[U-Boot] [PATCH] [82xx] ids8247: Remove legacy NAND defines
because legacy NAND support is deprecated converting to current NAND interface. !This just compile, because I have no more the hardware to test it.
Signed-off-by: Heiko Schocher hs@denx.de --- board/ids8247/ids8247.c | 92 +++++++++++++++++++++++++++++++++++++++++---- include/configs/IDS8247.h | 55 --------------------------- 2 files changed, 84 insertions(+), 63 deletions(-)
diff --git a/board/ids8247/ids8247.c b/board/ids8247/ids8247.c index 68b7070..79fe9da 100644 --- a/board/ids8247/ids8247.c +++ b/board/ids8247/ids8247.c @@ -304,21 +304,97 @@ phys_size_t initdram (int board_type) int misc_init_r (void) { gd->bd->bi_flashstart = 0xff800000; + return 0; }
#if defined(CONFIG_CMD_NAND) -extern ulong -nand_probe (ulong physadr); +#include <nand.h> +#include <linux/mtd/mtd.h> +#include <asm/io.h> + +static u8 hwctl; + +static void ids_nand_hwctrl(struct mtd_info *mtd, int cmd, unsigned int ctrl) +{ + struct nand_chip *this = mtd->priv; + + if (ctrl & NAND_CTRL_CHANGE) { + if ( ctrl & NAND_CLE ) { + hwctl |= 0x1; + writeb(0x00, (this->IO_ADDR_W + 0x0a)); + } else { + hwctl &= ~0x1; + writeb(0x00, (this->IO_ADDR_W + 0x08)); + } + if ( ctrl & NAND_ALE ) { + hwctl |= 0x2; + writeb(0x00, (this->IO_ADDR_W + 0x09)); + } else { + hwctl &= ~0x2; + writeb(0x00, (this->IO_ADDR_W + 0x08)); + } + if ( (ctrl & NAND_NCE) != NAND_NCE) + writeb(0x00, (this->IO_ADDR_W + 0x0c)); + else + writeb(0x00, (this->IO_ADDR_W + 0x08)); + } + if (cmd != NAND_CMD_NONE) + writeb(cmd, this->IO_ADDR_W); + +}
-void -nand_init (void) +static u_char ids_nand_read_byte(struct mtd_info *mtd) { - ulong totlen = 0; + struct nand_chip *this = mtd->priv;
- debug ("Probing at 0x%.8x\n", CONFIG_SYS_NAND0_BASE); - totlen += nand_probe (CONFIG_SYS_NAND0_BASE); + return readb(this->IO_ADDR_R); +} + +static void ids_nand_write_buf(struct mtd_info *mtd, const u_char *buf, int len) +{ + struct nand_chip *nand = mtd->priv; + int i; + + for (i = 0; i < len; i++) { + if (hwctl & 0x1) + writeb(buf[i], (nand->IO_ADDR_W + 0x02)); + else if (hwctl & 0x2) + writeb(buf[i], (nand->IO_ADDR_W + 0x01)); + else + writeb(buf[i], nand->IO_ADDR_W); + } +}
- printf ("%4lu MB\n", totlen >>20); +static void ids_nand_read_buf(struct mtd_info *mtd, u_char *buf, int len) +{ + struct nand_chip *this = mtd->priv; + int i; + + for (i = 0; i < len; i++) { + buf[i] = readb(this->IO_ADDR_R); + } +} + +static int ids_nand_dev_ready(struct mtd_info *mtd) +{ + /* constant delay (see also tR in the datasheet) */ + udelay(12); + return 1; +} + +int board_nand_init(struct nand_chip *nand) +{ + nand->ecc.mode = NAND_ECC_SOFT; + + /* Reference hardware control function */ + nand->cmd_ctrl = ids_nand_hwctrl; + nand->read_byte = ids_nand_read_byte; + nand->write_buf = ids_nand_write_buf; + nand->read_buf = ids_nand_read_buf; + nand->dev_ready = ids_nand_dev_ready; + nand->chip_delay = 12; + + return 0; }
#endif /* CONFIG_CMD_NAND */ diff --git a/include/configs/IDS8247.h b/include/configs/IDS8247.h index fbcbddb..51e012c 100644 --- a/include/configs/IDS8247.h +++ b/include/configs/IDS8247.h @@ -262,63 +262,8 @@ */ #if defined(CONFIG_CMD_NAND)
-#define CONFIG_NAND_LEGACY #define CONFIG_SYS_NAND0_BASE 0xE1000000 - #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ -#define SECTORSIZE 512 -#define NAND_NO_RB - -#define ADDR_COLUMN 1 -#define ADDR_PAGE 2 -#define ADDR_COLUMN_PAGE 3 - -#define NAND_ChipID_UNKNOWN 0x00 -#define NAND_MAX_FLOORS 1 - -#define NAND_DISABLE_CE(nand) do \ -{ \ - *(((volatile __u8 *)(nand->IO_ADDR)) + 0xc) = 0; \ -} while(0) - -#define NAND_ENABLE_CE(nand) do \ -{ \ - *(((volatile __u8 *)(nand->IO_ADDR)) + 0x8) = 0; \ -} while(0) - -#define NAND_CTL_CLRALE(nandptr) do \ -{ \ - *(((volatile __u8 *)nandptr) + 0x8) = 0; \ -} while(0) - -#define NAND_CTL_SETALE(nandptr) do \ -{ \ - *(((volatile __u8 *)nandptr) + 0x9) = 0; \ -} while(0) - -#define NAND_CTL_CLRCLE(nandptr) do \ -{ \ - *(((volatile __u8 *)nandptr) + 0x8) = 0; \ -} while(0) - -#define NAND_CTL_SETCLE(nandptr) do \ -{ \ - *(((volatile __u8 *)nandptr) + 0xa) = 0; \ -} while(0) - -#ifdef NAND_NO_RB -/* constant delay (see also tR in the datasheet) */ -#define NAND_WAIT_READY(nand) do { \ - udelay(12); \ -} while (0) -#else -/* use the R/B pin */ -#endif - -#define WRITE_NAND_COMMAND(d, adr) do{ *(volatile __u8 *)((unsigned long)(adr + 0x2)) = (__u8)(d); } while(0) -#define WRITE_NAND_ADDRESS(d, adr) do{ *(volatile __u8 *)((unsigned long)(adr + 0x1)) = (__u8)(d); } while(0) -#define WRITE_NAND(d, adr) do{ *(volatile __u8 *)((unsigned long)(adr + 0x0)) = (__u8)d; } while(0) -#define READ_NAND(adr) ((volatile unsigned char)(*(volatile __u8 *)(unsigned long)(adr + 0x0)))
Dear Heiko Schocher,
Applied, thanks.
Heiko Schocher
