[U-Boot] [PATCH] env_nand: Use nand_read_skip_bad instead of nand_read
19 Nov
2010
19 Nov
'10
3:45 p.m.
Otherwise environment read will fail if correctable errors occur
Signed-off-by: Steve Sakoman steve.sakoman@linaro.org ---
diff --git a/common/env_nand.c b/common/env_nand.c index 4e8307a..7f6c917 100644 --- a/common/env_nand.c +++ b/common/env_nand.c @@ -297,7 +297,7 @@ int readenv(size_t offset, u_char * buf) offset += blocksize; } else { char_ptr = &buf[amount_loaded]; - if (nand_read(&nand_info[0], offset, &len, char_ptr)) + if (nand_read_skip_bad(&nand_info[0], offset, &len, char_ptr)) return 1; offset += blocksize; amount_loaded += len;
5287
Steve Sakoman
