[U-Boot-Users] [PATCH 18/25] include/configs: Use new CONFIG_CMD_* in various m* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/mcc200.h | 29 +++++------ include/configs/ml300.h | 18 +++++-- include/configs/ml401.h | 109 +++++++++++++--------------------------- include/configs/modnet50.h | 12 +++-- include/configs/motionpro.h | 40 +++++++-------- include/configs/mp2usb.h | 62 +++++++++++++---------- include/configs/mpc7448hpc2.h | 39 ++++++++------- include/configs/mx1ads.h | 20 +++---- include/configs/mx1fs2.h | 27 +++++----- 9 files changed, 167 insertions(+), 189 deletions(-)
diff --git a/include/configs/mcc200.h b/include/configs/mcc200.h index c2324a0..10e25f0 100644 --- a/include/configs/mcc200.h +++ b/include/configs/mcc200.h @@ -40,11 +40,6 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) -# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - /* * Serial console configuration * @@ -92,22 +87,21 @@
/* USB */ #define CONFIG_USB_OHCI -#define ADD_USB_CMD CFG_CMD_USB | CFG_CMD_FAT #define CONFIG_USB_STORAGE /* automatic software updates (see board/mcc200/auto_update.c) */ #define CONFIG_AUTO_UPDATE 1
+ /* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - ADD_USB_CMD | \ - CFG_CMD_BEDBUG | \ - CFG_CMD_FAT | \ - CFG_CMD_I2C) +#include <config_cmd_default.h> + +#define CONFIG_CMD_BEDBUG +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_USB
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h>
/* * Autobooting @@ -291,7 +285,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -307,6 +301,11 @@
#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */
+#define CFG_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ +#if defined(CONFIG_CMD_KGDB) +# define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ +#endif + /* * Various low-level settings */ diff --git a/include/configs/ml300.h b/include/configs/ml300.h index 6762cd6..423c6eb 100644 --- a/include/configs/ml300.h +++ b/include/configs/ml300.h @@ -87,13 +87,19 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CFG_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
-#define REMOVE_COMMANDS (CFG_CMD_FLASH | CFG_CMD_LOADS | CFG_CMD_FAT | \ - CFG_CMD_IMLS ) -#define CONFIG_COMMANDS ((CONFIG_CMD_DFL | CFG_CMD_NET) \ - & ~REMOVE_COMMANDS)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_NET + +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_FAT +#undef CONFIG_CMD_IMLS +
/* #define CONFIG_SYS_CLK_FREQ XPAR_CORE_CLOCK_FREQ_HZ */ /* 300000000 */ diff --git a/include/configs/ml401.h b/include/configs/ml401.h index 3db2877..9537008 100644 --- a/include/configs/ml401.h +++ b/include/configs/ml401.h @@ -145,82 +145,45 @@ #define CFG_FLASH_PROTECTION /* hardware flash protection */ #endif /* !FLASH */
-#ifdef FLASH - #ifdef RAMENV - #define CONFIG_COMMANDS (CONFIG__CMD_DFL |\ - CFG_CMD_MEMORY |\ - CFG_CMD_MISC |\ - CFG_CMD_AUTOSCRIPT |\ - CFG_CMD_IRQ |\ - CFG_CMD_ASKENV |\ - CFG_CMD_BDI |\ - CFG_CMD_RUN |\ - CFG_CMD_LOADS |\ - CFG_CMD_LOADB |\ - CFG_CMD_IMI |\ - CFG_CMD_NET |\ - CFG_CMD_CACHE |\ - CFG_CMD_FAT |\ - CFG_CMD_EXT2 |\ - CFG_CMD_JFFS2 |\ - CFG_CMD_ECHO |\ - CFG_CMD_IMLS |\ - CFG_CMD_FLASH |\ - CFG_CMD_MFSL |\ - CFG_CMD_PING \ - ) - #else /* !RAMENV */ - #define CONFIG_COMMANDS (CONFIG__CMD_DFL |\ - CFG_CMD_MEMORY |\ - CFG_CMD_MISC |\ - CFG_CMD_AUTOSCRIPT |\ - CFG_CMD_IRQ |\ - CFG_CMD_ASKENV |\ - CFG_CMD_BDI |\ - CFG_CMD_RUN |\ - CFG_CMD_LOADS |\ - CFG_CMD_LOADB |\ - CFG_CMD_IMI |\ - CFG_CMD_NET |\ - CFG_CMD_CACHE |\ - CFG_CMD_IMLS |\ - CFG_CMD_FLASH |\ - CFG_CMD_PING |\ - CFG_CMD_ENV |\ - CFG_CMD_FAT |\ - CFG_CMD_EXT2 |\ - CFG_CMD_JFFS2 |\ - CFG_CMD_ECHO |\ - CFG_CMD_MFSL |\ - CFG_CMD_SAVES \ - )
+ +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_AUTOSCRIPT +#define CONFIG_CMD_BDI +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_IMI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_LOADB +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MISC +#define CONFIG_CMD_MFSL +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_RUN + +#if defined(FLASH) + #define CONFIG_CMD_ECHO + #define CONFIG_CMD_FLASH + #define CONFIG_CMD_IMLS + #define CONFIG_CMD_JFFS2 + + #if !defined(RAMENV) + #define CONFIG_CMD_ENV + #define CONFIG_CMD_SAVES #endif +#endif + +
-#else /* !FLASH */ - #define CONFIG_COMMANDS (CONFIG__CMD_DFL |\ - CFG_CMD_MEMORY |\ - CFG_CMD_MISC |\ - CFG_CMD_AUTOSCRIPT |\ - CFG_CMD_IRQ |\ - CFG_CMD_ASKENV |\ - CFG_CMD_BDI |\ - CFG_CMD_RUN |\ - CFG_CMD_LOADS |\ - CFG_CMD_FAT |\ - CFG_CMD_EXT2 |\ - CFG_CMD_LOADB |\ - CFG_CMD_IMI |\ - CFG_CMD_NET |\ - CFG_CMD_CACHE |\ - CFG_CMD_MFSL |\ - CFG_CMD_PING \ - ) -#endif /* !FLASH */ -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - -#if (CONFIG_COMMANDS & CFG_CMD_JFFS2) +#if defined(CONFIG_CMD_JFFS2) /* JFFS2 partitions */ #define CONFIG_JFFS2_CMDLINE /* mtdparts command line support */ #define MTDIDS_DEFAULT "nor0=ml401-0" diff --git a/include/configs/modnet50.h b/include/configs/modnet50.h index 2028767..33ae43e 100644 --- a/include/configs/modnet50.h +++ b/include/configs/modnet50.h @@ -65,10 +65,14 @@
#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT|CONFIG_BOOTP_BOOTFILESIZE)
-#define CONFIG_COMMANDS ((CONFIG_CMD_DFL | CFG_CMD_JFFS2))
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_JFFS2 +
#define CONFIG_NETMASK 255.255.255.0 #define CONFIG_IPADDR 192.168.30.2 @@ -81,7 +85,7 @@ #define CONFIG_BOOTCOMMAND "bootm 0x10020000 0x100a0000" #define CONFIG_BOOTARGS "console=ttyS0,38400 initrd=0x100a0040,530K root=/dev/ram keepinitrd"
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index e3899a5..7a61e49 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -37,28 +37,26 @@
/* - * Supported commands + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DHCP | \ - CFG_CMD_REGINFO | \ - CFG_CMD_IMMAP | \ - CFG_CMD_ELF | \ - CFG_CMD_MII | \ - CFG_CMD_BEDBUG | \ - CFG_CMD_NET | \ - CFG_CMD_PING | \ - CFG_CMD_IDE | \ - CFG_CMD_FAT | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_I2C | \ - CFG_CMD_DATE | \ - CFG_CMD_EEPROM | \ - CFG_CMD_DTT) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_IMMAP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_MII +#define CONFIG_CMD_BEDBUG +#define CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_IDE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_I2C +#define CONFIG_CMD_DATE +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_DTT
/* diff --git a/include/configs/mp2usb.h b/include/configs/mp2usb.h index 04f1f24..3a62240 100644 --- a/include/configs/mp2usb.h +++ b/include/configs/mp2usb.h @@ -123,36 +123,44 @@
#define CONFIG_BOOTDELAY 3
-#ifdef CONFIG_HARD_I2C -#define CONFIG_COMMANDS \ - ((CONFIG_CMD_DFL | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_EEPROM | \ - CFG_CMD_I2C | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP | \ - CFG_CMD_MISC)) -#else -#define CONFIG_COMMANDS \ - ((CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP | \ - CFG_CMD_USB | \ - CFG_CMD_CACHE) & \ - ~(CFG_CMD_BDI | \ - CFG_CMD_IMI | \ - CFG_CMD_AUTOSCRIPT | \ - CFG_CMD_FPGA | \ - CFG_CMD_MISC | \ - CFG_CMD_LOADS )) + +#if !defined(CONFIG_HARD_I2C) #define CONFIG_TIMESTAMP #endif -#define CFG_LONGHELP
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP + +#if defined(CONFIG_HARD_I2C) + + #define CONFIG_CMD_DATE + #define CONFIG_CMD_EEPROM + #define CONFIG_CMD_I2C + #define CONFIG_CMD_MISC + +#else + + #define CONFIG_CMD_USB + #define CONFIG_CMD_CACHE + + #undef CONFIG_CMD_AUTOSCRIPT + #undef CONFIG_CMD_BDI + #undef CONFIG_CMD_FPGA + #undef CONFIG_CMD_IMI + #undef CONFIG_CMD_LOADS + #undef CONFIG_CMD_MISC + +#endif + + +#define CFG_LONGHELP
#define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM 0x20000000 diff --git a/include/configs/mpc7448hpc2.h b/include/configs/mpc7448hpc2.h index 243a3f6..36ce9bf 100644 --- a/include/configs/mpc7448hpc2.h +++ b/include/configs/mpc7448hpc2.h @@ -149,22 +149,25 @@ #define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT | \ CONFIG_BOOTP_BOOTFILESIZE)
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ - | CFG_CMD_ASKENV \ - | CFG_CMD_CACHE \ - | CFG_CMD_PCI \ - | CFG_CMD_I2C \ - | CFG_CMD_SDRAM \ - | CFG_CMD_EEPROM \ - | CFG_CMD_FLASH \ - | CFG_CMD_ENV \ - | CFG_CMD_BSP \ - | CFG_CMD_DHCP \ - | CFG_CMD_PING \ - | CFG_CMD_DATE) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_PCI +#define CONFIG_CMD_I2C +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_ENV +#define CONFIG_CMD_BSP +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_DATE +
/*set date in u-boot*/ #define CONFIG_RTC_M48T35A @@ -182,7 +185,7 @@ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port at */ #else @@ -387,7 +390,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For all MPC74xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/mx1ads.h b/include/configs/mx1ads.h index 7f3dfd5..0ae2780 100644 --- a/include/configs/mx1ads.h +++ b/include/configs/mx1ads.h @@ -78,25 +78,23 @@
#define CONFIG_BAUDRATE 115200
-/*********************************************************** - * Command definition - ***********************************************************/
-#define CONFIG_COMMANDS \ - (CONFIG_CMD_DFL | \ - CFG_CMD_CACHE | \ - CFG_CMD_REGINFO | \ - CFG_CMD_ELF) +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_ELF
#define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTARGS "root=/dev/msdk mem=48M" #define CONFIG_BOOTFILE "mx1ads" #define CONFIG_BOOTCOMMAND "tftp; bootm"
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ /* what's this ? it's not used anywhere */ #define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ diff --git a/include/configs/mx1fs2.h b/include/configs/mx1fs2.h index 9816be8..47ca0f1 100644 --- a/include/configs/mx1fs2.h +++ b/include/configs/mx1fs2.h @@ -34,22 +34,21 @@ #undef _CONFIG_UART4 /* internal uart 4 */ #undef CONFIG_SILENT_CONSOLE /* use this to disable output */
+ /* - * Definition of u-boot build in commands. Check out CONFIG_CMD_DFL if - * neccessary in include/cmd_confdefs.h file. (Un)comment for getting - * functionality or size of u-boot code. + * Command line configuration. */ -#define CONFIG_COMMANDS (CONFIG_CMD_DFL \ - & ~CFG_CMD_LOADS \ - & ~CFG_CMD_CONSOLE \ - & ~CFG_CMD_AUTOSCRIPT \ - & ~CFG_CMD_NET \ - & ~CFG_CMD_PING \ - & ~CFG_CMD_DHCP \ - | CFG_CMD_JFFS2 \ - ) - -#include <cmd_confdefs.h> +#include <config_cmd_default.h> + +#define CONFIG_CMD_JFFS2 + +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_CONSOLE +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_NET +#undef CONFIG_CMD_PING +#undef CONFIG_CMD_DHCP +
/* * Boot options. Setting delay to -1 stops autostart count down.
Jon Loeliger
