[PATCH] arm: mvebu: turris_omnia: Set ETHPRIME to DT alias
CONFIG_ETHPRIME can be set to DT node name or alias which refers to DT node. Define ethernet aliases and set ETHPRIME to eth2 which refers to WAN ethernet port. This removes hardcoded DT node name from U-Boot configuration file.
Signed-off-by: Pali Rohár pali@kernel.org --- arch/arm/dts/armada-385-turris-omnia.dts | 6 ++++++ configs/turris_omnia_defconfig | 2 +- 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/armada-385-turris-omnia.dts b/arch/arm/dts/armada-385-turris-omnia.dts index 5511c84849ee..7f1478edfd23 100644 --- a/arch/arm/dts/armada-385-turris-omnia.dts +++ b/arch/arm/dts/armada-385-turris-omnia.dts @@ -55,6 +55,12 @@ stdout-path = &uart0; };
+ aliases { + ethernet0 = ð0; + ethernet1 = ð1; + ethernet2 = ð2; + }; + memory { device_type = "memory"; reg = <0x00000000 0x40000000>; /* 1024 MB */ diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 6460535ef94e..e2a0449b487b 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -65,7 +65,7 @@ CONFIG_CMD_FS_UUID=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_USE_ETHPRIME=y -CONFIG_ETHPRIME="ethernet@34000" +CONFIG_ETHPRIME="eth2" CONFIG_ARP_TIMEOUT=200 CONFIG_NET_RETRY_COUNT=50 CONFIG_NETCONSOLE=y
Oh yeah. Do we want to send this dt change also to Linux?
Reviewed-by: Marek Behún kabel@kernel.org
Rather synchronize Omnia/A385 DTS files between U-Boot and Linux.
Thanks, Stefan
- aliases {
ethernet0 = ð0;
ethernet1 = ð1;
ethernet2 = ð2;
- memory { device_type = "memory"; reg = <0x00000000 0x40000000>; /* 1024 MB */
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
- aliases {
ethernet0 = ð0;
ethernet1 = ð1;
ethernet2 = ð2;
Marek Behún
Pali Rohár
Stefan Roese
