[U-Boot] [PATCH] M68K: eb_cpu5282: general update and enhanced board support
From: "Jens Scharsig (BuS Elektronik)" esw@bus-elektronik.de
- update clock settings for higher perfomance - change standard baud rate to 115200 - fix flash base address - remove unused defines - add I2C support - switch form board dependent flash to cfi - remove board dependent flash code - use sdram bank 0 instead of bank 1 on boot - enable on board frame buffer instead external - remove fake mac address form config - add watchdog support - add status led support
Signed-off-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de --- board/BuS/eb_cpu5282/Makefile | 2 +- board/BuS/eb_cpu5282/cfm_flash.c | 212 ------------------- board/BuS/eb_cpu5282/cfm_flash.h | 40 ---- board/BuS/eb_cpu5282/config.mk | 27 --- board/BuS/eb_cpu5282/eb_cpu5282.c | 102 ++++++--- board/BuS/eb_cpu5282/flash.c | 415 ------------------------------------- boards.cfg | 2 +- include/configs/eb_cpu5282.h | 101 +++++---- 8 files changed, 142 insertions(+), 759 deletions(-) delete mode 100644 board/BuS/eb_cpu5282/cfm_flash.c delete mode 100644 board/BuS/eb_cpu5282/cfm_flash.h delete mode 100644 board/BuS/eb_cpu5282/config.mk delete mode 100644 board/BuS/eb_cpu5282/flash.c
diff --git a/board/BuS/eb_cpu5282/Makefile b/board/BuS/eb_cpu5282/Makefile index 0f14699..ac860c1 100644 --- a/board/BuS/eb_cpu5282/Makefile +++ b/board/BuS/eb_cpu5282/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
-COBJS = $(BOARD).o cfm_flash.o flash.o +COBJS = $(BOARD).o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/BuS/eb_cpu5282/cfm_flash.c b/board/BuS/eb_cpu5282/cfm_flash.c deleted file mode 100644 index fe03b17..0000000 --- a/board/BuS/eb_cpu5282/cfm_flash.c +++ /dev/null @@ -1,212 +0,0 @@ -/* - * Basic Flash Driver for Freescale MCF 5281/5282 internal FLASH - * - * (C) Copyright 2005 BuS Elektronik GmbH & Co.KG esw@bus-elektonik.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/m5282.h> -#include "cfm_flash.h" - -#if defined(CONFIG_M5281) || defined(CONFIG_M5282) - -#if (CONFIG_SYS_CLK>20000000) - #define CFM_CLK (((long) CONFIG_SYS_CLK / (400000 * 8) + 1) | 0x40) -#else - #define CFM_CLK ((long) CONFIG_SYS_CLK / 400000 + 1) -#endif - -#define cmf_backdoor_address(addr) (((addr) & 0x0007FFFF) | 0x04000000 | \ - (CONFIG_SYS_MBAR & 0xC0000000)) - -void cfm_flash_print_info (flash_info_t * info) -{ - printf ("Freescale: "); - switch (info->flash_id & FLASH_TYPEMASK) { - case FREESCALE_ID_MCF5281 & FLASH_TYPEMASK: - printf ("MCF5281 internal FLASH\n"); - break; - case FREESCALE_ID_MCF5282 & FLASH_TYPEMASK: - printf ("MCF5282 internal FLASH\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } -} - -void cfm_flash_init (flash_info_t * info) -{ - int sector; - ulong protection; - MCFCFM_MCR = 0; - MCFCFM_CLKD = CFM_CLK; - debug ("CFM Clock divider: %ld (%d Hz @ %ld Hz)\n",CFM_CLK,\ - CONFIG_SYS_CLK / (2* ((CFM_CLK & 0x3F)+1) * (1+((CFM_CLK & 0x40)>>6)*7)),\ - CONFIG_SYS_CLK); - MCFCFM_SACC = 0; - MCFCFM_DACC = 0; - - if (MCFCFM_SEC & MCFCFM_SEC_KEYEN) - puts("CFM backdoor access is enabled\n"); - if (MCFCFM_SEC & MCFCFM_SEC_SECSTAT) - puts("CFM securety is enabled\n"); - - #ifdef CONFIG_M5281 - info->flash_id = (FREESCALE_MANUFACT & FLASH_VENDMASK) | - (FREESCALE_ID_MCF5281 & FLASH_TYPEMASK); - info->size = 256*1024; - info->sector_count = 16; - #else - info->flash_id = (FREESCALE_MANUFACT & FLASH_VENDMASK) | - (FREESCALE_ID_MCF5282 & FLASH_TYPEMASK); - info->size = 512*1024; - info->sector_count = 32; - #endif - protection = MCFCFM_PROT; - for (sector = 0; sector < info->sector_count; sector++) - { - if (sector == 0) - { - info->start[sector] = CONFIG_SYS_INT_FLASH_BASE; - } - else - { - info->start[sector] = info->start[sector-1] + 0x04000; - } - info->protect[sector] = protection & 1; - protection >>= 1; - } -} - -int cfm_flash_readycheck(int checkblank) -{ - int rc; - unsigned char state; - - rc = ERR_OK; - while (!(MCFCFM_USTAT & MCFCFM_USTAT_CCIF)); - state = MCFCFM_USTAT; - if (state & MCFCFM_USTAT_ACCERR) - { - debug ("%s(): CFM access error",__FUNCTION__); - rc = ERR_PROG_ERROR; - } - if (state & MCFCFM_USTAT_PVIOL) - { - debug ("%s(): CFM protection violation",__FUNCTION__); - rc = ERR_PROTECTED; - } - if (checkblank) - { - if (!(state & MCFCFM_USTAT_BLANK)) - { - debug ("%s(): CFM erras error",__FUNCTION__); - rc = ERR_NOT_ERASED; - } - } - MCFCFM_USTAT = state & 0x34; /* reset state */ - return rc; -} - -/* Erase 16KiB = 8 2KiB pages */ - -int cfm_flash_erase_sector (flash_info_t * info, int sector) -{ - ulong address; - int page; - int rc; - rc= ERR_OK; - address = cmf_backdoor_address(info->start[sector]); - for (page=0; (page<8) && (rc==ERR_OK); page++) - { - *(volatile __u32*) address = 0; - MCFCFM_CMD = MCFCFM_CMD_PGERS; - MCFCFM_USTAT = MCFCFM_USTAT_CBEIF; - rc = cfm_flash_readycheck(0); - if (rc==ERR_OK) - { - *(volatile __u32*) address = 0; - MCFCFM_CMD = MCFCFM_CMD_PGERSVER; - MCFCFM_USTAT = MCFCFM_USTAT_CBEIF; - rc = cfm_flash_readycheck(1); - } - address += 0x800; - } - return rc; -} - -int cfm_flash_write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - int rc; - ulong dest, data; - - rc = ERR_OK; - if (addr & 3) - { - debug ("Byte and Word alignment not supported\n"); - rc = ERR_ALIGN; - } - if (cnt & 3) - { - debug ("Byte and Word transfer not supported\n"); - rc = ERR_ALIGN; - } - dest = cmf_backdoor_address(addr); - while ((cnt>=4) && (rc == ERR_OK)) - { - data = *((volatile u32 *) src); - *(volatile u32*) dest = data; - MCFCFM_CMD = MCFCFM_CMD_PGM; - MCFCFM_USTAT = MCFCFM_USTAT_CBEIF; - rc = cfm_flash_readycheck(0); - if (*(volatile u32*) addr != data) rc = ERR_PROG_ERROR; - src +=4; - dest +=4; - addr +=4; - cnt -=4; - } - return rc; -} - -#ifdef CONFIG_SYS_FLASH_PROTECTION - -int cfm_flash_protect(flash_info_t * info,long sector,int prot) -{ - int rc; - - rc= ERR_OK; - if (prot) - { - MCFCFM_PROT |= (1<<sector); - info->protect[sector]=1; - } - else - { - MCFCFM_PROT &= ~(1<<sector); - info->protect[sector]=0; - } - return rc; -} - -#endif - -#endif diff --git a/board/BuS/eb_cpu5282/cfm_flash.h b/board/BuS/eb_cpu5282/cfm_flash.h deleted file mode 100644 index ed4e794..0000000 --- a/board/BuS/eb_cpu5282/cfm_flash.h +++ /dev/null @@ -1,40 +0,0 @@ -/* - * Basic Flash Driver for Freescale MCF 5282 internal FLASH - * - * (C) Copyright 2005 BuS Elektronik GmbH & Co.KG esw@bus-elektonik.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CFM_FLASH_H_ -#define __CFM_FLASH_H_ - -#define FREESCALE_MANUFACT 0xFACFFACF -#define FREESCALE_ID_MCF5281 0x5281 -#define FREESCALE_ID_MCF5282 0x5282 - -extern void cfm_flash_print_info (flash_info_t * info); -extern int cfm_flash_erase_sector (flash_info_t * info, int sector); -extern void cfm_flash_init (flash_info_t * info); -extern int cfm_flash_write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt); -#ifdef CONFIG_SYS_FLASH_PROTECTION -extern int cfm_flash_protect(flash_info_t * info,long sector,int prot); -#endif - -#endif diff --git a/board/BuS/eb_cpu5282/config.mk b/board/BuS/eb_cpu5282/config.mk deleted file mode 100644 index 18fb84e..0000000 --- a/board/BuS/eb_cpu5282/config.mk +++ /dev/null @@ -1,27 +0,0 @@ -# -# (C) Copyright 2000-2003 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# Coldfire contribution by Bernhard Kuhn bkuhn@metrowerks.com -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -ifndef CONFIG_SYS_TEXT_BASE -CONFIG_SYS_TEXT_BASE = 0xFE000000 -endif diff --git a/board/BuS/eb_cpu5282/eb_cpu5282.c b/board/BuS/eb_cpu5282/eb_cpu5282.c index d64ad1b..231ff77 100644 --- a/board/BuS/eb_cpu5282/eb_cpu5282.c +++ b/board/BuS/eb_cpu5282/eb_cpu5282.c @@ -35,18 +35,19 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_VIDEO unsigned long display_width; unsigned long display_height; +#endif
int checkboard (void) { - puts ("Board: MCF-EV1 + MCF-EV23 (BuS Elektronik GmbH & Co. KG)\n"); + puts("Board: EB+CPU5282 (BuS Elektronik GmbH & Co. KG)\n"); #if (CONFIG_SYS_TEXT_BASE == CONFIG_SYS_INT_FLASH_BASE) - puts (" Boot from Internal FLASH\n"); + puts(" Boot from Internal FLASH\n"); #endif - return 0; }
@@ -55,29 +56,39 @@ phys_size_t initdram (int board_type) int size, i;
size = 0; - MCFSDRAMC_DCR = MCFSDRAMC_DCR_RTIM_6 - | MCFSDRAMC_DCR_RC ((15 * CONFIG_SYS_CLK) >> 4); + MCFSDRAMC_DCR = MCFSDRAMC_DCR_RTIM_6 | + MCFSDRAMC_DCR_RC((15 * CONFIG_SYS_CLK / 1000000) >> 4); + asm (" nop"); #ifdef CONFIG_SYS_SDRAM_BASE0 - - MCFSDRAMC_DACR0 = MCFSDRAMC_DACR_BASE (CONFIG_SYS_SDRAM_BASE0) - | MCFSDRAMC_DACR_CASL (1) - | MCFSDRAMC_DACR_CBM (3) - | MCFSDRAMC_DACR_PS_16; + MCFSDRAMC_DACR0 = MCFSDRAMC_DACR_BASE(CONFIG_SYS_SDRAM_BASE0)| + MCFSDRAMC_DACR_CASL(1) | MCFSDRAMC_DACR_CBM(3) | + MCFSDRAMC_DACR_PS_32; + asm (" nop");
MCFSDRAMC_DMR0 = MCFSDRAMC_DMR_BAM_16M | MCFSDRAMC_DMR_V; + asm (" nop");
MCFSDRAMC_DACR0 |= MCFSDRAMC_DACR_IP; + asm (" nop"); + for (i = 0; i < 10; i++) + asm (" nop");
- *(unsigned short *) (CONFIG_SYS_SDRAM_BASE0) = 0xA5A5; + *(unsigned long *)(CONFIG_SYS_SDRAM_BASE0) = 0xA5A5A5A5; + asm (" nop"); MCFSDRAMC_DACR0 |= MCFSDRAMC_DACR_RE; + asm (" nop"); + for (i = 0; i < 2000; i++) asm (" nop"); - mbar_writeLong (MCFSDRAMC_DACR0, - mbar_readLong (MCFSDRAMC_DACR0) | MCFSDRAMC_DACR_IMRS); - *(unsigned int *) (CONFIG_SYS_SDRAM_BASE0 + 0x220) = 0xA5A5; - size += CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; + + MCFSDRAMC_DACR0 |= MCFSDRAMC_DACR_IMRS; + asm (" nop"); + /* write SDRAM mode register */ + *(unsigned long *)(CONFIG_SYS_SDRAM_BASE0 + 0x80440) = 0xA5A5A5A5; + asm (" nop"); + size += CONFIG_SYS_SDRAM_SIZE0 * 1024 * 1024; #endif -#ifdef CONFIG_SYS_SDRAM_BASE1 +#ifdef CONFIG_SYS_SDRAM_BASE1xx MCFSDRAMC_DACR1 = MCFSDRAMC_DACR_BASE (CONFIG_SYS_SDRAM_BASE1) | MCFSDRAMC_DACR_CASL (1) | MCFSDRAMC_DACR_CBM (3) @@ -139,19 +150,53 @@ int misc_init_r(void) #ifdef CONFIG_HW_WATCHDOG hw_watchdog_init(); #endif -#ifndef CONFIG_VIDEO - vcxk_init(16, 16); -#endif return 1; }
-#if defined(CONFIG_VIDEO) +#if defined(CONFIG_HW_WATCHDOG)
-/* - ****h* EB+CPU5282-T1/drv_video_init - * FUNCTION - *** - */ +void hw_watchdog_init(void) +{ + char *s; + int enable; + + enable = 1; + s = getenv("watchdog"); + if (s != NULL) + if ((strncmp(s, "off", 3) == 0) || (strncmp(s, "0", 1) == 0)) + enable = 0; + if (enable) + MCFGPTA_GPTDDR |= (1<<2); + else + MCFGPTA_GPTDDR &= ~(1<<2); +} + +void hw_watchdog_reset(void) +{ + MCFGPTA_GPTPORT ^= (1<<2); +} +#endif + +void __led_toggle(led_id_t mask) +{ + MCFGPTA_GPTPORT ^= (1 << 3); +} + +void __led_init(led_id_t mask, int state) +{ + __led_set(mask, state); + MCFGPTA_GPTDDR |= (1 << 3) ; +} + +void __led_set(led_id_t mask, int state) +{ + if (state == STATUS_LED_ON) + MCFGPTA_GPTPORT |= (1 << 3); + else + MCFGPTA_GPTPORT &= ~(1 << 3); +} + +#if defined(CONFIG_VIDEO)
int drv_video_init(void) { @@ -159,13 +204,14 @@ int drv_video_init(void) unsigned long splash;
printf("Init Video as "); - - if ((s = getenv("displaywidth")) != NULL) + s = getenv("displaywidth"); + if (s != NULL) display_width = simple_strtoul(s, NULL, 10); else display_width = 256;
- if ((s = getenv("displayheight")) != NULL) + s = getenv("displayheight"); + if (s != NULL) display_height = simple_strtoul(s, NULL, 10); else display_height = 256; diff --git a/board/BuS/eb_cpu5282/flash.c b/board/BuS/eb_cpu5282/flash.c deleted file mode 100644 index 8b7f957..0000000 --- a/board/BuS/eb_cpu5282/flash.c +++ /dev/null @@ -1,415 +0,0 @@ -/* - * (C) Copyright 2005 - * BuS Elektronik GmbH & Co.KG esw@bus-elektonik.de - * - * Based On - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include "cfm_flash.h" - -#define PHYS_FLASH_1 CONFIG_SYS_FLASH_BASE -#define FLASH_BANK_SIZE 0x200000 - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -void flash_print_info (flash_info_t * info) -{ - int i; - - switch (info->flash_id & FLASH_VENDMASK) { - case (AMD_MANUFACT & FLASH_VENDMASK): - printf ("AMD: "); - switch (info->flash_id & FLASH_TYPEMASK) { - case (AMD_ID_LV160B & FLASH_TYPEMASK): - printf ("AM29LV160B (16Bit)\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - break; - case FREESCALE_MANUFACT & FLASH_VENDMASK: - cfm_flash_print_info (info); - break; - default: - printf ("Unknown Vendor "); - break; - } - - puts (" Size: "); - if ((info->size >> 20) > 0) - { - printf ("%ld MiB",info->size >> 20); - } - else - { - printf ("%ld KiB",info->size >> 10); - } - printf (" in %d Sectors\n", info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; i++) { - if ((i % 4) == 0) { - printf ("\n "); - } - printf ("%02d: %08lX%s ", i,info->start[i], - info->protect[i] ? " P" : " "); - } - printf ("\n\n"); -} - -unsigned long flash_init (void) -{ - int i, j; - ulong size = 0; - - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - ulong flashbase = 0; - - switch (i) - { - case 1: - flash_info[i].flash_id = - (AMD_MANUFACT & FLASH_VENDMASK) | - (AMD_ID_LV160B & FLASH_TYPEMASK); - flash_info[i].size = FLASH_BANK_SIZE; - flash_info[i].sector_count = CONFIG_SYS_MAX_FLASH_SECT; - memset (flash_info[i].protect, 0, CONFIG_SYS_MAX_FLASH_SECT); - flashbase = PHYS_FLASH_1; - for (j = 0; j < flash_info[i].sector_count; j++) { - if (j == 0) { - /* 1st is 16 KiB */ - flash_info[i].start[j] = flashbase; - } - if ((j >= 1) && (j <= 2)) { - /* 2nd and 3rd are 8 KiB */ - flash_info[i].start[j] = - flashbase + 0x4000 + 0x2000 * (j - 1); - } - if (j == 3) { - /* 4th is 32 KiB */ - flash_info[i].start[j] = flashbase + 0x8000; - } - if ((j >= 4) && (j <= 34)) { - /* rest is 256 KiB */ - flash_info[i].start[j] = - flashbase + 0x10000 + 0x10000 * (j - 4); - } - } - break; - case 0: - cfm_flash_init (&flash_info[i]); - break; - default: - panic ("configured to many flash banks!\n"); - } - - size += flash_info[i].size; - } - - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_FLASH_BASE, - CONFIG_SYS_FLASH_BASE + 0xffff, &flash_info[0]); - - return size; -} - -#define CMD_READ_ARRAY 0x00F0 -#define CMD_UNLOCK1 0x00AA -#define CMD_UNLOCK2 0x0055 -#define CMD_ERASE_SETUP 0x0080 -#define CMD_ERASE_CONFIRM 0x0030 -#define CMD_PROGRAM 0x00A0 -#define CMD_UNLOCK_BYPASS 0x0020 - -#define MEM_FLASH_ADDR1 (*(volatile u16 *)(info->start[0] + (0x00000555<<1))) -#define MEM_FLASH_ADDR2 (*(volatile u16 *)(info->start[0] + (0x000002AA<<1))) - - -#define BIT_ERASE_DONE 0x0080 -#define BIT_RDY_MASK 0x0080 -#define BIT_PROGRAM_ERROR 0x0020 -#define BIT_TIMEOUT 0x80000000 /* our flag */ - -#define ERR_READY -1 - -int amd_flash_erase_sector(flash_info_t * info, int sector) -{ - int state; - ulong result; - ulong start; - - volatile u16 *addr = - (volatile u16 *) (info->start[sector]); - - MEM_FLASH_ADDR1 = CMD_UNLOCK1; - MEM_FLASH_ADDR2 = CMD_UNLOCK2; - MEM_FLASH_ADDR1 = CMD_ERASE_SETUP; - - MEM_FLASH_ADDR1 = CMD_UNLOCK1; - MEM_FLASH_ADDR2 = CMD_UNLOCK2; - *addr = CMD_ERASE_CONFIRM; - - /* wait until flash is ready */ - state = 0; - start = get_timer(0); - - do { - result = *addr; - - /* check timeout */ - if (get_timer(start) > CONFIG_SYS_FLASH_ERASE_TOUT) { - MEM_FLASH_ADDR1 = CMD_READ_ARRAY; - state = ERR_TIMOUT; - } - - if (!state && (result & 0xFFFF) & BIT_ERASE_DONE) - state = ERR_READY; - } - while (!state); - if (state == ERR_READY) - state = ERR_OK; - - MEM_FLASH_ADDR1 = CMD_READ_ARRAY; - - return state; -} - -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - int iflag, cflag; - int sector; - int rc; - - rc = ERR_OK; - - if (info->flash_id == FLASH_UNKNOWN) - { - rc = ERR_UNKNOWN_FLASH_TYPE; - } /* (info->flash_id == FLASH_UNKNOWN) */ - - if ((s_first < 0) || (s_first > s_last) || s_last >= info->sector_count) - { - rc = ERR_INVAL; - } - - cflag = icache_status (); - icache_disable (); - iflag = disable_interrupts (); - - for (sector = s_first; (sector <= s_last) && (rc == ERR_OK); sector++) { - - if (info->protect[sector]) - { - putc('P'); /* protected sector will not erase */ - } - else - { - /* erase on unprotected sector */ - puts("E\b"); - switch (info->flash_id & FLASH_VENDMASK) - { - case (AMD_MANUFACT & FLASH_VENDMASK): - rc = amd_flash_erase_sector(info,sector); - break; - case (FREESCALE_MANUFACT & FLASH_VENDMASK): - rc = cfm_flash_erase_sector(info,sector); - break; - default: - return ERR_UNKNOWN_FLASH_VENDOR; - } - putc('.'); - } - } - if (rc!=ERR_OK) - { - printf ("\n "); - flash_perror (rc); - } - else - { - printf (" done\n"); - } - - udelay (10000); /* allow flash to settle - wait 10 ms */ - - if (iflag) - enable_interrupts (); - - if (cflag) - icache_enable (); - - return rc; -} - -volatile static int amd_write_word (flash_info_t * info, ulong dest, u16 data) -{ - volatile u16 *addr; - ulong result; - int cflag, iflag; - int state; - ulong start; - - /* - * Check if Flash is (sufficiently) erased - */ - addr = (volatile u16 *) dest; - - result = *addr; - if ((result & data) != data) - return ERR_NOT_ERASED; - - /* - * Disable interrupts which might cause a timeout - * here. Remember that our exception vectors are - * at address 0 in the flash, and we don't want a - * (ticker) exception to happen while the flash - * chip is in programming mode. - */ - - cflag = icache_status (); - icache_disable (); - iflag = disable_interrupts (); - - MEM_FLASH_ADDR1 = CMD_UNLOCK1; - MEM_FLASH_ADDR2 = CMD_UNLOCK2; - MEM_FLASH_ADDR1 = CMD_PROGRAM; - *addr = data; - - /* arm simple, non interrupt dependent timer */ - start = get_timer(0); - - /* wait until flash is ready */ - state = 0; - do { - result = *addr; - - /* check timeout */ - if (get_timer(start) > CONFIG_SYS_FLASH_ERASE_TOUT) { - state = ERR_TIMOUT; - } - if (!state && ((result & BIT_RDY_MASK) == (data & BIT_RDY_MASK))) - state = ERR_READY; - - } while (!state); - - *addr = CMD_READ_ARRAY; - - if (state == ERR_READY) - state = ERR_OK; - if ((*addr != data) && (state != ERR_TIMOUT)) - state = ERR_PROG_ERROR; - - if (iflag) - enable_interrupts (); - - if (cflag) - icache_enable (); - - return state; -} - -int amd_flash_write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - int rc; - ulong dest; - u16 data; - - rc = ERR_OK; - if (addr & 1) - { - debug ("Byte alignment not supported\n"); - rc = ERR_ALIGN; - } - if (cnt & 1) - { - debug ("Byte transfer not supported\n"); - rc = ERR_ALIGN; - } - - dest = addr; - while ((cnt>=2) && (rc == ERR_OK)) - { - data = *((volatile u16 *) src); - rc=amd_write_word (info,dest,data); - src +=2; - dest +=2; - cnt -=2; - } - return rc; -} - -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - int rc; - - switch (info->flash_id & FLASH_VENDMASK) - { - case (AMD_MANUFACT & FLASH_VENDMASK): - rc = amd_flash_write_buff(info,src,addr,cnt); - break; - case (FREESCALE_MANUFACT & FLASH_VENDMASK): - rc = cfm_flash_write_buff(info,src,addr,cnt); - break; - default: - rc = ERR_UNKNOWN_FLASH_VENDOR; - } - return rc; - -} -int amd_flash_protect(flash_info_t * info,long sector,int prot) -{ - int rc; - rc= ERR_OK; - if (prot) - { - info->protect[sector]=1; - } - else - { - info->protect[sector]=0; - } - return rc; -} - -#ifdef CONFIG_SYS_FLASH_PROTECTION - -int flash_real_protect(flash_info_t * info,long sector,int prot) -{ - int rc; - - switch (info->flash_id & FLASH_VENDMASK) - { - case (AMD_MANUFACT & FLASH_VENDMASK): - rc = amd_flash_protect(info,sector,prot); - break; - case (FREESCALE_MANUFACT & FLASH_VENDMASK): - rc = cfm_flash_protect(info,sector,prot); - break; - default: - rc = ERR_UNKNOWN_FLASH_VENDOR; - } - return rc; -} - -#endif diff --git a/boards.cfg b/boards.cfg index 7c1fc74..07699f7 100644 --- a/boards.cfg +++ b/boards.cfg @@ -361,7 +361,7 @@ M5235EVB m68k mcf523x m5235evb freesca M5235EVB_Flash32 m68k mcf523x m5235evb freescale - M5235EVB:NORFLASH_PS32BIT,SYS_TEXT_BASE=0xFFC00000 cobra5272 m68k mcf52x2 cobra5272 - idmr m68k mcf52x2 -eb_cpu5282 m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xFFE00000 +eb_cpu5282 m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xFF000000 eb_cpu5282_internal m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xF0000000 TASREG m68k mcf52x2 tasreg esd M5208EVBE m68k mcf52x2 m5208evbe freescale diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 9ecc10b..f1ce94e 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -38,7 +38,7 @@
#define CONFIG_MCFUART #define CONFIG_SYS_UART_PORT (0) -#define CONFIG_BAUDRATE 9600 +#define CONFIG_BAUDRATE 115200
#undef CONFIG_MONITOR_IS_IN_RAM /* starts uboot direct */
@@ -52,20 +52,24 @@ #define CONFIG_RESET_TO_RETRY #define CONFIG_SPLASH_SCREEN
+#define CONFIG_HW_WATCHDOG + +#define CONFIG_STATUS_LED +#define CONFIG_BOARD_SPECIFIC_LED +#define STATUS_LED_ACTIVE 0 +#define STATUS_LED_BIT 0x0008 /* Timer7 GPIO */ +#define STATUS_LED_BOOT 0 +#define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) +#define STATUS_LED_STATE STATUS_LED_OFF + /*----------------------------------------------------------------------* * Configuration for environment * * Environment is in the second sector of the first 256k of flash * *----------------------------------------------------------------------*/
-#ifndef CONFIG_MONITOR_IS_IN_RAM -#define CONFIG_ENV_ADDR 0xF003C000 /* End of 256K */ -#define CONFIG_ENV_SECT_SIZE 0x4000 -#define CONFIG_ENV_IS_IN_FLASH 1 -#else -#define CONFIG_ENV_ADDR 0xFFE04000 -#define CONFIG_ENV_SECT_SIZE 0x2000 +#define CONFIG_ENV_ADDR 0xFF040000 +#define CONFIG_ENV_SECT_SIZE 0x00020000 #define CONFIG_ENV_IS_IN_FLASH 1 -#endif
/* * BOOTP options @@ -78,26 +82,24 @@ /* * Command line configuration. */ +#define CONFIG_CMDLINE_EDITING #include <config_cmd_default.h>
#undef CONFIG_CMD_LOADB +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_LED #define CONFIG_CMD_MII #define CONFIG_CMD_NET
#define CONFIG_MCFTMR
- #define CONFIG_BOOTDELAY 5 -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_PROMPT "\nEB+CPU5282> " #define CONFIG_SYS_LONGHELP 1
-#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE @@ -112,12 +114,12 @@ /*----------------------------------------------------------------------* * Clock and PLL Configuration * *----------------------------------------------------------------------*/ -#define CONFIG_SYS_HZ 10000000 -#define CONFIG_SYS_CLK 58982400 /* 9,8304MHz * 6 */ +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_CLK 80000000 /* 8MHz * 8 */
-/* PLL Configuration: Ext Clock * 6 (see table 9-4 of MCF user manual) */ +/* PLL Configuration: Ext Clock * 8 (see table 9-4 of MCF user manual) */
-#define CONFIG_SYS_MFD 0x01 /* PLL Multiplication Factor Devider */ +#define CONFIG_SYS_MFD 0x02 /* PLL Multiplication Factor Devider */ #define CONFIG_SYS_RFD 0x00 /* PLL Reduce Frecuency Devider */
/*----------------------------------------------------------------------* @@ -135,7 +137,6 @@ #define CONFIG_SYS_FEC0_MIIBASE CONFIG_SYS_FEC0_IOBASE #define MCFFEC_TOUT_LOOP 50000
-#define CONFIG_ETHADDR 00:CF:52:82:EB:01 #define CONFIG_OVERWRITE_ETHADDR_ONCE
/*------------------------------------------------------------------------- @@ -151,7 +152,7 @@ *-----------------------------------------------------------------------*/
#define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 #define CONFIG_SYS_GBL_DATA_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET @@ -161,12 +162,11 @@ * (Set up by the startup code) * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 */ -#define CONFIG_SYS_SDRAM_BASE1 0x00000000 -#define CONFIG_SYS_SDRAM_SIZE1 16 /* SDRAM size in MB */ - -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_SDRAM_BASE1 -#define CONFIG_SYS_SDRAM_SIZE CONFIG_SYS_SDRAM_SIZE1 +#define CONFIG_SYS_SDRAM_BASE0 0x00000000 +#define CONFIG_SYS_SDRAM_SIZE0 16 /* SDRAM size in MB */
+#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_SDRAM_BASE0 +#define CONFIG_SYS_SDRAM_SIZE CONFIG_SYS_SDRAM_SIZE0
/* If M5282 port is fully implemented the monitor base will be behind * the vector table. */ @@ -190,16 +190,24 @@ /*----------------------------------------------------------------------- * FLASH organization */ +#define CONFIG_FLASH_SHOW_PROGRESS 45
#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE #define CONFIG_SYS_INT_FLASH_BASE 0xF0000000 #define CONFIG_SYS_INT_FLASH_ENABLE 0x21
-#define CONFIG_SYS_MAX_FLASH_SECT 35 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_MAX_FLASH_SECT 128 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_FLASH_ERASE_TOUT 10000000 #define CONFIG_SYS_FLASH_PROTECTION
+#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_SIZE 16*1024*1024 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT + +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } + /*----------------------------------------------------------------------- * Cache Configuration */ @@ -221,12 +229,16 @@ * Memory bank definitions */
-#define CONFIG_SYS_CS0_BASE 0xFFE00000 +#define CONFIG_SYS_CS0_BASE 0xFF000000 #define CONFIG_SYS_CS0_CTRL 0x00001980 -#define CONFIG_SYS_CS0_MASK 0x001F0001 +#define CONFIG_SYS_CS0_MASK 0x00FF0001
-#define CONFIG_SYS_CS3_BASE 0xE0000000 -#define CONFIG_SYS_CS0_CTRL 0x00001980 +#define CONFIG_SYS_CS2_BASE 0xE0000000 +#define CONFIG_SYS_CS2_CTRL 0x00001980 +#define CONFIG_SYS_CS2_MASK 0x000F0001 + +#define CONFIG_SYS_CS3_BASE 0xE0100000 +#define CONFIG_SYS_CS3_CTRL 0x00001980 #define CONFIG_SYS_CS3_MASK 0x000F0001
/*----------------------------------------------------------------------- @@ -248,23 +260,42 @@ #define CONFIG_SYS_PCDDR 0x0000000 #define CONFIG_SYS_PCDAT 0x0000000
+#define CONFIG_SYS_PASPAR 0x0F0F #define CONFIG_SYS_PEHLPAR 0xC0 #define CONFIG_SYS_PUAPAR 0x0F #define CONFIG_SYS_DDRUA 0x05 #define CONFIG_SYS_PJPAR 0xFF
/*----------------------------------------------------------------------- + * I2C + */ + +#define CONFIG_HARD_I2C +#define CONFIG_FSL_I2C + +#define CONFIG_SYS_I2C_OFFSET 0x00000300 +#define CONFIG_SYS_IMMR CONFIG_SYS_MBAR + +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0 + +#ifdef CONFIG_CMD_DATE +#define CONFIG_RTC_DS1338 +#define CONFIG_I2C_RTC_ADDR 0x68 +#endif + +/*----------------------------------------------------------------------- * VIDEO configuration */
#define CONFIG_VIDEO
#ifdef CONFIG_VIDEO -#define CONFIG_VIDEO_VCXK 1 +#define CONFIG_VIDEO_VCXK 1
#define CONFIG_SYS_VCXK_DEFAULT_LINEALIGN 2 #define CONFIG_SYS_VCXK_DOUBLEBUFFERED 1 -#define CONFIG_SYS_VCXK_BASE CONFIG_SYS_CS3_BASE +#define CONFIG_SYS_VCXK_BASE CONFIG_SYS_CS2_BASE #define CONFIG_SYS_VCXK_AUTODETECT 1
#define CONFIG_SYS_VCXK_ACKNOWLEDGE_PORT MCFGPTB_GPTPORT
Signed-off-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de --- changes since V1:
remove autodetect video, don't work on all hardware revisions
board/BuS/eb_cpu5282/Makefile | 2 +- board/BuS/eb_cpu5282/cfm_flash.c | 212 ------------------- board/BuS/eb_cpu5282/cfm_flash.h | 40 ---- board/BuS/eb_cpu5282/config.mk | 27 --- board/BuS/eb_cpu5282/eb_cpu5282.c | 110 +++++++--- board/BuS/eb_cpu5282/flash.c | 415 ------------------------------------- boards.cfg | 2 +- include/configs/eb_cpu5282.h | 102 +++++---- 8 files changed, 146 insertions(+), 764 deletions(-) delete mode 100644 board/BuS/eb_cpu5282/cfm_flash.c delete mode 100644 board/BuS/eb_cpu5282/cfm_flash.h delete mode 100644 board/BuS/eb_cpu5282/config.mk delete mode 100644 board/BuS/eb_cpu5282/flash.c
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/BuS/eb_cpu5282/cfm_flash.c b/board/BuS/eb_cpu5282/cfm_flash.c deleted file mode 100644 index fe03b17..0000000 --- a/board/BuS/eb_cpu5282/cfm_flash.c +++ /dev/null @@ -1,212 +0,0 @@ -/* - * Basic Flash Driver for Freescale MCF 5281/5282 internal FLASH - * - * (C) Copyright 2005 BuS Elektronik GmbH & Co.KG esw@bus-elektonik.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/m5282.h> -#include "cfm_flash.h" - -#if defined(CONFIG_M5281) || defined(CONFIG_M5282) - -#if (CONFIG_SYS_CLK>20000000) - #define CFM_CLK (((long) CONFIG_SYS_CLK / (400000 * 8) + 1) | 0x40) -#else - #define CFM_CLK ((long) CONFIG_SYS_CLK / 400000 + 1) -#endif - -#define cmf_backdoor_address(addr) (((addr) & 0x0007FFFF) | 0x04000000 | \ - (CONFIG_SYS_MBAR & 0xC0000000)) - -void cfm_flash_print_info (flash_info_t * info) -{ - printf ("Freescale: "); - switch (info->flash_id & FLASH_TYPEMASK) { - case FREESCALE_ID_MCF5281 & FLASH_TYPEMASK: - printf ("MCF5281 internal FLASH\n"); - break; - case FREESCALE_ID_MCF5282 & FLASH_TYPEMASK: - printf ("MCF5282 internal FLASH\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } -} - -void cfm_flash_init (flash_info_t * info) -{ - int sector; - ulong protection; - MCFCFM_MCR = 0; - MCFCFM_CLKD = CFM_CLK; - debug ("CFM Clock divider: %ld (%d Hz @ %ld Hz)\n",CFM_CLK,\ - CONFIG_SYS_CLK / (2* ((CFM_CLK & 0x3F)+1) * (1+((CFM_CLK & 0x40)>>6)*7)),\ - CONFIG_SYS_CLK); - MCFCFM_SACC = 0; - MCFCFM_DACC = 0; - - if (MCFCFM_SEC & MCFCFM_SEC_KEYEN) - puts("CFM backdoor access is enabled\n"); - if (MCFCFM_SEC & MCFCFM_SEC_SECSTAT) - puts("CFM securety is enabled\n"); - - #ifdef CONFIG_M5281 - info->flash_id = (FREESCALE_MANUFACT & FLASH_VENDMASK) | - (FREESCALE_ID_MCF5281 & FLASH_TYPEMASK); - info->size = 256*1024; - info->sector_count = 16; - #else - info->flash_id = (FREESCALE_MANUFACT & FLASH_VENDMASK) | - (FREESCALE_ID_MCF5282 & FLASH_TYPEMASK); - info->size = 512*1024; - info->sector_count = 32; - #endif - protection = MCFCFM_PROT; - for (sector = 0; sector < info->sector_count; sector++) - { - if (sector == 0) - { - info->start[sector] = CONFIG_SYS_INT_FLASH_BASE; - } - else - { - info->start[sector] = info->start[sector-1] + 0x04000; - } - info->protect[sector] = protection & 1; - protection >>= 1; - } -} - -int cfm_flash_readycheck(int checkblank) -{ - int rc; - unsigned char state; - - rc = ERR_OK; - while (!(MCFCFM_USTAT & MCFCFM_USTAT_CCIF)); - state = MCFCFM_USTAT; - if (state & MCFCFM_USTAT_ACCERR) - { - debug ("%s(): CFM access error",__FUNCTION__); - rc = ERR_PROG_ERROR; - } - if (state & MCFCFM_USTAT_PVIOL) - { - debug ("%s(): CFM protection violation",__FUNCTION__); - rc = ERR_PROTECTED; - } - if (checkblank) - { - if (!(state & MCFCFM_USTAT_BLANK)) - { - debug ("%s(): CFM erras error",__FUNCTION__); - rc = ERR_NOT_ERASED; - } - } - MCFCFM_USTAT = state & 0x34; /* reset state */ - return rc; -} - -/* Erase 16KiB = 8 2KiB pages */ - -int cfm_flash_erase_sector (flash_info_t * info, int sector) -{ - ulong address; - int page; - int rc; - rc= ERR_OK; - address = cmf_backdoor_address(info->start[sector]); - for (page=0; (page<8) && (rc==ERR_OK); page++) - { - *(volatile __u32*) address = 0; - MCFCFM_CMD = MCFCFM_CMD_PGERS; - MCFCFM_USTAT = MCFCFM_USTAT_CBEIF; - rc = cfm_flash_readycheck(0); - if (rc==ERR_OK) - { - *(volatile __u32*) address = 0; - MCFCFM_CMD = MCFCFM_CMD_PGERSVER; - MCFCFM_USTAT = MCFCFM_USTAT_CBEIF; - rc = cfm_flash_readycheck(1); - } - address += 0x800; - } - return rc; -} - -int cfm_flash_write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - int rc; - ulong dest, data; - - rc = ERR_OK; - if (addr & 3) - { - debug ("Byte and Word alignment not supported\n"); - rc = ERR_ALIGN; - } - if (cnt & 3) - { - debug ("Byte and Word transfer not supported\n"); - rc = ERR_ALIGN; - } - dest = cmf_backdoor_address(addr); - while ((cnt>=4) && (rc == ERR_OK)) - { - data = *((volatile u32 *) src); - *(volatile u32*) dest = data; - MCFCFM_CMD = MCFCFM_CMD_PGM; - MCFCFM_USTAT = MCFCFM_USTAT_CBEIF; - rc = cfm_flash_readycheck(0); - if (*(volatile u32*) addr != data) rc = ERR_PROG_ERROR; - src +=4; - dest +=4; - addr +=4; - cnt -=4; - } - return rc; -} - -#ifdef CONFIG_SYS_FLASH_PROTECTION - -int cfm_flash_protect(flash_info_t * info,long sector,int prot) -{ - int rc; - - rc= ERR_OK; - if (prot) - { - MCFCFM_PROT |= (1<<sector); - info->protect[sector]=1; - } - else - { - MCFCFM_PROT &= ~(1<<sector); - info->protect[sector]=0; - } - return rc; -} - -#endif - -#endif diff --git a/board/BuS/eb_cpu5282/cfm_flash.h b/board/BuS/eb_cpu5282/cfm_flash.h deleted file mode 100644 index ed4e794..0000000 --- a/board/BuS/eb_cpu5282/cfm_flash.h +++ /dev/null @@ -1,40 +0,0 @@ -/* - * Basic Flash Driver for Freescale MCF 5282 internal FLASH - * - * (C) Copyright 2005 BuS Elektronik GmbH & Co.KG esw@bus-elektonik.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CFM_FLASH_H_ -#define __CFM_FLASH_H_ - -#define FREESCALE_MANUFACT 0xFACFFACF -#define FREESCALE_ID_MCF5281 0x5281 -#define FREESCALE_ID_MCF5282 0x5282 - -extern void cfm_flash_print_info (flash_info_t * info); -extern int cfm_flash_erase_sector (flash_info_t * info, int sector); -extern void cfm_flash_init (flash_info_t * info); -extern int cfm_flash_write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt); -#ifdef CONFIG_SYS_FLASH_PROTECTION -extern int cfm_flash_protect(flash_info_t * info,long sector,int prot); -#endif - -#endif diff --git a/board/BuS/eb_cpu5282/config.mk b/board/BuS/eb_cpu5282/config.mk deleted file mode 100644 index 18fb84e..0000000 --- a/board/BuS/eb_cpu5282/config.mk +++ /dev/null @@ -1,27 +0,0 @@ -# -# (C) Copyright 2000-2003 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# Coldfire contribution by Bernhard Kuhn bkuhn@metrowerks.com -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -ifndef CONFIG_SYS_TEXT_BASE -CONFIG_SYS_TEXT_BASE = 0xFE000000 -endif diff --git a/board/BuS/eb_cpu5282/eb_cpu5282.c b/board/BuS/eb_cpu5282/eb_cpu5282.c index d64ad1b..fd71ab9 100644 --- a/board/BuS/eb_cpu5282/eb_cpu5282.c +++ b/board/BuS/eb_cpu5282/eb_cpu5282.c @@ -35,18 +35,19 @@
- *(unsigned short *) (CONFIG_SYS_SDRAM_BASE0) = 0xA5A5; + *(unsigned long *)(CONFIG_SYS_SDRAM_BASE0) = 0xA5A5A5A5; + asm (" nop"); MCFSDRAMC_DACR0 |= MCFSDRAMC_DACR_RE; + asm (" nop"); + for (i = 0; i < 2000; i++) asm (" nop"); - mbar_writeLong (MCFSDRAMC_DACR0, - mbar_readLong (MCFSDRAMC_DACR0) | MCFSDRAMC_DACR_IMRS); - *(unsigned int *) (CONFIG_SYS_SDRAM_BASE0 + 0x220) = 0xA5A5; - size += CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; + + MCFSDRAMC_DACR0 |= MCFSDRAMC_DACR_IMRS; + asm (" nop"); + /* write SDRAM mode register */ + *(unsigned long *)(CONFIG_SYS_SDRAM_BASE0 + 0x80440) = 0xA5A5A5A5; + asm (" nop"); + size += CONFIG_SYS_SDRAM_SIZE0 * 1024 * 1024; #endif -#ifdef CONFIG_SYS_SDRAM_BASE1 +#ifdef CONFIG_SYS_SDRAM_BASE1xx MCFSDRAMC_DACR1 = MCFSDRAMC_DACR_BASE (CONFIG_SYS_SDRAM_BASE1) | MCFSDRAMC_DACR_CASL (1) | MCFSDRAMC_DACR_CBM (3) @@ -139,33 +150,69 @@ int misc_init_r(void) #ifdef CONFIG_HW_WATCHDOG hw_watchdog_init(); #endif -#ifndef CONFIG_VIDEO - vcxk_init(16, 16); -#endif return 1; }
int drv_video_init(void) { char *s; +#ifdef CONFIG_SPLASH_SCREEN unsigned long splash; - +#endif printf("Init Video as "); - - if ((s = getenv("displaywidth")) != NULL) + s = getenv("displaywidth"); + if (s != NULL) display_width = simple_strtoul(s, NULL, 10); else display_width = 256;
- if ((s = getenv("displayheight")) != NULL) + s = getenv("displayheight"); + if (s != NULL) display_height = simple_strtoul(s, NULL, 10); else display_height = 256; @@ -178,10 +225,9 @@ int drv_video_init(void) vcxk_init(display_width, display_height);
#ifdef CONFIG_SPLASH_SCREEN - if ((s = getenv("splashimage")) != NULL) { - debug("use splashimage: %s\n", s); + s = getenv("splashimage"); + if (s != NULL) { splash = simple_strtoul(s, NULL, 16); - debug("use splashimage: %x\n", splash); vcxk_acknowledge_wait(); video_display_bitmap(splash, 0, 0); } diff --git a/board/BuS/eb_cpu5282/flash.c b/board/BuS/eb_cpu5282/flash.c deleted file mode 100644 index 8b7f957..0000000 --- a/board/BuS/eb_cpu5282/flash.c +++ /dev/null @@ -1,415 +0,0 @@ -/* - * (C) Copyright 2005 - * BuS Elektronik GmbH & Co.KG esw@bus-elektonik.de - * - * Based On - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include "cfm_flash.h" - -#define PHYS_FLASH_1 CONFIG_SYS_FLASH_BASE -#define FLASH_BANK_SIZE 0x200000 - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; - -void flash_print_info (flash_info_t * info) -{ - int i; - - switch (info->flash_id & FLASH_VENDMASK) { - case (AMD_MANUFACT & FLASH_VENDMASK): - printf ("AMD: "); - switch (info->flash_id & FLASH_TYPEMASK) { - case (AMD_ID_LV160B & FLASH_TYPEMASK): - printf ("AM29LV160B (16Bit)\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - break; - case FREESCALE_MANUFACT & FLASH_VENDMASK: - cfm_flash_print_info (info); - break; - default: - printf ("Unknown Vendor "); - break; - } - - puts (" Size: "); - if ((info->size >> 20) > 0) - { - printf ("%ld MiB",info->size >> 20); - } - else - { - printf ("%ld KiB",info->size >> 10); - } - printf (" in %d Sectors\n", info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; i++) { - if ((i % 4) == 0) { - printf ("\n "); - } - printf ("%02d: %08lX%s ", i,info->start[i], - info->protect[i] ? " P" : " "); - } - printf ("\n\n"); -} - -unsigned long flash_init (void) -{ - int i, j; - ulong size = 0; - - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - ulong flashbase = 0; - - switch (i) - { - case 1: - flash_info[i].flash_id = - (AMD_MANUFACT & FLASH_VENDMASK) | - (AMD_ID_LV160B & FLASH_TYPEMASK); - flash_info[i].size = FLASH_BANK_SIZE; - flash_info[i].sector_count = CONFIG_SYS_MAX_FLASH_SECT; - memset (flash_info[i].protect, 0, CONFIG_SYS_MAX_FLASH_SECT); - flashbase = PHYS_FLASH_1; - for (j = 0; j < flash_info[i].sector_count; j++) { - if (j == 0) { - /* 1st is 16 KiB */ - flash_info[i].start[j] = flashbase; - } - if ((j >= 1) && (j <= 2)) { - /* 2nd and 3rd are 8 KiB */ - flash_info[i].start[j] = - flashbase + 0x4000 + 0x2000 * (j - 1); - } - if (j == 3) { - /* 4th is 32 KiB */ - flash_info[i].start[j] = flashbase + 0x8000; - } - if ((j >= 4) && (j <= 34)) { - /* rest is 256 KiB */ - flash_info[i].start[j] = - flashbase + 0x10000 + 0x10000 * (j - 4); - } - } - break; - case 0: - cfm_flash_init (&flash_info[i]); - break; - default: - panic ("configured to many flash banks!\n"); - } - - size += flash_info[i].size; - } - - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_FLASH_BASE, - CONFIG_SYS_FLASH_BASE + 0xffff, &flash_info[0]); - - return size; -} - -#define CMD_READ_ARRAY 0x00F0 -#define CMD_UNLOCK1 0x00AA -#define CMD_UNLOCK2 0x0055 -#define CMD_ERASE_SETUP 0x0080 -#define CMD_ERASE_CONFIRM 0x0030 -#define CMD_PROGRAM 0x00A0 -#define CMD_UNLOCK_BYPASS 0x0020 - -#define MEM_FLASH_ADDR1 (*(volatile u16 *)(info->start[0] + (0x00000555<<1))) -#define MEM_FLASH_ADDR2 (*(volatile u16 *)(info->start[0] + (0x000002AA<<1))) - - -#define BIT_ERASE_DONE 0x0080 -#define BIT_RDY_MASK 0x0080 -#define BIT_PROGRAM_ERROR 0x0020 -#define BIT_TIMEOUT 0x80000000 /* our flag */ - -#define ERR_READY -1 - -int amd_flash_erase_sector(flash_info_t * info, int sector) -{ - int state; - ulong result; - ulong start; - - volatile u16 *addr = - (volatile u16 *) (info->start[sector]); - - MEM_FLASH_ADDR1 = CMD_UNLOCK1; - MEM_FLASH_ADDR2 = CMD_UNLOCK2; - MEM_FLASH_ADDR1 = CMD_ERASE_SETUP; - - MEM_FLASH_ADDR1 = CMD_UNLOCK1; - MEM_FLASH_ADDR2 = CMD_UNLOCK2; - *addr = CMD_ERASE_CONFIRM; - - /* wait until flash is ready */ - state = 0; - start = get_timer(0); - - do { - result = *addr; - - /* check timeout */ - if (get_timer(start) > CONFIG_SYS_FLASH_ERASE_TOUT) { - MEM_FLASH_ADDR1 = CMD_READ_ARRAY; - state = ERR_TIMOUT; - } - - if (!state && (result & 0xFFFF) & BIT_ERASE_DONE) - state = ERR_READY; - } - while (!state); - if (state == ERR_READY) - state = ERR_OK; - - MEM_FLASH_ADDR1 = CMD_READ_ARRAY; - - return state; -} - -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - int iflag, cflag; - int sector; - int rc; - - rc = ERR_OK; - - if (info->flash_id == FLASH_UNKNOWN) - { - rc = ERR_UNKNOWN_FLASH_TYPE; - } /* (info->flash_id == FLASH_UNKNOWN) */ - - if ((s_first < 0) || (s_first > s_last) || s_last >= info->sector_count) - { - rc = ERR_INVAL; - } - - cflag = icache_status (); - icache_disable (); - iflag = disable_interrupts (); - - for (sector = s_first; (sector <= s_last) && (rc == ERR_OK); sector++) { - - if (info->protect[sector]) - { - putc('P'); /* protected sector will not erase */ - } - else - { - /* erase on unprotected sector */ - puts("E\b"); - switch (info->flash_id & FLASH_VENDMASK) - { - case (AMD_MANUFACT & FLASH_VENDMASK): - rc = amd_flash_erase_sector(info,sector); - break; - case (FREESCALE_MANUFACT & FLASH_VENDMASK): - rc = cfm_flash_erase_sector(info,sector); - break; - default: - return ERR_UNKNOWN_FLASH_VENDOR; - } - putc('.'); - } - } - if (rc!=ERR_OK) - { - printf ("\n "); - flash_perror (rc); - } - else - { - printf (" done\n"); - } - - udelay (10000); /* allow flash to settle - wait 10 ms */ - - if (iflag) - enable_interrupts (); - - if (cflag) - icache_enable (); - - return rc; -} - -volatile static int amd_write_word (flash_info_t * info, ulong dest, u16 data) -{ - volatile u16 *addr; - ulong result; - int cflag, iflag; - int state; - ulong start; - - /* - * Check if Flash is (sufficiently) erased - */ - addr = (volatile u16 *) dest; - - result = *addr; - if ((result & data) != data) - return ERR_NOT_ERASED; - - /* - * Disable interrupts which might cause a timeout - * here. Remember that our exception vectors are - * at address 0 in the flash, and we don't want a - * (ticker) exception to happen while the flash - * chip is in programming mode. - */ - - cflag = icache_status (); - icache_disable (); - iflag = disable_interrupts (); - - MEM_FLASH_ADDR1 = CMD_UNLOCK1; - MEM_FLASH_ADDR2 = CMD_UNLOCK2; - MEM_FLASH_ADDR1 = CMD_PROGRAM; - *addr = data; - - /* arm simple, non interrupt dependent timer */ - start = get_timer(0); - - /* wait until flash is ready */ - state = 0; - do { - result = *addr; - - /* check timeout */ - if (get_timer(start) > CONFIG_SYS_FLASH_ERASE_TOUT) { - state = ERR_TIMOUT; - } - if (!state && ((result & BIT_RDY_MASK) == (data & BIT_RDY_MASK))) - state = ERR_READY; - - } while (!state); - - *addr = CMD_READ_ARRAY; - - if (state == ERR_READY) - state = ERR_OK; - if ((*addr != data) && (state != ERR_TIMOUT)) - state = ERR_PROG_ERROR; - - if (iflag) - enable_interrupts (); - - if (cflag) - icache_enable (); - - return state; -} - -int amd_flash_write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - int rc; - ulong dest; - u16 data; - - rc = ERR_OK; - if (addr & 1) - { - debug ("Byte alignment not supported\n"); - rc = ERR_ALIGN; - } - if (cnt & 1) - { - debug ("Byte transfer not supported\n"); - rc = ERR_ALIGN; - } - - dest = addr; - while ((cnt>=2) && (rc == ERR_OK)) - { - data = *((volatile u16 *) src); - rc=amd_write_word (info,dest,data); - src +=2; - dest +=2; - cnt -=2; - } - return rc; -} - -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - int rc; - - switch (info->flash_id & FLASH_VENDMASK) - { - case (AMD_MANUFACT & FLASH_VENDMASK): - rc = amd_flash_write_buff(info,src,addr,cnt); - break; - case (FREESCALE_MANUFACT & FLASH_VENDMASK): - rc = cfm_flash_write_buff(info,src,addr,cnt); - break; - default: - rc = ERR_UNKNOWN_FLASH_VENDOR; - } - return rc; - -} -int amd_flash_protect(flash_info_t * info,long sector,int prot) -{ - int rc; - rc= ERR_OK; - if (prot) - { - info->protect[sector]=1; - } - else - { - info->protect[sector]=0; - } - return rc; -} - -#ifdef CONFIG_SYS_FLASH_PROTECTION - -int flash_real_protect(flash_info_t * info,long sector,int prot) -{ - int rc; - - switch (info->flash_id & FLASH_VENDMASK) - { - case (AMD_MANUFACT & FLASH_VENDMASK): - rc = amd_flash_protect(info,sector,prot); - break; - case (FREESCALE_MANUFACT & FLASH_VENDMASK): - rc = cfm_flash_protect(info,sector,prot); - break; - default: - rc = ERR_UNKNOWN_FLASH_VENDOR; - } - return rc; -} - -#endif diff --git a/boards.cfg b/boards.cfg index 7c1fc74..07699f7 100644 --- a/boards.cfg +++ b/boards.cfg @@ -361,7 +361,7 @@ M5235EVB m68k mcf523x m5235evb freesca M5235EVB_Flash32 m68k mcf523x m5235evb freescale - M5235EVB:NORFLASH_PS32BIT,SYS_TEXT_BASE=0xFFC00000 cobra5272 m68k mcf52x2 cobra5272 - idmr m68k mcf52x2 -eb_cpu5282 m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xFFE00000 +eb_cpu5282 m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xFF000000 eb_cpu5282_internal m68k mcf52x2 eb_cpu5282 BuS - eb_cpu5282:SYS_TEXT_BASE=0xF0000000 TASREG m68k mcf52x2 tasreg esd M5208EVBE m68k mcf52x2 m5208evbe freescale diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 9ecc10b..5a0d321 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -38,7 +38,7 @@
/*----------------------------------------------------------------------- @@ -248,24 +260,42 @@ #define CONFIG_SYS_PCDDR 0x0000000 #define CONFIG_SYS_PCDAT 0x0000000
#define CONFIG_SYS_VCXK_DEFAULT_LINEALIGN 2 #define CONFIG_SYS_VCXK_DOUBLEBUFFERED 1 -#define CONFIG_SYS_VCXK_BASE CONFIG_SYS_CS3_BASE -#define CONFIG_SYS_VCXK_AUTODETECT 1 +#define CONFIG_SYS_VCXK_BASE CONFIG_SYS_CS2_BASE
#define CONFIG_SYS_VCXK_ACKNOWLEDGE_PORT MCFGPTB_GPTPORT #define CONFIG_SYS_VCXK_ACKNOWLEDGE_DDR MCFGPTB_GPTDDR
Hello,
I have seen this patch is marked as "Changes Requested" in patchwork. But I have never get a request or comment. Is there an real reason for this state?
regards Jens
Am 2012-10-30 11:46, schrieb Jens Scharsig (BuS Elektronik):
- add I2C support
Hello Jens,
On Wed, 14 Nov 2012 11:26:59 +0100 esw@bus-elektronik.de wrote: ..
I also do not see any such requests on the list, so it must have happened by an accident. I'll change the patch status in patchwork.
Thanks, Anatolij
On Tue, 30 Oct 2012 11:46:05 +0100 "Jens Scharsig (BuS Elektronik)" esw@bus-elektronik.de wrote:
- add I2C support
changes since V1:
Applied to staging/agust@denx.de after fixing a build warning and some small style issues. Please next time use tools/checkpatch.pl for checking the patches before submission. Thanks!
Anatolij
Anatolij Gustschin
