[U-Boot-Users] Resend : [patch][cvs] A fix in main.c
Hello Thomas,
I misused CONFIG_MENUKEY in my test program and found an error but not quite sure. Pls check it.
BTW, CONFIG_MENUKEY and CONFIG_MENUCOMMAND is only used in the AmigaOneG3SE board, which you maintaine. I didn't see their info in README. Could you pls explain the usage or even better send a patch in README?
Thanks a lot.
Sam
* Patch by Sam Song, 10 October 2004: - Fix a parameter of run_command in main.c
Index: doc/README.autoboot =================================================================== RCS file: /cvsroot/u-boot/u-boot/doc/README.autoboot,v retrieving revision 1.3 diff -p -u -r1.3 README.autoboot --- doc/README.autoboot 14 Jul 2003 22:13:45 -0000 1.3 +++ doc/README.autoboot 10 Oct 2004 00:49:54 -0000 @@ -138,10 +138,10 @@ What they do character of a key string does not appear in the rest of the string.
- Using the CONFIG_AUTOBOOT_DELAY_STR2 / bootdelaykey2 and/or - CONFIG_AUTOBOOT_STOP_STR2 / bootstopkey #defines and/or - environment variables you can specify a second, alternate - string (which allows you to have two "password" strings). + Using the CONFIG_AUTOBOOT_DELAY_STR2 and/or CONFIG_AUTOBOOT_STOP_STR2 + #defines and/or environment variables bootdelaykey2 and/or bootstopkey2, + you can specify a second, alternate string (which allows you to have + the possibility to give the option "password" to your boss:-).
CONFIG_ZERO_BOOTDELAY_CHECK
_________________________________________________________ Do You Yahoo!? 150万曲MP3疯狂搜,带您闯入音乐殿堂 http://music.yisou.com/ 美女明星应有尽有,搜遍美图、艳图和酷图 http://image.yisou.com 1G就是1000兆,雅虎电邮自助扩容! http://cn.rd.yahoo.com/mail_cn/tag/1g/*http://cn.mail.yahoo.com/event/mail_1...
In message 20041010052801.36662.qmail@web15609.mail.cnb.yahoo.com you wrote:
- Patch by Sam Song, 10 October 2004:
Patch broken by mailer wrapping lines, rejected.
Sam Song
