[U-Boot] [PATCH v2] cmd: gpt: fix the wrong size parse for the last partition
The calculation of "dev_desc->lba - 34 - 1 - offset" is not correct for size '-', because both fist_usable_lba and last_usable_lba will remain 34 sectors.
We can simply use 0 for size '-' because the part_efi module will decode the size and auto extend the size to maximum available size.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: - fix gpt verify error, do not check the extend partition size
cmd/gpt.c | 4 ++-- disk/part_efi.c | 4 ++++ 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/cmd/gpt.c b/cmd/gpt.c index 3d9706b..897596a 100644 --- a/cmd/gpt.c +++ b/cmd/gpt.c @@ -298,8 +298,8 @@ static int set_gpt_info(struct blk_desc *dev_desc, if (extract_env(val, &p)) p = val; if ((strcmp(p, "-") == 0)) { - /* remove first usable lba and last block */ - parts[i].size = dev_desc->lba - 34 - 1 - offset; + /* Let part efi module to auto extend the size */ + parts[i].size = 0; } else { size_ll = ustrtoull(p, &p, 0); parts[i].size = lldiv(size_ll, dev_desc->blksz); diff --git a/disk/part_efi.c b/disk/part_efi.c index 0af1e92..4566cab 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -655,6 +655,10 @@ int gpt_verify_partitions(struct blk_desc *dev_desc, (unsigned long long)partitions[i].size);
if (le64_to_cpu(gpt_part_size) != partitions[i].size) { + /* We do not check the extend partition size */ + if ((i == parts - 1) && (partitions[i].size == 0)) + continue; + error("Partition %s size: %llu does not match %llu!\n", efi_str, (unsigned long long)gpt_part_size, (unsigned long long)partitions[i].size);
Hi Michael,
Do you think this patch is necessary?
Changes in v2:
} else { size_ll = ustrtoull(p, &p, 0); parts[i].size = lldiv(size_ll, dev_desc->blksz);parts[i].size = 0;
continue;
Hi
On Aug 4, 2016 05:38, "Kever Yang" kever.yang@rock-chips.com wrote:
Hi Michael,
Yes, I have checked it and fix the regression. Today I will confirm on hot correctness but I think too
Michael
Thanks, -Kever
Changes in v2:
diff --git a/disk/part_efi.c b/disk/part_efi.c index 0af1e92..4566cab 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -655,6 +655,10 @@ int gpt_verify_partitions(struct blk_desc *dev_desc, (unsigned long long)partitions[i].size); if (le64_to_cpu(gpt_part_size) != partitions[i].size) {
0))
continue;
%llu!\n",
Kever Yang
Michael Trimarchi
