[U-Boot] [PATCH] Fix: if using crc32 command watchdog timed out
* Fix: if using crc32 command watchdog timed out
Signed-off-by: Jens Scharsig esw@bus-elektronik.de --- common/cmd_mem.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/cmd_mem.c b/common/cmd_mem.c index a5576aa..4daa1b3 100644 --- a/common/cmd_mem.c +++ b/common/cmd_mem.c @@ -1092,7 +1092,7 @@ int do_mem_crc (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
length = simple_strtoul (argv[2], NULL, 16);
- crc = crc32 (0, (const uchar *) addr, length); + crc = crc32_wd(0, (const uchar *) addr, length, CHUNKSZ_CRC32);
printf ("CRC32 for %08lx ... %08lx ==> %08lx\n", addr, addr + length - 1, crc); @@ -1137,7 +1137,7 @@ usage: addr += base_address; length = simple_strtoul(*av++, NULL, 16);
- crc = crc32(0, (const uchar *) addr, length); + crc = crc32_wd(0, (const uchar *) addr, length, CHUNKSZ_CRC32);
if (!verify) { printf ("CRC32 for %08lx ... %08lx ==> %08lx\n",
Hi Jens,
Le 05/07/2011 09:26, Jens Scharsig a écrit :
- Fix: if using crc32 command watchdog timed out
Signed-off-by: Jens Scharsigesw@bus-elektronik.de
Nitpick: in addition to describing which issue the patch fixes, can you describe how it fixes it?
Amicalement,
Hello, Am 2011-07-16 11:53, schrieb Albert ARIBAUD:
Hi Jens,
If your board is using a watchdog and you try to calculate/check a CRC2 with crc32 command, the watchdog timed out on large data blocks. The commands around uboot-images also uses crc32, but don't time out. The difference between:
CRC32 command calls the the crc32 function and the"image" commands crc32_wd (i think _wd stands for watchdog). So this patch changes the the function call from crc32 to crc_32 to support watchdog reset in the same way as "image" commands.
Best regards
Jens
Hi Jens,
Hi Jens,
Sorry, I meant: describe what the fix does in the commit message, not on the list.
Generally, a patch commit message should always describe what the patch does.
Best regards
Jens
Amicalement,
* Fix: if using crc32 command watchdog timed out * change function call crc32(..) to the watchdog save variant crc_32_wd(..) to support watchdog reset
- crc = crc32 (0, (const uchar *) addr, length); + crc = crc32_wd (0, (const uchar *) addr, length, CHUNKSZ_CRC32);
- crc = crc32(0, (const uchar *) addr, length); + crc = crc32_wd (0, (const uchar *) addr, length, CHUNKSZ_CRC32);
Hi Jens,
- change function call crc32(..) to the watchdog save variant crc_32_wd(..) to support watchdog reset
Sorry for nitpicking again -- can you fix the typo in the commit message? I assume it is "watchdog-safe", not "watchdog save".
Amicalement,
* Fix: if using crc32 command watchdog timed out * change function call crc32(..) to the watchdog-safe variant crc_32_wd(..) to support watchdog reset
Dear Jens Scharsig,
- change function call crc32(..) to the watchdog-safe variant crc_32_wd(..) to support watchdog reset
Applied, thanks.
Albert ARIBAUD
Jens Scharsig
Jens Scharsig
