[PATCH v2] CI: Add m68k target
Add M5208EVBE board to CI. This does not use default config due to limitations of QEMU emulation, instead the timer is switched from DMA timer to PIT timer and RAMBAR accesses are inhibited.
Local QEMU launch command is as follows: $ qemu-system-m68k -nographic -machine mcf5208evb -cpu m5208 -bios u-boot.bin
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Angelo Dureghello angelo@kernel-space.org Cc: Huan Wang alison.wang@nxp.com Cc: Marek Vasut marek.vasut+renesas@mailbox.org Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com --- V2: Disable CONFIG_MCFTMR using -a ~CONFIG_MCFTMR --- .azure-pipelines.yml | 5 +++++ .gitlab-ci.yml | 8 ++++++++ 2 files changed, 13 insertions(+)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 5594a67d6b5..6452127ff42 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -297,6 +297,11 @@ stages: qemu_arm64: TEST_PY_BD: "qemu_arm64" TEST_PY_TEST_SPEC: "not sleep" + qemu_m68k: + TEST_PY_BD: "M5208EVBE" + TEST_PY_ID: "--id qemu" + TEST_PY_TEST_SPEC: "not sleep and not efi" + OVERRIDE: "-a CONFIG_M68K_QEMU=y -a ~CONFIG_MCFTMR" qemu_malta: TEST_PY_BD: "malta" TEST_PY_ID: "--id qemu" diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 5431bf6011a..a06c2aa4be9 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -355,6 +355,14 @@ qemu_arm64 test.py: TEST_PY_TEST_SPEC: "not sleep" <<: *buildman_and_testpy_dfn
+qemu_m68k test.py: + variables: + TEST_PY_BD: "M5208EVBE" + TEST_PY_ID: "--id qemu" + TEST_PY_TEST_SPEC: "not sleep and not efi" + OVERRIDE: "-a CONFIG_M68K_QEMU=y -a ~CONFIG_MCFTMR" + <<: *buildman_and_testpy_dfn + qemu_malta test.py: variables: TEST_PY_BD: "malta"
Acked-by: Angelo Dureghello angelo@kernel-space.org
qemu_m68k:
+qemu_m68k test.py:
- variables:
- TEST_PY_BD: "M5208EVBE"
- TEST_PY_ID: "--id qemu"
- TEST_PY_TEST_SPEC: "not sleep and not efi"
- OVERRIDE: "-a CONFIG_M68K_QEMU=y -a ~CONFIG_MCFTMR"
- <<: *buildman_and_testpy_dfn
- qemu_malta test.py: variables: TEST_PY_BD: "malta"
Angelo Dureghello
