[U-Boot] [PATCH v2] powerpc/t2080qds: some update for t2080qds
- add more serdes protocols support. - fix some serdes lanes route. - fix SGMII doesn't work and incorrect mdio display for XFI when serdes 0x6d. - correct boot location info for SD/SPI boot.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- v2: update to support more serdes, applied in Gerrit sdk.
board/freescale/t2080qds/eth_t2080qds.c | 12 ++++-- board/freescale/t2080qds/t2080qds.c | 66 ++++++++++++++++++++++++++++++--- drivers/net/fm/t2080.c | 10 +++-- 3 files changed, 75 insertions(+), 13 deletions(-)
diff --git a/board/freescale/t2080qds/eth_t2080qds.c b/board/freescale/t2080qds/eth_t2080qds.c index 9a909db..68d74c3 100644 --- a/board/freescale/t2080qds/eth_t2080qds.c +++ b/board/freescale/t2080qds/eth_t2080qds.c @@ -372,9 +372,11 @@ int board_eth_init(bd_t *bis) break; case 0x6c: case 0x6d: + fm_info_set_phy_address(FM1_10GEC1, 4); + fm_info_set_phy_address(FM1_10GEC2, 5); /* SGMII in Slot3 */ fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); break; case 0x71: /* SGMII in Slot3 */ @@ -419,7 +421,6 @@ int board_eth_init(bd_t *bis) fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT2_PHY_ADDR); break; default: - puts("Invalid SerDes1 protocol for T2080QDS\n"); break; }
@@ -449,7 +450,12 @@ int board_eth_init(bd_t *bis) fm_info_set_mdio(i, mii_dev_for_muxval( mdio_mux[i])); break; - }; + case 3: + mdio_mux[i] = EMI1_SLOT3; + fm_info_set_mdio(i, mii_dev_for_muxval( + mdio_mux[i])); + break; + } break; case PHY_INTERFACE_MODE_RGMII: if (i == FM1_DTSEC3) diff --git a/board/freescale/t2080qds/t2080qds.c b/board/freescale/t2080qds/t2080qds.c index cac32fe..4fe8ccb 100644 --- a/board/freescale/t2080qds/t2080qds.c +++ b/board/freescale/t2080qds/t2080qds.c @@ -40,6 +40,11 @@ int checkboard(void) printf("Sys ID: 0x%02x, Board Arch: V%d, ", QIXIS_READ(id), sw >> 4); printf("Board Version: %c, boot from ", (sw & 0xf) + 'A' - 1);
+#ifdef CONFIG_SDCARD + puts("SD/MMC\n"); +#elif CONFIG_SPIFLASH + puts("SPI\n"); +#else sw = QIXIS_READ(brdcfg[0]); sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT;
@@ -51,6 +56,7 @@ int checkboard(void) puts("NAND\n"); else printf("invalid setting of SW%u\n", QIXIS_LBMAP_SWITCH); +#endif
printf("FPGA: v%d (%s), build %d", (int)QIXIS_READ(scver), qixis_read_tag(buf), (int)qixis_read_minor()); @@ -97,13 +103,25 @@ int brd_mux_lane_to_slot(void) /* SerDes1 is not enabled */ break; case 0x1c: - case 0x95: case 0xa2: - case 0x94: /* SD1(A:D) => SLOT3 SGMII * SD1(G:H) => SLOT1 SGMII */ - QIXIS_WRITE(brdcfg[12], 0x58); + QIXIS_WRITE(brdcfg[12], 0x1a); + break; + case 0x94: + case 0x95: + /* SD1(A:B) => SLOT3 SGMII@1.25bps + * SD1(C:D) => SFP Module, SGMII@3.125bps + * SD1(E:H) => SLOT1 SGMII@1.25bps + */ + case 0x96: + /* SD1(A:B) => SLOT3 SGMII@1.25bps + * SD1(C) => SFP Module, SGMII@3.125bps + * SD1(D) => SFP Module, SGMII@1.25bps + * SD1(E:H) => SLOT1 PCIe4 x4 + */ + QIXIS_WRITE(brdcfg[12], 0x3a); break; case 0x51: /* SD1(A:D) => SLOT3 XAUI @@ -134,6 +152,34 @@ int brd_mux_lane_to_slot(void) */ QIXIS_WRITE(brdcfg[12], 0xda); break; + case 0x6e: + /* SD1(A:B) => SFP Module, XFI + * SD1(C:D) => SLOT3 SGMII + * SD1(E:F) => SLOT1 PCIe4 x2 + * SD1(G:H) => SLOT2 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0xd9); + break; + case 0xda: + /* SD1(A:H) => SLOT3 PCIe3 x8 + */ + QIXIS_WRITE(brdcfg[12], 0x0); + break; + case 0xc8: + /* SD1(A) => SLOT3 PCIe3 x1 + * SD1(B) => SFP Module, SGMII@1.25bps + * SD1(C:D) => SFP Module, SGMII@3.125bps + * SD1(E:F) => SLOT1 PCIe4 x2 + * SD1(G:H) => SLOT2 SGMII + */ + QIXIS_WRITE(brdcfg[12], 0x79); + break; + case 0xab: + /* SD1(A:D) => SLOT3 PCIe3 x4 + * SD1(E:H) => SLOT1 PCIe4 x4 + */ + QIXIS_WRITE(brdcfg[12], 0x1a); + break; default: printf("WARNING: unsupported for SerDes1 Protocol %d\n", srds_prtcl_s1); @@ -147,7 +193,7 @@ int brd_mux_lane_to_slot(void) case 0x01: case 0x02: /* SD2(A:H) => SLOT4 PCIe1 */ - QIXIS_WRITE(brdcfg[13], 0x20); + QIXIS_WRITE(brdcfg[13], 0x10); break; case 0x15: case 0x16: @@ -164,7 +210,7 @@ int brd_mux_lane_to_slot(void) * SD2(E:F) => SLOT5 Aurora * SD2(G:H) => SATA1,SATA2 */ - QIXIS_WRITE(brdcfg[13], 0x70); + QIXIS_WRITE(brdcfg[13], 0x78); break; case 0x1f: /* @@ -180,7 +226,15 @@ int brd_mux_lane_to_slot(void) * SD2(A:D) => SLOT4 SRIO2 * SD2(E:H) => SLOT5 SRIO1 */ - QIXIS_WRITE(brdcfg[13], 0x50); + QIXIS_WRITE(brdcfg[13], 0xa0); + break; + case 0x36: + /* + * SD2(A:D) => SLOT4 SRIO2 + * SD2(E:F) => Aurora + * SD2(G:H) => SATA1,SATA2 + */ + QIXIS_WRITE(brdcfg[13], 0x78); break; default: printf("WARNING: unsupported for SerDes2 Protocol %d\n", diff --git a/drivers/net/fm/t2080.c b/drivers/net/fm/t2080.c index b5c1e9f..3b6212f 100644 --- a/drivers/net/fm/t2080.c +++ b/drivers/net/fm/t2080.c @@ -50,15 +50,17 @@ phy_interface_t fman_port_enet_if(enum fm_port port) if (is_device_disabled(port)) return PHY_INTERFACE_MODE_NONE;
- if ((port == FM1_10GEC1 || port == FM1_10GEC2 || - port == FM1_10GEC3 || port == FM1_10GEC4) && + if ((port == FM1_10GEC1 || port == FM1_10GEC2) && ((is_serdes_configured(XAUI_FM1_MAC9)) || - (is_serdes_configured(XFI_FM1_MAC1)) || - (is_serdes_configured(XFI_FM1_MAC2)) || (is_serdes_configured(XFI_FM1_MAC9)) || (is_serdes_configured(XFI_FM1_MAC10)))) return PHY_INTERFACE_MODE_XGMII;
+ if ((port == FM1_10GEC3 || port == FM1_10GEC4) && + ((is_serdes_configured(XFI_FM1_MAC1)) || + (is_serdes_configured(XFI_FM1_MAC2)))) + return PHY_INTERFACE_MODE_XGMII; + if ((port == FM1_DTSEC3) && ((rcwsr13 & FSL_CORENET_RCWSR13_EC1) == FSL_CORENET_RCWSR13_EC1_DTSEC3_RGMII)) return PHY_INTERFACE_MODE_RGMII;
Applied to u-boot-mpc85xx master branch. Awaiting upstream.
York
Shengzhou Liu
York Sun
