[U-Boot] [PATCH] Convert CONFIG_SYS_I2C_DAVINCI to Kconfig
This converts the following to Kconfig: CONFIG_SYS_I2C_DAVINCI
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index abb2295951..31e0529e40 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -38,6 +38,7 @@ CONFIG_DM=y CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_MTD_DEVICE=y CONFIG_MTD_PARTITIONS=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 4242728e6a..ea56d01344 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_GPIO=y CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_MTD_DEVICE=y CONFIG_MTD_PARTITIONS=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 9d6c47df50..b5f17c2575 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -38,6 +38,7 @@ CONFIG_DM=y CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y +CONFIG_SYS_I2C_DAVINCI=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index ace5fc51d4..76f2d97786 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_DIAG=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DA8XX_GPIO=y +CONFIG_SYS_I2C_DAVINCI=y # CONFIG_MMC is not set CONFIG_NAND=y CONFIG_NAND_DAVINCI=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index c5bb84a8d6..0b9fcd2cd9 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index a86eeb8b14..78b0060457 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -27,6 +27,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 911618c17a..813483b40f 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y # CONFIG_BLK is not set +CONFIG_SYS_I2C_DAVINCI=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 174af79960..015eb54ec1 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -27,6 +27,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y # CONFIG_BLK is not set +CONFIG_SYS_I2C_DAVINCI=y CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 942e44e7a9..ee24a558b7 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 12be37f0b7..4af27ed30f 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -27,6 +27,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 5381e9f7cc..4150af1d9c 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -34,6 +34,7 @@ CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 0381a7240c..f9f38ee62f 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -26,6 +26,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_TI_AEMIF=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 8ee2d223fd..c9a7eb6e10 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_SPI=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_DIAG=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 4a97269dd4..b16e9d3665 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -34,6 +34,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_DM_I2C=y CONFIG_DM_I2C_COMPAT=y +CONFIG_SYS_I2C_DAVINCI=y CONFIG_NAND=y CONFIG_NAND_DAVINCI=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 5eceab9ea8..27331259d3 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -96,6 +96,12 @@ config SYS_I2C_CADENCE Say yes here to select Cadence I2C Host Controller. This controller is e.g. used by Xilinx Zynq.
+config SYS_I2C_DAVINCI + bool "Davinci I2C Controller" + depends on (ARCH_KEYSTONE || ARCH_DAVINCI) + help + Say yes here to add support for Davinci and Keystone I2C controller + config SYS_I2C_DW bool "Designware I2C Controller" default n diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 3dcd1390ca..00efe6164c 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -141,7 +141,6 @@ * I2C Configuration */ #ifndef CONFIG_SPL_BUILD -#define CONFIG_SYS_I2C_DAVINCI #define CONFIG_SYS_I2C_EXPANDER_ADDR 0x20 #endif
diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 485866d694..f459ac4b2d 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -62,7 +62,6 @@ * I2C Configuration */ #define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_DAVINCI #define CONFIG_SYS_DAVINCI_I2C_SPEED 100000 #define CONFIG_SYS_DAVINCI_I2C_SLAVE 10 /* Bogus, master-only in U-Boot */
diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index 7a0511f88e..d5ea1fa833 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -56,7 +56,6 @@ * I2C Configuration */ #define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_DAVINCI #define CONFIG_SYS_DAVINCI_I2C_SPEED 400000 #define CONFIG_SYS_DAVINCI_I2C_SLAVE 10 /* Bogus, master-only in U-Boot */
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index a68c18f625..14b18ce623 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -133,7 +133,6 @@ /* * I2C Configuration */ -#define CONFIG_SYS_I2C_DAVINCI #define CONFIG_SYS_DAVINCI_I2C_SPEED 25000 #define CONFIG_SYS_DAVINCI_I2C_SLAVE 10 /* Bogus, master-only in U-Boot */ #define CONFIG_SYS_I2C_EXPANDER_ADDR 0x20 diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 116bfaa4d9..1c68aaf437 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -143,7 +143,6 @@ #define CONFIG_AEMIF_CNTRL_BASE KS2_AEMIF_CNTRL_BASE
/* I2C Configuration */ -#define CONFIG_SYS_I2C_DAVINCI #define CONFIG_SYS_DAVINCI_I2C_SPEED 100000 #define CONFIG_SYS_DAVINCI_I2C_SLAVE 0x10 /* SMBus host address */ #define CONFIG_SYS_DAVINCI_I2C_SPEED1 100000 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 0ec125160d..95d7ab0e7a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3071,7 +3071,6 @@ CONFIG_SYS_I2C_BASE4 CONFIG_SYS_I2C_BASE5 CONFIG_SYS_I2C_BUSES CONFIG_SYS_I2C_CLK_OFFSET -CONFIG_SYS_I2C_DAVINCI CONFIG_SYS_I2C_DIRECT_BUS CONFIG_SYS_I2C_DVI_ADDR CONFIG_SYS_I2C_DVI_BUS_NUM
Adam Ford
