[U-Boot] [PATCH V4 1/4] mmc: fsl_esdhc: correct type of wp_enable
The type should be int, not u8. cfg->wp_enable will finally be assigned to priv->wp_enable whose type is int.
Signed-off-by: Peng Fan peng.fan@nxp.com ---
V4: new
include/fsl_esdhc.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index e15d3ae..5550e00 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -177,7 +177,7 @@ struct fsl_esdhc_cfg { phys_addr_t esdhc_base; u32 sdhc_clk; u8 max_bus_width; - u8 wp_enable; + int wp_enable; struct mmc_config cfg; };
When using eMMC with 1.8V I/O, the VSELECT bit need to be set in the USDHC controller when init.
This patch adds a parameter "vs18_enable" in fsl_esdhc_cfg structure and priv data, so each controller can have different settings.
We could not use CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT, it has problem that it will apply to all USDHC controllers and it only set the 1.8V at init phase. So if user does not select to the eMMC device, the voltage on the I/O pins are not correct.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: York Sun york.sun@nxp.com Cc: Stefano Babic sbabic@denx.de ---
V4: Change type of cfg->vs_enable to int. V3: none V2: none
drivers/mmc/fsl_esdhc.c | 9 +++++++++ include/fsl_esdhc.h | 1 + 2 files changed, 10 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 5ee712f..aa08102 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -92,6 +92,7 @@ struct fsl_esdhc { * @dev: pointer for the device * @non_removable: 0: removable; 1: non-removable * @wp_enable: 1: enable checking wp; 0: no check + * @vs18_enable: 1: use 1.8V voltage; 0: use 3.3V * @cd_gpio: gpio for card detection * @wp_gpio: gpio for write protection */ @@ -104,6 +105,7 @@ struct fsl_esdhc_priv { struct udevice *dev; int non_removable; int wp_enable; + int vs18_enable; #ifdef CONFIG_DM_GPIO struct gpio_desc cd_gpio; struct gpio_desc wp_gpio; @@ -673,6 +675,9 @@ static int esdhc_init(struct mmc *mmc) esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); #endif
+ if (priv->vs18_enable) + esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); + return 0; }
@@ -733,6 +738,7 @@ static int fsl_esdhc_cfg_to_priv(struct fsl_esdhc_cfg *cfg, priv->bus_width = cfg->max_bus_width; priv->sdhc_clk = cfg->sdhc_clk; priv->wp_enable = cfg->wp_enable; + priv->vs18_enable = cfg->vs18_enable;
return 0; }; @@ -759,6 +765,9 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv) VENDORSPEC_HCKEN | VENDORSPEC_IPGEN | VENDORSPEC_CKEN); #endif
+ if (priv->vs18_enable) + esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); + writel(SDHCI_IRQ_EN_BITS, ®s->irqstaten); memset(&priv->cfg, 0, sizeof(priv->cfg));
diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index 5550e00..02b362d 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -178,6 +178,7 @@ struct fsl_esdhc_cfg { u32 sdhc_clk; u8 max_bus_width; int wp_enable; + int vs18_enable; /* Use 1.8V if set to 1 */ struct mmc_config cfg; };
Handle vqmmc supply. Some boards have a fixed I/O voltage at 1.8V for emmc, so the usdhc also needs to be configured as 1.8V by setting VSELECT bit. The vs18_enable is the one that used to checking whether setting VSELECT or not in the driver. So if vqmmc supply is 1.8V, set vs18_enable, the driver will set VSELECT.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: York Sun york.sun@nxp.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Jaehoon Chung jh80.chung@samsung.com ---
V4: add review tag V3: Include regulator header file, fix dev_dbg usage V2: none
drivers/mmc/fsl_esdhc.c | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index aa08102..5e320e0 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -16,6 +16,7 @@ #include <hwconfig.h> #include <mmc.h> #include <part.h> +#include <power/regulator.h> #include <malloc.h> #include <fsl_esdhc.h> #include <fdt_support.h> @@ -968,6 +969,7 @@ static int fsl_esdhc_probe(struct udevice *dev) struct fsl_esdhc_priv *priv = dev_get_priv(dev); const void *fdt = gd->fdt_blob; int node = dev_of_offset(dev); + struct udevice *vqmmc_dev; fdt_addr_t addr; unsigned int val; int ret; @@ -1005,6 +1007,29 @@ static int fsl_esdhc_probe(struct udevice *dev) if (ret) priv->wp_enable = 0; #endif + + priv->vs18_enable = 0; + +#ifdef CONFIG_DM_REGULATOR + /* + * If emmc I/O has a fixed voltage at 1.8V, this must be provided, + * otherwise, emmc will work abnormally. + */ + ret = device_get_supply_regulator(dev, "vqmmc-supply", &vqmmc_dev); + if (ret) { + dev_dbg(dev, "no vqmmc-supply\n"); + } else { + ret = regulator_set_enable(vqmmc_dev, true); + if (ret) { + dev_err(dev, "fail to enable vqmmc-supply\n"); + return ret; + } + + if (regulator_get_value(vqmmc_dev) == 1800000) + priv->vs18_enable = 1; + } +#endif + /* * TODO: * Because lack of clk driver, if SDHC clk is not enabled,
CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT is not the correct method to set I/O to 1.8. To boards that does not support vqmmc-supply, use vs18_enable in fsl_esdhc_cfg. If regulator is supported, use fixed 1.8V regulator for vqmmc-supply.
V4: Merge patch 3/4 and patch 4/4 of V3 patch set.
board/warp/warp.c | 2 +- doc/README.fsl-esdhc | 2 -- drivers/mmc/fsl_esdhc.c | 4 ---- include/configs/warp.h | 1 - scripts/config_whitelist.txt | 1 - 5 files changed, 1 insertion(+), 9 deletions(-)
diff --git a/board/warp/warp.c b/board/warp/warp.c index 0bc0a6a..b1b528a 100644 --- a/board/warp/warp.c +++ b/board/warp/warp.c @@ -62,7 +62,7 @@ static void setup_iomux_uart(void) }
static struct fsl_esdhc_cfg usdhc_cfg[1] = { - {USDHC2_BASE_ADDR}, + {USDHC2_BASE_ADDR, 0, 0, 0, 1}, };
int board_mmc_getcd(struct mmc *mmc) diff --git a/doc/README.fsl-esdhc b/doc/README.fsl-esdhc index 7e71387..29cc661 100644 --- a/doc/README.fsl-esdhc +++ b/doc/README.fsl-esdhc @@ -20,5 +20,3 @@ Freescale esdhc-specific options - CONFIG_SYS_FSL_ESDHC_BE ESDHC IP is in big-endian mode. Accessing ESDHC registers can be determined by ESDHC IP's endian mode or processor's endian mode. - - - CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT forces to run at 1.8V. diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 5e320e0..a65a465 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -672,10 +672,6 @@ static int esdhc_init(struct mmc *mmc) /* Set timout to the maximum value */ esdhc_clrsetbits32(®s->sysctl, SYSCTL_TIMEOUT_MASK, 14 << 16);
-#ifdef CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT - esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); -#endif - if (priv->vs18_enable) esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT);
diff --git a/include/configs/warp.h b/include/configs/warp.h index afe3eae..e3f79b1 100644 --- a/include/configs/warp.h +++ b/include/configs/warp.h @@ -23,7 +23,6 @@
/* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR -#define CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT #define CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE #define CONFIG_SUPPORT_EMMC_BOOT
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 2126a88..7bdf33a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3762,7 +3762,6 @@ CONFIG_SYS_FSL_ERRATUM_A_004934 CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_FSL_ESDHC_BE CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT -CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE CONFIG_SYS_FSL_ESDHC_LE CONFIG_SYS_FSL_ESDHC_NUM
Ping..
V4: new
- u8 wp_enable;
- int wp_enable; struct mmc_config cfg;
-- 2.6.2
Hi Peng,
On 07/07/2017 09:42, Peng Fan wrote:
Ping..
I was unsure if I have to take care of this patchset, because they are not strictly related to i.MX.
Anyway, there are no open points and if nobody complains, I merge them into u-boot-imx, -next.
Regards, Stefano
V4: new
- u8 wp_enable;
-- 2.6.2
Peng Fan
Peng Fan
Stefano Babic
