[PATCH 1/3] ARM: dts: rename stm32mp15xx-avenger96 ethernet0_rgmii_pins
Alignment with pins name used in Linux kernel v5.8.
It is a preleminary step for device tree alignment.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
arch/arm/dts/stm32mp15-pinctrl.dtsi | 4 ++-- arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/stm32mp15-pinctrl.dtsi b/arch/arm/dts/stm32mp15-pinctrl.dtsi index c385896ebc..b0c2aa52f8 100644 --- a/arch/arm/dts/stm32mp15-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp15-pinctrl.dtsi @@ -162,7 +162,7 @@ }; };
- ethernet0_rgmii_pins_b: rgmii-1 { + ethernet0_rgmii_pins_c: rgmii-2 { pins1 { pinmux = <STM32_PINMUX('G', 5, AF11)>, /* ETH_RGMII_CLK125 */ <STM32_PINMUX('G', 4, AF11)>, /* ETH_RGMII_GTX_CLK */ @@ -193,7 +193,7 @@ }; };
- ethernet0_rgmii_pins_sleep_b: rgmii-sleep-1 { + ethernet0_rgmii_sleep_pins_c: rgmii-sleep-2 { pins1 { pinmux = <STM32_PINMUX('G', 5, ANALOG)>, /* ETH_RGMII_CLK125 */ <STM32_PINMUX('G', 4, ANALOG)>, /* ETH_RGMII_GTX_CLK */ diff --git a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts index c1cc80bcf5..88f25d89b2 100644 --- a/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts +++ b/arch/arm/dts/stm32mp15xx-dhcor-avenger96.dts @@ -89,8 +89,8 @@
ðernet0 { status = "okay"; - pinctrl-0 = <ðernet0_rgmii_pins_b>; - pinctrl-1 = <ðernet0_rgmii_pins_sleep_b>; + pinctrl-0 = <ðernet0_rgmii_pins_c>; + pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>; pinctrl-names = "default", "sleep"; phy-mode = "rgmii"; max-speed = <1000>;
Add a new compatible "st,stm32mp15-i2c" introduced in Linux kernel v5.8
drivers/i2c/stm32f7_i2c.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/i2c/stm32f7_i2c.c b/drivers/i2c/stm32f7_i2c.c index ada8f4095e..593f713d6b 100644 --- a/drivers/i2c/stm32f7_i2c.c +++ b/drivers/i2c/stm32f7_i2c.c @@ -873,6 +873,7 @@ static const struct dm_i2c_ops stm32_i2c_ops = {
static const struct udevice_id stm32_i2c_of_match[] = { { .compatible = "st,stm32f7-i2c", .data = (ulong)&stm32f7_setup }, + { .compatible = "st,stm32mp15-i2c", .data = (ulong)&stm32f7_setup }, {} };
Hello Patrick,
Am 06.07.2020 um 13:26 schrieb Patrick Delaunay:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Patrick,
Applied to u-boot-i2c.git master
Thanks!
bye, Heiko
DT alignment with Linux kernel v5.8-rc1 for the STM32MP15x soc device tree files and the STMicroelectronics boards device tree files.
arch/arm/dts/stm32mp15-pinctrl.dtsi | 562 ++++++++++++++++++++++++++-- arch/arm/dts/stm32mp15-u-boot.dtsi | 4 + arch/arm/dts/stm32mp151.dtsi | 48 +-- arch/arm/dts/stm32mp157.dtsi | 8 +- arch/arm/dts/stm32mp157c-dk2.dts | 8 - arch/arm/dts/stm32mp157c-ed1.dts | 7 +- arch/arm/dts/stm32mp157c-ev1.dts | 14 +- arch/arm/dts/stm32mp15xx-dkx.dtsi | 20 +- 8 files changed, 577 insertions(+), 94 deletions(-)
diff --git a/arch/arm/dts/stm32mp15-pinctrl.dtsi b/arch/arm/dts/stm32mp15-pinctrl.dtsi index b0c2aa52f8..e9525b5d06 100644 --- a/arch/arm/dts/stm32mp15-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp15-pinctrl.dtsi @@ -6,7 +6,7 @@ #include <dt-bindings/pinctrl/stm32-pinfunc.h>
&pinctrl { - adc1_in6_pins_a: adc1-in6 { + adc1_in6_pins_a: adc1-in6-0 { pins { pinmux = <STM32_PINMUX('F', 12, ANALOG)>; }; @@ -21,6 +21,13 @@ }; };
+ adc12_ain_pins_b: adc12-ain-1 { + pins { + pinmux = <STM32_PINMUX('F', 12, ANALOG)>, /* ADC1 in6 */ + <STM32_PINMUX('F', 13, ANALOG)>; /* ADC2 in2 */ + }; + }; + adc12_usb_cc_pins_a: adc12-usb-cc-pins-0 { pins { pinmux = <STM32_PINMUX('A', 4, ANALOG)>, /* ADC12 in18 */ @@ -37,7 +44,7 @@ }; };
- cec_pins_sleep_a: cec-sleep-0 { + cec_sleep_pins_a: cec-sleep-0 { pins { pinmux = <STM32_PINMUX('A', 15, ANALOG)>; /* HDMI_CEC */ }; @@ -52,19 +59,19 @@ }; };
- cec_pins_sleep_b: cec-sleep-1 { + cec_sleep_pins_b: cec-sleep-1 { pins { pinmux = <STM32_PINMUX('B', 6, ANALOG)>; /* HDMI_CEC */ }; };
- dac_ch1_pins_a: dac-ch1 { + dac_ch1_pins_a: dac-ch1-0 { pins { pinmux = <STM32_PINMUX('A', 4, ANALOG)>; }; };
- dac_ch2_pins_a: dac-ch2 { + dac_ch2_pins_a: dac-ch2-0 { pins { pinmux = <STM32_PINMUX('A', 5, ANALOG)>; }; @@ -142,7 +149,7 @@ }; };
- ethernet0_rgmii_pins_sleep_a: rgmii-sleep-0 { + ethernet0_rgmii_sleep_pins_a: rgmii-sleep-0 { pins1 { pinmux = <STM32_PINMUX('G', 5, ANALOG)>, /* ETH_RGMII_CLK125 */ <STM32_PINMUX('G', 4, ANALOG)>, /* ETH_RGMII_GTX_CLK */ @@ -162,6 +169,57 @@ }; };
+ ethernet0_rgmii_pins_b: rgmii-1 { + pins1 { + pinmux = <STM32_PINMUX('G', 5, AF11)>, /* ETH_RGMII_CLK125 */ + <STM32_PINMUX('G', 4, AF11)>, /* ETH_RGMII_GTX_CLK */ + <STM32_PINMUX('G', 13, AF11)>, /* ETH_RGMII_TXD0 */ + <STM32_PINMUX('G', 14, AF11)>, /* ETH_RGMII_TXD1 */ + <STM32_PINMUX('C', 2, AF11)>, /* ETH_RGMII_TXD2 */ + <STM32_PINMUX('E', 2, AF11)>, /* ETH_RGMII_TXD3 */ + <STM32_PINMUX('B', 11, AF11)>, /* ETH_RGMII_TX_CTL */ + <STM32_PINMUX('C', 1, AF11)>; /* ETH_MDC */ + bias-disable; + drive-push-pull; + slew-rate = <2>; + }; + pins2 { + pinmux = <STM32_PINMUX('A', 2, AF11)>; /* ETH_MDIO */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins3 { + pinmux = <STM32_PINMUX('C', 4, AF11)>, /* ETH_RGMII_RXD0 */ + <STM32_PINMUX('C', 5, AF11)>, /* ETH_RGMII_RXD1 */ + <STM32_PINMUX('H', 6, AF11)>, /* ETH_RGMII_RXD2 */ + <STM32_PINMUX('H', 7, AF11)>, /* ETH_RGMII_RXD3 */ + <STM32_PINMUX('A', 1, AF11)>, /* ETH_RGMII_RX_CLK */ + <STM32_PINMUX('A', 7, AF11)>; /* ETH_RGMII_RX_CTL */ + bias-disable; + }; + }; + + ethernet0_rgmii_sleep_pins_b: rgmii-sleep-1 { + pins1 { + pinmux = <STM32_PINMUX('G', 5, ANALOG)>, /* ETH_RGMII_CLK125 */ + <STM32_PINMUX('G', 4, ANALOG)>, /* ETH_RGMII_GTX_CLK */ + <STM32_PINMUX('G', 13, ANALOG)>, /* ETH_RGMII_TXD0 */ + <STM32_PINMUX('G', 14, ANALOG)>, /* ETH_RGMII_TXD1 */ + <STM32_PINMUX('C', 2, ANALOG)>, /* ETH_RGMII_TXD2 */ + <STM32_PINMUX('E', 2, ANALOG)>, /* ETH_RGMII_TXD3 */ + <STM32_PINMUX('B', 11, ANALOG)>, /* ETH_RGMII_TX_CTL */ + <STM32_PINMUX('C', 1, ANALOG)>, /* ETH_MDC */ + <STM32_PINMUX('A', 2, ANALOG)>, /* ETH_MDIO */ + <STM32_PINMUX('C', 4, ANALOG)>, /* ETH_RGMII_RXD0 */ + <STM32_PINMUX('C', 5, ANALOG)>, /* ETH_RGMII_RXD1 */ + <STM32_PINMUX('H', 6, ANALOG)>, /* ETH_RGMII_RXD2 */ + <STM32_PINMUX('H', 7, ANALOG)>, /* ETH_RGMII_RXD3 */ + <STM32_PINMUX('A', 1, ANALOG)>, /* ETH_RGMII_RX_CLK */ + <STM32_PINMUX('A', 7, ANALOG)>; /* ETH_RGMII_RX_CTL */ + }; + }; + ethernet0_rgmii_pins_c: rgmii-2 { pins1 { pinmux = <STM32_PINMUX('G', 5, AF11)>, /* ETH_RGMII_CLK125 */ @@ -233,7 +291,7 @@ }; };
- ethernet0_rmii_pins_sleep_a: rmii-sleep-0 { + ethernet0_rmii_sleep_pins_a: rmii-sleep-0 { pins1 { pinmux = <STM32_PINMUX('G', 13, ANALOG)>, /* ETH1_RMII_TXD0 */ <STM32_PINMUX('G', 14, ANALOG)>, /* ETH1_RMII_TXD1 */ @@ -301,14 +359,14 @@ }; };
- i2c1_pins_sleep_a: i2c1-1 { + i2c1_sleep_pins_a: i2c1-sleep-0 { pins { pinmux = <STM32_PINMUX('D', 12, ANALOG)>, /* I2C1_SCL */ <STM32_PINMUX('F', 15, ANALOG)>; /* I2C1_SDA */ }; };
- i2c1_pins_b: i2c1-2 { + i2c1_pins_b: i2c1-1 { pins { pinmux = <STM32_PINMUX('F', 14, AF5)>, /* I2C1_SCL */ <STM32_PINMUX('F', 15, AF5)>; /* I2C1_SDA */ @@ -318,7 +376,7 @@ }; };
- i2c1_pins_sleep_b: i2c1-3 { + i2c1_sleep_pins_b: i2c1-sleep-1 { pins { pinmux = <STM32_PINMUX('F', 14, ANALOG)>, /* I2C1_SCL */ <STM32_PINMUX('F', 15, ANALOG)>; /* I2C1_SDA */ @@ -335,14 +393,14 @@ }; };
- i2c2_pins_sleep_a: i2c2-1 { + i2c2_sleep_pins_a: i2c2-sleep-0 { pins { pinmux = <STM32_PINMUX('H', 4, ANALOG)>, /* I2C2_SCL */ <STM32_PINMUX('H', 5, ANALOG)>; /* I2C2_SDA */ }; };
- i2c2_pins_b1: i2c2-2 { + i2c2_pins_b1: i2c2-1 { pins { pinmux = <STM32_PINMUX('H', 5, AF4)>; /* I2C2_SDA */ bias-disable; @@ -351,13 +409,13 @@ }; };
- i2c2_pins_sleep_b1: i2c2-3 { + i2c2_sleep_pins_b1: i2c2-sleep-1 { pins { pinmux = <STM32_PINMUX('H', 5, ANALOG)>; /* I2C2_SDA */ }; };
- i2c2_pins_c: i2c2-4 { + i2c2_pins_c: i2c2-2 { pins { pinmux = <STM32_PINMUX('F', 1, AF4)>, /* I2C2_SCL */ <STM32_PINMUX('H', 5, AF4)>; /* I2C2_SDA */ @@ -367,7 +425,7 @@ }; };
- i2c2_pins_sleep_c: i2c2-5 { + i2c2_pins_sleep_c: i2c2-sleep-2 { pins { pinmux = <STM32_PINMUX('F', 1, ANALOG)>, /* I2C2_SCL */ <STM32_PINMUX('H', 5, ANALOG)>; /* I2C2_SDA */ @@ -384,7 +442,7 @@ }; };
- i2c5_pins_sleep_a: i2c5-1 { + i2c5_sleep_pins_a: i2c5-sleep-0 { pins { pinmux = <STM32_PINMUX('A', 11, ANALOG)>, /* I2C5_SCL */ <STM32_PINMUX('A', 12, ANALOG)>; /* I2C5_SDA */ @@ -392,6 +450,23 @@ }; };
+ i2c5_pins_b: i2c5-1 { + pins { + pinmux = <STM32_PINMUX('D', 0, AF4)>, /* I2C5_SCL */ + <STM32_PINMUX('D', 1, AF4)>; /* I2C5_SDA */ + bias-disable; + drive-open-drain; + slew-rate = <0>; + }; + }; + + i2c5_sleep_pins_b: i2c5-sleep-1 { + pins { + pinmux = <STM32_PINMUX('D', 0, ANALOG)>, /* I2C5_SCL */ + <STM32_PINMUX('D', 1, ANALOG)>; /* I2C5_SDA */ + }; + }; + i2s2_pins_a: i2s2-0 { pins { pinmux = <STM32_PINMUX('I', 3, AF5)>, /* I2S2_SDO */ @@ -403,7 +478,7 @@ }; };
- i2s2_pins_sleep_a: i2s2-1 { + i2s2_sleep_pins_a: i2s2-sleep-0 { pins { pinmux = <STM32_PINMUX('I', 3, ANALOG)>, /* I2S2_SDO */ <STM32_PINMUX('B', 9, ANALOG)>, /* I2S2_WS */ @@ -411,7 +486,7 @@ }; };
- ltdc_pins_a: ltdc-a-0 { + ltdc_pins_a: ltdc-0 { pins { pinmux = <STM32_PINMUX('G', 7, AF14)>, /* LCD_CLK */ <STM32_PINMUX('I', 10, AF14)>, /* LCD_HSYNC */ @@ -447,7 +522,7 @@ }; };
- ltdc_pins_sleep_a: ltdc-a-1 { + ltdc_sleep_pins_a: ltdc-sleep-0 { pins { pinmux = <STM32_PINMUX('G', 7, ANALOG)>, /* LCD_CLK */ <STM32_PINMUX('I', 10, ANALOG)>, /* LCD_HSYNC */ @@ -480,7 +555,7 @@ }; };
- ltdc_pins_b: ltdc-b-0 { + ltdc_pins_b: ltdc-1 { pins { pinmux = <STM32_PINMUX('I', 14, AF14)>, /* LCD_CLK */ <STM32_PINMUX('I', 12, AF14)>, /* LCD_HSYNC */ @@ -516,7 +591,7 @@ }; };
- ltdc_pins_sleep_b: ltdc-b-1 { + ltdc_sleep_pins_b: ltdc-sleep-1 { pins { pinmux = <STM32_PINMUX('I', 14, ANALOG)>, /* LCD_CLK */ <STM32_PINMUX('I', 12, ANALOG)>, /* LCD_HSYNC */ @@ -549,6 +624,142 @@ }; };
+ ltdc_pins_c: ltdc-2 { + pins1 { + pinmux = <STM32_PINMUX('B', 1, AF9)>, /* LTDC_R6 */ + <STM32_PINMUX('B', 9, AF14)>, /* LTDC_B7 */ + <STM32_PINMUX('C', 0, AF14)>, /* LTDC_R5 */ + <STM32_PINMUX('D', 3, AF14)>, /* LTDC_G7 */ + <STM32_PINMUX('D', 6, AF14)>, /* LTDC_B2 */ + <STM32_PINMUX('D', 10, AF14)>, /* LTDC_B3 */ + <STM32_PINMUX('E', 11, AF14)>, /* LTDC_G3 */ + <STM32_PINMUX('E', 12, AF14)>, /* LTDC_B4 */ + <STM32_PINMUX('E', 13, AF14)>, /* LTDC_DE */ + <STM32_PINMUX('E', 15, AF14)>, /* LTDC_R7 */ + <STM32_PINMUX('H', 4, AF9)>, /* LTDC_G5 */ + <STM32_PINMUX('H', 8, AF14)>, /* LTDC_R2 */ + <STM32_PINMUX('H', 9, AF14)>, /* LTDC_R3 */ + <STM32_PINMUX('H', 10, AF14)>, /* LTDC_R4 */ + <STM32_PINMUX('H', 13, AF14)>, /* LTDC_G2 */ + <STM32_PINMUX('H', 15, AF14)>, /* LTDC_G4 */ + <STM32_PINMUX('I', 1, AF14)>, /* LTDC_G6 */ + <STM32_PINMUX('I', 5, AF14)>, /* LTDC_B5 */ + <STM32_PINMUX('I', 6, AF14)>, /* LTDC_B6 */ + <STM32_PINMUX('I', 9, AF14)>, /* LTDC_VSYNC */ + <STM32_PINMUX('I', 10, AF14)>; /* LTDC_HSYNC */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('E', 14, AF14)>; /* LTDC_CLK */ + bias-disable; + drive-push-pull; + slew-rate = <1>; + }; + }; + + ltdc_sleep_pins_c: ltdc-sleep-2 { + pins1 { + pinmux = <STM32_PINMUX('B', 1, ANALOG)>, /* LTDC_R6 */ + <STM32_PINMUX('B', 9, ANALOG)>, /* LTDC_B7 */ + <STM32_PINMUX('C', 0, ANALOG)>, /* LTDC_R5 */ + <STM32_PINMUX('D', 3, ANALOG)>, /* LTDC_G7 */ + <STM32_PINMUX('D', 6, ANALOG)>, /* LTDC_B2 */ + <STM32_PINMUX('D', 10, ANALOG)>, /* LTDC_B3 */ + <STM32_PINMUX('E', 11, ANALOG)>, /* LTDC_G3 */ + <STM32_PINMUX('E', 12, ANALOG)>, /* LTDC_B4 */ + <STM32_PINMUX('E', 13, ANALOG)>, /* LTDC_DE */ + <STM32_PINMUX('E', 15, ANALOG)>, /* LTDC_R7 */ + <STM32_PINMUX('H', 4, ANALOG)>, /* LTDC_G5 */ + <STM32_PINMUX('H', 8, ANALOG)>, /* LTDC_R2 */ + <STM32_PINMUX('H', 9, ANALOG)>, /* LTDC_R3 */ + <STM32_PINMUX('H', 10, ANALOG)>, /* LTDC_R4 */ + <STM32_PINMUX('H', 13, ANALOG)>, /* LTDC_G2 */ + <STM32_PINMUX('H', 15, ANALOG)>, /* LTDC_G4 */ + <STM32_PINMUX('I', 1, ANALOG)>, /* LTDC_G6 */ + <STM32_PINMUX('I', 5, ANALOG)>, /* LTDC_B5 */ + <STM32_PINMUX('I', 6, ANALOG)>, /* LTDC_B6 */ + <STM32_PINMUX('I', 9, ANALOG)>, /* LTDC_VSYNC */ + <STM32_PINMUX('I', 10, ANALOG)>, /* LTDC_HSYNC */ + <STM32_PINMUX('E', 14, ANALOG)>; /* LTDC_CLK */ + }; + }; + + ltdc_pins_d: ltdc-3 { + pins1 { + pinmux = <STM32_PINMUX('G', 7, AF14)>; /* LCD_CLK */ + bias-disable; + drive-push-pull; + slew-rate = <3>; + }; + pins2 { + pinmux = <STM32_PINMUX('I', 10, AF14)>, /* LCD_HSYNC */ + <STM32_PINMUX('I', 9, AF14)>, /* LCD_VSYNC */ + <STM32_PINMUX('E', 13, AF14)>, /* LCD_DE */ + <STM32_PINMUX('G', 13, AF14)>, /* LCD_R0 */ + <STM32_PINMUX('H', 3, AF14)>, /* LCD_R1 */ + <STM32_PINMUX('H', 8, AF14)>, /* LCD_R2 */ + <STM32_PINMUX('H', 9, AF14)>, /* LCD_R3 */ + <STM32_PINMUX('A', 5, AF14)>, /* LCD_R4 */ + <STM32_PINMUX('H', 11, AF14)>, /* LCD_R5 */ + <STM32_PINMUX('H', 12, AF14)>, /* LCD_R6 */ + <STM32_PINMUX('E', 15, AF14)>, /* LCD_R7 */ + <STM32_PINMUX('E', 5, AF14)>, /* LCD_G0 */ + <STM32_PINMUX('B', 0, AF14)>, /* LCD_G1 */ + <STM32_PINMUX('H', 13, AF14)>, /* LCD_G2 */ + <STM32_PINMUX('E', 11, AF14)>, /* LCD_G3 */ + <STM32_PINMUX('H', 15, AF14)>, /* LCD_G4 */ + <STM32_PINMUX('H', 4, AF9)>, /* LCD_G5 */ + <STM32_PINMUX('I', 11, AF9)>, /* LCD_G6 */ + <STM32_PINMUX('G', 8, AF14)>, /* LCD_G7 */ + <STM32_PINMUX('D', 9, AF14)>, /* LCD_B0 */ + <STM32_PINMUX('G', 12, AF14)>, /* LCD_B1 */ + <STM32_PINMUX('G', 10, AF14)>, /* LCD_B2 */ + <STM32_PINMUX('D', 10, AF14)>, /* LCD_B3 */ + <STM32_PINMUX('E', 12, AF14)>, /* LCD_B4 */ + <STM32_PINMUX('A', 3, AF14)>, /* LCD_B5 */ + <STM32_PINMUX('B', 8, AF14)>, /* LCD_B6 */ + <STM32_PINMUX('I', 7, AF14)>; /* LCD_B7 */ + bias-disable; + drive-push-pull; + slew-rate = <2>; + }; + }; + + ltdc_sleep_pins_d: ltdc-sleep-3 { + pins { + pinmux = <STM32_PINMUX('G', 7, ANALOG)>, /* LCD_CLK */ + <STM32_PINMUX('I', 10, ANALOG)>, /* LCD_HSYNC */ + <STM32_PINMUX('I', 9, ANALOG)>, /* LCD_VSYNC */ + <STM32_PINMUX('E', 13, ANALOG)>, /* LCD_DE */ + <STM32_PINMUX('G', 13, ANALOG)>, /* LCD_R0 */ + <STM32_PINMUX('H', 3, ANALOG)>, /* LCD_R1 */ + <STM32_PINMUX('H', 8, ANALOG)>, /* LCD_R2 */ + <STM32_PINMUX('H', 9, ANALOG)>, /* LCD_R3 */ + <STM32_PINMUX('A', 5, ANALOG)>, /* LCD_R4 */ + <STM32_PINMUX('H', 11, ANALOG)>, /* LCD_R5 */ + <STM32_PINMUX('H', 12, ANALOG)>, /* LCD_R6 */ + <STM32_PINMUX('E', 15, ANALOG)>, /* LCD_R7 */ + <STM32_PINMUX('E', 5, ANALOG)>, /* LCD_G0 */ + <STM32_PINMUX('B', 0, ANALOG)>, /* LCD_G1 */ + <STM32_PINMUX('H', 13, ANALOG)>, /* LCD_G2 */ + <STM32_PINMUX('E', 11, ANALOG)>, /* LCD_G3 */ + <STM32_PINMUX('H', 15, ANALOG)>, /* LCD_G4 */ + <STM32_PINMUX('H', 4, ANALOG)>, /* LCD_G5 */ + <STM32_PINMUX('I', 11, ANALOG)>, /* LCD_G6 */ + <STM32_PINMUX('G', 8, ANALOG)>, /* LCD_G7 */ + <STM32_PINMUX('D', 9, ANALOG)>, /* LCD_B0 */ + <STM32_PINMUX('G', 12, ANALOG)>, /* LCD_B1 */ + <STM32_PINMUX('G', 10, ANALOG)>, /* LCD_B2 */ + <STM32_PINMUX('D', 10, ANALOG)>, /* LCD_B3 */ + <STM32_PINMUX('E', 12, ANALOG)>, /* LCD_B4 */ + <STM32_PINMUX('A', 3, ANALOG)>, /* LCD_B5 */ + <STM32_PINMUX('B', 8, ANALOG)>, /* LCD_B6 */ + <STM32_PINMUX('I', 7, ANALOG)>; /* LCD_B7 */ + }; + }; + m_can1_pins_a: m-can1-0 { pins1 { pinmux = <STM32_PINMUX('H', 13, AF9)>; /* CAN1_TX */ @@ -569,6 +780,46 @@ }; };
+ m_can1_pins_b: m-can1-1 { + pins1 { + pinmux = <STM32_PINMUX('A', 12, AF9)>; /* CAN1_TX */ + slew-rate = <1>; + drive-push-pull; + bias-disable; + }; + pins2 { + pinmux = <STM32_PINMUX('A', 11, AF9)>; /* CAN1_RX */ + bias-disable; + }; + }; + + m_can1_sleep_pins_b: m_can1-sleep-1 { + pins { + pinmux = <STM32_PINMUX('A', 12, ANALOG)>, /* CAN1_TX */ + <STM32_PINMUX('A', 11, ANALOG)>; /* CAN1_RX */ + }; + }; + + m_can2_pins_a: m-can2-0 { + pins1 { + pinmux = <STM32_PINMUX('B', 13, AF9)>; /* CAN2_TX */ + slew-rate = <1>; + drive-push-pull; + bias-disable; + }; + pins2 { + pinmux = <STM32_PINMUX('B', 5, AF9)>; /* CAN2_RX */ + bias-disable; + }; + }; + + m_can2_sleep_pins_a: m_can2-sleep-0 { + pins { + pinmux = <STM32_PINMUX('B', 13, ANALOG)>, /* CAN2_TX */ + <STM32_PINMUX('B', 5, ANALOG)>; /* CAN2_RX */ + }; + }; + pwm1_pins_a: pwm1-0 { pins { pinmux = <STM32_PINMUX('E', 9, AF1)>, /* TIM1_CH1 */ @@ -618,6 +869,21 @@ }; };
+ pwm3_pins_b: pwm3-1 { + pins { + pinmux = <STM32_PINMUX('B', 5, AF2)>; /* TIM3_CH2 */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + }; + + pwm3_sleep_pins_b: pwm3-sleep-1 { + pins { + pinmux = <STM32_PINMUX('B', 5, ANALOG)>; /* TIM3_CH2 */ + }; + }; + pwm4_pins_a: pwm4-0 { pins { pinmux = <STM32_PINMUX('D', 14, AF2)>, /* TIM4_CH3 */ @@ -665,6 +931,25 @@ }; };
+ pwm5_pins_b: pwm5-1 { + pins { + pinmux = <STM32_PINMUX('H', 11, AF2)>, /* TIM5_CH2 */ + <STM32_PINMUX('H', 12, AF2)>, /* TIM5_CH3 */ + <STM32_PINMUX('I', 0, AF2)>; /* TIM5_CH4 */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + }; + + pwm5_sleep_pins_b: pwm5-sleep-1 { + pins { + pinmux = <STM32_PINMUX('H', 11, ANALOG)>, /* TIM5_CH2 */ + <STM32_PINMUX('H', 12, ANALOG)>, /* TIM5_CH3 */ + <STM32_PINMUX('I', 0, ANALOG)>; /* TIM5_CH4 */ + }; + }; + pwm8_pins_a: pwm8-0 { pins { pinmux = <STM32_PINMUX('I', 2, AF3)>; /* TIM8_CH4 */ @@ -778,7 +1063,7 @@ }; };
- sai2a_sleep_pins_a: sai2a-1 { + sai2a_sleep_pins_a: sai2a-sleep-0 { pins { pinmux = <STM32_PINMUX('I', 5, ANALOG)>, /* SAI2_SCK_A */ <STM32_PINMUX('I', 6, ANALOG)>, /* SAI2_SD_A */ @@ -787,7 +1072,7 @@ }; };
- sai2a_pins_b: sai2a-2 { + sai2a_pins_b: sai2a-1 { pins1 { pinmux = <STM32_PINMUX('I', 6, AF10)>, /* SAI2_SD_A */ <STM32_PINMUX('I', 7, AF10)>, /* SAI2_FS_A */ @@ -798,7 +1083,7 @@ }; };
- sai2a_sleep_pins_b: sai2a-sleep-3 { + sai2a_sleep_pins_b: sai2a-sleep-1 { pins { pinmux = <STM32_PINMUX('I', 6, ANALOG)>, /* SAI2_SD_A */ <STM32_PINMUX('I', 7, ANALOG)>, /* SAI2_FS_A */ @@ -806,6 +1091,25 @@ }; };
+ sai2a_pins_c: sai2a-4 { + pins { + pinmux = <STM32_PINMUX('D', 13, AF10)>, /* SAI2_SCK_A */ + <STM32_PINMUX('D', 11, AF10)>, /* SAI2_SD_A */ + <STM32_PINMUX('D', 12, AF10)>; /* SAI2_FS_A */ + slew-rate = <0>; + drive-push-pull; + bias-disable; + }; + }; + + sai2a_sleep_pins_c: sai2a-5 { + pins { + pinmux = <STM32_PINMUX('D', 13, ANALOG)>, /* SAI2_SCK_A */ + <STM32_PINMUX('D', 11, ANALOG)>, /* SAI2_SD_A */ + <STM32_PINMUX('D', 12, ANALOG)>; /* SAI2_FS_A */ + }; + }; + sai2b_pins_a: sai2b-0 { pins1 { pinmux = <STM32_PINMUX('E', 12, AF10)>, /* SAI2_SCK_B */ @@ -821,7 +1125,7 @@ }; };
- sai2b_sleep_pins_a: sai2b-1 { + sai2b_sleep_pins_a: sai2b-sleep-0 { pins { pinmux = <STM32_PINMUX('F', 11, ANALOG)>, /* SAI2_SD_B */ <STM32_PINMUX('E', 12, ANALOG)>, /* SAI2_SCK_B */ @@ -830,14 +1134,27 @@ }; };
- sai2b_pins_b: sai2b-2 { + sai2b_pins_b: sai2b-1 { pins { pinmux = <STM32_PINMUX('F', 11, AF10)>; /* SAI2_SD_B */ bias-disable; }; };
- sai2b_sleep_pins_b: sai2b-3 { + sai2b_sleep_pins_b: sai2b-sleep-1 { + pins { + pinmux = <STM32_PINMUX('F', 11, ANALOG)>; /* SAI2_SD_B */ + }; + }; + + sai2b_pins_c: sai2a-4 { + pins1 { + pinmux = <STM32_PINMUX('F', 11, AF10)>; /* SAI2_SD_B */ + bias-disable; + }; + }; + + sai2b_sleep_pins_c: sai2a-sleep-5 { pins { pinmux = <STM32_PINMUX('F', 11, ANALOG)>; /* SAI2_SD_B */ }; @@ -852,7 +1169,7 @@ }; };
- sai4a_sleep_pins_a: sai4a-1 { + sai4a_sleep_pins_a: sai4a-sleep-0 { pins { pinmux = <STM32_PINMUX('B', 5, ANALOG)>; /* SAI4_SD_A */ }; @@ -939,7 +1256,7 @@ sdmmc1_dir_pins_b: sdmmc1-dir-1 { pins1 { pinmux = <STM32_PINMUX('F', 2, AF11)>, /* SDMMC1_D0DIR */ - <STM32_PINMUX('E', 14, AF8)>, /* SDMMC1_D123DIR */ + <STM32_PINMUX('E', 14, AF11)>, /* SDMMC1_D123DIR */ <STM32_PINMUX('B', 9, AF11)>; /* SDMMC1_CDIR */ slew-rate = <1>; drive-push-pull; @@ -954,9 +1271,9 @@ sdmmc1_dir_sleep_pins_b: sdmmc1-dir-sleep-1 { pins { pinmux = <STM32_PINMUX('F', 2, ANALOG)>, /* SDMMC1_D0DIR */ - <STM32_PINMUX('E', 14, ANALOG)>, /* SDMMC1_D123DIR */ - <STM32_PINMUX('B', 9, ANALOG)>, /* SDMMC1_CDIR */ - <STM32_PINMUX('E', 4, ANALOG)>; /* SDMMC1_CKIN */ + <STM32_PINMUX('E', 14, ANALOG)>, /* SDMMC1_D123DIR */ + <STM32_PINMUX('B', 9, ANALOG)>, /* SDMMC1_CDIR */ + <STM32_PINMUX('E', 4, ANALOG)>; /* SDMMC1_CKIN */ }; };
@@ -1079,6 +1396,27 @@ };
sdmmc2_d47_pins_b: sdmmc2-d47-1 { + pins { + pinmux = <STM32_PINMUX('A', 8, AF9)>, /* SDMMC2_D4 */ + <STM32_PINMUX('A', 9, AF10)>, /* SDMMC2_D5 */ + <STM32_PINMUX('C', 6, AF10)>, /* SDMMC2_D6 */ + <STM32_PINMUX('C', 7, AF10)>; /* SDMMC2_D7 */ + slew-rate = <1>; + drive-push-pull; + bias-disable; + }; + }; + + sdmmc2_d47_sleep_pins_b: sdmmc2-d47-sleep-1 { + pins { + pinmux = <STM32_PINMUX('A', 8, ANALOG)>, /* SDMMC2_D4 */ + <STM32_PINMUX('A', 9, ANALOG)>, /* SDMMC2_D5 */ + <STM32_PINMUX('C', 6, ANALOG)>, /* SDMMC2_D6 */ + <STM32_PINMUX('C', 7, ANALOG)>; /* SDMMC2_D7 */ + }; + }; + + sdmmc2_d47_pins_c: sdmmc2-d47-2 { pins { pinmux = <STM32_PINMUX('A', 8, AF9)>, /* SDMMC2_D4 */ <STM32_PINMUX('A', 15, AF9)>, /* SDMMC2_D5 */ @@ -1090,7 +1428,7 @@ }; };
- sdmmc2_d47_sleep_pins_b: sdmmc2-d47-sleep-1 { + sdmmc2_d47_sleep_pins_c: sdmmc2-d47-sleep-2 { pins { pinmux = <STM32_PINMUX('A', 8, ANALOG)>, /* SDMMC2_D4 */ <STM32_PINMUX('A', 15, ANALOG)>, /* SDMMC2_D5 */ @@ -1153,6 +1491,60 @@ }; };
+ sdmmc3_b4_pins_b: sdmmc3-b4-1 { + pins1 { + pinmux = <STM32_PINMUX('F', 0, AF9)>, /* SDMMC3_D0 */ + <STM32_PINMUX('F', 4, AF9)>, /* SDMMC3_D1 */ + <STM32_PINMUX('D', 5, AF10)>, /* SDMMC3_D2 */ + <STM32_PINMUX('D', 7, AF10)>, /* SDMMC3_D3 */ + <STM32_PINMUX('D', 0, AF10)>; /* SDMMC3_CMD */ + slew-rate = <1>; + drive-push-pull; + bias-pull-up; + }; + pins2 { + pinmux = <STM32_PINMUX('G', 15, AF10)>; /* SDMMC3_CK */ + slew-rate = <2>; + drive-push-pull; + bias-pull-up; + }; + }; + + sdmmc3_b4_od_pins_b: sdmmc3-b4-od-1 { + pins1 { + pinmux = <STM32_PINMUX('F', 0, AF9)>, /* SDMMC3_D0 */ + <STM32_PINMUX('F', 4, AF9)>, /* SDMMC3_D1 */ + <STM32_PINMUX('D', 5, AF10)>, /* SDMMC3_D2 */ + <STM32_PINMUX('D', 7, AF10)>; /* SDMMC3_D3 */ + slew-rate = <1>; + drive-push-pull; + bias-pull-up; + }; + pins2 { + pinmux = <STM32_PINMUX('G', 15, AF10)>; /* SDMMC3_CK */ + slew-rate = <2>; + drive-push-pull; + bias-pull-up; + }; + pins3 { + pinmux = <STM32_PINMUX('D', 0, AF10)>; /* SDMMC2_CMD */ + slew-rate = <1>; + drive-open-drain; + bias-pull-up; + }; + }; + + sdmmc3_b4_sleep_pins_b: sdmmc3-b4-sleep-1 { + pins { + pinmux = <STM32_PINMUX('F', 0, ANALOG)>, /* SDMMC3_D0 */ + <STM32_PINMUX('F', 4, ANALOG)>, /* SDMMC3_D1 */ + <STM32_PINMUX('D', 5, ANALOG)>, /* SDMMC3_D2 */ + <STM32_PINMUX('D', 7, ANALOG)>, /* SDMMC3_D3 */ + <STM32_PINMUX('G', 15, ANALOG)>, /* SDMMC3_CK */ + <STM32_PINMUX('D', 0, ANALOG)>; /* SDMMC3_CMD */ + }; + }; + spdifrx_pins_a: spdifrx-0 { pins { pinmux = <STM32_PINMUX('G', 12, AF8)>; /* SPDIF_IN1 */ @@ -1160,7 +1552,7 @@ }; };
- spdifrx_sleep_pins_a: spdifrx-1 { + spdifrx_sleep_pins_a: spdifrx-sleep-0 { pins { pinmux = <STM32_PINMUX('G', 12, ANALOG)>; /* SPDIF_IN1 */ }; @@ -1168,15 +1560,15 @@
spi2_pins_a: spi2-0 { pins1 { - pinmux = <STM32_PINMUX('B', 10, AF5)>, /* SPI2_SCK */ - <STM32_PINMUX('I', 0, AF5)>, /* SPI2_NSS */ - <STM32_PINMUX('I', 3, AF5)>; /* SPI2_MOSI */ + pinmux = <STM32_PINMUX('B', 10, AF5)>, /* SPI1_SCK */ + <STM32_PINMUX('I', 3, AF5)>; /* SPI1_MOSI */ bias-disable; drive-push-pull; - slew-rate = <3>; + slew-rate = <1>; }; + pins2 { - pinmux = <STM32_PINMUX('I', 2, AF5)>; /* SPI2_MISO */ + pinmux = <STM32_PINMUX('I', 2, AF5)>; /* SPI1_MISO */ bias-disable; }; }; @@ -1188,6 +1580,54 @@ }; };
+ usart2_pins_a: usart2-0 { + pins1 { + pinmux = <STM32_PINMUX('F', 5, AF7)>, /* USART2_TX */ + <STM32_PINMUX('D', 4, AF7)>; /* USART2_RTS */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('D', 6, AF7)>, /* USART2_RX */ + <STM32_PINMUX('D', 3, AF7)>; /* USART2_CTS_NSS */ + bias-disable; + }; + }; + + usart2_sleep_pins_a: usart2-sleep-0 { + pins { + pinmux = <STM32_PINMUX('F', 5, ANALOG)>, /* USART2_TX */ + <STM32_PINMUX('D', 4, ANALOG)>, /* USART2_RTS */ + <STM32_PINMUX('D', 6, ANALOG)>, /* USART2_RX */ + <STM32_PINMUX('D', 3, ANALOG)>; /* USART2_CTS_NSS */ + }; + }; + + usart2_pins_b: usart2-1 { + pins1 { + pinmux = <STM32_PINMUX('F', 5, AF7)>, /* USART2_TX */ + <STM32_PINMUX('A', 1, AF7)>; /* USART2_RTS */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('F', 4, AF7)>, /* USART2_RX */ + <STM32_PINMUX('E', 15, AF7)>; /* USART2_CTS_NSS */ + bias-disable; + }; + }; + + usart2_sleep_pins_b: usart2-sleep-1 { + pins { + pinmux = <STM32_PINMUX('F', 5, ANALOG)>, /* USART2_TX */ + <STM32_PINMUX('A', 1, ANALOG)>, /* USART2_RTS */ + <STM32_PINMUX('F', 4, ANALOG)>, /* USART2_RX */ + <STM32_PINMUX('E', 15, ANALOG)>; /* USART2_CTS_NSS */ + }; + }; + usart3_pins_a: usart3-0 { pins1 { pinmux = <STM32_PINMUX('B', 10, AF7)>; /* USART3_TX */ @@ -1227,6 +1667,19 @@ }; };
+ uart4_pins_c: uart4-2 { + pins1 { + pinmux = <STM32_PINMUX('G', 11, AF6)>; /* UART4_TX */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('B', 2, AF8)>; /* UART4_RX */ + bias-disable; + }; + }; + uart7_pins_a: uart7-0 { pins1 { pinmux = <STM32_PINMUX('E', 8, AF7)>; /* UART4_TX */ @@ -1242,6 +1695,19 @@ }; };
+ uart7_pins_b: uart7-1 { + pins1 { + pinmux = <STM32_PINMUX('F', 7, AF7)>; /* UART7_TX */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('F', 6, AF7)>; /* UART7_RX */ + bias-disable; + }; + }; + uart8_pins_a: uart8-0 { pins1 { pinmux = <STM32_PINMUX('E', 1, AF8)>; /* UART8_TX */ @@ -1279,7 +1745,7 @@ }; };
- i2c2_pins_sleep_b2: i2c2-1 { + i2c2_sleep_pins_b2: i2c2-sleep-0 { pins { pinmux = <STM32_PINMUX('Z', 0, ANALOG)>; /* I2C2_SCL */ }; @@ -1295,7 +1761,7 @@ }; };
- i2c4_pins_sleep_a: i2c4-1 { + i2c4_sleep_pins_a: i2c4-sleep-0 { pins { pinmux = <STM32_PINMUX('Z', 4, ANALOG)>, /* I2C4_SCL */ <STM32_PINMUX('Z', 5, ANALOG)>; /* I2C4_SDA */ @@ -1316,4 +1782,18 @@ bias-disable; }; }; + + spi4_pins_a: spi4-0 { + pins { + pinmux = <STM32_PINMUX('E', 12, AF5)>, /* SPI4_SCK */ + <STM32_PINMUX('E', 6, AF5)>; /* SPI4_MOSI */ + bias-disable; + drive-push-pull; + slew-rate = <1>; + }; + pins2 { + pinmux = <STM32_PINMUX('E', 13, AF5)>; /* SPI4_MISO */ + bias-disable; + }; + }; }; diff --git a/arch/arm/dts/stm32mp15-u-boot.dtsi b/arch/arm/dts/stm32mp15-u-boot.dtsi index 1279589a56..142ad25c43 100644 --- a/arch/arm/dts/stm32mp15-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15-u-boot.dtsi @@ -32,6 +32,10 @@
reboot { u-boot,dm-pre-reloc; + compatible = "syscon-reboot"; + regmap = <&rcc>; + offset = <0x404>; + mask = <0x1>; };
soc { diff --git a/arch/arm/dts/stm32mp151.dtsi b/arch/arm/dts/stm32mp151.dtsi index 75d2c0d296..fb9bfeb633 100644 --- a/arch/arm/dts/stm32mp151.dtsi +++ b/arch/arm/dts/stm32mp151.dtsi @@ -26,8 +26,6 @@ psci { compatible = "arm,psci-1.0"; method = "smc"; - cpu_off = <0x84000002>; - cpu_on = <0x84000003>; };
intc: interrupt-controller@a0021000 { @@ -110,13 +108,6 @@ status = "disabled"; };
- reboot { - compatible = "syscon-reboot"; - regmap = <&rcc>; - offset = <0x404>; - mask = <0x1>; - }; - soc { compatible = "simple-bus"; #address-cells = <1>; @@ -482,7 +473,7 @@ };
i2c1: i2c@40012000 { - compatible = "st,stm32f7-i2c"; + compatible = "st,stm32mp15-i2c"; reg = <0x40012000 0x400>; interrupt-names = "event", "error"; interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>, @@ -491,12 +482,13 @@ resets = <&rcc I2C1_R>; #address-cells = <1>; #size-cells = <0>; + st,syscfg-fmp = <&syscfg 0x4 0x1>; wakeup-source; status = "disabled"; };
i2c2: i2c@40013000 { - compatible = "st,stm32f7-i2c"; + compatible = "st,stm32mp15-i2c"; reg = <0x40013000 0x400>; interrupt-names = "event", "error"; interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>, @@ -505,12 +497,13 @@ resets = <&rcc I2C2_R>; #address-cells = <1>; #size-cells = <0>; + st,syscfg-fmp = <&syscfg 0x4 0x2>; wakeup-source; status = "disabled"; };
i2c3: i2c@40014000 { - compatible = "st,stm32f7-i2c"; + compatible = "st,stm32mp15-i2c"; reg = <0x40014000 0x400>; interrupt-names = "event", "error"; interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, @@ -519,12 +512,13 @@ resets = <&rcc I2C3_R>; #address-cells = <1>; #size-cells = <0>; + st,syscfg-fmp = <&syscfg 0x4 0x4>; wakeup-source; status = "disabled"; };
i2c5: i2c@40015000 { - compatible = "st,stm32f7-i2c"; + compatible = "st,stm32mp15-i2c"; reg = <0x40015000 0x400>; interrupt-names = "event", "error"; interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>, @@ -533,6 +527,7 @@ resets = <&rcc I2C5_R>; #address-cells = <1>; #size-cells = <0>; + st,syscfg-fmp = <&syscfg 0x4 0x10>; wakeup-source; status = "disabled"; }; @@ -557,14 +552,14 @@
dac1: dac@1 { compatible = "st,stm32-dac"; - #io-channels-cells = <1>; + #io-channel-cells = <1>; reg = <1>; status = "disabled"; };
dac2: dac@2 { compatible = "st,stm32-dac"; - #io-channels-cells = <1>; + #io-channel-cells = <1>; reg = <2>; status = "disabled"; }; @@ -1139,6 +1134,11 @@ }; };
+ pwr_mcu: pwr_mcu@50001014 { + compatible = "syscon"; + reg = <0x50001014 0x4>; + }; + exti: interrupt-controller@5000d000 { compatible = "st,stm32mp1-exti", "syscon"; interrupt-controller; @@ -1395,14 +1395,12 @@ "mac-clk-tx", "mac-clk-rx", "eth-ck", - "ethstp", - "syscfg-clk"; + "ethstp"; clocks = <&rcc ETHMAC>, <&rcc ETHTX>, <&rcc ETHRX>, <&rcc ETHCK_K>, - <&rcc ETHSTP>, - <&rcc SYSCFG>; + <&rcc ETHSTP>; st,syscon = <&syscfg 0x4>; snps,mixed-burst; snps,pbl = <2>; @@ -1440,6 +1438,11 @@ clock-names = "lcd"; resets = <&rcc LTDC_R>; status = "disabled"; + + port { + #address-cells = <1>; + #size-cells = <0>; + }; };
iwdg2: watchdog@5a002000 { @@ -1495,7 +1498,7 @@ };
i2c4: i2c@5c002000 { - compatible = "st,stm32f7-i2c"; + compatible = "st,stm32mp15-i2c"; reg = <0x5c002000 0x400>; interrupt-names = "event", "error"; interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>, @@ -1504,6 +1507,7 @@ resets = <&rcc I2C4_R>; #address-cells = <1>; #size-cells = <0>; + st,syscfg-fmp = <&syscfg 0x4 0x8>; wakeup-source; status = "disabled"; }; @@ -1531,7 +1535,7 @@ };
i2c6: i2c@5c009000 { - compatible = "st,stm32f7-i2c"; + compatible = "st,stm32mp15-i2c"; reg = <0x5c009000 0x400>; interrupt-names = "event", "error"; interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>, @@ -1540,6 +1544,7 @@ resets = <&rcc I2C6_R>; #address-cells = <1>; #size-cells = <0>; + st,syscfg-fmp = <&syscfg 0x4 0x20>; wakeup-source; status = "disabled"; }; @@ -1721,6 +1726,7 @@ resets = <&rcc MCU_R>; st,syscfg-holdboot = <&rcc 0x10C 0x1>; st,syscfg-tz = <&rcc 0x000 0x1>; + st,syscfg-pdds = <&pwr_mcu 0x0 0x1>; status = "disabled"; }; }; diff --git a/arch/arm/dts/stm32mp157.dtsi b/arch/arm/dts/stm32mp157.dtsi index 3f0a4a91cc..54e73ccea4 100644 --- a/arch/arm/dts/stm32mp157.dtsi +++ b/arch/arm/dts/stm32mp157.dtsi @@ -15,7 +15,6 @@ clocks = <&rcc GPU>, <&rcc GPU_K>; clock-names = "bus" ,"core"; resets = <&rcc GPU_R>; - status = "disabled"; };
dsi: dsi@5a000000 { @@ -25,7 +24,14 @@ clock-names = "pclk", "ref", "px_clk"; resets = <&rcc DSI_R>; reset-names = "apb"; + #address-cells = <1>; + #size-cells = <0>; status = "disabled"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + }; }; }; }; diff --git a/arch/arm/dts/stm32mp157c-dk2.dts b/arch/arm/dts/stm32mp157c-dk2.dts index 7985b80967..9a8a26710a 100644 --- a/arch/arm/dts/stm32mp157c-dk2.dts +++ b/arch/arm/dts/stm32mp157c-dk2.dts @@ -27,15 +27,10 @@ };
&dsi { - #address-cells = <1>; - #size-cells = <0>; status = "okay"; phy-dsi-supply = <®18>;
ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { reg = <0>; dsi_in: endpoint { @@ -83,9 +78,6 @@ status = "okay";
port { - #address-cells = <1>; - #size-cells = <0>; - ltdc_ep1_out: endpoint@1 { reg = <1>; remote-endpoint = <&dsi_in>; diff --git a/arch/arm/dts/stm32mp157c-ed1.dts b/arch/arm/dts/stm32mp157c-ed1.dts index 186dc46754..c3a43c1423 100644 --- a/arch/arm/dts/stm32mp157c-ed1.dts +++ b/arch/arm/dts/stm32mp157c-ed1.dts @@ -126,13 +126,12 @@
&gpu { contiguous-area = <&gpu_reserved>; - status = "okay"; };
&i2c4 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2c4_pins_a>; - pinctrl-1 = <&i2c4_pins_sleep_a>; + pinctrl-1 = <&i2c4_sleep_pins_a>; i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; clock-frequency = <400000>; @@ -320,6 +319,10 @@ bus-width = <4>; vmmc-supply = <&vdd_sd>; vqmmc-supply = <&sd_switch>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr50; + sd-uhs-ddr50; status = "okay"; };
diff --git a/arch/arm/dts/stm32mp157c-ev1.dts b/arch/arm/dts/stm32mp157c-ev1.dts index 8a4c7ff31a..b19056557e 100644 --- a/arch/arm/dts/stm32mp157c-ev1.dts +++ b/arch/arm/dts/stm32mp157c-ev1.dts @@ -98,15 +98,10 @@ };
&dsi { - #address-cells = <1>; - #size-cells = <0>; phy-dsi-supply = <®18>; status = "okay";
ports { - #address-cells = <1>; - #size-cells = <0>; - port@0 { reg = <0>; dsi_in: endpoint { @@ -141,7 +136,7 @@ ðernet0 { status = "okay"; pinctrl-0 = <ðernet0_rgmii_pins_a>; - pinctrl-1 = <ðernet0_rgmii_pins_sleep_a>; + pinctrl-1 = <ðernet0_rgmii_sleep_pins_a>; pinctrl-names = "default", "sleep"; phy-mode = "rgmii-id"; max-speed = <1000>; @@ -176,7 +171,7 @@ &i2c2 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2c2_pins_a>; - pinctrl-1 = <&i2c2_pins_sleep_a>; + pinctrl-1 = <&i2c2_sleep_pins_a>; i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; status = "okay"; @@ -230,7 +225,7 @@ &i2c5 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2c5_pins_a>; - pinctrl-1 = <&i2c5_pins_sleep_a>; + pinctrl-1 = <&i2c5_sleep_pins_a>; i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; status = "okay"; @@ -240,9 +235,6 @@ status = "okay";
port { - #address-cells = <1>; - #size-cells = <0>; - ltdc_ep0_out: endpoint@0 { reg = <0>; remote-endpoint = <&dsi_in>; diff --git a/arch/arm/dts/stm32mp15xx-dkx.dtsi b/arch/arm/dts/stm32mp15xx-dkx.dtsi index 7589c6f9dc..05cafb79b3 100644 --- a/arch/arm/dts/stm32mp15xx-dkx.dtsi +++ b/arch/arm/dts/stm32mp15xx-dkx.dtsi @@ -112,14 +112,18 @@ &cec { pinctrl-names = "default", "sleep"; pinctrl-0 = <&cec_pins_b>; - pinctrl-1 = <&cec_pins_sleep_b>; + pinctrl-1 = <&cec_sleep_pins_b>; + status = "okay"; +}; + +&dts { status = "okay"; };
ðernet0 { status = "okay"; pinctrl-0 = <ðernet0_rgmii_pins_a>; - pinctrl-1 = <ðernet0_rgmii_pins_sleep_a>; + pinctrl-1 = <ðernet0_rgmii_sleep_pins_a>; pinctrl-names = "default", "sleep"; phy-mode = "rgmii-id"; max-speed = <1000>; @@ -137,13 +141,12 @@
&i2c1 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2c1_pins_a>; - pinctrl-1 = <&i2c1_pins_sleep_a>; + pinctrl-1 = <&i2c1_sleep_pins_a>; i2c-scl-rising-time-ns = <100>; i2c-scl-falling-time-ns = <7>; status = "okay"; @@ -218,7 +221,7 @@ &i2c4 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2c4_pins_a>; - pinctrl-1 = <&i2c4_pins_sleep_a>; + pinctrl-1 = <&i2c4_sleep_pins_a>; i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; clock-frequency = <400000>; @@ -385,7 +388,7 @@ clock-names = "pclk", "i2sclk", "x8k", "x11k"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2s2_pins_a>; - pinctrl-1 = <&i2s2_pins_sleep_a>; + pinctrl-1 = <&i2s2_sleep_pins_a>; status = "okay";
i2s2_port: port { @@ -409,13 +412,10 @@ <dc { pinctrl-names = "default", "sleep"; pinctrl-0 = <<dc_pins_a>; - pinctrl-1 = <<dc_pins_sleep_a>; + pinctrl-1 = <<dc_sleep_pins_a>; status = "okay";
port { - #address-cells = <1>; - #size-cells = <0>; - ltdc_ep0_out: endpoint@0 { reg = <0>; remote-endpoint = <&sii9022_in>;
&pinctrl {
- adc1_in6_pins_a: adc1-in6-0 { pins { pinmux = <STM32_PINMUX('F', 12, ANALOG)>; };
- adc12_ain_pins_b: adc12-ain-1 {
pins {
- adc12_usb_cc_pins_a: adc12-usb-cc-pins-0 { pins { pinmux = <STM32_PINMUX('A', 4, ANALOG)>, /* ADC12 in18 */
- cec_sleep_pins_a: cec-sleep-0 { pins { pinmux = <STM32_PINMUX('A', 15, ANALOG)>; /* HDMI_CEC */ };
- cec_sleep_pins_b: cec-sleep-1 { pins { pinmux = <STM32_PINMUX('B', 6, ANALOG)>; /* HDMI_CEC */ }; };
- dac_ch1_pins_a: dac-ch1-0 { pins { pinmux = <STM32_PINMUX('A', 4, ANALOG)>; }; };
- dac_ch2_pins_a: dac-ch2-0 { pins { pinmux = <STM32_PINMUX('A', 5, ANALOG)>; };
- ethernet0_rgmii_sleep_pins_a: rgmii-sleep-0 { pins1 { pinmux = <STM32_PINMUX('G', 5, ANALOG)>, /* ETH_RGMII_CLK125 */ <STM32_PINMUX('G', 4, ANALOG)>, /* ETH_RGMII_GTX_CLK */
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <2>;
pins2 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins3 {
bias-disable;
- ethernet0_rgmii_sleep_pins_b: rgmii-sleep-1 {
pins1 {
- ethernet0_rgmii_pins_c: rgmii-2 { pins1 { pinmux = <STM32_PINMUX('G', 5, AF11)>, /* ETH_RGMII_CLK125 */
- ethernet0_rmii_sleep_pins_a: rmii-sleep-0 { pins1 { pinmux = <STM32_PINMUX('G', 13, ANALOG)>, /* ETH1_RMII_TXD0 */ <STM32_PINMUX('G', 14, ANALOG)>, /* ETH1_RMII_TXD1 */
- i2c1_sleep_pins_a: i2c1-sleep-0 { pins { pinmux = <STM32_PINMUX('D', 12, ANALOG)>, /* I2C1_SCL */ <STM32_PINMUX('F', 15, ANALOG)>; /* I2C1_SDA */ }; };
- i2c1_pins_b: i2c1-1 { pins { pinmux = <STM32_PINMUX('F', 14, AF5)>, /* I2C1_SCL */ <STM32_PINMUX('F', 15, AF5)>; /* I2C1_SDA */
- i2c1_sleep_pins_b: i2c1-sleep-1 { pins { pinmux = <STM32_PINMUX('F', 14, ANALOG)>, /* I2C1_SCL */ <STM32_PINMUX('F', 15, ANALOG)>; /* I2C1_SDA */
- i2c2_sleep_pins_a: i2c2-sleep-0 { pins { pinmux = <STM32_PINMUX('H', 4, ANALOG)>, /* I2C2_SCL */ <STM32_PINMUX('H', 5, ANALOG)>; /* I2C2_SDA */ }; };
- i2c2_pins_b1: i2c2-1 { pins { pinmux = <STM32_PINMUX('H', 5, AF4)>; /* I2C2_SDA */ bias-disable;
- i2c2_sleep_pins_b1: i2c2-sleep-1 { pins { pinmux = <STM32_PINMUX('H', 5, ANALOG)>; /* I2C2_SDA */ }; };
- i2c2_pins_c: i2c2-2 { pins { pinmux = <STM32_PINMUX('F', 1, AF4)>, /* I2C2_SCL */ <STM32_PINMUX('H', 5, AF4)>; /* I2C2_SDA */
- i2c2_pins_sleep_c: i2c2-sleep-2 { pins { pinmux = <STM32_PINMUX('F', 1, ANALOG)>, /* I2C2_SCL */ <STM32_PINMUX('H', 5, ANALOG)>; /* I2C2_SDA */
- i2c5_sleep_pins_a: i2c5-sleep-0 { pins { pinmux = <STM32_PINMUX('A', 11, ANALOG)>, /* I2C5_SCL */ <STM32_PINMUX('A', 12, ANALOG)>; /* I2C5_SDA */
- i2c5_pins_b: i2c5-1 {
pins {
bias-disable;
drive-open-drain;
slew-rate = <0>;
- i2c5_sleep_pins_b: i2c5-sleep-1 {
pins {
- i2s2_pins_a: i2s2-0 { pins { pinmux = <STM32_PINMUX('I', 3, AF5)>, /* I2S2_SDO */
- i2s2_sleep_pins_a: i2s2-sleep-0 { pins { pinmux = <STM32_PINMUX('I', 3, ANALOG)>, /* I2S2_SDO */ <STM32_PINMUX('B', 9, ANALOG)>, /* I2S2_WS */
- ltdc_pins_a: ltdc-0 { pins { pinmux = <STM32_PINMUX('G', 7, AF14)>, /* LCD_CLK */ <STM32_PINMUX('I', 10, AF14)>, /* LCD_HSYNC */
- ltdc_sleep_pins_a: ltdc-sleep-0 { pins { pinmux = <STM32_PINMUX('G', 7, ANALOG)>, /* LCD_CLK */ <STM32_PINMUX('I', 10, ANALOG)>, /* LCD_HSYNC */
- ltdc_pins_b: ltdc-1 { pins { pinmux = <STM32_PINMUX('I', 14, AF14)>, /* LCD_CLK */ <STM32_PINMUX('I', 12, AF14)>, /* LCD_HSYNC */
- ltdc_sleep_pins_b: ltdc-sleep-1 { pins { pinmux = <STM32_PINMUX('I', 14, ANALOG)>, /* LCD_CLK */ <STM32_PINMUX('I', 12, ANALOG)>, /* LCD_HSYNC */
- ltdc_pins_c: ltdc-2 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
drive-push-pull;
slew-rate = <1>;
- ltdc_sleep_pins_c: ltdc-sleep-2 {
pins1 {
- ltdc_pins_d: ltdc-3 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <3>;
pins2 {
bias-disable;
drive-push-pull;
slew-rate = <2>;
- ltdc_sleep_pins_d: ltdc-sleep-3 {
pins {
- m_can1_pins_a: m-can1-0 { pins1 { pinmux = <STM32_PINMUX('H', 13, AF9)>; /* CAN1_TX */
- m_can1_pins_b: m-can1-1 {
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-disable;
pins2 {
bias-disable;
- m_can1_sleep_pins_b: m_can1-sleep-1 {
pins {
- m_can2_pins_a: m-can2-0 {
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-disable;
pins2 {
bias-disable;
- m_can2_sleep_pins_a: m_can2-sleep-0 {
pins {
- pwm1_pins_a: pwm1-0 { pins { pinmux = <STM32_PINMUX('E', 9, AF1)>, /* TIM1_CH1 */
- pwm3_pins_b: pwm3-1 {
pins {
bias-disable;
drive-push-pull;
slew-rate = <0>;
- pwm3_sleep_pins_b: pwm3-sleep-1 {
pins {
- pwm4_pins_a: pwm4-0 { pins { pinmux = <STM32_PINMUX('D', 14, AF2)>, /* TIM4_CH3 */
- pwm5_pins_b: pwm5-1 {
pins {
bias-disable;
drive-push-pull;
slew-rate = <0>;
- pwm5_sleep_pins_b: pwm5-sleep-1 {
pins {
- pwm8_pins_a: pwm8-0 { pins { pinmux = <STM32_PINMUX('I', 2, AF3)>; /* TIM8_CH4 */
- sai2a_sleep_pins_a: sai2a-sleep-0 { pins { pinmux = <STM32_PINMUX('I', 5, ANALOG)>, /* SAI2_SCK_A */ <STM32_PINMUX('I', 6, ANALOG)>, /* SAI2_SD_A */
- sai2a_pins_b: sai2a-1 { pins1 { pinmux = <STM32_PINMUX('I', 6, AF10)>, /* SAI2_SD_A */ <STM32_PINMUX('I', 7, AF10)>, /* SAI2_FS_A */
- sai2a_sleep_pins_b: sai2a-sleep-1 { pins { pinmux = <STM32_PINMUX('I', 6, ANALOG)>, /* SAI2_SD_A */ <STM32_PINMUX('I', 7, ANALOG)>, /* SAI2_FS_A */
- sai2a_pins_c: sai2a-4 {
pins {
slew-rate = <0>;
drive-push-pull;
bias-disable;
- sai2a_sleep_pins_c: sai2a-5 {
pins {
- sai2b_pins_a: sai2b-0 { pins1 { pinmux = <STM32_PINMUX('E', 12, AF10)>, /* SAI2_SCK_B */
- sai2b_sleep_pins_a: sai2b-sleep-0 { pins { pinmux = <STM32_PINMUX('F', 11, ANALOG)>, /* SAI2_SD_B */ <STM32_PINMUX('E', 12, ANALOG)>, /* SAI2_SCK_B */
- sai2b_pins_b: sai2b-1 { pins { pinmux = <STM32_PINMUX('F', 11, AF10)>; /* SAI2_SD_B */ bias-disable; }; };
- sai2b_sleep_pins_b: sai2b-sleep-1 {
pins {
- sai2b_pins_c: sai2a-4 {
pins1 {
bias-disable;
- sai2b_sleep_pins_c: sai2a-sleep-5 { pins { pinmux = <STM32_PINMUX('F', 11, ANALOG)>; /* SAI2_SD_B */ };
- sai4a_sleep_pins_a: sai4a-sleep-0 { pins { pinmux = <STM32_PINMUX('B', 5, ANALOG)>; /* SAI4_SD_A */ };
}; };<STM32_PINMUX('E', 4, ANALOG)>; /* SDMMC1_CKIN */
pins {
slew-rate = <1>;
drive-push-pull;
bias-disable;
pins {
- sdmmc2_d47_pins_c: sdmmc2-d47-2 { pins { pinmux = <STM32_PINMUX('A', 8, AF9)>, /* SDMMC2_D4 */ <STM32_PINMUX('A', 15, AF9)>, /* SDMMC2_D5 */
- sdmmc2_d47_sleep_pins_c: sdmmc2-d47-sleep-2 { pins { pinmux = <STM32_PINMUX('A', 8, ANALOG)>, /* SDMMC2_D4 */ <STM32_PINMUX('A', 15, ANALOG)>, /* SDMMC2_D5 */
- sdmmc3_b4_pins_b: sdmmc3-b4-1 {
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-pull-up;
pins2 {
slew-rate = <2>;
drive-push-pull;
bias-pull-up;
- sdmmc3_b4_od_pins_b: sdmmc3-b4-od-1 {
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-pull-up;
pins2 {
slew-rate = <2>;
drive-push-pull;
bias-pull-up;
pins3 {
slew-rate = <1>;
drive-open-drain;
bias-pull-up;
- sdmmc3_b4_sleep_pins_b: sdmmc3-b4-sleep-1 {
pins {
- spdifrx_pins_a: spdifrx-0 { pins { pinmux = <STM32_PINMUX('G', 12, AF8)>; /* SPDIF_IN1 */
- spdifrx_sleep_pins_a: spdifrx-sleep-0 { pins { pinmux = <STM32_PINMUX('G', 12, ANALOG)>; /* SPDIF_IN1 */ };
slew-rate = <3>;
};slew-rate = <1>;
- pins2 {
}; };pinmux = <STM32_PINMUX('I', 2, AF5)>; /* SPI1_MISO */ bias-disable;
- usart2_pins_a: usart2-0 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
- usart2_sleep_pins_a: usart2-sleep-0 {
pins {
- usart2_pins_b: usart2-1 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
- usart2_sleep_pins_b: usart2-sleep-1 {
pins {
- usart3_pins_a: usart3-0 { pins1 { pinmux = <STM32_PINMUX('B', 10, AF7)>; /* USART3_TX */
- uart4_pins_c: uart4-2 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
- uart7_pins_a: uart7-0 { pins1 { pinmux = <STM32_PINMUX('E', 8, AF7)>; /* UART4_TX */
- uart7_pins_b: uart7-1 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
- uart8_pins_a: uart8-0 { pins1 { pinmux = <STM32_PINMUX('E', 1, AF8)>; /* UART8_TX */
- i2c2_sleep_pins_b2: i2c2-sleep-0 { pins { pinmux = <STM32_PINMUX('Z', 0, ANALOG)>; /* I2C2_SCL */ };
- i2c4_sleep_pins_a: i2c4-sleep-0 { pins { pinmux = <STM32_PINMUX('Z', 4, ANALOG)>, /* I2C4_SCL */ <STM32_PINMUX('Z', 5, ANALOG)>; /* I2C4_SDA */
- spi4_pins_a: spi4-0 {
pins {
bias-disable;
drive-push-pull;
slew-rate = <1>;
pins2 {
bias-disable;
regmap = <&rcc>;
offset = <0x404>;
mask = <0x1>;
soc {
- reboot {
regmap = <&rcc>;
offset = <0x404>;
mask = <0x1>;
};st,syscfg-fmp = <&syscfg 0x4 0x10>; wakeup-source; status = "disabled";
#io-channel-cells = <1>; reg = <1>; status = "disabled"; }; dac2: dac@2 { compatible = "st,stm32-dac";
- exti: interrupt-controller@5000d000 { compatible = "st,stm32mp1-exti", "syscon"; interrupt-controller;
"ethstp",
"syscfg-clk";
<&rcc ETHSTP>,
<&rcc SYSCFG>;
port {
#size-cells = <0>;
};st,syscfg-fmp = <&syscfg 0x4 0x8>; wakeup-source; status = "disabled";
};st,syscfg-fmp = <&syscfg 0x4 0x20>; wakeup-source; status = "disabled";
}; };st,syscfg-pdds = <&pwr_mcu 0x0 0x1>; status = "disabled";
dsi: dsi@5a000000 {
ports {
#size-cells = <0>;
&dsi {
ports {
#size-cells = <0>;
port {
#size-cells = <0>;
- status = "okay";
- pinctrl-1 = <&i2c4_sleep_pins_a>; i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; clock-frequency = <400000>;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-ddr50; status = "okay";
&dsi {
ports {
#size-cells = <0>;
- pinctrl-1 = <ðernet0_rgmii_sleep_pins_a>; pinctrl-names = "default", "sleep"; phy-mode = "rgmii-id"; max-speed = <1000>;
- pinctrl-1 = <&i2c2_sleep_pins_a>; i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; status = "okay";
- pinctrl-1 = <&i2c5_sleep_pins_a>; i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; status = "okay";
port {
#size-cells = <0>;
- pinctrl-1 = <&cec_sleep_pins_b>;
- status = "okay";
- status = "okay";
- pinctrl-1 = <&i2c1_sleep_pins_a>; i2c-scl-rising-time-ns = <100>; i2c-scl-falling-time-ns = <7>; status = "okay";
i2s2_port: port {
port {
#size-cells = <0>;
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Thanks
Patrice
&pinctrl {
pins {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <2>;
pins2 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins3 {
bias-disable;
pins1 {
pins {
bias-disable;
drive-open-drain;
slew-rate = <0>;
pins {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
drive-push-pull;
slew-rate = <1>;
pins1 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <3>;
pins2 {
bias-disable;
drive-push-pull;
slew-rate = <2>;
pins {
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-disable;
pins2 {
bias-disable;
pins {
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-disable;
pins2 {
bias-disable;
pins {
pins {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins {
pins {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins {
pins {
slew-rate = <0>;
drive-push-pull;
bias-disable;
pins {
pins {
pins1 {
bias-disable;
pins {
slew-rate = <1>;
drive-push-pull;
bias-disable;
pins {
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-pull-up;
pins2 {
slew-rate = <2>;
drive-push-pull;
bias-pull-up;
pins1 {
slew-rate = <1>;
drive-push-pull;
bias-pull-up;
pins2 {
slew-rate = <2>;
drive-push-pull;
bias-pull-up;
pins3 {
slew-rate = <1>;
drive-open-drain;
bias-pull-up;
pins {
slew-rate = <3>;
};slew-rate = <1>;
- pins2 {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
pins {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
pins {
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
pins1 {
bias-disable;
drive-push-pull;
slew-rate = <0>;
pins2 {
bias-disable;
pins {
bias-disable;
drive-push-pull;
slew-rate = <1>;
pins2 {
bias-disable;
regmap = <&rcc>;
offset = <0x404>;
mask = <0x1>;
soc {
- reboot {
regmap = <&rcc>;
offset = <0x404>;
mask = <0x1>;
"ethstp",
"syscfg-clk";
<&rcc ETHSTP>,
<&rcc SYSCFG>;
port {
#size-cells = <0>;
dsi: dsi@5a000000 {
ports {
#size-cells = <0>;
&dsi {
ports {
#size-cells = <0>;
port {
#size-cells = <0>;
- status = "okay";
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
&dsi {
ports {
#size-cells = <0>;
port {
#size-cells = <0>;
- status = "okay";
- status = "okay";
i2s2_port: port {
port {
#size-cells = <0>;
Thanks
Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Applied to u-boot-stm/master
Thanks
Patrice
- ethernet0_rgmii_pins_c: rgmii-2 { pins1 { pinmux = <STM32_PINMUX('G', 5, AF11)>, /* ETH_RGMII_CLK125 */ <STM32_PINMUX('G', 4, AF11)>, /* ETH_RGMII_GTX_CLK */
- ethernet0_rgmii_sleep_pins_c: rgmii-sleep-2 { pins1 { pinmux = <STM32_PINMUX('G', 5, ANALOG)>, /* ETH_RGMII_CLK125 */ <STM32_PINMUX('G', 4, ANALOG)>, /* ETH_RGMII_GTX_CLK */
- pinctrl-0 = <ðernet0_rgmii_pins_c>;
- pinctrl-1 = <ðernet0_rgmii_sleep_pins_c>; pinctrl-names = "default", "sleep"; phy-mode = "rgmii"; max-speed = <1000>;
Thanks
Patrice
Thanks
Patrice
Heiko Schocher
Patrice CHOTARD
Patrick Delaunay
