[U-Boot] [PATCH] cosmetic: FIT: fix a strange comment
There is a strange comment in fit_image_load(). This function can be used for loading Kernel Image, FDT as well as ramsisk.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Simon Glass sjg@chromium.org --- common/image-fit.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/image-fit.c b/common/image-fit.c index cf4b67e..b94a3fe 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -1500,7 +1500,7 @@ int fit_image_load(bootm_headers_t *images, const char *prop_name, ulong addr, } bootstage_mark(bootstage_id + BOOTSTAGE_SUB_FORMAT_OK); if (fit_uname) { - /* get ramdisk component image node offset */ + /* get FIT component image node offset */ bootstage_mark(bootstage_id + BOOTSTAGE_SUB_UNIT_NAME); noffset = fit_image_get_node(fit, fit_uname); } else {
Masahiro Yamada
