Re: [U-Boot] Fwd: [STATUS] WARNING: huge ARM board removal pending
Dear Xu, Hong,
Dear Reinhard,
We just noticed the warning from Wolfgang Denk about the status of the ARM boards.
See http://article.gmane.org/gmane.comp.boot-loaders.u-boot/100918
There're quite a lot of AT91 boards listed. We're going to focus on
fixing the current issues to let MAKEALL happy. :-)
I know exactly your great work on AT91 and AVR32. The rework you're
doing is quite excellent. We of course want to sync with what you have
done. Could you please describe us the starting point we can begin with?
Do you have special things which we can help? And so on ...
Thanks a lot.
If there are SoC specific files to be adapted, they should be adapted as done in 9260.
Board specific files should be looking like those of at91sam9260-ek.
Remove fixed boards from the global Makefile and add them to boards.cfg.
I'll put the fix for at91sam9260*-ek on u-boot-atmel/master in the next hours, you can have a look at it - or look at the patch I posted yesterday for it.
Two notes: 1. please limit line length in e-Mails to 80 or less - I had to manually break your mail to be able to read it.
2. please post to the u-boot mailing list as well
Best Regards,
Reinhard
Hi Reinhard,
On 06/07/2011 04:18 PM, Reinhard Meyer wrote:
Dear Xu, Hong,
Dear Reinhard,
Thanks a lot.
OK, very nice. I'm just worried because I can not compile at91sam9260ek on u-boot-atmel/master and u-boot-atmel/next 3 hrs ago.
So, we're waiting for your work on sam9260 and take it as a starting point for other boards.
Two notes:
- please limit line length in e-Mails to 80 or less - I had to manually
- please post to the u-boot mailing list as well
No problem.
BR, Eric
Best Regards,
Reinhard
Dear Hong Xu,
Its now there.
With toolchain ARM-4.5.2 the following warning is given (building top9000_eval_xe_config). I had no time to look into this. The warning is not due to rework and shows only with newer toolchains, I think.
*** make u-boot.bin macb.c: In function ‘macb_write_hwaddr’: macb.c:525:2: warning: dereferencing type-punned pointer will break strict-aliasing rules
at91sam9260-ek builds but throws a few more warnings in the dataflash_spi driver. Please also see my post titled "[U-Boot] ATMEL atmel_dataflash_spi.c - work at hand - can someone do it ?"
Maybe you can look into that :)
Best Regards,
Reinhard
Hong Xu
Reinhard Meyer
