[U-Boot-Users] [PATCH] Adds Altera Stratix II fpga burn support
Adds generic implementation of Altera Stratix II fpga burn both in: fast passive parallel, and fast passive parallel with security, formats.
Signed-off-by: Eran Liberty eran.liberty@gmail.com
Index: common/altera.c =================================================================== --- common/altera.c (.../tags/trunk/20070620_2_merge_to_exsw6000) (revision 69) +++ common/altera.c (.../branches/exsw6000) (revision 69) @@ -1,4 +1,7 @@ /* + * (C) Copyright 2007 + * Eran Liberty, Extricom , eran.liberty@gmail.com + * * (C) Copyright 2003 * Steven Scholz, imc Measurement & Control, steven.scholz@imc-berlin.de * @@ -30,6 +33,7 @@ */ #include <common.h> #include <ACEX1K.h> +#include <stratixII.h>
/* Define FPGA_DEBUG to get debug printf's */ /* #define FPGA_DEBUG */ @@ -43,7 +47,7 @@ #if (CONFIG_FPGA & CFG_FPGA_ALTERA)
/* Local Static Functions */ -static int altera_validate (Altera_desc * desc, char *fn); +static int altera_validate (Altera_desc * desc,const char *fn);
/* ------------------------------------------------------------------------- */ int altera_load( Altera_desc *desc, void *buf, size_t bsize ) @@ -69,6 +73,16 @@ __FUNCTION__); #endif break; + case Altera_StratixII: +#if (CONFIG_FPGA & CFG_STRATIX_II) + PRINTF ("%s: Launching the Stratix II Loader...\n", + __FUNCTION__); + ret_val = StratixII_load (desc, buf, bsize); +#else + printf ("%s: No support for Stratix II devices.\n", + __FUNCTION__); +#endif + break;
default: printf ("%s: Unsupported family type, %d\n", @@ -97,6 +111,16 @@ __FUNCTION__); #endif break; + case Altera_StratixII: +#if (CONFIG_FPGA & CFG_STRATIX_II) + PRINTF ("%s: Launching the Stratix II Reader...\n", + __FUNCTION__); + ret_val = StratixII_dump (desc, buf, bsize); +#else + printf ("%s: No support for Stratix II devices.\n", + __FUNCTION__); +#endif + break;
default: printf ("%s: Unsupported family type, %d\n", @@ -117,6 +141,9 @@ case Altera_ACEX1K: printf ("ACEX1K\n"); break; + case Altera_StratixII: + printf ("Stratix II\n"); + break; /* Add new family types here */ case Altera_CYC2: printf ("CYCLON II\n"); @@ -142,7 +169,14 @@ case altera_jtag_mode: /* Not used */ printf ("JTAG Mode\n"); break; + case fast_passive_parallel: + printf ("Fast Passive Parallel (FPP)\n"); + break; /* Add new interface types here */ + case fast_passive_parallel_security: + printf ("Fast Passive Parallel with Security (FPPS) \n"); + break; + /* Add new interface types here */ default: printf ("Unsupported interface type, %d\n", desc->iface); } @@ -166,6 +200,14 @@ __FUNCTION__); #endif break; + case Altera_StratixII: +#if (CONFIG_FPGA & CFG_STRATIX_II) + StratixII_info (desc); +#else + printf ("%s: No support for Stratix II devices.\n", + __FUNCTION__); +#endif + break; /* Add new family types here */ default: /* we don't need a message here - we give one up above */ @@ -199,6 +241,16 @@ __FUNCTION__); #endif break; + + case Altera_StratixII: +#if (CONFIG_FPGA & CFG_STRATIX_II) + ret_val = StratixII_reloc (desc, reloc_offset); +#else + printf ("%s: No support for Stratix II devices.\n", + __FUNCTION__); +#endif + break; + case Altera_CYC2: #if (CONFIG_FPGA & CFG_CYCLON2) ret_val = CYC2_reloc (desc, reloc_offset); @@ -219,7 +271,7 @@
-static int altera_validate (Altera_desc * desc, char *fn) +static int altera_validate (Altera_desc * desc, const char *fn) { int ret_val = FALSE;
@@ -249,4 +301,4 @@
-#endif /* CONFIG_FPGA & CFG_FPGA_ALTERA */ +#endif /* CONFIG_FPGA & CFG_FPGA_ALTERA */ Index: include/altera.h =================================================================== --- include/altera.h (.../tags/trunk/20070620_2_merge_to_exsw6000) (revision 69) +++ include/altera.h (.../branches/exsw6000) (revision 69) @@ -27,22 +27,21 @@ #ifndef _ALTERA_H_ #define _ALTERA_H_
-/* - * See include/xilinx.h for another working example. - */ - /* Altera Model definitions *********************************************************************/ #define CFG_ACEX1K CFG_FPGA_DEV( 0x1 ) #define CFG_CYCLON2 CFG_FPGA_DEV( 0x2 ) +#define CFG_STRATIX_II CFG_FPGA_DEV( 0x4 )
#define CFG_ALTERA_ACEX1K (CFG_FPGA_ALTERA | CFG_ACEX1K) #define CFG_ALTERA_CYCLON2 (CFG_FPGA_ALTERA | CFG_CYCLON2) +#define CFG_ALTERA_STRATIX_II (CFG_FPGA_ALTERA | CFG_STRATIX_II) /* Add new models here */
/* Altera Interface definitions *********************************************************************/ #define CFG_ALTERA_IF_PS CFG_FPGA_IF( 0x1 ) /* passive serial */ +#define CFG_ALTERA_IF_FPP CFG_FPGA_IF( 0x2 ) /* fast passive parallel */ /* Add new interfaces here */
typedef enum { /* typedef Altera_iface */ @@ -52,6 +51,8 @@ passive_parallel_asynchronous, /* parallel data */ passive_serial_asynchronous, /* serial data w/ internal clock (not used) */ altera_jtag_mode, /* jtag/tap serial (not used ) */ + fast_passive_parallel, /* fast passive parallel (FPP) */ + fast_passive_parallel_security, /* fast passive parallel with security (FPPS) */ max_altera_iface_type /* insert all new types before this */ } Altera_iface; /* end, typedef Altera_iface */
@@ -59,6 +60,7 @@ min_altera_type, /* insert all new types after this */ Altera_ACEX1K, /* ACEX1K Family */ Altera_CYC2, /* CYCLONII Family */ + Altera_StratixII, /* StratixII Familiy */ /* Add new models here */ max_altera_type /* insert all new types before this */ } Altera_Family; /* end, typedef Altera_Family */ @@ -91,4 +93,15 @@ typedef int (*Altera_abort_fn)( int cookie ); typedef int (*Altera_post_fn)( int cookie );
+typedef struct { + Altera_pre_fn pre; + Altera_config_fn config; + Altera_status_fn status; + Altera_done_fn done; + Altera_clk_fn clk; + Altera_data_fn data; + Altera_abort_fn abort; + Altera_post_fn post; +} altera_board_specific_func; + #endif /* _ALTERA_H_ */ Index: common/stratixII.c =================================================================== --- common/stratixII.c (.../tags/trunk/20070620_2_merge_to_exsw6000) (revision 0) +++ common/stratixII.c (.../branches/exsw6000) (revision 69) @@ -0,0 +1,213 @@ +/* + * (C) Copyright 2007 + * Eran Liberty, Extricom , eran.liberty@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> /* core U-Boot definitions */ +#include <altera.h> + +#if (CONFIG_FPGA & (CFG_ALTERA | CFG_STRATIX_II)) + +int StratixII_fpp_load (Altera_desc * desc, void *buf, size_t bsize, + int secure); +int StratixII_fpp_dump (Altera_desc * desc, void *buf, size_t bsize); + +/****************************************************************/ +/* Stratix II Generic Implementation */ +int StratixII_load (Altera_desc * desc, void *buf, size_t bsize) +{ + int ret_val = FPGA_FAIL; + + switch (desc->iface) { + case fast_passive_parallel: + ret_val = StratixII_fpp_load (desc, buf, bsize, 0); + break; + case fast_passive_parallel_security: + ret_val = StratixII_fpp_load (desc, buf, bsize, 1); + break; + + /* Add new interface types here */ + default: + printf ("%s: Unsupported interface type, %d\n", __FUNCTION__, + desc->iface); + } + return ret_val; +} + +int StratixII_dump (Altera_desc * desc, void *buf, size_t bsize) +{ + int ret_val = FPGA_FAIL; + + switch (desc->iface) { + case fast_passive_parallel: + case fast_passive_parallel_security: + ret_val = StratixII_fpp_dump (desc, buf, bsize); + break; + /* Add new interface types here */ + default: + printf ("%s: Unsupported interface type, %d\n", __FUNCTION__, + desc->iface); + } + return ret_val; +} + +int StratixII_info (Altera_desc * desc) +{ + return FPGA_SUCCESS; +} + +int StratixII_reloc (Altera_desc * desc, ulong reloc_offset) +{ + int i; + void **func_table; + + desc->iface_fns = (void *)((ulong) (desc->iface_fns) + reloc_offset); + for (i = 0, func_table = (void **)desc->iface_fns; + i < sizeof (altera_board_specific_func) / sizeof (void *); i++) { + func_table[i] = + (void *)((ulong) (func_table[i]) + reloc_offset); + } + return FPGA_SUCCESS; +} + +#endif + +/************************************************************/ +/* Stratix II Fast Passive Parallel Generic Implementation */ +int StratixII_fpp_dump (Altera_desc * desc, void *buf, size_t bsize) +{ + printf ("Stratix II Fast Passive Parallel dump is not implemented\n"); + return FPGA_FAIL; +} + +int StratixII_fpp_load (Altera_desc * desc, void *buf, size_t bsize, int secure) +{ + altera_board_specific_func *fns; + int cookie; + int ret_val = FPGA_FAIL; + int bytecount; + char *buff = buf; + int i; + + if (!desc) { + printf ("%s(%d) Altera_desc missing\n", __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + if (!buff) { + printf ("%s(%d) buffer is missing\n", __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + if (!bsize) { + printf ("%s(%d) size is zero\n", __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + if (!desc->iface_fns) { + printf + ("%s(%d) Altera_desc function interface table is missing\n", + __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + fns = (altera_board_specific_func *) (desc->iface_fns); + cookie = desc->cookie; + + if (! + (fns->config && fns->status && fns->done && fns->data + && fns->abort)) { + printf + ("%s(%d) Missing some function in the function interface table\n", + __FUNCTION__, __LINE__); + return FPGA_FAIL; + } + + /* 1. give board specific a chance to do anything before we start */ + if (fns->pre) { + if ((ret_val = fns->pre (cookie)) < 0) { + return ret_val; + } + } + + /* from this point on we must fail gracfully by calling lower layer abort */ + + /* 2. Strat burn cycle by deasserting config for t_CFG and waiting t_CF2CK after reaserted */ + fns->config (0, 1, cookie); + udelay (5); /* nCONFIG low pulse width 2usec */ + fns->config (1, 1, cookie); + udelay (100); /* nCONFIG high to first rising edge on DCLK */ + + /* 3. Start the Data cycle with clk deasserted */ + bytecount = 0; + fns->clk (0, 1, cookie); + + printf ("loading to fpga "); + while (bytecount < bsize) { + /* 3.1 check stratix has not signaled us an error */ + if (fns->status (cookie) != 1) { + printf + ("\n%s(%d) Stratix failed (byte transfered till failure 0x%x)\n", + __FUNCTION__, __LINE__, bytecount); + fns->abort (cookie); + return FPGA_FAIL; + } + /* 3.2 put data on the bus */ + fns->data (buff[bytecount++], 1, cookie); + + /* 3.3 clock once */ + ndelay (5); + fns->clk (1, 1, cookie); + ndelay (5); + fns->clk (0, 1, cookie); + + /* 3.4 for secure cycle push 3 more clocks */ + for (i = 0; secure && i < 3; i++) { + ndelay (5); + fns->clk (1, 1, cookie); + ndelay (5); + fns->clk (0, 1, cookie); + } + + /* 3.5 while clk is deasserted it is safe to print some progress indication */ + if ((bytecount % (bsize / 100)) == 0) { + printf ("\b\b\b%02d%", bytecount * 100 / bsize); + } + } + + /* 4. Set one last clock and check conf done signal */ + fns->clk (1, 1, cookie); + udelay (100); + if (!fns->done (cookie)) { + printf (" error!.\n"); + fns->abort (cookie); + return FPGA_FAIL; + } else { + printf ("\b\b\b done.\n"); + } + + /* 5. call lower layer post configuration */ + if (fns->post) { + if ((ret_val = fns->pre (cookie)) < 0) { + fns->abort (cookie); + return ret_val; + } + } + + return FPGA_SUCCESS; +} Index: include/stratixII.h =================================================================== --- include/stratixII.h (.../tags/trunk/20070620_2_merge_to_exsw6000) (revision 0) +++ include/stratixII.h (.../branches/exsw6000) (revision 69) @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2007 + * Eran Liberty, Extricom, eran.liberty@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#ifndef _STRATIXII_H_ +#define _STRATIXII_H_ + +extern int StratixII_load (Altera_desc * desc, void *image, size_t size); +extern int StratixII_dump (Altera_desc * desc, void *buf, size_t bsize); +extern int StratixII_info (Altera_desc * desc); +extern int StratixII_reloc (Altera_desc * desc, ulong reloc_off); + +#endif /* _STRATIXII_H_ */ Index: common/Makefile =================================================================== --- common/Makefile (.../tags/trunk/20070620_2_merge_to_exsw6000) (revision 69) +++ common/Makefile (.../branches/exsw6000) (revision 69) @@ -27,7 +27,8 @@
AOBJS =
-COBJS = main.o ACEX1K.o altera.o bedbug.o circbuf.o cmd_autoscript.o \ +COBJS = main.o ACEX1K.o altera.o stratixII.o \ + bedbug.o circbuf.o cmd_autoscript.o \ cmd_bdinfo.o cmd_bedbug.o cmd_bmp.o cmd_boot.o cmd_bootm.o \ cmd_cache.o cmd_console.o \ cmd_date.o cmd_dcr.o cmd_diag.o cmd_display.o cmd_doc.o cmd_dtt.o \
Mostly looks okay; except for how it's hooked into the fpga command. Comments below.
g.
- (C) Copyright 2007
- Eran Liberty, Extricom , eran.liberty@gmail.com
- (C) Copyright 2003
- Steven Scholz, imc Measurement & Control, steven.scholz@imc-berlin.de
__FUNCTION__);
+#else
__FUNCTION__);
break;
Yuck; I wouldn't do this. Dump the else and put the 'case' inside the conditional (and fix Altera_ACEX1K while you're at it). Otherwise you're adding size to all boards which use altera.c for no real benefit.
__FUNCTION__);
+#else
__FUNCTION__);
break; default: printf ("%s: Unsupported family type, %d\n",
break;
I think all this stuff should really be table driven (instead of using switch statements). You should create a structure containing the relevant strings & functions, and statically populate it based on what support is configured in.
break;
+#else
__FUNCTION__);
Ditto: dump the else clause
+#else
__FUNCTION__);
break;
case Altera_CYC2:
@@ -249,4 +301,4 @@
Unneeded whitespace churn
- See include/xilinx.h for another working example.
+typedef struct {
Altera_pre_fn pre;
Altera_clk_fn clk;
- project.
- MA 02111-1307 USA
int secure);
break;
break;
default:
desc->iface);
return ret_val;
break;
default:
desc->iface);
return ret_val;
int i;
void **func_table;
func_table[i] =
return FPGA_FAIL;
int cookie;
int bytecount;
char *buff = buf;
int i;
if (!desc) {
return FPGA_FAIL;
if (!buff) {
return FPGA_FAIL;
if (!bsize) {
return FPGA_FAIL;
printf
return FPGA_FAIL;
if (!
&& fns->abort)) {
printf
return FPGA_FAIL;
if (fns->pre) {
return ret_val;
bytecount = 0;
printf
return FPGA_FAIL;
ndelay (5);
ndelay (5);
ndelay (5);
ndelay (5);
printf ("\b\b\b%02d\%", bytecount * 100 / bsize);
udelay (100);
return FPGA_FAIL;
} else {
if (fns->post) {
return ret_val;
- Eran Liberty, Extricom, eran.liberty@gmail.com
- project.
- MA 02111-1307 USA
AOBJS =
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now. http://sourceforge.net/powerbar/db2/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
I agree. I would not have written that way had it been from cratch. tried to follow the code that was already there.
buttried to follow the alre
g.
__FUNCTION__);
+#else
__FUNCTION__);
break;
Agree! will do.
__FUNCTION__);
+#else
__FUNCTION__);
break;
I do want to convert it to table driven myself. Or in other words, though I basically agree I prefer to ignore it.
break;
+#else
__FUNCTION__);
ok.
+#else
__FUNCTION__);
break;
case Altera_CYC2:
@@ -249,4 +301,4 @@
dont get this one. what do you mean?
+typedef struct {
Altera_pre_fn pre;
Altera_clk_fn clk;
- project.
- MA 02111-1307 USA
int secure);
break;
break;
default:
desc->iface);
return ret_val;
break;
default:
desc->iface);
return ret_val;
int i;
void **func_table;
func_table[i] =
return FPGA_FAIL;
int cookie;
int bytecount;
char *buff = buf;
int i;
if (!desc) {
return FPGA_FAIL;
if (!buff) {
return FPGA_FAIL;
if (!bsize) {
return FPGA_FAIL;
printf
return FPGA_FAIL;
if (!
&& fns->abort)) {
printf
return FPGA_FAIL;
if (fns->pre) {
return ret_val;
bytecount = 0;
printf
return FPGA_FAIL;
ndelay (5);
ndelay (5);
ndelay (5);
ndelay (5);
udelay (100);
return FPGA_FAIL;
} else {
if (fns->post) {
return ret_val;
- project.
- MA 02111-1307 USA
AOBJS =
-- Grant Likely, B.Sc., P.Eng. Secret Lab Technologies Ltd. grant.likely@secretlab.ca (403) 399-0195
Liberty
my mailer had made a mess of it (always blame someone else! preferably someone who cant blame you back)
some of it is not even English...
<disregard>
</disregard>
I do < NOT> want to convert it to table driven myself. Or in other words, though I basically agree I prefer to ignore it.
I think all the rest is ok. (I hope)
Liberty
eran liberty
Grant Likely
