Hello Custodians and Mailing List Aficionados,
I don't know if anyone has noticed, but patchwork is starting to collect a rather large amount of cruft.
I occasionally jump onto patchwork and do a little housekeeping by marking updated patches as 'Superceeded' and anything applied by Wolfgang as 'Accepted' (There may be a few patches that have been applied to custodian tress that I marked as 'Accepted' when really they should have been marked as 'Awaiting Upstream')
I really don't mind doing this housekeeping, but I would like to make a few suggestions that will make the work a little easier:
- If you are a custodian: o When you apply a patch to your repo, can you please assign it to yourself in patchwork and set it to 'Awaiting Upstream' o Reply to the ML with 'Applied to <repo>/<branch>' o When you send a pull request, create a bundle with all the patches that are to be pulled (you can create the bundle early and add patches as you apply them) o When Wolfgang pulls your repo, go to the bundle and mark all the patches 'Accepted'
- If you are a patch submitter: o Visit http://patchwork.ozlabs.org/project/uboot/list/ o Search for your patches by following the 'Filters'link and entering your name o Send and email (with 'patchwork' somewhere in the subject) to the ML with a list of patches that you submitted say more than one month ago. For each patch, please indicate if the patch is: * Superseded - By another patch (either by you or someone else) * Not Applicable - The patch can be ignored (was an RFC, was due to a misunderstanding, another patch did the same thing, etc) * Applied - Has been applied (state the repo and branch) * Rejected - Patch has been officially rejected * Waiting - You believe the patch is still valid but has not been applied (send a ping as a reply to the patch on the mailing list as well * Other - Please describe what state you feel the patch is in
Once I get the raw list down to a manageable level, I'll start to look at the leftovers...
Regards,
"Your friendly Patchwork janitor" Graeme
Dear Graeme Russ,
WAT ? Yet another ruleset ... and a long one while at that. Maybe we should cobble together an "U-Boot contributors guidebook" ... printed edition with 1k pages ;-D
We really need to make it easier for people to contribute to u-boot, these long rulesets only ward people away.
Regards,
Best regards, Marek Vasut
Hi Marek,
On 03/22/2012 05:45 PM, Marek Vasut wrote:
Dear Graeme Russ,
The submission rules (http://www.denx.de/wiki/U-Boot/Patches) are pretty clear and concise (I've added a not about starting the subject with a tag)
This patchwork cleanup should really only be a once off to try and get things cleaned up a bit. There are patches in patchwork from 2009, if we can get some of the stale patches cleaned out (and contact the submitters to see if they are interested in resubmitting or verifying re-based patches) then we will all be better off.
Nothing is more discouraging to patch submitters than patches that get ignored.
Regards,
Graeme
Dear Graeme Russ,
Hi Marek,
Dear Graeme Russ,
patches 'Accepted'
your name
Some distilled down version for first-time comers won't hurt of that page.
Agreed
Yes
Regards,
Graeme
Thanks for working on this, Graeme, I really appreciate that
Do we, or do we not have the magic "update patchwork when the master repo gets a patch" hook setup? It's not fool-proof, but it works well.
Where does one find this?
-M
I'm just a user over in OpenEmbedded-land where it's in use. Khem?
Yes. I am the one who set it up on OE. Its setup as post-receive hook. I am attaching the sample to this mail.
Thanks -Khem
A while back I recall it being established that patches should be marked "accepted" when they go into the custodian repo -- has this changed?
-Scott
Hi Graeme,
If you are a custodian: o When you apply a patch to your repo, can you please assign it to yourself in patchwork and set it to 'Awaiting Upstream' o Reply to the ML with 'Applied to<repo>/<branch>' o When you send a pull request, create a bundle with all the patches that are to be pulled (you can create the bundle early and add patches as you apply them) o When Wolfgang pulls your repo, go to the bundle and mark all the patches 'Accepted'
http://patchwork.ozlabs.org/patch/135526/ http://patchwork.ozlabs.org/patch/135699/ http://patchwork.ozlabs.org/patch/135697/ http://patchwork.ozlabs.org/patch/135698/
That's the list of patches sent in January, still no progress.
I marked the patches as `awaiting upstream'.
-- With best wishes, Vladimir
On Mar 26, 2012, at 12:30 PM, Vladimir Zapolskiy wrote:
Hi Graeme,
Awaiting upstream means that the patches have been applied already, and are waiting for Wolfgang's pull. I suspect this is not the case for your patches. If it is the case, then there's probably no need to mention it, as Wolfgang will eventually pull that tree.
Andy
Hi Graeme,
Thanks for correction, I haven't found literally a state `Waiting' among options as it was recommended by Graeme, however I have to change it certainly.
Should it be `Under Review' or which state, if a patch is valid, but hasn't been applied yet?
-- Vladimir
participants (8)
Andy Fleming
Graeme Russ
Khem Raj
Scott Wood
Vladimir Zapolskiy
