[U-Boot] [U-boot] [PATCH] Support for the Calao USB-A9260/USB-A9G20 boards
The Calao USB-A9260 and USB-9G20 boards are manufactured and sold by Calao Systems http://www.calao-systems.com. They are built around an AT91SAM9260 ARM SoC running at 180MHz and an AT91SAM9G20 ARM SoC running at 400MHz respectively. They feature an Ethernet port, 64Mo of SDRAM, 256Mo of NAND flash, two USB host ports, and an USB device port. They also feature a FTDI2232 converter which provides the ability to use the DBGU serial port & the JTAG port over a USB interface.
Signed-off-by: Gregory Hermant gregory.hermant@calao-systems.com --- MAINTAINERS | 5 + MAKEALL | 2 + Makefile | 5 + board/calao/usb_a9260/Makefile | 55 ++++++++++ board/calao/usb_a9260/config.mk | 1 + board/calao/usb_a9260/spi.c | 50 ++++++++++ board/calao/usb_a9260/usb_a9260.c | 197 +++++++++++++++++++++++++++++++++++++ include/configs/usb_a9260.h | 179 +++++++++++++++++++++++++++++++++ 8 files changed, 494 insertions(+), 0 deletions(-) create mode 100644 board/calao/usb_a9260/Makefile create mode 100644 board/calao/usb_a9260/config.mk create mode 100644 board/calao/usb_a9260/spi.c create mode 100644 board/calao/usb_a9260/usb_a9260.c create mode 100644 include/configs/usb_a9260.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9734b1d..f47acb6 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -588,6 +588,11 @@ Kshitij Gupta kshitij@ti.com omap1510inn ARM925T omap1610inn ARM926EJS
+Gregory Hermant gregory.hermant@calao-systems.com + + usb_a9260 ARM926EJS (AT91SAM9G20 SoC) + usb_a9g20 ARM926EJS (AT91SAM9G20 SoC) + Grazvydas Ignotas notasas@gmail.com
omap3_pandora ARM CORTEX-A8 (OMAP3xx SoC) diff --git a/MAKEALL b/MAKEALL index ab1bb6f..b07118d 100755 --- a/MAKEALL +++ b/MAKEALL @@ -657,6 +657,8 @@ LIST_at91=" \ SBC35_A9G20 \ TNY_A9260 \ TNY_A9G20 \ + USB_A9260 \ + USB_A9G20 \ "
######################################################################### diff --git a/Makefile b/Makefile index ed6156f..c5e66a5 100644 --- a/Makefile +++ b/Makefile @@ -2874,6 +2874,11 @@ TNY_A9260_config : unconfig @echo "#define CONFIG_$(@:_config=) 1" >$(obj)include/config.h @$(MKCONFIG) -a tny_a9260 arm arm926ejs tny_a9260 calao at91
+USB_A9G20_config \ +USB_A9260_config : unconfig + @mkdir -p $(obj)include + @echo "#define CONFIG_$(@:_config=) 1" >$(obj)include/config.h + @$(MKCONFIG) -a usb_a9260 arm arm926ejs usb_a9260 calao at91 ######################################################################## ## ARM Integrator boards - see doc/README-integrator for more info. integratorap_config \ diff --git a/board/calao/usb_a9260/Makefile b/board/calao/usb_a9260/Makefile new file mode 100644 index 0000000..c092863 --- /dev/null +++ b/board/calao/usb_a9260/Makefile @@ -0,0 +1,55 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += usb_a9260.o +COBJS-$(CONFIG_ATMEL_SPI) += spi.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/calao/usb_a9260/config.mk b/board/calao/usb_a9260/config.mk new file mode 100644 index 0000000..ff2cfd1 --- /dev/null +++ b/board/calao/usb_a9260/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x23f00000 diff --git a/board/calao/usb_a9260/spi.c b/board/calao/usb_a9260/spi.c new file mode 100644 index 0000000..689dd28 --- /dev/null +++ b/board/calao/usb_a9260/spi.c @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2009 + * Gregory Hermant, Calao-systems gregory.hermant@calao-systems.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/hardware.h> +#include <asm/arch/at91_spi.h> +#include <asm/arch/gpio.h> +#include <spi.h> + +#define USB_A9260_CS_PIN AT91_PIN_PC11 + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + return bus == 0 && cs == 1; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + at91_set_gpio_value(USB_A9260_CS_PIN, 0); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + at91_set_gpio_value(USB_A9260_CS_PIN, 1); +} + +void spi_init_f(void) +{ + /* everything done in board_init */ +} diff --git a/board/calao/usb_a9260/usb_a9260.c b/board/calao/usb_a9260/usb_a9260.c new file mode 100644 index 0000000..f195bd5 --- /dev/null +++ b/board/calao/usb_a9260/usb_a9260.c @@ -0,0 +1,197 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * Copyright (C) 2009 + * Gregory Hermant, Calao-systems gregory.hermant@calao-systems.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9260.h> +#include <asm/arch/at91sam9_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/gpio.h> +#include <asm/arch/io.h> +#include <asm/arch/hardware.h> +#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) +#include <net.h> +#endif +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ +/* + * Miscelaneous platform dependent initialisations + */ + +#ifdef CONFIG_CMD_NAND +static void usb_a9260_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBICSA); + at91_sys_write(AT91_MATRIX_EBICSA, + csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | + /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | + AT91_SMC_TDF_(2)); + + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif + +#ifdef CONFIG_MACB +static void usb_a9260_macb_hw_init(void) +{ + unsigned long rstc; + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_EMAC); + + /* + * Disable pull-up on: + * RXDV (PA17) => PHY normal mode (not Test mode) + * ERX0 (PA14) => PHY ADDR0 + * ERX1 (PA15) => PHY ADDR1 + * ERX2 (PA25) => PHY ADDR2 + * ERX3 (PA26) => PHY ADDR3 + * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 + * + * PHY has internal pull-down + */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUDR); + + rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + + /* Need to reset PHY -> 500ms reset */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (AT91_RSTC_ERSTL & (0x0D << 8)) | + AT91_RSTC_URSTEN); + + at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + + /* Wait for end hardware reset */ + while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)); + + /* Restore NRST value */ + at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | + (rstc) | + AT91_RSTC_URSTEN); + + /* Re-enable pull-up */ + writel(pin_to_mask(AT91_PIN_PA14) | + pin_to_mask(AT91_PIN_PA15) | + pin_to_mask(AT91_PIN_PA17) | + pin_to_mask(AT91_PIN_PA25) | + pin_to_mask(AT91_PIN_PA26) | + pin_to_mask(AT91_PIN_PA28), + pin_to_controller(AT91_PIN_PA0) + PIO_PUER); + + at91_macb_hw_init(); +} +#endif + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + +#if defined(CONFIG_USB_A9260) + gd->bd->bi_arch_number = MACH_TYPE_USB_A9260; +#elif defined(CONFIG_USB_A9G20) + gd->bd->bi_arch_number = MACH_TYPE_USB_A9G20; +#endif + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); + usb_a9260_nand_hw_init(); +#ifdef CONFIG_ATMEL_SPI + at91_spi0_hw_init(1 << 5); +#endif +#ifdef CONFIG_MACB + usb_a9260_macb_hw_init(); +#endif + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + if(get_ram_size((long *) PHYS_SDRAM, PHYS_SDRAM_SIZE) != PHYS_SDRAM_SIZE) + return -1; + + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void reset_phy(void) +{ +#ifdef CONFIG_MACB + /* + * Initialize ethernet HW addr prior to starting Linux, + * needed for nfsroot + */ + eth_init(gd->bd); +#endif +} +#endif + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x01); +#endif + return rc; +} diff --git a/include/configs/usb_a9260.h b/include/configs/usb_a9260.h new file mode 100644 index 0000000..f92b23d --- /dev/null +++ b/include/configs/usb_a9260.h @@ -0,0 +1,179 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * Copyright (C) 2009 + * Gregory Hermant, Calao-systems gregory.hermant@calao-systems.com + * + * Configuation settings for the Calao USB-A9260 and USB-A9G20 boards + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_USB_A9260 +#define CONFIG_AT91SAM9260 +#else +#define CONFIG_AT91SAM9G20 +#endif + +/* ARM asynchronous clock */ +#define AT91_MAIN_CLOCK 12000000 /* 12 MHz crystal */ +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_ARCH_CPU_INIT +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +/* + * Hardware drivers + */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_USB 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 +#define PHYS_SDRAM_SIZE 0x04000000 /* 64 MB */ + +/* SPI EEPROM */ +#define CONFIG_SPI +#define CONFIG_CMD_SPI +#define CONFIG_ATMEL_SPI +#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) + +#define CONFIG_CMD_EEPROM +#define CONFIG_SPI_M95XXX +#define CONFIG_SYS_EEPROM_SIZE 0x10000 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 + +/* NAND flash */ +#define CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +//#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 + +/* NOR flash - no real flash on this board */ +#define CONFIG_SYS_NO_FLASH 1 + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_RESET_PHY_R 1 +#define CONFIG_MACB_SEARCH_PHY 1 + +/* USB */ +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW 1 +#define CONFIG_DOS_PARTITION 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 /* AT91SAM9260_UHP_BASE */ +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_USB_STORAGE 1 +#define CONFIG_CMD_FAT 1 + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x23e00000 + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_OFFSET 0x60000 +#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_SIZE 0x20000 + +#define CONFIG_BOOTCOMMAND "nboot 0x21000000 0 400000" +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock1 " \ + "mtdparts=atmel_nand:16M(kernel)ro," \ + "120M(rootfs),-(other) " \ + "rw rootfstype=jffs2" + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "U-Boot> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
Please run the linux kernel's checkpatch.pl program In general errors must be fixed. The warnings should be fixed when appropriate.
<snip>
Order alphabetically
<snip>
- Miscelaneous platform dependent initialisations
sp 'initializations'
- unsigned long csa;
<snip>
Move clock definitions below board/cpu definitions
- Hardware drivers
- BOOTP options
- Command line configuration.
Remove if unneeded or uncomment
Tom
Gregory Hermant
Tom
