[U-Boot] [PATCH] 85xx: Fix memory test range on MPC8536DS
With current values of CONFIG_SYS_MEMTEST_START and CONFIG_SYS_MEMTEST_END memory test hangs if run without arguments. Set them to sane values, so that all available 512MB of RAM excluding exception vectors at the bottom and u-boot code and stack at the top can be tested.
Signed-off-by: Felix Radensky felix@embedded-sol.com --- include/configs/MPC8536DS.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 9d2b860..93dd61e 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -77,8 +77,8 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy);
#define CONFIG_ENABLE_36BIT_PHYS 1
-#define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x7fffffff +#define CONFIG_SYS_MEMTEST_START 0x00010000 /* skip exception vectors */ +#define CONFIG_SYS_MEMTEST_END 0x1f000000 /* skip u-boot at top of RAM */ #define CONFIG_PANIC_HANG /* do not reset board on panic */
applied to next
- k
Felix Radensky
Kumar Gala
