[U-Boot] [PATCH v10 0/9] Add support for loading FPGA bitstream
This version mainly resolved some comments from Simek in [v9].
This series is working on top of u-boot.git http://git.denx.de/u-boot.git
These patches are required before applying this series of patches 1. [U-Boot,v4] misc: fs_loader: Add support for initializing block device https://patchwork.ozlabs.org/project/uboot/list/?series=89282(done review)
3. [U-Boot] misc: fs_loader: Replace label with DT phandle https://patchwork.ozlabs.org/project/uboot/list/?series=92167(under review)
[v9]: https://www.mail-archive.com/u-boot@lists.denx.de/msg316086.html [v8]: https://www.mail-archive.com/u-boot@lists.denx.de/msg316086.html [v7]: https://www.mail-archive.com/u-boot@lists.denx.de/msg314511.html
Tien Fong Chee (9): ARM: socfpga: Description on FPGA bitstream type and file name for Arria 10 ARM: socfpga: Add default FPGA bitstream fitImage for Arria10 SoCDK ARM: socfpga: Cleaning up the messages ARM: socfpga: Move the watchdog reset to the looping location ARM: socfpga: Add FPGA drivers for Arria 10 FPGA bitstream loading ARM: socfpga: Add the configuration for FPGA SoCFPGA A10 SoCDK spl : socfpga: Implement fpga bitstream loading with socfpga loadfs ARM: socfpga: Synchronize the configuration for A10 SoCDK ARM: socfpga: Increase Malloc pool size to support FAT filesystem in SPL
arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 17 + .../include/mach/fpga_manager_arria10.h | 40 +- arch/arm/mach-socfpga/spl_a10.c | 31 +- board/altera/arria10-socdk/fit_spl_fpga.its | 38 ++ configs/socfpga_arria10_defconfig | 21 +- .../fpga/altera-socfpga-a10-fpga-mgr.txt | 26 +- drivers/fpga/socfpga_arria10.c | 514 ++++++++++++++++++++- include/configs/socfpga_common.h | 4 +- include/image.h | 4 + 9 files changed, 663 insertions(+), 32 deletions(-) create mode 100644 board/altera/arria10-socdk/fit_spl_fpga.its
This patch adds description on properties about file name used for both peripheral bitstream and core bitstream.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com
changes for v8 - Removed explanation about support for altr,bitstream-core
changes for v7 - Provided example of setting FPGA FIT image for both early IO release and full release FPGA configuration. --- .../fpga/altera-socfpga-a10-fpga-mgr.txt | 26 +++++++++++++++++++++- 1 file changed, 25 insertions(+), 1 deletion(-)
diff --git a/doc/device-tree-bindings/fpga/altera-socfpga-a10-fpga-mgr.txt b/doc/device-tree-bindings/fpga/altera-socfpga-a10-fpga-mgr.txt index 2fd8e7a847..da210bfc86 100644 --- a/doc/device-tree-bindings/fpga/altera-socfpga-a10-fpga-mgr.txt +++ b/doc/device-tree-bindings/fpga/altera-socfpga-a10-fpga-mgr.txt @@ -7,8 +7,31 @@ Required properties: - The second index is for writing FPGA configuration data. - resets : Phandle and reset specifier for the device's reset. - clocks : Clocks used by the device. +- altr,bitstream : Fit image file name for both FPGA peripheral bitstream, + FPGA core bitstream and full bitstream.
-Example: + Full bitstream, consist of peripheral bitstream and core + bitstream. + + FPGA peripheral bitstream is used to initialize FPGA IOs, + PLL, IO48 and DDR. This bitstream is required to get DDR up + running. + + FPGA core bitstream contains FPGA design which is used to + program FPGA CRAM and ERAM. + +Example: Bundles both peripheral bitstream and core bitstream into FIT image + called fit_spl_fpga.itb. This FIT image can be created through running + this command: tools/mkimage + -E -p 400 + -f board/altera/arria10-socdk/fit_spl_fpga.its + fit_spl_fpga.itb + + For details of describing structure and contents of the FIT image, + please refer board/altera/arria10-socdk/fit_spl_fpga.its + +- Examples for booting with full release or booting with early IO release, then + follow by entering early user mode:
fpga_mgr: fpga-mgr@ffd03000 { compatible = "altr,socfpga-a10-fpga-mgr"; @@ -16,4 +39,5 @@ Example: 0xffcfe400 0x20>; clocks = <&l4_mp_clk>; resets = <&rst FPGAMGR_RESET>; + altr,bitstream = "fit_spl_fpga.itb"; };
Add default fitImage file bundling FPGA bitstreams for Arria10.
changes for v10 - Replaced both periph anc core image nodes "@1" and "@2" with "-1", the numeric associates the core and periph images in case where there are multiple.
changes for v9 - Reordered the images and fpga configurations. - Removed the load property at core image.
changes for v8 - Changed the FPGA node name to fpga-core and fpga-periph for both core and periph bitstreams respectively. --- board/altera/arria10-socdk/fit_spl_fpga.its | 38 +++++++++++++++++++++++++++++ 1 file changed, 38 insertions(+) create mode 100644 board/altera/arria10-socdk/fit_spl_fpga.its
diff --git a/board/altera/arria10-socdk/fit_spl_fpga.its b/board/altera/arria10-socdk/fit_spl_fpga.its new file mode 100644 index 0000000000..adae997213 --- /dev/null +++ b/board/altera/arria10-socdk/fit_spl_fpga.its @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0 + /* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + * + */ + +/dts-v1/; + +/ { + description = "FIT image with FPGA bistream"; + #address-cells = <1>; + + images { + fpga-periph-1 { + description = "FPGA peripheral bitstream"; + data = /incbin/("../../../ghrd_10as066n2.periph.rbf"); + type = "fpga"; + arch = "arm"; + compression = "none"; + }; + + fpga-core-1 { + description = "FPGA core bitstream"; + data = /incbin/("../../../ghrd_10as066n2.core.rbf"); + type = "fpga"; + arch = "arm"; + compression = "none"; + }; + }; + + configurations { + default = "config-1"; + config-1 { + description = "Boot with FPGA early IO release config"; + fpga = "fpga-periph-1", "fpga-core-1"; + }; + }; +};
Ensure the comment and debug messages are always consistent with the rest.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- drivers/fpga/socfpga_arria10.c | 13 +++++++------ 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/drivers/fpga/socfpga_arria10.c b/drivers/fpga/socfpga_arria10.c index 114dd910ab..b0abe1955c 100644 --- a/drivers/fpga/socfpga_arria10.c +++ b/drivers/fpga/socfpga_arria10.c @@ -94,7 +94,7 @@ int fpgamgr_wait_early_user_mode(void) i++; }
- debug("Additional %i sync word needed\n", i); + debug("FPGA: Additional %i sync word needed\n", i);
/* restoring original CDRATIO */ fpgamgr_set_cd_ratio(cd_ratio); @@ -172,9 +172,10 @@ static int fpgamgr_set_cdratio_cdwidth(unsigned int cfg_width, u32 *rbf_data, compress = (rbf_data[COMPRESSION_OFFSET] >> 1) & 1; compress = !compress;
- debug("header word %d = %08x\n", 69, rbf_data[69]); - debug("header word %d = %08x\n", 229, rbf_data[229]); - debug("read from rbf header: encrypt=%d compress=%d\n", encrypt, compress); + debug("FPGA: Header word %d = %08x.\n", 69, rbf_data[69]); + debug("FPGA: Header word %d = %08x.\n", 229, rbf_data[229]); + debug("FPGA: Read from rbf header: encrypt=%d compress=%d.\n", encrypt, + compress);
/* * from the register map description of cdratio in imgcfg_ctrl_02: @@ -455,10 +456,10 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) { int status;
- /* disable all signals from hps peripheral controller to fpga */ + /* Disable all signals from hps peripheral controller to fpga */ writel(0, &system_manager_base->fpgaintf_en_global);
- /* disable all axi bridge (hps2fpga, lwhps2fpga & fpga2hps) */ + /* Disable all axi bridge (hps2fpga, lwhps2fpga & fpga2hps) */ socfpga_bridges_reset();
/* Initialize the FPGA Manager */
Ensure the watchdog is reset timely if the looping is long.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- drivers/fpga/socfpga_arria10.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/fpga/socfpga_arria10.c b/drivers/fpga/socfpga_arria10.c index b0abe1955c..9499d1a014 100644 --- a/drivers/fpga/socfpga_arria10.c +++ b/drivers/fpga/socfpga_arria10.c @@ -360,6 +360,7 @@ static int fpgamgr_program_poll_cd(void) printf("nstatus == 0 while waiting for condone\n"); return -EPERM; } + WATCHDOG_RESET(); }
if (i == FPGA_TIMEOUT_CNT) @@ -433,7 +434,6 @@ int fpgamgr_program_finish(void) printf("FPGA: Poll CD failed with error code %d\n", status); return -EPERM; } - WATCHDOG_RESET();
/* Ensure the FPGA entering user mode */ status = fpgamgr_program_poll_usermode();
Add FPGA driver to support program FPGA with FPGA bitstream loading from filesystem. The driver are designed based on generic firmware loader framework. The driver can handle FPGA program operation from loading FPGA bitstream in flash to memory and then to program FPGA.
changes for v10 -Cleaned up the codes. -Return -EPERM when programing core on non early IO release mode. -Using live function to get rid of gd-> -Removed @0 for fs-loader node
changes for v9 - Support data offset - Added default DDR load address - Squashed the image.h - Changed to phandle - Ensure the DDR is fully up running by checking the gd->ram
changes for v8 - Added codes to discern bitstream type based on fpga node name.
changes for v7 - Restructure the FPGA driver to support both peripheral bitstream and core bitstream bundled into FIT image. - Support loadable property for core bitstream. User can set loadable in DDR for better performance. This loading would be done in one large chunk instead of chunk by chunk loading with small memory buffer. --- arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts | 17 + .../include/mach/fpga_manager_arria10.h | 39 +- drivers/fpga/socfpga_arria10.c | 497 ++++++++++++++++++++- include/image.h | 4 + 4 files changed, 542 insertions(+), 15 deletions(-)
diff --git a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts index 998d811210..cc761967c7 100644 --- a/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts +++ b/arch/arm/dts/socfpga_arria10_socdk_sdmmc.dts @@ -18,6 +18,23 @@ /dts-v1/; #include "socfpga_arria10_socdk.dtsi"
+/ { + chosen { + firmware-loader = <&fs_loader0>; + }; + + fs_loader0: fs-loader { + u-boot,dm-pre-reloc; + compatible = "u-boot,fs-loader"; + phandlepart = <&mmc 1>; + }; +}; + +&fpga_mgr { + u-boot,dm-pre-reloc; + altr,bitstream = "fit_spl_fpga.itb"; +}; + &mmc { u-boot,dm-pre-reloc; status = "okay"; diff --git a/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h index 09d13f6fd3..c5f67714aa 100644 --- a/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h @@ -1,9 +1,13 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (C) 2017 Intel Corporation <www.intel.com> + * Copyright (C) 2017-2019 Intel Corporation <www.intel.com> * All rights reserved. */
+#include <asm/cache.h> +#include <altera.h> +#include <image.h> + #ifndef _FPGA_MANAGER_ARRIA10_H_ #define _FPGA_MANAGER_ARRIA10_H_
@@ -51,6 +55,10 @@ #define ALT_FPGAMGR_IMGCFG_CTL_02_CFGWIDTH_SET_MSK BIT(24) #define ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_LSB 16
+#define FPGA_SOCFPGA_A10_RBF_UNENCRYPTED 0xa65c +#define FPGA_SOCFPGA_A10_RBF_ENCRYPTED 0xa65d +#define FPGA_SOCFPGA_A10_RBF_PERIPH 0x0001 +#define FPGA_SOCFPGA_A10_RBF_CORE 0x8001 #ifndef __ASSEMBLY__
struct socfpga_fpga_manager { @@ -88,12 +96,39 @@ struct socfpga_fpga_manager { u32 imgcfg_fifo_status; };
+enum rbf_type { + unknown, + periph_section, + core_section +}; + +enum rbf_security { + invalid, + unencrypted, + encrypted +}; + +struct rbf_info { + enum rbf_type section; + enum rbf_security security; +}; + +struct fpga_loadfs_info { + fpga_fs_info *fpga_fsinfo; + u32 remaining; + u32 offset; + struct rbf_info rbfinfo; +}; + /* Functions */ int fpgamgr_program_init(u32 * rbf_data, size_t rbf_size); int fpgamgr_program_finish(void); int is_fpgamgr_user_mode(void); int fpgamgr_wait_early_user_mode(void); - +const char *get_fpga_filename(void); +int socfpga_loadfs(fpga_fs_info *fpga_fsinfo, const void *buf, size_t bsize, + u32 offset); +void fpgamgr_program(const void *buf, size_t bsize, u32 offset); #endif /* __ASSEMBLY__ */
#endif /* _FPGA_MANAGER_ARRIA10_H_ */ diff --git a/drivers/fpga/socfpga_arria10.c b/drivers/fpga/socfpga_arria10.c index 9499d1a014..9df2c430d7 100644 --- a/drivers/fpga/socfpga_arria10.c +++ b/drivers/fpga/socfpga_arria10.c @@ -1,8 +1,7 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2017 Intel Corporation <www.intel.com> + * Copyright (C) 2017-2019 Intel Corporation <www.intel.com> */ - #include <asm/io.h> #include <asm/arch/fpga_manager.h> #include <asm/arch/reset_manager.h> @@ -10,8 +9,11 @@ #include <asm/arch/sdram.h> #include <asm/arch/misc.h> #include <altera.h> +#include <asm/arch/pinmux.h> #include <common.h> +#include <dm/ofnode.h> #include <errno.h> +#include <fs_loader.h> #include <wait_bit.h> #include <watchdog.h>
@@ -21,6 +23,9 @@ #define COMPRESSION_OFFSET 229 #define FPGA_TIMEOUT_MSEC 1000 /* timeout in ms */ #define FPGA_TIMEOUT_CNT 0x1000000 +#define DEFAULT_DDR_LOAD_ADDRESS 0x400 + +DECLARE_GLOBAL_DATA_PTR;
static const struct socfpga_fpga_manager *fpga_manager_base = (void *)SOCFPGA_FPGAMGRREGS_ADDRESS; @@ -448,13 +453,461 @@ int fpgamgr_program_finish(void) return 0; }
-/* - * FPGA Manager to program the FPGA. This is the interface used by FPGA driver. - * Return 0 for sucess, non-zero for error. - */ +ofnode get_fpga_mgr_ofnode(ofnode from) +{ + return ofnode_by_compatible(from, "altr,socfpga-a10-fpga-mgr"); +} + +const char *get_fpga_filename(void) +{ + const char *fpga_filename = NULL; + + ofnode fpgamgr_node = get_fpga_mgr_ofnode(ofnode_null()); + + if (ofnode_valid(fpgamgr_node)) + fpga_filename = ofnode_read_string(fpgamgr_node, + "altr,bitstream"); + + return fpga_filename; +} + +static void get_rbf_image_info(struct rbf_info *rbf, u16 *buffer) +{ + /* + * Magic ID starting at: + * -> 1st dword[15:0] in periph.rbf + * -> 2nd dword[15:0] in core.rbf + * Note: dword == 32 bits + */ + u32 word_reading_max = 2; + u32 i; + + for (i = 0; i < word_reading_max; i++) { + if (*(buffer + i) == FPGA_SOCFPGA_A10_RBF_UNENCRYPTED) { + rbf->security = unencrypted; + } else if (*(buffer + i) == FPGA_SOCFPGA_A10_RBF_ENCRYPTED) { + rbf->security = encrypted; + } else if (*(buffer + i + 1) == + FPGA_SOCFPGA_A10_RBF_UNENCRYPTED) { + rbf->security = unencrypted; + } else if (*(buffer + i + 1) == + FPGA_SOCFPGA_A10_RBF_ENCRYPTED) { + rbf->security = encrypted; + } else { + rbf->security = invalid; + continue; + } + + /* PERIPH RBF(buffer + i + 1), CORE RBF(buffer + i + 2) */ + if (*(buffer + i + 1) == FPGA_SOCFPGA_A10_RBF_PERIPH) { + rbf->section = periph_section; + break; + } else if (*(buffer + i + 1) == FPGA_SOCFPGA_A10_RBF_CORE) { + rbf->section = core_section; + break; + } else if (*(buffer + i + 2) == FPGA_SOCFPGA_A10_RBF_PERIPH) { + rbf->section = periph_section; + break; + } else if (*(buffer + i + 2) == FPGA_SOCFPGA_A10_RBF_CORE) { + rbf->section = core_section; + break; + } + + rbf->section = unknown; + break; + + WATCHDOG_RESET(); + } +} + +#ifdef CONFIG_FS_LOADER +static int first_loading_rbf_to_buffer(struct udevice *dev, + struct fpga_loadfs_info *fpga_loadfs, + u32 *buffer, size_t *buffer_bsize) +{ + u32 *buffer_p = (u32 *)*buffer; + u32 *loadable = buffer_p; + size_t buffer_size = *buffer_bsize; + size_t fit_size; + int ret, i, count, confs_noffset, images_noffset, rbf_offset, rbf_size; + const char *fpga_node_name = NULL; + const char *uname = NULL; + + /* Load image header into buffer */ + ret = request_firmware_into_buf(dev, + fpga_loadfs->fpga_fsinfo->filename, + buffer_p, sizeof(struct image_header), + 0); + if (ret < 0) { + debug("FPGA: Failed to read image header from flash.\n"); + return -ENOENT; + } + + if (image_get_magic((struct image_header *)buffer_p) != FDT_MAGIC) { + debug("FPGA: No FDT magic was found.\n"); + return -EBADF; + } + + fit_size = fdt_totalsize(buffer_p); + + if (fit_size > buffer_size) { + debug("FPGA: FIT image is larger than available buffer.\n"); + debug("Please use FIT external data or increasing buffer.\n"); + return -ENOMEM; + } + + /* Load entire FIT into buffer */ + ret = request_firmware_into_buf(dev, + fpga_loadfs->fpga_fsinfo->filename, + buffer_p, fit_size, 0); + if (ret < 0) + return ret; + + ret = fit_check_format(buffer_p); + if (!ret) { + debug("FPGA: No valid FIT image was found.\n"); + return -EBADF; + } + + confs_noffset = fdt_path_offset(buffer_p, FIT_CONFS_PATH); + images_noffset = fdt_path_offset(buffer_p, FIT_IMAGES_PATH); + if (confs_noffset < 0 || images_noffset < 0) { + debug("FPGA: No Configurations or images nodes were found.\n"); + return -ENOENT; + } + + /* Get default configuration unit name from default property */ + confs_noffset = fit_conf_get_node(buffer_p, NULL); + if (confs_noffset < 0) { + debug("FPGA: No default configuration was found in config.\n"); + return -ENOENT; + } + + count = fit_conf_get_prop_node_count(buffer_p, confs_noffset, + FIT_FPGA_PROP); + if (count < 0) { + debug("FPGA: Invalid configuration format for FPGA node.\n"); + return count; + } + debug("FPGA: FPGA node count: %d\n", count); + + for (i = 0; i < count; i++) { + images_noffset = fit_conf_get_prop_node_index(buffer_p, + confs_noffset, + FIT_FPGA_PROP, i); + uname = fit_get_name(buffer_p, images_noffset, NULL); + if (uname) { + debug("FPGA: %s\n", uname); + + if (strstr(uname, "fpga-periph") && + (!is_fpgamgr_early_user_mode() || + is_fpgamgr_user_mode())) { + fpga_node_name = uname; + printf("FPGA: Start to program "); + printf("peripheral/full bitstream ...\n"); + break; + } else if (strstr(uname, "fpga-core") && + (is_fpgamgr_early_user_mode() && + !is_fpgamgr_user_mode())) { + fpga_node_name = uname; + printf("FPGA: Start to program core "); + printf("bitstream ...\n"); + break; + } + } + WATCHDOG_RESET(); + } + + if (!fpga_node_name) { + debug("FPGA: No suitable bitstream was found, count: %d.\n", i); + return 1; + } + + images_noffset = fit_image_get_node(buffer_p, fpga_node_name); + if (images_noffset < 0) { + debug("FPGA: No node '%s' was found in FIT.\n", + fpga_node_name); + return -ENOENT; + } + + if (!fit_image_get_data_position(buffer_p, images_noffset, + &rbf_offset)) { + debug("FPGA: Data position was found.\n"); + } else if (!fit_image_get_data_offset(buffer_p, images_noffset, + &rbf_offset)) { + /* + * For FIT with external data, figure out where + * the external images start. This is the base + * for the data-offset properties in each image. + */ + rbf_offset += ((fdt_totalsize(buffer_p) + 3) & ~3); + debug("FPGA: Data offset was found.\n"); + } else { + debug("FPGA: No data position/offset was found.\n"); + return -ENOENT; + } + + ret = fit_image_get_data_size(buffer_p, images_noffset, &rbf_size); + if (ret < 0) { + debug("FPGA: No data size was found (err=%d).\n", ret); + return -ENOENT; + } + + if (gd->ram_size < rbf_size) { + debug("FPGA: Using default OCRAM buffer and size.\n"); + } else { + ret = fit_image_get_load(buffer_p, images_noffset, + (ulong *)loadable); + if (ret < 0) { + buffer_p = (u32 *)DEFAULT_DDR_LOAD_ADDRESS; + debug("FPGA: No loadable was found.\n"); + debug("FPGA: Using default DDR load address: 0x%x .\n", + DEFAULT_DDR_LOAD_ADDRESS); + } else { + buffer_p = (u32 *)*loadable; + debug("FPGA: Found loadable address = 0x%x.\n", + *loadable); + } + + buffer_size = rbf_size; + } + + debug("FPGA: External data: offset = 0x%x, size = 0x%x.\n", + rbf_offset, rbf_size); + + fpga_loadfs->remaining = rbf_size; + + /* + * Determine buffer size vs bitstream size, and calculating number of + * chunk by chunk transfer is required due to smaller buffer size + * compare to bitstream + */ + if (rbf_size <= buffer_size) { + /* Loading whole bitstream into buffer */ + buffer_size = rbf_size; + fpga_loadfs->remaining = 0; + } else { + fpga_loadfs->remaining -= buffer_size; + } + + fpga_loadfs->offset = rbf_offset; + /* Loading bitstream into buffer */ + ret = request_firmware_into_buf(dev, + fpga_loadfs->fpga_fsinfo->filename, + buffer_p, buffer_size, + fpga_loadfs->offset); + if (ret < 0) { + debug("FPGA: Failed to read bitstream from flash.\n"); + return -ENOENT; + } + + /* Getting info about bitstream types */ + get_rbf_image_info(&fpga_loadfs->rbfinfo, (u16 *)buffer_p); + + /* Update next reading bitstream offset */ + fpga_loadfs->offset += buffer_size; + + /* Update the final addr for bitstream */ + *buffer = (u32)buffer_p; + + /* Update the size of bitstream to be programmed into FPGA */ + *buffer_bsize = buffer_size; + + return 0; +} + +static int subsequent_loading_rbf_to_buffer(struct udevice *dev, + struct fpga_loadfs_info *fpga_loadfs, + u32 *buffer, size_t *buffer_bsize) +{ + int ret = 0; + u32 *buffer_p = (u32 *)*buffer; + + /* Read the bitstream chunk by chunk. */ + if (fpga_loadfs->remaining > *buffer_bsize) { + fpga_loadfs->remaining -= *buffer_bsize; + } else { + *buffer_bsize = fpga_loadfs->remaining; + fpga_loadfs->remaining = 0; + } + + ret = request_firmware_into_buf(dev, + fpga_loadfs->fpga_fsinfo->filename, + buffer_p, *buffer_bsize, + fpga_loadfs->offset); + if (ret < 0) { + debug("FPGA: Failed to read bitstream from flash.\n"); + return -ENOENT; + } + + /* Update next reading bitstream offset */ + fpga_loadfs->offset += *buffer_bsize; + + return 0; +} + +int socfpga_loadfs(fpga_fs_info *fpga_fsinfo, const void *buf, size_t bsize, + u32 offset) +{ + struct fpga_loadfs_info fpga_loadfs; + struct udevice *dev; + int status, ret, size; + u32 buffer = (uintptr_t)buf; + size_t buffer_sizebytes = bsize; + size_t buffer_sizebytes_ori = bsize; + size_t total_sizeof_image = 0; + ofnode node; + const fdt32_t *phandle_p; + u32 phandle; + + node = get_fpga_mgr_ofnode(ofnode_null()); + + if (ofnode_valid(node)) { + phandle_p = ofnode_get_property(node, "firmware-loader", &size); + if (!phandle_p) { + node = ofnode_path("/chosen"); + if (!ofnode_valid(node)) { + debug("FPGA: /chosen node was not found.\n"); + return -ENOENT; + } + + phandle_p = ofnode_get_property(node, "firmware-loader", + &size); + if (!phandle_p) { + debug("FPGA: firmware-loader property was not"); + debug(" found.\n"); + return -ENOENT; + } + } + } else { + debug("FPGA: FPGA manager node was not found.\n"); + return -ENOENT; + } + + phandle = fdt32_to_cpu(*phandle_p); + ret = uclass_get_device_by_phandle_id(UCLASS_FS_FIRMWARE_LOADER, + phandle, &dev); + if (ret) + return ret; + + memset(&fpga_loadfs, 0, sizeof(fpga_loadfs)); + + fpga_loadfs.fpga_fsinfo = fpga_fsinfo; + fpga_loadfs.offset = offset; + + printf("FPGA: Checking FPGA configuration setting ...\n"); + + /* + * Note: Both buffer and buffer_sizebytes values can be altered by + * function below. + */ + ret = first_loading_rbf_to_buffer(dev, &fpga_loadfs, &buffer, + &buffer_sizebytes); + if (ret == 1) { + printf("FPGA: Skipping configuration ...\n"); + return 0; + } else if (ret) { + return ret; + } + + if (fpga_loadfs.rbfinfo.section == core_section && + !(is_fpgamgr_early_user_mode() && !is_fpgamgr_user_mode())) { + debug("FPGA : Must be in Early Release mode to program "); + debug("core bitstream.\n"); + return -EPERM; + } + + /* Disable all signals from HPS peripheral controller to FPGA */ + writel(0, &system_manager_base->fpgaintf_en_global); + + /* Disable all axi bridges (hps2fpga, lwhps2fpga & fpga2hps) */ + socfpga_bridges_reset(); + + if (fpga_loadfs.rbfinfo.section == periph_section) { + /* Initialize the FPGA Manager */ + status = fpgamgr_program_init((u32 *)buffer, buffer_sizebytes); + if (status) { + debug("FPGA: Init with peripheral bitstream failed.\n"); + return -EPERM; + } + } + + /* Transfer bitstream to FPGA Manager */ + fpgamgr_program_write((void *)buffer, buffer_sizebytes); + + total_sizeof_image += buffer_sizebytes; + + while (fpga_loadfs.remaining) { + ret = subsequent_loading_rbf_to_buffer(dev, + &fpga_loadfs, + &buffer, + &buffer_sizebytes_ori); + + if (ret) + return ret; + + /* Transfer data to FPGA Manager */ + fpgamgr_program_write((void *)buffer, + buffer_sizebytes_ori); + + total_sizeof_image += buffer_sizebytes_ori; + + WATCHDOG_RESET(); + } + + if (fpga_loadfs.rbfinfo.section == periph_section) { + if (fpgamgr_wait_early_user_mode() != -ETIMEDOUT) { + config_pins(gd->fdt_blob, "shared"); + puts("FPGA: Early Release Succeeded.\n"); + } else { + debug("FPGA: Failed to see Early Release.\n"); + return -EIO; + } + + /* For monolithic bitstream */ + if (is_fpgamgr_user_mode()) { + /* Ensure the FPGA entering config done */ + status = fpgamgr_program_finish(); + if (status) + return status; + + config_pins(gd->fdt_blob, "fpga"); + puts("FPGA: Enter user mode.\n"); + } + } else if (fpga_loadfs.rbfinfo.section == core_section) { + /* Ensure the FPGA entering config done */ + status = fpgamgr_program_finish(); + if (status) + return status; + + config_pins(gd->fdt_blob, "fpga"); + puts("FPGA: Enter user mode.\n"); + } else { + debug("FPGA: Config Error: Unsupported bitstream type.\n"); + return -ENOEXEC; + } + + return (int)total_sizeof_image; +} + +void fpgamgr_program(const void *buf, size_t bsize, u32 offset) +{ + fpga_fs_info fpga_fsinfo; + + fpga_fsinfo.filename = get_fpga_filename(); + + if (fpga_fsinfo.filename) + socfpga_loadfs(&fpga_fsinfo, buf, bsize, offset); +} +#endif + +/* This function is used to load the core bitstream from the OCRAM. */ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) { - int status; + unsigned long status; + struct rbf_info rbfinfo; + + memset(&rbfinfo, 0, sizeof(rbfinfo));
/* Disable all signals from hps peripheral controller to fpga */ writel(0, &system_manager_base->fpgaintf_en_global); @@ -462,13 +915,31 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) /* Disable all axi bridge (hps2fpga, lwhps2fpga & fpga2hps) */ socfpga_bridges_reset();
- /* Initialize the FPGA Manager */ - status = fpgamgr_program_init((u32 *)rbf_data, rbf_size); - if (status) - return status; + /* Getting info about bitstream types */ + get_rbf_image_info(&rbfinfo, (u16 *)rbf_data); + + if (rbfinfo.section == periph_section) { + /* Initialize the FPGA Manager */ + status = fpgamgr_program_init((u32 *)rbf_data, rbf_size); + if (status) + return status; + }
- /* Write the RBF data to FPGA Manager */ + if (rbfinfo.section == core_section && + !(is_fpgamgr_early_user_mode() && !is_fpgamgr_user_mode())) { + debug("FPGA : Must be in early release mode to program "); + debug("core bitstream.\n"); + return -EPERM; + } + + /* Write the bitstream to FPGA Manager */ fpgamgr_program_write(rbf_data, rbf_size);
- return fpgamgr_program_finish(); + status = fpgamgr_program_finish(); + if (status) { + config_pins(gd->fdt_blob, "fpga"); + puts("FPGA: Enter user mode.\n"); + } + + return status; } diff --git a/include/image.h b/include/image.h index 83a2d412c9..f839443c3f 100644 --- a/include/image.h +++ b/include/image.h @@ -1041,6 +1041,10 @@ int fit_check_format(const void *fit);
int fit_conf_find_compat(const void *fit, const void *fdt); int fit_conf_get_node(const void *fit, const char *conf_uname); +int fit_conf_get_prop_node_count(const void *fit, int noffset, + const char *prop_name); +int fit_conf_get_prop_node_index(const void *fit, int noffset, + const char *prop_name, int index);
/** * fit_conf_get_prop_node() - Get node refered to by a configuration
Update the default configuration file to enable the necessary functionality to get the SoCFPGA loadfs driver support. This would enable the implementation of programming bitstream into FPGA from MMC.
changes for v8 - Added FIT related configs
changes for v7 - Removed limit set for CONFIG_FS_FAT_MAX_CLUSTSIZE --- configs/socfpga_arria10_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 0554f1b6ec..c870543346 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -27,10 +27,18 @@ CONFIG_MTDIDS_DEFAULT="nor0=ff705000.spi.0" # CONFIG_EFI_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria10_socdk_sdmmc" CONFIG_ENV_IS_IN_MMC=y +CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_DM_MMC=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_FS_FAT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_FS_LOADER=y CONFIG_FPGA_SOCFPGA=y +CONFIG_SPL_FIT=y +CONFIG_FIT=y CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y
Add support for loading FPGA bitstream to get DDR up running before U-Boot is loaded into DDR. Boot device initialization, generic firmware loader and SPL FAT support are required for this whole mechanism to work.
changes for v10 - Removed the static so the function can be referred by other c file.
changes for v9 - Used ALLOC_CACHE_ALIGN_BUFFER - De-duplicated the same chunks of codes
changes for v7 - Removed casting for get_fpga_filename - Removed hard coding DDR address for loading core bistream, using loadable property from FIT. - Added checking for config_pins, return if error.
# Conflicts: # arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h --- .../include/mach/fpga_manager_arria10.h | 1 + arch/arm/mach-socfpga/spl_a10.c | 31 +++++++++++++++++++++- drivers/fpga/socfpga_arria10.c | 2 +- 3 files changed, 32 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h index c5f67714aa..62249b3695 100644 --- a/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/fpga_manager_arria10.h @@ -126,6 +126,7 @@ int fpgamgr_program_finish(void); int is_fpgamgr_user_mode(void); int fpgamgr_wait_early_user_mode(void); const char *get_fpga_filename(void); +int is_fpgamgr_early_user_mode(void); int socfpga_loadfs(fpga_fs_info *fpga_fsinfo, const void *buf, size_t bsize, u32 offset); void fpgamgr_program(const void *buf, size_t bsize, u32 offset); diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index c97eacb424..4b658c87a3 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2019 Altera Corporation <www.altera.com> */
#include <common.h> @@ -23,6 +23,11 @@ #include <fdtdec.h> #include <watchdog.h> #include <asm/arch/pinmux.h> +#include <asm/arch/fpga_manager.h> +#include <mmc.h> +#include <memalign.h> + +#define FPGA_BUFSIZ 16 * 1024
@@ -68,11 +73,35 @@ u32 spl_boot_mode(const u32 boot_device)
void spl_board_init(void) { + ALLOC_CACHE_ALIGN_BUFFER(char, buf, FPGA_BUFSIZ); + /* enable console uart printing */ preloader_console_init(); WATCHDOG_RESET();
arch_early_init_r(); + + /* If the full FPGA is already loaded, ie.from EPCQ, config fpga pins */ + if (is_fpgamgr_user_mode()) { + int ret = config_pins(gd->fdt_blob, "shared"); + + if (ret) + return; + + ret = config_pins(gd->fdt_blob, "fpga"); + if (ret) + return; + } else if (!is_fpgamgr_early_user_mode()) { + /* Program IOSSM(early IO release) or full FPGA */ + fpgamgr_program(buf, FPGA_BUFSIZ, 0); + } + + /* If the IOSSM/full FPGA is already loaded, start DDR */ + if (is_fpgamgr_early_user_mode() || is_fpgamgr_user_mode()) + ddr_calibration_sequence(); + + if (!is_fpgamgr_user_mode()) + fpgamgr_program(buf, FPGA_BUFSIZ, 0); }
void board_init_f(ulong dummy) diff --git a/drivers/fpga/socfpga_arria10.c b/drivers/fpga/socfpga_arria10.c index 9df2c430d7..285280e507 100644 --- a/drivers/fpga/socfpga_arria10.c +++ b/drivers/fpga/socfpga_arria10.c @@ -69,7 +69,7 @@ static int wait_for_user_mode(void) 1, FPGA_TIMEOUT_MSEC, false); }
-static int is_fpgamgr_early_user_mode(void) +int is_fpgamgr_early_user_mode(void) { return (readl(&fpga_manager_base->imgcfg_stat) & ALT_FPGAMGR_IMGCFG_STAT_F2S_EARLY_USERMODE_SET_MSK) != 0;
Update the default configuration file to enable the necessary functionality the get the kit working.
changes for v8 - Moved the FIT related configs to the patch of configuration for FPGA SoCFPGA A10 SoCDK.
changes for v7 - Keep minimal configs. --- configs/socfpga_arria10_defconfig | 15 +++++++++------ 1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index c870543346..bdbf90ed44 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -10,10 +10,13 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200" # CONFIG_USE_BOOTCOMMAND is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y +CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y +CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y CONFIG_DEFAULT_FDT_FILE="socfpga_arria10_socdk_sdmmc.dtb" +CONFIG_VERSION_VARIABLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_FPGA_SUPPORT=y -CONFIG_SPL_SPI_LOAD=y CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set @@ -22,9 +25,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_MTDIDS_DEFAULT="nor0=ff705000.spi.0" -# CONFIG_SPL_DOS_PARTITION is not set -# CONFIG_ISO_PARTITION is not set -# CONFIG_EFI_PARTITION is not set +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-parent dmas dma-names" CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria10_socdk_sdmmc" CONFIG_ENV_IS_IN_MMC=y CONFIG_SPL_ENV_SUPPORT=y @@ -32,7 +33,6 @@ CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_DM_MMC=y CONFIG_SPL_MMC_SUPPORT=y -CONFIG_SPL_EXT_SUPPORT=y CONFIG_SPL_FS_FAT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_FS_LOADER=y @@ -43,11 +43,14 @@ CONFIG_DM_GPIO=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_MTD_DEVICE=y +CONFIG_MMC_DW=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y +CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_DESIGNWARE_APB_TIMER=y -CONFIG_USE_TINY_PRINTF=y
After some series of patches to maximise reusable of memory pool, here come to result of reasonable size required for whole SDMMC boot working on A10 SoCDK. Size required come from default max cluster(0x10000) + others(0x2000) + additional memory for headroom(0x3000).
changes for v7 - Added 0x3000 for memory headroom. --- include/configs/socfpga_common.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 4551cb29bc..548b458e78 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2019 Altera Corporation <www.altera.com> */ #ifndef __CONFIG_SOCFPGA_COMMON_H__ #define __CONFIG_SOCFPGA_COMMON_H__ @@ -258,7 +258,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) /* SPL memory allocation configuration, this is for FAT implementation */ #ifndef CONFIG_SYS_SPL_MALLOC_START -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00010000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00015000 #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_SPL_MALLOC_SIZE + \ CONFIG_SYS_INIT_RAM_ADDR)
- [U-Boot,v4] misc: fs_loader: Add support for initializing block device
- [U-Boot] misc: fs_loader: Replace label with DT phandle
Is this actually V11 ?
This series is working on top of u-boot.git http://git.denx.de/u-bo ot.git
tml [v8]: https://www.mail-archive.com/u-boot@lists.denx.de/msg316086.h tml [v7]: https://www.mail-archive.com/u-boot@lists.denx.de/msg314511.h tml
Okay.
Chee, Tien Fong
