[U-Boot] [PATCH v3.1 1/9] sunxi: clk: add MMC gates/resets
Add the MMC clock gates and reset bits for all the Allwinner SoCs. This allows them to be used by the MMC driver.
We don't advertise the mod clock yet, as this is still handled by the MMC driver.
Signed-off-by: Andre Przywara andre.przywara@arm.com [jagan: add V3S, A80 gates/resets] Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3.1: - revert CLK_AHB1_MMC3 bit to 11 - add A80 gate clocks and reset bits
drivers/clk/sunxi/clk_a10.c | 4 ++++ drivers/clk/sunxi/clk_a10s.c | 3 +++ drivers/clk/sunxi/clk_a23.c | 6 ++++++ drivers/clk/sunxi/clk_a31.c | 8 ++++++++ drivers/clk/sunxi/clk_a64.c | 6 ++++++ drivers/clk/sunxi/clk_a80.c | 4 ++++ drivers/clk/sunxi/clk_a83t.c | 6 ++++++ drivers/clk/sunxi/clk_h3.c | 6 ++++++ drivers/clk/sunxi/clk_h6.c | 6 ++++++ drivers/clk/sunxi/clk_r40.c | 8 ++++++++ drivers/clk/sunxi/clk_v3s.c | 6 ++++++ 11 files changed, 63 insertions(+)
diff --git a/drivers/clk/sunxi/clk_a10.c b/drivers/clk/sunxi/clk_a10.c index b00f51af8b..2aa41efe17 100644 --- a/drivers/clk/sunxi/clk_a10.c +++ b/drivers/clk/sunxi/clk_a10.c @@ -18,6 +18,10 @@ static struct ccu_clk_gate a10_gates[] = { [CLK_AHB_OHCI0] = GATE(0x060, BIT(2)), [CLK_AHB_EHCI1] = GATE(0x060, BIT(3)), [CLK_AHB_OHCI1] = GATE(0x060, BIT(4)), + [CLK_AHB_MMC0] = GATE(0x060, BIT(8)), + [CLK_AHB_MMC1] = GATE(0x060, BIT(9)), + [CLK_AHB_MMC2] = GATE(0x060, BIT(10)), + [CLK_AHB_MMC3] = GATE(0x060, BIT(11)),
[CLK_APB1_UART0] = GATE(0x06c, BIT(16)), [CLK_APB1_UART1] = GATE(0x06c, BIT(17)), diff --git a/drivers/clk/sunxi/clk_a10s.c b/drivers/clk/sunxi/clk_a10s.c index aa904ce067..87b74e52dc 100644 --- a/drivers/clk/sunxi/clk_a10s.c +++ b/drivers/clk/sunxi/clk_a10s.c @@ -16,6 +16,9 @@ static struct ccu_clk_gate a10s_gates[] = { [CLK_AHB_OTG] = GATE(0x060, BIT(0)), [CLK_AHB_EHCI] = GATE(0x060, BIT(1)), [CLK_AHB_OHCI] = GATE(0x060, BIT(2)), + [CLK_AHB_MMC0] = GATE(0x060, BIT(8)), + [CLK_AHB_MMC1] = GATE(0x060, BIT(9)), + [CLK_AHB_MMC2] = GATE(0x060, BIT(10)),
[CLK_APB1_UART0] = GATE(0x06c, BIT(16)), [CLK_APB1_UART1] = GATE(0x06c, BIT(17)), diff --git a/drivers/clk/sunxi/clk_a23.c b/drivers/clk/sunxi/clk_a23.c index 854259bf81..1ef2359286 100644 --- a/drivers/clk/sunxi/clk_a23.c +++ b/drivers/clk/sunxi/clk_a23.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun8i-a23-a33-ccu.h>
static struct ccu_clk_gate a23_gates[] = { + [CLK_BUS_MMC0] = GATE(0x060, BIT(8)), + [CLK_BUS_MMC1] = GATE(0x060, BIT(9)), + [CLK_BUS_MMC2] = GATE(0x060, BIT(10)), [CLK_BUS_OTG] = GATE(0x060, BIT(24)), [CLK_BUS_EHCI] = GATE(0x060, BIT(26)), [CLK_BUS_OHCI] = GATE(0x060, BIT(29)), @@ -35,6 +38,9 @@ static struct ccu_reset a23_resets[] = { [RST_USB_PHY1] = RESET(0x0cc, BIT(1)), [RST_USB_HSIC] = RESET(0x0cc, BIT(2)),
+ [RST_BUS_MMC0] = RESET(0x2c0, BIT(8)), + [RST_BUS_MMC1] = RESET(0x2c0, BIT(9)), + [RST_BUS_MMC2] = RESET(0x2c0, BIT(10)), [RST_BUS_OTG] = RESET(0x2c0, BIT(24)), [RST_BUS_EHCI] = RESET(0x2c0, BIT(26)), [RST_BUS_OHCI] = RESET(0x2c0, BIT(29)), diff --git a/drivers/clk/sunxi/clk_a31.c b/drivers/clk/sunxi/clk_a31.c index a38d76cb7c..5bd8b7dccc 100644 --- a/drivers/clk/sunxi/clk_a31.c +++ b/drivers/clk/sunxi/clk_a31.c @@ -13,6 +13,10 @@ #include <dt-bindings/reset/sun6i-a31-ccu.h>
static struct ccu_clk_gate a31_gates[] = { + [CLK_AHB1_MMC0] = GATE(0x060, BIT(8)), + [CLK_AHB1_MMC1] = GATE(0x060, BIT(9)), + [CLK_AHB1_MMC2] = GATE(0x060, BIT(10)), + [CLK_AHB1_MMC3] = GATE(0x060, BIT(11)), [CLK_AHB1_OTG] = GATE(0x060, BIT(24)), [CLK_AHB1_EHCI0] = GATE(0x060, BIT(26)), [CLK_AHB1_EHCI1] = GATE(0x060, BIT(27)), @@ -40,6 +44,10 @@ static struct ccu_reset a31_resets[] = { [RST_USB_PHY1] = RESET(0x0cc, BIT(1)), [RST_USB_PHY2] = RESET(0x0cc, BIT(2)),
+ [RST_AHB1_MMC0] = RESET(0x2c0, BIT(8)), + [RST_AHB1_MMC1] = RESET(0x2c0, BIT(9)), + [RST_AHB1_MMC2] = RESET(0x2c0, BIT(10)), + [RST_AHB1_MMC3] = RESET(0x2c0, BIT(11)), [RST_AHB1_OTG] = RESET(0x2c0, BIT(24)), [RST_AHB1_EHCI0] = RESET(0x2c0, BIT(26)), [RST_AHB1_EHCI1] = RESET(0x2c0, BIT(27)), diff --git a/drivers/clk/sunxi/clk_a64.c b/drivers/clk/sunxi/clk_a64.c index a2ba6eefc5..910275fbce 100644 --- a/drivers/clk/sunxi/clk_a64.c +++ b/drivers/clk/sunxi/clk_a64.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun50i-a64-ccu.h>
static const struct ccu_clk_gate a64_gates[] = { + [CLK_BUS_MMC0] = GATE(0x060, BIT(8)), + [CLK_BUS_MMC1] = GATE(0x060, BIT(9)), + [CLK_BUS_MMC2] = GATE(0x060, BIT(10)), [CLK_BUS_OTG] = GATE(0x060, BIT(23)), [CLK_BUS_EHCI0] = GATE(0x060, BIT(24)), [CLK_BUS_EHCI1] = GATE(0x060, BIT(25)), @@ -38,6 +41,9 @@ static const struct ccu_reset a64_resets[] = { [RST_USB_PHY1] = RESET(0x0cc, BIT(1)), [RST_USB_HSIC] = RESET(0x0cc, BIT(2)),
+ [RST_BUS_MMC0] = RESET(0x2c0, BIT(8)), + [RST_BUS_MMC1] = RESET(0x2c0, BIT(9)), + [RST_BUS_MMC2] = RESET(0x2c0, BIT(10)), [RST_BUS_OTG] = RESET(0x2c0, BIT(23)), [RST_BUS_EHCI0] = RESET(0x2c0, BIT(24)), [RST_BUS_EHCI1] = RESET(0x2c0, BIT(25)), diff --git a/drivers/clk/sunxi/clk_a80.c b/drivers/clk/sunxi/clk_a80.c index d6dd6a1fa1..d4bfb0a98b 100644 --- a/drivers/clk/sunxi/clk_a80.c +++ b/drivers/clk/sunxi/clk_a80.c @@ -13,6 +13,8 @@ #include <dt-bindings/reset/sun9i-a80-ccu.h>
static const struct ccu_clk_gate a80_gates[] = { + [CLK_BUS_MMC] = GATE(0x580, BIT(8)), + [CLK_BUS_UART0] = GATE(0x594, BIT(16)), [CLK_BUS_UART1] = GATE(0x594, BIT(17)), [CLK_BUS_UART2] = GATE(0x594, BIT(18)), @@ -22,6 +24,8 @@ static const struct ccu_clk_gate a80_gates[] = { };
static const struct ccu_reset a80_resets[] = { + [RST_BUS_MMC] = RESET(0x5a0, BIT(8)), + [RST_BUS_UART0] = RESET(0x5b4, BIT(16)), [RST_BUS_UART1] = RESET(0x5b4, BIT(17)), [RST_BUS_UART2] = RESET(0x5b4, BIT(18)), diff --git a/drivers/clk/sunxi/clk_a83t.c b/drivers/clk/sunxi/clk_a83t.c index 1ef6ac5b25..b5a555da36 100644 --- a/drivers/clk/sunxi/clk_a83t.c +++ b/drivers/clk/sunxi/clk_a83t.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun8i-a83t-ccu.h>
static struct ccu_clk_gate a83t_gates[] = { + [CLK_BUS_MMC0] = GATE(0x060, BIT(8)), + [CLK_BUS_MMC1] = GATE(0x060, BIT(9)), + [CLK_BUS_MMC2] = GATE(0x060, BIT(10)), [CLK_BUS_OTG] = GATE(0x060, BIT(24)), [CLK_BUS_EHCI0] = GATE(0x060, BIT(26)), [CLK_BUS_EHCI1] = GATE(0x060, BIT(27)), @@ -36,6 +39,9 @@ static struct ccu_reset a83t_resets[] = { [RST_USB_PHY1] = RESET(0x0cc, BIT(1)), [RST_USB_HSIC] = RESET(0x0cc, BIT(2)),
+ [RST_BUS_MMC0] = RESET(0x2c0, BIT(8)), + [RST_BUS_MMC1] = RESET(0x2c0, BIT(9)), + [RST_BUS_MMC2] = RESET(0x2c0, BIT(10)), [RST_BUS_OTG] = RESET(0x2c0, BIT(24)), [RST_BUS_EHCI0] = RESET(0x2c0, BIT(26)), [RST_BUS_EHCI1] = RESET(0x2c0, BIT(27)), diff --git a/drivers/clk/sunxi/clk_h3.c b/drivers/clk/sunxi/clk_h3.c index f82949b3b6..98af372ec5 100644 --- a/drivers/clk/sunxi/clk_h3.c +++ b/drivers/clk/sunxi/clk_h3.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun8i-h3-ccu.h>
static struct ccu_clk_gate h3_gates[] = { + [CLK_BUS_MMC0] = GATE(0x060, BIT(8)), + [CLK_BUS_MMC1] = GATE(0x060, BIT(9)), + [CLK_BUS_MMC2] = GATE(0x060, BIT(10)), [CLK_BUS_OTG] = GATE(0x060, BIT(23)), [CLK_BUS_EHCI0] = GATE(0x060, BIT(24)), [CLK_BUS_EHCI1] = GATE(0x060, BIT(25)), @@ -44,6 +47,9 @@ static struct ccu_reset h3_resets[] = { [RST_USB_PHY2] = RESET(0x0cc, BIT(2)), [RST_USB_PHY3] = RESET(0x0cc, BIT(3)),
+ [RST_BUS_MMC0] = RESET(0x2c0, BIT(8)), + [RST_BUS_MMC0] = RESET(0x2c0, BIT(9)), + [RST_BUS_MMC0] = RESET(0x2c0, BIT(10)), [RST_BUS_OTG] = RESET(0x2c0, BIT(23)), [RST_BUS_EHCI0] = RESET(0x2c0, BIT(24)), [RST_BUS_EHCI1] = RESET(0x2c0, BIT(25)), diff --git a/drivers/clk/sunxi/clk_h6.c b/drivers/clk/sunxi/clk_h6.c index 0da3a40e3d..902612da91 100644 --- a/drivers/clk/sunxi/clk_h6.c +++ b/drivers/clk/sunxi/clk_h6.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun50i-h6-ccu.h>
static struct ccu_clk_gate h6_gates[] = { + [CLK_BUS_MMC0] = GATE(0x84c, BIT(0)), + [CLK_BUS_MMC1] = GATE(0x84c, BIT(1)), + [CLK_BUS_MMC2] = GATE(0x84c, BIT(2)), [CLK_BUS_UART0] = GATE(0x90c, BIT(0)), [CLK_BUS_UART1] = GATE(0x90c, BIT(1)), [CLK_BUS_UART2] = GATE(0x90c, BIT(2)), @@ -20,6 +23,9 @@ static struct ccu_clk_gate h6_gates[] = { };
static struct ccu_reset h6_resets[] = { + [RST_BUS_MMC0] = RESET(0x84c, BIT(16)), + [RST_BUS_MMC1] = RESET(0x84c, BIT(17)), + [RST_BUS_MMC2] = RESET(0x84c, BIT(18)), [RST_BUS_UART0] = RESET(0x90c, BIT(16)), [RST_BUS_UART1] = RESET(0x90c, BIT(17)), [RST_BUS_UART2] = RESET(0x90c, BIT(18)), diff --git a/drivers/clk/sunxi/clk_r40.c b/drivers/clk/sunxi/clk_r40.c index fd7aae97ea..b9457e1971 100644 --- a/drivers/clk/sunxi/clk_r40.c +++ b/drivers/clk/sunxi/clk_r40.c @@ -13,6 +13,10 @@ #include <dt-bindings/reset/sun8i-r40-ccu.h>
static struct ccu_clk_gate r40_gates[] = { + [CLK_BUS_MMC0] = GATE(0x060, BIT(8)), + [CLK_BUS_MMC1] = GATE(0x060, BIT(9)), + [CLK_BUS_MMC2] = GATE(0x060, BIT(10)), + [CLK_BUS_MMC3] = GATE(0x060, BIT(11)), [CLK_BUS_OTG] = GATE(0x060, BIT(25)), [CLK_BUS_EHCI0] = GATE(0x060, BIT(26)), [CLK_BUS_EHCI1] = GATE(0x060, BIT(27)), @@ -43,6 +47,10 @@ static struct ccu_reset r40_resets[] = { [RST_USB_PHY1] = RESET(0x0cc, BIT(1)), [RST_USB_PHY2] = RESET(0x0cc, BIT(2)),
+ [RST_BUS_MMC0] = RESET(0x2c0, BIT(8)), + [RST_BUS_MMC1] = RESET(0x2c0, BIT(9)), + [RST_BUS_MMC2] = RESET(0x2c0, BIT(10)), + [RST_BUS_MMC3] = RESET(0x2c0, BIT(11)), [RST_BUS_OTG] = RESET(0x2c0, BIT(25)), [RST_BUS_EHCI0] = RESET(0x2c0, BIT(26)), [RST_BUS_EHCI1] = RESET(0x2c0, BIT(27)), diff --git a/drivers/clk/sunxi/clk_v3s.c b/drivers/clk/sunxi/clk_v3s.c index 25ad87500e..c8a9027889 100644 --- a/drivers/clk/sunxi/clk_v3s.c +++ b/drivers/clk/sunxi/clk_v3s.c @@ -13,6 +13,9 @@ #include <dt-bindings/reset/sun8i-v3s-ccu.h>
static struct ccu_clk_gate v3s_gates[] = { + [CLK_BUS_MMC0] = GATE(0x060, BIT(8)), + [CLK_BUS_MMC1] = GATE(0x060, BIT(9)), + [CLK_BUS_MMC2] = GATE(0x060, BIT(10)), [CLK_BUS_OTG] = GATE(0x060, BIT(24)),
[CLK_BUS_UART0] = GATE(0x06c, BIT(16)), @@ -25,6 +28,9 @@ static struct ccu_clk_gate v3s_gates[] = { static struct ccu_reset v3s_resets[] = { [RST_USB_PHY0] = RESET(0x0cc, BIT(0)),
[RST_BUS_UART0] = RESET(0x2d8, BIT(16)),
On Fri, 25 Jan 2019 13:54:50 +0530 Jagan Teki jagan@amarulasolutions.com wrote:
Thanks for adding this. While reviewing my own stuff ;-) I found a copy & paste bug in the H3 reset section below ...
Changes for v3.1:
- [CLK_BUS_MMC0] = GATE(0x060, BIT(8)),
- [CLK_BUS_MMC1] = GATE(0x060, BIT(9)),
- [CLK_BUS_MMC2] = GATE(0x060, BIT(10)), [CLK_BUS_OTG] = GATE(0x060, BIT(24)), [CLK_BUS_EHCI] = GATE(0x060, BIT(26)), [CLK_BUS_OHCI] = GATE(0x060, BIT(29)),
- [RST_BUS_MMC0] = RESET(0x2c0, BIT(8)),
- [RST_BUS_MMC1] = RESET(0x2c0, BIT(9)),
- [RST_BUS_MMC2] = RESET(0x2c0, BIT(10)), [RST_BUS_OTG] = RESET(0x2c0, BIT(24)), [RST_BUS_EHCI] = RESET(0x2c0, BIT(26)), [RST_BUS_OHCI] = RESET(0x2c0, BIT(29)),
- [CLK_AHB1_MMC0] = GATE(0x060, BIT(8)),
- [CLK_AHB1_MMC1] = GATE(0x060, BIT(9)),
- [CLK_AHB1_MMC2] = GATE(0x060, BIT(10)),
- [CLK_AHB1_MMC3] = GATE(0x060, BIT(11)), [CLK_AHB1_OTG] = GATE(0x060, BIT(24)), [CLK_AHB1_EHCI0] = GATE(0x060, BIT(26)), [CLK_AHB1_EHCI1] = GATE(0x060, BIT(27)),
- [RST_AHB1_MMC0] = RESET(0x2c0, BIT(8)),
- [RST_AHB1_MMC1] = RESET(0x2c0, BIT(9)),
- [RST_AHB1_MMC2] = RESET(0x2c0, BIT(10)),
- [RST_AHB1_MMC3] = RESET(0x2c0, BIT(11)), [RST_AHB1_OTG] = RESET(0x2c0, BIT(24)), [RST_AHB1_EHCI0] = RESET(0x2c0, BIT(26)), [RST_AHB1_EHCI1] = RESET(0x2c0, BIT(27)),
- [CLK_BUS_MMC2] = GATE(0x060, BIT(10)), [CLK_BUS_OTG] = GATE(0x060, BIT(23)), [CLK_BUS_EHCI0] = GATE(0x060, BIT(24)), [CLK_BUS_EHCI1] = GATE(0x060, BIT(25)),
- [RST_BUS_MMC2] = RESET(0x2c0, BIT(10)), [RST_BUS_OTG] = RESET(0x2c0, BIT(23)), [RST_BUS_EHCI0] = RESET(0x2c0, BIT(24)), [RST_BUS_EHCI1] = RESET(0x2c0, BIT(25)),
- [CLK_BUS_MMC] = GATE(0x580, BIT(8)),
- [CLK_BUS_UART0] = GATE(0x594, BIT(16)), [CLK_BUS_UART1] = GATE(0x594, BIT(17)), [CLK_BUS_UART2] = GATE(0x594, BIT(18)),
- [RST_BUS_MMC] = RESET(0x5a0, BIT(8)),
- [RST_BUS_UART0] = RESET(0x5b4, BIT(16)), [RST_BUS_UART1] = RESET(0x5b4, BIT(17)), [RST_BUS_UART2] = RESET(0x5b4, BIT(18)),
- [CLK_BUS_MMC2] = GATE(0x060, BIT(10)), [CLK_BUS_OTG] = GATE(0x060, BIT(24)), [CLK_BUS_EHCI0] = GATE(0x060, BIT(26)), [CLK_BUS_EHCI1] = GATE(0x060, BIT(27)),
- [RST_BUS_MMC2] = RESET(0x2c0, BIT(10)), [RST_BUS_OTG] = RESET(0x2c0, BIT(24)), [RST_BUS_EHCI0] = RESET(0x2c0, BIT(26)), [RST_BUS_EHCI1] = RESET(0x2c0, BIT(27)),
- [RST_BUS_MMC0] = RESET(0x2c0, BIT(9)),
- [RST_BUS_MMC0] = RESET(0x2c0, BIT(10)),
Doh. yypp:x ;-)
Jagan, can you please fix this up?
Cheers, Andre.
- [CLK_BUS_MMC0] = GATE(0x84c, BIT(0)),
- [CLK_BUS_MMC1] = GATE(0x84c, BIT(1)),
- [CLK_BUS_MMC2] = GATE(0x84c, BIT(2)), [CLK_BUS_UART0] = GATE(0x90c, BIT(0)), [CLK_BUS_UART1] = GATE(0x90c, BIT(1)), [CLK_BUS_UART2] = GATE(0x90c, BIT(2)),
- [RST_BUS_MMC0] = RESET(0x84c, BIT(16)),
- [RST_BUS_MMC1] = RESET(0x84c, BIT(17)),
- [RST_BUS_MMC2] = RESET(0x84c, BIT(18)), [RST_BUS_UART0] = RESET(0x90c, BIT(16)), [RST_BUS_UART1] = RESET(0x90c, BIT(17)), [RST_BUS_UART2] = RESET(0x90c, BIT(18)),
- [CLK_BUS_MMC3] = GATE(0x060, BIT(11)), [CLK_BUS_OTG] = GATE(0x060, BIT(25)), [CLK_BUS_EHCI0] = GATE(0x060, BIT(26)), [CLK_BUS_EHCI1] = GATE(0x060, BIT(27)),
- [RST_BUS_MMC3] = RESET(0x2c0, BIT(11)), [RST_BUS_OTG] = RESET(0x2c0, BIT(25)), [RST_BUS_EHCI0] = RESET(0x2c0, BIT(26)), [RST_BUS_EHCI1] = RESET(0x2c0, BIT(27)),
Andre Przywara
Jagan Teki
