[U-Boot-Users] [DNX#2006101142000031] [PATCH 1/2] Adding support for KS8993, KS8893, KS8 [...]
Hello list,
inside the automatic U-Boot patch tracking system a follow up to [DNX#2006101142000031] was entered through the web interface:
<snip>
Hello Mirco,
We are using KS8893 Ethernet switch with BF527. Pls let me know from where I can get this driver for KS8893 Ethernet switch
Thanks, TEL
DENX Support System wrote:
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006101142000031] was created:
<snip> > Hi, > > this patch adds support for Micrel's switches KS8893 and KS8993 and for > Micrel's PHYs KS8721 and KS8001. The drivers can be used with AT91RM9200 > based boards. > > Using these drivers requires to apply the CONFIG_PHY_ADDR patch that was > send to the list on 11.08.06. > > Best Regards > Mirco > > Signed-off-by: Mirco Fuchs mircofuchs@web.de > > CHANGELOG: > - Add support for Micrel's switches (KS8893 and KS8993) und Micrel's > PHYs (KS8721, KS8001) for AT91RM9200 based boards. > > diff --git a/cpu/arm920t/at91rm9200/Makefile > b/cpu/arm920t/at91rm9200/Makefile > index 8d4e478..7d50c22 100644 > --- a/cpu/arm920t/at91rm9200/Makefile > +++ b/cpu/arm920t/at91rm9200/Makefile > @@ -25,8 +25,8 @@ include $(TOPDIR)/config.mk > > LIB = $(obj)lib$(SOC).a > > -COBJS = bcm5221.o dm9161.o ether.o i2c.o interrupts.o \ > - lxt972.o serial.o usb_ohci.o > +COBJS = bcm5221.o dm9161.o ether.o i2c.o interrupts.o ks8893.o \ > + ks8993.o ks8xx1.o lxt972.o serial.o usb_ohci.o > SOBJS = lowlevel_init.o > > SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) > diff --git a/cpu/arm920t/at91rm9200/ks8893.c > b/cpu/arm920t/at91rm9200/ks8893.c > new file mode 100644 > index 0000000..d79d064 > --- /dev/null > +++ b/cpu/arm920t/at91rm9200/ks8893.c > @@ -0,0 +1,272 @@ > +/* > + * Driver for Micrel's KS8893 ethernet switch. The configuration of the > switch > + * uses the Serial Management Interface (SMI), modification of the > + * MII-Management Interface. > + * > + * (C) Copyright 2006 > + * Authors : > + * Udo Jakobza (jakobza@ftz-leipzig.de) > + * Mirco Fuchs (fuchs@ftz-leipzig.de) > + * > + * See file CREDITS for list of people who contributed to this > + * project. > + * > + * This program is free software; you can redistribute it and/or > + * modify it under the terms of the GNU General Public License as > + * published by the Free Software Foundation; either version 2 of > + * the License, or (at your option) any later version. > + * > + * This program is distributed in the hope that it will be useful, > + * but WITHOUT ANY WARRANTY; without even the implied warranty of > + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the > + * GNU General Public License for more details. > + * > + * You should have received a copy of the GNU General Public License > + * along with this program; if not, write to the Free Software > + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, > + * MA 02111-1307 USA > + */ > + > +#include <at91rm9200_net.h> > +#include <net.h> > +#include <ks8893.h> > + > +#ifdef CONFIG_DRIVER_ETHER > + > +#if (CONFIG_COMMANDS & CFG_CMD_NET) > + > +/* > + * Name: > + * ks8893_SmiReadPhy > + * Description:ETHER_MD_CA_ADDR_MSK
</snip>
Your U-Boot support team
DENX Support System
