Re: [U-Boot] [PATCH] arm: socfpga: Fix QSPI doesn't work on socdk board
Hi Chin,
The PLL settings are copied from previous version http://git.rocketboards.org/u-boot-socfpga.git,
On Dec 17, 2015, at 11:45 PM, Chin Liang See clsee@altera.com wrote:
Hi Shengjiang,
On Fri, 2015-12-18 at 15:21 +0800, shengjiangwu wrote: Updated pinmux group MIXED1IO[15-20] for QSPI. Updated QSPI clock.
Signed-off-by: shengjiangwu shengjiangwu@icloud.com Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de --- board/altera/cyclone5-socdk/qts/pinmux_config.h | 12 ++++++------ board/altera/cyclone5-socdk/qts/pll_config.h | 4 ++-- 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/board/altera/cyclone5-socdk/qts/pinmux_config.h b/board/altera/cyclone5-socdk/qts/pinmux_config.h index 442b1e0..06783dc 100644 --- a/board/altera/cyclone5-socdk/qts/pinmux_config.h +++ b/board/altera/cyclone5-socdk/qts/pinmux_config.h @@ -87,12 +87,12 @@ const u8 sys_mgr_init_table[] = { 2, /* MIXED1IO12 */ 2, /* MIXED1IO13 */ 0, /* MIXED1IO14 */ - 1, /* MIXED1IO15 */ - 1, /* MIXED1IO16 */ - 1, /* MIXED1IO17 */ - 1, /* MIXED1IO18 */ - 0, /* MIXED1IO19 */ - 0, /* MIXED1IO20 */ + 3, /* MIXED1IO15 */ + 3, /* MIXED1IO16 */ + 3, /* MIXED1IO17 */ + 3, /* MIXED1IO18 */ + 3, /* MIXED1IO19 */ + 3, /* MIXED1IO20 */ 0, /* MIXED1IO21 */ 0, /* MIXED2IO0 */ 0, /* MIXED2IO1 */ diff --git a/board/altera/cyclone5-socdk/qts/pll_config.h b/board/altera/cyclone5-socdk/qts/pll_config.h index 42905f4..eccc705 100644 --- a/board/altera/cyclone5-socdk/qts/pll_config.h +++ b/board/altera/cyclone5-socdk/qts/pll_config.h @@ -14,7 +14,7 @@ #define CONFIG_HPS_MAINPLLGRP_MPUCLK_CNT 0 #define CONFIG_HPS_MAINPLLGRP_MAINCLK_CNT 0 #define CONFIG_HPS_MAINPLLGRP_DBGATCLK_CNT 0 -#define CONFIG_HPS_MAINPLLGRP_MAINQSPICLK_CNT 511 +#define CONFIG_HPS_MAINPLLGRP_MAINQSPICLK_CNT 3 #define CONFIG_HPS_MAINPLLGRP_MAINNANDSDMMCCLK_CNT 511 #define CONFIG_HPS_MAINPLLGRP_CFGS2FUSER0CLK_CNT 15 #define CONFIG_HPS_MAINPLLGRP_MAINDIV_L3MPCLK 1 @@ -32,7 +32,7 @@ #define CONFIG_HPS_PERPLLGRP_VCO_PSRC 0 #define CONFIG_HPS_PERPLLGRP_EMAC0CLK_CNT 3 #define CONFIG_HPS_PERPLLGRP_EMAC1CLK_CNT 3 -#define CONFIG_HPS_PERPLLGRP_PERQSPICLK_CNT 511 +#define CONFIG_HPS_PERPLLGRP_PERQSPICLK_CNT 1
Let's not change this as we are using mainpll for QSPI clock. Besides that, the QSPI perpll will yield 500MHz which exceed the 400MHz max clock.
Thanks Chin Liang
OK, I will restore CONFIG_HPS_PERPLLGRP_PERQSPICLK_CNT as 511
Thanks ShengjiangWu
#define CONFIG_HPS_PERPLLGRP_PERNANDSDMMCCLK_CNT 4 #define CONFIG_HPS_PERPLLGRP_PERBASECLK_CNT 4 #define CONFIG_HPS_PERPLLGRP_S2FUSER1CLK_CNT 511
On Friday, December 18, 2015 at 08:57:22 AM, 圣江 吴 wrote:
Hi Chin,
This stuff should be generated by quartus, so why are you copying it from some random version of u-boot somewhere ?
Best regards, Marek Vasut
圣江 吴
