[PATCH v3 0/4] rockchip: sdhci: Fix reinit and add HS400 Enhanced Strobe support
My rk3399-gru-kevin has some problems with the eMMC. The board can boot to U-Boot proper with the eMMC working at a low speed, but trying to reinitialize it with "mmc dev 0" or "mmc rescan" makes it unusable. If the HS400 mode is enabled, it times out while executing tuning and doesn't even start at a working state.
To work around these errors, I had implemented support for the HS400 Enhanced Strobe mode as the first version of this series. I have also managed the fix the issue above (related to power-cycling the eMMC PHY), which exposed another one with this series: reinitialization at lower speeds fail if the ES bit is set. Since fixing that needed changes to this series I decided to send the previous fix as part of this instead of as an independent patch.
To test, I'm building with the following configs enabled:
+CONFIG_MMC_SPEED_MODE_SET=y [...] CONFIG_MMC_PWRSEQ=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS400_ES_SUPPORT=y +CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y
and running roughly:
$ mmc rescan [0|1|3|10|11|12] $ mmc info $ mmc part $ load mmc 0:1 0xd0000000 256MiB.bin $ load mmc 0:1 0xd0000000 16MiB.bin $ load mmc 0:1 0xd0000000 8MiB.bin
I used to test by loading different sizes from a very big file (~7GiB), but that's slower than reading fixed-size files for some reason I don't know. I thought loading full files would be a better test so I switched to those. Here's the differences in info and speeds I get with this:
Mode | Bus Speed | Bus Width -----------------------+--------------+-------------- MMC Legacy | 25000000 | 8-bit MMC High Speed (26MHz) | 26000000 | 8-bit MMC High Speed (52MHz) | 52000000 | 8-bit HS200 (200MHz) | 200000000 | 8-bit HS400 (200MHz) | 200000000 | 8-bit DDR HS400ES (200MHz) | 200000000 | 8-bit DDR
Mode | 256 MiB Load | 16 MiB Load | 8 MiB Load -----------------------+--------------+--------------+-------------- MMC Legacy | ~22.1 MiB/s | ~21.9 MiB/s | ~21.6 MiB/s MMC High Speed (26MHz) | ~22.1 MiB/s | ~21.9 MiB/s | ~21.6 MiB/s MMC High Speed (52MHz) | ~43.7 MiB/s | ~42.8 MiB/s | ~41.7 MiB/s HS200 (200MHz) | ~161.2 MiB/s | ~149.5 MiB/s | ~137.9 MiB/s HS400 (200MHz) | ~254.5 MiB/s | ~235.3 MiB/s | ~216.2 MiB/s HS400ES (200MHz) | ~254.7 MiB/s | ~238.8 MiB/s | ~216.2 MiB/s
Hope I haven't missed anything. Enabling the configs above for each board is left to board maintainers as I can't test on those boards.
As an aside, I want to further clean up this driver when I have the time (it's a weird combination of what could be three different drivers), but wanted to send this as it at least gets the driver to a working state.
Changes in v3: - Set DWCMSHC_CARD_IS_EMMC bit in rk3568_emmc_phy_init()
v2: https://patchwork.ozlabs.org/project/uboot/list/?series=280494
Changes in v2: - Add patch to fix PHY power cycling at higher speeds - Unset ES bit in rk3399 set_control_reg() to fix a reinit issue - Don't use unnecessary & for function pointer in ops struct - Rename rk3399_set_enhanced_strobe -> rk3399_sdhci_set_enhanced_strobe - Rename rk3568_set_enhanced_strobe -> rk3568_sdhci_set_enhanced_strobe - Let set_enhanced_strobe() unset the ES bit if mode is not HS400_ES - Rewrote cover letter
v1: https://patchwork.ozlabs.org/project/uboot/list/?series=269768
Alper Nebi Yasak (4): mmc: sdhci: Add HS400 Enhanced Strobe support rockchip: sdhci: Fix RK3399 eMMC PHY power cycling rockchip: sdhci: Add HS400 Enhanced Strobe support for RK3399 rockchip: sdhci: Add HS400 Enhanced Strobe support for RK3568
drivers/mmc/rockchip_sdhci.c | 136 ++++++++++++++++++++++++++++++++--- drivers/mmc/sdhci.c | 18 +++++ include/sdhci.h | 1 + 3 files changed, 145 insertions(+), 10 deletions(-)
Delegate setting the Enhanced Strobe configuration to individual drivers if they set a function for it. Return -ENOTSUPP if they do not, like what the MMC uclass does.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com ---
(no changes since v2)
Changes in v2: - Add tag: "Reviewed-by: Jaehoon Chung jh80.chung@samsung.com"
drivers/mmc/sdhci.c | 18 ++++++++++++++++++ include/sdhci.h | 1 + 2 files changed, 19 insertions(+)
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 766e4a6b0c5e..bf989a594f7e 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -513,6 +513,7 @@ void sdhci_set_uhs_timing(struct sdhci_host *host) reg |= SDHCI_CTRL_UHS_SDR104; break; case MMC_HS_400: + case MMC_HS_400_ES: reg |= SDHCI_CTRL_HS400; break; default: @@ -666,6 +667,7 @@ static int sdhci_set_ios(struct mmc *mmc) mmc->selected_mode == MMC_DDR_52 || mmc->selected_mode == MMC_HS_200 || mmc->selected_mode == MMC_HS_400 || + mmc->selected_mode == MMC_HS_400_ES || mmc->selected_mode == UHS_SDR25 || mmc->selected_mode == UHS_SDR50 || mmc->selected_mode == UHS_SDR104 || @@ -799,6 +801,19 @@ static int sdhci_wait_dat0(struct udevice *dev, int state, return -ETIMEDOUT; }
+#if CONFIG_IS_ENABLED(MMC_HS400_ES_SUPPORT) +static int sdhci_set_enhanced_strobe(struct udevice *dev) +{ + struct mmc *mmc = mmc_get_mmc_dev(dev); + struct sdhci_host *host = mmc->priv; + + if (host->ops && host->ops->set_enhanced_strobe) + return host->ops->set_enhanced_strobe(host); + + return -ENOTSUPP; +} +#endif + const struct dm_mmc_ops sdhci_ops = { .send_cmd = sdhci_send_command, .set_ios = sdhci_set_ios, @@ -808,6 +823,9 @@ const struct dm_mmc_ops sdhci_ops = { .execute_tuning = sdhci_execute_tuning, #endif .wait_dat0 = sdhci_wait_dat0, +#if CONFIG_IS_ENABLED(MMC_HS400_ES_SUPPORT) + .set_enhanced_strobe = sdhci_set_enhanced_strobe, +#endif }; #else static const struct mmc_ops sdhci_ops = { diff --git a/include/sdhci.h b/include/sdhci.h index c718dd7206c1..7a65fdf95d30 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -272,6 +272,7 @@ struct sdhci_ops { int (*platform_execute_tuning)(struct mmc *host, u8 opcode); int (*set_delay)(struct sdhci_host *host); int (*deferred_probe)(struct sdhci_host *host); + int (*set_enhanced_strobe)(struct sdhci_host *host); };
#define ADMA_MAX_LEN 65532
The Rockchip RK3399 eMMC PHY has to be power-cycled while changing its clock speed to some higher speeds. This is dependent on the desired SDHCI clock speed, and it looks like the PHY should be powered off while setting the SDHCI clock in these cases.
Commit ac804143cfd1 ("mmc: rockchip_sdhci: add phy and clock config for rk3399") attempts to do this in the set_ios_post() hook by setting the SDHCI clock once more while the PHY is turned off/on as necessary, as the SDHCI framework does not provide a way to override how it sets its clock. However, the commit breaks reinitializing the eMMC on a few boards including chromebook_kevin and reportedly ROCKPro64.
This patch reworks the power cycling to utilize the SDHCI framework slightly better (using the set_control_reg() hook to power off the PHY and set_ios_post() hook to power it back on) which happens to fix the issue, at least on a chromebook_kevin.
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- RK3568 parts only build-tested as I don't have a RK3568 board.
Changes in v2: - Add this patch
drivers/mmc/rockchip_sdhci.c | 53 +++++++++++++++++++++++++++++------- 1 file changed, 43 insertions(+), 10 deletions(-)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index 278473899c7c..f0d7ba4774d6 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -90,9 +90,10 @@ struct rockchip_sdhc { };
struct sdhci_data { - int (*emmc_set_clock)(struct sdhci_host *host, unsigned int clock); int (*emmc_phy_init)(struct udevice *dev); int (*get_phy)(struct udevice *dev); + void (*set_control_reg)(struct sdhci_host *host); + int (*set_ios_post)(struct sdhci_host *host); };
static int rk3399_emmc_phy_init(struct udevice *dev) @@ -182,15 +183,28 @@ static int rk3399_emmc_get_phy(struct udevice *dev) return 0; }
-static int rk3399_sdhci_emmc_set_clock(struct sdhci_host *host, unsigned int clock) +static void rk3399_sdhci_set_control_reg(struct sdhci_host *host) { struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); + struct mmc *mmc = host->mmc; + uint clock = mmc->tran_speed; int cycle_phy = host->clock != clock && clock > EMMC_MIN_FREQ;
if (cycle_phy) rk3399_emmc_phy_power_off(priv->phy);
- sdhci_set_clock(host->mmc, clock); + sdhci_set_control_reg(host); +}; + +static int rk3399_sdhci_set_ios_post(struct sdhci_host *host) +{ + struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); + struct mmc *mmc = host->mmc; + uint clock = mmc->tran_speed; + int cycle_phy = host->clock != clock && clock > EMMC_MIN_FREQ; + + if (!clock) + clock = mmc->clock;
if (cycle_phy) rk3399_emmc_phy_power_on(priv->phy, clock); @@ -269,10 +283,8 @@ static int rk3568_emmc_get_phy(struct udevice *dev) return 0; }
-static int rockchip_sdhci_set_ios_post(struct sdhci_host *host) +static int rk3568_sdhci_set_ios_post(struct sdhci_host *host) { - struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); - struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(priv->dev); struct mmc *mmc = host->mmc; uint clock = mmc->tran_speed; u32 reg; @@ -280,8 +292,7 @@ static int rockchip_sdhci_set_ios_post(struct sdhci_host *host) if (!clock) clock = mmc->clock;
- if (data->emmc_set_clock) - data->emmc_set_clock(host, clock); + rk3568_sdhci_emmc_set_clock(host, clock);
if (mmc->selected_mode == MMC_HS_400 || mmc->selected_mode == MMC_HS_400_ES) { reg = sdhci_readw(host, SDHCI_HOST_CONTROL2); @@ -295,6 +306,26 @@ static int rockchip_sdhci_set_ios_post(struct sdhci_host *host) return 0; }
+static void rockchip_sdhci_set_control_reg(struct sdhci_host *host) +{ + struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); + struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(priv->dev); + + if (data->set_control_reg) + data->set_control_reg(host); +} + +static int rockchip_sdhci_set_ios_post(struct sdhci_host *host) +{ + struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); + struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(priv->dev); + + if (data->set_ios_post) + return data->set_ios_post(host); + + return 0; +} + static int rockchip_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) { struct sdhci_host *host = dev_get_priv(mmc->dev); @@ -358,6 +389,7 @@ static int rockchip_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) static struct sdhci_ops rockchip_sdhci_ops = { .set_ios_post = rockchip_sdhci_set_ios_post, .platform_execute_tuning = &rockchip_sdhci_execute_tuning, + .set_control_reg = rockchip_sdhci_set_control_reg, };
static int rockchip_sdhci_probe(struct udevice *dev) @@ -436,15 +468,16 @@ static int rockchip_sdhci_bind(struct udevice *dev) }
static const struct sdhci_data rk3399_data = { - .emmc_set_clock = rk3399_sdhci_emmc_set_clock, .get_phy = rk3399_emmc_get_phy, .emmc_phy_init = rk3399_emmc_phy_init, + .set_control_reg = rk3399_sdhci_set_control_reg, + .set_ios_post = rk3399_sdhci_set_ios_post, };
static const struct sdhci_data rk3568_data = { - .emmc_set_clock = rk3568_sdhci_emmc_set_clock, .get_phy = rk3568_emmc_get_phy, .emmc_phy_init = rk3568_emmc_phy_init, + .set_ios_post = rk3568_sdhci_set_ios_post, };
static const struct udevice_id sdhci_ids[] = {
On RK3399, a register bit must be set to enable Enhanced Strobe. Let the Rockchip SDHCI driver set it when Enhanced Strobe configuration is requested. However, having it set makes the lower-speed modes stop working and makes reinitialization fail, so let it be unset as needed in set_control_reg().
This is mostly ported from Linux's Arasan SDHCI driver which happens to be the underlying IP. (drivers/mmc/host/sdhci-of-arasan.c in Linux tree).
Changes in v2: - Unset ES bit in rk3399 set_control_reg() to fix a reinit issue - Don't use unnecessary & for function pointer in ops struct - Rename rk3399_set_enhanced_strobe -> rk3399_sdhci_set_enhanced_strobe - Let set_enhanced_strobe() unset the ES bit if mode is not HS400_ES
drivers/mmc/rockchip_sdhci.c | 41 ++++++++++++++++++++++++++++++++++++ 1 file changed, 41 insertions(+)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index f0d7ba4774d6..f920c5141142 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -42,6 +42,9 @@ ((((x) >> PHYCTRL_DLLRDY_SHIFT) & PHYCTRL_DLLRDY_MASK) ==\ PHYCTRL_DLLRDY_DONE)
+#define ARASAN_VENDOR_REGISTER 0x78 +#define ARASAN_VENDOR_ENHANCED_STROBE BIT(0) + /* Rockchip specific Registers */ #define DWCMSHC_EMMC_DLL_CTRL 0x800 #define DWCMSHC_EMMC_DLL_CTRL_RESET BIT(1) @@ -94,6 +97,7 @@ struct sdhci_data { int (*get_phy)(struct udevice *dev); void (*set_control_reg)(struct sdhci_host *host); int (*set_ios_post)(struct sdhci_host *host); + int (*set_enhanced_strobe)(struct sdhci_host *host); };
static int rk3399_emmc_phy_init(struct udevice *dev) @@ -183,6 +187,21 @@ static int rk3399_emmc_get_phy(struct udevice *dev) return 0; }
+static int rk3399_sdhci_set_enhanced_strobe(struct sdhci_host *host) +{ + struct mmc *mmc = host->mmc; + u32 vendor; + + vendor = sdhci_readl(host, ARASAN_VENDOR_REGISTER); + if (mmc->selected_mode == MMC_HS_400_ES) + vendor |= ARASAN_VENDOR_ENHANCED_STROBE; + else + vendor &= ~ARASAN_VENDOR_ENHANCED_STROBE; + sdhci_writel(host, vendor, ARASAN_VENDOR_REGISTER); + + return 0; +} + static void rk3399_sdhci_set_control_reg(struct sdhci_host *host) { struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); @@ -194,6 +213,15 @@ static void rk3399_sdhci_set_control_reg(struct sdhci_host *host) rk3399_emmc_phy_power_off(priv->phy);
sdhci_set_control_reg(host); + + /* + * Reinitializing the device tries to set it to lower-speed modes + * first, which fails if the Enhanced Strobe bit is set, making + * the device impossible to use. Set the correct value here to + * let reinitialization attempts succeed. + */ + if (CONFIG_IS_ENABLED(MMC_HS400_ES_SUPPORT)) + rk3399_sdhci_set_enhanced_strobe(host); };
static int rk3399_sdhci_set_ios_post(struct sdhci_host *host) @@ -386,10 +414,22 @@ static int rockchip_sdhci_execute_tuning(struct mmc *mmc, u8 opcode) return ret; }
+static int rockchip_sdhci_set_enhanced_strobe(struct sdhci_host *host) +{ + struct rockchip_sdhc *priv = container_of(host, struct rockchip_sdhc, host); + struct sdhci_data *data = (struct sdhci_data *)dev_get_driver_data(priv->dev); + + if (data->set_enhanced_strobe) + return data->set_enhanced_strobe(host); + + return -ENOTSUPP; +} + static struct sdhci_ops rockchip_sdhci_ops = { .set_ios_post = rockchip_sdhci_set_ios_post, .platform_execute_tuning = &rockchip_sdhci_execute_tuning, .set_control_reg = rockchip_sdhci_set_control_reg, + .set_enhanced_strobe = rockchip_sdhci_set_enhanced_strobe, };
static int rockchip_sdhci_probe(struct udevice *dev) @@ -472,6 +512,7 @@ static const struct sdhci_data rk3399_data = { .emmc_phy_init = rk3399_emmc_phy_init, .set_control_reg = rk3399_sdhci_set_control_reg, .set_ios_post = rk3399_sdhci_set_ios_post, + .set_enhanced_strobe = rk3399_sdhci_set_enhanced_strobe, };
On RK3568, a register bit must be set to enable Enhanced Strobe. However, it appears that the address of this register may differ from vendor to vendor and should be read from the underlying MMC IP. Let the Rockchip SDHCI driver read this address and set the relevant bit when Enhanced Strobe configuration is requested.
Additionally, a bit signifying that the connected hardware is an eMMC chip must be set to enable Data Strobe for HS400 and HS400ES modes. Also make the driver set this bit as appropriate.
This is partly ported from Linux's Synopsys DWC MSHC driver which happens to be the underlying IP. (drivers/mmc/host/sdhci-of-dwcmshc.c in Linux tree).
Signed-off-by: Alper Nebi Yasak alpernebiyasak@gmail.com --- Only build-tested as I don't have a RK3568 board.
Changes in v2: - Rename rk3568_set_enhanced_strobe -> rk3568_sdhci_set_enhanced_strobe - Let set_enhanced_strobe() unset the ES bit if mode is not HS400_ES
drivers/mmc/rockchip_sdhci.c | 42 ++++++++++++++++++++++++++++++++++++ 1 file changed, 42 insertions(+)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index f920c5141142..4c7cc7535e2e 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -45,6 +45,14 @@ #define ARASAN_VENDOR_REGISTER 0x78 #define ARASAN_VENDOR_ENHANCED_STROBE BIT(0)
+/* DWC IP vendor area 1 pointer */ +#define DWCMSHC_P_VENDOR_AREA1 0xe8 +#define DWCMSHC_AREA1_MASK GENMASK(11, 0) +/* Offset inside the vendor area 1 */ +#define DWCMSHC_EMMC_CONTROL 0x2c +#define DWCMSHC_CARD_IS_EMMC BIT(0) +#define DWCMSHC_ENHANCED_STROBE BIT(8) + /* Rockchip specific Registers */ #define DWCMSHC_EMMC_DLL_CTRL 0x800 #define DWCMSHC_EMMC_DLL_CTRL_RESET BIT(1) @@ -244,11 +252,25 @@ static int rk3568_emmc_phy_init(struct udevice *dev) { struct rockchip_sdhc *prv = dev_get_priv(dev); struct sdhci_host *host = &prv->host; + struct mmc *mmc = host->mmc; u32 extra; + u32 vendor; + int reg;
extra = DLL_RXCLK_NO_INVERTER << DWCMSHC_EMMC_DLL_RXCLK_SRCSEL; sdhci_writel(host, extra, DWCMSHC_EMMC_DLL_RXCLK);
+ /* set CARD_IS_EMMC bit to enable Data Strobe for HS400 and HS400ES */ + reg = (sdhci_readl(host, DWCMSHC_P_VENDOR_AREA1) & DWCMSHC_AREA1_MASK) + + DWCMSHC_EMMC_CONTROL; + + vendor = sdhci_readw(host, reg); + if (IS_MMC(mmc)) + vendor |= DWCMSHC_CARD_IS_EMMC; + else + vendor &= ~DWCMSHC_CARD_IS_EMMC; + sdhci_writew(host, vendor, reg); + return 0; }
@@ -311,6 +333,25 @@ static int rk3568_emmc_get_phy(struct udevice *dev) return 0; }
+static int rk3568_sdhci_set_enhanced_strobe(struct sdhci_host *host) +{ + struct mmc *mmc = host->mmc; + u32 vendor; + int reg; + + reg = (sdhci_readl(host, DWCMSHC_P_VENDOR_AREA1) & DWCMSHC_AREA1_MASK) + + DWCMSHC_EMMC_CONTROL; + + vendor = sdhci_readl(host, reg); + if (mmc->selected_mode == MMC_HS_400_ES) + vendor |= DWCMSHC_ENHANCED_STROBE; + else + vendor &= ~DWCMSHC_ENHANCED_STROBE; + sdhci_writel(host, vendor, reg); + + return 0; +} + static int rk3568_sdhci_set_ios_post(struct sdhci_host *host) { struct mmc *mmc = host->mmc; @@ -519,6 +560,7 @@ static const struct sdhci_data rk3568_data = { .get_phy = rk3568_emmc_get_phy, .emmc_phy_init = rk3568_emmc_phy_init, .set_ios_post = rk3568_sdhci_set_ios_post, + .set_enhanced_strobe = rk3568_sdhci_set_enhanced_strobe, };
Hi Alper,
On Sun, 16 Jan 2022 at 13:18, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
Mode | Bus Speed | Bus Width -----------------------+--------------+-------------- MMC Legacy | 25000000 | 8-bit MMC High Speed (26MHz) | 26000000 | 8-bit MMC High Speed (52MHz) | 52000000 | 8-bit HS200 (200MHz) | 200000000 | 8-bit HS400 (200MHz) | 200000000 | 8-bit DDR HS400ES (200MHz) | 200000000 | 8-bit DDR Mode | 256 MiB Load | 16 MiB Load | 8 MiB Load -----------------------+--------------+--------------+-------------- MMC Legacy | ~22.1 MiB/s | ~21.9 MiB/s | ~21.6 MiB/s MMC High Speed (26MHz) | ~22.1 MiB/s | ~21.9 MiB/s | ~21.6 MiB/s MMC High Speed (52MHz) | ~43.7 MiB/s | ~42.8 MiB/s | ~41.7 MiB/s HS200 (200MHz) | ~161.2 MiB/s | ~149.5 MiB/s | ~137.9 MiB/s HS400 (200MHz) | ~254.5 MiB/s | ~235.3 MiB/s | ~216.2 MiB/s HS400ES (200MHz) | ~254.7 MiB/s | ~238.8 MiB/s | ~216.2 MiB/s
Changes in v3:
Changes in v2:
This looks great, but your 'kevin' patches do not seem to be applied on master. What gives?
I hope it's just Kever not finding the time to send a pull request for 2022.04. The latest u-boot-rockchip PR was about fixes for 2022.01 and didn't include those.
Alper Nebi Yasak
