, -0x3f,0x59,0xcb,0x6c,0x67,0xf6,0x34,0x0e,0x71,0x3b,0x0d,0xec,0x3d,0x54,0x6d,0x14, -0xe2,0xf2,0x8b,0x97,0x2b,0xbd,0x72,0xd0,0x99,0x53,0x5b,0x51,0x66,0x3f,0x54,0x4d, -0x44,0xaa,0x32,0x6c,0xa7,0x69,0x94,0x1f,0xda,0x49,0xac,0x37,0x87,0xef,0x74,0x26, -0xf2,0x24,0x77,0x18,0x9c,0x61,0xba,0x2e,0x93,0x39,0xe0,0xe6,0xb9,0x6f,0xfe,0x32, -0x1b,0x5b,0x45,0x38,0x34,0x93,0x67,0xa6,0xcf,0x28,0x77,0x50,0x8f,0x03,0xbe,0x1d, -0xed,0x71,0x6f,0x07,0xde,0x7f,0x69,0xec,0xd1,0x33,0xe9,0xd7,0xb5,0x2d,0x8a,0x9e, -0xf5,0x0e,0x7e,0x2e,0x74,0x7f,0x14,0x4f,0x7e,0xa9,0x3f,0x53,0xb2,0xe8,0x7f,0x56, -0x31,0x7f,0x5c,0x7a,0x72,0x71,0x66,0x71,0xc9,0xe0,0xd0,0xee,0x87,0x4e,0x1c,0x96, -0x2b,0xd4,0x0c,0xb1,0x78,0x39,0xdc,0x2f,0xf5,0x43,0xd5,0x46,0x23,0x99,0x6d,0x59, -0xaa,0x9b,0x1f,0x3a,0x7b,0x60,0xc9,0xf4,0xbd,0x46,0x37,0x83,0xee,0x43,0xb7,0xea, -0xdb,0x71,0xbc,0xd2,0x02,0xac,0x19,0xc3,0x4c,0x44,0x2a,0xfc,0x6c,0xd0,0x4a,0x70, -0x1a,0x89,0x33,0x35,0xce,0x12,0xa6,0x7e,0xa8,0x53,0x82,0xc8,0x31,0x68,0xbb,0x43, -0xae,0x1b,0x54,0x12,0xca,0x14,0xbc,0xb7,0xff,0x66,0x95,0xe9,0x65,0xf2,0xd7,0xb9, -0xa0,0x51,0x6d,0xfe,0x57,0xb6,0xe2,0x6d,0x2f,0x45,0x23,0x1e,0x4e,0x2e,0xae,0x65, -0x76,0x8c,0x56,0x1a,0xb3,0x1f,0x3a,0xb5,0x95,0xa2,0xd1,0x4a,0xd5,0x5e,0x99,0xdf, -0x0f,0xbf,0xdd,0xf0,0xd5,0x82,0x82,0x12,0xe3,0x10,0xb6,0xcb,0x80,0xcb,0xd4,0x27, -0xea,0xc1,0x21,0x39,0xab,0xec,0x34,0x42,0x12,0xbf,0xbc,0x53,0xff,0xb5,0x27,0xee, -0x0e,0xa5,0x25,0xbe,0x99,0x98,0xa4,0xd4,0x3a,0x4b,0x98,0xf9,0x21,0xf1,0xac,0xd8, -0x26,0xf3,0x30,0x42,0x23,0x8a,0x24,0x9f,0x1d,0xb9,0x31,0x78,0x77,0xe8,0xe6,0xd0, -0x5d,0xad,0xdc,0x18,0x3c,0x17,0x7f,0xd5,0xfb,0x36,0x88,0xf6,0xb5,0xd5,0x6a,0x35, -0x0e,0x39,0xfd,0x70,0x2d,0x83,0xfc,0x10,0x71,0xd8,0xa5,0x51,0x88,0xfd,0x70,0x4e, -0x66,0x7e,0x68,0xa5,0xb0,0x72,0xcd,0x10,0x2b,0xb8,0x8c,0x8d,0xad,0xab,0x81,0xe9, -0x12,0xc8,0x6a,0x4f,0x09,0x04,0xd1,0x18,0x1e,0x53,0x5b,0x1f,0x3f,0x44,0x67,0xa1, -0x13,0x79,0xe6,0x12,0xdb,0x6c,0xc4,0x1a,0x30,0x2f,0x8e,0x65,0x3d,0x71,0x88,0xda, -0xae,0x6a,0x99,0x25,0x4c,0x39,0x04,0x51,0x25,0x2a,0x24,0xd2,0xd4,0xa3,0x4d,0xed, -0x3f,0x69,0xdf,0x33,0x77,0x83,0x95,0x37,0x0e,0x99,0x1f,0x9a,0x7b,0xf1,0x09,0x85, -0xf0,0x3b,0xaf,0x5c,0x33,0xc4,0xfa,0x4a,0x70,0xe8,0x50,0x3f,0x54,0xc1,0x65,0xe2, -0x89,0xf5,0x6b,0xa7,0x71,0x27,0xb1,0x31,0x1c,0xa2,0x1c,0x36,0xbc,0x39,0xbf,0xd9, -0xcc,0x72,0xff,0xb3,0x84,0x75,0x0e,0x71,0x5d,0x8f,0x52,0x87,0xeb,0x76,0xa4,0xde, -0x87,0x09,0x4d,0xfb,0x9e,0x21,0x11,0xac,0xfc,0x72,0x88,0xfd,0x30,0x6b,0xf3,0x43, -0x12,0x47,0xbb,0x8f,0x16,0xe4,0xe0,0x50,0xde,0x3f,0x1c,0xb2,0x98,0x14,0x64,0xba, -0x97,0x4b,0xc6,0x0c,0xaf,0xfa,0xf9,0xa1,0x7b,0x69,0x14,0x87,0xa1,0xd0,0x73,0x67, -0xf1,0xdc,0x1b,0xd4,0xe7,0xac,0xaf,0xd5,0x86,0xb7,0xaa,0x3c,0xfa,0x9d,0x25,0xdc, -0xdf,0xab,0xca,0x46,0x46,0x99,0x22,0xc9,0x3b,0x13,0x65,0xd7,0x8d,0x08,0x15,0x71, -0xd8,0x1a,0xab,0xa7,0xec,0xe5,0x78,0x39,0xdc,0x76,0xf0,0x43,0x6b,0x2b,0x0d,0xb9, -0x6f,0xf5,0x9a,0x21,0x16,0xc9,0x50,0xb5,0xff,0xfd,0xd0,0xdc,0x46,0x6a,0xac,0xfa, -0xc2,0x5a,0x2c,0xea,0xec,0x87,0x6e,0x25,0x5a,0x6c,0xdc,0xda,0x84,0xd7,0x66,0x97, -0xab,0xac,0x57,0x4a,0x56,0x2d,0x45,0xdb,0x32,0x5a,0x6b,0x58,0x3b,0xbf,0x26,0x25, -0x7f,0xb3,0x84,0x71,0x5c,0x6a,0xb4,0x75,0x6a,0x7b,0x56,0x4b,0x04,0xad,0x32,0xc5, -0xd6,0xf1,0x43,0x7e,0x0e,0x9d,0xe2,0x52,0xd8,0x7b,0x58,0xa2,0x24,0x16,0x5c,0x6a, -0x86,0x58,0x5f,0xa5,0xb8,0xd4,0x58,0x7b,0x47,0x06,0x59,0xee,0xe9,0x1a,0x84,0xf8, -0x53,0x6b,0xa2,0x1f,0x36,0x90,0x43,0x34,0xd6,0x0d,0xcf,0x08,0x67,0x25,0x6d,0xb9, -0x6c,0x5d,0xc1,0x34,0x92,0xf7,0xd3,0x5e,0x8e,0xfd,0xd0,0xc8,0xbe,0xb6,0x49,0x73, -0xaa,0x6d,0x46,0x8b,0xe6,0x1c,0x6c,0xad,0xe7,0x87,0xce,0x7d,0x93,0x95,0xfd,0xd0, -0xdc,0x6b,0xc1,0x28,0x2c,0x2b,0x4e,0xa3,0x49,0xed,0x72,0xca,0x50,0xb5,0xdf,0x38, -0x3c,0x31,0xcd,0x56,0xdd,0x21,0x5e,0xb8,0x6e,0x78,0x60,0x41,0x61,0x79,0x77,0xeb, -0xd7,0x6f,0xd1,0x6a,0x1c,0xa2,0x75,0x50,0xf0,0x0a,0x0b,0xac,0xa4,0xf4,0x0d,0x95, -0xef,0x48,0x29,0x0b,0xa3,0xe8,0x1c,0xdb,0xce,0x78,0x67,0x05,0xfb,0x21,0x26,0x0f, -0x70,0x08,0x32,0x24,0xe2,0xeb,0xad,0xe4,0x87,0x7c,0xbf,0x9b,0x3b,0xb9,0xaa,0x71, -0xa9,0x41,0x62,0xb4,0x58,0xad,0xcf,0x10,0xaa,0x6b,0xb5,0x1a,0x7d,0xac,0x64,0xdb, -0x98,0xc3,0x6b,0xb3,0x6c,0x1d,0x3a,0x90,0xeb,0x1a,0xac,0x3e,0x50,0x4f,0x3f,0xfc, -0x92,0x8b,0xc3,0x46,0xc6,0xa5,0x58,0x27,0x17,0xf5,0xfc,0x99,0xa0,0x24,0xe8,0x06, -0xe9,0x24,0x4c,0xce,0xc9,0xde,0x7b,0x13,0x8d,0xfa,0x21,0xa1,0xcf,0x20,0x8f,0xee, -0x8d,0xdb,0x93,0x2d,0xe6,0x87,0x6e,0x5e,0x88,0xfe,0xb7,0x9d,0x9b,0xc9,0x6c,0x67, -0x76,0xf4,0xd1,0x34,0x46,0xaf,0x85,0xad,0x7e,0x18,0xdd,0xe4,0xa9,0x19,0x62,0x75, -0xd1,0x19,0x57,0x95,0x3d,0x11,0x9d,0xaf,0xed,0xec,0x87,0xd7,0x66,0xcb,0x0a,0x71, -0x43,0x98,0x03,0xcb,0xe0,0xd0,0x88,0xe6,0xeb,0x55,0x3f,0xe4,0x8d,0x4b,0xeb,0xdd, -0x8f,0x6f,0xd5,0xcb,0x61,0x34,0x67,0x07,0xcd,0x17,0xc0,0xa5,0x6b,0x75,0xef,0x27, -0x68,0x3d,0x3e,0x34,0x3e,0x24,0xb2,0x0a,0xc9,0x24,0x44,0xa6,0x25,0xaf,0xbd,0x89, -0x26,0x0e,0x37,0x0d,0x02,0x89,0x0f,0x92,0xc8,0xb4,0xc5,0xe2,0xd2,0x6a,0x23,0xca, -0xa1,0x1f,0xbe,0xad,0xf9,0xe1,0x9e,0x63,0x5c,0x8a,0x33,0x26,0xea,0x59,0x6c,0xb8, -0x6b,0xd5,0x11,0xae,0x8c,0xfe,0xaa,0xdc,0xfe,0x7e,0xa8,0x52,0x3f,0x34,0xd6,0x5f, -0x32,0x65,0xf7,0x55,0xeb,0x57,0x3f,0xe4,0xaa,0xf9,0x37,0x3a,0x2e,0x45,0xfa,0x34, -0xf6,0x5a,0x06,0xad,0xaf,0x40,0xca,0x1e,0xdd,0x20,0x9d,0x11,0xca,0x22,0xfa,0xdd, -0xf7,0xd6,0x9b,0xc8,0x38,0x8c,0x3a,0x44,0xa3,0xb1,0x16,0xf4,0xc3,0x64,0x11,0x8e, -0x68,0x85,0x7b,0x46,0x27,0xda,0xd0,0x6a,0x69,0x64,0x74,0xa9,0xb9,0xd7,0x82,0xb5, -0x96,0xf2,0xd5,0x0c,0xb1,0xcc,0x23,0x5b,0x2b,0xd3,0x98,0x95,0x47,0xdb,0x98,0xc3, -0x32,0x75,0xbf,0x75,0x92,0x13,0xcb,0xb4,0xfa,0x40,0x2b,0xb4,0xd3,0x34,0xda,0x0f, -0x91,0x46,0xe3,0xaf,0x65,0xd6,0x1c,0xcb,0x07,0xfa,0x5c,0x82,0x1d,0x4a,0x25,0xa1, -0x71,0xd2,0x94,0xdf,0xc8,0x4d,0x4f,0x92,0xfa,0x21,0x28,0x84,0x46,0xe8,0x93,0xad, -0x55,0x3f,0x34,0x8f,0x26,0x87,0xf4,0xb1,0xdb,0x11,0x87,0x1f,0x64,0x4c,0xbd,0x87, -0x60,0xee,0x21,0xea,0x03,0xf3,0x16,0x3b,0x90,0x4c,0x00,0x2e,0x7e,0xb8,0x1f,0x38, -0xc4,0x99,0x76,0x2c,0x63,0x70,0x41,0xde,0xd6,0x3a,0x71,0xc8,0xd7,0x12,0xde,0x0c, -0x3f,0x44,0xba,0x31,0x88,0xc6,0x67,0xcd,0x64,0x66,0x16,0x5f,0xcb,0xbc,0xbd,0x88, -0x56,0xc4,0x64,0xc5,0x60,0x92,0xd2,0x88,0xbc,0x11,0xb1,0xc8,0xdf,0x9b,0xf8,0x6e, -0xcc,0xce,0xa1,0xbd,0x24,0x8b,0x73,0x72,0x6b,0xf8,0x61,0xd7,0x6a,0xb2,0x18,0xdb, -0x64,0xf3,0x3d,0x18,0x83,0x66,0x4f,0x8c,0x15,0xf7,0x72,0x4b,0x0e,0xbd,0xf8,0xa4, -0x67,0xac,0xac,0x74,0xad,0x7a,0x7b,0x65,0xfb,0x4c,0x0f,0x33,0x89,0xaa,0x91,0xdb, -0xbb,0xbd,0xe3,0xd2,0xb2,0x02,0xe6,0x35,0x5b,0x7a,0x2b,0x58,0x69,0x6e,0x5c,0xda, -0x0c,0x3f,0x44,0xba,0x3f,0x74,0x72,0xd1,0x5e,0x66,0xf4,0xc2,0x88,0xdc,0xd6,0xfd, -0x91,0x38,0x23,0x6f,0x6f,0xe2,0x6d,0x8d,0xc3,0xa4,0x0b,0x85,0xd1,0x16,0x8a,0x4b, -0xbb,0x56,0x2b,0xff,0x6a,0xc2,0x99,0x56,0xb1,0x4d,0xc8,0xa1,0xad,0xf7,0xd0,0x87, -0x6b,0x39,0x65,0xc6,0xb1,0x7a,0x21,0x6e,0xed,0xaf,0x47,0xbe,0xe7,0xc6,0x08,0x73, -0x08,0xdc,0x0f,0xae,0x00,0x22,0xd7,0x9b,0x43,0x5e,0x3f,0x6c,0x16,0x87,0x68,0x6d, -0xb8,0xce,0x05,0x6b,0x39,0xa2,0x17,0xc6,0x24,0xa1,0x11,0x9f,0x7b,0x3b,0xb9,0x7e, -0xae,0xde,0xc4,0x77,0x39,0x38,0xc4,0xf5,0xc3,0x7a,0xbf,0x47,0x3e,0xa1,0xfa,0x21, -0x19,0x07,0x8b,0xe7,0x89,0xe0,0xd1,0xe8,0x66,0x67,0x44,0xb7,0x57,0xe6,0x10,0x9d, -0x49,0x5e,0x62,0x77,0x2c,0xe7,0x11,0x75,0x66,0x0a,0x71,0x69,0x5f,0x0e,0x2f,0x4c, -0x97,0x95,0x75,0xa3,0x5d,0x94,0xac,0xdf,0x41,0xdd,0x1e,0xac,0x15,0x58,0x56,0x2e, -0x04,0xbe,0xf2,0x51,0x7d,0xda,0x69,0x46,0xe3,0x78,0x6e,0xc1,0xb9,0xea,0xfb,0x41, -0x97,0xff,0x1b,0xfb,0xd1,0xf8,0x5b,0xd3,0x84,0xb8,0xd7,0xd0,0x66,0x8d,0x4c,0xa9, -0x17,0x92,0xc8,0x34,0x2d,0xed,0xe4,0x6e,0x73,0xcc,0xb5,0xe5,0xf1,0x43,0x54,0x0a, -0xf2,0xf9,0xb1,0xfb,0x43,0xe1,0x91,0xfa,0x14,0x7e,0x6f,0x42,0x7e,0x18,0xa5,0xe3, -0x61,0x9d,0xf3,0x77,0xe8,0x7e,0x68,0xe1,0x10,0xb6,0x96,0x96,0x7d,0xad,0x56,0x64, -0xf5,0x43,0x4b,0x54,0x2a,0xb3,0x79,0x32,0xad,0xc3,0xe1,0xcd,0xc1,0xf0,0xc8,0xe7, -0xc7,0x58,0x41,0xd7,0xcc,0x1b,0x2a,0x64,0x7f,0x77,0xe8,0xc8,0x02,0x65,0x8e,0xf6, -0x1b,0x3a,0x15,0x34,0xbb,0x33,0x3e,0x76,0x9e,0xbb,0xbc,0x38,0xe6,0x7e,0x2e,0x06, -0xef,0x87,0xa3,0xf1,0x48,0xbe,0x64,0xfb,0xc6,0xec,0x97,0xfd,0x14,0x77,0x62,0x98, -0x87,0x0d,0x70,0x64,0x75,0xe3,0xe5,0x10,0x3d,0x5f,0xfd,0x4a,0x59,0xe1,0x39,0x56, -0xa4,0x88,0x56,0x3f,0x34,0x46,0x1c,0x98,0xe6,0x84,0xa0,0x3e,0xe0,0x2f,0x41,0x6b, -0x0d,0xe2,0xd0,0x79,0x34,0x4d,0xc9,0xe7,0xec,0x69,0xe7,0x8c,0x8d,0xd0,0x0f,0xd5, -0x96,0xe2,0xb0,0x37,0xbc,0x94,0x71,0xa6,0x88,0xd1,0x04,0x37,0xe3,0xdd,0xe0,0x19, -0x4e,0xb0,0x8d,0xb4,0xc2,0x63,0x79,0x8b,0x3e,0x42,0xb9,0x98,0x95,0xdd,0x56,0x9f, -0x0d,0xbe,0x7e,0xb8,0xa3,0xc7,0x4e,0x74,0x1e,0x9f,0xfd,0x9c,0x26,0x6b,0x75,0xd6, -0xb5,0x24,0x8b,0x57,0x39,0x66,0x61,0xf0,0x73,0x18,0x70,0xd9,0x04,0xed,0xb2,0x9b, -0xc9,0x62,0x49,0xfe,0x94,0x2b,0x53,0x46,0x97,0xce,0x21,0xcc,0x07,0x80,0x3f,0x63, -0x63,0xbe,0x24,0x6d,0xaf,0xc1,0x1c,0xc2,0x5e,0x0b,0x32,0xf7,0x30,0x2d,0xf9,0x6b, -0xcf,0x74,0xca,0xc8,0x01,0xce,0x4c,0x3a,0x3a,0xba,0x3e,0xeb,0x01,0x79,0x17,0x8a, -0x31,0xcd,0x33,0x98,0xe8,0x25,0x32,0x7f,0x82,0xd6,0xfb,0x4c,0xde,0x57,0xc5,0x07, -0xf9,0xa9,0xb6,0x92,0x1a,0x2b,0xba,0xfd,0xfa,0xb9,0xf9,0x21,0xad,0xf9,0x73,0x72, -0xd8,0x1b,0x4a,0x4b,0xe8,0x4c,0x33,0x46,0x4e,0x2b,0xe6,0xf5,0x70,0x0d,0x2e,0x2d, -0x7d,0x74,0xa4,0xf7,0x3c,0x48,0x0a,0xf9,0x6a,0x74,0x4d,0xe3,0xd0,0x56,0x6e,0x72, -0xcd,0xd1,0xff,0xbf,0x39,0x70,0xb4,0xda,0x27,0x86,0x3f,0x5f,0x90,0xa1,0x83,0x64, -0xe2,0x28,0x76,0xad,0xae,0x65,0x9c,0x32,0x26,0xfa,0x9d,0x23,0x56,0xad,0x7e,0x68, -0x5e,0xd7,0x9b,0x67,0xd4,0x78,0xfd,0x85,0x62,0x4c,0x38,0x6f,0xb0,0x00,0xfe,0x92, -0x31,0xa4,0x34,0xdf,0x0a,0x58,0x0f,0xde,0xb2,0x26,0x6f,0x60,0x44,0xba,0x8d,0x5c, -0x0a,0xba,0x7e,0xd8,0x1b,0x46,0x1c,0xda,0xf3,0xb7,0xc4,0xa8,0x0f,0x1a,0x63,0xa8, -0xe1,0x6a,0xd5,0x9b,0xf0,0xdc,0x82,0x7b,0x6b,0x8f,0x3a,0x3f,0x87,0x7c,0x91,0x5e, -0xb3,0x39,0x64,0xef,0x9e,0x2f,0x57,0x06,0xee,0xb7,0x88,0x92,0xc7,0x19,0x19,0x3b, -0xca,0x60,0xfe,0x24,0x76,0xc4,0x58,0x31,0x92,0xdf,0x26,0x1c,0xd2,0x5e,0x0b,0x55, -0xf6,0xbf,0x5e,0xd8,0xde,0x4f,0xcc,0x7e,0x58,0x62,0x7e,0x28,0xc3,0x5c,0xe0,0xad, -0xc4,0x21,0x98,0xbd,0x0b,0x7c,0x91,0xe4,0x99,0xa1,0x23,0xd6,0x4c,0x3e,0x68,0x5a, -0xd1,0x2a,0x10,0x2f,0xe4,0xe5,0xd0,0xbd,0x7e,0xe8,0xc5,0x0f,0x8f,0x19,0x1c,0x46, -0x8d,0x55,0xe2,0xf1,0x38,0x15,0x3c,0x8b,0x2f,0x0a,0xb9,0xb2,0xf4,0x94,0xfb,0x25, -0xce,0x99,0x42,0xde,0x95,0xaf,0x9b,0xcd,0x21,0x2b,0x7c,0x7e,0xd8,0x95,0x47,0x47, -0x1b,0xc5,0xbf,0x63,0xa6,0xdf,0x2a,0x7c,0x0b,0x9b,0xb9,0x8c,0xda,0x8c,0x71,0xab, -0x15,0xcb,0x4c,0x53,0x4b,0x8b,0xb7,0x7d,0xc6,0x15,0x23,0x91,0xd5,0x0d,0xb3,0x2d, -0xc5,0x21,0x9c,0x5b,0x4f,0x58,0x2c,0xc9,0x30,0xff,0x18,0x6b,0x03,0x55,0x4d,0x11, -0x69,0xed,0x34,0x5a,0x09,0x72,0xcb,0x0d,0xe6,0xee,0x87,0xa4,0xc6,0xc1,0x19,0x97, -0xea,0x1c,0x12,0xb2,0xa2,0xa0,0x36,0x68,0x8c,0xdb,0xa4,0xfc,0x59,0xc9,0x0b,0x8e, -0xc4,0x64,0x91,0x37,0xf3,0x7e,0xeb,0x70,0xc8,0xe7,0x87,0x11,0xdd,0x0f,0xd9,0x27, -0x86,0x0b,0xa2,0x8f,0xee,0xf5,0xba,0x63,0x6c,0x13,0x73,0x08,0x33,0x44,0x4d,0xd6, -0xb4,0x02,0xcc,0x5e,0xce,0x7e,0x9e,0x90,0x33,0x50,0x05,0x2b,0xd4,0xb4,0x12,0x87, -0x30,0x2a,0x55,0x69,0x9e,0x99,0x02,0xec,0x9f,0x37,0x66,0xd8,0x7b,0x8f,0x3e,0x79, -0xe8,0x83,0xd1,0xa4,0x57,0x3f,0xb4,0x8f,0x94,0xc2,0x97,0x92,0x9e,0xfc,0x90,0x9c, -0x25,0x76,0xc2,0xa2,0x01,0x7b,0x9f,0x13,0x85,0xfc,0xbd,0x7d,0x98,0xc3,0xa4,0xfe, -0xa8,0xca,0x5b,0xac,0xca,0x3e,0xa8,0xc2,0xe7,0x87,0x91,0x3c,0x79,0x5d,0x36,0x1f, -0x24,0x6a,0x27,0x53,0xbb,0x9e,0xd0,0x38,0x64,0x63,0x69,0x50,0x66,0x1a,0x9e,0x76, -0xab,0xca,0x72,0xf2,0x43,0x7c,0x26,0xaf,0xcb,0x90,0xc2,0xb4,0xc3,0x1a,0x35,0xcd, -0x10,0xab,0x1f,0x5a,0x32,0x00,0xd2,0x91,0xdc,0x25,0xd6,0x52,0x83,0x59,0xb4,0x66, -0xc9,0x0d,0x90,0x46,0x1e,0x3f,0x74,0x8a,0x4b,0xed,0x39,0xad,0xbd,0xfa,0x61,0xd4, -0xdc,0x3e,0x53,0xa4,0x75,0x1a,0x47,0x3a,0x83,0xe5,0x90,0x7f,0x1d,0x1a,0xe2,0x87, -0x56,0xaa,0x82,0xa6,0xcc,0xbd,0xf0,0xf9,0xa1,0xd1,0x16,0x8d,0x7b,0xf0,0x49,0x9c, -0x01,0x3e,0x5f,0xec,0x85,0x98,0x43,0xd8,0x4a,0x53,0x90,0x6b,0x1d,0x01,0xa2,0x71, -0xb8,0x69,0xa7,0x50,0x35,0xad,0x5f,0x8a,0x56,0x4e,0x6c,0x25,0x0e,0x59,0xbd,0x90, -0x44,0xa2,0x05,0x1a,0x8d,0xd2,0x88,0x5a,0x61,0xe3,0x46,0xbd,0x12,0xe8,0xee,0x83, -0xb4,0xdc,0xf1,0xe2,0x87,0xf6,0x75,0x8e,0x58,0x56,0x5d,0x2f,0x7e,0x98,0x2c,0x56, -0xf0,0xc0,0x3a,0xf5,0x56,0x24,0xc1,0xde,0xdb,0xd8,0x17,0x3e,0x3f,0xf4,0xb2,0xc1, -0xe3,0x09,0x9e,0xc3,0xb5,0x4c,0xd2,0xf8,0x1c,0x69,0xeb,0x33,0x6c,0xd9,0x02,0xfd, -0x44,0xa9,0x3c,0x5a,0x6f,0x2d,0xa5,0x73,0x98,0x95,0x6b,0x1f,0x1b,0x5c,0xc9,0x0f, -0x61,0x0b,0x0d,0xce,0x66,0xc2,0x3f,0x97,0xaa,0x9e,0x82,0xf5,0x43,0xd5,0xa8,0x17, -0x92,0x96,0x98,0x75,0x05,0xf6,0x12,0x92,0xb5,0x72,0xaa,0xf5,0x17,0xfa,0x8f,0x48, -0x09,0x59,0xfe,0xda,0x69,0xac,0x63,0x35,0x3c,0xd7,0x0f,0x8b,0xf5,0x25,0xaf,0x32, -0x91,0xc9,0xa2,0x97,0xd9,0x3c,0xd0,0x0f,0x9b,0x49,0xa1,0x17,0x0e,0x4d,0x71,0x84, -0x29,0xca,0xa7,0xbd,0x42,0xda,0x3e,0x25,0xb1,0xbc,0xa5,0x89,0xfc,0x67,0x3d,0xfc, -0x9f,0x89,0xb3,0xac,0x1c,0x92,0xa8,0x14,0xb6,0xd0,0xcc,0xe9,0x1c,0xb6,0x46,0xff, -0x21,0xe6,0x90,0xd0,0x47,0x33,0x00,0xd3,0x76,0x18,0x15,0x8e,0x1f,0xf5,0x4d,0x1f, -0x97,0x17,0x22,0x8a,0x5c,0x73,0xb8,0xdb,0x39,0x84,0x2b,0x1f,0xe9,0x7f,0xf5,0x56, -0x71,0xcf,0x7e,0x58,0xa7,0x7a,0x60,0x75,0x12,0xf8,0x5b,0x4a,0xb1,0x88,0x1f,0xfa, -0x2d,0x31,0xb0,0xf7,0x4f,0x29,0xba,0x8d,0xaf,0x7e,0xf8,0x41,0xce,0xe9,0xf1,0x3a, -0x83,0x80,0xc5,0xa8,0xce,0x21,0x6b,0x2b,0x7d,0x71,0xcc,0xcb,0x67,0xe2,0x2c,0x33, -0x87,0x2c,0x2a,0x55,0x4d,0x75,0x43,0x54,0xf8,0xde,0x49,0xbd,0xc5,0xe2,0x52,0x53, -0xc6,0x27,0xdc,0x5a,0xa3,0x10,0x2e,0x55,0x9f,0xfd,0x84,0x5e,0x49,0x74,0xf7,0xc3, -0x67,0x47,0x2a,0x65,0x1e,0x82,0xeb,0xa6,0xf8,0xf1,0xc3,0x46,0x8c,0x9b,0x81,0x67, -0x37,0xde,0xbc,0x8d,0x60,0x66,0x1c,0xc6,0x1c,0xc8,0x0a,0x26,0x62,0xe5,0x2b,0x7c, -0x7e,0xb8,0x9d,0x01,0xcf,0xb8,0x69,0xa7,0xcf,0xe8,0x23,0xd2,0xf6,0x28,0xbb,0x0f, -0x72,0xc3,0xac,0x1c,0xcc,0x98,0x64,0x27,0x0e,0x4b,0xa6,0xfe,0x8a,0x65,0x23,0x7f, -0x57,0xeb,0xf8,0x21,0x6b,0x1f,0x45,0xe4,0xad,0xd3,0xf6,0x18,0x3f,0xe3,0x65,0xfc, -0x7b,0x21,0x2a,0x31,0x57,0x3f,0xbc,0x3a,0x01,0x33,0x0f,0x59,0x57,0x37,0xa2,0xb9, -0xad,0x3d,0xd4,0x0f,0xe7,0x24,0xfe,0xb3,0xcf,0x2b,0x65,0x95,0x7d,0x10,0xef,0xbd, -0xb9,0x61,0xed,0x7e,0x18,0x9c,0x47,0xf2,0xb9,0xc8,0x76,0x45,0x3f,0x24,0x64,0x92, -0x82,0xa2,0x51,0x7f,0x39,0x7b,0x9c,0xe5,0xec,0x87,0xa0,0x8d,0x46,0xf7,0x42,0x54, -0x1b,0x6d,0x15,0x0e,0xcb,0x4a,0x01,0xf8,0xa0,0x8d,0x40,0x3a,0x86,0xc6,0x3a,0xab, -0x29,0x68,0x2f,0xc4,0x71,0xa9,0x9b,0x1f,0x22,0x0e,0xa1,0x0f,0xc2,0xb5,0x8f,0xe8, -0xa5,0xa2,0xe7,0x7e,0x8b,0x00,0x7d,0x90,0x8f,0x46,0x5c,0xbc,0xce,0xe7,0x09,0x96, -0xc3,0x98,0xc3,0xbe,0x3a,0x7d,0xac,0x78,0x6a,0xa7,0x71,0x2c,0xe6,0x96,0x1b,0xc4, -0x61,0x5a,0x8b,0x4d,0xf9,0xc6,0xad,0xba,0xcb,0x89,0xc3,0x75,0x45,0x35,0xd5,0x0d, -0x27,0x5b,0x8a,0x43,0xd2,0x22,0x53,0xa2,0x99,0x66,0x68,0x3d,0xb0,0xa6,0x7a,0xa1, -0x9f,0xc2,0xe7,0x87,0x96,0xf9,0xdc,0x77,0x30,0x8f,0x64,0x76,0x0d,0xee,0xa1,0x6a, -0x94,0x1f,0x56,0x27,0x2d,0xe6,0x78,0xfe,0xe3,0x32,0xe5,0xd9,0x0d,0x11,0x87,0x6a, -0xe0,0x7e,0xc8,0x4b,0xac,0x79,0xe3,0xe3,0xf0,0xc0,0x59,0xde,0xcf,0x36,0xab,0xc7, -0x88,0xf1,0x00,0x6a,0x86,0x58,0xe6,0x19,0xc8,0xe4,0x7c,0xb6,0x46,0xa5,0xad,0xc4, -0x61,0x59,0xff,0x9d,0x20,0x19,0x10,0x0b,0x8c,0x29,0xb9,0x64,0xce,0xfe,0xe4,0x3b, -0x32,0xe5,0x2f,0xee,0xed,0x34,0xe7,0xc7,0x92,0xa0,0x7e,0x08,0xfc,0x10,0xdd,0x0a, -0x56,0x5f,0x49,0x16,0xb7,0x39,0x39,0xcc,0x06,0x30,0x42,0x05,0x7a,0x06,0x2f,0x91, -0x53,0x9e,0xdd,0xb0,0x91,0x1c,0x56,0x7a,0x2f,0xe4,0x7d,0xf0,0xae,0xc5,0x76,0x64, -0x31,0x06,0x9e,0xb3,0x0a,0x87,0x9a,0x3f,0xd5,0xb2,0x02,0x8f,0x55,0x3b,0x36,0x3f, -0xd4,0xa2,0x52,0xc5,0xdc,0x63,0x81,0x39,0x6c,0x8d,0xfe,0x43,0xb4,0xd6,0x3b,0x9d, -0x53,0xa1,0xd4,0x36,0x9f,0xa2,0x36,0x2f,0xe4,0xf3,0xc3,0x73,0x71,0x74,0x2f,0xb2, -0x72,0x26,0x5c,0xe3,0x01,0xcc,0x8d,0xd0,0xb6,0xa9,0x22,0xef,0xec,0xd1,0xbd,0xdc, -0xa9,0x8a,0x14,0xd5,0xab,0x4c,0x15,0xa7,0xb6,0xfc,0xd5,0x84,0x12,0xf9,0x53,0x5b, -0xf6,0x67,0x63,0xfb,0x29,0xcb,0x75,0xa7,0xfb,0xd5,0x5a,0x4e,0x15,0x0b,0xf2,0x65, -0xee,0xb5,0x8d,0xdf,0x18,0x3c,0x70,0xf6,0xc8,0xc2,0x5e,0x2e,0x2d,0xa1,0x5e,0xdd, -0x4a,0x4c,0x16,0xe4,0x93,0x01,0xd5,0x0c,0xb1,0x0e,0x9c,0x45,0xcf,0x8a,0xe3,0x5e, -0x13,0x8d,0x26,0x12,0xd3,0x52,0x73,0xb2,0x18,0xd9,0xf5,0xdc,0x74,0x99,0x9b,0xae, -0x5a,0x08,0xb3,0xe6,0xaf,0x24,0x6d,0x9b,0x74,0xf5,0x4c,0x7d,0xcc,0x45,0x92,0x23, -0x5f,0xf3,0xfb,0xb3,0x25,0x90,0x51,0x01,0xae,0xb6,0xc9,0xc6,0x6b,0x94,0x95,0xbd, -0xdc,0xcb,0x9c,0x67,0xca,0xb9,0xf8,0x77,0xa4,0x5a,0xdf,0x97,0x75,0x83,0x9f,0x9b, -0xd3,0x67,0x39,0x27,0xf9,0x1d,0x2f,0xf2,0xc6,0x60,0x2a,0x5f,0x02,0xdf,0x84,0x79, -0x54,0x22,0x2c,0xaa,0x65,0x5f,0x70,0xb9,0x1f,0x5f,0x41,0x31,0x5d,0x2a,0x1f,0xf6, -0xb5,0x4e,0xce,0x68,0x3c,0x3e,0x76,0x6d,0x76,0x66,0x31,0x91,0xcf,0xca,0x28,0x62, -0x81,0xde,0x3b,0x29,0xbd,0x13,0x50,0xcd,0x90,0xe8,0xc2,0x34,0xcc,0xdf,0x8c,0xf3, -0xc7,0xa2,0x7c,0xb2,0x7b,0x39,0x9c,0xdb,0x12,0xe5,0x45,0x78,0x78,0xa9,0x75,0x56, -0x03,0x46,0x19,0xe1,0xc9,0x1a,0x0c,0x64,0x1d,0x06,0xeb,0x7a,0x0c,0x4e,0x6b,0x34, -0x38,0x95,0x49,0xd7,0x92,0xb6,0x5c,0x32,0x3f,0xf7,0xe0,0x62,0x0f,0xc7,0x11,0xf7, -0xf7,0xde,0x1d,0x22,0xe5,0xa6,0xe3,0xde,0x6b,0xac,0x81,0xf2,0x59,0xf8,0x58,0xa9, -0xb3,0xc2,0x36,0x1a,0xef,0xef,0xad,0x5e,0xfc,0x7c,0x4f,0x4c,0x4f,0xb2,0x67,0xd2, -0x5e,0xe9,0xd3,0xd8,0xed,0x06,0x96,0xef,0x87,0x83,0xc8,0x40,0x75,0xb9,0xf3,0x8d, -0xc1,0x5b,0x13,0x0f,0x2f,0xed,0x68,0x2e,0x89,0xb2,0xb1,0x15,0x6a,0x1c,0x4d,0x1a, -0xac,0x5e,0x09,0x15,0x43,0x77,0xf4,0xed,0x4a,0x68,0x21,0xf4,0x5b,0x0d,0x7b,0xdd, -0x63,0xe1,0x77,0x3a,0x2f,0x77,0xda,0xb7,0x77,0x1c,0xf6,0x4e,0xe5,0x5d,0xf4,0x37, -0xf6,0xae,0x76,0x9f,0xde,0x70,0x6f,0xb8,0x27,0xdc,0xeb,0x58,0x2a,0xdd,0x4e,0x4a, -0x6b,0x64,0x18,0x13,0x6a,0xb4,0x9e,0xec,0x7d,0x75,0xf0,0xfb,0x2d,0xf5,0xdd,0xab, -0x47,0x57,0x8e,0x5f,0xd4,0xca,0x94,0x56,0x7e,0x3c,0xbe,0x92,0xba,0x98,0x92,0x5f, -0xf8,0xe1,0xa1,0x67,0x3b,0xf8,0x1e,0xdd,0x11,0x3a,0xcf,0x79,0x4f,0x21,0x21,0xa1, -0xca,0x7a,0xee,0xe0,0xca,0x71,0x5c,0xe6,0xb5,0x6d,0x77,0xbc,0xfb,0xcc,0xf0,0xb9, -0xc7,0xe3,0xf3,0x09,0xb9,0xef,0xa3,0xa7,0xdc,0x1f,0x7d,0xb0,0x6f,0x7e,0xb8,0x58, -0xff,0x83,0x14,0x12,0xda,0xf7,0x3a,0xd8,0xf7,0xa1,0xc6,0xe0,0xbc,0xe6,0x89,0x68, -0x5b,0x19,0x7f,0xf4,0xbd,0xee,0x73,0x8f,0x53,0xd7,0x87,0x4f,0xf5,0xff,0xdd,0x33, -0xd5,0x1f,0xf9,0x2b,0xbf,0x3c,0x3f,0x3c,0x3f,0xfc,0x7b,0x07,0x1b,0x73,0x9c,0x42, -0x42,0xfb,0x59,0x1d,0xa1,0x2f,0xf4,0xd8,0x74,0x5e,0x8f,0x4f,0x2f,0x22,0x57,0x4c, -0x75,0x9f,0xc1,0x24,0xbe,0xf6,0x42,0x4f,0xc5,0x28,0xfa,0x46,0xe8,0xf9,0x04,0xe2, -0x50,0x3e,0xdc,0xc8,0xa3,0x15,0x12,0xda,0xaf,0xfa,0x7a,0xc7,0x14,0xa5,0x50,0xab, -0x27,0x0e,0x5f,0x3c,0xfe,0xa1,0x16,0x9f,0x76,0x9f,0xd9,0x38,0x3e,0x3f,0xb0,0xf6, -0xdd,0xff,0x51,0xa1,0x6d,0x77,0xf9,0xf0,0xfc,0xf0,0xd4,0x30,0xda,0x44,0x64,0x2a, -0x24,0x14,0x84,0x50,0x2d,0xf1,0x22,0x20,0x71,0x0a,0xc7,0xa7,0x1a,0x89,0x17,0xc7, -0xff,0xf5,0x52,0xbf,0x43,0x36,0xc7,0x9f,0x1d,0x42,0x04,0x6a,0xcc,0x0e,0xaf,0x0c, -0xff,0x50,0x44,0xa6,0x42,0x42,0x81,0xe8,0x60,0xdf,0x8a,0x46,0xa0,0x41,0xa1,0x5e, -0xe6,0xf5,0xf8,0x74,0x77,0xfc,0xef,0x17,0x7e,0x7f,0xd1,0x3a,0xa2,0xe8,0x6a,0x07, -0xb9,0xd7,0x94,0x88,0x4c,0x85,0x84,0x02,0x53,0x47,0x48,0x3d,0x3a,0xaf,0xf7,0x5e, -0x58,0x49,0x8c,0x5d,0xe9,0xca,0xcf,0x2c,0x9e,0x07,0xa3,0x61,0x8f,0x6b,0x35,0x4a, -0x72,0x9f,0x8b,0x28,0x32,0x4d,0xdc,0x68,0xde,0x81,0x0b,0x09,0xed,0x2b,0x7d,0xbd, -0xe3,0xf9,0x61,0x48,0xa1,0x4e,0xd9,0xf1,0x8d,0xf1,0x53,0x6f,0x65,0xe5,0x48,0x7e, -0x29,0xc3,0x72,0x29,0x1c,0xed,0x83,0xf7,0xd1,0x4a,0xe2,0x7f,0x8b,0x5e,0x44,0x21, -0xa1,0x80,0xf4,0xdc,0xc1,0x8b,0x30,0x32,0xd5,0xf7,0xf3,0x89,0x53,0x57,0xa6,0xb6, -0x54,0x39,0x91,0x5f,0xcb,0x5c,0x98,0xee,0xd1,0xee,0xf5,0x9f,0x0e,0x9a,0x48,0xd5, -0x28,0x4c,0x0e,0xfc,0x9b,0xa8,0x21,0x0a,0x09,0x05,0xa6,0x3f,0x3d,0xf4,0xfa,0xe1, -0xcc,0x61,0xf9,0xa8,0x7c,0xf4,0xef,0x8f,0xaa,0x47,0xbf,0xd0,0x8a,0xda,0x57,0xfe, -0xd1,0x75,0xf5,0xd4,0x56,0x49,0x99,0x94,0x76,0x72,0xef,0xcf,0xfe,0x79,0x6f,0xf9, -0x68,0xd2,0xe4,0x86,0xc9,0x44,0xb9,0xef,0xf5,0xee,0x66,0x1f,0xb9,0x90,0xd0,0x7e, -0x12,0x99,0x5b,0xd2,0x11,0xfa,0x5a,0xa8,0x4f,0x2b,0x1d,0xa1,0x5f,0x9c,0xde,0x50, -0xaf,0xab,0xf3,0x5b,0x65,0x05,0xad,0x98,0x77,0x72,0xe1,0x3f,0x8f,0x27,0x13,0x90, -0xc3,0xe8,0x40,0xb9,0x7b,0xb9,0xef,0x95,0xe6,0x1e,0xb6,0x90,0xd0,0xbe,0xd1,0xe5, -0xce,0x5f,0x9c,0x3e,0xb2,0x70,0x6d,0xd6,0xdc,0x77,0x7f,0x7f,0x08,0x71,0x78,0x5d, -0x5d,0xd9,0x42,0x33,0x27,0xb7,0x73,0xff,0xeb,0xb7,0x92,0x89,0xe4,0x30,0xf5,0xc4, -0x44,0xb4,0x5f,0xed,0x96,0xfb,0xae,0x34,0xeb,0xa0,0x85,0x84,0xf6,0x95,0xce,0x8f, -0x7d,0xf3,0x47,0x33,0x8b,0x3b,0xb9,0x49,0xc9,0x9c,0xdd,0x21,0x3c,0x82,0x39,0xd4, -0x48,0xd4,0xe2,0xd3,0x6f,0x2e,0xfc,0x6d,0xc7,0x14,0xa3,0x70,0xf8,0xf9,0x81,0x2f, -0xfa,0xe4,0xae,0x97,0xfa,0x1a,0x37,0x53,0x43,0x48,0x68,0xbf,0xea,0xe6,0xd0,0xfb, -0xb3,0x27,0x17,0xd7,0x32,0x91,0x3c,0x9a,0xc1,0x3c,0xbf,0x05,0xf3,0x3b,0x10,0x3f, -0xbc,0xae,0x6e,0xa8,0xc9,0xe2,0xed,0x58,0x7f,0x28,0x9a,0x98,0x4a,0x50,0x37,0x1c, -0x50,0xbb,0x97,0xbb,0x7e,0xee,0x32,0x12,0x55,0x48,0x48,0xa8,0xba,0xbe,0x1d,0xbf, -0x30,0x7d,0x72,0x71,0x29,0xb3,0xa7,0x39,0x21,0xca,0x44,0x32,0xbf,0x85,0x88,0x63, -0xeb,0x1f,0xdc,0x1d,0xc2,0x5e,0x88,0xfe,0xe2,0x99,0x93,0xaf,0xf7,0xc1,0x36,0x1a, -0xb5,0x2b,0xd3,0xfd,0x17,0x2d,0x33,0xc3,0x58,0x48,0xa8,0xfd,0xf4,0xdf,0x3b,0x1f, -0x68,0x35,0xc2,0x99,0xcc,0x4e,0x0e,0xe5,0x0d,0x40,0x4e,0x48,0x9c,0x6f,0x7e,0x8b, -0xe4,0x94,0xc2,0x1c,0xa2,0xdb,0x48,0x36,0x8f,0x5f,0x41,0x3d,0x17,0x09,0x1c,0x95, -0xaa,0xdf,0x58,0x7e,0x62,0xfb,0xbb,0x62,0x3e,0xad,0x90,0x90,0x4f,0x85,0xaf,0x8e, -0x3d,0xf5,0xfa,0x6b,0x0b,0x1f,0x2c,0x46,0x56,0xd3,0x1a,0x83,0x53,0x5b,0x2b,0xba, -0x13,0x12,0xea,0x4a,0x0a,0xa6,0xeb,0x8d,0x41,0xec,0x90,0x59,0x99,0x3c,0xf0,0x0a, -0x8a,0x4c,0x51,0xbf,0x61,0x7f,0xe9,0x89,0x6f,0x0d,0xcb,0x0b,0xc1,0x64,0x43,0x16, -0x12,0xfa,0xea,0x69,0xe0,0x99,0x5f,0x1d,0xbf,0x38,0xfe,0xe1,0xf8,0xa3,0xd4,0xa3, -0x57,0xfe,0xfd,0x95,0xa1,0x2b,0xff,0x20,0x0d,0x15,0x37,0xd4,0x5d,0x83,0x43,0xf4, -0x77,0x57,0xc5,0xeb,0xc6,0x23,0x0e,0x37,0xd4,0x53,0x5b,0xe7,0xc0,0x68,0xef,0xae, -0xae,0xa9,0x81,0x8b,0xe3,0x5f,0xbe,0x7e,0x71,0x79,0x5d,0x4e,0x49,0xb5,0xe6,0x3e, -0x11,0x12,0xfa,0x2a,0x2a,0x1f,0x92,0x8f,0xce,0x0f,0x5c,0x1f,0xf8,0xe4,0xf8,0xe3, -0xd4,0xe3,0xd4,0x6e,0x6a,0x77,0x7c,0x63,0x7c,0xe5,0xf8,0x5f,0xf7,0x7e,0x7e,0x6c, -0x29,0x53,0x52,0xae,0xeb,0x34,0x6e,0xe8,0x34,0xa2,0x15,0xd4,0x3f,0xeb,0x29,0x2b, -0xb0,0xbe,0x88,0xf4,0xf6,0x77,0x3f,0x5c,0x3d,0xb5,0x89,0xfb,0xf7,0xdd,0xb3,0x9d, -0x09,0x09,0x09,0x59,0x75,0x25,0x54,0x3e,0x7c,0x7d,0x60,0x03,0x31,0xf8,0xbd,0x47, -0x88,0xc2,0xd4,0x86,0xb6,0x7d,0xf1,0x02,0xf9,0xff,0xcd,0xa1,0x8f,0x2f,0x65,0xe5, -0x53,0x9a,0x07,0x7e,0x72,0x0f,0xc7,0xa2,0x9f,0xc6,0xd8,0x7c,0x8b,0xf8,0xd8,0x52, -0xa6,0xac,0xe0,0xd8,0x75,0x7e,0x2b,0xb6,0x99,0x96,0xee,0xb7,0xc4,0xda,0x35,0x42, -0x42,0xed,0x25,0xf9,0xf0,0x5f,0x0e,0x7f,0x32,0xde,0x7d,0x86,0x50,0x88,0xcb,0xb5, -0x43,0xe6,0x7b,0x8d,0xc6,0x4f,0x4c,0x27,0x4c,0x39,0x23,0xc3,0x23,0x88,0xc0,0x0d, -0xc3,0x2b,0x51,0x39,0xb5,0x55,0x56,0x5a,0x25,0x27,0xaa,0x90,0x50,0x3b,0xe9,0x4f, -0x0f,0x3d,0xd6,0xe7,0xda,0x3f,0x32,0x51,0xb8,0x32,0xee,0x92,0xd2,0x5a,0xab,0x25, -0x5e,0x07,0x04,0xe2,0xf1,0x35,0xc9,0x62,0x41,0x7e,0xcf,0x73,0x9e,0x76,0x21,0xa1, -0xaf,0xba,0x9e,0x09,0x7d,0x98,0x7a,0x01,0x51,0x98,0x82,0x14,0xee,0xa6,0xe4,0x17, -0x9c,0xee,0x0d,0xdb,0x5f,0x46,0xe3,0xc9,0xe2,0xae,0x89,0x44,0x34,0xe2,0x34,0x92, -0x6f,0xad,0x2c,0x90,0x42,0x42,0xed,0x20,0xe9,0x99,0x61,0x07,0x0a,0x77,0x53,0xdf, -0xb0,0xcc,0x5b,0xba,0x31,0xf8,0xfe,0x6c,0x41,0x9e,0xdf,0x82,0x99,0xd8,0x3f,0xeb, -0x79,0x70,0x3a,0x91,0x4f,0x16,0x49,0x64,0x3a,0xa5,0xb9,0xe1,0x5b,0xa2,0xc7,0x42, -0x48,0xc8,0xb3,0x9e,0x47,0xf5,0x42,0x9d,0x42,0x48,0xe2,0xc5,0xf1,0xaf,0xd1,0x7b, -0x7c,0x7e,0xec,0xc8,0x42,0x49,0xc6,0x6d,0xa6,0x9f,0xdc,0x4b,0xeb,0xab,0x74,0x5d, -0x9d,0x60,0x3c,0xde,0x8e,0xdd,0x9a,0x40,0xeb,0xbc,0x5d,0x57,0xd1,0xfa,0x00,0x4e, -0x99,0x6b,0x84,0x84,0x84,0xaa,0xe9,0xd7,0x3a,0x1e,0x7f,0x4f,0x2b,0x29,0x44,0xe2, -0x23,0x83,0xc6,0xc7,0xa9,0x8d,0xd4,0x4f,0xf5,0xd1,0xa1,0x2f,0x8e,0x2d,0x65,0x92, -0x46,0x1f,0xe2,0x86,0x31,0xa6,0x06,0xad,0xd9,0x30,0x1a,0xbf,0xae,0x11,0x69,0xee, -0x9d,0xb8,0xdc,0x19,0x1e,0xe9,0xfc,0xd1,0x6f,0xbc,0x2e,0xa6,0xe1,0x0b,0x09,0x79, -0x55,0xe7,0x61,0xd4,0x4a,0x8a,0x4b,0xf7,0xe4,0xe3,0xd4,0x8f,0xc7,0xe5,0x17,0x4e, -0x1c,0xba,0x83,0xff,0xb7,0x80,0xda,0x42,0x1f,0xdf,0xfb,0xe4,0x1e,0xe9,0xc9,0xdf, -0x50,0xf1,0x38,0x99,0x57,0xf5,0x7e,0xfc,0x0d,0xf5,0xbc,0x69,0xbd,0xc6,0xd1,0x50, -0xaa,0x6f,0x2a,0xf1,0xc5,0xd1,0x7f,0x7b,0xe6,0x7c,0xc7,0xd7,0x1c,0x5e,0x4b,0x48, -0x48,0xc8,0x59,0x7f,0xa0,0xb7,0x94,0x22,0x16,0xa7,0xc6,0x5f,0x3a,0xfa,0x2f,0x4f, -0xc1,0xb9,0x4a,0xb8,0xcf,0xf0,0x13,0xca,0xe1,0x27,0x2a,0x59,0x15,0xf0,0x5c,0x1c, -0x73,0x38,0x55,0x1c,0xa5,0x51,0xe8,0xef,0x1d,0x4c,0x0e,0xe3,0x4c,0xfc,0xa8,0x44, -0x87,0x0f,0xf6,0xbd,0x29,0x68,0x14,0x12,0xe2,0xd0,0xaf,0x75,0x74,0x9f,0xd9,0x4d, -0x7d,0xeb,0xf8,0xc3,0x5f,0xff,0x9d,0x5f,0xb2,0xff,0xf7,0xd6,0x44,0x5a,0x42,0x2d, -0xa2,0x8f,0xef,0xe1,0x76,0x98,0x58,0x91,0xac,0x1a,0x8e,0xfd,0x10,0x39,0x64,0x41, -0xef,0xd5,0xbf,0x12,0x7a,0xfd,0xf0,0x8a,0x9e,0x89,0x9f,0x94,0x95,0xe3,0x1b,0xc7, -0x3f,0x14,0x34,0x0a,0x09,0x71,0xa8,0x23,0xf4,0x2f,0x4f,0xdd,0xa9,0xf8,0xdf,0x73, -0xf1,0x54,0x1e,0x47,0xa6,0xb8,0x7e,0xc8,0xa2,0x50,0xec,0x87,0xd7,0xf5,0x11,0xa7, -0x4b,0x99,0xf7,0x3a,0x9e,0x1f,0xc6,0x59,0xf8,0x19,0x85,0xb8,0x5c,0xd7,0x68,0xdc, -0x38,0x9e,0x1c,0x7e,0xa9,0x4f,0x0c,0x74,0x13,0x12,0xf2,0xa7,0x63,0xe1,0xb5,0x4c, -0x49,0x9e,0xdf,0x42,0x35,0xc4,0x5d,0x53,0xab,0x0c,0xf1,0x43,0x5c,0x6b,0x3c,0x75, -0x65,0x3e,0x81,0xe9,0x63,0x04,0xae,0x00,0x16,0x77,0xb5,0xdb,0xbf,0x2e,0x9a,0x6f, -0x84,0x84,0x7c,0xaa,0x73,0x01,0xd7,0x10,0x1f,0xdf,0xfb,0xcd,0xcd,0xbf,0xf9,0x0f, -0xec,0x76,0xe4,0x87,0xd8,0x23,0xf5,0x76,0xd4,0xad,0x7f,0xff,0xa3,0x53,0x89,0x79, -0x47,0x0a,0x91,0x1f,0xca,0x87,0xdd,0x46,0xe6,0x08,0x09,0x09,0x55,0xd6,0xc0,0xd9, -0xb4,0x14,0x2b,0xee,0xde,0xfb,0x44,0xfd,0xcd,0xf4,0xca,0xf1,0x0b,0x74,0xbc,0xe9, -0x68,0x7c,0x43,0x7d,0xfa,0xfe,0xe3,0x7b,0xa8,0x20,0x4a,0xff,0x5b,0xf1,0xc7,0xe3, -0xc9,0x81,0x29,0x94,0x1b,0x43,0x5f,0xef,0x09,0x97,0x95,0xe1,0xeb,0x1a,0x9b,0x3f, -0x3b,0x54,0xed,0x15,0x84,0x84,0x84,0xdc,0x74,0x7f,0x68,0x52,0x42,0x35,0xc4,0xdd, -0xd5,0x8d,0xe3,0xa8,0x77,0x7f,0xf6,0x28,0x6e,0x73,0x39,0x17,0xdf,0xbd,0xf7,0xf4, -0xfd,0xee,0x7f,0xd4,0x37,0xed,0xef,0xf0,0xfd,0x43,0x05,0xb5,0x4b,0xed,0xfa,0xa2, -0xaf,0xdc,0x17,0xed,0xc7,0x25,0x39,0x90,0x1c,0x90,0xfb,0x78,0x57,0x11,0x16,0x12, -0x12,0xaa,0xa4,0x77,0x63,0x7b,0xb9,0x92,0xf2,0x0f,0xf9,0x8d,0xf1,0xdd,0x71,0x3c, -0xce,0xe6,0x79,0xbd,0xa6,0x77,0x73,0xe8,0xd4,0xd6,0xbc,0x31,0x57,0x7f,0x43,0x1f, -0x65,0xf3,0xf8,0xde,0xd4,0xf2,0xeb,0x4f,0x2c,0x3f,0xb1,0xdc,0xbd,0xdc,0x2d,0x6b, -0x45,0xd5,0xca,0x0f,0x7f,0xb9,0xd9,0xc7,0x2f,0x24,0xb4,0x3f,0x74,0x72,0x31,0x2b, -0xfd,0x38,0xb5,0x32,0x0c,0xe7,0x61,0xfc,0xae,0x46,0xe2,0x81,0xb3,0xd7,0x66,0x8f, -0x2c,0xa0,0x4c,0x52,0x89,0x7c,0x5a,0x2a,0xc8,0xb1,0xcd,0xa9,0xe2,0xb7,0x96,0xff, -0xec,0x85,0xa3,0xdf,0x78,0xa9,0xeb,0xa5,0xae,0xd9,0xee,0x9f,0x1f,0xba,0xdf,0xec, -0x43,0x17,0x12,0xda,0x37,0x7a,0x6b,0xf6,0x8b,0xc5,0xe8,0x81,0x95,0xe3,0x8c,0xc3, -0xc7,0xa9,0x8f,0x2d,0x19,0x11,0x8f,0x85,0x3f,0xeb,0x79,0x63,0x30,0x3c,0xf2,0xe0, -0xf4,0xdf,0x4e,0x8c,0xff,0xc6,0x89,0x43,0x07,0x0e,0xfd,0x73,0x73,0x0e,0x56,0x48, -0x68,0x9f,0xea,0xfc,0xc4,0xe4,0x2b,0xe5,0x27,0xe6,0x87,0x77,0xc7,0xc9,0x28,0xf0, -0x47,0xc6,0xd8,0x53,0x21,0x21,0xa1,0x46,0x69,0x34,0xfe,0xff,0xfe,0x4b,0xf9,0x89, -0xa9,0x04,0xa9,0x1f,0x3e,0x72,0xf0,0x43,0x21,0x21,0xa1,0xfa,0xea,0x58,0x78,0xe2, -0xa8,0xfa,0x8d,0xe4,0xc0,0xc6,0x38,0x99,0x8f,0xf1,0x58,0xf8,0xa1,0x90,0x50,0xc3, -0xf5,0xf3,0x5f,0x57,0xbb,0x62,0xfd,0x2b,0x7a,0x1e,0xb7,0xc7,0xc2,0x0f,0x85,0x84, -0x9a,0xa2,0x37,0x9f,0x52,0xfb,0xa2,0x4f,0xcf,0x0f,0x3f,0x4a,0x61,0x12,0xbb,0x27, -0xaf,0x09,0x0e,0x85,0x84,0x1a,0xae,0x9f,0x3d,0x13,0x7b,0x7a,0x3e,0xb1,0x4b,0x38, -0x3c,0xf3,0x96,0x18,0x21,0x23,0x24,0xd4,0x04,0x1d,0xec,0x3e,0x35,0xb0,0x3b,0x4e, -0xfc,0x50,0x70,0x28,0x24,0xd4,0x1c,0xfd,0xdd,0xa1,0xdd,0xf1,0xee,0x49,0x94,0x41, -0xa3,0xfb,0xcc,0x1f,0x09,0x0e,0x85,0x84,0x9a,0xa4,0x0b,0x87,0x76,0x53,0x28,0xa3, -0x54,0xf7,0x99,0xc3,0x82,0x43,0x21,0xa1,0xa6,0xe9,0x0f,0x7f,0xe9,0xe2,0xf8,0xf0, -0x99,0xa7,0x05,0x87,0x42,0x42,0x4d,0x55,0x47,0x68,0xf6,0xe8,0xb0,0xe0,0x50,0x48, -0xa8,0xed,0xf5,0xff,0x01,0xd1,0x0a,0xff,0xc9,0xa6,0xee,0x01,0x00}; -#endif
Dear Tom,
On Sat, 11 Jun 2022 at 12:03, Tom Rini trini@konsulko.com wrote:
Since bb5930d5c97f ("exynos: video: Convert several boards to driver model for video") there have been no callers of any of the exynos_lcd_* family of functions. Remove these from the boards, and then remove unused logo and related code as well.
Signed-off-by: Tom Rini trini@konsulko.com
arch/arm/mach-exynos/include/mach/system.h | 1 - board/samsung/trats/trats.c | 23 - board/samsung/trats2/trats2.c | 35 - board/samsung/universal_c210/universal.c | 107 - drivers/video/Makefile | 1 - drivers/video/s6e8ax0.c | 265 - include/configs/s5pc210_universal.h | 2 - include/configs/trats.h | 2 - include/configs/trats2.h | 2 - lib/Makefile | 1 - lib/tizen/Makefile | 6 - lib/tizen/tizen.c | 34 - lib/tizen/tizen_logo_16bpp.h | 7934 -------------------- lib/tizen/tizen_logo_16bpp_gzip.h | 647 -- 14 files changed, 9060 deletions(-) delete mode 100644 drivers/video/s6e8ax0.c delete mode 100644 lib/tizen/Makefile delete mode 100644 lib/tizen/tizen.c delete mode 100644 lib/tizen/tizen_logo_16bpp.h delete mode 100644 lib/tizen/tizen_logo_16bpp_gzip.h
Reviewed-by: Minkyu Kang mk7.kang@samsung.com
Remove the unused older exynos pwm backlight driver.
Signed-off-by: Tom Rini trini@konsulko.com --- .../mach-exynos/include/mach/pwm_backlight.h | 20 --------- drivers/video/exynos/exynos_pwm_bl.c | 44 ------------------- 2 files changed, 64 deletions(-) delete mode 100644 arch/arm/mach-exynos/include/mach/pwm_backlight.h delete mode 100644 drivers/video/exynos/exynos_pwm_bl.c
diff --git a/arch/arm/mach-exynos/include/mach/pwm_backlight.h b/arch/arm/mach-exynos/include/mach/pwm_backlight.h deleted file mode 100644 index c7d3a91e3183..000000000000 --- a/arch/arm/mach-exynos/include/mach/pwm_backlight.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2012 Samsung Electronics - * - * Author: Donghwa Lee dh09.lee@samsung.com - */ - -#ifndef _PWM_BACKLIGHT_H_ -#define _PWM_BACKLIGHT_H_ - -struct pwm_backlight_data { - int pwm_id; - int period; - int max_brightness; - int brightness; -}; - -extern int exynos_pwm_backlight_init(struct pwm_backlight_data *pd); - -#endif /* _PWM_BACKLIGHT_H_ */ diff --git a/drivers/video/exynos/exynos_pwm_bl.c b/drivers/video/exynos/exynos_pwm_bl.c deleted file mode 100644 index a3d467aa23b5..000000000000 --- a/drivers/video/exynos/exynos_pwm_bl.c +++ /dev/null @@ -1,44 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * PWM BACKLIGHT driver for Board based on EXYNOS. - * - * Author: Donghwa Lee dh09.lee@samsung.com - * - * Derived from linux/drivers/video/backlight/pwm_backlight.c - */ - -#include <common.h> -#include <pwm.h> -#include <linux/types.h> -#include <asm/io.h> -#include <asm/arch/cpu.h> -#include <asm/arch/gpio.h> -#include <asm/arch/pwm.h> -#include <asm/arch/pwm_backlight.h> - -static struct pwm_backlight_data *pwm; - -static int exynos_pwm_backlight_update_status(void) -{ - int brightness = pwm->brightness; - int max = pwm->max_brightness; - - if (brightness == 0) { - pwm_config(pwm->pwm_id, 0, pwm->period); - pwm_disable(pwm->pwm_id); - } else { - pwm_config(pwm->pwm_id, - brightness * pwm->period / max, pwm->period); - pwm_enable(pwm->pwm_id); - } - return 0; -} - -int exynos_pwm_backlight_init(struct pwm_backlight_data *pd) -{ - pwm = pd; - - exynos_pwm_backlight_update_status(); - - return 0; -}
Dear Tom,
- In a number of cases, use CONFIG_ARCH_EXYNOS[45] rather than CONFIG_EXYNOS[45] - In other cases, test for CONFIG_ARCH_EXYNOS or CONFIG_ARCH_S5PC1XX - Migrate specific SoC CONFIG values to Kconfig - Use CONFIG_TARGET_x rather than CONFIG_x - Migrate other CONFIG_EXYNOS_x symbols to Kconfig - Reference CONFIG_EXYNOS_RELOCATE_CODE_BASE directly as EXYNOS_RELOCATE_CODE_BASE - Rename CONFIG_S5P_PA_SYSRAM to CONFIG_SMP_PEN_ADDR to match the rest of U-Boot usage.
Cc: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/Kconfig | 3 ++ arch/arm/dts/Makefile | 8 ++--- arch/arm/include/asm/spl.h | 5 ++-- arch/arm/mach-exynos/Kconfig | 39 +++++++++++++++++++++++++ arch/arm/mach-exynos/Makefile | 4 +-- arch/arm/mach-exynos/dmc_init_exynos4.c | 2 +- arch/arm/mach-exynos/exynos4_setup.h | 4 +-- arch/arm/mach-exynos/lowlevel_init.c | 8 +++-- arch/arm/mach-exynos/sec_boot.S | 2 +- board/samsung/arndale/arndale.c | 4 +-- configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + drivers/i2c/exynos_hs_i2c.c | 2 +- drivers/i2c/s3c24x0_i2c.c | 4 +-- include/configs/arndale.h | 6 +--- include/configs/espresso7420.h | 2 -- include/configs/exynos-common.h | 4 --- include/configs/exynos4-common.h | 2 -- include/configs/exynos5-common.h | 10 ------- include/configs/exynos5-dt-common.h | 2 -- include/configs/exynos5250-common.h | 2 -- include/configs/exynos5420-common.h | 7 ----- include/configs/exynos7420-common.h | 4 --- include/configs/exynos78x0-common.h | 4 --- include/configs/odroid.h | 3 -- include/configs/odroid_xu3.h | 3 -- include/configs/origen.h | 4 --- include/configs/s5p_goni.h | 5 ---- include/configs/smdkc100.h | 8 ----- include/configs/smdkv310.h | 2 -- include/configs/trats.h | 5 ---- include/configs/trats2.h | 3 -- include/power/fg_battery_cell_params.h | 2 +- scripts/Makefile.spl | 6 ++-- 36 files changed, 74 insertions(+), 99 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index da661ce30b03..b60b47743e79 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -609,6 +609,9 @@ config ARM64_SUPPORT_AARCH32 help This ARM64 system supports AArch32 execution state.
+config S5P + def_bool y if ARCH_EXYNOS || ARCH_S5PC1XX + choice prompt "Target select" default TARGET_HIKEY diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0a2713c06a3c..539eeb5a87a2 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -5,9 +5,9 @@ dtb-$(CONFIG_TARGET_TAURUS) += at91sam9g20-taurus.dtb dtb-$(CONFIG_TARGET_CORVUS) += at91sam9g45-corvus.dtb dtb-$(CONFIG_TARGET_GURNARD) += at91sam9g45-gurnard.dtb
-dtb-$(CONFIG_S5PC100) += s5pc1xx-smdkc100.dtb -dtb-$(CONFIG_S5PC110) += s5pc1xx-goni.dtb -dtb-$(CONFIG_EXYNOS4) += exynos4210-origen.dtb \ +dtb-$(CONFIG_TARGET_SMDKC100) += s5pc1xx-smdkc100.dtb +dtb-$(CONFIG_TARGET_S5P_GONI) += s5pc1xx-goni.dtb +dtb-$(CONFIG_ARCH_EXYNOS4) += exynos4210-origen.dtb \ exynos4210-smdkv310.dtb \ exynos4210-universal_c210.dtb \ exynos4210-trats.dtb \ @@ -19,7 +19,7 @@ dtb-$(CONFIG_TARGET_HIKEY960) += hi3660-hikey960.dtb
dtb-$(CONFIG_TARGET_POPLAR) += hi3798cv200-poplar.dtb
-dtb-$(CONFIG_EXYNOS5) += exynos5250-arndale.dtb \ +dtb-$(CONFIG_ARCH_EXYNOS5) += exynos5250-arndale.dtb \ exynos5250-snow.dtb \ exynos5250-spring.dtb \ exynos5250-smdk5250.dtb \ diff --git a/arch/arm/include/asm/spl.h b/arch/arm/include/asm/spl.h index b5790bd0bc45..0ece4b09060a 100644 --- a/arch/arm/include/asm/spl.h +++ b/arch/arm/include/asm/spl.h @@ -6,9 +6,8 @@ #ifndef _ASM_SPL_H_ #define _ASM_SPL_H_
-#if defined(CONFIG_ARCH_OMAP2PLUS) \ - || defined(CONFIG_EXYNOS4) || defined(CONFIG_EXYNOS5) \ - || defined(CONFIG_EXYNOS4210) || defined(CONFIG_ARCH_K3) +#if defined(CONFIG_ARCH_EXYNOS4) || defined(CONFIG_ARCH_EXYNOS5) || \ + defined(CONFIG_ARCH_K3) || defined(CONFIG_ARCH_OMAP2PLUS) /* Platform-specific defines */ #include <asm/arch/spl.h>
diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index 77fb9d1775bb..84102908561e 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -54,11 +54,15 @@ endchoice
if ARCH_EXYNOS4
+config EXYNOS4210 + bool + choice prompt "EXYNOS4 board select"
config TARGET_SMDKV310 bool "Exynos4210 SMDKV310 board" + select EXYNOS4210 select OF_CONTROL select SUPPORT_SPL
@@ -70,6 +74,7 @@ config TARGET_S5PC210_UNIVERSAL
config TARGET_ORIGEN bool "Exynos4412 Origen board" + select EXYNOS4210 select SUPPORT_SPL
config TARGET_TRATS2 @@ -83,6 +88,15 @@ endif
if ARCH_EXYNOS5
+config EXYNOS5250 + bool + +config EXYNOS5420 + bool + +config EXYNOS5_DT + bool + config SPL_GPIO default y
@@ -97,6 +111,8 @@ choice
config TARGET_ODROID_XU3 bool "Exynos5422 Odroid board" + select EXYNOS5_DT + select EXYNOS5420 select OF_CONTROL
config TARGET_ARNDALE @@ -105,36 +121,49 @@ config TARGET_ARNDALE select ARM_ERRATA_774769 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT + select EXYNOS5250 select OF_CONTROL select SUPPORT_SPL
config TARGET_SMDK5250 bool "SMDK5250 board" + select EXYNOS5_DT + select EXYNOS5250 select OF_CONTROL select SUPPORT_SPL
config TARGET_SNOW bool "Snow board" + select EXYNOS5_DT + select EXYNOS5250 select OF_CONTROL select SUPPORT_SPL
config TARGET_SPRING bool "Spring board" + select EXYNOS5_DT + select EXYNOS5250 select OF_CONTROL select SUPPORT_SPL
config TARGET_SMDK5420 bool "SMDK5420 board" + select EXYNOS5_DT + select EXYNOS5420 select OF_CONTROL select SUPPORT_SPL
config TARGET_PEACH_PI bool "Peach Pi board" + select EXYNOS5_DT + select EXYNOS5420 select OF_CONTROL select SUPPORT_SPL
config TARGET_PEACH_PIT bool "Peach Pit board" + select EXYNOS5_DT + select EXYNOS5420 select OF_CONTROL select SUPPORT_SPL
@@ -189,6 +218,16 @@ endif config SYS_SOC default "exynos"
+config EXYNOS_ACE_SHA + bool "Advanced Crypto Engine SHA support" + depends on (ARCH_EXYNOS4 || ARCH_EXYNOS5) && (LIB_HW_RAND || SHA_HW_ACCEL) + default y if ARCH_EXYNOS5 + +config EXYNOS_TMU + bool "Exynos5 thermal management unit support" + depends on ARCH_EXYNOS5 + default y + source "board/samsung/smdkv310/Kconfig" source "board/samsung/trats/Kconfig" source "board/samsung/universal_c210/Kconfig" diff --git a/arch/arm/mach-exynos/Makefile b/arch/arm/mach-exynos/Makefile index e895c13157f1..dd097cf54183 100644 --- a/arch/arm/mach-exynos/Makefile +++ b/arch/arm/mach-exynos/Makefile @@ -10,8 +10,8 @@ obj-$(CONFIG_ARM64) += mmu-arm64.o obj-$(CONFIG_EXYNOS5420) += sec_boot.o
ifdef CONFIG_SPL_BUILD -obj-$(CONFIG_EXYNOS5) += clock_init_exynos5.o -obj-$(CONFIG_EXYNOS5) += dmc_common.o dmc_init_ddr3.o +obj-$(CONFIG_ARCH_EXYNOS5) += clock_init_exynos5.o +obj-$(CONFIG_ARCH_EXYNOS5) += dmc_common.o dmc_init_ddr3.o obj-$(CONFIG_EXYNOS4210)+= dmc_init_exynos4.o clock_init_exynos4.o obj-y += spl_boot.o tzpc.o obj-y += lowlevel_init.o diff --git a/arch/arm/mach-exynos/dmc_init_exynos4.c b/arch/arm/mach-exynos/dmc_init_exynos4.c index ecddc7268497..58a3c82f681d 100644 --- a/arch/arm/mach-exynos/dmc_init_exynos4.c +++ b/arch/arm/mach-exynos/dmc_init_exynos4.c @@ -175,7 +175,7 @@ void mem_ctrl_init(int reset) * 0: full_sync */ writel(1, ASYNC_CONFIG); -#ifdef CONFIG_ORIGEN +#ifdef CONFIG_TARGET_ORIGEN /* Interleave: 2Bit, Interleave_bit1: 0x15, Interleave_bit0: 0x7 */ writel(APB_SFR_INTERLEAVE_CONF_VAL, EXYNOS4_MIU_BASE + APB_SFR_INTERLEAVE_CONF_OFFSET); diff --git a/arch/arm/mach-exynos/exynos4_setup.h b/arch/arm/mach-exynos/exynos4_setup.h index a08d64a8e23e..fbb45eb897e3 100644 --- a/arch/arm/mach-exynos/exynos4_setup.h +++ b/arch/arm/mach-exynos/exynos4_setup.h @@ -420,7 +420,7 @@ struct mem_timings { #define ABP_SFR_SLV1_SINGLE_ADDRMAP_START_OFFSET 0x828 #define ABP_SFR_SLV1_SINGLE_ADDRMAP_END_OFFSET 0x830
-#ifdef CONFIG_ORIGEN +#ifdef CONFIG_TARGET_ORIGEN /* Interleave: 2Bit, Interleave_bit1: 0x15, Interleave_bit0: 0x7 */ #define APB_SFR_INTERLEAVE_CONF_VAL 0x20001507 #define APB_SFR_ARBRITATION_CONF_VAL 0x00000001 @@ -542,7 +542,7 @@ struct mem_timings {
#define CONTROL2_VAL 0x00000000
-#ifdef CONFIG_ORIGEN +#ifdef CONFIG_TARGET_ORIGEN #define TIMINGREF_VAL 0x000000BB #define TIMINGROW_VAL 0x4046654f #define TIMINGDATA_VAL 0x46400506 diff --git a/arch/arm/mach-exynos/lowlevel_init.c b/arch/arm/mach-exynos/lowlevel_init.c index 2645a8ff4924..1ff5fcac1b38 100644 --- a/arch/arm/mach-exynos/lowlevel_init.c +++ b/arch/arm/mach-exynos/lowlevel_init.c @@ -49,6 +49,10 @@ enum { };
#ifdef CONFIG_EXYNOS5420 + +/* Address for relocating helper code (Last 4 KB of IRAM) */ +#define EXYNOS_RELOCATE_CODE_BASE (CONFIG_IRAM_TOP - 0x1000) + /* * Power up secondary CPUs. */ @@ -56,7 +60,7 @@ static void secondary_cpu_start(void) { v7_enable_smp(EXYNOS5420_INFORM_BASE); svc32_mode_en(); - branch_bx(CONFIG_EXYNOS_RELOCATE_CODE_BASE); + branch_bx(EXYNOS_RELOCATE_CODE_BASE); }
/* @@ -153,7 +157,7 @@ static void power_down_core(void) static void secondary_cores_configure(void) { /* Clear secondary boot iRAM base */ - writel(0x0, (CONFIG_EXYNOS_RELOCATE_CODE_BASE + 0x1C)); + writel(0x0, (EXYNOS_RELOCATE_CODE_BASE + 0x1C));
/* set lowpower flag and address */ writel(CPU_RST_FLAG_VAL, CONFIG_LOWPOWER_FLAG); diff --git a/arch/arm/mach-exynos/sec_boot.S b/arch/arm/mach-exynos/sec_boot.S index 59d05e6c01d9..40c07209e475 100644 --- a/arch/arm/mach-exynos/sec_boot.S +++ b/arch/arm/mach-exynos/sec_boot.S @@ -21,7 +21,7 @@ relocate_wait_code: .ltorg /* * Secondary core waits here until Primary wake it up. - * Below code is copied to CONFIG_EXYNOS_RELOCATE_CODE_BASE. + * Below code is copied to (CONFIG_IRAM_TOP - 0x1000) * This is a workaround code which is supposed to act as a * substitute/supplement to the iROM code. * diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index b43242fd3f40..5320c1f2e0ad 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -112,10 +112,10 @@ int checkboard(void) } #endif
-#ifdef CONFIG_S5P_PA_SYSRAM +#ifdef CONFIG_SMP_PEN_ADDR void smp_set_core_boot_addr(unsigned long addr, int corenr) { - writel(addr, CONFIG_S5P_PA_SYSRAM); + writel(addr, CONFIG_SMP_PEN_ADDR);
/* make sure this write is really executed */ __asm__ volatile ("dsb\n"); diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 7acdca93398d..929a52140d5d 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_SYS_MALLOC_LEN=0x5004000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ARCH_EXYNOS5=y +# CONFIG_EXYNOS_TMU is not set CONFIG_NR_DRAM_BANKS=8 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x310000 diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index d442aca78871..8beb6a006e5e 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_MALLOC_LEN=0x5004000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_ODROID=y +CONFIG_EXYNOS_ACE_SHA=y CONFIG_NR_DRAM_BANKS=8 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x140000 diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 00a663fcf2aa..5c47a22d1e06 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_MALLOC_LEN=0x5001000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_TRATS2=y +CONFIG_EXYNOS_ACE_SHA=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x7000 CONFIG_DEFAULT_DEVICE_TREE="exynos4412-trats2" diff --git a/configs/trats_defconfig b/configs/trats_defconfig index d5f08666068c..008a8ff4b30e 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_MALLOC_LEN=0x5001000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ARCH_EXYNOS4=y CONFIG_TARGET_TRATS=y +CONFIG_EXYNOS_ACE_SHA=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x7000 CONFIG_DEFAULT_DEVICE_TREE="exynos4210-trats" diff --git a/drivers/i2c/exynos_hs_i2c.c b/drivers/i2c/exynos_hs_i2c.c index 39bcacc17a7e..a7349e06cfd3 100644 --- a/drivers/i2c/exynos_hs_i2c.c +++ b/drivers/i2c/exynos_hs_i2c.c @@ -147,7 +147,7 @@ static int hsi2c_get_clk_details(struct s3c24x0_i2c_bus *i2c_bus) unsigned int i = 0, utemp0 = 0, utemp1 = 0; unsigned int t_ftl_cycle;
-#if (defined CONFIG_EXYNOS4 || defined CONFIG_EXYNOS5) +#if defined(CONFIG_ARCH_EXYNOS4) || defined(CONFIG_ARCH_EXYNOS5) clkin = get_i2c_clk(); #else clkin = get_PCLK(); diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index aaccb3aa2280..505e20bc61c8 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -8,7 +8,7 @@ #include <errno.h> #include <dm.h> #include <fdtdec.h> -#if (defined CONFIG_EXYNOS4 || defined CONFIG_EXYNOS5) +#if defined(CONFIG_ARCH_EXYNOS4) || defined(CONFIG_ARCH_EXYNOS5) #include <log.h> #include <asm/arch/clk.h> #include <asm/arch/cpu.h> @@ -53,7 +53,7 @@ static void read_write_byte(struct s3c24x0_i2c *i2c) static void i2c_ch_init(struct s3c24x0_i2c *i2c, int speed, int slaveadd) { ulong freq, pres = 16, div; -#if (defined CONFIG_EXYNOS4 || defined CONFIG_EXYNOS5) +#if defined(CONFIG_ARCH_EXYNOS4) || defined(CONFIG_ARCH_EXYNOS5) freq = get_i2c_clk(); #else freq = get_PCLK(); diff --git a/include/configs/arndale.h b/include/configs/arndale.h index 5ebba0cda20d..7a244769e30a 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -14,13 +14,9 @@ #include "exynos5250-common.h" #include <configs/exynos5-common.h>
-/* MMC SPL */ -#define CONFIG_EXYNOS_SPL - /* Miscellaneous configurable options */
-#define CONFIG_S5P_PA_SYSRAM 0x02020000 -#define CONFIG_SMP_PEN_ADDR CONFIG_S5P_PA_SYSRAM +#define CONFIG_SMP_PEN_ADDR 0x02020000
/* The PERIPHBASE in the CBAR register is wrong on the Arndale, so override it */ #define CONFIG_ARM_GIC_BASE_ADDRESS 0x10480000 diff --git a/include/configs/espresso7420.h b/include/configs/espresso7420.h index 660d1a080495..2f067a442482 100644 --- a/include/configs/espresso7420.h +++ b/include/configs/espresso7420.h @@ -10,8 +10,6 @@
#include <configs/exynos7420-common.h>
-#define CONFIG_ESPRESSO7420 - #define CONFIG_SYS_SDRAM_BASE 0x40000000
/* DRAM Memory Banks */ diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index cbcef261f432..79860212f403 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -8,10 +8,6 @@ #ifndef __EXYNOS_COMMON_H #define __EXYNOS_COMMON_H
-/* High Level Configuration Options */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P /* S5P Family */ - #include <asm/arch/cpu.h> /* get chip and board defs */ #include <linux/sizes.h> #include <linux/stringify.h> diff --git a/include/configs/exynos4-common.h b/include/configs/exynos4-common.h index 4202c6261262..625a2d8dc185 100644 --- a/include/configs/exynos4-common.h +++ b/include/configs/exynos4-common.h @@ -8,8 +8,6 @@ #ifndef __CONFIG_EXYNOS4_COMMON_H #define __CONFIG_EXYNOS4_COMMON_H
-#define CONFIG_EXYNOS4 /* Exynos4 Family */ - #include "exynos-common.h"
/* SD/MMC configuration */ diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 7ab821d08ca3..44f5cb1e83f4 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -8,15 +8,8 @@ #ifndef __CONFIG_EXYNOS5_COMMON_H #define __CONFIG_EXYNOS5_COMMON_H
-#define CONFIG_EXYNOS5 /* Exynos5 Family */ - #include "exynos-common.h"
-#define CONFIG_EXYNOS_SPL - -/* Enable ACE acceleration for SHA1 and SHA256 */ -#define CONFIG_EXYNOS_ACE_SHA - /* Power Down Modes */ #define S5P_CHECK_SLEEP 0x00000BAD #define S5P_CHECK_DIDLE 0xBAD00000 @@ -31,9 +24,6 @@ /* select serial console configuration */ #define EXYNOS5_DEFAULT_UART_OFFSET 0x010000
-/* Thermal Management Unit */ -#define CONFIG_EXYNOS_TMU - /* MMC SPL */ #define COPY_BL2_FNPTR_ADDR 0x02020030
diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index bcbdfa7ae35a..38f6940a3dbc 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -15,8 +15,6 @@ "stdout=serial,vidconsole\0" \ "stderr=serial,vidconsole\0"
-#define CONFIG_EXYNOS5_DT - #define CONFIG_SYS_SPI_BASE 0x12D30000 #define FLASH_SIZE (4 << 20) #define CONFIG_SPI_BOOTING diff --git a/include/configs/exynos5250-common.h b/include/configs/exynos5250-common.h index 8d91a7de5cde..8e2f135f934c 100644 --- a/include/configs/exynos5250-common.h +++ b/include/configs/exynos5250-common.h @@ -9,8 +9,6 @@ #ifndef __CONFIG_5250_H #define __CONFIG_5250_H
-#define CONFIG_EXYNOS5250 - #define CONFIG_SYS_SDRAM_BASE 0x40000000
/* DRAM Memory Banks */ diff --git a/include/configs/exynos5420-common.h b/include/configs/exynos5420-common.h index 35bf3c2fb4a7..7a9307ccc3db 100644 --- a/include/configs/exynos5420-common.h +++ b/include/configs/exynos5420-common.h @@ -8,19 +8,12 @@ #ifndef __CONFIG_EXYNOS5420_H #define __CONFIG_EXYNOS5420_H
-#define CONFIG_EXYNOS5420 - -#define CONFIG_EXYNOS5_DT - #define CONFIG_VAR_SIZE_SPL
#define CONFIG_IRAM_TOP 0x02074000
#define CONFIG_PHY_IRAM_BASE 0x02020000
-/* Address for relocating helper code (Last 4 KB of IRAM) */ -#define CONFIG_EXYNOS_RELOCATE_CODE_BASE (CONFIG_IRAM_TOP - 0x1000) - /* * Low Power settings */ diff --git a/include/configs/exynos7420-common.h b/include/configs/exynos7420-common.h index e8aed567102e..a8bef860c2f7 100644 --- a/include/configs/exynos7420-common.h +++ b/include/configs/exynos7420-common.h @@ -8,10 +8,6 @@ #ifndef __CONFIG_EXYNOS7420_COMMON_H #define __CONFIG_EXYNOS7420_COMMON_H
-/* High Level Configuration Options */ -#define CONFIG_SAMSUNG /* in a SAMSUNG core */ -#define CONFIG_S5P - #include <asm/arch/cpu.h> /* get chip and board defs */ #include <linux/sizes.h>
diff --git a/include/configs/exynos78x0-common.h b/include/configs/exynos78x0-common.h index 4a2e56b63588..6b1de18bc159 100644 --- a/include/configs/exynos78x0-common.h +++ b/include/configs/exynos78x0-common.h @@ -11,10 +11,6 @@ #ifndef __CONFIG_EXYNOS78x0_COMMON_H #define __CONFIG_EXYNOS78x0_COMMON_H
diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 11a4a409dbaf..fec2d6e62f77 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -146,9 +146,6 @@
/* GPT */
-/* Security subsystem - enable hw_rand() */ -#define CONFIG_EXYNOS_ACE_SHA - /* * Supported Odroid boards: X3, U3 * TODO: Add Odroid X support diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index 476bde53572d..1361f83ffec2 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -28,9 +28,6 @@ #define CONFIG_G_DNL_UMS_VENDOR_NUM 0x0525 #define CONFIG_G_DNL_UMS_PRODUCT_NUM 0xA4A5
-/* FIXME: MUST BE REMOVED AFTER TMU IS TURNED ON */ -#undef CONFIG_EXYNOS_TMU - #define CONFIG_DFU_ALT_SYSTEM \ "uImage fat 0 1;" \ "zImage fat 0 1;" \ diff --git a/include/configs/origen.h b/include/configs/origen.h index 4d296b7a03fb..36aaa7c14fb3 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -10,10 +10,6 @@
#include <configs/exynos4-common.h>
-/* High Level Configuration Options */ -#define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ -#define CONFIG_ORIGEN 1 /* working with ORIGEN*/ - /* ORIGEN has 4 bank of DRAM */ #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index d27116ad1136..8b7e2e5dc9e9 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -10,11 +10,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-/* High Level Configuration Options */ -#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ -#define CONFIG_S5P 1 /* which is in a S5P Family */ -#define CONFIG_S5PC110 1 /* which is in a S5PC110 */ - #include <linux/sizes.h> #include <asm/arch/cpu.h> /* get chip and board defs */
diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index 2f04b077ad35..9a9f3fedff18 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -11,14 +11,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ -#define CONFIG_S5P 1 /* which is in a S5P Family */ -#define CONFIG_S5PC100 1 /* which is in a S5PC100 */ - #include <asm/arch/cpu.h> /* get chip and board defs */
/* input clock of PLL: SMDKC100 has 12MHz input clock */ diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 1367b7d0600a..bb0f5473030d 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -13,8 +13,6 @@ #undef CONFIG_USB_GADGET_DWC2_OTG_PHY
/* High Level Configuration Options */ -#define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ - #define CONFIG_SYS_SDRAM_BASE 0x40000000
/* Handling Sleep Mode*/ diff --git a/include/configs/trats.h b/include/configs/trats.h index 118ceb525010..ee4a583baa82 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -11,8 +11,6 @@
-#define CONFIG_TRATS - #ifndef CONFIG_SYS_L2CACHE_OFF #define CONFIG_SYS_L2_PL310 #define CONFIG_SYS_PL310_BASE 0x10502000 @@ -128,9 +126,6 @@
/* GPT */
-/* Security subsystem - enable hw_rand() */ -#define CONFIG_EXYNOS_ACE_SHA - /* Common misc for Samsung */ #define CONFIG_MISC_COMMON
diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 2d644a8b231d..c5df03a9f54d 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -116,9 +116,6 @@
/* GPT */
diff --git a/include/power/fg_battery_cell_params.h b/include/power/fg_battery_cell_params.h index b8c895bbabb1..500c8ea7174d 100644 --- a/include/power/fg_battery_cell_params.h +++ b/include/power/fg_battery_cell_params.h @@ -7,7 +7,7 @@ #ifndef __FG_BATTERY_CELL_PARAMS_H_ #define __FG_BATTERY_CELL_PARAMS_H_
-#if defined(CONFIG_POWER_FG_MAX17042) && defined(CONFIG_TRATS) +#if defined(CONFIG_POWER_FG_MAX17042) && defined(CONFIG_TARGET_TRATS)
/* Cell characteristics - Exynos4 TRATS development board */ /* Shall be written to addr 0x80h */ diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index c1d32f587911..1cfb8115e310 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -253,7 +253,7 @@ endif
INPUTS-y += $(obj)/$(SPL_BIN).bin $(obj)/$(SPL_BIN).sym
-ifdef CONFIG_SAMSUNG +ifneq ($(CONFIG_ARCH_EXYNOS)$(CONFIG_ARCH_S5PC1XX),) INPUTS-y += $(obj)/$(BOARD)-spl.bin endif
@@ -367,8 +367,8 @@ $(platdata-hdr) $(u-boot-spl-platdata_c) &: $(obj)/$(SPL_BIN).dtb @rm -f $(u-boot-spl-all-platdata_c) $(u-boot-spl-all-platdata) $(call if_changed,dtoc)
-ifdef CONFIG_SAMSUNG -ifdef CONFIG_VAR_SIZE_SPL +ifneq ($(CONFIG_ARCH_EXYNOS)$(CONFIG_ARCH_S5PC1XX),) +ifeq ($(CONFIG_EXYNOS5420),y) VAR_SIZE_PARAM = --vs else VAR_SIZE_PARAM =
Following how it's done for the majority of drivers, add a new VIDEO_EXYNOS option and Kconfig file under drivers/video/exynos and list the current options there.
Cc: Anatolij Gustschin agust@denx.de Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com Signed-off-by: Tom Rini trini@konsulko.com --- It would be good to have help options here, but I don't know the underlying parts, so what to add would be appreciated, or done as a follow-up. On a related note, the drivers themselves should be under something in the top-level MAINTAINERS file as they are not currently. --- configs/peach-pi_defconfig | 3 +++ configs/peach-pit_defconfig | 3 +++ configs/snow_defconfig | 3 +++ configs/spring_defconfig | 3 +++ drivers/video/Kconfig | 2 ++ drivers/video/exynos/Kconfig | 20 ++++++++++++++++++++ include/configs/exynos5-dt-common.h | 7 ------- include/configs/peach-pi.h | 7 ------- include/configs/smdk5250.h | 3 --- include/configs/smdk5420.h | 3 --- include/configs/trats.h | 1 - include/configs/trats2.h | 1 - 12 files changed, 34 insertions(+), 22 deletions(-) create mode 100644 drivers/video/exynos/Kconfig
diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 27be6075661b..d6662e18ab7b 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -84,6 +84,9 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y +CONFIG_VIDEO_EXYNOS=y +CONFIG_EXYNOS_DP=y +CONFIG_EXYNOS_FB=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 296b4ceb195b..07740571c757 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -83,6 +83,9 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y +CONFIG_VIDEO_EXYNOS=y +CONFIG_EXYNOS_DP=y +CONFIG_EXYNOS_FB=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 4377a58130e3..8d1b28dcf8c5 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -94,6 +94,9 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y +CONFIG_VIDEO_EXYNOS=y +CONFIG_EXYNOS_DP=y +CONFIG_EXYNOS_FB=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_VIDEO_BRIDGE_NXP_PTN3460=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index ad017564d994..366790b4efe4 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -95,6 +95,9 @@ CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set CONFIG_VIDCONSOLE_AS_LCD=y CONFIG_DISPLAY=y +CONFIG_VIDEO_EXYNOS=y +CONFIG_EXYNOS_DP=y +CONFIG_EXYNOS_FB=y CONFIG_VIDEO_BRIDGE=y CONFIG_VIDEO_BRIDGE_PARADE_PS862X=y CONFIG_LCD=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 965b5879274e..4ecc158c4605 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -583,6 +583,8 @@ config ATMEL_HLCD
source "drivers/video/ti/Kconfig"
+source "drivers/video/exynos/Kconfig" + config LOGICORE_DP_TX bool "Enable Logicore DP TX driver" depends on DISPLAY diff --git a/drivers/video/exynos/Kconfig b/drivers/video/exynos/Kconfig new file mode 100644 index 000000000000..37e661b1edd2 --- /dev/null +++ b/drivers/video/exynos/Kconfig @@ -0,0 +1,20 @@ + +menuconfig VIDEO_EXYNOS + bool "Enable Exynos video support" + depends on DM_VIDEO + help + Enable support for various video output options on Exynos SoCs. + +if VIDEO_EXYNOS + +config EXYNOS_DP + bool "Exynos Display Port support" + +config EXYNOS_FB + bool "Exynos FIMD support" + +config EXYNOS_MIPI_DSIM + bool "Exynos MIPI DSI support" + depends on EXYNOS_FB + +endif diff --git a/include/configs/exynos5-dt-common.h b/include/configs/exynos5-dt-common.h index 38f6940a3dbc..a94f5a15f0d1 100644 --- a/include/configs/exynos5-dt-common.h +++ b/include/configs/exynos5-dt-common.h @@ -19,11 +19,4 @@ #define FLASH_SIZE (4 << 20) #define CONFIG_SPI_BOOTING
-/* Display */ -#ifdef CONFIG_LCD -#define CONFIG_EXYNOS_FB -#define CONFIG_EXYNOS_DP -#define LCD_BPP LCD_COLOR16 -#endif - #endif diff --git a/include/configs/peach-pi.h b/include/configs/peach-pi.h index ff4180a8331d..7a8d3c63d445 100644 --- a/include/configs/peach-pi.h +++ b/include/configs/peach-pi.h @@ -22,13 +22,6 @@
#define CONFIG_SYS_SDRAM_BASE 0x20000000
-/* Display */ -#ifdef CONFIG_LCD -#define CONFIG_EXYNOS_FB -#define CONFIG_EXYNOS_DP -#define LCD_BPP LCD_COLOR16 -#endif - #define CONFIG_POWER_TPS65090_EC
/* DRAM Memory Banks */ diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index 1ea3b650cd26..c6d2b23197d1 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -12,7 +12,4 @@ #include <configs/exynos5-dt-common.h> #include <configs/exynos5-common.h>
-#undef CONFIG_EXYNOS_FB -#undef CONFIG_EXYNOS_DP - #endif /* __CONFIG_SMDK_H */ diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h index 254d0d91046c..12c2e1f6159a 100644 --- a/include/configs/smdk5420.h +++ b/include/configs/smdk5420.h @@ -12,9 +12,6 @@ #include <configs/exynos5-dt-common.h> #include <configs/exynos5-common.h>
-#undef CONFIG_EXYNOS_FB -#undef CONFIG_EXYNOS_DP - #define CONFIG_SMDK5420 /* which is in a SMDK5420 */
#define CONFIG_SYS_SDRAM_BASE 0x20000000 diff --git a/include/configs/trats.h b/include/configs/trats.h index ee4a583baa82..bca239ae817e 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -150,7 +150,6 @@
/* LCD */ #define CONFIG_FB_ADDR 0x52504000 -#define CONFIG_EXYNOS_MIPI_DSIM #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE ((500 * 160 * 4) + 54)
#endif /* __CONFIG_H */ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index c5df03a9f54d..20bd116c9e3d 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -140,7 +140,6 @@
Dear Tom,
Introduce board/siemens/common/Kconfig and have it hold FACTORYSET to start with. Use select for this on the boards that need it.
Cc: Anatolij Gustschin agust@denx.de Cc: Samuel Egli samuel.egli@siemens.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/Kconfig | 1 + arch/arm/mach-imx/imx8/Kconfig | 2 ++ arch/arm/mach-omap2/am33xx/Kconfig | 6 ++++++ board/siemens/common/Kconfig | 2 ++ include/configs/capricorn-common.h | 2 -- include/configs/draco.h | 2 -- include/configs/etamin.h | 2 -- include/configs/pxm2.h | 2 -- include/configs/rastaban.h | 2 -- include/configs/rut.h | 2 -- include/configs/thuban.h | 2 -- 11 files changed, 11 insertions(+), 14 deletions(-) create mode 100644 board/siemens/common/Kconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index b60b47743e79..4b21955e8e69 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -2331,6 +2331,7 @@ source "board/hisilicon/poplar/Kconfig" source "board/isee/igep003x/Kconfig" source "board/kontron/sl28/Kconfig" source "board/myir/mys_6ulx/Kconfig" +source "board/siemens/common/Kconfig" source "board/seeed/npi_imx6ull/Kconfig" source "board/socionext/developerbox/Kconfig" source "board/st/stv0991/Kconfig" diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index 51c3f21b6e76..2ba7454457dd 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -57,11 +57,13 @@ config TARGET_COLIBRI_IMX8X config TARGET_DENEB bool "Support i.MX8QXP Capricorn Deneb board" select BOARD_LATE_INIT + select FACTORYSET select IMX8QXP
config TARGET_GIEDI bool "Support i.MX8QXP Capricorn Giedi board" select BOARD_LATE_INIT + select FACTORYSET select IMX8QXP
config TARGET_IMX8QM_MEK diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 23865d4c0704..bd6b08655260 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -138,6 +138,7 @@ config TARGET_DRACO select DM select DM_GPIO select DM_SERIAL + select FACTORYSET imply CMD_DM
config TARGET_ETAMIN @@ -146,6 +147,7 @@ config TARGET_ETAMIN select DM select DM_GPIO select DM_SERIAL + select FACTORYSET imply CMD_DM
config TARGET_PCM051 @@ -168,6 +170,7 @@ config TARGET_PXM2 select DM select DM_GPIO select DM_SERIAL + select FACTORYSET imply CMD_DM
config TARGET_RASTABAN @@ -176,6 +179,7 @@ config TARGET_RASTABAN select DM select DM_GPIO select DM_SERIAL + select FACTORYSET imply CMD_DM
config TARGET_RUT @@ -184,6 +188,7 @@ config TARGET_RUT select DM select DM_GPIO select DM_SERIAL + select FACTORYSET imply CMD_DM
config TARGET_THUBAN @@ -192,6 +197,7 @@ config TARGET_THUBAN select DM select DM_GPIO select DM_SERIAL + select FACTORYSET imply CMD_DM
config TARGET_PDU001 diff --git a/board/siemens/common/Kconfig b/board/siemens/common/Kconfig new file mode 100644 index 000000000000..131439fcfeac --- /dev/null +++ b/board/siemens/common/Kconfig @@ -0,0 +1,2 @@ +config FACTORYSET + bool diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index 933fcfcfd287..4ca9e13ecf7a 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -24,8 +24,6 @@
#endif /* CONFIG_SPL_BUILD */
-#define CONFIG_FACTORYSET - /* ENET1 connects to base board and MUX with ESAI */ #define CONFIG_FEC_ENET_DEV 1 #define CONFIG_FEC_MXC_PHYADDR 0x0 diff --git a/include/configs/draco.h b/include/configs/draco.h index d30560810133..b4998f5c2e56 100644 --- a/include/configs/draco.h +++ b/include/configs/draco.h @@ -27,8 +27,6 @@ /* Physical Memory Map */ #define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */
-#define CONFIG_FACTORYSET - /* Define own nand partitions */ #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
diff --git a/include/configs/etamin.h b/include/configs/etamin.h index 654faedf33e9..654bfc612168 100644 --- a/include/configs/etamin.h +++ b/include/configs/etamin.h @@ -75,8 +75,6 @@ #define EEPROM_ADDR_DDR3 0x90 #define EEPROM_ADDR_CHIP 0x120
-#define CONFIG_FACTORYSET - /* nedded by compliance test in read mode */
/* Define own nand partitions */ diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 7272470d12e6..ad05920ad6b1 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -30,8 +30,6 @@ /* Physical Memory Map */ #define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* 1GB */
-#define CONFIG_FACTORYSET - #ifndef CONFIG_SPL_BUILD
/* Use common default */ diff --git a/include/configs/rastaban.h b/include/configs/rastaban.h index 8e20a448d2a7..6c942a809809 100644 --- a/include/configs/rastaban.h +++ b/include/configs/rastaban.h @@ -37,8 +37,6 @@ #define EEPROM_ADDR_DDR3 0x90 #define EEPROM_ADDR_CHIP 0x120
diff --git a/include/configs/rut.h b/include/configs/rut.h index b30b12af52c3..fc3194654ae3 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -21,8 +21,6 @@ /* Physical Memory Map */ #define CONFIG_MAX_RAM_BANK_SIZE (256 << 20) /* 256 MiB */
-#define CONFIG_FACTORYSET - /* Watchdog */ #define WATCHDOG_TRIGGER_GPIO 14
diff --git a/include/configs/thuban.h b/include/configs/thuban.h index 3b120073fef0..bb0b9fa1560d 100644 --- a/include/configs/thuban.h +++ b/include/configs/thuban.h @@ -30,8 +30,6 @@ #define EEPROM_ADDR_DDR3 0x90 #define EEPROM_ADDR_CHIP 0x120
These symbols do not exist in mainline, remove them.
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/capricorn-common.h | 3 --- include/configs/cgtqmx8.h | 4 ---- include/configs/imx8mm-cl-iot-gate.h | 3 --- include/configs/imx8mm_beacon.h | 3 --- include/configs/imx8mm_data_modul_edm_sbc.h | 4 ---- include/configs/imx8mm_evk.h | 3 --- include/configs/imx8mm_icore_mx8mm.h | 2 -- include/configs/imx8mm_venice.h | 3 --- include/configs/imx8mn_beacon.h | 4 ---- include/configs/imx8mn_evk.h | 6 ------ include/configs/imx8mn_venice.h | 5 ----- include/configs/imx8mp_dhcom_pdk2.h | 6 ------ include/configs/imx8mp_evk.h | 2 -- include/configs/imx8mp_rsb3720.h | 2 -- include/configs/imx8mp_venice.h | 5 ----- include/configs/imx8mq_cm.h | 3 --- include/configs/imx8mq_evk.h | 2 -- include/configs/imx8mq_phanbell.h | 2 -- include/configs/imx8qm_mek.h | 4 ---- include/configs/imx8qxp_mek.h | 4 ---- include/configs/imx8ulp_evk.h | 2 -- include/configs/kontron_pitx_imx8m.h | 3 --- include/configs/phycore_imx8mm.h | 2 -- include/configs/phycore_imx8mp.h | 2 -- include/configs/pico-imx8mq.h | 2 -- include/configs/verdin-imx8mm.h | 2 -- include/configs/verdin-imx8mp.h | 2 -- 27 files changed, 85 deletions(-)
diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index 4ca9e13ecf7a..456d1828d629 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -19,9 +19,6 @@
#define CONFIG_MALLOC_F_ADDR 0x00120000
-#define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #endif /* CONFIG_SPL_BUILD */
/* ENET1 connects to base board and MUX with ESAI */ diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index 0266d6988ce1..f53c49db3899 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -16,10 +16,6 @@
#define CONFIG_SERIAL_LPUART_BASE 0x5a060000 #define CONFIG_MALLOC_F_ADDR 0x00120000 - -#define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE - -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
/* Flat Device Tree Definitions */ diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index c559778c1d32..8303c68e369e 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -19,9 +19,6 @@ #ifdef CONFIG_SPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x912000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #endif
/* GUIDs for capsule updatable firmware images */ diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 897eac66b148..131eedac6c5e 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -16,9 +16,6 @@ #ifdef CONFIG_SPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #endif
/* Initial environment variables */ diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index bb19aa292b81..f8af3baef6f4 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -16,10 +16,6 @@
#ifdef CONFIG_SPL_BUILD #define CONFIG_MALLOC_F_ADDR 0x930000 - -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #endif
/* Link Definitions */ diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 983743b50936..d239c926ad5c 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -18,9 +18,6 @@ #ifdef CONFIG_SPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #endif
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index e6642936cba0..f02d6d58c4ad 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -17,8 +17,6 @@ #ifdef CONFIG_SPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ # define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -# define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif /* CONFIG_SPL_BUILD */
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 595c10749668..573af3b7e286 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -16,9 +16,6 @@ #ifdef CONFIG_SPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #endif
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index 99cbc1d07c8f..bfee1e29705e 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -16,10 +16,6 @@ #ifdef CONFIG_SPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x184000 - -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #endif /* CONFIG_SPL_BUILD */
/* Initial environment variables */ diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 73ba49b0d8fb..1b8caba3321c 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -16,12 +16,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - -#endif - #ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index 8565ba7fdb15..a3ba520eb0b5 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -13,11 +13,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE -#endif - #define MEM_LAYOUT_ENV_SETTINGS \ "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "fdt_addr_r=0x50200000\0" \ diff --git a/include/configs/imx8mp_dhcom_pdk2.h b/include/configs/imx8mp_dhcom_pdk2.h index 1ad90e5bdbd9..79db625d0373 100644 --- a/include/configs/imx8mp_dhcom_pdk2.h +++ b/include/configs/imx8mp_dhcom_pdk2.h @@ -14,12 +14,6 @@
#define CONFIG_SYS_MONITOR_LEN SZ_1M
-#ifdef CONFIG_SPL_BUILD -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - -#endif - /* Link Definitions */ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x200000 diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 65c1616bca72..6464d2ff28b3 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -18,8 +18,6 @@ #ifdef CONFIG_SPL_BUILD /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/
-#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #define CONFIG_POWER_PCA9450
#endif diff --git a/include/configs/imx8mp_rsb3720.h b/include/configs/imx8mp_rsb3720.h index efff6b955534..e4ec63c7050d 100644 --- a/include/configs/imx8mp_rsb3720.h +++ b/include/configs/imx8mp_rsb3720.h @@ -32,8 +32,6 @@ * set \ */
-#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #if defined(CONFIG_NAND_BOOT) #define CONFIG_SPL_NAND_MXS #endif diff --git a/include/configs/imx8mp_venice.h b/include/configs/imx8mp_venice.h index e1d335539568..7b30a3a21d7b 100644 --- a/include/configs/imx8mp_venice.h +++ b/include/configs/imx8mp_venice.h @@ -13,11 +13,6 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#ifdef CONFIG_SPL_BUILD -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE -#endif - #define MEM_LAYOUT_ENV_SETTINGS \ "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ "fdt_addr_r=0x50200000\0" \ diff --git a/include/configs/imx8mq_cm.h b/include/configs/imx8mq_cm.h index a242d5e3e8ee..28f61b9fa13e 100644 --- a/include/configs/imx8mq_cm.h +++ b/include/configs/imx8mq_cm.h @@ -19,9 +19,6 @@
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #endif
/* ENET Config */ diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 98ddb06fe337..63bd1955f453 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -20,8 +20,6 @@
#define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index 1b3c0493ebd1..66b3c2091ed3 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -17,8 +17,6 @@
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
/* ENET Config */ diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index f4d19f87312f..8c4402dab5ff 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -17,10 +17,6 @@
#ifdef CONFIG_AHAB_BOOT diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index a6aabc7add70..375079584586 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -15,10 +15,6 @@
#ifdef CONFIG_AHAB_BOOT diff --git a/include/configs/imx8ulp_evk.h b/include/configs/imx8ulp_evk.h index 987069447d53..8c911c925409 100644 --- a/include/configs/imx8ulp_evk.h +++ b/include/configs/imx8ulp_evk.h @@ -16,8 +16,6 @@ #ifdef CONFIG_SPL_BUILD #define CONFIG_MALLOC_F_ADDR 0x22040000
-#define CONFIG_SPL_ABORT_ON_RAW_IMAGE /* For RAW image gives a error info not panic */ - #endif
/* ENET Config */ diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h index 88aaa55bef53..40b1be7058ae 100644 --- a/include/configs/kontron_pitx_imx8m.h +++ b/include/configs/kontron_pitx_imx8m.h @@ -21,9 +21,6 @@
#define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index 1d01104cfe83..36f3adebf423 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -19,8 +19,6 @@ #ifdef CONFIG_SPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index 75ddcf465f9e..467216bf54c7 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -17,8 +17,6 @@ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - #define CONFIG_POWER_PCA9450
#endif diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index 25ad936a06bb..1a43ef2fe2c3 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -17,8 +17,6 @@
/* ENET Config */ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index a93d94dafe4e..846d6566a55a 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -18,8 +18,6 @@ #ifdef CONFIG_SPL_BUILD /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 906a20fd8402..2bbe2b72e0a7 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -18,8 +18,6 @@
/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x184000 -/* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
This converts the following to Kconfig: CONFIG_SYS_MPC85XX_NO_RESETVEC
Signed-off-by: Tom Rini trini@konsulko.com --- README | 5 ----- arch/powerpc/cpu/mpc85xx/Kconfig | 23 ++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 6 ++--- arch/powerpc/cpu/mpc85xx/u-boot.lds | 4 ++-- configs/P1010RDB-PA_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 2 ++ configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PA_NAND_defconfig | 2 ++ configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 2 ++ configs/P1010RDB-PA_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NAND_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 2 ++ configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1010RDB-PB_NAND_defconfig | 2 ++ configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 2 ++ configs/P1010RDB-PB_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 2 ++ configs/P1020RDB-PC_SDCARD_defconfig | 2 ++ configs/P1020RDB-PC_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 2 ++ configs/P1020RDB-PD_SDCARD_defconfig | 2 ++ configs/P1020RDB-PD_SPIFLASH_defconfig | 2 ++ configs/P1020RDB-PD_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 2 ++ configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 2 ++ configs/P2020RDB-PC_SDCARD_defconfig | 2 ++ configs/P2020RDB-PC_SPIFLASH_defconfig | 2 ++ configs/P2020RDB-PC_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 2 ++ configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 2 ++ configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 2 ++ configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 2 ++ configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_revD_NAND_defconfig | 2 ++ configs/T2080RDB_revD_SDCARD_defconfig | 1 + configs/T2080RDB_revD_SPIFLASH_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + include/configs/P1010RDB.h | 7 ------ include/configs/T102xRDB.h | 9 -------- include/configs/T104xRDB.h | 9 -------- include/configs/T208xQDS.h | 9 -------- include/configs/T208xRDB.h | 9 -------- include/configs/T4240RDB.h | 3 --- include/configs/p1_p2_rdb_pc.h | 7 ------ include/configs/qemu-ppce500.h | 2 -- scripts/config_whitelist.txt | 1 - 66 files changed, 113 insertions(+), 66 deletions(-)
diff --git a/README b/README index c95f4334199e..841f8ce082c0 100644 --- a/README +++ b/README @@ -2164,11 +2164,6 @@ Low Level (hardware related) configuration options: proper). Code that needs stage-specific behavior should check this.
-- CONFIG_SYS_MPC85XX_NO_RESETVEC - Only for 85xx systems. If this variable is specified, the section - .resetvec is not kept and the section .bootpg is placed in the - previous 4k of the .text section. - - CONFIG_ARCH_MAP_SYSMEM Generally U-Boot (and in particular the md command) uses effective address. It is therefore not necessary to regard diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index c1b4e94d9191..02efa1c60301 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -1185,6 +1185,29 @@ config SYS_FSL_LBC_CLK_DIV Defines divider of platform clock(clock input to eLBC controller).
+config SYS_MPC85XX_NO_RESETVEC + bool "Discard resetvec section and move bootpg section up" + depends on MPC85xx + help + If this variable is specified, the section .resetvec is not kept and + the section .bootpg is placed in the previous 4k of the .text section. + +config SPL_SYS_MPC85XX_NO_RESETVEC + bool "Discard resetvec section and move bootpg section up, in SPL" + depends on MPC85xx && SPL + help + If this variable is specified, the section .resetvec is not kept and + the section .bootpg is placed in the previous 4k of the .text section, + of the SPL portion of the binary. + +config TPL_SYS_MPC85XX_NO_RESETVEC + bool "Discard resetvec section and move bootpg section up, in TPL" + depends on MPC85xx && TPL + help + If this variable is specified, the section .resetvec is not kept and + the section .bootpg is placed in the previous 4k of the .text section, + of the SPL portion of the binary. + config FSL_VIA bool
diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds index 1b4d1e05a4a3..60628c4187a3 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds @@ -9,7 +9,7 @@ #include "config.h"
OUTPUT_ARCH(powerpc) -#ifdef CONFIG_SYS_MPC85XX_NO_RESETVEC +#if CONFIG_IS_ENABLED(SYS_MPC85XX_NO_RESETVEC) PHDRS { text PT_LOAD; @@ -19,7 +19,7 @@ PHDRS SECTIONS { /* For ifc, elbc, esdhc, espi, all need the SPL without section .resetvec */ -#ifdef CONFIG_SYS_MPC85XX_NO_RESETVEC +#if CONFIG_IS_ENABLED(SYS_MPC85XX_NO_RESETVEC) .bootpg IMAGE_TEXT_BASE - 0x1000 : { KEEP(*(.bootpg)) @@ -75,7 +75,7 @@ SECTIONS #endif
/* For nor and nand is needed the SPL with section .resetvec */ -#ifndef CONFIG_SYS_MPC85XX_NO_RESETVEC +#if !CONFIG_IS_ENABLED(SYS_MPC85XX_NO_RESETVEC) #if defined(CONFIG_FSL_IFC) /* Restrict bootpg at 4K boundry for IFC */ #ifndef BOOT_PAGE_OFFSET #define BOOT_PAGE_OFFSET 0x1000 diff --git a/arch/powerpc/cpu/mpc85xx/u-boot.lds b/arch/powerpc/cpu/mpc85xx/u-boot.lds index e1bbee43bcb4..ee5cbe57f431 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot.lds @@ -23,7 +23,7 @@ PHDRS SECTIONS { /* Read-only sections, merged into text segment: */ -#ifdef CONFIG_SYS_MPC85XX_NO_RESETVEC +#if CONFIG_IS_ENABLED(SYS_MPC85XX_NO_RESETVEC) .bootpg CONFIG_SYS_TEXT_BASE - 0x1000 : { KEEP(arch/powerpc/cpu/mpc85xx/start.o (.bootpg)) @@ -84,7 +84,7 @@ SECTIONS __init_end = .; _end = .;
-#ifndef CONFIG_SYS_MPC85XX_NO_RESETVEC +#if !CONFIG_IS_ENABLED(SYS_MPC85XX_NO_RESETVEC) .bootpg RESET_VECTOR_ADDRESS - 0xffc : { arch/powerpc/cpu/mpc85xx/start.o (.bootpg) diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 85fa20534637..4ebb8d06cdd3 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 1972f140f90d..6783f1ffb35e 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_ADDR=0xEFF20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index b057d1fad3d8..40dd02cf8f9c 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index da5041068af3..30998e8ac72e 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index b5ec62d3f9ae..9ab41e80a278 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 2e3dc8f5e701..a31b2c2f0d7c 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_ADDR=0xEFF20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index ed63b5e936ba..5ad69a1e633b 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 4c22687db87b..4b3ac2403f6b 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PA=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 4291cbf9c233..e2abe92e7a6b 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 367632894b1c..505c168c97a6 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_ADDR=0xEFF20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 7182e0b33077..d2c99053d781 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 45ef797b89fd..62d36584610f 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 5e052733f57f..f27a24b7a18e 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 2cd571443da6..b4b145377679 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_ADDR=0xEFF20000 CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index d8e872bd6d0e..30a1f2436b04 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index b9887e3e3e2f..74c280c1b453 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_MPC85xx=y CONFIG_TARGET_P1010RDB_PB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 51d4510d7388..96a79927b535 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index ec5c8a7821ec..036482b53f7a 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 3da39efb4375..a4936777ad0b 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_SPI=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index b9632026a271..89b34e6585cd 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -10,6 +10,7 @@ CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 27d155dea74d..27a8653c4ec9 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index e3068f5f0ce6..238e450f2e5a 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index c0e8ab8042df..92f8209f024b 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_SPI=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 5c6d27ade4e7..78f186bdca8b 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -10,6 +10,7 @@ CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PC=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index a6b9e047e6d1..68034b1febd8 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PD=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 84be176fb41c..a5c1fce82a47 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PD=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index ded22f273b22..2f57f51ad7b2 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_SPI=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PD=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 8b90ac554156..01290b3a7b0a 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -10,6 +10,7 @@ CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P1020RDB_PD=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index ec1a07945596..1401009fb62b 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 6c5c064db3b5..0706350fa7f5 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index e6a00a737acd..bca22f947b18 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_SPI=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 73b626879242..a88eb2e81831 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -10,6 +10,7 @@ CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_PHYS_64BIT=y CONFIG_MP=y CONFIG_FIT=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 0d213054bf6b..627c2ab18673 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_TPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 190d6ceb4b36..8b4bcf920b9b 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -14,6 +14,8 @@ CONFIG_SPL=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 61763b50b83a..208e09b4568f 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -16,6 +16,8 @@ CONFIG_SPL_SPI=y CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index dd92833f6b63..11e1fcfc8bac 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -10,6 +10,7 @@ CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_P2020RDB=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 2eb985823ec0..c33db8330075 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -12,6 +12,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 9daf7fd5ef77..8796db6b635e 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -13,6 +13,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index ee9292a4fb9f..63b655917712 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -15,6 +15,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_MPC85xx=y CONFIG_TARGET_T1024RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 91a83007ce87..6254c8f4e154 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -11,6 +11,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 32fed7a33a4a..eb756c8adbe7 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -12,6 +12,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 638ed7147a72..b5ce93e715a0 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -14,6 +14,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_MPC85xx=y CONFIG_TARGET_T1042D4RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 6f3af93e8832..417f7ea83dda 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -18,6 +18,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 4314c924fac2..6da6a173bd95 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 9d275b75fed8..36f6761f8715 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 80c7b18634c6..d0542b65de41 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 80b33a9ed5b1..a3007cb4d138 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 810eea042d94..b3973e151d77 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 CONFIG_MP=y diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 2a68163b5685..2bc8f56b302d 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -15,6 +15,8 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y +CONFIG_SPL_SYS_MPC85XX_NO_RESETVEC=y CONFIG_T2080RDB_REV_D=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index a9af2951cb9b..97460205cb95 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_T2080RDB_REV_D=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index a3cda0da8050..ba836be355dd 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -18,6 +18,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_T2080RDB_REV_D=y CONFIG_SYS_MEMTEST_START=0x00200000 CONFIG_SYS_MEMTEST_END=0x00400000 diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index 2bc568939360..63fb7145c9aa 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_MPC85xx=y CONFIG_TARGET_T4240RDB=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_MP=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index 322fe12ae9a7..7d35d058a7df 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -6,6 +6,7 @@ CONFIG_SYS_CLK_FREQ=33000000 CONFIG_MPC85xx=y # CONFIG_CMD_ERRATA is not set CONFIG_TARGET_QEMU_PPCE500=y +CONFIG_SYS_MPC85XX_NO_RESETVEC=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_STDOUT_VIA_ALIAS=y diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index fce4bfb3dd93..27361f2d447f 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -20,7 +20,6 @@ #define CONFIG_SYS_MMC_U_BOOT_DST (0x11000000) #define CONFIG_SYS_MMC_U_BOOT_START (0x11000000) #define CONFIG_SYS_MMC_U_BOOT_OFFS (96 << 10) -#define CONFIG_SYS_MPC85XX_NO_RESETVEC #endif
#ifdef CONFIG_SPIFLASH @@ -32,7 +31,6 @@ #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x11000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x11000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (96 << 10) -#define CONFIG_SYS_MPC85XX_NO_RESETVEC #endif #endif
@@ -43,7 +41,6 @@ #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 #else #ifdef CONFIG_TPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC #define CONFIG_SYS_NAND_U_BOOT_SIZE (576 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST (0x11000000) #define CONFIG_SYS_NAND_U_BOOT_START (0x11000000) @@ -51,10 +48,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0xD0000000 #define CONFIG_SYS_NAND_U_BOOT_START 0xD0000000 -#else -#ifndef CONFIG_MPC85XX_HAVE_RESET_VECTOR -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif #endif #endif diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index b412438116df..bd458ff35e9a 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -28,9 +28,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x30000000 #define CONFIG_SYS_NAND_U_BOOT_START 0x30000000 -#ifndef CONFIG_MPC85XX_HAVE_RESET_VECTOR -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#ifdef CONFIG_SPIFLASH @@ -39,9 +36,6 @@ #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x30000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x30000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (256 << 10) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#ifdef CONFIG_SDCARD @@ -50,9 +44,6 @@ #define CONFIG_SYS_MMC_U_BOOT_DST (0x30000000) #define CONFIG_SYS_MMC_U_BOOT_START (0x30000000) #define CONFIG_SYS_MMC_U_BOOT_OFFS (260 << 10) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#endif /* CONFIG_RAMBOOT_PBL */ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 767c360b36c0..505bae931e6b 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -32,9 +32,6 @@ #endif #define CONFIG_SYS_NAND_U_BOOT_DST 0x30000000 #define CONFIG_SYS_NAND_U_BOOT_START 0x30000000 -#ifndef CONFIG_MPC85XX_HAVE_RESET_VECTOR -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#ifdef CONFIG_SPIFLASH @@ -43,9 +40,6 @@ #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x30000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x30000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (256 << 10) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#ifdef CONFIG_SDCARD @@ -54,9 +48,6 @@ #define CONFIG_SYS_MMC_U_BOOT_DST (0x30000000) #define CONFIG_SYS_MMC_U_BOOT_START (0x30000000) #define CONFIG_SYS_MMC_U_BOOT_OFFS (260 << 10) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#endif diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 55b9260d9317..2db2b07fb4b7 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -35,9 +35,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x00200000 #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 -#ifndef CONFIG_MPC85XX_HAVE_RESET_VECTOR -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#ifdef CONFIG_SPIFLASH @@ -46,9 +43,6 @@ #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x00200000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x00200000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (256 << 10) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#ifdef CONFIG_SDCARD @@ -57,9 +51,6 @@ #define CONFIG_SYS_MMC_U_BOOT_DST (0x00200000) #define CONFIG_SYS_MMC_U_BOOT_START (0x00200000) #define CONFIG_SYS_MMC_U_BOOT_OFFS (260 << 10) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#endif /* CONFIG_RAMBOOT_PBL */ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 642099bd098d..07e1108f0f04 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -30,9 +30,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x00200000 #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 -#ifndef CONFIG_MPC85XX_HAVE_RESET_VECTOR -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#ifdef CONFIG_SPIFLASH @@ -41,9 +38,6 @@ #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x00200000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x00200000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (256 << 10) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#ifdef CONFIG_SDCARD @@ -52,9 +46,6 @@ #define CONFIG_SYS_MMC_U_BOOT_DST (0x00200000) #define CONFIG_SYS_MMC_U_BOOT_START (0x00200000) #define CONFIG_SYS_MMC_U_BOOT_OFFS (260 << 10) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#endif /* CONFIG_RAMBOOT_PBL */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 757fb054a807..526d40fa0349 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -30,9 +30,6 @@ #define CONFIG_SYS_MMC_U_BOOT_DST 0x00200000 #define CONFIG_SYS_MMC_U_BOOT_START 0x00200000 #define CONFIG_SYS_MMC_U_BOOT_OFFS (260 << 10) -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif
#endif diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 202697ec646f..81bebff6cf76 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -81,16 +81,13 @@ #define CONFIG_SYS_MMC_U_BOOT_DST (0x11000000) #define CONFIG_SYS_MMC_U_BOOT_START (0x11000000) #define CONFIG_SYS_MMC_U_BOOT_OFFS (128 << 10) -#define CONFIG_SYS_MPC85XX_NO_RESETVEC #elif defined(CONFIG_SPIFLASH) #define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (768 << 10) #define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x11000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x11000000) #define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (128 << 10) -#define CONFIG_SYS_MPC85XX_NO_RESETVEC #elif defined(CONFIG_MTD_RAW_NAND) #ifdef CONFIG_TPL_BUILD -#define CONFIG_SYS_MPC85XX_NO_RESETVEC #define CONFIG_SYS_NAND_U_BOOT_SIZE (832 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST (0x11000000) #define CONFIG_SYS_NAND_U_BOOT_START (0x11000000) @@ -98,10 +95,6 @@ #define CONFIG_SYS_NAND_U_BOOT_SIZE (128 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0xf8f80000 #define CONFIG_SYS_NAND_U_BOOT_START 0xf8f80000 -#else -#ifndef CONFIG_MPC85XX_HAVE_RESET_VECTOR -#define CONFIG_SYS_MPC85XX_NO_RESETVEC -#endif #endif /* not CONFIG_TPL_BUILD */ #endif
diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index e427b854fced..c3fef0de173b 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -9,8 +9,6 @@ #ifndef __QEMU_PPCE500_H #define __QEMU_PPCE500_H
-#define CONFIG_SYS_MPC85XX_NO_RESETVEC - #define CONFIG_SYS_RAMBOOT
#define CONFIG_ENABLE_36BIT_PHYS diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index a2a02e5db67f..8d67e98372e3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1198,7 +1198,6 @@ CONFIG_SYS_MPC83xx_DMA_ADDR CONFIG_SYS_MPC83xx_DMA_OFFSET CONFIG_SYS_MPC83xx_ESDHC_ADDR CONFIG_SYS_MPC83xx_ESDHC_OFFSET -CONFIG_SYS_MPC85XX_NO_RESETVEC CONFIG_SYS_MPC85xx_DMA CONFIG_SYS_MPC85xx_DMA1_OFFSET CONFIG_SYS_MPC85xx_DMA2_OFFSET
With the exception of how PowerPC handles SPL and TPL (which has its own issues), we cannot safely hide options under CONFIG_SPL_BUILD. Largely remove the places that have this test today.
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/am335x_igep003x.h | 2 -- include/configs/am335x_sl50.h | 4 ---- include/configs/apalis_imx6.h | 4 ---- include/configs/baltos.h | 2 -- include/configs/brppt1.h | 2 -- include/configs/brsmarc1.h | 3 --- include/configs/brxre1.h | 3 --- include/configs/capricorn-common.h | 3 --- include/configs/clearfog.h | 6 ------ include/configs/cm_fx6.h | 6 ------ include/configs/cm_t335.h | 4 ---- include/configs/colibri_imx6.h | 4 ---- include/configs/controlcenterdc.h | 2 -- include/configs/da850evm.h | 2 -- include/configs/db-88f6820-amc.h | 2 -- include/configs/db-88f6820-gp.h | 2 -- include/configs/db-mv784mp-gp.h | 2 -- include/configs/dh_imx6.h | 2 -- include/configs/draco.h | 6 ------ include/configs/dragonboard820c.h | 2 -- include/configs/ds414.h | 2 -- include/configs/helios4.h | 6 ------ include/configs/imx6dl-mamoj.h | 2 -- include/configs/imx8mm_data_modul_edm_sbc.h | 4 ---- include/configs/imx8mm_evk.h | 2 -- include/configs/imx8mm_icore_mx8mm.h | 4 ---- include/configs/imx8mm_venice.h | 4 ---- include/configs/imx8mn_evk.h | 2 -- include/configs/imx8mn_venice.h | 4 ---- include/configs/imx8mp_dhcom_pdk2.h | 4 ---- include/configs/imx8mp_evk.h | 2 -- include/configs/imx8mp_venice.h | 4 ---- include/configs/imx8mq_cm.h | 2 -- include/configs/imx8mq_evk.h | 2 -- include/configs/iot2050.h | 4 ---- include/configs/kontron-sl-mx6ul.h | 4 ---- include/configs/kontron-sl-mx8mm.h | 4 ---- include/configs/kp_imx6q_tpc.h | 2 -- include/configs/kylin_rk3036.h | 6 ------ include/configs/ls1012a_common.h | 2 -- include/configs/ls1012afrdm.h | 2 -- include/configs/ls1012afrwy.h | 2 -- include/configs/ls1043a_common.h | 2 -- include/configs/ls1046a_common.h | 2 -- include/configs/ls1046afrwy.h | 2 -- include/configs/ls2080aqds.h | 2 +- include/configs/mx6cuboxi.h | 5 ----- include/configs/mx6sxsabresd.h | 4 ---- include/configs/mx6ul_14x14_evk.h | 4 ---- include/configs/novena.h | 5 ----- include/configs/omap3_igep00x0.h | 4 ---- include/configs/opos6uldev.h | 4 ---- include/configs/pdu001.h | 2 -- include/configs/pomelo.h | 2 -- include/configs/poplar.h | 2 -- include/configs/px30_common.h | 4 ---- include/configs/pxm2.h | 7 ------- include/configs/qemu-riscv.h | 2 -- include/configs/rastaban.h | 6 ------ include/configs/rk3036_common.h | 3 --- include/configs/rk3066_common.h | 4 ---- include/configs/rk3128_common.h | 4 ---- include/configs/rk3188_common.h | 3 --- include/configs/rk322x_common.h | 3 --- include/configs/rk3288_common.h | 3 --- include/configs/rk3308_common.h | 4 ---- include/configs/rk3328_common.h | 4 ---- include/configs/rk3368_common.h | 3 --- include/configs/rk3568_common.h | 2 -- include/configs/rut.h | 8 -------- include/configs/rv1108_common.h | 3 +-- include/configs/sandbox.h | 2 -- include/configs/siemens-am33x-common.h | 6 ------ include/configs/sifive-unleashed.h | 2 -- include/configs/sifive-unmatched.h | 2 -- include/configs/smartweb.h | 2 -- include/configs/socfpga_soc64_common.h | 15 --------------- include/configs/sunxi-common.h | 6 ------ include/configs/synquacer.h | 4 ---- include/configs/taurus.h | 6 ------ include/configs/tegra-common-post.h | 5 ----- include/configs/thuban.h | 6 ------ include/configs/ti_omap4_common.h | 2 -- include/configs/uniphier.h | 4 ---- include/configs/verdin-imx8mm.h | 4 ---- include/configs/verdin-imx8mp.h | 4 ---- include/configs/x530.h | 2 -- include/configs/xilinx_zynqmp.h | 2 -- 88 files changed, 2 insertions(+), 308 deletions(-)
diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index 2cf77a67c0c2..8d36ddeba596 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -20,7 +20,6 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ "bootdir=/boot\0" \ @@ -89,7 +88,6 @@ "setenv fdtfile am335x-igep-base0040-lite.dtb; fi; " \ "if test ${fdtfile} = ''; then " \ "echo WARNING: Could not determine device tree to use; fi; \0" -#endif
/* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* UART0 */ diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index a57d551bcf17..79d9d03a176b 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -16,8 +16,6 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#ifndef CONFIG_SPL_BUILD - #define MEM_LAYOUT_ENV_SETTINGS \ "scriptaddr=0x80000000\0" \ "pxefile_addr_r=0x80100000\0" \ @@ -39,8 +37,6 @@ MEM_LAYOUT_ENV_SETTINGS \ BOOTENV
-#endif - /* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */ #define CONFIG_SYS_NS16550_COM2 0x48022000 /* UART1 */ diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 5db8b2be2cb8..7767fce4050e 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -48,7 +48,6 @@ #undef CONFIG_SERVERIP #define CONFIG_SERVERIP 192.168.10.1
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 2) \ @@ -58,9 +57,6 @@ #include <config_distro_bootcmd.h> #undef BOOTENV_RUN_NET_USB_START #define BOOTENV_RUN_NET_USB_START "" -#else /* CONFIG_SPL_BUILD */ -#define BOOTENV -#endif /* CONFIG_SPL_BUILD */
#define UBOOT_UPDATE \ "uboot_hwpart=1\0" \ diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 7b43741fde7c..1abda0836ab6 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -52,7 +52,6 @@ #define NANDARGS "" #endif
-#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ "boot_fdt=try\0" \ @@ -183,7 +182,6 @@ "findfdt=setenv fdtfile am335x-baltos.dtb\0" \ NANDARGS /*DFUARGS*/ -#endif
/* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */ diff --git a/include/configs/brppt1.h b/include/configs/brppt1.h index 12a4048a511c..440571a799e5 100644 --- a/include/configs/brppt1.h +++ b/include/configs/brppt1.h @@ -99,7 +99,6 @@ MMCSPI_TGTS \
#define LOAD_OFFSET(x) 0x8##x
-#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ BUR_COMMON_ENV \ "verify=no\0" \ @@ -123,7 +122,6 @@ NANDTGTS \ "b_default=run b_deftgts; for target in ${b_tgts};"\ " do echo "### booting ${target} ###"; run b_${target};" \ " if test ${b_break} = 1; then; exit; fi; done\0" -#endif /* !CONFIG_SPL_BUILD*/
#ifdef CONFIG_MTD_RAW_NAND /* diff --git a/include/configs/brsmarc1.h b/include/configs/brsmarc1.h index f1e6dbf61358..eccf16fdb7a1 100644 --- a/include/configs/brsmarc1.h +++ b/include/configs/brsmarc1.h @@ -24,8 +24,6 @@ #define V_OSCK 26000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#ifndef CONFIG_SPL_BUILD - /* Default environment */ #define CONFIG_EXTRA_ENV_SETTINGS \ BUR_COMMON_ENV \ @@ -56,7 +54,6 @@ BUR_COMMON_ENV \ " fdt boardsetup\0" \ "startsys=run vxargs && mw 0x80001100 0 && run vxfdt &&" \ " bootm ${loadaddr} - ${dtbaddr}\0" -#endif /* !CONFIG_SPL_BUILD*/
/* SPI Flash */
diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index d34d69778f1b..b4e8d73db05a 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -23,8 +23,6 @@ #define V_OSCK 26000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#ifndef CONFIG_SPL_BUILD - /* Default environment */ #define CONFIG_EXTRA_ENV_SETTINGS \ BUR_COMMON_ENV \ @@ -51,7 +49,6 @@ BUR_COMMON_ENV \ "b_usb0=usb start && load usb 0 ${scradr} usbscript.img && source ${scradr}\0" \ "b_default=run b_deftgts; for target in ${b_tgts};"\ " do run b_${target}; if test ${b_break} = 1; then; exit; fi; done\0" -#endif /* !CONFIG_SPL_BUILD*/
/* Environment */
diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index 456d1828d629..6b1e82ad3b17 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -25,15 +25,12 @@ #define CONFIG_FEC_ENET_DEV 1 #define CONFIG_FEC_MXC_PHYADDR 0x0
-/* I2C Configuration */ -#ifndef CONFIG_SPL_BUILD /* EEPROM */ #define EEPROM_I2C_BUS 0 /* I2C0 */ #define EEPROM_I2C_ADDR 0x50 /* PCA9552 */ #define PCA9552_1_I2C_BUS 1 /* I2C1 */ #define PCA9552_1_I2C_ADDR 0x60 -#endif /* !CONFIG_SPL_BUILD */
/* AHAB */ #ifdef CONFIG_AHAB_BOOT diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 8497fe28effe..af04352eda3b 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -31,9 +31,7 @@ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* PCIe support */ -#ifndef CONFIG_SPL_BUILD #define CONFIG_PCI_SCAN_SHOW -#endif
/* Keep device tree and initrd in lower memory so the kernel can access them */ #define RELOCATION_LIMITS_ENV_SETTINGS \ @@ -47,8 +45,6 @@ #include "mv-common.h"
/* Include the common distro boot environment */ -#ifndef CONFIG_SPL_BUILD - #ifdef CONFIG_MMC #define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) #else @@ -125,6 +121,4 @@ "console=ttyS0,115200\0" \ BOOTENV
-#endif /* CONFIG_SPL_BUILD */ - #endif /* _CONFIG_CLEARFOG_H */ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index fbe1e35e001a..02935430c25e 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -30,7 +30,6 @@
/* Environment */
-#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ @@ -130,16 +129,11 @@ func(SATA, sata, 0)
#include <config_distro_bootcmd.h> -#else -#define CONFIG_EXTRA_ENV_SETTINGS -#endif
/* NAND */ -#ifndef CONFIG_SPL_BUILD #define CONFIG_SYS_NAND_BASE 0x40000000 #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* APBH DMA is required for NAND support */ -#endif
/* Ethernet */ #define CONFIG_FEC_MXC_PHYADDR 0 diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index b3ccc3cac3da..b2bec10960aa 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -19,7 +19,6 @@ #define V_OSCK 25000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#ifndef CONFIG_SPL_BUILD #define MMCARGS \ "mmcdev=0\0" \ "mmcroot=/dev/mmcblk0p2 rw rootwait\0" \ @@ -55,7 +54,6 @@ "loaduimage=fatload mmc ${mmcdev} ${loadaddr} uImage\0" \ MMCARGS \ NANDARGS -#endif /* CONFIG_SPL_BUILD */
#define CONFIG_SYS_AUTOLOAD "no"
@@ -95,7 +93,6 @@
/* EEPROM */
-#ifndef CONFIG_SPL_BUILD /* * Enable PCA9555 at I2C0-0x26. * First select the I2C0 bus with "i2c dev 0", then use "pca953x" command. @@ -103,6 +100,5 @@ #define CONFIG_PCA953X #define CONFIG_SYS_I2C_PCA953X_ADDR 0x26 #define CONFIG_SYS_I2C_PCA953X_WIDTH { {0x26, 16} } -#endif /* CONFIG_SPL_BUILD */
#endif /* __CONFIG_CM_T335_H */ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index f62a3f6688ed..0d8922bc3f83 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -45,7 +45,6 @@ #undef CONFIG_SERVERIP #define CONFIG_SERVERIP 192.168.10.1
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \ @@ -54,9 +53,6 @@ #include <config_distro_bootcmd.h> #undef BOOTENV_RUN_NET_USB_START #define BOOTENV_RUN_NET_USB_START "" -#else /* CONFIG_SPL_BUILD */ -#define BOOTENV -#endif /* CONFIG_SPL_BUILD */
#define UBOOT_UPDATE \ "uboot_hwpart=1\0" \ diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index d1bea54b207e..bb1595f96111 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -18,9 +18,7 @@ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* * Environment Configuration diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 71ebca587d14..1f6ac8d28adf 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -101,9 +101,7 @@ /* * I2C Configuration */ -#ifndef CONFIG_SPL_BUILD #define CONFIG_SYS_I2C_EXPANDER_ADDR 0x20 -#endif
/* * Flash & Environment diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 3c442018ab1d..6912f39d32d2 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -15,9 +15,7 @@ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* NAND */
diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index 6b2edbb1e0d3..3b3a7abd281f 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -18,9 +18,7 @@ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* Keep device tree and initrd in lower memory so the kernel can access them */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index b4cfa61d4e75..da6514b64fc9 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -23,9 +23,7 @@ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* NAND */
diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 6fe45a86dcc0..0c0abe6023e8 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -52,7 +52,6 @@ #endif #endif
-#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200\0" \ "fdt_addr=0x18000000\0" \ @@ -77,7 +76,6 @@ func(DHCP, dhcp, na)
#include <config_distro_bootcmd.h> -#endif
/* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR diff --git a/include/configs/draco.h b/include/configs/draco.h index b4998f5c2e56..21367f0a6f5e 100644 --- a/include/configs/draco.h +++ b/include/configs/draco.h @@ -30,8 +30,6 @@ /* Define own nand partitions */ #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
-#ifndef CONFIG_SPL_BUILD - /* Default env settings */ #define CONFIG_EXTRA_ENV_SETTINGS \ "hostname=draco\0" \ @@ -43,8 +41,4 @@ CONFIG_ENV_SETTINGS_V2 \ CONFIG_ENV_SETTINGS_NAND_V2
-#ifndef CONFIG_RESTORE_FLASH -/* set to negative value for no autoboot */ -#endif -#endif /* CONFIG_SPL_BUILD */ #endif /* ! __CONFIG_DRACO_H */ diff --git a/include/configs/dragonboard820c.h b/include/configs/dragonboard820c.h index e3940dc3217c..705146d04f76 100644 --- a/include/configs/dragonboard820c.h +++ b/include/configs/dragonboard820c.h @@ -22,9 +22,7 @@ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_BOOTM_LEN SZ_64M
-#ifndef CONFIG_SPL_BUILD #include <config_distro_bootcmd.h> -#endif
#define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) diff --git a/include/configs/ds414.h b/include/configs/ds414.h index 7fa1a4ebf020..7e3f657e31cc 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -20,9 +20,7 @@ #define CONFIG_I2C_MVTWSI_BASE0 MVEBU_TWSI_BASE
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/helios4.h b/include/configs/helios4.h index 23eb0d4375df..cae20073584c 100644 --- a/include/configs/helios4.h +++ b/include/configs/helios4.h @@ -31,9 +31,7 @@ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* Include the common distro boot environment */ -#ifndef CONFIG_SPL_BUILD - #ifdef CONFIG_MMC #define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) #else @@ -126,6 +122,4 @@ "console=ttyS0,115200\0" \ BOOTENV
-#endif /* CONFIG_SPL_BUILD */ - #endif /* _CONFIG_HELIOS4_H */ diff --git a/include/configs/imx6dl-mamoj.h b/include/configs/imx6dl-mamoj.h index 2707ae644067..0bae238a4b03 100644 --- a/include/configs/imx6dl-mamoj.h +++ b/include/configs/imx6dl-mamoj.h @@ -20,7 +20,6 @@ /* Environment in MMC */ #endif
-#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ "scriptaddr=0x14000000\0" \ "fdt_addr_r=0x13000000\0" \ @@ -34,7 +33,6 @@ func(MMC, mmc, 2)
/* UART */ #define CONFIG_MXC_UART_BASE UART3_BASE diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index f8af3baef6f4..e8f56b0759aa 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -35,8 +35,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-#if !defined(CONFIG_SPL_BUILD) - #define CONFIG_EXTRA_ENV_SETTINGS \ "altbootcmd=setenv devpart 2 && run bootcmd ; reset\0" \ "bootlimit=3\0" \ @@ -102,5 +100,3 @@ "fi"
#endif - -#endif diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index d239c926ad5c..fbbc3ab30058 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -20,14 +20,12 @@ #define CONFIG_MALLOC_F_ADDR 0x930000 #endif
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 2) \ func(DHCP, dhcp, na)
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index f02d6d58c4ad..dc7756e0c610 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -19,14 +19,10 @@ # define CONFIG_MALLOC_F_ADDR 0x930000 #endif /* CONFIG_SPL_BUILD */
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 2) \ func(MMC, mmc, 0) #include <config_distro_bootcmd.h> -#else -#define BOOTENV -#endif
#define ENV_MEM_LAYOUT_SETTINGS \ "fdt_addr_r=0x44000000\0" \ diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 573af3b7e286..9d3ecd51ccda 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -26,7 +26,6 @@ "kernel_comp_addr_r=0x40200000\0"
/* Enable Distro Boot */ -#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 2) \ @@ -34,9 +33,6 @@ func(USB, usb, 1) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> -#else -#define BOOTENV -#endif
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 1b8caba3321c..f6889d4676db 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -16,14 +16,12 @@ #define CONFIG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
/* Initial environment variables */ /* see include/configs/ti_armv7_common.h */ diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index a3ba520eb0b5..0103d7df6131 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -21,16 +21,12 @@ "kernel_comp_addr_r=0x40200000\0"
/* Enable Distro Boot */ -#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 2) \ func(USB, usb, 0) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> -#else -#define BOOTENV -#endif
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/imx8mp_dhcom_pdk2.h b/include/configs/imx8mp_dhcom_pdk2.h index 79db625d0373..797ea0c7fad2 100644 --- a/include/configs/imx8mp_dhcom_pdk2.h +++ b/include/configs/imx8mp_dhcom_pdk2.h @@ -32,8 +32,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-#if !defined(CONFIG_SPL_BUILD) - #define CONFIG_EXTRA_ENV_SETTINGS \ "altbootcmd=run bootcmd ; reset\0" \ "bootlimit=3\0" \ @@ -85,5 +83,3 @@ #include <config_distro_bootcmd.h>
#endif - -#endif diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 6464d2ff28b3..206f5c2fb353 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -31,13 +31,11 @@
#endif
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/imx8mp_venice.h b/include/configs/imx8mp_venice.h index 7b30a3a21d7b..c9a2cefcd632 100644 --- a/include/configs/imx8mp_venice.h +++ b/include/configs/imx8mp_venice.h @@ -21,16 +21,12 @@ "kernel_comp_addr_r=0x40200000\0"
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/imx8mq_cm.h b/include/configs/imx8mq_cm.h index 28f61b9fa13e..96e736e1e69a 100644 --- a/include/configs/imx8mq_cm.h +++ b/include/configs/imx8mq_cm.h @@ -24,14 +24,12 @@ /* ENET Config */ /* ENET1 */
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(MMC, mmc, 1) \ func(DHCP, dhcp, na)
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 63bd1955f453..781a40e3de29 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -31,14 +31,12 @@ #define CONFIG_FEC_MXC_PHYADDR 0 #endif
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/iot2050.h b/include/configs/iot2050.h index 296bcd4c7b7b..d379bad0b154 100644 --- a/include/configs/iot2050.h +++ b/include/configs/iot2050.h @@ -21,8 +21,6 @@ #define EXTRA_ENV_IOT2050_BOARD_SETTINGS \ "usb_pgood_delay=900\0"
-#ifndef CONFIG_SPL_BUILD - #if CONFIG_IS_ENABLED(CMD_USB) # define BOOT_TARGET_USB(func) \ func(USB, usb, 0) \ @@ -44,8 +42,6 @@
-#endif - #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ BOOTENV \ diff --git a/include/configs/kontron-sl-mx6ul.h b/include/configs/kontron-sl-mx6ul.h index d04684955d3c..7b5e57734644 100644 --- a/include/configs/kontron-sl-mx6ul.h +++ b/include/configs/kontron-sl-mx6ul.h @@ -35,7 +35,6 @@ #endif
/* Boot order for distro boot */ -#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \ @@ -44,9 +43,6 @@ func(PXE, pxe, na) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> -#else -#define BOOTENV -#endif
/* MMC Configs */ #ifdef CONFIG_FSL_USDHC diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index 64bfddde3b00..dcc98fdef867 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -37,7 +37,6 @@ EFI_GUID(0xd488e45a, 0x4929, 0x4b55, 0x8c, 0x14, \ 0x86, 0xce, 0xa2, 0xcd, 0x66, 0x29)
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \ @@ -47,9 +46,6 @@ /* Do not try to probe USB net adapters for net boot */ #undef BOOTENV_RUN_NET_USB_START #define BOOTENV_RUN_NET_USB_START -#else -#define BOOTENV -#endif
diff --git a/include/configs/kp_imx6q_tpc.h b/include/configs/kp_imx6q_tpc.h index a513213c5980..7b8e70e59453 100644 --- a/include/configs/kp_imx6q_tpc.h +++ b/include/configs/kp_imx6q_tpc.h @@ -26,7 +26,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 /* Enabled USB controller number */ #endif
-#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200\0" \ "fdt_addr=0x18000000\0" \ @@ -87,7 +86,6 @@ func(DHCP, dhcp, na)
/* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR diff --git a/include/configs/kylin_rk3036.h b/include/configs/kylin_rk3036.h index 75fc03f14723..fea7c835fdcb 100644 --- a/include/configs/kylin_rk3036.h +++ b/include/configs/kylin_rk3036.h @@ -9,10 +9,4 @@ #include <linux/sizes.h> #include <configs/rk3036_common.h>
-#ifndef CONFIG_SPL_BUILD - -/* Store env in emmc */ - -#endif - #endif diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 1d8d9485e743..19201a735f0a 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -36,14 +36,12 @@ #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(USB, usb, 0) \ func(SCSI, scsi, 0) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> -#endif
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/ls1012afrdm.h b/include/configs/ls1012afrdm.h index cb79d6362fcb..674bcbeb7584 100644 --- a/include/configs/ls1012afrdm.h +++ b/include/configs/ls1012afrdm.h @@ -12,11 +12,9 @@ /* DDR */ #define CONFIG_SYS_SDRAM_SIZE 0x20000000
-#ifndef CONFIG_SPL_BUILD #undef BOOT_TARGET_DEVICES #define BOOT_TARGET_DEVICES(func) \ func(USB, usb, 0) -#endif
#undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/ls1012afrwy.h b/include/configs/ls1012afrwy.h index a1d23b64630d..7f083c597e30 100644 --- a/include/configs/ls1012afrwy.h +++ b/include/configs/ls1012afrwy.h @@ -19,13 +19,11 @@ /* ENV */ #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000
-#ifndef CONFIG_SPL_BUILD #undef BOOT_TARGET_DEVICES #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(USB, usb, 0) \ func(DHCP, dhcp, na) -#endif
#define CONFIG_PCIE1 /* PCIE controller 1 */
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index fe9a8fd3754e..6e2c048fb128 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -137,13 +137,11 @@ #define HWCONFIG_BUFFER_SIZE 128
#ifndef SPL_NO_MISC -#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(USB, usb, 0) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> -#endif
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 8e9103562eb7..e139aa93e1fc 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -104,14 +104,12 @@ #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(SCSI, scsi, 0) \ func(MMC, mmc, 0) \ func(USB, usb, 0) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> -#endif
#if defined(CONFIG_TARGET_LS1046AFRWY) #define LS1046A_BOOT_SRC_AND_HDR\ diff --git a/include/configs/ls1046afrwy.h b/include/configs/ls1046afrwy.h index d56d0c029474..e663fa0f6c7d 100644 --- a/include/configs/ls1046afrwy.h +++ b/include/configs/ls1046afrwy.h @@ -80,13 +80,11 @@ */ #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000
/* FMan */ #ifdef CONFIG_SYS_DPAA_FMAN diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index f2eae073810b..21ca4afa51ce 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -410,7 +410,7 @@ "env exists secureboot && esbc_halt;" #endif
-#if defined(CONFIG_FSL_MC_ENET) && !defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_MC_ENET) #define CONFIG_FSL_MEMAC #define SGMII_CARD_PORT1_PHY_ADDR 0x1C #define SGMII_CARD_PORT2_PHY_ADDR 0x1d diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index c6744e970f68..cffbb64bcd53 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -27,7 +27,6 @@
#define CONFIG_MXC_UART_BASE UART1_BASE
-#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ "som_rev=undefined\0" \ "has_emmc=undefined\0" \ @@ -87,10 +86,6 @@
-#else -#define CONFIG_EXTRA_ENV_SETTINGS -#endif /* CONFIG_SPL_BUILD */ - /* Physical Memory Map */ #define CONFIG_SYS_SDRAM_BASE MMDC0_ARB_BASE_ADDR #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index a5596d98fe68..8bddc5281e5e 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -136,10 +136,6 @@ #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(2, 1) #endif
-#ifndef CONFIG_SPL_BUILD -#ifdef CONFIG_DM_VIDEO #define MXS_LCDIF_BASE MX6SX_LCDIF1_BASE_ADDR -#endif -#endif
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 7c76290a2aeb..6a110132a759 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -134,10 +134,6 @@ #endif #endif
-#ifndef CONFIG_SPL_BUILD -#if defined(CONFIG_DM_VIDEO) #define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR -#endif -#endif
#endif diff --git a/include/configs/novena.h b/include/configs/novena.h index 9c67a3a77750..40304ba468c1 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -76,7 +76,6 @@ #define CONFIG_IMX_VIDEO_SKIP
/* Extra U-Boot environment. */ -#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ @@ -147,8 +146,4 @@
-#else -#define CONFIG_EXTRA_ENV_SETTINGS -#endif /* CONFIG_SPL_BUILD */ - #endif /* __CONFIG_H */ diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index c1ef040ce360..6be214753f1b 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -28,8 +28,6 @@ #define GPIO_IGEP00X0_BOARD_DETECTION 28 #define GPIO_IGEP00X0_REVISION_DETECTION 129
-#ifndef CONFIG_SPL_BUILD - /* Environment */ #define ENV_DEVICE_SETTINGS \ "stdin=serial\0" \ @@ -67,8 +65,6 @@ MEM_LAYOUT_SETTINGS \ BOOTENV
-#endif - /* OneNAND config */ #define CONFIG_USE_ONENAND_BOARD_INIT #define CONFIG_SYS_ONENAND_BASE ONENAND_MAP diff --git a/include/configs/opos6uldev.h b/include/configs/opos6uldev.h index ebfba72d0da4..d368376d2028 100644 --- a/include/configs/opos6uldev.h +++ b/include/configs/opos6uldev.h @@ -30,11 +30,7 @@ #endif
/* LCD */ -#ifndef CONFIG_SPL_BUILD -#ifdef CONFIG_DM_VIDEO #define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR -#endif -#endif
/* Environment is stored in the eMMC boot partition */
diff --git a/include/configs/pdu001.h b/include/configs/pdu001.h index 7ab6a896040f..ed3201aa3c42 100644 --- a/include/configs/pdu001.h +++ b/include/configs/pdu001.h @@ -32,7 +32,6 @@ #define CONSOLE_DEV "ttyO5" #endif
-#ifndef CONFIG_SPL_BUILD #define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ "fdtfile=am335x-pdu001.dtb\0" \ @@ -49,7 +48,6 @@ "reset;" \ "fi;" \ "\0" -#endif
/* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 UART0_BASE diff --git a/include/configs/pomelo.h b/include/configs/pomelo.h index 11d408f19084..647bb3d02a1b 100644 --- a/include/configs/pomelo.h +++ b/include/configs/pomelo.h @@ -16,12 +16,10 @@ /*BOOT*/ #define CONFIG_SYS_BOOTM_LEN 0x3c00000
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/poplar.h b/include/configs/poplar.h index 6def3691103c..b119465420df 100644 --- a/include/configs/poplar.h +++ b/include/configs/poplar.h @@ -31,9 +31,7 @@ func(USB, usb, 0) \ func(MMC, mmc, 0) \ func(DHCP, dhcp, na) -#ifndef CONFIG_SPL_BUILD #include <config_distro_bootcmd.h> -#endif
#define CONFIG_EXTRA_ENV_SETTINGS \ "loader_mmc_blknum=0x0\0" \ diff --git a/include/configs/px30_common.h b/include/configs/px30_common.h index 96dcfb420f7b..62ed86b29c89 100644 --- a/include/configs/px30_common.h +++ b/include/configs/px30_common.h @@ -24,8 +24,6 @@ #define SDRAM_MAX_SIZE 0xff000000 #define SDRAM_BANK_SIZE (2UL << 30)
-#ifndef CONFIG_SPL_BUILD - #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00500000\0" \ "pxefile_addr_r=0x00600000\0" \ @@ -43,5 +41,3 @@ BOOTENV
#endif - -#endif diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index ad05920ad6b1..4f24b13f500e 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -30,8 +30,6 @@ /* Physical Memory Map */ #define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* 1GB */
-#ifndef CONFIG_SPL_BUILD - /* Use common default */
/* Default env settings */ @@ -67,9 +65,4 @@ "bootm ${kloadaddr}\0" \ ""
-#ifndef CONFIG_RESTORE_FLASH -/* set to negative value for no autoboot */ -#endif -#endif /* CONFIG_SPL_BUILD */ - #endif /* ! __CONFIG_PXM2_H */ diff --git a/include/configs/qemu-riscv.h b/include/configs/qemu-riscv.h index f3e16e55966d..a81c503d9fd1 100644 --- a/include/configs/qemu-riscv.h +++ b/include/configs/qemu-riscv.h @@ -21,7 +21,6 @@
/* Environment options */
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(QEMU, qemu, na) \ func(VIRTIO, virtio, 0) \ @@ -50,6 +49,5 @@ "pxefile_addr_r=0x8c200000\0" \ "ramdisk_addr_r=0x8c300000\0" \ BOOTENV -#endif
#endif /* __CONFIG_H */ diff --git a/include/configs/rastaban.h b/include/configs/rastaban.h index 6c942a809809..5de980ddc00a 100644 --- a/include/configs/rastaban.h +++ b/include/configs/rastaban.h @@ -40,8 +40,6 @@ /* Define own nand partitions */ #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
-#ifndef CONFIG_SPL_BUILD - /* Default env settings */ #define CONFIG_EXTRA_ENV_SETTINGS \ "hostname=rastaban\0" \ @@ -53,8 +51,4 @@ CONFIG_ENV_SETTINGS_V2 \ CONFIG_ENV_SETTINGS_NAND_V2
-#ifndef CONFIG_RESTORE_FLASH -/* set to negative value for no autoboot */ -#endif -#endif /* CONFIG_SPL_BUILD */ #endif /* ! __CONFIG_RASTABAN_H */ diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 2f3260e449c1..ac57721f0214 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -17,8 +17,6 @@ #define SDRAM_BANK_SIZE (512UL << 20UL) #define SDRAM_MAX_SIZE (CONFIG_NR_DRAM_BANKS * SDRAM_BANK_SIZE)
-#ifndef CONFIG_SPL_BUILD - #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x60000000\0" \ "pxefile_addr_r=0x60100000\0" \ @@ -36,6 +34,5 @@ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ BOOTENV -#endif
#endif diff --git a/include/configs/rk3066_common.h b/include/configs/rk3066_common.h index 41e0d18f88c6..9297184bded8 100644 --- a/include/configs/rk3066_common.h +++ b/include/configs/rk3066_common.h @@ -15,8 +15,6 @@ #define SDRAM_BANK_SIZE (1024UL << 20UL) #define SDRAM_MAX_SIZE CONFIG_NR_DRAM_BANKS * SDRAM_BANK_SIZE
-#ifndef CONFIG_SPL_BUILD - #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x60000000\0" \ "pxefile_addr_r=0x60100000\0" \ @@ -34,6 +32,4 @@ ROCKCHIP_DEVICE_SETTINGS \ BOOTENV
-#endif /* CONFIG_SPL_BUILD */ - #endif diff --git a/include/configs/rk3128_common.h b/include/configs/rk3128_common.h index 5c60d119f995..f3e0eefb9a21 100644 --- a/include/configs/rk3128_common.h +++ b/include/configs/rk3128_common.h @@ -22,8 +22,6 @@ #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1
-#ifndef CONFIG_SPL_BUILD - /* usb mass storage */
#define ENV_MEM_LAYOUT_SETTINGS \ @@ -41,5 +39,3 @@ BOOTENV
#endif - -#endif diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index c1d66845412f..56fba3ff2578 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -19,7 +19,6 @@ #define SDRAM_BANK_SIZE (2UL << 30) #define SDRAM_MAX_SIZE 0x80000000
-#ifndef CONFIG_SPL_BUILD /* usb otg */
/* usb host support */ @@ -43,6 +42,4 @@ ROCKCHIP_DEVICE_SETTINGS \ BOOTENV
-#endif /* CONFIG_SPL_BUILD */ - #endif diff --git a/include/configs/rk322x_common.h b/include/configs/rk322x_common.h index dd1a207aed33..c3279b84d3a4 100644 --- a/include/configs/rk322x_common.h +++ b/include/configs/rk322x_common.h @@ -20,8 +20,6 @@ #define SDRAM_BANK_SIZE (512UL << 20UL) #define SDRAM_MAX_SIZE 0x80000000
-#ifndef CONFIG_SPL_BUILD - #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x60000000\0" \ "pxefile_addr_r=0x60100000\0" \ @@ -39,6 +37,5 @@ "partitions=" PARTS_DEFAULT \ ENV_MEM_LAYOUT_SETTINGS \ BOOTENV -#endif
#endif diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 844c154217bd..18f4289d29ab 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -23,8 +23,6 @@
#define CONFIG_SYS_MONITOR_LEN (600 * 1024)
-#ifndef CONFIG_SPL_BUILD - #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00000000\0" \ "pxefile_addr_r=0x00100000\0" \ @@ -44,6 +42,5 @@ ENV_MEM_LAYOUT_SETTINGS \ ROCKCHIP_DEVICE_SETTINGS \ BOOTENV -#endif
#endif diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index 169cf2ac9c1f..d5aadd5fa803 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -20,8 +20,6 @@ #define SDRAM_MAX_SIZE 0xff000000 #define SDRAM_BANK_SIZE (2UL << 30)
-#ifndef CONFIG_SPL_BUILD - #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00500000\0" \ "pxefile_addr_r=0x00600000\0" \ @@ -37,5 +35,3 @@ BOOTENV
#endif - -#endif diff --git a/include/configs/rk3328_common.h b/include/configs/rk3328_common.h index 9cdc9004a91f..90183579202d 100644 --- a/include/configs/rk3328_common.h +++ b/include/configs/rk3328_common.h @@ -16,8 +16,6 @@ #define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xff000000
-#ifndef CONFIG_SPL_BUILD - #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00500000\0" \ "pxefile_addr_r=0x00600000\0" \ @@ -32,8 +30,6 @@ "partitions=" PARTS_DEFAULT \ BOOTENV
-#endif - /* rockchip ohci host driver */ #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index ac8818868245..4db4026ebe56 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -18,7 +18,6 @@
#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */
-#ifndef CONFIG_SPL_BUILD #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00500000\0" \ "pxefile_addr_r=0x00600000\0" \ @@ -34,5 +33,3 @@ BOOTENV
#endif - -#endif diff --git a/include/configs/rk3568_common.h b/include/configs/rk3568_common.h index f9c7c23cd9ab..ef4f725b5793 100644 --- a/include/configs/rk3568_common.h +++ b/include/configs/rk3568_common.h @@ -15,7 +15,6 @@ #define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xf0000000
-#ifndef CONFIG_SPL_BUILD #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00c00000\0" \ "pxefile_addr_r=0x00e00000\0" \ @@ -30,6 +29,5 @@ "partitions=" PARTS_DEFAULT \ ROCKCHIP_DEVICE_SETTINGS \ BOOTENV -#endif
#endif diff --git a/include/configs/rut.h b/include/configs/rut.h index fc3194654ae3..ac48372b6c0b 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -24,8 +24,6 @@ /* Watchdog */ #define WATCHDOG_TRIGGER_GPIO 14
/* Default env settings */ @@ -59,10 +57,4 @@ "bootm ${kloadaddr}\0" \ ""
-#ifndef CONFIG_RESTORE_FLASH -/* set to negative value for no autoboot */ -#endif - -#endif /* CONFIG_SPL_BUILD */ - #endif /* ! __CONFIG_RUT_H */ diff --git a/include/configs/rv1108_common.h b/include/configs/rv1108_common.h index f088f0e7a0c1..d8de9c25df2b 100644 --- a/include/configs/rv1108_common.h +++ b/include/configs/rv1108_common.h @@ -20,9 +20,7 @@ /* rockchip ohci host driver */ #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 -#endif
-#ifndef CONFIG_SPL_BUILD #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x60000000\0" \ "fdt_addr_r=0x61f00000\0" \ @@ -35,4 +33,5 @@ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "partitions=" PARTS_DEFAULT \ BOOTENV + #endif diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index c22b74f707ef..5168e2fa3531 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -6,9 +6,7 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#ifndef CONFIG_SPL_BUILD #define CONFIG_IO_TRACE -#endif
#define CONFIG_MALLOC_F_ADDR 0x0010000
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 941e02c5c68d..db8ff848285a 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -17,9 +17,7 @@
/* commands to include */
-#ifndef CONFIG_SPL_BUILD #define CONFIG_ROOTPATH "/opt/eldk" -#endif
#define CONFIG_SYS_AUTOLOAD "yes"
@@ -81,16 +79,12 @@ * we don't need to do it twice. */
-#ifndef CONFIG_SPL_BUILD - /* USB DRACO ID as default */ #define CONFIG_USBD_HS
/* USB Device Firmware Update support */ #define DFU_MANIFEST_POLL_TIMEOUT 25000
-#endif /* CONFIG_SPL_BUILD */ - /* * Default to using SPI for environment, etc. We have multiple copies * of SPL as the ROM will check these locations. diff --git a/include/configs/sifive-unleashed.h b/include/configs/sifive-unleashed.h index 4442fc29e316..a99d143485c4 100644 --- a/include/configs/sifive-unleashed.h +++ b/include/configs/sifive-unleashed.h @@ -24,7 +24,6 @@
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ func(SF, sf, 0) \ @@ -61,6 +60,5 @@ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ BOOTENV \ BOOTENV_SF -#endif
#endif /* __CONFIG_H */ diff --git a/include/configs/sifive-unmatched.h b/include/configs/sifive-unmatched.h index f5a341c84496..680caac377bc 100644 --- a/include/configs/sifive-unmatched.h +++ b/include/configs/sifive-unmatched.h @@ -19,7 +19,6 @@
-#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(NVME, nvme, 0) \ func(USB, usb, 0) \ @@ -53,7 +52,6 @@ "partitions=" PARTS_DEFAULT "\0" \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ BOOTENV -#endif /* CONFIG_SPL_BUILD */
#define CONFIG_SYS_EEPROM_BUS_NUM 0
diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index cde6abc62611..458d22d61f48 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -69,7 +69,6 @@ #define CONFIG_USART_BASE ATMEL_BASE_DBGU #define CONFIG_USART_ID ATMEL_ID_SYS
-#if !defined(CONFIG_SPL_BUILD) /* USB configuration */ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB @@ -85,7 +84,6 @@
/* DFU class support */ #define DFU_MANIFEST_POLL_TIMEOUT 25000 -#endif
/* General Boot Parameter */
diff --git a/include/configs/socfpga_soc64_common.h b/include/configs/socfpga_soc64_common.h index b71f8bab156f..c388ae9a816c 100644 --- a/include/configs/socfpga_soc64_common.h +++ b/include/configs/socfpga_soc64_common.h @@ -34,21 +34,6 @@ * U-Boot environment configurations */
-/* - * QSPI support - */ - #ifdef CONFIG_CADENCE_QSPI -/* Enable it if you want to use dual-stacked mode */ -/*#define CONFIG_QSPI_RBF_ADDR 0x720000*/ - -/* Flash device info */ - -#ifndef CONFIG_SPL_BUILD -#define MTDIDS_DEFAULT "nor0=ff705000.spi.0" -#endif /* CONFIG_SPL_BUILD */ - -#endif /* CONFIG_CADENCE_QSPI */ - /* * Environment variable */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 327bf98ddb23..1f77b7b2dfde 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -125,8 +125,6 @@ #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 #endif
-#ifndef CONFIG_SPL_BUILD - #ifdef CONFIG_ARM64 /* * Boards seem to come with at least 512MB of DRAM. @@ -372,8 +370,4 @@ BOOTCMD_SUNXI_COMPAT \ BOOTENV
-#else /* ifndef CONFIG_SPL_BUILD */ -#define CONFIG_EXTRA_ENV_SETTINGS -#endif - #endif /* _SUNXI_COMMON_CONFIG_H */ diff --git a/include/configs/synquacer.h b/include/configs/synquacer.h index 5b862f4f2ee9..63d897d090af 100644 --- a/include/configs/synquacer.h +++ b/include/configs/synquacer.h @@ -60,7 +60,6 @@ 0xf0, 0xa3, 0x83, 0x87, 0xe6, 0x30)
/* Distro boot settings */ -#ifndef CONFIG_SPL_BUILD #ifdef CONFIG_CMD_USB #define BOOT_TARGET_DEVICE_USB(func) func(USB, usb, 0) #else @@ -92,9 +91,6 @@ BOOT_TARGET_DEVICE_NVME(func) \
#include <config_distro_bootcmd.h> -#else /* CONFIG_SPL_BUILD */ -#define BOOTENV -#endif
#define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_addr_r=0x9fe00000\0" \ diff --git a/include/configs/taurus.h b/include/configs/taurus.h index b9285e8cabad..798d72d8e26b 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -84,13 +84,8 @@ /* SPI EEPROM */ #define TAURUS_SPI_MASK (1 << 4)
-#if defined(CONFIG_SPL_BUILD) -/* SPL related */ -#endif - /* bootstrap in spi flash , u-boot + env + linux in nandflash */
-#ifndef CONFIG_SPL_BUILD #if defined(CONFIG_BOARD_AXM) #define CONFIG_EXTRA_ENV_SETTINGS \ "addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:" \ @@ -139,7 +134,6 @@ "stdout=serial\0" \ "upgrade_available=0\0" #endif -#endif /* #ifndef CONFIG_SPL_BUILD */
/* Defines for SPL */
diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index 755a41fef7e2..c8f9d7cb175c 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -9,8 +9,6 @@
#define CONFIG_SYS_NONCACHED_MEMORY (1 << 20) /* 1 MiB */
-#ifndef CONFIG_SPL_BUILD - #if CONFIG_IS_ENABLED(CMD_USB) # define BOOT_TARGET_USB(func) func(USB, usb, 0) #else @@ -26,9 +24,6 @@ func(DHCP, dhcp, na) #endif #include <config_distro_bootcmd.h> -#else -#define BOOTENV -#endif
#ifdef CONFIG_TEGRA_KEYBOARD #define STDIN_KBD_KBC ",tegra-kbc" diff --git a/include/configs/thuban.h b/include/configs/thuban.h index bb0b9fa1560d..fd903537ae5e 100644 --- a/include/configs/thuban.h +++ b/include/configs/thuban.h @@ -33,8 +33,6 @@ /* Define own nand partitions */ #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
-#ifndef CONFIG_SPL_BUILD - /* Default env settings */ #define CONFIG_EXTRA_ENV_SETTINGS \ "hostname=thuban\0" \ @@ -46,8 +44,4 @@ CONFIG_ENV_SETTINGS_V2 \ CONFIG_ENV_SETTINGS_NAND_V2
-#ifndef CONFIG_RESTORE_FLASH -/* set to negative value for no autoboot */ -#endif -#endif /* CONFIG_SPL_BUILD */ #endif /* ! __CONFIG_THUBAN_H */ diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index 5d8c45af2fa0..fcf282bc4c18 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -47,9 +47,7 @@ #endif
/* TWL6030 */ -#ifndef CONFIG_SPL_BUILD #define CONFIG_TWL6030_POWER 1 -#endif
/* * Environment setup diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 2bb9e59b9462..8096b2c89603 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -10,7 +10,6 @@ #ifndef __CONFIG_UNIPHIER_H__ #define __CONFIG_UNIPHIER_H__
#ifdef CONFIG_CMD_MMC @@ -35,9 +34,6 @@ BOOT_TARGET_DEVICE_MMC(func) \ BOOT_TARGET_DEVICE_UBIFS(func) \ BOOT_TARGET_DEVICE_USB(func) -#else -#define BOOTENV -#endif
#define CONFIG_SYS_MONITOR_LEN 0x00200000 /* 2MB */
diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 846d6566a55a..0192a4fe06cb 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -27,15 +27,11 @@ "scriptaddr=0x46000000\0"
/* Enable Distro Boot */ -#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 0) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> -#else -#define BOOTENV -#endif
/* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 2bbe2b72e0a7..beec393a3997 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -39,15 +39,11 @@ "scriptaddr=0x46000000\0"
/* Enable Distro Boot */ -#ifndef CONFIG_SPL_BUILD #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ func(MMC, mmc, 2) \ func(DHCP, dhcp, na) #include <config_distro_bootcmd.h> -#else -#define BOOTENV -#endif
#if defined(CONFIG_TDX_EASY_INSTALLER) # define BOOT_SCRIPT "boot-tezi.scr" diff --git a/include/configs/x530.h b/include/configs/x530.h index d8fc3c13d062..1f1b4e1449eb 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -48,9 +48,7 @@ #define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */
/* NAND */
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index bfd622bb0289..20515b4e26ac 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -37,13 +37,11 @@ #define DFU_DEFAULT_POLL_TIMEOUT 300 #define CONFIG_THOR_RESET_OFF
-#ifndef CONFIG_SPL_BUILD # define PARTS_DEFAULT \ "partitions=uuid_disk=${uuid_gpt_disk};" \ "name=""boot"",size=16M,uuid=${uuid_gpt_boot};" \ "name=""Linux"",size=-M,uuid=${uuid_gpt_Linux}\0" #endif -#endif
#if !defined(PARTS_DEFAULT) # define PARTS_DEFAULT
On Fri, Jun 10, 2022 at 10:59:24PM -0400, Tom Rini wrote:
The only use of CONFIG_XTFPGA was to build all of the in-tree device trees. Switch to using CONFIG_XTENSA instead of a non-Kconfig symbol.
For the series, applied to u-boot/next, thanks!
Minkyu Kang
