[PATCH 0/3] azure/gitlab/travis: Switch to gcc 9.2.0
This updates all CI services to use gcc 9.2.0 for build testing.
Azure results: https://dev.azure.com/bmeng/GitHub/_build/results?buildId=201&view=resul...
Gitlab results: https://gitlab.denx.de/u-boot/custodians/u-boot-x86/pipelines/2632
Travis results: https://travis-ci.org/github/lbmeng/u-boot/builds/671506792
This series depends on Docker file update for azure/gitlab: http://patchwork.ozlabs.org/patch/1266862/
This series should be applied after: http://patchwork.ozlabs.org/project/uboot/list/?series=167328
Bin Meng (3): video: sunxi: Change sunxi_get_mon_desc() to not return NULL for the default case buildman: Support fetching gcc 9.2.0 travis: Switch to gcc 9.2.0
.travis.yml | 40 ++++++++++++++++++------------------- drivers/video/sunxi/sunxi_display.c | 2 +- tools/buildman/toolchain.py | 2 +- 3 files changed, 22 insertions(+), 22 deletions(-)
When building with gcc 9.2.0, the following build warning was seen:
drivers/video/sunxi/sunxi_display.c: In function 'video_hw_init': drivers/video/sunxi/sunxi_display.c:1217:2: error: '%s' directive argument is null [-Werror=format-overflow=]
Change sunxi_get_mon_desc() to not return NULL for the default case, to fix the compiler warning.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
drivers/video/sunxi/sunxi_display.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index 31f0aa7..5679d83 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -1024,7 +1024,7 @@ static const char *sunxi_get_mon_desc(enum sunxi_monitor monitor) case sunxi_monitor_composite_pal_m: return "composite-pal-m"; case sunxi_monitor_composite_pal_nc: return "composite-pal-nc"; } - return NULL; /* never reached */ + return "none"; /* never reached */ }
ulong board_get_usable_ram_top(ulong total_size)
- return "none"; /* never reached */
That's fine. But do we want to re-work the function to catch sunxi_monitor_none in the default case and use "none" there as well (like it does today) to silence the warning? Thanks!
This adds support to fetch gcc 9.2.0 toolchains.
tools/buildman/toolchain.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 89c54d6..4456a80 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -490,7 +490,7 @@ class Toolchains: if arch == 'aarch64': arch = 'arm64' base = 'https://www.kernel.org/pub/tools/crosstool/files/bin' - versions = ['7.3.0', '6.4.0', '4.9.4'] + versions = ['9.2.0', '7.3.0', '6.4.0', '4.9.4'] links = [] for version in versions: url = '%s/%s/%s/' % (base, arch, version)
Use gcc 9.2.0 to do the build testing.
.travis.yml | 40 ++++++++++++++++++++-------------------- 1 file changed, 20 insertions(+), 20 deletions(-)
diff --git a/.travis.yml b/.travis.yml index fddaee8..c70099e 100644 --- a/.travis.yml +++ b/.travis.yml @@ -118,11 +118,11 @@ before_script: ./bootstrap && ./configure --target=arm --with-platform=efi CC=gcc - TARGET_CC=~/.buildman-toolchains/gcc-7.3.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-gcc - TARGET_OBJCOPY=~/.buildman-toolchains/gcc-7.3.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-objcopy - TARGET_STRIP=~/.buildman-toolchains/gcc-7.3.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-strip - TARGET_NM=~/.buildman-toolchains/gcc-7.3.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-nm - TARGET_RANLIB=~/.buildman-toolchains/gcc-7.3.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ranlib && + TARGET_CC=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-gcc + TARGET_OBJCOPY=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-objcopy + TARGET_STRIP=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-strip + TARGET_NM=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-nm + TARGET_RANLIB=~/.buildman-toolchains/gcc-9.2.0-nolibc/arm-linux-gnueabi/bin/arm-linux-gnueabi-ranlib && make -j4 && ./grub-mkimage -O arm-efi -o ~/grub_arm.efi --prefix= -d grub-core cat chain configfile echo efinet ext2 fat halt help linux @@ -138,11 +138,11 @@ before_script: ./bootstrap && ./configure --target=aarch64 --with-platform=efi CC=gcc - TARGET_CC=~/.buildman-toolchains/gcc-7.3.0-nolibc/aarch64-linux/bin/aarch64-linux-gcc - TARGET_OBJCOPY=~/.buildman-toolchains/gcc-7.3.0-nolibc/aarch64-linux/bin/aarch64-linux-objcopy - TARGET_STRIP=~/.buildman-toolchains/gcc-7.3.0-nolibc/aarch64-linux/bin/aarch64-linux-strip - TARGET_NM=~/.buildman-toolchains/gcc-7.3.0-nolibc/aarch64-linux/bin/aarch64-linux-nm - TARGET_RANLIB=~/.buildman-toolchains/gcc-7.3.0-nolibc/aarch64-linux/bin/aarch64-linux-ranlib && + TARGET_CC=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-gcc + TARGET_OBJCOPY=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-objcopy + TARGET_STRIP=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-strip + TARGET_NM=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-nm + TARGET_RANLIB=~/.buildman-toolchains/gcc-9.2.0-nolibc/aarch64-linux/bin/aarch64-linux-ranlib && make -j4 && ./grub-mkimage -O arm64-efi -o ~/grub_arm64.efi --prefix= -d grub-core cat chain configfile echo efinet ext2 fat halt help linux @@ -158,11 +158,11 @@ before_script: ./bootstrap && ./configure --target=riscv32 --with-platform=efi CC=gcc - TARGET_CC=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv32-linux/bin/riscv32-linux-gcc - TARGET_OBJCOPY=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv32-linux/bin/riscv32-linux-objcopy - TARGET_STRIP=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv32-linux/bin/riscv32-linux-strip - TARGET_NM=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv32-linux/bin/riscv32-linux-nm - TARGET_RANLIB=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv32-linux/bin/riscv32-linux-ranlib && + TARGET_CC=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-gcc + TARGET_OBJCOPY=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-objcopy + TARGET_STRIP=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-strip + TARGET_NM=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-nm + TARGET_RANLIB=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv32-linux/bin/riscv32-linux-ranlib && make -j4 && ./grub-mkimage -O riscv32-efi -o ~/grub_riscv32.efi --prefix= -d grub-core cat chain configfile echo efinet ext2 fat halt help linux @@ -178,11 +178,11 @@ before_script: ./bootstrap && ./configure --target=riscv64 --with-platform=efi CC=gcc - TARGET_CC=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-gcc - TARGET_OBJCOPY=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-objcopy - TARGET_STRIP=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-strip - TARGET_NM=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-nm - TARGET_RANLIB=~/.buildman-toolchains/gcc-7.3.0-nolibc/riscv64-linux/bin/riscv64-linux-ranlib && + TARGET_CC=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-gcc + TARGET_OBJCOPY=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-objcopy + TARGET_STRIP=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-strip + TARGET_NM=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-nm + TARGET_RANLIB=~/.buildman-toolchains/gcc-9.2.0-nolibc/riscv64-linux/bin/riscv64-linux-ranlib && make -j4 && ./grub-mkimage -O riscv64-efi -o ~/grub_riscv64.efi --prefix= -d grub-core cat chain configfile echo efinet ext2 fat halt help linux
And when I grab this I'll also grab the patch to push to a newer LLVM I posted a while ago. Thanks!
Bin Meng
