[U-Boot] [PATCH V2] ARM: mach-omap2: omap3: Fix GPIO clocking in SPL
OMAP3_GPIO_x is needed to enable each GPIO bank on the OMAP3 boards. At one point, the #ifdef's were replaced with if CONFIG_IS_ENABLED but this won't work for people who need OMAP3_GPIO_x in SPL since the SPL prefix for this option isn't used in Kconfig. This patch moves the check to #if defined and also makes Kconfig select the banks if CMD_GPIO is used which makes the checks in the code less cumbersome.
Fixes: bd8a9c14c91c ("arm: mach-omap2/omap3/clock.c: Enable all GPIO with CMD_GPIO")
Reported-by: Liam O'Shaughnessy liam.o.shaughnessy@gumstix.com Signed-off-by: Adam Ford aford173@gmail.com --- V2: change if defined(OMAP3_GPIO_x) to include the CONFIG_ prefix
diff --git a/arch/arm/mach-omap2/omap3/Kconfig b/arch/arm/mach-omap2/omap3/Kconfig index e0d02fb4e5..0286b0daa3 100644 --- a/arch/arm/mach-omap2/omap3/Kconfig +++ b/arch/arm/mach-omap2/omap3/Kconfig @@ -3,18 +3,23 @@ if OMAP34XX # We only enable the clocks for the GPIO banks that a given board requies. config OMAP3_GPIO_2 bool + default y if CMD_GPIO
config OMAP3_GPIO_3 bool + default y if CMD_GPIO
config OMAP3_GPIO_4 bool + default y if CMD_GPIO
config OMAP3_GPIO_5 bool + default y if CMD_GPIO
config OMAP3_GPIO_6 bool + default y if CMD_GPIO
choice prompt "OMAP3 board select" diff --git a/arch/arm/mach-omap2/omap3/clock.c b/arch/arm/mach-omap2/omap3/clock.c index 9a03bfa9d3..cb9e91ebc3 100644 --- a/arch/arm/mach-omap2/omap3/clock.c +++ b/arch/arm/mach-omap2/omap3/clock.c @@ -750,23 +750,23 @@ void per_clocks_enable(void) setbits_le32(&prcm_base->iclken_per, 0x00000800); #endif
-#if (CONFIG_IS_ENABLED(OMAP3_GPIO_2) || CONFIG_IS_ENABLED(CMD_GPIO)) +#if defined(CONFIG_OMAP3_GPIO_2) setbits_le32(&prcm_base->fclken_per, 0x00002000); setbits_le32(&prcm_base->iclken_per, 0x00002000); #endif -#if (CONFIG_IS_ENABLED(OMAP3_GPIO_3) || CONFIG_IS_ENABLED(CMD_GPIO)) +#if defined(CONFIG_OMAP3_GPIO_3) setbits_le32(&prcm_base->fclken_per, 0x00004000); setbits_le32(&prcm_base->iclken_per, 0x00004000); #endif -#if (CONFIG_IS_ENABLED(OMAP3_GPIO_4) || CONFIG_IS_ENABLED(CMD_GPIO)) +#if defined(CONFIG_OMAP3_GPIO_4) setbits_le32(&prcm_base->fclken_per, 0x00008000); setbits_le32(&prcm_base->iclken_per, 0x00008000); #endif -#if (CONFIG_IS_ENABLED(OMAP3_GPIO_5) || CONFIG_IS_ENABLED(CMD_GPIO)) +#if defined(CONFIG_OMAP3_GPIO_5) setbits_le32(&prcm_base->fclken_per, 0x00010000); setbits_le32(&prcm_base->iclken_per, 0x00010000); #endif -#if (CONFIG_IS_ENABLED(OMAP3_GPIO_6) || CONFIG_IS_ENABLED(CMD_GPIO)) +#if defined(CONFIG_OMAP3_GPIO_6) setbits_le32(&prcm_base->fclken_per, 0x00020000); setbits_le32(&prcm_base->iclken_per, 0x00020000); #endif
Adam Ford
