[U-Boot] [PATCH] kirkwood: define empty CONFIG_MVGBE_PORTS by default
Each board with defines it's own set of values. If we do not define CONFIG_MVGBE_PORTS we will hit following error:
mvgbe.c: In function 'mvgbe_initialize': mvgbe.c:700:34: error: 'CONFIG_MVGBE_PORTS' undeclared (first use in this function) u8 used_ports[MAX_MVGBE_DEVS] = CONFIG_MVGBE_PORTS;
This patch fixes above described problem.
Signed-off-by: Luka Perkov luka@openwrt.org CC: Prafulla Wadaskar prafulla@marvell.com CC: Stefan Roese sr@denx.de --- drivers/net/mvgbe.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 0cd06b6..d558f59 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -35,6 +35,10 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifndef CONFIG_MVGBE_PORTS +# define CONFIG_MVGBE_PORTS {0, 0} +#endif + #define MV_PHY_ADR_REQUEST 0xee #define MVGBE_SMI_REG (((struct mvgbe_registers *)MVGBE0_BASE)->smi)
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
-----Original Message----- From: Luka Perkov [mailto:luka@openwrt.org] Sent: 02 July 2014 05:48 To: u-boot@lists.denx.de Cc: luka@openwrt.org; Prafulla Wadaskar; Stefan Roese Subject: [PATCH] kirkwood: define empty CONFIG_MVGBE_PORTS by default
This is generic to network driver, to be picked up by net custodian..
+Joe
Acked-by: Prafulla Wadaskar prafulla@marvell.com
Regards... Prafulla . . .
+Joe
It's in the marvell driver so please just pick it up, thanks.
Luka Perkov
Prafulla Wadaskar
Stefan Roese
